Laurent B.
Bonne upgrade
Hans B.
Patrice L.
Un produit bien conçu.
Avis clients - Il y a 19358 avis.
Jean-Louis R.
CANARE BCP-A77 Connecteur BNC Cuivre Béryllium Plaqué Or Ø5.2mm Le connecteur BNC Canare BCP-A77 offre une belle qualité de conception, avec un corps en métal et des contacts en cuivre béryllium plaqué or,...
Dommage qu’il n’y ait pas plusieurs embouts à sertir, pour si on veut changer de cable.
Dispo séparement?
Wojciech S.
1877PHONO CryoGold-Ag Fils de Litz Argent / PC-OCC Plaqué or 40mm (x4) 1.0 - 1.2 Un jeu de fils de liaison (Headshell Leads) haute qualité pour cellule de lecteur vinyle.
The best headshell cables ever made
As long as you use the 1877PHONO GoldRush turntable cable (probably the best turntable cable there is - when I first connected it to my Technics SL-1200G, it seemed to me that Mephistopheles was behind the music and was helping to extract the magic from the sound) - CryoGold-Ag are the only ones you can use as a companion to GoldRush, because they are made in the same way and from the same materials. I have a dozen or so turntable cartridges and this is the third CryoGoldAg-Ag set I have bought (by the way, Audiophonics.fr offers the best price for them), because there is a complete synergy between the turntable, preamp and amplifier. These little wonders squeeze the maximum information out of the records. I can't give 6 stars out of 5, because there is not that much on the scale, and these cables are off the scale! 200% recommendation!
Wojciech S.
TUNG-SOL EL34B Tubes Pentode Platinum (Quad Appairé) Ces tubes pentodes Tung-Sol EL34B haute tension profitent d'une belle conception, utilisant des matériaux de grande qualité. Ils disposent d'une impédance...
Great sound for the price
These tubes are not as prone to failure as the Chinese ones, they are made solidly and will serve for many years. They give a very saturated, soft sound, with beautiful mid tones, good bass and a sonorous top of the band. Worth recommending, they have a great value for money.
CARLIER B.
Idéla pour synthétiseur yamaha MM6
Je recherchais un encodeur rotatif pour mon synthétiseur yamaha MM6. J'ai contacté le service client Audiophonics qui m'a conseillé le BOURNS PEC16 Encodeur Rotatif Numérique 24 Positions Axe court. Emballage soigné et envoi rapide..
Merci Audiophonics pour votre sympathie et votre professionnalisme.
Jerry T.
Audiophonics DAC sabre board ESS9038
Please keep selling this item. It is very high quality! I will buy many more in the future!
Jean-François D.
FIIO K11 R2R DAC Amplificateur Casque 24bit 384kHz DSD256 Noir Le FiiO K11 R2R, version R2R de son cousin le K11, est un petit DAC amplificateur casque polyvalent et performant. Il repose sur un réseau de résistance et des...
Impeccable !
Commande facile et expédition rapide. Le produit répond parfaitement à mes attentes et à sa réputation. Je branche mon casque Mezze 109 Pro dessus avec le câble symétrique de 4.4 mm. Le son est excellent, très doux. Les basses et sub-basses sont chaudes et dynamiques, les médiums et les aigüs sont bien détaillés. Satisfaction totale !
Vasilios K.
From the moment I connected it, the difference was clear: the sound became more musical, fuller, and flowed more naturally. Any harshness or edginess disappeared, and the presentation came to life with a new sense of energy and presence. Everything felt faster, more fluid, and emotionally engaging. It made me want to rediscover my vinyl collection all over again. Very pleased!
LHY AUDIO LPS25VA Alimentation Linéaire Régulée Faible Bruit 220V vers 18V 1A 25VA Cette alimentation linéaire régulée LHY Audio LPS25VA est idéale pour tout projet audiophile de haute qualité. Tous les raffinements...
Ça Chauffe !
En charge avec un préamplificateurs phono Pro-Ject Tube Box DS3 B, l'alim. monte à 52°C avec 26 °C dans le local....Je pense placer des dissipateurs thermiques.
Geert J.
du haut de gamme à petit prix
J’ai acheté le JC2-FET pour relier mes sources à mon amplificateur de puissance. Mes sources n’ayant pas de réglage de volume, il me fallait un préampli. L’insertion d’un préamplificateur actif me permet aussi d’augmenter le rapport signal sur bruit de mon système.
La finition est à la fois spartiate et soignée. Le boîtier en aluminium brossé est solide. La face avant a une épaisseur de 8 mm. Même les boutons de réglage de volume et de sélection d’entrée sont en aluminium. Les bornes d’entrée et de sortie sont plaquées or. Le JC2-FET est conçu et produit en Chine.
Les concepteurs du JC2-FET se sont inspirés par le JC-2 que John Curl a réalisé pour Mark Levinson. Le JC2-FET a un montage en double mono et fonctionne en classe A. Chaque canal est pourvu d’une alimentation régulée (15 VA) : cela est très important pour les électroniques qui doivent gérer des signaux électriques très faibles. Les transistors utilisés sont de type JFET (Toshiba) qui ont la réputation d’être particulièrement musicaux. Il n’y a pas de condensateurs d'entrée et de sortie. Bizarrement, les concepteurs paraissent avoir ajouté un étage de sortie offrant un courant important. Cela n’est pas très ‘courant’ sur un préampli, la première fonction d’un préampli étant d’augmenter la tension (c’est l’ampli de puissance qui ajoute un courant). Le JC2-FET a un niveau de sortie de max. 9 volt, ce qui est un peu la norme pour les préamplificateurs ayant des sorties non-symétriques. Cela suffit largement pour piloter n’importe quel amplificateur de puissance.
Rappelons que la qualité des électroniques en amont de l’amplificateur de puissance est de prime importance. Le préamplificateur permet d’augmenter le ratio signal sur bruit du système puisqu’il n’amplifie que le signal de la source (musique, parole …) et non pas le bruit résiduel, contrairement à l’amplificateur de puissance qui amplifie la totalité du signal, donc aussi le bruit. Un préampli puissant (tension de sortie suffisante) permet donc de réduire le gain de l’amplificateur de puissance pour éviter que ce dernier amplifie trop le bruit. Chaque imperfection en amont de l’ampli de puissance sera littéralement ‘amplifiée’ par ce dernier. Voilà pourquoi la qualité des électroniques en amont de l’ampli de puissance est un facteur plus décisif que la qualité de l’ampli de puissance même (cf. théorème de Friis). Signalons aussi que la séparation du préamplificateur de l’amplificateur de puissance fait que les deux étages disposent d’une alimentation spécifique adaptée à leurs besoins et qu’ils sont moins sujets à des interférences mutuelles.
Contrairement aux autres avis, j’ai trouvé que le JC2-FET ne nécessite pas de rodage intensif : il dévoile assez vite son potentiel.
Voulant éviter les commentaires dithyrambiques, je vais me limiter à dire que l’insertion du JC2-FET dans mon système ne mène à aucune dégradation sonore. Bien au contraire : j’ai l’impression que le son est un peu plus grand. Les concepteurs du JC2-FET ont réussi le tour de force de créer un préamplificateur abordable qui offre une grande musicalité et une transparence totale. Je m’attendais à de légères dégradations (comme une transparence et une scène sonore réduites), mais heureusement ce n’est pas le cas. Il est clair que le JC2-FET joue dans la cour des grands: au tarif proposé, cela est un peu déconcertant …
Certains regretteront l’absence de sorties et d’entrées symétriques et de télécommande. Je signale aussi que le JC2-FET est livré sans câble d’alimentation.
Conclusion : du haut de gamme à un prix abordable.
Geert J.
3E AUDIO A5 Amplificateur Class D Stéréo PBTL 2xTPA3251 2x150W 4 ohm 3E Audio, acteur reconnu dans le monde du DIY, propose le A5, un amplificateur classe D stéréo conçu avec des composants Hi-Fi audiophiles. En effet,...
le petit qui joue dans la cour des grands
J’ai des enceintes à haut rendement et avec la plupart des amplis que j’ai déjà essayés, un souffle se manifeste, en particulier sur les moteurs à compression. J’ai acheté trois A5 pour réduire le souffle dans mon système, vu que le A5 a un bruit résiduel extrêmement bas. Avec les A5, sur les moteurs à compression, on entend toujours un léger souffle, mais cela est dû au bruit qu’il y a en amont des amplis : c’est mon processeur qui génère un souffle. Ce n’est donc pas la faute du A5 qui ne fait qu’amplifier ce qu’on lui donne, donc aussi le bruit. Quand je branche les A5 directement sur les moteurs à compression sans processeur, le souffle disparaît presque complètement.
J’ai déjà eu plusieurs amplis classe D d’origine professionnelle (Crown XLS Drivecore, Crest Pro-LITE, QSC PLD …). J’ai toujours été charmé par le son audiophile de ces amplis, mais sur mes enceintes à haut rendement, ces amplis pro augmentent le bruit qu’il y a dans ma chaîne. Le A5 fait preuve lui aussi d’une grande musicalité, mais il n’ajoute pas de souffle au système. On est très loin du son maigre et froid de certains amplis de classe D venant du monde hifi. Les timbres ne sont pas dénaturés et le rendu sonore se caractérise par une grande clarté et par une belle fluidité. Cela n’étonne pas : certains composants sont de très bonne qualité (alimentation, condensateurs, puce …). Ajoutons à cela que le A5 offre une puissance respectable malgré sa taille réduite. En plus, le A5 est indépendant de la charge : cela est rendu possible par le ‘post filter feedback design’ (PFFB) et par les caractéristiques de la puce TI. Cela donne un son très équilibré. La scène sonore est précise, large et profonde.
Conclusion : petite taille, petit prix mais grand son.
István R.
AECO ABI-0611S Borniers Haut-Parleurs Cuivre Tellurium Plaqué Argent (La paire) Ces borniers pour enceintes aeco ABI-0611S offrent une excellente qualité de conception. Ils utilisent en effet des contacts de faible masse en cuivre au tellure haute...
AECO ABI-0611S vs ETI CRYO
I had the opportunity to compare the 0611S binding post with the ETI KRYO Silver Plated Tellurium Copper. (ETI KRYO Silver Plated is not certain to be cryo-treated either, because there is no information on the manufacturer's website https://eti-research.com/connector/kryo-binding-post/ ) Both have the same conductor (tellurium copper) and silver plating. The direct clamping of the spade and wire is the same and practical. It can be soldered on the inside and also fixed with a screw. There are two differences. The AECO fixes the wire with screw through a removable optional hard material ring. The other difference is that the AECO clamping cylinder is grooved for gripping the fork, which allows you to clamp the fork on heavy cables more firmly. I don't think the two sound different, I like the 0611S better and it is much more affordable price.
Julien L.
DAYTON AUDIO XO2W-2K Filtre Haut-Parleurs 2 Voies 2000Hz La gamme de filtres crossovers 2 voies Dayton Audio a été conçue en utilisant un alignement Linkwitz-Riley de second ordre (12db/octave). Des condensateurs...
Qualité visuelle au rdv. Reste à tester à l'écoute.
Julien L.
AIYIMA B07 Amplificateur 2.1 Bluetooth 5.2 Class D TPA3255 2x250W + 300W 4Ω Le B07 de Aiyima est un amplificateur intégré disposant de 3 canaux, dont un dédié au subwoofer ainsi qu’une sortie auxiliaire. Il est capable...
Ampli
Petit mais costaud. Par contre chauffe rapidement.
Jacques B.
ETI LEGATO 20 AMP Connecteur IEC C19 Cuivre Plaqué Or Ø20mm ETI Research, avec son connecteur d'alimentation Legato 20 AMP, propose un IEC C19 haut de gamme acceptant des câbles secteur jusqu'à 20mm de diamètre. Ses...
Excellente connectique !!
De l'ETI, encore et toujours, de grand qualité de fabrication et toujours une ouverture remarquable, un naturel avec beaucoup d'aération. Attention à bien attendre le "rôdage" de la prise pour en tirer le meilleur, notamment avec un grave en avant qui s'équilibre à l'issue !!! Evidemment, le prix est conséquent mais justifié. Bravo !!
Jean-François L.
AUDIOPHONICS LPA-S450ET Amplificateur de Puissance Stéréo Class D Purifi 1ET6525SA 2x450W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics LPA-S450ET, un amplificateur de puissance stéréo classe D basé sur deux modules Purifi 1ET6525SA....
Superbe choix
Le challenge n'était pas gagné d'avance : Alimenter mes Martin Logan Sequel II.
Après de nombreuses recherches sur les amplis adaptés, l'intelligence artificielle a attiré mon attention sur les amplis de classe D et notamment sur Hypex et Purifi.
Audiophonics m'a été d'excellent conseil dans le choix de celui-ci.
Je l'ai associé au préamplificateur MUSES72320 pour gérer facilement mes sources.
En plus, la livraison a été rapide et efficace.
Le résultat est exceptionnel quel que soit le volume d'écoute.
Merci à vous
Arnaud M.
RAMM AUDIO TA-14SP Câble Haut-Parleur Cuivre OFHC Blindé 4x 2.1mm² Ø10.5mm Le Ramm Audio TA-14SP est un câble haut-parleur offrant une conception de qualité à prix abordable. Il se compose de quatre conducteurs en cuivre OFHC d'une...
TOP
Aucun souci sur cette commande, ce câble, surgainé par mes soins (finition en thermo rétractable), a pris place entre un Electrocompaniet ECI6 et des Living Voice IBXR3 en bi-câblage. Il est un peu rigide mais se travaille très bien.
Je ne sais pas bien comment font ceux qui commentent le son d'un câble ou d'un élément en particulier, mais ce que je peux dire, c'est que chez moi, l'ensemble désigné plus haut fonctionne parfaitement à mon goût. Tout est en place, sans excès ni frustration, image, timbres tout est ok... CD, plateforme, vinyle, tout tourne, et ça fait même de la musique ! -;) Que demander d'autre ?
Frederic L.
gaine thermo rétractable...
Qualité parfaite.
Service parait. Merci à l'équipe technique.
Frederic L.
gaine Thermo rétractable...
Qualité impeccable mais je n'ai pas reçu la gaine 5 mm.
Celle que j'ai reçu était plus petite. Heureusement j'ai pu l'utiliser malgré cela.
Frederic L.
fiches bananes à souder...
C'est un produit exceptionnel que je recommande.
Ajoutez un bout de gaine thermorétractable et c'est parfait.
PATRICE R.
Superbe Amplificateur
C'est mon 4ème ampli en Class D .. Je ne reviendrai plus vers les tubes , la class A ou même AB.
Absolu transparence , maintien du grave et dynamique, ce sont les qualités déjà connues et au top avec la dernière version de PURIFI.
Je l'ai utilisé avec différentes enceintes a rendement différents. avec le réglage de gain de la carte Audiophonics il est toujours possible d'avoir une bonne progression du réglage de volume.
Actuellement je l'utilise avec le Dac Preamp JADE de Metrum Acoustic. La qualité de fabrication est excellente ainsi que la possibilité de changer l'AOP si besoin .. !
Si vous optez pour des montages séparés avec ampli de puissance. C'est le meilleur choix à ce prix et peut être dans l'absolu. Il faudra penser à lui associer un bon câble secteur il y en a de bons ici dans la gamme ELECAUDIO, c'est ce que j'utilise aussi.
avec liaison MOGAMI XLR
Enfin je ne partage pas l'avis précédent qui parle d'un haut médium en avant .. , en fait ces amplis sont tellement transparents qu'ils mettent en évidence les qualités et les défauts des équipements associés.
Notamment les colorations caractéristiques de certaines marques !
Dominique E.
JANTZEN AUDIO COMPACT MKT 001-8140 Condensateur MKT Axial 160V 22µF Les condensateurs Compact MKT de Jantzen Audio sont fabriqués avec un film polyester métallisé de la lus haute qualité possible. Jantzen Audio est...
Tolérance erronée, valeurs non respectées
Si les condensateurs présentent bien, j’ai de sérieux doutes sur la tolérance quant à leurs valeurs. Il est indiqué 5%. Mais quand je mesure les 4 condensateurs de 22 µF à plus de 24µF et avec deux capacimètres différents, ça questionne. Un des condensateurs est même mesuré à 25,06µF, soit presque 14% de plus que la valeur indiquée. J'éviterai à l'avenir cette marque.
gilles A.
MUNDORF MRESIST ULTRA Résistance 30W 1.2 Ohm Le développement des résistances Mundorf MResist Ultra se base sur les excellentes propriétés tonales de la feuille Cuivre-Manganine. Comparé...
Produit cher, mais de qualité audio, Associé à des condensateurs hdg genre jantzen alumen z sur la partie ' série ' des filtres enceintes, apporte transparence et musicalité, rapport a des associations condos/résistances moins hdg, le son semble s'améliorer au fil des heures d'écoute.
Nicolas S.
FIIO DM13 BT Lecteur CD Ripper sur Batterie 2xCS43198 Argent Le DM13 BT de FiiO est un lecteur CD portable à l’esthétique soignée et à la qualité des composants internes indéniable. Son...
plus qu'un simple lecteur
lecteur CD pouvant servir de DAC, intègre le Bluetooth et dispose d'une mémoire antichoc impressionnante. Sortie asymétrique puissante produit remarquablement bien fini au vu du prix ! très bonne autonomie. Je regrette simplement l'absence d'une housse de protection, j aurai bien payé quelque euros de plus pour cela. et vraiment pour pinailler, le dessous en plastique
Ralf S.
AUDIOPHONICS HPA-S600NCX Amplificateur de Puissance Class D Stéréo NCore NCx500 2x600W 4 Ohm Assemblé en France dans nos ateliers, l'amplificateur de puissance stéréo Audiophonics HPA-S600NCX, version mise à jour et améliorée du...
Best bang for your bucks :-)
Now this really is an extraordinary product, both Audiophonic's housing and Hypex' amplifier are way beyond the qualitiy that you can expect in this price range, if there is some famous brand label attached to the front... I particularly appreciate the switchable RCA/XLR inputs, as I use this power amp in a configuration that allows multichannel (R+L preamp output of my AVR via RCA) and pure stereo (via XLR). Now this stereo setup, which exists of the minimum number of components, is what really blows my mind. Source is an Eversolo DMP-A6, which can also serve as preamp and has balanced output, directly connected to the HPA-S600NCX via high quality XLR cables (of Funk Tonstudiotechnik in Berlin, Germany, who produce absolutely fantastic quality cables for nearly all audio applications) which serves to a pair of ambitious middle class speakers with 89dB efficiency. All this in a very small dedicated listening room, which does not allow for a proper bass reproduction. What should I say? The HPA-S600NCX delivers a precision in bass in this acoustically unfavorable environment that not even an absolutely high-end amplifier (an ASR Emitter, that a friend had lent me for testing) could deliver. I can only assume that the extremely low output impedance / high damping factor does the trick. Anyway, it's on a level which I never would have expected. As also the clarity of sound and the realistic performance over the rest of the frequency range is first class, I can highly recommend this amp even for high-end setups. For the fun of it: If you want to enjoy the potential of this little box, listen to Yello's "The Expert" from the "Touch Yello" album at a high listening level - I'm sure you will be amazed, too :-)
Benoit B.
Extracteur HDMI vers HDMI / Optique / Jack 3.5mm 5.1 18Gbps HDCP 2.2 4K 60Hz HDR ARC 3D CEC Cet extracteur permet de récupérer et extraire un signal HDMI en entrée pour ensuite sortir à la fois en HDMI, Optique Toslink et Jack 3.5mm afin de...
Fonctionne parfaitement pour extraire l'audio d'une PS5 vers un kit 5.1 avec un câble optique.
Aymeric D.
AUDIOPHONICS TPA-S100 Amplificateur Class D TPA3255 Bluetooth 5.0 2x 85W 4 Ohm Noir Nous vous proposons avec le Audiophonics TPA-S100 un amplificateur Class D profitant d'une belle conception, lui permettant de délivrer une puissance confortable de 2x85W...
J'ai commandé cet amli depuis la Nouvelle Calédonie, le suivi de la livraison a été clair, livraison rapide sans ennui.
L'ampli en lui même est compact, simple, il n'y a que deux boutons et une télécommande. Le bluetooth marche super bien. Le son délivré est très satisfaisant sur mes enceintes caisson équipées de haut parleur Supravox.
Un rapport qualité prix excellent !!!
Aymeric
Henri c.
JANTZEN AUDIO SILVER Z-CAP Condensateur 800V 2.2µF Les condensateurs Jantzen Audio Silver Z-Cap permettent de maintenir une parfaite neutralité sonore et un très bel équilibre tonal. Il sont...
trés analytique
j"ai utilisé ces condensateurs pour filtrer2 domes textile,monacord DT25n et audax TM025f1, chaque fois le résultat était très analytique
un extrême aigu bien présent,il faut utiliser un ampli a faible contre réaction avec un bon slew rate
Henri c.
tres bonne self
utilisé pour filtrer un 12cm fostex FE126nv ,le résultat est très dynamique,le son très vivant,ce haut parleur est très bon et la self ne
réduit pas ses capacités (sans jeu de mot )
Ideal
Une embase iec, un porte fusible et un interrupteur, en cuivre ofc ?
Connexion efficace, sonorité neutre .
VIBORG CF201 (G) Embase XLR Femelle 3 Pôles Cuivre Pur Plaqué Argent / Or 24k 3μ (Unité) Cette embase XLR 3 pins femelle CF201(G) profite d'une très belle qualité de conception et de l'usage de matériaux de qualité. Ainsi, les contacts...
J’ ai remplacé des neutrino plaque argent pour ces fiches viborg, plus de précision et de silence. Demande un temps de rodage .
Ludovic P.
Excellent avec Ifi Audio LAN ipurifier Pro
Utilisée sur un filtre Ifi Audio LAN iPurifier Pro, cette alimentation linéaire transcende le produit !
Meilleure aération et surtout disparition complète de la dureté dans le haut médium et des sibilances qui sont très présentes avec l'alimentation à découpage d'origine.
Pour ceux qui ont un LAN iPurifier Pro, je vous recommande absolument d'essayer avec cette alimentation !
Paulius S.
LHY AUDIO AC LINE Module Filtre EMI d'Alimentation AC Ce filtre d'alimentation LHY Audio AC Line permet de filtrer les interférences EMI provenant d'un courant secteur. Il est particulièrement utile pour la...
I implemented it to my CD player Denafrips Avatar, works very well.
AIYIMA A80 Amplificateur Intégré Class D Bluetooth 5.1 TPA3255 2x120W 4 Ohm Aiyima dévoile son A80, un amplificateur intégré classe D compact doté de nombreuses fonctions et de composants audiophiles. Il repose principalement...
Un très bon rapport qualité prix
Dans un volume contenu, ce petit amplificateur delivre un excellente performance sonore et une neutralité appreciable dans le bas du spectre. L'afficheur est un pur bonheur pour les yeux. Néanmoins, les entrées trs n'offrent pas un gain notable par rapport aux classiques RCA ( intérêt?) et il manque une entree hdmi pour ma télé : 4 étoiles pour les fonctionnalités.
TINYSINE AUDIO-B PLUS Module Récepteur Bluetooth 5.0 aptX Stéréo RCA Ce module récepteur Bluetooth 5.0 intègre une sortie RCA Stéréo permettant de le brancher directement à un DAC ou un amplificateur. Il est...
Convenable
Fonctionne sans problème, son correct.
Incroyable mais vrai...
Branché à un ampli Taga Harmony 25 B, a permis d'obtenir un son d'une pureté et d'un détail incroyables, et surtout sans AUCUNE dureté à une paire de Focal Aria 906, magnifiques enceintes biblio, mais aux aigus un peu durs pour mes oreilles jusqu'à présent, malgré plusieurs essais de différentes combinaisons ampli/câble de liaison enceintes-ampli/ pièces...
J'étais sur le point de m'en séparer, mais là il n'en est plus question !
Il va de soi que je ne regrette qu'une seule chose : ne pas avoir acheté ce câble secteur plus tôt, le jeu en valant largement la chandelle en l'occurrence...
Nikolaus S.
VIBORG VE512S Connecteur Secteur Schuko Type E/F Cuivre Pur Plaqué Argent Ø20mm Ce connecteur secteur Schuko Viborg VE512S profite d'une qualité de conception exceptionnelle, utilisant uniquement des matériaux de grande qualité pour...
Kombiniere die VE/VF512S mit dem "Supra Cables LoRad 2.5 SPC Silver Anniversary Edition", ergänze das ganze mit einem Baumwollmantel um die elektrostatische Aufladung zu überlisten und Du erhältst ein Top-Stromkabel für ca. 150,- Euro. Um dieses Klanglich zu übertreffen muss man ein Vielfaches investieren... (PS: kein Löten, keine Aderhülsen, kein gar nix)
Parfait sur un bureau
Je confirme les qualités évoquées lors des messages précédents : rapport qualité/prix exceptionnel, avec 3 entrées (BT, aux jack et usb) toutes fort correctes. Le seul petit bémol que j'ai trouvé est l'absence de réglage de tonalité (pas choquant à ce prix-là ! )
Sinon, il a redonné vie avec brio à des petites Jamo de vingt ans d'âge, mais peut également remuer quelques enceintes de type biblio...
Bref, bravo Audiophonics !
MICHAEL K.
AIYIMA A07 MAX Amplificateur Stéréo / Mono Class D TPA3255 2x225W 4 Ohm / 1x315W 4 Ohm Ce petit amplificateur Class D Aiyima A07 MAX possède la particularité de fonctionner aussi bien en stéréo qu'en mono pour...
Recommended
It does its job well. I paired it with a BST300 bass shaker and it's able to drive it quite nicely. Pretty significant difference compared to the Fosi V3 which I also tried but couldn't drive it as well as this one.
jean michel G.
jean michel G.
Gaine Tressée Thermorétractable 2:1 Ø20-22mm Noir Cette gaine tressée en Nylon thermorétractable de 20mm de diamètre permet d'offrir à vos câbles une finition avec un résultat propre. Le...
Gaine thermo adapté pour la finition, plus souple.
jean michel G.
Excellente
Très bonne gaine coton que j'utilise pour mes différents câbles.
Micael C.
Improve router performance
Installed post dual 3A LT3045 PS regulators powering my main wireless router with great results. Improves picture quality and sound quality. A strong recommendation.
Micael C.
Filtre Jack DC 12V 3F à Supercondensateurs vers jack DC Ce filtre jack DC 12V à supercondensateur vous permet d'obtenir une alimentation propre pour vos équipements et appareils Hi-Fi grâce à 5...
Awesome SQ improvement
I have three of these powering two streamers and a DAC. Give a nice SQ improvement even after dual 5A LT3045 PS regulators. A firm recommendation from me.
HYPEX FUSIONAMP FA501 Module Amplificateur NCore 1x500W DSP ADAU1450 DAC AK4454 192kHz L'amplificateur Hypex FusionAMP FA501 pourra vous permettre de concevoir un subwoofer ou une enceinte une voie active. Celui-ci est basé sur un module NCore capable de...
Bon ampli et DSP paramétrable
J'ai acheté cet ampli pour alimenter mon subwoofer JMLab SW900 car l'ampli d'origine tombait régulièrement en panne du fait des vibrations (faux contacts sur le circuit imprimé).
J'ai donc sorti l'ampli pour qu'il ne soit plus soumis aux vibrations et cet ampli fait bien le job. La paramètrage du DSP se fait avec un micro et une carte son calibrés et les logiciels REW, HFD et rePhase.
Le processus de paramètrage se fait sans souci une fois qu'on a compris la méthode et maitrisé les logiciels. J'ai mis plusieurs jours avant d'aboutir au résultat final.
Cette petite critique n'est pas spécifique de Hypex car tous les DSP sont comme cela. On pourrait réver d'un logiciel intégré un peu comme Audissey dans les amplis Home-cinema qui fait à la fois la mesure, le calcul et l'implémentation...
Ceci étant je ne met pas 5 étoiles car le résultat acoustique s'est certes amélioré par rapport à l'ampli d'origine sous l'angle courbe de réponse mais s'est un peu dégradé en réponse impulsionnelle.
Cela est certainement dû à l'empilement des traitements avec un convertisseur ADC puis les filtres DSP puis le convertisseur DAC.
Néanmoins content de mon achat
Sébastien C.
SBOOSTER BOTW P&P MKII Alimentation Linéaire Régulée 24V 1.1A Avec l'alimentation linéaire régulée SBooster BOTW P&P ECO MKII, la purification du signal électrique commence immédiatement là...
Optimisation sonore
Une nette amélioration sur le rendu de mon pré phono Octave Audio.
L'image et la scène sont encore plus nettes avec plus de profondeur et une sensation de plus de détails.
J'avais un doute en passant sur une grosse version d'alim type LPS et cet achat était pour "tester". Finalement c'est largement concluant; Sans même dégrader le niveau de bruit de fond qui est quasi nul sur cet excellent pré phono.
Un petit "boost" qui vaut largement son tarif.
Laurent C.
LPSU200 Alimentation Linéaire Régulée HiFi 12V 7.5A + 9V 7.5A 200W L'équipe Audiophonics est fière de pouvoir vous proposer une alimentation linéaire régulée destinée à alimenter proprement les...
Fait parfaitement le job.
Installée sur lecteur réseau 3dlab Nano transport PLATINUM V5, je suis très satisfait du résultat.
Davantage de matière, donc de présence, un gap sur la qualité des timbres, une scène sonore encore plus stable.
Pour le prix, Comparé à une alimentation 3dlab à 1300 € , elle fait parfaitement le job. Elle offre un upgrade très net , en attendant que mes moyens me permettent d'accéder à l'alimentation constructeur. Est ce que ce sera meilleur au point de justifier un prix 4 fois supérieur? Je ne suis plus pressé de tester :)))
De plus, les deux cables d'alimentation DC gx16 fournis avec la LPSU 200 sont basiques, et ce point est encore un axe d' upgrade intéressant .. J'attends un câble d'un fabricant spécialiste, qui devrait encore améliorer l'expérience. Je ferai volontiers un retour ici si je constate un gap.
Pour finir, j'ai eu un problème électrique indépendant de la LPSU200 lors de la mise en route, le service après vente audiophonics a été impeccable . Comme d'habitude. Bravo à toute l'équipe.
Super micro
Micro de mesure performant calibré à un prix raisonnable. L'intégration dans REW est sans souci
Laurent C.
DYNAVOX ANTIVIBE Pieds Absorbeurs Antivibratoires Ronds Caoutchouc Noir (Set x4) Ces pieds pour enceintes ou systèmes hifi en caoutchouc très simples d'utilisation absorberont efficacement les vibrations générés par votre système pour un son plus clair.
Rapport Q/P excelleent
Placés sous des tablettes , afin de permettre d'isoler celles-ci du meuble, je peux profiter pleinement des qualités de ces support en bois de bouleau sous mes éléments, sans coloration du son.
Pour mon usage, c'est parfait.
ERIC C.
Aspect IEC audiophile
Très bon produit pour le prix et qui remplace allègrement une prise IEC standard et permet d'utiliser un câble de section bien supérieur.
ERIC C.
VIABLUE FILTER 16 Réducteur à Ferrite de Filtrage Ø16mm vers Ø15.5mm Les réducteurs à ferrite Viablue permettent d'éliminer les interférences électromagnétiques hautes fréquences (EMI) et le bruit...
Ferrite pour gros câble secteur
Excellent produit facile à installé sur du câble de grosse section grâce aux deux visses de serrage qui rentre dans la gaine et empêche la ferrite de coulisser.
