Miklos C.
Miklos C.
Miklos C.
Avis clients - Il y a 19510 avis.
Mika P.
SMSL M300 DAC AKM AK4497 XMOS Double Horloge NDK 32bit 768kHz DSD512 Rouge Le M300 de SMSL est un DAC performant et compact au format atypique. Intégrant des composants de haute qualité, il est l'allié parfait pour offrir à...
Great little cute balanced dac!
This is best dac what i have been encounter... Sound is bottom to all the way highs are so plesaure to hear! Very engage in sound!
Alexandr C.
LM3886 Amplificateur Stéréo audiophile 2x68W / 4 Ohm Ce module LM3886TF est idéal pour la conception d'ampli stéréo dynamique et de qualité avec des composants typés audiophile. Les aop d'entrées sur support DIP 8 permettent de...
Good bass, Harsh treble
For me -It is imposible to listen this for long period. The treble sounds harsh, that's why I use this for bass in a 3 way active system. I compared this amplifier to LJ TTA1943 Amplifier boards 100W 8 ohm Mono that sounded much better than LM3886
Alexandr C.
Very bad
I bought this device as a second try after LJM analogy ( same as audiophonics with same SA9023 chip that stoped to work), they both had same problem: stop streaming randomly or after switching next song, I need to conect and disconect usb more than 10 times !!! and simply at the end stoped to work, they stoped download driver to computer. Please note this was not my laptop problem because it works with many other usb audio device very good.
Hi,
We stronly doesnt believe on any hardware defect here.
You may have a lack of power or a defective cable.
We have used this chip on numerous device over the years without any problems of any kind.
Alexandr C.
Recommend to run this with asynchronous dac
This device works prety well with asynchronous dac, and reclocking device, If you run this directly via spdif or i2s to a dac that needs master clock it will sound bad, This device provide high jitter master clock so you need a reclock, asynchronous device. I subjectively tested it.
Alexandr C.
Good sound for 44.1khz family some samplig rate
With 44.1khz imput via Spdif it output a decent i2s (tested with a synchronous dac that needs free jitter i2s imput) But with 48 khz imput it sounded awful !! Because: 1. Spdif source was bad (ljm usb iterface 192khz) 2. This source selector have clock (audiophonics specify 12.288Mhz that is not right) 11.2896MHZ on bord that deal very well with 44.1k family, I think that is why it sound good with 44.1khz
Alexandr C.
Very good sounding amp
I bought 3 pairs of them already, Free fatigue listening, It sounds much beter than lm3886 amplifier (lm3886 chip was imposible to listen long -for harsh treble, also bought from audiophonics).
Alexandr C.
Sound is good
Provide a low jitter i2s input with master clock, this dac don't have it's own clock and it don't run asynchronous. With bad source it sound bad , with good it sound good, I checked both.
Alexandr C.
Interface Numérique I2S vers SPDIF BNC WM8805 24bit 192kHz Cette interface WM8805 avec DSP XilinX permet de transformer un signal I2S avec MCLK vers un signal SPDIF classique.
it works well
It works, if you want to connect to rca SPDIF (not BNC) connect sign(-) from (spdif out) to ground of rca cable, sign(+) throught a 75 ohm resistor in series to central pin of RCA cable . (without resistor conection jumps random) try any value near 75 ohm, mine 100 ohm works well.
Stephane K.
CABLE AU TOP
SUPER CÂBLE RAPPORT QUALITÉ PRIX IMBATTABLE .UNE ECOUTE AU TOP BRAVO A TOUTES l'EQUIPE POUR DES RÉALISATION DE QUALITÉ A PRIX RAISONNABLE . SI VOUS CHERCHEZ UN BON CÂBLE FONCEZ ......
Stéphane K.
Médiocre
Encore un produit fait à la va vite, le maintien du câble en sortie de prise est vraiment merdique, un produit moyen qui justifie à peine son prix
Stéphane K.
Bien fabriqué avec un bon rapport qualité prix, facile à monter.
Pas de retour son le son, période de rodage nécessaire pour donner un avis objectif.
Quoiqu'il en soit c'est du cuivre pur toujours bien mieux que du laiton
Jerome S.
SOMMERCABLE HBA-3SC2 Câble RCA Stéréo Mâles vers Jack 3.5mm Stéréo Mâle 1.5m Ce câble Sommercable HBA-3SC2 d'une longueur de 1.5m dispose d'une part de deux connecteurs RCA avec bagues rouge et blanche et d'autre part d'un connecteur Jack 3.5mm stéréo...
Simple, solide. Gaine très souple et bon contact. Parfait.
Jerome S.
Simple et de bonne qualité. Audiophonics toujours aussi efficace!
Laurent G.
Barrette très efficace
Construction solide et sérieuse. Tres Nette amélioration de la qualité du son, plus d'aération des sons , plus de détails. Super rapport qualité prix
Jean-Yves M.
Accessoire parfait
Fonctionne très bien pour la freebox pilotée par une Logitech harmonie 655
Bon vendeur . Respect des délais
Jérôme L.
Attention avec un bémol !
Cinq étoiles quand même!.
A la fois redoutable de précision et de justesse, exécrable dans les " "boom boom" les mauvaises basses vendus par des David Guetta.
Tout dépend de la source, j'entends par là la qualité de l'enregistrement ou le mixage. Et comme je privilégie la source directe cela ne pardonne pas. Meilleurs résultats en acoustique pure , classique , jazz , blues et j'en passe , j'ai quand même pris mon pied vulgairement parlant. Donc les mixages de prise de sons de prétendu pro. à bannir car ce petit ampli mine de rien révèle les mauvaises notes (canards).
Denis E.
Fidèle acquéreur :))
Bon ... Je n'ai pas changé d'avis ... C'est la deuxième fois que j'achète ce produit ET je recommencerai dès que ce sera nécessaire : à ce prix là pourquoi se priver ! Bravo Audiophonics pour l'emballage et le délai très court de livraison !
Denis E.
Produit recommandé par le mag' "Haute Fidélidé"
OK ... C'est recommandé par un "grand" de la presse audiophile, ça nettoie sans aucun doute nos précieux vinyles ... En revanche, il paraît que ça a un effet antistatique : très sincèrement, là, je n'ai rien vu ! De très jolis claquements sont venus ponctuer la lecture de mes LP, anciens ou neufs . J'ai pourtant utilisé le chiffon fourni ... Chiffon en microfibre ; bref du synthétique qui ne peut que charger nos galettes noires ... Je tenterais l'aventure avec une brosse velours !
Denis E.
Petit ET brillant !
Petit : il prend peu de place et fonctionne bien ! En revanche la LED rouge éclaire comme un phare dans la nuit ... On en est tout ébloui : j'envisage de cacher l'appareil pour pouvoir supporter un tel éclat !
boîtier hifi2000
Super produit compte tenu du prix. Pour plus de rigidité et fixation des pcb/transfo j ai remplacé la plaque en tôle de fond de boîtier par un Capot Aluminium GALAXY GX248-288 Noir.
Produit recommandé
HIFI 2000 Capot Aluminium pour Boîtier GALAXY GX248-288 Noir Capot en Aluminium brossé de 2mm d’épaisseur destiné à habiller les boîtiers GALAXY GX248-288 HIFI 2000 de pour un résultat « tout aluminium » de très grande classe.
capot aluminium
Permet de renforcer un boîtier HIFI 2000 Galaxy GX288 (remplacement de la tôle 1mm en fond de boîtier)
Aucun problème. Produit recommandé
Denis E.
Bon ressenti qualitatif
C'est joli et ça marche ... Mais pourquoi minimum 1m80 ??? Ca me fait au moins 1 mètre de trop ! Des versions 50 cm ou 1 mètre seraient les bienvenues ... Délai de livraison et emballage parfaits !
Bof!
Valeurs inférieurs à celles annoncées sur les condo
Foret Métal HSS Cobalt 5% Ø2.5mm Ce foret à métaux hélicoïdal est conçu à partir d'un alliage d'acier rapide (HSS) et de Cobalt à hauteur de 5%. Cette conception lui assure une excellente résistance à l'usure...
Foret Métaux Ø2.5mm
Perçage aisé dans l'aluminium avant taraudage.
Denis E.
Fonctionne
Quel "avis" donner, si ce n'est que ça fonctionne et que le délai de livraison a été encore une fois parfait ? Il serait peut être juste intéressant de fournir cet adaptateur directement avec l'appareil qui en a besoin ... Un "p'tit kit Madame Audiophonics" ?
Les valeurs correspondent
Taraud M3
Bon produit,
Après perçage en 2,5 mm
Permet de tarauder en M3
Mise en œuvre facile dans les métaux tendres type aluminium. Les filets sont propres, vissage aisé des vis/entretoise...
Je recommande ce produit
Moyen...
….Après mesures, les 2 achetés de valeur 4,5uf, le résultat est 4,2uf et 4,3uf avec capacimètre.
Ce n'est pas la seule marque dont les valeurs annoncées sont inférieurs.
Pour moi, les seuls condo qui ont la valeur annoncée, c'est Monacor!!
JEAN-LOUIS B.
FX-AUDIO D802E Amplificateur FDA STA326 Lecteur réseau WiFi DLNA Bluetooth 5.0 Multiroom 2x80W 4 Ohm Noir La version E des amplificateurs FDA D802 de chez FX Audio intègre désormais les connexions WiFI (DLNA) qui vient compléter la connectivité bluetooth.
Satisfaction
Ce nouveau 802 avec davantage de possibilités reste égal à lui-même pour ses qualités musicales.
Seul incident, le modèle reçu avait un défaut de fabrication.
Aussitôt renvoyé le SAV a procédé à son remplacement dans les plus brefs délais.
En à peine une semaine tout est rentré dans l'ordre avec un second appareil tout à fait satisfaisant.
Un SAV efficace c'est tellement mieux !
Gael J.
Un son impeccable
J'avais branché mon PC via HDMI mais avec ce câble quelle différence!! Énorme!. Le son est beaucoup plus précis , la scène sonore plus vaste et plus détaillée. Que du bonheur.
Salvatore c.
Good pre class A with BJ
Good pre class A with BJ discrete components you need to make it play for at least 200 hours before enjoying its sonic qualities. Wide range and yield, excellent speed.
Edmond S.
Excellent cable...souple mais qui reste bien et en forme ( construction d'avec les deux tubes silicones) cuivre plaqué argent et plaqué étain..de l'aigu,de la basse et du médium.. Bon rendu sonore, facile a mettre en œuvre... Je n'en suis pris qu'un mettre pu une enceinte centrale de home cinéma, mais il y a une différence en mieux par rapport au 2,5 mm2 cuivre précédemment installé.. Plus de naturel a l'écoute
Stefano S.
Stefano Simonelli
very very solid, as promised
Stefano S.
Mellab
We bought many units
Stefano S.
stefano simonelli
very good product for the price
Stefano S.
stefano
Michael M.
HIFI 2000 GALAXY GX387 Boîtier Aluminium 80x330x170mm Façade Avant 3mm Ce boîtier HIFI 2000 Galaxy GX387 tout en Aluminium vous permettra de créer et d'habiller vos créations DIY. Solide, il s'avérera durable et...
Dominique T.
Conformité en tous points
Roberto G.
Useful for thick jobs
Jimmy P.
Servisol ipa 170
Guy A.
Câble
Stéphan A.
DOMINIQUE B.
Christophe M.
Plaqué or mais...
Hervé B.
XDUOO LINK Adaptateur DAC USB-C Hi-Res ES9118 32bit 384kHz DSD256 Les smartphones récents délaissent de plus en plus les connecteurs audio Jack 3.5mm, maintenant remplacés par de l'USB-C. Les téléphones...
topmoumoutte
Dans la cour des grands
Quand on raccorde cette dac
Florent P.
Ici audio purifer
Florent P.
Cool!!
DENIS F.
