Efthymios X.
If you need it, no alternative for the moment, so 5/5
Efthymios X.
At its price, nothing else out there.
Efthymios X.
Good for its price, beggars and choosers as the saying would go :)
Avis clients - Il y a 19473 avis.
Bruno V.
Presque parfait...
Cet outil indispensable est presque parfait. Rien à redire sur la conception. Seul reproche : les petites tiges sont d'un métal trop fragile. Autrement dit elles se tordent rapidement, et si on les redresse, elles finissent par casser. Dommage.
Mario Z.
MINIDSP SHD STUDIO Processeur Audio Numérique DSP SHARC ADSP21486 Dirac Live Lecteur Réseau Volumio Le Studio SHD (pour  Streaming High Definition ) de MiniDSP est un Processeur Audio Numérique (DSP) embarquant la solution de correction acoustique Dirac Live. Une...
What a difference
I tried several streamers and i was not satisfied. When I bought the MiniDSP SHD Studio and connected it to my DAC, Wow, out of the box, without calibration it left me speechless.
The sound much fuller (as the saying got meat on the bones), no sharpness, everything sounds far better.
But the star is the DIRAC, when I did the calibration, wow again, I didn't know my system could sound like this.
I listen to different genres of music, Jazz, Rock, Indie, Electronic and some Classic.
For example, Lindsy Starling in 88.2 / 24 format, as if I was in concert now. Whatever i play, it just sounds so much better.
I must say that Hans Beekhuyzen is absolutely right, magnificent.
The only thing I do not use is factory power supply, but I specifically bought the IFI AUDIO IPOWER X Low Noise Switched Mode Power Supply 12V to eliminate the noise of cheap factory power supply at first.
All in all Thank you Audiophonics, for your fast delivery at such a weird time.
stay well, stay healthy
Jerome L.
Utilise en condensateur de liaison sur un ampli en class a, a apporté dynamique stabilité et clarté . Leur encombrement est intéressant, je voulais mettre des jantzen mais la place manquait sur la carte d ampli.
Jerome L.
JANTZEN AUDIO SILVER Z-CAP Condensateur 800V 1.8µF Les condensateurs Jantzen Audio Silver Z-Cap permettent de maintenir une parfaite neutralité sonore et un très bel équilibre tonal. Il sont...
Excellent materiel utilisé sur des tweeters audax tw034x0
Grande aération, grande définition, pas d agressivité
Etienne T.
Gaine Thermo Rétractable 3:1 Ø12.7mm 1m (Transparente) Gaine thermo rétractable avec un ratio de 3:1, dotée en interne d'une couche adhésive assurant un meilleur maintient sur tout type de surface (plastique, caoutchouc, métal...)
Efficace mais attention !
Très bon produit, utilisé pour finition entre fiches bananes et câble 2x2,5mm, la rétractation est suffisante et le fini qualitatif et souple. Cependant pas de chauffe au briquet, celui-ci noircit la gaine, pistolet air pulsé ou gaz recommandé pour une finition transparente et propre.
Etienne T.
Bon rapport q/p
Bon câble, la mémoire de forme est bien là et il est original avec son liseré vert. Performances corrects pour un budget serré !
Patrick R.
Assez déçu par les prestations sonores
Je n'ai pas été convaincu par les résultats sonores de ces fourches qui m'ont semblé "boucher" un peu la restitution.
Patrick R.
Belle qualité de cable
Ce cable est équilibré, l'aigu est particulièrement doux et détaillé, les graves sont tendus. Se révèle après une très longue période de rodage. Le choix des connecteurs est important. Attention au montage, il y a de nombreux conducteurs à dénuder et leur assemblage peut-être délicat (1 étoile en moins). Il y a un tuto video sur le net qui peut aider.
colas c.
super medium. remplacement HP réussi!
en remplacement de HP sur revox symbol B. le couple tweeter et medium hivi s'est reveillé redoutable. qualité audio au top. timbres respectés. pas de brillance exagérée. le son reste doux même à niveau élevé. plus grande spatialisation. je redécouvre mes enceintes. super rapport qualité / prix. je recommande.
colas c.
remplacement réussi. super qualité
Vincent b.
TOPPING D90 DAC Symétrique AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Noir Successeur direct du Topping D70, le D90 profite des mêmes raffinements que son grand frère tout en mettant à jour son DAC vers une version plus...
Excellent dac
j'ai acheté ce dac en remplacement d'un AKM4490 et franchement je ne pensais pas que le gap serait aussi important : beaucoup plus d'information dans ce qu'on appelle généralement le haut médium, la scène sonore est encore plus réelle avec plus de matière et sur les bons enregistrements,
on a l'impression d'y être,,,,,
Benoit c.
Envolée du prix
Déjà utilisé en 2015, je comptais utiliser de nouveau ce cablage mais le prix a doublé depuis ?!?
Frederic V.
ELECAUDIO DF-03 Gaine Tressée Extensible Nylon (PET) 06-16mm Gaine tressée élaborée en  PET (Polyéthylène Terephtalate)  monobrins pouvant être utilisée dans une large...
Décevante
J’ai déjà monté plusieurs gaines mais celle-ci est vraiment galère. Elle s’effiloche et se troue très facilement. Elle est très souple et donc sans tenue .Sensible au moindre accrochage. Pour l’enfiler sur un câble de 3 mètres , bon courage !.
Un régal !
Ce cable est incroyable pour le prix. Beaucoup de qualités... très dynamique, précis, cristallin mais sans duretés. Le compagnon idéal pour réveiller un ampli un peu sage (comme mon petit Luxman vintage) il sera aussi parfait en complément d'enceintes un peu molles. Un régal à écouter.... j'y retourne.
Avis mitigé
Jai choisi ces fourches pour leur prix incroyable avec leur composition cuivre assorti du petit manchon isolant. Un montage rapide serti sur du cable 2,5 mm2, sur du Nes 5005 (belle petite trouvaille sur ce site) quelques écoutes rapides en aveugle sont sans appel, ces fourches ne sont pas tout à fait neutres pour le signal. Dommage, mais pour le prix on ne peut pas être trop exigeant.
Jean-Yves C.
Excellent DAC+ Volume Rapport qualité/prix excellent
Reçu il y a quelques jours, j'ai testé ce DAC sous toutes ses coutures avec des configurations très différentes:
Lecteur CD Denon en optique, BlueRay Samsung en coaxial, PC Asus en USB. En sortie, raccordement sur plusieurs amplis de puissance (Cairn, ampli tubes et transistors tous deux faits maison). Rien à dire, du bon son sur des Triangles haut de gamme.
Tests à l'oscillo impeccables.
Et en plus ce boitier n'est pas encombrant et peut se poser à plat ou sur le côté.
Je suis très satisfait.
Gianluca C.
Pangea Pico
Même chose pour le petit frère , le Pico est redoutablement efficace sous mon pré-ampli Audio Research.J'en ai finis avec les pointes et contrepointes , je conseille vivement ce produit .Merci AudioPhonics et Pangea .
Gianluca C.
Pangea Mega
produit reçu à ce jour , installé sous mon krell ( 35kg ) , le poids de l'ampli le fait basculer un peu plus sur l'avant une fois les 4 Pangea placé sous celui ci,en effet le poids de l'ampli étant plus lourd a l'avant ,ceci explique cela :) Malgré cela , je pense avoir trouvé le produit efficace contre les petites vibrations.Un produit efficace , sans ergoterie aucunes , je suis satisfait , merci Audiophonics et Pangea !
Olivier H.
upgrade alim zappiti one se 4K hdr
moins de bruit dans l'image, plus de piqué et meilleur son sur mon hc.
Olivier H.
bon câble secteur
upgrade du cable d'origine 3x0.75mm2 par celui ci de 3x2.5mm2.
Après rodage de plusieurs jours, on ne peut nier qu'il y a une amélioration, notamment au niveau des graves qui sont mieux tenus, plus de finesse dans les aiguës et une meilleur définition des timbres.
HIFI 2000 Capot Aluminium
Très bonne finition, j aurais cependant apprécié qu'il soit en 3mm d'épaisseur (il plie un peu quand on appuie dessus)
Très bon boîtier, comme toujours avec hifi2000...
Romain B.
Bouton Axe Cranté 30x23x15mm Ø6mm Noir avec Emplacement LED Ce bouton noir de 30mm de diamètre à sa base, 23mm pour sa poignée et d'une profondeur de 15mm dispose d'un axe cranté de 6mm de diamètre. De...
Pas de repère
Le grand repère blanc sur la tranche que l'on aperçoit sur la photo n'est pas un repère mais un reflet. Le bouton est donc tout noir sans repère visuel évident. Il y'a bien une toute petite encoche sur le bord mais qui est quasi invisible en vrai.
La fabrication en plastique est, de plus, très légère.
Delacour j.
Un beau et bon cordon RCA
Installé entre mon lecteur cd Onkyo Dx 710 et mon ampli préampli séparés Rotel 971 mk2 ce cordon remplace un cordon d'une grande marque commerciale au médium "un peu trop marqué" (fiches turbines); le résultat est plus que probant . Sur les Réga EL8 le son devient presque velouté(dark side au bon sens du terme)... Je le recommande .
Delacour j.
Un excellent câble
J'avais besoin d'un câble pour mon second système composé d'un ampli et préampli séparés Rotel série 971 mk2 et d'une paire d'enceintes Réga EL8 , et je reste donc toujours aussi satisfait de ce produit que je recommande...
Patrick c.
dac smsl 500 MQA
je suis satisfait de ce dac , le son est fidèle , pas de coloration à l'écoute.
Je l'ai associé à une carte usb efidelity acheté aussi sur ce site qui à grandement amélioré la qualité sonore bien qu'ayant un pc très très haut de gamme , la différence était 'audible'. Il reste cependant proche de la qualité de ma carte son supreme fx hi fi vendu avec la carte mère asus rampage v edition 10. La différence est audible tout de même avec un effet loupe au niveau du medium moins marqué (puce plus récente oblige). La distorsion est plus faible sur ce type d 'appareil . Il faut l'associer avec des éléments de qualité pour en tirer toute sa valeur. Encore un grand merci à David qui a su répondre a mes multiples questions , je l 'ai pas ménagé ;-). Je recommande ce dac mais avant tout je recommande cet enseigne qui apporte un service exceptionnel a ses clients patience et professionnalisme sont deux qualités rares de nos jour , ici vous êtes au bon endroit.
L'aspect général est bien, le montage du câble ne pose pas de problème, le serrage est bon. Musicalement neutre.Bon rapport qualité/prix.
Emmanuel B.
Un très grand tweeter...
J'ai commandé ce produit il y a quelques temps et je n'ai pu trouver le temps de finaliser mon projet que récemment.
Ce tweeter et tous simplement magique. Très faible distorsion, très rapide. Il en résulte une image stéréo très large et un agrément d'écoute vraiment réservé à des systèmes très haut de gamme. Je recommande sans hésiter une seconde. Attention le rendement est bien de 95 db voir un peut plus. Il
sera nécessaire de faire une atténuation dans beaucoup de cas d'enceinte bas rendement.
Amaury A.
C'est correct
Pour un bricoleur, ce fil est amplement suffisant pour mes projets BT (commande et audio). Il résiste longtemps à mes soudures foireuses et quand l'isolant chauffe de trop, il garde à peu près sa forme.
Amaury A.
Satisfaisant
Utilisé pour loger un assemblage d'ampli classe AB 350W. La peinture est propre, relativement résistante, le montage est simple et des visses supplémentaires sont fourni pour l'utilisation de panneaux optionnels. Le bémol, c'est la tôle du fond qui flanche un peu sous la masse d'équipements installés (3mm de débattement pour environ 4kg total). Perso, ce n'est pas gênant car c'est uniquement visible depuis l'arrière. Je ne l'utilise pas encore en montage baie.
Jean-marc B.
WBT-0708Ag Borniers pour haut parleur Argent (Set x4) Issue de la dernière génération de développement par WBT, les borniers haut-parleur 0708Ag sont pourvus de conducteurs en argent.
Ne pas hésiter
En remplacement des borniers d’origine sur un NAD C368, vraiment rien à dire ou plutôt si, on gagne dans tous les domaines et notamment sur celui de la scène sonore, elle est plus large et plus profonde. Il y a plein de détail et micodétail supplémentaires, on localise beaucoup plus facilement chaque instrumentiste. Evidemment il faut derrière le câble Hp qui va bien. vaut largement son prix.
jm
Jean-marc B.
Ne pas hésiter
en remplacement de l’embase d’origine sur un NAD C638, l’apport est sans conteste, tout est mieux et surtout les graves sont plus définis.
jm
Pier Luigi C.
ARYLIC A50 Amplificateur FDA STA326 WiFi DLNA AirPlay Bluetooth 2x80W 4 Ohm Le A50 de Arylic est un FDA aux nombreux atouts, portant notamment sur sa connectivité sans-fil et réseau très complète. Il permet donc de streamer...
High Value for Money
Are you seeking for a low cost an alternative to Sonos Amp? Here it is! I used only with the app via wifi (non bluetooth or other) and it works great able also toi pilot in decent way A pair of B&W AM-1 on my terrace. A50 is hidden in a big box (3 times the tiny amp) and is working fine. I reccomend it
Andrius M.
Huge leap in listening experience
What can i say compared to my old dac, it got left in the dust. On a rating scale last dac 5/10 this one 9/10. To hear new crisp details in the recording ive listened to a hundred times is really something. Almost cant believe this inexpensive sabre dac is so good.
On the packaging. Its in a neat little box, inside it the dac comes packaged in all around bubble wrap so theres zero chance of any damage from tossing during shipment. The connections look really nice. Driver setup is easy. DSD works, Highly recommend. I hear the engineer behind this board have made a few more products. But as is this is probably 90% as good and cant go wrong.
Elsa A.
Clés Allen indispensables pour certaines fiches
Bon matériel , pratiques avec le support à petits modèle, quasi impossibles à trouver ailleurs.
à compléter avec les dimensions anglaises!
Elsa A.
Fiches bananes correctes
Pas chères , font le job
Elsa A.
FI E48 NCF
Très belle construction qui va de pair avec un excellent rendu sonore propre à la technologie NCF
Elsa A.
Monacor SPX 30M
Excellent HP qui a remplacé 2 HP (tweeter et médium) d'une mini enceinte
à voir sur la durée.
Rémi B.
Pack Kit Enceinte Stéréo Bluetooth Portable 2x30W Ce kit à monter soi-même fera le bonheur des mélomanes cherchant à s'initier à l'électronique pour audio à travers un projet simple et aboutissant à un résultat concret.
Très bien mais pas très bon marché
Rémi B.
Rémi B.
DAYTON AUDIO CE32A-4 Mini Haut-Parleur Large Bande 2W 4 Ohm 81dB 240Hz - 20kHz Ø3.2cm Ce mini haut parleur Dayton Audio CE32A-4 est destiné à répondre à des besoins divers grâce à une plage de réponse en fréquence large. Il est particulièrement adapté pour de...
Cool
Bon produit mais vraiment petit
Herve J.
IPAR 1023B Amplificateur de puissance Class AB LM317 2x50W / 8 Ohm Le 1023B est un amplificateur de puissance classe AB compact et efficace. Il exploite un design d'alimentation très soigné et des composants audio éprouvés.
tres bon ampli
dynamique fantastique ,aeré et precis
hautement recommandé
Hervé T.
Le point chaud tourne même à froid et c'est normal s'il n'est pas arrêté en rotation. En dehors de sa température maxi d'utilisation ( 400°C env ), le PTFE est aussi utilisé pour son pouvoir autolubrifiant ( Teflon ). Finalement, grâce à ça, on peut orienter le point chaud comme on veut pour la soudure et le fabriquant n'a pas à se faire ch...! à le positionner avec précision avant le surmoulage au PTFE et cela doit se retrouver sur le prix de vente. Du coup, il n,y a pas vraiment de raison de s'en plaindre.....Pour le reste, même avis que pour le blanc !
Hervé T.
Achetée pour remplacer les embases d'origine qui s'étaient déformées lors d'un changement de fils audio. Belle finition, montage depuis l'intérieur ( on peut donc faire les soudures avant le montage, ce qui est bien pratique ) et soudure facile et tout cela pour un tarif raisonnable. Que du bonheur ! Pas besoin de plus
Hervé T.
Même avis que pour le noir. A moins d'être féru d'ésotérisme, cette prise remplit à peu prés toutes les conditions : Belle qualité, robuste, dorée pour l'oxydation (quand on a comme moi une transpiration acide, c'est indispensable), soudure facile, cables de fortes sections et tarif contenu. Que demander de plus ?
Hervé T.
Très bonne prise
Bonne finition, repérage facile car tout le corps est à la couleur, soudure aisée, l'isolant n'a pas bougé à la soudure du point chaud, permet des fils de forte section (mogami 2524) et on peut même enlever l'embout souple pour les plus gros cables. Tout cela pour un tarif très raisonnable. Soyons pragmatiques, on n'a pas besoin de plus.
Guy G.
Un excellent produit mais pour mon utilisation il est un peut petit il faudrait un diamètre supérieur d'un millimètre...
Guy G.
produit parfait
Ce produit est bien mails il ne me convient pas je ne peux pas l'utiliser pour mes enceintes que je possède.
Gérard F.
Très bonne surprise !
Pour alimenter mon Dac Sanskrit je l'ai attendu 3 mois , covid oblige, je ne m'attendais pas à une telle amélioration sur mon système à base Euphia-Mulidine !
Grave plus propre, espace sonore plus large et plus profond ,la musique est là et grandeur nature ! bravo!
