Sélecteur de source ALPS SRRN152000 5 positions 2 voies
Référence : 8612
8,90 €TTC
7,42 € HT
Ce produit n'est plus disponible.
Se montent par exemple dans un préamplificateur pour sélectionner les sources.
  • Puissance maximum : 0.15A 12V DC
  • Durée de vie : 10000 cycles
  • Fabriqué au Japon
Number of wafer1
Poles2
Positions5
Changeover angle30±3°
Changeover timingNon shorting
Rotational torque70±30mN·m
Actuator configurationFlat
Actuator lengthL: 15mm
Operating temperature range-30℃ to +65℃
Rating (max.)/(min.) (Resistive load)0.15A 12V DC/50µA 3V DC
Electrical performanceContact resistance (Initial performance/After lifetime)50mΩ max./100mΩ max.
Insulation resistance100MΩ min. 500V DC
Voltage proof500V AC for 1 minute
Mechanical performanceTerminal strength5N for 1 minute
Actuator strengthRotational direction1N·m
Push direction
Wobble of actuator (load at the tip of shaft: 5N)Measuring position from mounting surface10mm
Shaft wobble (max. value)0.17mm max.
Applicable mounting dimension15mm
DurabilityOperating life without load10,000 cycles 70mΩ max.
Operating life with load (at max. rated load)10,000 cycles 100mΩ max.
Environmental performanceCold-40±2℃ for 96h
Dry heat85±2℃ for 96h
Damp heat40±2℃, 90 to 95%RH for 96h
Page Constructeur
PDF Constructeur
https://www.audiophonics.fr/images2/8612/8612_ALPS_SRRN152000_1.jpg
Colissimo - TNT - SoColissimo
0,00 € Dont TVA 20%
