Jerome L.
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Avis clients - Il y a 19503 avis.
Karl R.
Flexible, high-performance with minor usability annoyances
I do not have the equipment to measure the performance so I'm gonna refer to AudioScienceReview for that:
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-topping-dx3pro-dac-and-headphone-amp.4967/
Summarizing the performance: it has great performance, as good as many units at 2-3x the price.
Things I noticed about the sound:
1. Noise is waaay lower. Quiet sounds are much easier to hear.
2. A slight shift in frequency response which I assume is down to by previous (integrated) hardware having high resistance (while Dx3 Pro has 1Ohm, which is excellent).
3. Noise from the PC is mostly gone. Previously I could hear faint noise when moving my mouse. That is no longer the case. I can still hear noise when pushing my PC hard, playing games, but I'm not sure if that's due to my motherboard having poor isolation. And this noise can only be heard in headphones, not through my speakers (Line Out in DAC-only mode).
Finally, my main gripes:
1. The volume knob is nice and clicky but can sometimes skip back the other direction at a slight touch; it's not as precise as I would have liked.
2. Even when setting Line Out as DAC-only in the settings it will use the Amp when you have Headphones AND Line Out active at the same time.
Overall a great piece of hardware with minor issues. Highly recommended.
alexandre s.
Et la musique prend place !
Je l'utilise depuis une dizaine de jour, ce dernier ne doit pas être encore tout a fait roder.
J'ai testé plusieurs câble RCA et jusqu'a présent c'est le meilleur!!!!
Ce qui saute vraiment aux oreilles et j'insiste énormément sur ce fait, sont avant tout la qualité naturel des instruments et le du timbre.
Du grains, belle spatialisation et un jolie médium.
Je dirai aussi que c'est un cable doux et chaleureux, je peux écouter plusieurs morceaux différents sans aucune brillance et pourtant j'ai des tweeter à ruban.
Tout est bien distingué !!!
Si il y aurait une phrase à dire je dirai que la musique sonne vrai et juste !!!!!!
alexandre s.
Cela apporte de suite de meilleurs basses, avec une meilleure résolution donc plus de petits détails.
La spécialisation est aussi améliorée, mes Monitor Audio Gold 100 sont plus libérées .
Ils seraient dommage de s'en passer vu le prix
Pour le prix il serait dommage de s'en privé !!!
Barrette secteur
Je me suis confectionné une barrette secteur avec 8 embases ABL câblées en étoile avec ce câble OCC: https://www.audiophonics.fr/fr/fils-de-cablage/elecaudio-fc125tc-fil-de-cablage-cuivre-occ-fep-25mm-rouge-p-6273.html, sur une embase IEC :https://www.audiophonics.fr/fr/fiches-secteur-connecteurs-iec/viborg-vi-06bc-embase-iec-c14-cuivre-pur-red-copper-o6mm-p-12745.html
celle ci raccordée a la prise murale : https://www.audiophonics.fr/fr/fiches-secteur-embases-schuko/furutech-fi-e30-ncf-r-embase-schuko-cuivre-pur-plaque-rhodium-p-11336.html
par un cable secteur : https://www.audiophonics.fr/fr/kits-cables-secteur/kit-cable-diy-elecaudio-secteur-ofc-3x35mm-c7-15m-p-10925.html
j'ai gagné en tout points, bande passante + large, scène sonore élargie, définition accrue, présence des musiciens dans mon salon. Je ne sais pas si cela vient du câblage, des embases ou du câble secteur, mais je recommande vivement, l'apport d'une barrette secteur de qualité apporte vraiment un plus. Merci à Audiophonics de nous proposer ces produits de très grande qualité pour un tarif très très raisonnable.
Gilles G.
AUDIOPHONICS DIGITAL AUDIO Câble USB-A Mâle vers USB-B Mâle Cuivre OFC 4N PTFE 0.5m Le câble USB Audiophonics Digital Audio est un câble numérique développé par l'équipe Audiophonics et assemblé dans nos ateliers....
Découverte de l'importance de la qualité du câble USB à l'écoute.
Avant que de commander ce câble USB Audiphonics, j'ai lu pas mal d'avis sur l'efficacité de câbles de bonne qualité sur le son. En fait j'étais perplexe et le suis resté jusqu'à ce que je remplace le câble USB d'origine de mon combo DAC/AMP Audio GD NFB 1138 Performance. le plaisir Audiophile pourrait être décrit en comparant une boisson acide au citron avec la même dans laquelle on aurait ajouté du miel et du rum. Depuis j'attends que le câble secteur Pangéa AC14 SE MK2 soit à nouveau en stock chez Audiophonics et je change celui d'origine sans hésitation. Bravo Audiophonics, cohérence de la qualité sonore audiophile dans tous les éléments de la chaîne sonore.
Benjamin H.
TOPPING D90 DAC Symétrique AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Argent Successeur direct du Topping D70, le D90 profite des mêmes raffinements que son grand frère tout en mettant à jour son DAC ves une version plus...
Top end device
This device is something special and sounds great! Excellent build quality and hefty weight makes it feel every bit as high-end as its sound performance. The price is up there but as far as I'm concerned this might very well be the last DAC I'll own. Using XLR connections to squeeze every bit of performance out of it. Built-in volume control is a bit finicky. Topping drivers enable Windows Volume control in both ASIO- and WASAPI-mode. I Hope this review and the many others on the Internet help you in your purchasing decision :-)
Gilles G.
AUDIO-GD NFB-11.38 PERFORMANCE EDITION DAC ES9038PRO / Préampli / Ampli casque DSD 32bit / 384kHz Accusilicon Le NFB d'Audio-GD revient avec plusieurs évolutions notables. Son étage de conversion digital / analogique s'équipe désormais d'une puce ES9038Pro...
Audio GD NFB 1138 Performance Edition
Avant de commander ce combo, je me suis documenté pendant deux mois. J'ai abouti à une "short list" de 10 appareils, et c'est là que David d'Audiophonics m'a considérablement aidé à faire le choix définitif.
Ce combo a un prix qui pourrait aisément être au double sinon au triple si l'on fait un comparatif avec le matériels existants du marché ainsi qu'un bilan performances/prix.
J'ai perso un casque Grado PS500e, 32 Ohms qui détaille la musique, large bande 19htz/29 Khz, scène sonore très large et précise. Je voulais un dAC au top et un ampli digne de ce nom pour ne rien perdre des qualités de mon casque. Je suis comblé, je ne m'attendais pas à une écoute aussi performante, détaillée et coulante à la fois. Quant au préampli, je le pousse en général au quart de ses possibilités et ça cartonne ! Si vous privilégiez l'écoute à l'esthétique, foncez, vous ne le regretterez pas. Livraison en 3 jours parfaitement protégé. Que désirer de plus ?
Michel B.
Transformateur R-CORE 30VA 2x115V vers 2x15V 1A Ce transformateur R-Core est idéal pour alimenter un DAC ou préamplificateur. Il possède un primaire 2x115V et deux secondaires de 15V 1A
Bien mais phases des secondaires non repérées
Plutôt bien, mais les phases des 2 secondaires de 15V ne sont pas repérées.
Si on les utilise en //, par exemple pour alimenter une alimentation stabilisée, l'absence de repérage des phases peut entraîner une surchauffe du transformateur même à vide (et l'alim peut ne pas fonctionner) comme dans mon cas.
Pour retrouver un fonctionnement normal, il suffit d'inverser un des 2 secondaires, mais il est regrettable que les phases ne soient pas repérées !
Un point qu'Audiophonics devrait faire corriger au fabricant..
A part ça RAS: Audiophonics au top côté livraison comme d'habitude.
Denis B.
bonne amélioration
Voulant améliorer un peu l'exploitation d'un tweeter kevlar double ferrite Davis, j'ai tenté de remplacer le condensateur existant (filtre DIY) déjà ancien par celui ci. J'avoue avoir été étonné du résultat, notamment dans un gain de précision (équipés d'appareils auditifs c'est une partie sensible chez moi : intelligibilité des paroles notamment). ils ne sont pas donnés, mais je suis pleinement content du résultat !
Denis B.
Efficace comme attendu
Utilisé pour (mieux) alimenter un dac Pro-ject pre box s digital, précédemment alimenté par l'USB de mon PC, le gain est notable sur la dynamique globale et la définition. ça n'en fait pas un "dac de course" quoique de bonne qualité déjà, mais l'effet attendu est atteint ;o) !
Miltiadis M.
Perfect little box
Clear and powerful enough to power my 90W RMS passive monitors. I have connected it to my DX7 Pro and the sound is great. Good value for money too.
Vitor B.
XDUOO X-10T II DAP 32bit 384kHz DSD256 - Interface USB vers S/PDIF Le XDuoo X10T II est un lecteur numérique haute fidélité nomade (DAP). Extrêmement complet, il est doté d'une connectique variée (AES/...
Great idea
It does what it says. Great set of cables. It is more practical to use it with Mojo than Poly. Navigation could be improved as well as manual but for the price - equivocally a 5 star product.
Alberto M.
ALPS RK09712100AV Potentiomètre 2 Voies 50K Ohm 20% Ce potentiomètre linéaire ALPS RK09 dispose de deux voies, d'une résistance de 50 kOhm et assure une tolérance de 20%. Particulièrement utile...
potenziometro
tempi di consegna rapidi,
artcolo come da descrizione
Francois P.
Exceptionnelle
La série 50 est vraiment un cran au dessus de la série 48. Encore plus d'aération, plus de contrôle, de maîtrise, scène sonore plus précise!
Utilisée avec une IEC 50 sur un câble secteur Furutech 055N, l'effet est impressionnant sur l'appareil électronique sur lequel ce câble secteur est installé!
Cher certes mais efficace!!
johann g.
mouais
on va faire bref.. ne fait pas mieux qu'un câble à 8€ acheté sur amazon.. passez votre chemin
Pascal E.
Adaptateur XLR Mâle vers Mini XLR Mâle Cet adaptateur robuste et compact vous permet de modifier à la volée la terminaison d'un câble XLR mâle 3 pôles par une version mini XLR.
Livraison rapide malgré le confinement, trés bon adaptateur, aucun bruit parasite.
Antonios S.
antsam
Value for money DAC. I am using optical and coaxial inputs in my system.
Clear, precise, neutral with open stage.
Useful remote control.
Excellent at this price
Pierre-Marin L.
RQP hors norme
Bon ampli, tient des enceintes complexes (petites Proacs) Offert à mes beaux parents pour un système au rqp imbattable et très plaisant à l'écoute...
Pierre-Marin L.
Un bon DAC
Bon RQP. Offert à mes parents qui ont très apprécié l'amélioration sur leur système.
Pierre-Marin L.
Sublime...
C'est mon deuxième. Le premier est placé en entrée de la barrette, un très bon achat la qualité ayant augmenté de manière impressionnante.
J'hésitais à m'offrir un autre DAC et puis le WAF a pas suivi... Résultat, à titre de petite amélioration je m'achète un second ifi purifier, espérant une petite amélioration sans trop y croire : et là la claque absolue : le deuxième entre l'ampli et le DAC fait faire à mon système un bond stratosphérique, même pas celui que j'espérait en changeant de DAC. Que dire, c'est un produit fabuleux et le deuxième est pour mon système indipensable. Merci !
Arnaud K.
Pas des plus évident à câbler proprement mais avec de la minutie on y arrive
Christoffer P.
Terrible banana plugs
The banana plugs on these cables are terrible. I was plugging them in to my Audiophonics amp (MPA-S250NC), so far so good. Then I unplugged them and the "shell" of the banana plugs got stuck in the binding posts of the amp. I had to use tweesers to remove the small metallic parts from the amp and was scared that I would damage the amp.
Otherwise the cable itself is OK. Very thick but pretty flexible.
Christoffer P.
Excellent amp
I have been using this amp for a few weeks now and can only praise it. It has plenty of clean power to drive my system and no audible distortion. XLR connections work nicely.
Package was wrapped very good with nothing moving around.
Took more than two months after order to get, but that was more to do with the current COVID situation. Customer service answered my questions well enough when order took longer than anticipated. But a little more information without having to ask would be nice.
christophe S.
TRES BON
Se connecteur est neutre avec des timbres juste sans le coté blanc de certain connecteurs,musical et sans dureté ,le rhoduim n est pas montant ,comme beaucoup, de personnes le pense ,tous dépend de son systéme.Si vous avez un son montant ,le rhoduim étant neutre va ciblé se déséquilibre,car cette matiére est sans compromis.Par contre si vous avez un son équilibré elle vous délivrera un message musical et vocal réaliste ,avec une bonne tenue général .Convient tres bien avec un son mat aussi .
TESTER avec Cable tunami V2 OYADE ou tc31
FURUTECH iec viborg R et schuko viborg R Musicalement a tous.
Frank d.
SMSL Adaptateur Secteur Alimentation 100-240V AC vers 24V 5.75A DC pour AD18 Cet adaptateur secteur AC 100-240V 50/60Hz 1.2A vers 24V 5.75A DC est idéal pour remplacer un modèle de caractéristiques équivalentes...
New power supply
My old SMSL broke down which meant no music in my garden shed.
I found the right replacement at Audiophonics which was delivered to the Netherlands in about 4 working days. Excellent service.
And the product works fine with my SA-50 amplifier.
Robert P.
Sound
So far this has proved be excellent, voltage once set is rock solid, although the load i have on it is well below its rating (maximum of 2amps) and at that it runs cool.
Fairly robust it has with stood a dead short on the output due to me using a faulty low voltage power socket. In dead short conditions the unit did get hot and then shut down, after removing the the short and letting it cool down it powered back up and is sound.
Pair with a good transformer and you have an excellent linear power supply, recommended.
Jean-Louis r.
AUDIOPHONICS Alimentation Linéaire Régulée Double 5V / 12V 30W T-Amp V-DAC2 LT1085 L'équipe Audiophonics est fière de pouvoir vous proposer une alimentation linéaire régulée destinée à alimenter proprement de...
une vraie amélioration
il y a incontestablement une grande différence par rapport au cordon basique d'origine.
Tout est mieux défini, plus précis avec une meilleure dynamique.
Bref: n'hésitez pas !!
Attention: le cordon secteur n'est pas fourni..
Grégory B.
Quoi de plus ?
Ayant fait récemment l’acquisition d’un casque, j’avais passé commande du couple A30/D30 de chez Topping, sur Audiophonics.
Le dac D30 avec sa puce CS ne correspondait visiblement pas à ce que je recherchais. Et cela, que ce soit au casque ou au salon sur les enceintes B&W ou d’autres matériels. L’ampli A30 était bien pour ce que je puisse en juger, connecté à un dac sabre 9023 ou la platine en 9018 du salon. Les dac sabre semble plus correspondre à ce que j’aime.
Ce petit combo 9028 et ampli class A me semblait être une bonne alternative à essayer.
Et bien comment dire, je ne remercierais jamais assez audiophonics de proposer ce type de matériels et surtout à ce prix. Je ne sais pas si d’autres boutiques comme celle-ci existe dans d’autres pays, mais je trouve que de disposer d’une enseigne comme audiophonics en France est une vrai aubaine. Surtout que les envois sont rapides, le site est clair, on dispose de détails sur les matériels …
Je suis conscient que les avis sur le son que produisent ces matériels sont subjectifs. Ce qui plaira à certains ne plaira pas à d’autres, certes. Ce qui suit doit donc être pris avec des pincettes, mais je suis vraiment resté assis lors des premières écoutes.
Des frissons dans tout le corps, je ne sais pas ce qui apporte le plus, la puce en 9028, l’ampli en class A ou la combinaison des deux, mais je suis vraiment resté scié.
Je ne suis pas un habitué des casques, j’étais avant surtout porté sur le couple ampli/enceintes dans un salon non traité (donc pas idéal), mais c’est la première fois que ça me fait ça toutes écoutes confondues.
Bref au casque, je n’ai pas testé la sortie RCA, c’est à la fois détaillé et les voix, les guitares sèches/électrique, tout prend vie, même l’électro prend de l’ampleur.
Encore une fois, cela correspondant peut-être aussi à ce que j’attendais comme « son » et mon avis est très positif, mais il est à mettre en relation avec le prix de « l’objet »
J’en viens à me demander ce que l’on peut vraiment espérer de matériels qui se vendent à des milliers d’euros … et le plus drôle, c’est qu’il y a justement quelques milliers d’euros dans le salon entre les amplis, les enceintes … et la claque … ben elle était au bout d’un ampli/dac à 130 euros et d’un casque fidelio X2HR de Philips à peu près au même prix …
Pour conclure, merci audiophonics
Gilles J.
Pied Aluminium 3 Pôles à Billes 39x24mm Argent (Unité) Ce pied de découplage est tout indiqué pour traiter les amplificateurs et sources numériques. Particulièrement efficaces et abordables en aluminum, ils sont tout indiqués pour...
Produit satisfaisant
Bon rapport qualité/ prix, système satisfaisant.
Marc L.
AUDIOPHONICS DIGITAL AUDIO Câble USB-A Mâle vers USB-B Mâle Cuivre OFC 4N PTFE 1m Le câble USB Audiophonics Digital Audio est un câble numérique développé par l'équipe Audiophonics et assemblé dans nos ateliers....
Ce câble fonctionnait mieux dans mon environnement qu'un câble qui coutait beaucoup plus cher. Par contre, ce dernier câble était meilleur dans d'autres environnements. Comme quoi tout est une question de mariage. Au niveau des qualités de l'AUDIOPHONIC, j'ai noté de la précision après un période de rodage dépassant une dizaine d'heures et une belle ouverture. C'est un câble a tendance neutre.
HIDIZS AP80 Baladeur Numérique HiFi DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX Gris Avec son AP80, Hidizs propose un DAP au format vraiment réduit pour vous accompagner tout au long de votre journée, et ce en assurant d'excellentes performances audio.
Il a tout d'un grand ce petit !
Tout petit, il tient dans la main et peut être manipulé sans l'autre. L'objet est beau. La coque silicone (indispensable pour protéger l'entrée de la carte SD) n'altère pas son look.
L'écran est très lisible, fluide, je m'en inquiétais un peu avec mes gros doigts.
Je lui trouve cinq défauts d'ergonomie :
-1- On ne pas lancer un album entier en un seul clic, faut rentrer dans l'album et cliquer sur le 1er track (une manip de trop quoi !).
-2- Je tags moi même ma musique avec mes "genres". Ils apparaissent bien dans la liste mais mélangés à d'autres genres. Là, je ne comprends pas. Toute ma musique retaguée est reconnue sur AIMP, médiacenter, bluesound ... mais pas sur le DIHIZS qui me rajoutent des "genres" que je n'ai pas. J'ai vérifié la SD sur un éditeur de tags. DIHIZS est mythomane.
-3- La lecture aléatoire se fait uniquement sur l'ensemble du contenu de la carte SD.
-4- L'aléatoire encore. Pas possible d'être en aléatoire sur un "genre" souhaité. Là, suis pas content du tout. J'aime écouter en aléatoire sur le tag "genre". Par exemple, en Jazz, j'ai les tags "jazz-piano, Jazz-rock, Jazz-word ... Si je veux écouter aléatoirement parmi les artistes répondant au tag "Jazz-Piano" ... je ne peux pas.
-5- Quand vous demandez les albums d'un "genre" il vous les donne par "Album" et non par "Compositeurs -Album" :
Soient tous les albums de Pink Floyd, de Airbag et de Porcupine. Vous aurez le résultat par ordre alphabétique des Albums. C'est ballot ...
L'essentiel à présent : Le son.
Là, c'est magnifique. J'ai un casque Divore Addict filaire ET Bluetooth APTX-HD, j'ai exactement ce que je souhaitais entendre. Du silence entre les notes, de l'aération, du grave présent mais pas bourrin. Le DIHIZS est très puissant et possède deux systèmes d'équalisation performants. Un classique et un très sophistiqué MSEB qui m'a surpris par son efficacité.
Prochain essais sur un casque filaire haut de gamme.
Je recommande ce baladeur pour son prix et son excellent son, je remettrais une étoile si quelqu'un m'explique comment enlever les 5 défauts d'ergonomie ;)
Laurent M.
Ras
Produit conforme, livré en temps et en heure...
Marc L.
VIABLUE Gaine tressée Noire 13-26mm Le diamètre de ces gaines est modulable de 13 à 26mm.
Belle et bonne gaine pour des cables a grosse section
Plamen T.
Good looks but bad material
These are from some kind of alloy with bad conductivity, not copper. Gold plating is not enough to conduct such high currents. Look for a real copper terminals.
Bruno G.
L'acquisition de cette alimentation ipower est-elle une bonne chose ? Je crois que la réponse est oui. Les gains sont multiples, en tout cas, dans le contexte de l'utilisation du petit dac usabre d'audiophonics. Ce dac, très bon au demeurant, devient excellent. L'amélioration de la transparence, des petits signaux, du relief et de l'extinction des notes, entre autres, donne une lisibilité et une musicalité accrues.
lezzoum h.
TOPPING D90 DAC Symétrique AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Noir Successeur direct du Topping D70, le D90 profite des mêmes raffinements que son grand frère tout en mettant à jour son DAC vers une version plus...
Satisfait, un gain significatif,
Bonjour, d'abord bravo à l'equide d'Audiophonics, qui m'ont envoyé le produit aussi rapidement, sachant qu'on est sous confinement, le DAC est utilisé comme dac pure sur un streamer attol 200 "son agressif"et préamp attol pr 300 qui est équipé d'une puce AKM =4490, ampli Marantz mm 7025 et enceintes Chorus 836, je peux dire que j'ai un gain significatif en qualité sonore, plus de profondeur dans les graves, le medium reste relativement neutre pour mes enceintes, y compris dans le haut medium"maillon faible de mes enceintes" transparence, le timbre et qualité des aigues très appréciés, bref je ne regrète pas mon achat, ah oui pour l'instant j'utilise l'entrée coaxal et sortie RCA, je n'ai pas branché encore avec la sortie XLR directement sur l'ampli Marantz, d'ailleur je demande si quelqu'un peux me conseiller sur un cable XLR qui va avec la gamme de mon matériel. Je reste disponible pour partager ma modeste expérience .
SMSL DP3 Lecteur Réseau DLNA Airplay Bluetooth AptX DAC 2x ES9018Q2C 32bit 384kHz DSD256 Après nous avoir proposé leur flagship, le FDA AD18, SMSL revient et complète sa gamme avec le DP3. Nous avons ici à faire à un lecteur...
Ce streamer véritable couteau Suisse est une très bonne affaire a ce tarif, il est "presque" résolument hifi, en clair excellent pour une écoute de très haute qualité et il est dommage qu'il soit entachés de bugs qui sont difficile à résoudre. De plus le firmware fourni par smsl ne rend pas justice à l'appareil un groupe de passionnés Russe ont réussi a faire une rétro ingénieries sur le firmware et ont supprimé une particularité de l'original qui consistait à réinjecter sur canal gauche le signal inversé du canal droit et affaibli de 18db c'est une astuce qui permet d'obtenir a l'écoute une image plus large et plus profonde mais au détriment de la signature réelle de ce Dp3 qui en devient presque brouillon.
Si vous cherchez ce firmware sur Gogol cherchez à Pogoo + forum des indépendants. Je ne sais pas si Audiophonics laissera passer cette info mais si oui sachez que ce lecteur excellent en deviendra fantastique.
Par contre désolé j'ai pas testé le Dac et je ne le ferai peut être pas.
Musicalement
Eddy R.
Très bonne qualité
En remplacement de mes 12AU7 Cayin d'origine, ils apportent plus de détails dans les haut médiums et aiguës, plus de clartés, je n'en suis qu'a 20H d'écoute j'espère ne pas devoir revoir mon jugement après plus d'heures.
Cernat G.
Module Amplificateur TPA3116D2 avec Contrôle de Volume 2x50W 4 Ohm Ce module amplificateur se base sur une puce d'amplification TPA3116D2. Celle-ci lui permet de délivrer une puissance de 2x25W sous 8Ω. De plus, l'architecture de cette...
Good
For this price...it works! :)
Jean-Marie G.
surprise !
Bonjour, ...... oui grande surprise.
Excellent amplificateur, sur les premières heures d'écoute: grave excellent, aigus très fin et détaillé - de l'air ! - le medium à peine moins bon que les deux extrêmes pour l'instant...
Le contexte: ampli pas rodé, auditeur habitué aux tubes ( qui restent, à ce stade, plus à mon gout, sur le médium uniquement, car pour les extrémités du spectre c'est du très très qualitatif !); les enceintes ont deux modes,
Mode 1:des large-bande Phy-hp ( 21cm, bobine argent ) sur petit baffle plan avec en parallèle deux 38cm Yamaha dans 75 litres chacun filtrés par self de 3.8mH et un peu boosté en bas, obligé.
Mode 2: le même que le précédent avec un filtre actif numérique ( mini dsp ) qui le coupe à 780 Hz et relayé donc par ampli tubes (pp 6v6 schéma Dynaco ) qui alimente des compressions Altec 802D sur pavillon 811 avec en // à l’arrière une paire de compressions Yamaha sur petit pavillon Guigue filtrées par 1 microF orientées vers le haut, à l’arrière du pavillon 811 donc. Le mode 2 est donc une bi-amplification 3 voies et demi, actif/passif.
Ca matche parfaitement, cet Amp25 fait le job jusqu'à 780Hz et la transition ne se fait pas sentir..... Si le medium s'adoucit avec le rodage ça va être terrible en mode 1 ( large-bande ) ! Je reviendrais poster un avis plus tard, merci à Audiophonics d'avoir choisi d'importer ce petit bijou.
Pas testé le bluetooth...
Ludovic L.
Cela fait plusieures fois que j'achète ce modèle et pour son tarif il n'y a rien à dire. Les finitions, la fixation du câble et la connection aux borniers sont excellentes.
Ludovic L.
Utilisés pour doubler les sorties d'un préampli, la finition est excellente et l'objet est très qualitatif, aucune perte du signal.
Ludovic L.
J'ai acheté ce préampli pour installer deux amplis Tripath Trends TA 10.2P en blocs mono chacun amplifiant son enceinte. Je ne voulais pas dépenser une grosse somme mais avoir un contrôle de volume et de tonalité.
C'est plutôt pas mal du tout. Pour le moment j'ai juste essayer avec mon baladeur Hi-Res.
Dominique A.
MATRIX X-SABRE PRO MQA FULL DECODER DAC USB I2S ES9038PRO 32Bit/768kHz DSD1024 Noir Avec cette version modernisée du X-Sabre Pro, Matrix nous propose un DAC 32bit basé sur une puce ES9038Pro. Cette nouvelle version ajoute une prise en charge de la...
superbe qualité de fabrication et superbe écoute .
Bonjour , livraison rapide , très content et satisfait de ma commande . Produit sérieux , de qualité , construction haut de gamme . Qualité son sublime . Merci AUDIOPHONICS .
A. D.
Sandro R.
1877PHONO ARCADIA MKII Câble de modulation PC-OCC RCA-RCA 1.5m (La paire) L'Arcadia MKII de 1877Phono est un câble de modulation élitiste, nouveau modèle de la version MKI réputée et adoubée. Composé de...
One of the best
It will certainly be the most neutral cable I have ever had.
High quality construction
Nice Price
Helmut H.
TOPPING A50 Amplificateur Casque Symétrique Argent Le Topping A50 se présente comme amplificateur casque sédentaire efficace et abordable. Sa conception soignée en fait un allié idéal pour tout...
I also like that Amp..
.. but I'm only a listener, it is my second Headphone-Amp. For me it sounds nice and can drive a Sennheiser HD650 at +9dB loud enough for my ears.
I can't say anything more than the reviewer before, it's all I perceive myself.
The ordering process from Germany was very agreeable. I had one RMA, but it was a problem with the source I connected, not the Amp itself. The RMA was really painless. The concerns ordering a product outside my country are discarded. Thanks for that nice and gentle process!
Kirsch p.
IFI AUDIO HIP DAC Amplificateur DAC Casque Portable Symétrique 32bit 384kHz DSD256 MQA iFi Audio présente le HIP DAC, un combo DAC et amplificateur casque symétrique nomade, à la fois compact pour vous accompagner dans tous vos...
Avis d'un néophytes ^^
Étant mon premier DAC je ne peut pas vraiment être objectif mais cest que je peux dire c'est que j'ai redécouvert mes morceaux il est précis et l'ouverture de scène qu'il apporte est gigantesque (de mon point de vue de débutant^^) il y à un peut trop de basse a mon gout mais je suis un psychopathe du son neutre donc bon... Rien a redire pour moi à si les leds sont sensé changer de couleur en fonction du type de fichier du coup j'ai essayé un fichier en mQa pour le voir s'illuminer d'un magenta mais la couleur n'a pas changé.
Eemeli V.
Sélecteur de Source Automatique 4 Entrées RCA Stéréo Ce module permet de switcher automatiquement entre 4 sources stéréo. La sélection des sources s'effectue de manière totalement automatique à partir d'un signal de minimum 0.2V.
Not for HI-FI audio!
If your plan is to connect multiple audio sources to active speakers or ampfilther THIS IS NOT THE RIGHT DEVICE! When input is selected a loud "bang" noice is heard from your speakers. And when there is no output the device continously switches between inputs and same sound will be heard again and again.
Michel B.
Très bien mais pourrait encore mieux faire
Mécaniquement il est très bien et robuste.
Ergonomiquement il est facile à souder avec une pin centrale qui permet d'enfiler le câble central profondément, et un corps facile à souder avec un système de serrage du câble par pincement correct. Sur ce point, le OYADE est plus abouti, mais je ne suis pas certain que ce soit mieux en pratique.
Le diamètre du trou de passage du câble est largement suffisant pour tous les câbles utilisés en DC, même si vous utilisez un 4 conducteurs 24-AWG.
Pas loin du sans faute donc pour la partie mécanique et ergonomique.
Parmi les connecteurs DC disponibles, c'est le seul avec le OYADE à indiquer le métal utilisé: Laiton pour les 2 fabricants, mais le OYADE est 2 fois plus cher...
En terme de rapport Q/P, il me fait l'air bien mieux placé que le OYADE qui propose le même matériau (laiton). Si OYADE proposait du cuivre, l'écart de prix pourrait se comprendre.
Cependant pourquoi ne trouve-t-on aucun connecteur avec contact en vrai cuivre ??
Sans aller jusqu'au UP-OCC, on est légitimement en droit d'espérer un connecteur DC en cuivre !
Les fabricants auraient-ils oublié à quel point la qualité du matériau est essentielle dans un connecteur ?
Robert P.
Nice looking box on a budget
On the plus side the box once assembled looks good for a relatively budget box and is performing the job I required.
On the negative side the small bolts that are used attach the base and the top plate to the side plates are very short and only just catch the nuts they screw into, they are effectively one shot use. If you need to remove the top plate to gain access after assembly the bolts will be scrap and need replacing, fortunately there are some spare bolts in the kit I had.
Another negative is that there is no electrical continuity between the components which if you intend to put mains voltages in the box is potentially dangerous. As I was constructing a power supply one of the main components was a transformer from 240v to 12v so this was an issue for me. To get continuity I had to remove the paint from all the jointing faces in order to get an electrical continuity and enable the box to be earthed, not ideal.
