Gianfranco P.
crystalline
Alexandre G.
Thierry C.
Avis clients - Il y a 19516 avis.
Didier G.
Critique cd Tempo
Appareil plutot satisfaisant : en terme de qualité. commande d'ouverture de plateau particulierement douce, boitier de telecommande agreable
Seul petit reproche, la commande de volume est inoperante lorsque l'on branche un convertisseur!
Yiorgos P.
Matches perfect in my downfiring handmade sealed wooden cylinder, with an internal volume about 20 liters
Charles B.
diamètre de perçage...
le diamètre mentionné de 10.5 n'est pas suffisant. Mes collerettes font plutôt 11.2mm. A savoir si on commande sa face arrière chez Frontpanel et que l'on doit ensuite agrandir ou angler tous ses trous.
A part ça bon produit pour le prix !
Patrice V.
je suis satisfait, aspect visuel impec.
très bonne gaine. résiste bien au chauffage gaine thermo.
Adam C.
Adam Ch
A little quirk with FI-06 you may want to pay special attention to.
I would advice to do a "dry run" wire assembly prior to final installation.
You have to make sure that the resistance you're feeling under the screwdriver is from thightening the wire and not from reaching the end of the tread.
Out from the box, FI-06 probably works well with wires in 6mm² - 8mm² range and up.
You need a certain minimum volume of wire in order to tightly secure it with the screws.
FI-06 will not hold 2,5mm² or 4mm² well, as the screws do not reach the bottom of the opening, ( not to mention cutting through the strands of the wire... horror... )
I found a solution to it, which may actually give a much more expensive FI-09 a run for the money and gives FI-06 ( and possibly many other connectors and plugs ) a terrific advantage.
Use a short piece of 2,5mm² solid core regular electric wire ( in case of FI-06 it has to be this exact gauge 2,5mm² )
Remove the insulation, bend the wire in the middle and form a tight long U shape.
with the plyers squeeze the two legs toghether so they run parallel to each other and touch each other as well.
This now becomes a pressure plate that fits quite nicely between the screw and the wire to be installed.
You may want to trim it to the total length of 10mm -11mmm.
It prevents the screw from cutting the strands of your wire and also the strands from going up, to the sides of the screw.
Works like a charm.
Can't really speak of sonic merits of FI-06 as I'm upgrading simultaneously several elements in the same time and pinpinting IEC connector becomes impossible,
however given my past good experience with Furutech products, also based on the description ( alpha treated pure copper ) and now with the screw problem solved, I would be very very surprised if this connector did not perform as expected. Very solid and precise built. Possibly worth every penny.
5 stars for the tweaked version,
4 1/2 stars for out of the box untweaked one ( why should I be tweaking it and not Furutech ? )
Dalibor M.
DM Audio
this VB X-40 cable tends to clarify the sound
pushes stereo components into even better space
great satisfaction with the X-40
Michel D.
Produit conforme à mes attentes, livraison impec.
fabrice j.
tres bon cable d'un excellent rapport qualité prix .
PIERRE R.
Amélioration qualité soudure .
Résultats exceptionnels en clarté ,fluidité , dynamique et micro informations en refaisant toutes les soudures des câbles liaisons ainsi que des fils véhiculant les signaux audio dans l'intérieur des amplis ,préampli et lecteur CD/SACD .
Jean-Marc B.
AUDIO-GD MASTER 10 2019 EDITION Amplificateur Class A Symétrique ACSS 2x 500W 4 Ohm L'Audio-GD Master 10 est un impressionnant amplificateur intégré symétrique en Class A, capable de délivrer une grande puissance pour accompagner les enceintes les plus exigeantes.
Excellent RQP, mais quand même ...
Aucun doute, pour le même prix, les amplis des autres marques font pâle figure à côté du M10. Mais quand même il ne faut pas exagérer.
J'ai acheté cet ampli pour remplacer un vieil Audio Analogue Grand Intégré. C'est un ampli double mono de 52 kg, qui se vendait dans les 4000 € dans les années 2000 (équivalent à 5000-5500 € d'aujourd'hui). En comparant les 2 amplis, je dirai que le M10 est un peu meilleur en fermeté du grave et en dynamique, mais que le AA est plus naturelle, et surtout respecte mieux les timbres des instruments. Le M10 parait parfois un peu crispé sur des violons ou des cuivres. Ma femme m'a dit que le nouvel ampli est pas mal, mais que le vieux avant plus de corps.
J-C- P.
Redoutable
Ce câble est tout à fait surprenant à plus d'un titre. Tout d'abord, son poids et sa conception de qualité forcent le respect. Placé derrière un boitier TV ou un démodulateur C+, son action est immédiate. L'image s'améliore aussitôt avec une colorimétrie et un contraste accentués. Son action se fait même sentir à distance si on le place derrière le boitier Adsl ! De surcroît, les améliorations s'additionnent si on utilise deux câbles (1 sur le boitier Adsl et 1 sur le boitier Tv) ! Cerise sur le gâteau pour le son, tout est plus consistant et notamment au niveau des graves. NB : Il est important de mettre en phase tous les appareils branchés sur la même prise électrique afin d'obtenir le meilleur de ce câble.
J-C- P.
A recommander vivement
Améliore incontestablement le son des enceintes notamment sur un sol carrelé ou sur un parquet. On retrouve de fait un message musical expressif, puissant, libéré et surtout, pour les graves, sans effet de trainage notoire.
Certainement les meilleurs
J'ai attendu quelques dizaines d'heures de rodage avant d’émettre un avis...et ces tubes sont tout simplement sublimes par le son et ce qui ne gâche rien par le look.
Ils sont couplés avec ses petites sœurs en pré ampli : PSVANE 12AX7-T ECC83 Tube Série TII
C'est vraiment un duo gagnant avec un son chaleureux, des médiums fouillés , des basses rondes et des aigus pas trop agressifs.
Auparavant j'ai utilisé les excellentes Shuguang Treasure 6CA7-Z qui elles aussi ont ce revêtement intérieur, mais les PSVANE sont un ton au dessus.
Ce revêtement n'est pas de la peinture mais du carbone cristallisé (Breveté) sensé améliorer l'absorption des électrons aléatoires à l'intérieur du tube.
Je n'ai rien contre les tubes dits NOS des années 50, mais je pense que ces générations de tubes étudiés avec les moyens technologiques d'aujourd'hui sont nettement meilleurs.
Sur des forums américains, on peu lire que ce sont peut être actuellement les meilleurs tubes de puissance, et je le pense aussi.
Aux USA ces tubes sont vendus 150$ plus chers, alors ne vous privez pas. Le tarif de ce site est plus que bon.
Ps pour Audiophonics: n'en profitez pour les augmenter.
Herve G.
ajustement self Mundorf L300
Très bien informé de la progression du traitement de ma commande. Économique car cela permet de ne pas commander plusieurs selfs pour obtenir l'inductance désirée et de simplifier le montage du filtre sans risque d’influence entre selfs.
(Le colis chrono-post a été délivré à la poste et non dans ma boite aux lettres !)
Ivano P.
End of the games
To me the amplification issue is solved whit this device.
Thanks to Audiophonics that make accessible this great technology at fair price.
Michel P.
Câble OTG USB-B Mâle vers Micro USB Mâle 15cm Ce câble USB OTG de très bonne qualité intègre des conducteurs en cuivre OFC et des connecteurs (USB-B / Micro USB) plaqués Or. De plus, étant OTG vous pourrez l'utiliser pour...
De beaux composants bien assemblés. Fonctionne parfaitement pour récupérer signal audio numérique sur prise USB d'un smartphone Samsung.
Petit bémol : J'aurais préféré que l'alignement des deux prises soit décalé de 180° mais la rigidité du câble n'autorise aucune torsion de celui-ci.
Michel P.
Bel usinage, très belle finition , très bon contact électrique. Un adaptateur qui sait se faire oublier.
Michel P.
Beau produit
Très belle réalisation.. Utilisé pour raccorder un potentiomètre AUDIOPHONICS M1 contrôleur de volume Analogique. Ça fonctionne parfaitement.
Michel P.
Utilisé pour ajuster le niveau d'un second casque en sortie d'un ampli casque à lampes équipé de 2 sorties. Ça fonctionne parfaitement sans dégradation audible du signal. Très satisfait de cet achat.
Damien M.
Équilibre, très bien.
Satisfait, je vois la différence avec mon cable d'origine. Pour un essai de cable "audiophile" je suis content. J'ai gagné en naturel, en définition, en détails, en nuances, en équilibre(transition aigu médium était moyen sur mon système, mieux maintenant) , que demande le peuple ? Je ne sais pas si un cable moins cher aurait fait le job pareil, mais là j'ai pas besoin de plus. (pas fan de la couleur rouge du plastique mais c'est secondaire)
ELECAUDIO TE-RC90G Connecteurs RCA Cuivre Tellurium Or Ø8.5mm (La paire) Ces connecteurs ont été conçus pour vous offrir une très grande conductivité grâce au Cuivre Tellurium.
cable HdG
j'ai besoin d'un câble de modulation de qualité, pour faire la liaison entre mon préampli et mon ampli.je suis venu chez Audiophonics, et après recherche, et lecture d'Avis, j'ai trouvé. connecteurs RCA Elecaudio TE-RC 90G et câble Neotech NEI- 3004 symétrique OCC. commande faite le 12, colis livré le 14, bien emballé, pas de problème, au déballage, les produits de qualité bien conçus. les connecteurs sont a souder,( surtout le point chaud) et avec la petite vis de serrage, appuyer , pour le contact avec la masse. montage suivant : j'ai tracé sur la gaine rouge, la cote nécessaire, pour le montage,22/23 mm. couper la gaine rouge doucement , l'enlever, défaire la tresse, doucement avec une pointe de compas, un coup a gauche, un coup a droite, jusqu'àu bord de la gaine. Couper avec une petite pince coupante les fibres de remplissage, dénuder les fils rouge et bleu, les vriller ensemble, la tresse défaite, lui faire faire plusieurs tours bien serré, mettre les deux fils a plat, partie ensemble, dans le point chaud, visser la vis de serrage doucement et souder. faire glisser la partie noire du RCA, sur le câble et visser complètement, faire pareil sur les autres bouts, et contrôler au multimètre si le point chaud ne siffle pas avec la masse. les inscriptions en doré sur le câble ne sont pas très visible, avec une lampe mettre les flèches dans le même sens, et coté départ, mettre un morceau de gaine thermo de couleur claire, tenant les deux câbles, et tracer au feutre une flèche; plus de problème. La je redécouvre mes CDs,et les autres entrées, tuner, TD. Que du bonheur, tout est la, présent, ( mais pas projeté ) bien en place, en largeur et profondeur, l'image est meilleure, plus de définition, c'est un plaisir, et surtout, c'était faire un câble, pour savoir si les éléments utilisés sont de qualité ? EH bien OUI, allez y ne vous gênez pas, car pour moi c'est un début, je vais aller plus loin. la rénovation que j'ai fait sur mon ensemble HK citation 17 et 12, avec des RCA Audiophonics, étaient bien, mais en laiton doré. prochaine étape chgt des embases RCA ,par des cu/te or, sur les sorties de mon préampli, et les entrées de mon ampli, et les borniers HP. Et après quelques entrées du préampli, et les sorties de mon CD MARANTZ qui n'est plus sous garantie. Sans changer mon matériel, je vais monter en gamme… et sans me ruiner. merci AUDIOPHONICS si vous avez du matériel vintage n'hésitez pas, le jeu en vaux la chandelle. PS : il y a des sceptiques, sur les flèches, ou la notion de sens d'un câble, le constructeur ne fait pas cela pour "frimer" mais sa fabrication est faite en faisant avancer le cuivre, afin de maitriser l'alignement des cristaux de cuivre OCC. de cette opération découle les flèches. trop de gens disent que le cd est froid, c'est faux ,simplement nous avons trop de fainéants qui veulent faire des enregistrements a la vas vite pour gagner des pépettes, donc il y a des mer… un bon câble ne rendra pas un mauvais cd, bon…. pi.r
AUDIO-GD PRECISION 3S Amplificateur Class A/B Stéréo Discret ACSS 2x70W Le PRECISION 3S d'Audio-GD est un amplificateur de puissance possédant un étage d'entrée et de gain Class A symétrique arborant une conception...
Petit rectificatif à mes précédents posts…
Après l'avoir testé sur des enceintes plus délicates à alimenter, ce Precision 3 avoue finalement assez vite ses limites.
Aussi, mieux vaut le réserver, si non bridgé, à des enceintes de 90dB mini et, si possible, d'une impédance moyenne supérieure à 4 ohm.
Sinon, les basses fréquences deviennent mal contrôlées, et la précision (!) générale régresse (baisse de netteté et de dynamisme).
Gilles D.
Ce produit permet de réaliser les transformateurs de vos rêves !
Produit de qualité. Délai un peu long mais j'ai commandé fin avril :-) et en plus j'ai demandé 6 transformateurs d'un coup.
En tout cas Audiophonics m'a tenu informé de l'évolution de ma commande.
Parfait pour réaliser un ampli à lampes qui requière des hautes tensions.
Andrea S.
nCore Technology rocks !
I would like to spend a couple of words about this amplifier. Being it based on a new concept and being nCore technology something really new, especially in terms of the mathematical theory behind its design that has been recently formalized. I have a real passion for audiophile devices and even if I didn't have the possibility to buy very expensive rigs I had the possibility, along the years, to test several devices passing through the complete digital audio revolution started in the 80s. I don't have the ability of the perfect pitch and I'm not the kind of audiophile that spends one million words speaking about the music planes, the perspective box or other amenities or buys a 1m mono signal cable costing 1000€. What I have to say is that this amplifier really doesn't sound.. it doesn't sound at all, it simply amplifies the signal for your speakers. This could seem a very minimal statement but it's not actually ! I always
had the impression, with ALL the amplifiers I tried before in this 40 years, that there was a kind of "alias" following the sound, something like a "noise" modulated by the main signal that was superimposed to the real sound. In some amplifiers this "coloration" was less evident in some others was more but it was ALWAYS there. I was blaming the speakers, I was blaming the digital conversion but I couldn't really tell what it was causing it. Now I know, it was the amplifier ! This amplifier really amplifies only the sound you put at its inputs and doesn't generate this distorted alias that ALL the units I tried before
were adding. This "alias" has nothing to do with harmonic distortion or intermodulation stuff since I tried amplifiers with very nice numbers in this respect and it was the same. This is the first time in my life that I find an amplifier that is completely transparent. You can easily spot this because typically the
superimposed noise of other amplifiers was masking partially or completely the very subtle ambience-related echo signals, with this amplifier the sensation of reality instead is increased a bunch. Also the voices (that typically are causing a lot of the alias signal I was mentioning in other amplifiers) here are
reproduced with a very high degree of reality and you can easily grasp any nuance. The bass is hugely deep and very precise and clean. The absence of the alias allows you also to appreciate subtle sounds in the music that with other mplifiers are inaudible. The difference in the reproduction of songs I know very very well and the absence of this distorted alias is very evident and audible with exactly the same setup of source, cables and speakers changing only the amplifier. The alias noise I'm speaking about is mainly generated in the mid-high frequencies so, its absence, could seem to make the sound "dull" if your speakers have a very linear response on the high frequencies and you're used to amplifiers producing a lot of this alias sound. Nevertheless the amplifier reproduces the high frequencies with a very high control and an impressing cleaness. The sound of the trumpets and the piano are incredibly detailed and "real". In short, this amplifier is really of another league for me respect to anything I heard before. Let's come to the two only small issues I would like to pinpoint. The first one: there is a transient noise made by the amplifier when switching OFF that is clearly audible in the speakers. It's not loud but it's audible. It's mainly mid and high frequencies (woofers are not moving at all). This happens if the amplifier, after being switched ON, is not run for at least 10-15 minutes with music. The issue is related to the amplifier board, Hypex knows about it and they're working to a solution. The second drawback is the heat produced by the unit. nCore Class D amplifiers are VERY efficient and the on-board SMPS is very efficient as well, nonetheless a certain amount of heat is
produced when the amplifier works. In this implementation of the amplifier the only heat dissipation is provided by the aluminium box since there are no external/internal heatsinks. Running the amplifier at an average volume (in an apartment) for an extended period of time with an ambient temperature of 25-26°C makes the amplifier box gets warm. I don't know what could happen to the temperature of the amplifier in hot environments if the amplifier is run near its limits. In a domestic envrionment however I don't anticipate any issue with heat dissipation. Do I recommend this amplifier ? Well I bought two !! draw your own conclusions :-)
philippe B.
DAYTON AUDIO ND16FA-6 Haut-Parleur Tweeter à Dôme Soie Néodyme 10W 6 Ohm 88dB 3500Hz - 27kHz Ø1.9cm
DAYTON AUDIO TCP115-4 Haut Parleur Bas Médium Papier 40W 4 Ohm 87dB 55Hz - 5000Hz Ø10cm Ce haut parleur DAYTON AUDIO 115-4 posséde une fréquence de coupure à 54Hz pour 100mm de diamètre. Il est tout indiqué pour des enceintes deux voies compact et de qualité....
WONDOM AA-AB32178 Module Amplificateur TPA3116 Class D 2 x 50 Watts 4 Ohms
bien
Andrea S.
Volume Controller / Source Selector
The device is very well assembled and the feeling of quality is high. Also the aluminium box with the front panel of polished black aluminium held in place by allen screws has a very professional look. Volume potentiometer rotates very smoothly with absolutely no noise being introduced in the audio signal and the source selector has very precise rotation marks so the overall feeling is the one of a very good quality product. The balance between Left and Right stereo channels of the audio volume at very low levels is good as well confirming the quality of the logarithmic potentiometer by ALPS. Since this is a passive preamp we cannot speak about "sound quality", however I can say there is no noise or hum being picked up by using this unit even if RF devices are placed in its vicinity so its shielding is very good and the internal wiring must have been properly routed. The only real drawback of the unit is its price that, unfortunately, is not cheap, especially considering that there are no active components inside it and consindering that its form factor is not the typical "big" one with a box 43cm wide. However, if you need a passive preamp built with very good components and you don't mind about the size of the box (or maybe you even want it to be the smallest possible) I would certainly consider this small passive preamp.
Jiri G.
TINYSINE CSR USB-SPI Programmateur pour Puces Bluetooth CSR Cette carte TinySine CSR USB-SPI vous permettra de programmer vos puces bluetooth CSR. Ce module dispose d'une bien meilleure vitesse de téléchargement qu'un...
It works
No problems, I could recommend.
Laurent R.
Câble de très grande qualité à un prix imbattable. Entièrement satisfait par cette achat.
Laurent R.
Reçue rapidement, produit très bien emballé visiblement de grande qualité.
J'avais de simple câbles Monster mais la mon système est transfigurer. Satisfait de mon achat.
Didier L.
MATRIX X-SPDIF 2 Interface USB XMOS U208 32bit / 768khz Coaxial-AES/EBU I2S HDMI LVDS La nouvelle interface USB vers SPDIF et HDMI Matrix X-SPDIF 2 est une relecture totale et non une évolution de l'ancienne X-SPDIF. De part ses caractéristiques...
Enfin le produit que j'attendais
En sortie USB du mac avec Audirvana le résultat est parfait avec un cable RCA SPDIF CANARE en entrée de mon DAC.
La qualité de fabrication est exemplaire.
La terre est reliée en entrée USB (apparement nécessaire pour obtenir le 32bit/768khz), mais bien isolée en sortie RCA et en sortie AES/EBU.
Je n'utilise pas d'alimentation auxiliaire pour le moment ni la sortie I2S HDMI.
Didier L.
Court-circuitant
C'est bien précisé, les caches sont court-circuitants. Ne pas utiliser sur les sorties des appareils. La pin centrale se dévisse, on peut donc dans ce cas l'utiliser en entrée et sortie.
Didier L.
Capuchons Bouchons anti-poussière métal pour XLR mâle et femelle Protégez vos entrées XLR mâles et femelle de l'oxydation et de la poussière lorsqu'elles ne sont pas en service. Idéal pour limiter la dégradation des circuits électroniques.
Mise à la terre
Attention pour la prise mâle, la pin 1 est reliée au chassis. Ne pas utiliser en sortie d'un appareil.
Claude B.
Déçus
Excellent produit, son détaillé et plus, commutation d'entrées agréable. MAIS :
* livré avec les sorties en opposition de phase : câble de liaison inversé
* carte mal découpée qui est du coup montée de travers et empêche le vérouillage correct des fibres optiques.
Certe j'ai acheté ce produit en promotion, et ces petits défauts sont facile à corriger; mais est-ce une raison pour fourguer des produits défectueux ?
José L.
J'ai acheté ce d'ongle en complément d'un casque Bluetooth momentum de chez sennheiser, l'ensemble fonctionne parfaitement et la diféfence en Bluetooth ou filaire n'est pas audible.
L'aptitude rempli parfaitement son rôle.
Frederic V.
DAYTON AUDIO ND140-4 Haut-Parleur Bas Médium Aluminium 40W 4 Ohm 88dB 54Hz - 8000Hz Ø13cm Le ND140-4 est un amplificateur type médium graves appartenant à la série NEO de Dayton Audio. Moderne et résistant, il exploite un cône aluminium cerclé de gomme pour maintenir...
Bon petit HP
J'ai acheté ces HP's pour réaliser une paire d'enceintes 2 voies compactes à un prix raisonnable.
Le HP est de bonne facture, donne de bonne basses pour un HP de ce diamètre, ils encaissent bien a puissance !
Je recommande ce HP fortement !
Fred.
Arnaud F.
FURUTECH TF Fusible Cuivre OFC Plaqué Rhodium Type T Lent 5x20mm 0.5A Furutech propose avec sa gamme TF des fusibles temporisés semi-lent d'exception. En effet, la marque y intègre des composants de très grande qualité...
Plus de transparence et de précision mais...
Comme tous les fusibles audiophiles, l'apport en transparence ou précision est réel et bienvenu mais dans le cas de ce Furutech, essayé sur un lecteur CD HDG ou un ampli-préampli HDG, la musicalité est moindre qu'avec le fusible d'origine (évidemment essayé dans les deux sens !). Cela dit, je suis convaincu maintenant qu'un fusible Furutech apportera beaucoup à de très nombreux systèmes par rapport au fusible d'origine. J'hésitai donc entre trois et quatre étoiles.
antoine L.
AUDIOPHONICS PSU-HC Alimentation Linéaire régulée ifi Audio Pro iCAN 15V 5A 100VA Cette alimentation linéaire régulée 15V 5A avec deux sorties sur jack 5.5/2.1 & 5.5/2.5 est dédiée pour les appareils audio HiFi nécessitant une alimentation propre et soignée.
alimentation 15 volts 4A
avant de faire l'achat d'une alim , ou autre option, l'on a toujours un doute sur le résultât final,
c'est vrai que dans les années 1970 ( il me semble) des gens comme Naim ou autres avaient adoptés cet option, cela permettait de faire évoluer leur matériels, pré amplis ou amplis,.......
si le schéma d'un ampli, d'un pré ampli, ou d'un Dac est abouti, bien construit, pourquoi en changer, plutôt que d'y adjoindre une alimentation de qualité, ( surtout si le materiel est évolutif ) disons mieux construite, mieux filtrée plus conséquentes, plutôt que des alim genre PC portable qui n'apporteraient pas le courant suffisant pour exploiter au mieux un materiel audiophile, à l'achat et déballage d'un materiel l'on croit avoir trouvé la " pépite " que l'on cherchait, et surtout dans le résultat final n'est pas toujours entièrement satisfaisant,
en faisant l'achat de cette alim régulée, et c'est ce genre de résultat auquel je souhaitais bénéficier et le résultat final à dépassé la petite amélioration auquel j'avais espoir, l’amélioration a été un résultat bien plus flagrant, avec un résultat d'écoute bien supérieure à l'origine, tout les intervenants ( chanteurs, musiciens ) gagnent en précisions, localisations, présences, transparences, recul du bruit de fond, c'est comme une monté en gamme du materiel, qui aurait coûté bien plus cher, que le simple prix d'une alim,........à ne pas négliger,......
bruno n.
Pas audiophile
Câble standard. Rca standard.
L’objectif était de remplacer une rallonge en 3 morceaux
Grado 6,35 mâle femelle
Quel adaptateur 6,35 vers 3,5
Audioquest mini jack vers rca
le tout pour attaquer un ampli depuis un preamp en jack 6,35.. Bref le câble unique de cette gamme sommer câble donne un résultat plus terne que les « morceaux » plus typés audiophile. A mon avis c est un matériel plus destiné aux branchements pro qu audiophile. Dommage qu ils ne proposent pas un tel câble sur leur base « stratos » . Celui ci ne m a rien amené. J ai gardé ma rallonge grado+audioquest.
bruno n.
Usb3 supérieur
Difficile de trouver de l usb 3 de qualité plus audiophile que les câbles de base usb proposés avec les Dac mobile.
Après avoir envisagé du wireword, celui ci m apporte un plus audible dans la transparence principalement au niveau des aigus . Je trouvait mes tannoy légèrement ternes sur ce point, et ce câble a amené quelques micros détail mais surtout un chouilla d aération et de transparence dans le haut du spectre.
bref mieux que le câble bleu d origine (dac ifi) sans etre exorbitant...
A essayer..
Jean-Patrice H.
Vraiment bluffant
Ayant disposé, il y a quelques années d'un gros ampli de puissance en classe A qui représentait le nec plus ultra en matière de reproduction sonore, je ne m'attendais pas à écouter un son aussi excellent, et ce malgré les commentaires lus, que celui de ce petit AD18. Bravo! Je recommande cet ampli à tous ceux qui veulent avoir une véritable qualité hi-fi.
j'ai entrepris la réalisation d'un cordon rca avec ce câble de modulation. Le son semble plus dynamique, plus détaillé et gagne en clarté dans le haut du spectre. Le câble est un élément de la chaine aussi, et ce n'est que mon avis, je le conseillerais avec des électroniques plutôt douces
Ces connecteurs sont de très bonne facture et assurent un serrage très fort, de plus ils sont esthétiques et ajoutent un look très chic au cordon. Seul petit souci qui doit malgré tout rebuter personne, les soudures de la tresse et de la masse ne sont pas des plus aisées.
Fichtre les fiches
Non mais vraiment, quelle galère ces fiches DIN ! Qu'est ce qu'on n'est pas allé inventer à l'époque! Un bon bornier à visser c'était plus simple quand même. Mais non. Bref, j'ai été obligé d'acheter ces fiches pour faire des cables compatibles avec un vieil ampli qui n'accepte que ça. Un peu galère pour les monter car les trous n'acceptent que du 1mm2 max. Par ailleurs, le cul des fiches n'est pas un simple trou comme sur l'image, mais une espèce de tresse plastifiée d'1cm+ environ, solidaire du corps de la fiche. Ce système est archi nul, mais les fiches sont ok, même si le plastique me semble un peu mou. Un conseil, faites des cables exprès pour ces fiches en mettant des bananes ou des fourches à l'autre extrémité.
Avis limité
Cable souple et bien construit, rien à dire là dessus. Concernant ses qualités audio, je n'ai pas encore d'avis mais je ne l'ai pas acheté pour faire la différence entre une source à 5000€ et une autre à 50000€. Non, je devais faire de nouveaux câbles et j'ai pris Mogami, comme j'aurais pu prendre Sommercable. Sa structure le rend assez compliqué pour faire des terminaisons simples, mais c'est le seul bémol.
Yarbo c'est tout bon
Fines, esthétiques, pratiques, peu encombrantes, bonne qualité, tout est bon dans Yarbo. En plus, il y a les couleurs pour ne pas se tromper. Génial, non ?
Grosse banane
Ouaip, c'est de la grosse banane et franchement ça ne se met pas partout. Si vous avez de la place derrière vos enceintes ou votre ampli, ça peut passer mais sinon, regardez ailleurs. Sinon, la qualité de construction est au rdv et l'idée de la protection est très bonne.
stephane d.
iEAST AUDIOCAST M5 Récepteur Audio Wifi Multiroom DLNA Airplay Le iEast Audiocast M5 est un récepteur audio Wifi supportant les protocoles DLNA, Airplay et UPnP simple et abordable. Il vous permettra également de concevoir un...
audiocast M5
bonjour, produit expedié rapidement, conforme à mon utilisation à savoir lire ma musique en airplay sur mon ampli, appareillage pas evident au premier coup sur ma livebox , aussi après maintes essais fonctionne plutot bien, je l'utilise surtout pour envoyer mes musiques depuis disque dur branché sur livebox play depuis application music streamer et la c'est que du plaisir, tous les formats sont reconnus, ras, par contre via application ieast play je ne peux avoir accès à mes fichiers sur mon serveur livebox malgré le fait qu'il soit reconnu mais n'affiche rien du tout, pourquoi je n'ai pas encore trouvé la solution mais si quelqu'un pouvait m'aider ça serait avec plaisir, voilà mes ressentis sur le produit, pour le prix je le recommande sans detour sur ce site, allez y.
Frédéric D.
Mitigé
Résultat mitigé: un médium trés riche (un peu en avant) mais une définition et dynamique un peu en retrait. Au final, cela donne un petit côté "tube".
Pour des applications spécifiques mais, en général, je préfère encore le standard NE5534 ou le LM4562.
Frédéric D.
Dynamique d'enfer, timbres raffinés, équilibre parfait et transparence absolue.
Cet ampli a avantageusement remplacé 2 Parasound Halo A23 bridgés. C'est un ampli qui rivalise avec les meilleurs amplis du marché.
Il est trés (trop) compact. Seul détail légèrement ennuyeux: pas d'entrée XLR et un promiscuité des connecteurs qui rend le raccordement des cables un peu difficile. Mais une fois que cela est fait ... Toutefois, le boîtier est de bonne qualité.
Dommage que Audiophonics ne fait pas les plus gros modèles avec entrée XLR.
Arnaud F.
Précision mais au détriment de la musicalité
Évidemment que l'apport s'entend sur la précision des sons, des timbres plus subtils donc c'est à ce titre indispensable dans un système HDG mais malheureusement on perd en musicalité, en émotion, en tension dans la musique et ce dans dans les deux sens de montage (c'est évidemment encore pire dans le "mauvais" sens) par rapport à mon bon vieux fusibles en verre bas de gamme.
