Ramiro F.
Ramiro F.
Marcus L.
Avis clients - Il y a 20139 avis.
Joy O.
iFi Audio LAN Silencer
This product brought my Eversolo DMP-A6 to live in a way I could not have imagined. I would highly recommend this product to anyone. The enhancement to my audio listening experience since I installed one of this is very pleasing.
JEROME J.
FOSI AUDIO MC101 Amplificateur Stéréo 2x TPA3116 Bluetooth 5.3 2x100W 4 ohm Avec son amplificateur stéréo MC101, Fosi Audio dévoile un petit appareil à la croisée entre vintage et modernisme. Le MC101 se dote de la...
Musical mais...
Du souffle léger et chuintement dans les hauts parleurs avant de lancer musique, mal isolé pour éviter parasitages vers enceintes, a revoir.
Simon S.
AUDIOPHONICS AP300-S125NC Amplificateur de Puissance Class D Stéréo Ncore NC122MP 2x125W 4 Ohm Le Audiophonics AP300-S125NC est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore NC122MP. Cette solution est...
Incredible value for money
I normally never write a review but i feel inclined to do so for this product.
I have high sensitivity speakers (Blumenhofer) and thought that only a SET tube amplifier would be a good match, i was wrong.
My 300b died on me and having already put so much money in tubes i thought, time to try something different.
So after consideration and reading on audio science review forum about what makes an amplifier truly good, i choose this amplifier as in blind testing most people couldn’t hear a difference between Ncore and Purify (more expensive) and also between other even much more expensive amplifiers.
So i chose the smallest Ncore as my speakers are very easy to drive.
Listening:
The lower end is much cleaner and more controlled than my 300b was.
Midrange is fine, it hasn’t got the romantic touch of 300b tube but in it’s own right it doesn’t sound worse, just a bit different.
Highs, for class d, where in the past this just wasn’t very good, with Ncore i hear no problems whatsoever.
It just sounds great, and i dare say, for this price INCREDIBLE.
Hats off to Hypex and the original designer Bruno Putzey for making such a great inexpensive amplifier.
In my middle end to high end system it’s no slough.
Highly recommended, if your speakers need more juice, than the NC400 is better i guess.
Patrick d.
Great quality Speaker Cable
This is absolutely great cable for the money
FOSI AUDIO BT20A PRO Amplificateur Class D TPA3255 Bluetooth 5.0 2x225W 4 Ohm Le Fosi Audio BT20A PRO est un amplificateur Class D compact et puissant, proposé à prix contenu. Son étage d'amplification utilise une puce  TI...
La fin... Excellent rapport qualité prix !
Mauvaises manip clavier qui valident illico le message en cours de rédaction...
Remplacement des AOP NE5532 d’origine par des Burson V5i, puis des OP275 en enfin des oracles II.
Avec ces trois AOP on a enfin des voix timbrées et incarnées, des aigus variés avec du poids et de la matière, des cuivres rutilants, des instruments à corde en vrai bois d'arbre et non en plastique et toujours une bonne dynamique. Disparues les sifflantes et petites duretés/raideurs, c'est nettement plus expressif que les NE5532 qui sonnent un peu secs et monochromes en comparaison.
L'image sonore est globalement mieux remplie avec une largeur correcte, là où elle reste un peu coincée dans les HP avec les AOP d’origine. Avec une préférence envers l'OP275 par rapport au Burson V5i qui est moins homogène.
L'Oracle après 24 heures de fonctionnement non stop est le plus homogène des trois, avec de beaux timbres, un bon équilibre, pas de sifflantes ou dureté, une dynamique bien répartie, Bref un bon niveau de transparence qui rend hommage aux enregistrements. L'image sonore est large avec une bonne profondeur, du relief et les ambiances de prise de son son palpables. Un peu faible en niveau dans l’infra (via la sortie sub).
Bref on peut modifier de façon substantielle le rendu du Fois BT20a Pro en changeant d'AOP. Selon les enceintes associées, on peut arriver à un haut niveau de qualité globale, sans frustration comparé à de nombreux ampli plus classiques et pas ridicule face à mon SE 845 DIY, qui va certes plus loin en tout mais à quel prix.
La qualité en Bluetooth est moyenne, graves écourtés et aigus proéminents à atténuer sur l'ampli.
suite
Bref l'alim à découpage d'origine n'est pas silencieuse sur des enceintes à haut rendement et l'ampli souffle un peu.
Le niveau de la sortie sub est un poil faible en niveau mais ça passe.
Au niveau écoute au bout de quelques jours de fonctionnement, c'est assez surprenant pour une si petite boite et en regard du prix. C'est propre, dynamique, droit, très détaillé, mais un peu sec et monocorde, avec des sybillances et un aigu qui manque de poids et de texture.
L'image sonore correcte mais qui reste un peu coincée dans les HP et ça m
J'ai branché le petit BT20a Pro et son alim 32V/5A à la place de mon SE 845, sur pavillons mid bass + compression qui reproduisent les fréquences entre 150 H et 20 000 Hz, avec 103/105db d'efficacité.
La sortie sub du Fosi alimente un Crown avec deux 15".
À l'allumage, on entend pendant quelques secondes un petit sifflement qui disparait. À 1,5 mètre EN ENVIRONNEMENT TRÈS CALME, on entend le souffle dans la compression là où mon SE 845 est parfaitement silencieux même à 5 cm.
On proximité du pavillon, on entend faiblement le tiktiktiktik de l'alim à découpage.
Rien de gênant à la position d'écoute, mais l'a
Benjamin B.
Very good, high resolution, high end cable.
Very good! Makes a difference. Price justified. But you have to know: It brings out the highs! If your system is already a bit too bright this cable might not be for you. Tried it with my Hegel amp and my tube amp. Crisp, Clear, Good Resolution, Dynamic. With my Hegel amp the sound becomes a bit too bright but with my el-34 tube amp it makes a crisp dynamic resolving sound. Maybe the base gets a bit less with this cable but the base will be less boomy but accurate and more tight. I think this cable is mostly about resolution in all frequency ranges. Very good I think!
nicolas s.
Le AIYIMA D03 est un très bon amplificateur classe D. Etant mon 4ème, celui-ci est le plus naturel et dynamique. Excellent, même à volume très élevé... Je l'utilise dans 25m2 sur un woofer SBAcoustics + tweeter à ruban + sub. La sortie sub passive est bonne, la sortie USB est largement supérieure à la sortie RCA. Je n'ai pas testé la Coaxiale ni l'Optique.
Comme il est dit dans un autre commentaire et sur certains forums anglo-saxons les basses sont fermes et profondes.
Une précision quand même, en le branchant la 1ère fois je me suis aperçu que les basses étaient poussées à +14db. Le S.A.V d'Audiophonics m'a fait savoir qu'il peut y avoir des modèles dont les réglages ne sont pas remis à zéro suite au contrôle qualité, donc à vérifier si vous évaluez votre D3 au premier branchement.
Bernard D.
SMSL PL200 Lecteur CD DAC AK4499EX + AK4191EQ USB XMOS Bluetooth 5.0 AptX HD LDAC 32bit 768kHz DSD512 MQA-CD Le SMSL PL200 est une platine CD/lecteur CD haute qualité intégrant un DAC AKM AK4499EX couplé à un filtre numérique...
Un best-seller
Sans surprise, un excellent produit. La définition aussi bien dans le spectre haut que bas est excellente. La puce AKM du Dac n'est certainement pas étrangère à cet excellent résultat. Très satisfait d'autant que la livraison (vers la Belgique) fut très rapide.
Bravo Audiophonics !
Lennart H.
AUDIOPHONICS U-SABRE PRO DAC USB 32Bit/384kHz SA9227 / ES9018K2M OTG TCXO Le fameux DAC Audiophonics U-SABRE évolue en version PRO, avec une mise à jour de ses composants principaux. Le décodage se fait maintenant grâce...
Audiophonics u-sabre pro dac usb
Super Perfekt
Dace P.
AUDIO-TECHNICA ATH-MSR7B Casque Haute Fidélité Symétrique 101dB 36 Ohm 5Hz - 50kHz Le casque Audio-Technica ATH-MSR7b vous offre la dernière technologie de casque haute résolution, associant les fonctionnalités avancées du ATH-MSR7...
Visuell fiasko
Le son est bon. En revanche, la finition est misérable. Les coutures sont tordues et inesthétiques. J'ai une photo, mais comment la télécharger ? En raison de la mauvaise finition, je ne recommande pas l'achat.
Hugues D.
SABAJ A20A 2022 Amplificateur Stéréo Class D Infineon MA5332M Bluetooth 5.0 2x170W / 1x350W 4 Ohm Le A20A 2022 de Sabaj est un amplificateur Class D stéréo puissant et performant. Avec ses 2x170W sous 4Ω, il vous permettra d'accompagner même les enceintes...
J'avais pour projet la recherche d'un "petit" ampli mono afin de driver une Triangle Secret LCR7, enceinte encastrable pour en faire une enceinte centrale.
En effet étant mélomane et cinéphile, je me voyais mal passé d'un ampli stéréo à un ampli full home cinéma. Ayant en front une paire de JBL 4312 MK2 et en back des Klipsch RP 600 M, un caisson Klipsch R-115SW le tout relié à un Yamaha RN 803 D, il me manquait pour une meilleure lisibilitée des paroles dans les films une centrale.
Mon choix c'est porté après plusieurs jours de recherche sur la SABAJ A20 qui semblait répondre à mes exigences et je ne suis pas déçu ! Relié en rca Out,
Le son est surprenant de clarté et de puissance ! Vraiment très plaisant à l'écoute en plus du boîtier en alu assez classe, élément important.
Merci à Audiophonics pour les informations claires et détaillées, l'envoi super rapide ! Je recommande !
Anthony M.
Libreelec
C'est le module qui manquait a mon raspberry pour le brancher à mon ampli Yamaha qui ne dispose pas de hdmi mais que d'une simple prise optique toslink.
Pour la configuration de Libre Elec il faut juste configurer le fichier config.txt avec l'overlay suivant (je le précise car je me suis fait avoir car la doc de hifiberry c'est pour un digi pas pro, du coup j'avais le son qui micro coupait toutes les 3s et en léger décalage)
dtoverlay=hifiberry-digi-pro
Mladen K.
ALPS
Very satisfied. Good price, fast shipment.
IFI AUDIO ZEN AIR PHONO Préamplificateur Phono MM/MC Avec le Zen Air Phono, iFi Audio propose un préamplificateur phono abordable et pour autant performant. Il vous permettra de brancher votre platine vinyle en...
Excellent pre phono a conseiller
Pour celui qui ne veut pas de prise de tête pour choisir un prérempli phono, celui-ci est parfait pour un système plus que correct.
Merci à Audiophonics pour l'envoi hyper rapide comme d'habitude.
Andrea T.
Filtre Jack DC 12V 3F à Supercondensateurs vers jack DC Ce filtre jack DC 12V à supercondensateur vous permet d'obtenir une alimentation propre pour vos équipements et appareils Hi-Fi grâce à 5...
Utilisé pour alimenter un routeur Fastweb.
Je retrouve une plus grande clarté dans le son avec Qobuz.
Rien de spectaculaire mais quand même perceptible à ce prix c'est fortement recommandé.
Vasileios K.
A great dac for the money
I really love the sound and the soundstage . Very natural sound and very good baseline
PIERRE A.
TBIEN
bonne qualité . Envoi très rapide , matériel bien emballé et bien protégé pour le transport
Jacques P.
EVERSOLO DMP-A8 Lecteur Réseau AK4191EQ AK4499EX XMOS XU316 WiFi DLNA AirPlay Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Eversolo  revient cette fois-ci avec son  DMP-A8 , un  lecteur réseau et DAC  de très haute qualité et d'une incroyable...
Expérience client au top
Emballage soigné , installation simple , prise en main intuitive et rapide ; c'est un produit exemplaire au niveau de son interface client et le son est au rendez vous ... Me reste plus qu'à en profiter et découvrir ou redécouvrir plein de musique!
Deividas S.
OYAIDE ACROSS 3000 Câble Haut-Parleur Cuivre 102SSC 2x2.8mm² Ø9.2mm Le câble Oyaide Across 3000 est maintenant disponible au mètre. Profitez de l'occasion pour améliorer vos installations audio personnalisées avec ces...
Deividas S.
Deividas S.
OYAIDE SGBN Fiches Bananes Plaquées Argent / Or 24k Ø4mm (Set x4) Les Oyaide SGBN sont des fiches bananes haut de gamme, permettant la conception de câbles HP haute performance. Celles-ci profitent en effet d'un double plaquage argent et...
Super quality
LAURENT G.
GUSTARD P26 Préamplificateur symétrique Discret Class A XLR RCA Noir Le P26 de chez Gustard est un préamplificateur / contrôleur de volume / sélecteur de souce (3 entrées) élaboré. Il fera le bonheur des...
Au bout de 4 mois d'utilisation
Les premières impressions positives se confirment. La transparence de la restitution et la séparation des canaux sont tout à fait remarquables. Les réglages de gains possibles 0, 6 ou 12 dB permettent une grande souplesse d'utilisation en fonction de la nature des sources et/ou des enregistrements. L'association avec un HPA-S 400ET forme un duo dont les performances sonores sont cohérentes avec les mesures et essais techniques que l'on peut trouver sur internet. Cependant, il ne faut pas s'attendre à une restitution systématiquement somptueuse ou flatteuse : les enregistrements sont reproduits sans fard. Les timbres peuvent perdre le charme que peut présenter un ampli à tubes (je le sais pour en avoir un). Mais le gain en terme de précision de la restitution est si flagrant qu'il est impossible de masquer les différences entre les sources numériques (en prenant le format CD comme référence) et les sources analogiques (radio ou phono). Les 30 à 40 dB de transparence supplémentaire qu'offre une source numérique ressort immédiatement.
Laurent G.
Jean-Pierre D.
Rendu très musical, fin et naturel
Je partage ce qui a été écrit précédemment, ayant le 1220 en version RCA monté par Néotech, l'ajout de connecteur argent et les XLR me semble améliorer la qualité d'écoute, c'est encore plus propre et transparent. Ce câble est étonnant, il peut se hisser à un niveau comparable des câbles haut de gamme de Cardas, Tellurium que je connais avec un tarif plus doux.
Pascal C.
bien mais...
j'ai commandé ce petit appareil pour avoir la possibilité de calmer un peu la partie médium de mon ensemble, c'est mieux en diminuant un peu les aigus mais il ne faut pas trop baisser au risque de perdre trop, un réglage pour les médium aurait été plus pertinent et j'ai vu trop tard que ça existait. concernant les lampes je n'ai pas remarqué un son plus chaud qu'avant, après un moment de chauffe par contre la scène sonore s'élargie un peu plus et c'est très bien, le rendu est plus doux. suite à ce que j'avais lu, j'ai laissé allumé une journée, résultat je ne le referai pas, je pensais qu'une fois une certaine température était atteinte l'écoute serait stabilisée ben j'ai trouvé le son encore plus agressif comme si l'appareil ne faisait plus effet, résultat je le coupe en même temps que le reste et ça va mieux. je pense que je testerai les autres tubes. j'ai fait une comparaison sur mon installation avec un autre modèle sans lampes mais avec réglage médium en plus, une catastrophe, medium utile mais même en laissant les boutons sur midi les voix étaient trop en retrait et son étouffé et en activant le bypass quelle claque, le son est redevenu vivant et les voix présentes. j'ai rebranché mon fx audio et c'est bien mieux quand même. les réglages aigus sont bien calibrés, mettre au milieu pour démarrer, le volume est bien aussi calibré pas de mauvaise surprise ( inséré entre un préampli Atoll pr200 et un ampli 3Dlab Nano ) surtout ne pas oublier l'ordre de la mise en route, à l'allumage fx audio en premier et ensuite le reste, et à la fin de l'écoute éteindre tous les appareils en premier et le fx audio en dernier sinon gros bruit dans les enceintes ( et ça fait peur ) .
Pascal C.
après en avoir testé un jeu, j'ai complété aves 8 autres pour relier petit à petit mon ensemble hifi et mon autre home cinéma. j'avais des cordons rel câble moniteur mais ceux-ci je les trouvais trop montant un petit poil agressif et fabrication un peu légère( obliger de mettre un petit coup de pince pour serrer plus sur la rca contrairement aux elecaudio , écoute moins agressive, plus de détails dans le médium et belle fabrication, fiches bien calibrées pour l'insertion dans les rca.
peu naturel ,metallique
Cable neotech cuivre argent mit sur ma play 4 ,son trop metallique ,fatiguant ,je le conseille pour l image ,pas pour le son!
Anthony C.
KECES P8 Alimentation Linéaire Régulée Ultra Faible Bruit 9 / 12V 8A + USB 5V 1A La Keces P8 est une alimentation linéaire régulée de grande qualité qui permettra à votre système audio haute-fidélité de...
Génial
Cette alimentation est génial, je viens de faire un bon en avant assez important niveau qualité audio sur mon lecteur réseau Antipode S30 grâce à elle, plus de dynamique, du silence en fond, un son plus naturel franchement je ne regrette pas mon achat et c’est en rodage en plus, je recommande fortement, jeté les alimentations à découpage et à deux balles qui sont si bruyantes et qui peuvent polluer les autres appareils aux alentour
Fabien B.
Fabien B.
Fabien B.
Fabien B.
Fabien B.
Support Magnétique pour Vis et Objets Métalliques Ø110mm Ce support magnétique est idéal pour accueillir vis et objets métalliques, afin de maintenir ceux-ci et ne pas risquer de perte. Le récipient dispose...
Fabien B.
Fabien B.
Très bon rapport qualité prix. A quand une version coudée sur Audiophonics?
Hocine H.
VIBORG GX16G Connecteur GX16 2 Pôles Plaqué Or Ø8mm Le Viborg GX16G est un GX16 à deux pôles. Ses contacts sont fait d'un alliage de cuivre plaqué or, assurant une bonne conductivité. Le corps du...
Bonne qualité, mais il manque un truc.
Connecteur de très bonne qualité, le soucis c'est que les pins sont trop proches du corps du connecteur, et comme il n'est pas fournit avec une protection isolante, celui-ci peut entrer en contact avec le point chaud si votre soudire est un peu trop épaisse.
Ce qui m'est arrivé, du coup j'envoyais du 48v sur le coffret de mon alimentation et par malchance, lors d'un changement de câbles RCA, un des connecteurs RCA est venu faire contact sur l'alimentaion, résultat, alimentation grillée, et carte d'alimentation de mon DAC grillée. Ceci est de ma faute, mais je trouve dommage qu'une marque comme Viborg n'ait pas pensé à ce genre de détail. Donc n'oubliez pas d'y ajouter un petit morceau de gaine thermo pour isoler le tout.
Hocine H.
BURSON AUDIO V7 VIVID PRO AOP Double (Unité) Évolution du V6 VIVID, le V7 VIVID Pro se distingue par sa clarté, sa précision et sa dynamique élevée. Il...
Magnifique
Ces Op amp sont extraordinaires de clarté, de précisions, de dynamisme, une réelle bouffée d'air frais dans la musique. C'est bien construit, solide et se plug et deplug facilement. Très bon achat, d'ailleurs j'en recommande une autre paire.
Hocine H.
AIYIMA A07 MAX Amplificateur Stéréo / Mono Class D TPA3255 2x225W 4 Ohm / 1x315W 4 Ohm Ce petit amplificateur Class D Aiyima A07 MAX possède la particularité de fonctionner aussi bien en stéréo qu'en mono pour...
Respectable
Ce petit ampli reste correct, même après une 50 aine d'heures d'écoute et alimenté en 48V 7.3A, c'est plat, sans. Je le garde en spare au cas où, mais n'en acheterai pas d'autre. Rien de comparable à un Fosi ZA3.
Michiel W.
Audiophile NAS linear power supply
I use this power supply for my audio NAS streaming to JRiver on my audio PC. The sound effect is more quiteness (as I hoped) but also a bit restriction or less freedom (which is not as I want).
Surprisingly, Spotify sound seems improved, better details and transparent low. Here the NAS does not do anything, it is Spotify running on the audio PC.
The stand-by power consumption is not specified, but it gets above 35 deg C doing nothing, so I am curious how long I am willing to pay the electricity bill.
Nicolas B.
PSVANE EL84 Tubes Série HiFi (Paire Appairée) Le PSVane EL84 est un tube de préamplification/amplification offrant de très bonnes performances. Ces tubes appartiennent à la...
A essayer...
Montées dans un ampli guitare bugera v22. Même pas 3h d'utilisation et c'est déjà très très bon. Très beau grain.
Toni S.
BEATECHNIK x LHY AUDIO LPS-A6 220V MK1 Kit Module Alimentation Linéaire pour EverSolo DMP-A6 Gen 1 Le module d'alimentation linéaire LPS-A6 a été spécialement conçu pour améliorer l'étage d'alimentation des lecteurs...
Tres bon
The better power supply raised the sound quality of the eversolo
DMP -A6 ME really a lot. I am happy that I bought it. The service was also good.
quel naturel!!!!!!
Bonjour ,cable qui remplace un 250 occ elecaudio sur mes concept20 , il est tres profond,doux, rapide, ouvert , on sent pas les enceintes c est naturel!!!! basse precises et seches! Pour l instant le meilleur cable hp que j ai eu ( qed revelation,mogami ,canare,250 occ, triangle,cabasse, ) a recommander
Didier T.
JANTZEN AUDIO CROSS-CAP Condensateur 400V 30µF Les condensateurs Jantzen Audio Cross Cap MKP 400V sont considérés comme étant le meilleur rapport qualité/prix pour la conception de filtres passifs...
Excellent rapport Q/P !
Adopté sur une correction // des boomers d'une paire d'EPOS Epic 5 en lieu et place de chimiques bipolaires basiques.
En effet, avant de me précipiter sur le changement des polypros en série avec les HP's, j'ai fait le choix de "nettoyer" en premier lieu ce qui est en général considéré à tord comme marginal avant d'aller plus loin.
Pour l'anecdote, les Epic 5 sont raccordées à un ensemble Nuprime DAC9X + STA9X eux-mêmes alimentés par un BADA LB6610.
Les Cross-Cap sont des polypropylènes métallisés (aluminium + zinc) la documentation constructeur ne dit pas s'ils sont non-inductifs.
Le résultat obtenu avec ces Cross-Cap est en l'occurence une sensation de "liant souple et aéré" accru, subtilement huileux avec moins de duretés.
La musique s'écoule avec moins d'efforts, de manière moins "carrée" et moins "in your face", au profit d'une sensation d'élégance tridimentionnelle.
Le ressenti de plus grande noblesse est plus que subtil.
Si je devais résumer mes sensations en quelques mots, je retiendrai "souplesse", "nuance" et "aération".
A ce tarif et dans cet usage-là, je ne lui voit aucun concurrent, seul de possibles manques de place sur les cartes des filtres ajoute un peu de difficulté à leur installation, le résultat valant nettement certaines contorsions d'installation.
Merci Jantzen, mention spéciale à Audiophonics pour ses délais de livraison tjrs aussi spectaculaires.
Didier T.
JANTZEN AUDIO CROSS-CAP Condensateur 400V 10µF Les condensateurs Jantzen Audio Cross Cap MKP 400V sont considérés comme étant le meilleur rapport qualité/prix pour la conception de filtres passifs...
Adopté sur une correction // des woofers d'une paire d'EPOS Epic 5 en lieu et place de chimiques bipolaires basiques.
Hocine H.
Neutre
Branché entre une box et un streamer Red Holo avec câble RJ45 Viablue et connecteurs Telegartner (longueur 1m), je n'ai pas ressenti de différence avec et sans, donc je le laisse. Pour cela 3* car je reste neutre comme ce filtre sur mon installation. Peut être est-il plus efficace avec des câbles plus long ou alors n'en ai-je pas l'utilité...
Julien R.
Déçu
J’ai suivi les avis utilisateurs et après les heures de rodage nécessaires et bien c’est pas ça.
Je gagne dans les aigus (précision) mais je perd trop sur les médiums et le grave. J’ai tout de suite remis les mullards (12Ax7). J’ai un ampli Cayin I170 (kt170) il faut un peu de douceur pour calmer la bête. Certainement pas le bon match pour moi.
Marco D.
The Fosi ZA3 is absolutely great if you consider the price tag.
The Fosi ZA3 is absolutely great if you consider the price tag. The build quality is very good and I also like the minimalistic design. The orange power/volume knob and the orange dust covers in the side ventilation are nice details. Inside are mainly components of pretty good quality. One little "complaint" is that I find the volume potentiometer a bit coarse in the low range. That means a small adjustment results in relatively large volume increase.
I use it at home in my setup for the first floor and I also bought it to take with me if I stay in a vacation home for instance. I "need" a certain minimum level of sound quality and these homes in general just have a TV to play music or a very poor stereo. I take my Fosi ZA3, a set of Eltax Monitor 3 speakers and a raspberry Pi with a DAC board on top. In this compact setup the ZA3 does it's job very good in terms of sound quality.
Jean-Charles G.
Superbe fiches
Ces fiches utilisées pour mes câble HP Elecaudio font merveilleusement le travail avec une finition irréprochable, et en plus les gaines Thermo sont livrés avec.
Merci à Mr Aubert pour son conseil.
Jean-Charles G.
Câble de Modulation XLR Femelle - XLR Mâle Plaqué Or CANARE L-4E6S 0.5m Rouge Ce câble de modulation XLR mâle vers XLR femelle profite d'une belle qualité de conception, utilisant un câble Canare L-4E6S. Celui-ci intègre...
Câbles fantastiques
Je possède ces câbles de modulation depuis bientôt un mois et ils font mieux que mes Viard Audio silver HD qui valent 800€.
Merci à Mr Aubert pour ces conseils.
