Serge P.
Avis
un Dac vraiment génial, livraison au top et réponse rapide sur une question technique, je recommande Audiophonics
Tomaž T.
Poslali ste popoln par. Činele spet zvenijo... Stare tube so samo še kričale, z novimi pa je poslušanje spet užitek.
jérome M.
bien mais...
Dommage que la section du câble n'est pas mentionnée dans le descriptif ; j'ai dû réduire l'épaisseur à la...
AUDIOPHONICS MPA-S125NCX XLR Amplificateur de Puissance Class D Stéréo NCoreX NCx122MP 2x125W 4 Ohm - avis - Il y a 14 avis.
Szilard S.
Audiophonics is the Mecca of Class D!
The second one has just arrived, I have been using the first one with great satisfaction for over a year. It is no exaggeration to say that this is a game changer. It is worth entering the world of Ncore amplifiers with this one, I guarantee that no one will regret it. This amplifier beats many of its competitors on the market with its cheap price. A third amplifier is also planned for the two subwoofers, I think I will order a Purifi amplifier next time. I think the Purifi will provide enough power for the two subs. Once someone tries the quality Class D, they will not want anything else. The sound is wonderful, accurate and transparent. You can practically set the sound for yourself according to the preamplifier you connect in front of it. Be it a DAC or a preamplifier, you can also use tube buffers, there are many variations. I myself use a MiniDSP Flex HT processor in front of the power stages, I use my speakers with active tone switching, there are no passive components. The sound is heavenly, you can create any sound with the processor, delay, crossover frequencies, PEQ... very flexible. Congratulations to Audiophonics for their wonderful products! I am a returning customer and have become addicted. Thank you!
Baptiste B.
parfait
Je débute une installation hi-fi qui évoluera, il en est la première pièce.
Niveau puissance, c'est génial, je n'avais jamais entendu sonner mes Focal cobalt 806s aussi bien dans le grave, la partie aiguë devenue plus douce et moins fatiguante, elle s'accorde bien est les enceintes focal et leur tweeter.
Je l'utilise avec une carte son Beringher.
Ce que je retiens, c'est l’absence total de souffle avec cette configuration. Niveau rendu, je ne connais pas bien la carte son Beringher et son influence.
Prochaine étape, un dac avec réglage du volume :)
Lucio G.
Ottimo
Ho da poco una coppia di Klipschorn e sto facendo vari esperimenti. Il suono con questo ampli, con un pre Primare prisma35, e' finora il migliore: la definizione e la pulizia dello s125 ben si sposano alla incredibile naturalezza delle klipsch che, con altra amplificazione ab (NVA) e Copland ( push pull di el 34), suonano, per i miei gusti, fin troppo "organiche", con i bassi un po lunghi. Insomma lo S125 asciuga il giusto il suono e.rende i bassi molto meglio definiti e controllati. Il tutto senza nulla di asettico o freddo...il rapporto qualita' prezzo e' incredibile!
Hervé C.
Etonnant rapport qualité prix.
Un équilibre tonal parfait (surprenant quand on sort d'amplis "classiques", toujours un peu typés), une dynamique "réaliste", une écoute très précise. Les basses sont percutantes et présentes sans abus mais manquent un peu de délié et de différenciation. Scène sonore très précise et focalisée mais manquant un peu profondeur et d'"enveloppement".
Pour l'instant associé en direct à un SMSL Su-9 avec des XLR Mogami 2549 et alimentant des Acoustic Energy Aegis Evo3 (colonnes 2,5 voies), je songe tout de même à intercaler un préampli ou essayer un autre câble pour gagner un peu en densité et améliorer la rondeur des basses.
Rapport qualité prix quand même particulièrement étonnant.
Aziz A.
Très bien qualité / prix
J’ai remplacer mon ampli smsl ad-18 pas cet ampli et je suis très content les basse sont plus profonde accouplée à un DAC RME adi-2 et des enceintes Dali obéron 3 le rendu est vraiment bon
Egon B.
Great
Between DAC/Preamp and Triangle bookshelves. Noticeable improvement in base, soundstage, clarity and detail over similarly priced class A/B integrated amplifier.
Szilard M.
Beautiful sound
This is the first time I ordered this Hypex module based amplifier of Audiophonics and I don't regret it. It arrived into to a luxurious home's audiophile system and the owner (a friend of mine) was blown away by the quality and cleanness of sound. Excellent product, thank you Hypex, thank you Audiophonics.
Stephane N.
Excellent ampli qui malgré la faible puissance sous 8 ohm (avec une distorsion acceptable) fait bien fonctionner des SA 2K pourtant "gourmandes".
Pas de déséquilibre entre haut et bas et grande transparence.
Associé à un S.M.S.L 300, en symétrique et des câbles OYADE Explorer en HP, c'est peut être pour moi l'ampli définitif ...
Gustavo O.
Excelent
In my 18m2 room this sounds great, neutral, amazing bas.
Guillaume F.
Impeccable
Acheté pour remplacer un SMSL SA-50, il a parfaitement rempli son rôle. Construction sérieuse, le bouton face avant est pratique, avec un éclairage LED blanc sobre quand il est allumé. C'est tout léger, et ça ne chauffe pas. Assez profond par contre, vérifiez bien les mesure. Beaux borniers.
Côté musique je ne vais pas m'embarquer dans des qualificatifs ou comparaisons peu utiles. Ca sonne très bien, très précis & dynamique, mais surtout, élément objectif : disparition intégrale du bruit de fond que j'avais avec le SMSL. Là rien, nada, silence total, c'est ultra propre. Rien que pour ça l'upgrade valait le coup, et je conserve l'efficacité énergétique du classeD dont j'aurais maintenant du mal à me passer (l'ampli est allumé toute la journée).
Pour info associé à un SMSL M500 en XLR, aucun souci. Ca alimente des Dali Menuet haut la main : j'oscille entre 01 et 11 de volume sur le SMSL (sur 40 Max je crois). Il faut juste faire attention à éteindre l'ampli avant le DAC pour éviter un méchant plop.
Et le "logo made in france" fait plaisir même si on sait d'où vient le module principal ;)
Simone E.
Excellent Amp
I bought this amp in order to replace a TA2024 based amp (that I consider a giant killer amp). In comparison the ncore amp has both more power and more neutral sound. Furthemore it is detailed and fast as the best digital amps are. I fed it with a smsl m500 (as preamp dac) and the result satisfied me at all.
JUAN MANUEL H.
el mejor precio
Precio excelente.
La caja está bien pero la forma es un poco rara.
Envío rápido.
El sonido es lo que cabe esperar de este módulo NCore. Muy transparente, potente y refinado. Lo uso con un rme adi2 dac por xlr y apenas necesito subir el volumen. Los graves son muy definidos pero comedidos en cantidad. No sé cómo sonarán los monofónicos de 400W con módulos SMPS, buffers de entrada etc, pero este amplificador económico suena muy bien. En general es un sonido de gama alta. Potencia? Con el rme a -15dB tiemblan las paredes y aún falta mucho volumen por usar (monitores de 88dB). Sonido limpio. No entiendo para qué más en la mayoría de los casos. Hay que tener en cuenta que por xlr suena más potente que por rca. Habitación de 15m2.
 (3)
Jean-Pierre P.
Peut-être mes amplis définitifs ?
Sur un système haut-parleur hautement discriminant*, ils comblent mes attentes et se distinguent de mes amplis précédents par une absence totale de bruit de fond, une très grande dynamique et beaucoup de pouvoir analytique. Je craignais un rendu froid mais il n'en est rien. Je découvre ici les qualités vantées des unités NCore de Hypex.
Le boîtier n'appelle aucun reproche de ma part, sobre et inspirant confiance dans sa confection; une très belle connectique.
*Linkwitz LX521.4 quadri amplifié
Roberto C.
Fully satisfied
Excellent and fast service, and the quality I expected from an nCore amplifier
Version XLR du Audiophonics MPA-S125NCX. Un amplificateur de puissance Class D basé sur la technologie Hypex...
