Pour ibasso dx340
Arvydas V.
A
Mohammed B.
Im Vergleich zu Mundorf...
Avis clients - Il y a 19400 avis.
Luca M.
Excellent performance for the price
I purchased this amplifier for a pair of Kef LS50, small but a bit difficult speakers in terms of amplification (85 db sensitivity, 8 Ohm), replacing an integrated class A amplifier with 50W/ch @ 8Ohm. At a normal listening volume, the sound is richer, bass is more defined and the dynamic is much improved; the sound is detailed, balanced and non-fatiguing. Construction is good and the aluminum case is very solid.
As written in another review, I confirm that the device, when connected to the electrical grid, emits a slight buzz; however the noise is really weak and audible only if you are very close to the amp in a completely silent room (anyway for me it’s not a problem because I usually disconnect from the electrical grid all my HiFi devices when I'm not using them, simply switching off the power strip ).
Tae-Gil N.
Very nice companion for my KEF LS50
Previously I was using NAD D3020 (internally uses Hypex UcD102-based output stage) as amplification for my KEF LS50 speakers. I've purchased this amplifier as an "upgrade" to grant some more natural output to the speakers. I am quite satisfied with the result. This tiny amplifier drives full dynamics of the speaker with ease. The amplification / sound performance alone would be 5 star!
However, I am not totally happy with the chassis, and thus giving only 4 stars. It may be just my module, but I am having a tiny physical hum noise from the amplifier, near transformer side: This is tiny (i.e. tiny noise you can hear only within 50cm or so), and it is a typical 50hz mains hum. It comes out both in standby / on. Minor issue, since this is strictly on physical side, and not on signal side. So it isn't affecting output at all. However, I hate any such noise from my audio equipment. To identify further the exact source of the noise, I've opened the case (okay, warranty sticker removed and void now, but I don't care) and tried to identify which component is making this noise. But surprise surprise, the noise is gone when the top cover is off. I suspect some magnetic effect between one of transformer component with the enclosure cover. If the enclosure was slightly bigger, I guess this won't happen. Running with the cover-off can be very dangerous (NC122MP document shows front side of components with red color of dangerous voltages). So for the moment, I am with this hum. I am planning to do some DIY with a slightly bigger enclosure.
It would have been 120% perfect (?), if the module was supplied with a slightly bigger enclosure, with both XLR & RCA connection. Well, for this, 699 euro PA-S250NC is exactly that kind of stuff, but I didn't need that much gain for my current setup, so I am rather happy with this cheap-but-great amplifier.
Well, all in all, I am totally happy with it. Great job, Audiophonics, on providing one of the most economic NCore amplifier.
Jacob L.
RASPTOUCH I-SABRE V4 Lecteur Réseau Tactile Raspberry Pi 4 DAC ES9023 Noir Le Rasptouch Audiophonics est un lecteur réseau basé sur Raspberry Pi 4 disposant d'un écran tactile pour une utilisation facilitée. Il est...
Very good hardware, sound really excellent - software NaJa not so good
Wanted a small audio streamer with a display.
I noticed this one and it looked very good.
From a build point of view it is very good. All I wanted.
Managed to get it up and running with Volumio - including the touch screen - very nice - sound very good.
So I would have rated it with 5 stars for my purpose and use case if if was not for the software. I am not a developer or hacker and besides it is hard to key in command line commands when using the browser UI.
I will keep it but will have to look for a better software.
I tried to get software up and running, what a major pain in the a..
I managed to get Max2Play up and running but was unable to mount my Synology NAS. Just didn't want to mount... so I actually but unusable (for my scenario) hardware. I could play music from a USB stick
Then tried out Volumio, where I managed to install the Raspberry 7" display driver. and voila on first try I was able to mount, I cannot see any difference in the commands between Max2Play and Volumio only that Volumio requires less information.
With Max2Play I couldn't get Wireless up and running.
With Volumio I can only make it work with wireless.
if I attach a ethernet cable I somehow get two entries for Volumio with two different IP adresses (but same MAC adress).
Hi,
Please give a try to Picoreplayer.
It's by far the greatest software solution for this device :
http://forum.audiophonics.fr/viewtopic.php?f=12&t=1756
Best regards
Clément M.
AUDIOPHONICS PA-M250NC Amplificateur Mono Class D NCore 1x250W 4 Ohm Le Audiophonics PA-M250NC intègre un module d'amplification de puissance Hypex Ncore NC250MP . Celui-ci est une base solide pour construire un système...
Performances inégalées à ce prix.
J'ai d'abord eu le PA-125NC quelques jours... je l'ai trouvé si bon que je me suis dit que cela méritait d'aller plus loin, vers deux PA-M250NC.
Du côté des points négatifs, ce sont les mêmes que j'ai pu faire à leur petit frère: placement de la connectique pas idéal. De plus, vu la place libérée due à la nature mono de ce modèle, une entrée XLR symétrique aurait été plus pertinente (conformément au cahier des charges des modules Hypex).
Eh bien, ces reproches mis de côté, on est face ici à un chef d'oeuvre de conception électronique. Il faut savoir que les modules NC250MP sont ceux qui présentent le taux de distorsion le plus bas de la gamme NC-MP... C'est même incroyablement bas: THD+N à 0.0009%, de 2W à 55W / 8Ω. Pour vous donner une idée: d'autres amplis sont capables de telles prouesses, par exemple le Benchmark AHB2 à... 3000$.
La réserve en puissance est exceptionnelle, bien que c'est finalement la "propreté" du rendu qui choque le plus. Particulièrement à très fort volume, lorsque qu'on sent le son de manière physique, sans être incommodé par une distorsion harmonique désagréable. C'est assez déroutant par rapport à nombre d'amplis en classe AB qui commencent à saturer beaucoup plus tôt.
Enfin, mes blocs sont attaqués par mon RME ADI-2 DAC. L'avantage d'utiliser un tel matériel et de pouvoir régler le niveau de sortie avec une grande précision. La sensibilité d'entrée, donnée pour la puissance maximale, est de 1.66V (6.61 dBu). Je peux donc régler mon niveau de sortie sur une référence de +7dBu (1.7V), pour pouvoir piloter l'ensemble de la puissance disponible de -96 à 0db.
A recommander sans réserve! La signature sonore, droite, linéaire et totalement épurée de la moindre coloration, rebutera sans doute les "audiophiles" adeptes d'électroniques fort peu fidèles aux enregistrements!
Clément M.
Sans concurrence.
Finition et construction assez sommaire. Je regrette les connecteurs très exigus à l'arrière, ainsi que le placement: Les borniers devraient être en dessous des emphases RCA et non l'inverse. A noter que l'ampli est aux normes: Terre rattachée au châssis et phase bien à gauche de l'entrée IEC.
Ceci étant dit, cet ampli, qui est le moins cher du marché en Ncore (ampli monté) est tout juste excellent pour une entrée en la matière. Les chiffres mesurés parlent d'eux même: La majorité de la puissance est disponible en dessous de 0.005% de Distorsion Harmonique + Bruit, soit la limite théoriquement audible. Dans la pratique, cela ce ressent, on peut pousser l'ampli dans ses retranchements (sensibilité d'entrée max à 1.17V - 3.6 dBu). Tout en profitant d'une puissance particulièrement propre. Signature très neutre: pour les personnes qui n'attendent pas d'un ampli qu'il apporte une quelconque coloration (ce qui n'est, en aucun cas, le rôle d'un tel matériel).
Hautement recommandé. Je l'ai tellement apprécié que je ne pouvais pas en rester là! j'ai donc commandé deux PA-M250NC Mono pour aller plus loin en puissance disponible.
Marek V.
Adaptateur jack 6.35 mâle stéréo vers 2 x RCA femelle plaqué Or
Adaptateur RCA mâle vers RCA mâle plaqué Or
Allo Shanti
It's my first linear source and I can't come out of wonder. Excellent product. He moved Allo USBridge to the next level.
Everything has improved.Separation of tools, depth, location in space .....
I'm really impressed.
I recommend to all.
Adrien P.
Tous simplement indispensable pour un pc audio multimédia
Je possède 2 filtres PCIE, 4 filtres SATA + 2 filtres FAN ainsi que les filtres pour la RAM. Chacun installé l'un après l'autre.
Le gain est nettement supérieur si on installe une paire de chaque filtre par ligne d'alimentation, surtout pour les filtres PCIE et la RAM. Le résultat est sans appelle c'est indispensable pour transformer son PC en drive avec sortie numérique ou analogique.
Jerome V.
Inutilement essentiel 2 - suite et fin
car cela apporté à la chromecast doublé du DAC beaucoup plus de tenue dans tous les registres.
En outre, c'est plutôt solidement construit. C'est pas en plastoc.
Concernant la fiabilité, il faut voir sur le long terme.
Mais de prime abord, moi, je suis fan...
Sylvain J.
AUDIOPHONICS DIGITAL AUDIO Câble USB-A Mâle vers USB-B Mâle Cuivre OFC 4N PTFE 1m Le câble USB Audiophonics Digital Audio est un câble numérique développé par l'équipe Audiophonics et assemblé dans nos ateliers....
Impressionnant !!
Fonctionne mieux que mon WireWorld Ultraviolet 7 que j'avais avant...
A part dans l’extrême grave.
Guillaume B.
AUDIOPHONICS COBALT Câbles d'Enceintes Bananes Cuivre OFC Plaqué Or 2x4mm² 3m (La paire) Le câble pour enceintes  Audiophonics Cobalt  a été conçu et monté dans nos ateliers afin de proposer un produit performant tout en...
Livré à Bruxelles en à peine 3 jours dans un paquet hyper soigné... produit d’une qualité supérieure au prix :)
PIERRE C.
Je sent que quelque chose s'est passé depuis que j'ai mis ce petit chapeau à mon RPI3. J'avais par le passé utilisé une interface basique compatible digi+ mais là c'est meilleur.
La musique coule vers mon dac Geek Pulse et ressort dans mes JMR bliss silver (en passant par un cyrus8vs2) avec un très bon timing et une très bonne musicalité...
bruno B.
Très satisfait du produit et de la livraison
Valery R.
Bouton correct
Bouton de grande taille, que je trouve un peu cheap. Pour des boitier où le poids est critique, ce bouton est léger et a une bonne prise en main. Je pense cependant que pour une utilisation dite "haut de gamme", un modèle massif est plus adapté.
Valery R.
Bouton Aluminium Axe Méplat 38x22mm Ø6mm Argent pour Potentiomètre Ce bouton pour potentiomètre est idéal pour les projets DIY, par exemple pour le contrôle du volume ou de la source.
Bouton massif qui fait très bon effet sur un bloc de puissance de grande taille.
Sans trop grand pour des petit boitier. A voir suivant le type de réalisation.
E G.
DAYTON AUDIO KAB-PMV3 Panneau de contrôle JAB / KAB Panneau de contrôle pré-percé pour KAB / JAB. Aucune soudure nécessaire. Livré avec toute la connectique requise pour profiter de l'ensemble des fonctionnalités de votre module...
Très pratique
Il s’agit d’un excellent produit. Tres pratique pour créer des installations bluetooth notamment à partir de vieilles radio TSF. Faciles à monter, même si une notice explicative aurait été nécessaire (ne serait-ce qu’un pdf en ligne).
Bravo pour la disponibilité et rapidité de l’équipe Audiophonics.
E G.
Pas de souffle de mon côté (utilisation bluetooth avec iphone SE et ipad air), son très correct et suffisamment puissant, en tout cas suffisant pour moi (transformation TSF en HP bluetooth). Livré avec cable mono HP mais sortie dispo pour stereo.
A associer avec panneau de contrôle Dayton.
Bravo pour la disponibilité et la reactivité de l’equipe Audiophonics.
Gérard H.
Fiches bananes DYNAVOX
Très bon produit.
Attention !
Il faut bien savoir ce que l'on fait : l'évacuation de la chaleur se fait beaucoup moins bien : après collage d'une plaque sur mon dac , celui ci s'est mis en sécurité plusieurs fois, j'ai du décoller la plaque de Pinta , et là bonjour la galère : le décollage est TRÈS difficile , donc prudence ...
Joseph G.
IAN CANADA DUAL MONO PLUS DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD Le module Ian Canada 9038Q2M Dual Mono DAC HAT est un DAC de très haut niveau pour Raspberry Pi. Il exploite deux puces ES9038Q2M SABRE 32-bit intégrées en mode double Mono.
information
satisfait de mon achat mais a signaler que l'accessoire "IAN CANADA Contrôleur ESS SABRE 90X8 avec afficheur" n'est pas une option mais est obligatoire pour que la carte fonctionne!
Ernesto S.
Super Schuko
Je m'excuse pour la langue si très probablement pas correcte, j'écris d'Italie à l'aide du traducteur Google.
J'ai récemment pris deux de ces schuko et un IEC de la même série.
  J'ai commandé un autre 2 schuko aujourd'hui. Leur inclusion a donné à la plante un nettoyage, un son plus autoritaire sans perdre le bon équilibre entre chaleur et transparence. Excellente. C'est un peu cher pour le prix mais les qualités sont toutes présentes, même dans la construction et dans la résistance presque bouclée
David R.
Impécable!
Vu le prix,je m'attendais largement à moins bien.
Les pas de vis sont solides,on peut serrer ferment (pas faire la brute quand même) à aucun moment je ne me suis dit "oups...trop fort"
Du câble 2.5 (Sommercable Orbit) s'y insère parfaitement (petite astuce, chauffer légèrement la gaine de vos câbles puis , avec les doigts lui donner une forme effilée,la gaine pourra alors pénétrer plus facilement dans la fiche,ce qui évitera de trop tirer sur les brins lors des manipulations)
Pour la gaine thermo,dévisser la bague,laisser dépasser jusqu'au filetage chauffer,laisser refroidir et visser la bague pour un résultat propre et "pro".
ATTENTION! ne chauffer pas trop,la gaine rouge a tendance à brunir légèrement.
Le contact avec les borniers se fait sans souci,ça serre ni trop,ni trop peu.
Coté son,rien à dire de négatif.
On dit "pas cher,pas bien" ici ce n'est pas le cas.
Pour comparaison,je possède également des fiches Sommercable Hicon.
A voir dans le temps?
Gérard H.
fiche banane
Super produit. A recommander
Paul D.
AUDIO-GD R-1 2021 DAC R2R DSP FPGA USB Amanero HDMI I2S 384Khz 2x Accusilicon Avec le R1, AUDIO GD nous propose une nouvelle version du fameux R2R1, équipée cette fois d'une interface permettant de paramétrer les filtres, le niveau...
Surprenant!
Fabrication, finition, connectique de haute qualité. Ecoute surprenante de délié, on est
surpris par l’aération que l’on ne ressentait pas avant l’achat sur le précédant matériel
que je possédais. Le cable ACSS est de toute beauté!
Christian O.
LITTLE DOT MKIII Amplificateur Casque / Préamplificateur à Tubes Le Little Dot MKIII est un très bel amplificateur casque à tubes, offrant d'excellentes performances audio. Il est surmonté de deux tubes GE5654 (United...
Meilleur RQP de la gamme Little Dot
L'écoute au casque est excellente à condition d'utiliser un modèle d'impédance supérieur ou égal à 120 ohms. Le son est fin et subtile, les timbres sont de toute beauté. Ce qu'on ne retrouve que sur des amplis casque de très haut de gamme tel qu'Audiovalve.
Pour ce qui concerne la partie préampli, c'est plus qu'excellent. La bande passante est énorme. Le son est raffiné, dynamique, avec un très bon étagement des plans sonores.
Ne changez pas les tubes de sortie (6h6p) ils sont excellents. par contre je vous recommande chaudement d'utiliser des Mullard M8100 (ef95) en entrée. Ceux sont à mon avis les meilleurs.
Par curiosité, j'ai écouté le Little Dot MK 4 se, personnellement je ne le trouve pas supérieur au MK3. Il est certes plus dynamique, mais moins précis
Jerome V.
De prime abord, une alimentation supplémentaire en remplacement de celle d'origine peut paraitre totalement inutile (c'était mon humble opinion).
Cependant, dans le cadre d'une google chrome-cast audio accompagné d'un petit dac smsl sankrit 10, je me suis dit, je vais alimenter tout ça avec une seule alim que je pourrais éteindre en une seule fois.
Et bien alors, bien m'en a pris c
Roussanne A.
Simple et efficace
Achat à recommander, m'a permis de supprimer un ronflement que j'avais en passant par les prises trigger de mon ampli de puissance.
jean-pierre G.
ACCUSILICON AS318-B-983040 Horloge Ultra Low Jitter 98.3040MHz Cet oscillateur crystal à bruit de phase extrêmement bas (<90dBc @ 10Hz) est destiné aux appareils d'enregistrement professionnels ainsi qu'aux circuits électroniques audiophiles.
masterclock audio-gd nos7
Ajoutée en masterclock pour passer d'un master 7 à un nos7 audio-gd le résultat est impressionnant !
C'est plus qu'une amélioration de la qualité sonore, c'est un autre dac !
L'écoute est d'emblée dénuée de la moindre agressivité, richesse des détails et musicalité ne se contredisent pas, les basses, les voix, les timbres, la finesse des cymbales, ect... sont un régal ;-)
Et alimentée indépendamment en interne comme le module usb Amanero par des module LT3045 c'est encore mieux.
Et après une dizaine de jours d'écoute quotidienne de plusieurs heures, j'ai bien l'impression que c'est encore un peu mieux sur les basses (rodage ?).
Bref, un rapport qualité/prix imbattable, Kingwa d'audio-gd (très réactif) explique toujours la marche à suivre, merci à lui.
Ecoute sur 2 pc audios Roon, audio-gd Nos7entrée Amanero,Master9 et blocs 2H panneaux Magnepan 3.7
jean-pierre G.
MATRIX X-SPDIF 2 Interface USB XMOS U208 32bit / 768khz Coaxial-AES/EBU I2S HDMI LVDS La nouvelle interface USB vers SPDIF et HDMI Matrix X-SPDIF 2 est une relecture totale et non une évolution de l'ancienne X-SPDIF. De part ses caractéristiques...
en i2S sur audio-gd Master 7 2015
Amélioration globale de la qualité sonore comparé à l'entrée usb Amanero (alimentée en interne par LT3045, alimentation usb coupée, source 2 pc dédiés audio avec sortie usb SoTm et superclock).
Sauf les aigus qui sont "secs" et manquent d'énergie notamment sur des cymbales par exemple.
Jerome L.
Excellent condo pour filtrer les tweeter. L effort du prix est a la hauteur de la recompense.
GENALEX GOLD LION 12AU7 / ECC82 / B749 Tube (Unité) 12AU7 de très haute qualité fabriqué sur cahier des charges.
Révision avis précédent
Problème de souffle apparu secondairement sur le XDuoo TA-10, dommage car j'aimais beaucoup le son de ce tube, mais ce souffle rend la Genalex inutilisable sur le TA-10.
XDUOO TA-10 Amplificateur Casque USB DAC Tube Hybride class A Le xDuoo TA-10 est une amplificateur à tube et DAC pour casque, intégrant une puce USB XMOS. Il saura vous offrire une restitution sonore des plus juste.
Complément avis précédent
Problème avec la Genalex, un souffle apparaît qui n'existait vraiment pas au départ! donc Florian R. avait sans doute raison...
Dommage j'aimais bien le son avec ce tube, mais ça n'enlève rien aux qualités du TA-10.
Je remonte l'Electro Harmonix Gold, pas de souffle.
Monté sur un XDuoo TA-10 qui fonctionne avec un tube double triode en étage préampli.
J'avais une Electro Harmonix Gold que je trouvais très bonne, mais à mon avis la Genalex va plus loin =
Qualité du grave, rond mais pas trop, et très défini
Beau médium détaillé et aéré
Aigu comme j'aime, fin et pas agressif
La spatialisation, aucune critique
Pas de souffle
Et subjectivement le TA-10 a un son plus "tube" avec la Genalex.
Très sympa!
J'ai acheté le mien d'occasion, le vendeur l'avait pris chez Audiophonics.
Mon TA-10 est équipé d'une Electro Harmonix Gold qui va bien dessus.
J'essaye une Genalex Gold Lion achetée sur le site, et contrairement à l'avis de Florian R. je n'ai aucun problème de souffle, son exemplaire était peut-être défectueux?
Toujours est-il que je préfère la Genalex, c'est plus fin partout. Le grave en particulier très défini, rond comme j'aime mais pas trop. Médium détaillé et aéré, aigu fin et aucune agressivité. Je trouve le son plus "tube" avec la Genalex.
Le casque que j'utilise est un Fostex TH900.
Le dac à base d'AK4490 rien à dire, en tous cas le combo dans sa globalité est excellent. C'est meilleur avec un câble usb comme le modèle d'Audiophonics, ou le Neotech argent monobrin. J'ai essayé aussi avec une Regen alimentée par une Ifi Ipower 9v et deux câbles usb Neotech argent, ça exploite bien la liaison PC vers dac mais ça n'engage que moi.
Anders L.
Robust and quick assembly
Very robust plug that is quick and easy to assemble thanks to the pressure plates on the conductors. The cable ring really grabs on to the cable, as well. Highly recommended.
Anders L.
Bornier Encastré Isolé pour Bi-Câblage Enceintes 95x75mm Ces borniers pour enceintes disposent de connecteurs à visser, acceptant également les fiches bananes (4mm). Le diamètre de perçage est de 95x75mm.
Excellent quality
Excellent quality terminals. The binding posts are machined with precision and the plastic block is robust. The foam seal prevents any venting around the block. The conductivity seems excellent, as far as I can tell. Again, superb value for the price.
SPARKOS LABS SS3601 AOP Discret Simple DIP8 (Unité) SparkoS Labs a crée une gamme d'AOP discrets montés sur DIP8 optimisés pour fournir d'excellentes performances audio. Ils vous permettront de remplacer des...
Une alternative aux Burson
J’ai branché deux Sparkos SS3601 sur un DAC AK4497 à la place de deux Burson V6 classic, les Sparkos se placent très facilement sur les support DIP8. Après une semaine de rodage, le son des Sparkos est plus défini, plus détaillé, plus transparent la localisation des instruments très précise en largeur et en profondeur. Pourtant, je conserve mes Burson, qui sont un peu moins brillant dans le médium/aigu mais donnent plus de relief aux instruments, c’est le constat sur mes enceintes isodynamiques. J’ai apporté les Burson chez un ami qui possède un DAC DIY avec TDA1541/OPA627 et des enceintes Proac reponse 3 avec membranes en polypropylène et là les Sparkos ont amélioré la restitution de manière incroyable.
DAYTON AUDIO DSP-RC Télécommande Filaire pour DSP-408 Le DSP-RC de Dayton Audio est une télécommande filaire compacte permettant de contrôler le Processeur de Signal Numérique (DSP) DSP-408. Elle vous...
Déçu
Dommage, bien que de belle qualité, ce petit appareil lorsqu'il est raccordé au DSP-408 émet un petit buzzz dans les hauts parleurs, perceptible à bas niveau, quoi que sur des enceintes à très haut rendement. A mon humble avis, l'alimentation de l'éclairage (trop vif) passant contre le signal de modulation (sur 5 mètres) doit générer ces interférences. En Hi-Fi embarquée, ça doit passer inaperçu, pas sur une chaîne de salon à très haut rendement.
DAYTON AUDIO DSP-BT4.0 Dongle Bluetooth 4.0 pour Contrôle DSP-408 Ce dongle Bluetooth proposé par Dayton Audio a été conçu pour vous permettre de contrôler votre Processeur de Signal Numérique (DSP)...
Permet avec un simple téléphone, ou tablette de régler son filtre, simple rapide, efficace.
Super appareil
Très simple d'utilisation, belle qualité, beaucoup de possibilités. Il ne manque que la possibilité de mesurer la mise en phase des différents haut parleurs, ce qui serait le Graal pour ce type d'appareil.
Conforme à la description, prix correct, que demander de plus !
Très bon produit, conforme à la description, qualité au rendez-vous, attention toutefois à ne pas trop chauffer les fiches au risque de les faire fondre, sinon pour plus de sécurité, achetez les cosses idoines !
Alimentation de très bonne facture, bien construite, très silencieuse. Une petite amélioration souhaitée, un bouton on/off plus "silencieux" et moins gros serait top !
Eric L.
Capuchon pour connecteur male XLR
Très bonne finition efficace cotre les EMI /RFI et protège efficacement les connecteurs de l'oxydation et des poussières .
Eric L.
Capuchons pour connecteurs felelles XLR
Excellent produit très bonne finition avec un plot de détrompage relié à la masse du capuchon donnant une barrière plus efficace pour les EMI / RFI
Kai J.
Very good quality and good looks.
I liked this plug a lot,good to solder and it has a very classy design.
My interconnect cables looked very nice with these.
I´m sure they will sound good too,have not tried them yet.
Kai J.
Very good quality plug.
I liked the quality of this plug,and it was good to work with.
Nice look too.
Yours sincerely,
Kai Johnsen
Christophe M.
Gagner en musicalité
Tout est plus précis: des basses bien assises et mieux définies, un médium qui gagne en réalisme et des aigus plus purs. Pas de perte dynamique et neutre. En classique, on lie la portée et la sensibilité de l'interprète ressort, bref on gagne en émotion. J'en rachète un second.
Harald B.
Pace, rhythm and timing are top
I'm a huge fan of the Allo Boss Dac. I like his musicality. Pace, rhythm and timing are top. I have tried different power supplies, LPS,Ifi etc. I became best results with two supplies. Pi and Boss separate powered. Now I use a Allo Shanti and it's the best i tried until now. The music becomes more natural, less grainy, less sharpness. And this without loosing his musicality. I detected only benefits and no disadvantage.
One power supply and you are done. The Allo Shanti is imho a must have, if you like the Boss dac.
Harald B.
Make good things better
One power supply and you are done. Imho a must have, if you like the Boss dac.
Gianluca S.
Top quality
Top quality connector to be soldered.
Just be careful to scratch the rodium plating on the soldering points inside. This way they will be properly wet by the tin during soldering. I used to replace a 3,5mm connector on a Furutech adl phone cable.
