MUNDORF L071 Self à Air 0.71mm 3.30mH
Référence : 4251
9,90 €TTC
8,25 € HT
Disponible
Date d'expédition : 21-01-2019.
MUNDORF L071 Air Cored Coil 0.71mm 3.30mH
Air cored coils are, for physical reasons, unbeatable as far as accurate pulse reproduction and freedom from distortion are concerned.
For this reason, for all the purists, we stock air cored coils with wire diameters of up to 3.0 mm.
It is also possible in this way to create greater inductances with relatively low internal resistance.
Vacuum impregnation also leads in the air cored coils described here to greater detail and spatial quality in the reproduction of music.
Technical Specifications :
  • Electrolyte copper 99.99 %
  • Pure Coil forms : PA, glass fibre reinforced
  • Tolerance : Max 3%, typically 1.5%
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_1.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_3.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_4.jpg
Modèles Diamètre du Fil /mm
L/mH
R / Ohm
Puissance max (8 Ohm)
Dimensions
L071-0050.710.050.19
35 W
25 x 10mm
L071-0100.710.100.23
31 W
25 x 10mm
L071-0120.710.120.2542 W  36 x 10mm
L071-0150.710.150.2839 W 36 x 10mm
L071-0180.710.180.3138 W 36 x 10mm
L071-0220.710.220.3437 W36 x 10mm
L071-0270.710.270.3934 W36 x 10mm
L071-0330.710.330.4333 W  36 x 10mm
L071-0390.710.390.5129 W 36 x 10mm
L071-0470.710.470.5821 W  30 x 20mm
L071-0560.710.560.6420 W 30 x 20mm
L100-0680.710.680.7120 W 30 x 20mm
L100-0820.710.820.8118 W 30 x 20mm
L100-1000.711.00.9117 W  30 x 20mm
L100-1200.711.21.018 W40 x 20mm
L100-1500.711.51.117 W  40 x 20mm
L100-1800.711.81.217 W 40 x 20mm
L100-2000.712.01.316 W 40 x 20mm
L100-2200.712.21.416 W  40 x 20mm
L100-2700.712.71.515 W 40 x 20mm
L100-3000.713.01.615 W 40 x 20mm
L100-3300.713.31.814 W 40 x 20mm
L100-3900.713.92.016 W 58 x 18mm
L100-4700.714.72.216 W 58 x 18mm
L100-5600.715.62.416 W 58 x 18mm
L100-6800.716.82.715 W 58 x 18mm
L100-8200.718.23.114 W 58 x 28mm
L100-10000.7110.03.613 W 58 x 28mm
L100-12000.7112.03.914 W 70 x 29mm
L100-15000.7115.04.513 W 70 x 29mm
L100-18000.7118.05.013 W 70 x 29mm
L100-22000.7122.05.712 W 70 x 29mm
L100-27000.7127.06.411 W 70 x 29mm
Colissimo - TNT - SoColissimo
0,00 € Dont TVA 20%
