VIABLUE SC-2 Câbles d'Enceintes Plaqué Argent 5m (La Paire)
En achetant ce produit vous obtenez 22 points de fidélité
Référence : 2037
229,00 €TTC
190,83 € HT
Disponible
Date d'expédition : 24-07-2018.
Definition. Details. Living music.
High-End quality. Salient Design. ViaBlue™ Cobra.
ViaBlue™ SC-2 Silver Series loudspeaker cables have a combination of silvered braids for the high pass range and tinned braids for the pressureful rendition of the low pass. On the ends the ViaBlue™ T6s Series loudspeaker plug-in connections plated with genuine gold are terminated.
SC-2 speaker cables have a transparent and three-dimensional acoustics and a brilliant, airy quality in the high range. Clean lows and basses homogeneously round out the acoustic pattern. Technically, all of the frequency ranges are cleanly and realistically represented and reproduced in a linear fashion.
Different materials for different ranges.
Both 4 mm2 leads of the SC-2 speaker cable consist of seven-stranded lays with a total of 448 individual wire conductors. In order to customize the sound range for the individual frequency ranges, five strands have genuine silver plating for accurate reproduction of the high range and two strands have pure copper strands for powerful accentuation of the bass.
The SC-2 speaker cables have ViaBlue™ Cobra sleeve around them that even at first glance displays the dynamics of the high-end speaker cables.
Silver plating for more brilliance.
Through the combination of silver-plated and tin-plated leads, the finest details and brilliance of the treble range as well as the lower frequency signals of the bass range are fully carried and powerfully reproduced through the attached speakers.
The SC-2 speaker cables are braided with the ViaBlue™Cobra protective sleeve, which also affords at first glance a visual impression of the dynamic quality of the high-end speaker cables.
The splitters typically used with ViaBlue™ cables protect the cable ends from snapping off and, at the same time, provide a professional, well thought out cable routing of the single leads.
All ViaBlue™ cables are manufactured in Germany and are made by hand.
Fiche technique
Diamètre (mm)11
Longueur5m
PlaquageOr
ConfigurationMono-Câblage
Colissimo - TNT - SoColissimo
0,00 € Dont TVA 20%
