Noel C.
Andrea T.
excellent
Rien de spectaculaire...
Vasileios K.
A great dac for the money
WM AUDIO TORNADO Câble Secteur Double Blindage 3x4mm² Ø12.9mm - avis - Il y a 23 avis.
Vladimir S.
Buy and wait for ugly burn-in...you will be more than satisfied.
I mounted the cable to cheap plastic plugs (EU Power Plug 12 euros for 2) 2x1.5m
After 2 weeks of constant burn in I connected the 2 cables to 2 sbooster power supplies to my chord qutest and Auralic Aries
The sound is warmer with a good base foundation without losing resolution, more organic mid-range and the most important: !!! extremely musical and natural sound with a good size of the sound image.
I compared with transparent power cord 500 euros and up and I was not disappointed.
Dimitar C.
Tornado blows expensive ones
Second time purchase this product, first time implementation was in system for 100000Euro the result was amazing, more definition,better separation and wider sound scene(replacement was only for monoblocks).Now expect delivery from Audiophonics to implement on system for 500000Euro and above for all sources, pre amp,phono and monoblocks.For those who are sceptical about power cords, pleace try and then share the experience .Also on system let me say" low quality "it doesn't matter what kind of power cable you are using .
On the second system I and my friend who is the owner started with replacing power cords of Halcro dm10 pre and Halcro dm58 monos, just for the experiment .Amazing result,he confirm that this replacement change the sound entirely with the same performance as in my first atempt.
As soon as I finish with the project, I will post results!
Thanks again Audiophonics!
Jonathan K.
Neutre et serein
Cela fait huit ans que j'alimente mon ampli principal avec ce câble, je pense avoir assez de recul pour en dire tout le bien que j'en pense. Image sonore élargie et qui respire. Câble ayant la faculté première de supprimer les agressivités surtout dans les aigus. J'ai pu reconfirmer ce dernier point avec la confection d'un second câble pour mon préampli phono. Une fois ce dernier installé, et avec peu de rodage, la différence est évidente. Tout est plus posé, équilibré et tend vers une certaine neutralité. Un des meilleurs rapport qualité-prix à ma connaissance.
 (3)
stephane k.
Rapport qualité prix imbattable
Ce câble m’ a permis d’alimenter mes deux belles cabasse The Pearl qui avait un câble d’origine simple.
Il amène une grosse ouverture de scène et supprime ce voile que possèdent ces deux enceintes.
Très bon rapport qualité prix. Mais attention la première écoute est raide, quelques heures sont nécessaire afin de livrer la totalité du spectre équilibré.
Coupler à deux prises iec et schuco Elec audio amène deux câbles secteurs abordable
Câble un peu rigide, en prenant son temps nous arrivons à bon résultat d’assemblage.
CHRISTOPHE T.
Mon scepticisme à l'égard de l'utilité de soigner la liaison électrique entre la prise 220V du mur et l'ampli était grand avant que je jette mon dévolu sur le WM audio Tornado. Ce câble imposant et rigide a indiscutablement augmenté le dynamisme et l'aération de la restitution. A l'écoute, la distance entre les enceintes est accentuée et gratifiée d'un effet surround (la profondeur spécifique à ce câble dont parle Raphael S.).
Un peu comme si des haut-parleurs supplémentaires avaient trouvés place sur les côté extérieur des enceintes. Le son semble par moment venir également de la pièce d'à côté.
Le rendu stéréo est bluffant.
Donc oui ! Loin des polémiques qui tentent de discréditer l'importance de la qualité des cordons d'alimentation, une écoute objective impose de reconnaitre que ce paramètre influe sur le résultat avec force.
Faites-en l'expérience
 (3)
Frank O.
Voor de prijs een prima kabel!
Deze kabel gekozen ter vervanging van de standaard meegeleverde Rotel Michi kabels. De WM kabel is vrij stug maar ziet er verder prima uit. Bij het verwijderen van de buitenmantel valt direct op dat deze zeer goed geïsoleerd is. Dit was dan ook meteen de reden van de aankoop. Voor deze prijs vindt je geen betere. Kabel werd heel snel verzonden door Audiophonics, waarvoor dank!
Alain V.
RQP imbattable
Il a remplacé un câble de marque beaucoup plus cher... Son apport: dynamique, séparation des instruments, effet stéréo, aigu mieux perçu.
Je le conseille sur le bloc ampli, pas en DAC mais à voir selon son matériel.
Pour le prix vous ne risquez rien de l'essayer!
 (3)
roland g.
cable tornado
merci pour l envoi du cable tres bon produit a recommander
christian A.
Excellent cable secteur au rapport qualité prix imbattable
Cable tres naturel tres équilibré dynamique tres supérieur aux autres cables proposés souvent à des prix excessifs.......pas de duretés belle dynamique , il est surprenant pour le prix.....peut-etre que son excellent blindage et sa constitution en multibrins cuivre plus gros que ce qu'on trouve couramment (20 brins de 3/10 de mm) y est pour quelque chose.
il est parfait pour les amplis de puissance comme pour les sources si votre source est transparente....vous l'avez compris je le recommande vivement par contre il est tres rigide et ce n'est pas du tout pratique aussi prenez le d'au moins 1.5m à 2m.
Christophe C.
Trés bien
Utilisé pour alimenter une barrette secteur et mon ampli en classe D. A l'écoute tout est plus net, plus précis. Bien fabriqué mais rigide. Bon rapport qualité prix.
Stephane C.
Homogène, oui mais...
Câble offrant une restitution homogène, sans accident majeur, avec de jolies nuances et un aigu assez fin, mais manquant considérablement de diversité et d'expressivité fine. Tout est bien posé, ample et plein, mais en comparaison directe avec mon câble chouchou (un câble lambda de 3x2.5² de bonne facture), le mien est énormément plus varié et diversifié, avec plein de petits détails subtils tout en étant plus neutre que le tornado.
 (3)
 (3)
Pascal j.
excellent !
je suis équipé Avec ce câble et connecteurs Elecaudio ( montés par Audiophonics )
résultat : Rapport qualité Prix excellent
Conseils Audiophonics pertinents et objectifs
 (3)
Francis L.
Un câble pour remplacer très avantageusement le câble d'origine
Le câble d'origine pêche par brillance. Le câble 1877PHONO apporte de la sérénité, de la matière et des timbres plus justes.
frederic R.
Excellent rapport qualité prix !
j'ais acheter ce câble pour son prix évidement je suis pas déçus ! li est monté sur prise rhodium je le trouve dynamique avec grave percutant ! est rien de négatif , sur un ampli a tubes kt88 ., Par contre sur un lecteur cd j’aime pas il est moins précis , moins détaillé. En gros par rapport au prix il excellent !
juste un seul défaut il est gros de diamètre très rigide !
 (3)
Mikael V.
Excellent rapport qualité prix mais très rigide
J'ai utilisé ce câble pour confectionné une barrette secteur en 3m + un câble de 1m pour mon intégré à lampe. Ce câble est très neutre et apporte un plus en dynamique, détail et largeur de l'image stéréo. Je redécouvre France Musique et tous mes vinyles! En revanche, je n'ai pas constaté de gain au niveau des basses. Il est vrai que je dispose d'un système assez clair à base de colonnes Triangle. Attention, le câble est relativement rigide. Ca passe juste juste dans mon meuble avec les prises shucko qui sont assez imposantes déjà.
 (5)
Xavier A.
Mon premier cable je suis satisfait à ce jour comparé a mon cable d'origine c'est le jour et la nuit .
Marc H.
Bluffant ... j'ai monté ce câble de 2m moi même avec les prises c simple comme bonjour. Le résultat je doit le dire m'a laissé sans voix mais les oreilles grande ouverte. Mon vieux cyrus two c'est trouvé dopé en dynamique sur toutes les plage avec des notes bien définie et de l'air autour et mes triangles elypse d'un coup sont descendues dans le grave un beau grave tendu sec quelle plaisir . Une belle réussite et un rapport qualité prix sans appel pour la concurence
Raphael S.
Câble secteur à l'excellent rapport qualité prix, qui peux convenir avantageusement à une ligne de transmission secteur de la prise murale à une barrette de bonne qualité non filtrée (sachant que les derniers câbles ou barrette filtrée raisonnablement pour ne pas tasser la dynamique, branchés sur les appareils, influent principalement sur celle-ci...).
Ce câble, par exemple, convient bien aussi pour alimenter un caisson de basses...
Il a un très bon équilibre sur toute la bande passante, sans colorations sur le medium-aigu (il semblent donc bien convenir à des systèmes montants dans ces registres).
Le registre du grave au bas médium est parfaitement lisible et très bien tendu, sans effet physiologique sur les premières octaves, avec une belle profondeur du champ sonore (une spécificité de ce câble!).
Avec comme équipement des prises FURUTECK pure cuivre (FURUTECH FI-E-11CU), la restitution est naturelle, aérée et surtout dynamique!
A conseiller sans réserve si l'on veut du résultat et préserver son porte monnaie.
Merci Audiophonics.
 (7)
FREDERIC P.
Câble utilisé pour ampli classe D, dac et drive cd/ DVD il inspiré la confiance par sa très bonne qualité de finition et le rendu sonore est tout simplement bluffant.
Les grave sont très bien équilibrés les médiums parfaitement présents et les aigus ciselés.
C'est un produit rapport qualite/prix qui n'a pas de concurrence : 5 stars.
La meilleure preuve est qu'il reste très peu de temps dispo en stock...
 (3)
Girand Michel C.
Câble d'une musicalité incroyable! Pour ce prix c'est du jamais vu!!! A mettre avec n'importe quoi, son apport est tout simplement indéniable. Grave tendu, aigu chatoyant, medium plus équilibré bref ce câble porte très bien son nom (TORNADO)!!! Associé avec une prise furutech en shucko, elle lui donne encore plus de chaleur musicale.
Merci Audiophonics.
Chan
 (5)
Frank T.
Cable secteur d'un belle équilibre des timbres et de la dynamique ,à ce prix certainement le plus performant du moment.
Raoul B.
Excellent câble. Rapport qualité / prix incomparable.....
Harry m.
Bjr . trés bon cable secteur trés musical raport prix 5 étoil merçi tornado bonne route bon boulot audiophonics que dire de plus il y à pas photo quoi raport qualité prix .
Renaud D.
Très bon ce cable, un gros diamètre, un peu rigide mais sa qualité en fait une référence à petit prix.
