Johan V.
Exceptionnel
István R.
not easy to assemble
Paul M.
Excellent speaker cables
Avis clients - Il y a 18998 avis.
Matej J.
ELNA LAO Condensateur Électrolytique Hautes Performances 63V 15000µF ELNA propose avec les condensateurs de sa gamme "For Audio" des produits particulièrements adaptés au domaine de l'audio et de la HiFi.
ELNA LAO High Quality Electrolytic Capacitor 63V 15000µF
In my opinion, very clean sound, especially at high frequencies, of course, the other bands do not fall behind in any way.
I have tried many capacitors with identical capacity, this one seems to be the best, and the price is also OK.
I highly recommend.
Martin S.
AUDIOPHONICS TPA-S120 Amplificateur 2.1 Class D 2x TPA3255 Bluetooth 5.0 QCC5125 2x120W + 1x240W 4 Ohm Noir Le Audiophonics TPA-S120 est un amplificateur Class D capable de fournir une puissance confortable et une restitution sonore riche, le tout à prix contenu. Au cœur...
Great Product
I am genuinely impressed with this amp.
Purchased to power some small bookshelf speakers in my office, I was impressed the first time I turned it on.
Okay, in my opinion, this is obviously not a contender for a main system. However, that said, for €220 it really does a lot right. Very surprising midrange, most of what is on the recording can be heard. What the amplifier lacks is control and refinement. But the system I generally listen to, cost rather a lot more than this. I am giving 5 stars as at this price point it is a lot better than I had expected.
If you are looking for a small low cost amp. Then I think this product will satisfy. The most important thing is to enjoy the music you are listening to. I am certainly enjoying the music in my office using this amp.
jean michel G.
Utilisé pour un câble DIY. Sertissage parfait.
jean michel G.
Très bonne pince, maniable, facile à utiliser.
SHANLING EC MINI Lecteur CD et DAP Portable Sanyo 680 2x ES9219MQ Bluetooth 5.0 aptX LDAC 32bit 384kHz DSD256 MQA-CD Argent Le Shanling EC Mini se présente comme un combo lecteur CD et DAP, aussi compact que polyvalent et performant. Il profite d'une conception de grande qualité afin de...
MOYEN
J'ai acheté ce lecteur principalement pour le lecteur cd pour ma chaine secondaire . En lecture cd les timbres médium aigu ont une tendance simplifiés et synthétiques légèrement frustrant à l'écoute . L'équaliseur est de qualité moyenne et ne corrigera pas ce défaut . Dommage car les détails sont présent et le suivi mélodique est agréable . En Bluetooth ce phénomène disparait et le liaison LDAC est bonne .
François G.
Remplacement haut parleur
J'ai déjà utilisé ce haut parleur sur une enceinte que j'avais développée il y a une quinzaine d'années et j'en avais un bon souvenir.
Aujourd'hui c'est pour restaurer des enceintes JMlab dont les tweeters Focal T101 ont rendu l'âme, j'ai réalisé avec une imprimante 3D une plaque d'adaptation pour les DT28N et après simulations et contrôle, il s'adaptait parfaitement en réponse en fréquence, phase, impédance.
Après écoute, aucune modification sur le filtre n'a été nécessaire. Les enceintes ont retrouvé leur jeunesse.
HERVE H.
EVERSOLO DAC-Z6 DAC 2x ES9068AS XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Le DAC-Z6 de EverSolo est un DAC performant basé sur une structure technique soignée. Il embarque des composants haut de gamme avec notamment deux puces de...
Popularité méritée
Dac Z6 reçu rapidement(comme toujours
Pierre E.
ORACLE II 02 AOP Discret Double DIP8 (Unité) L'AOP double Oracle II 02 représente une nouvelle génération d'amplificateur opérationnel discret hybride, spécialement conçu pour...
Suitable for Fosi Audio BT20A Pro
Installed in a Fosi Audio BT20A Pro. Works well, I did not compare with the original op amp as I changed them right away.
Fast & efficient delivery by Audiophonics
Sasha B.
Sasha B.
Sasha B.
perfectly made and correctly packaged
2 ème avis
Voici une quinzaine d'heure qu'il fonctionne... Quelle amélioration !
Superbe basse, détail , la separation des canaux se fait de plus en plus précise.
J' ai autant de plaisir qu' a écouter mon tube de 10 fois le prix.... Autrement recommandé.
Thierry V.
Dommage
Celà fait plusieurs mois que j'ai acquis ce petit syteamer. Pour ce qui ai du streaming, pas de soucis, il fait bien le job et son appli smartphone est cool (Qobuz intégré). Par contre une petite faiblesse au niveau du dac et de sa partie sortie analogique. En tout cas sur une chaîne hifi correcte. La restitution est vraiment très moyenne. J'ai dû acheter un petit Dac externe et via les connexions optiques on arrive à qque chose d'acceptable. Mais encore et toujours, à ce prix, faut pas attendre des performances de fou !
Brian C.
Fiches Bananes BFA Plaquées Rhodium Ø9mm (La paire) Ces fiches bananes, bien que peu onéreuses, profitent d'une belle qualité de conception. Le design BFA de ces fiches permet un très bon contact...
I like them...use them without the sleeve
I like them...use them without the sleeve...the set of two screwws are on same side so it makes an even pressure on the wire
RAMM AUDIO S8MC Câbles de Modulation RCA Cuivre OFC 1m Ce câbles de modulation RCA-RCA RAMM Audio S8MC est de bonne qualité pour un prix très abordable. Les conducteurs du câble sont en cuivre OFC monobrin....
Rqp de folie !!!!
Ne cherchez pas ailleurs !!!
Si vous souhaitez un câble équilibré pour un prix dérisoire ce petit Ramm est une super affaire !!
Il est arrivé ce matin à la casa et alors qu'il n'est absolument pas rodé il affiche de très belles qualités.....notamment un bel équilibre entre toutes les parties du message....certes il n'est pour le moment pas aussi ouvert qu'un câble à 600 euros mais ce dernier propose une mise en avant du haut médium aigu....ce qui peut fausser l'écoute....
Brut de décoffrage le Ramm donne une fessée à un câble anglais à 250 euros....comme le disent nos amis anglophones for thé price it's a giant killer !!!!!
efficace
Utilisée sur le câble secteur de mon vinyle et l'alim de mon récepteur Bluetooth . Dans le deux cas la musique est plus incarnée ; une sensation de présence qui implique à l'écoute . Un gain très appréciable pour un coût faible . J'ai déjà remplacé des câbles secteur par des produits de marque onéreux avec des résultats moins concluants . Cependant j'ai essayé le modèle de diamètre supérieur pour les câbles de mes barrettes et j'ai était moins convaincu . Vu le prix à essayé en fonction des résultats .
Pascal C.
Amélioration notable
Utilisé en remplacement d'un câble générique pour relier mon lecteur réseau à mon hub audiophile ce câble Audiophonics contribue à ce que les extinctions de notes soient plus longues, les graves plus tendus et améliore la définition en allant chercher les micros détails.
Pas forcément le plus neutre car peut-être un soupçon chaleureux mais le rapport qualité prix est très bon et tient aisément la comparaison avec un câble Atl*s 3 fois plus cher.
Robert C.
SMSL PO100 PRO Interface USB XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA Le SMSL PO100 PRO se présente comme une interface USB extrêmement performante et incroyablement compacte. Malgré des dimensions réduites, le PO100 PRO...
Not noticeable SQ improvement on my laptop
The device didn't bring any noticeable difference in terms of sound quality in my existing laptop configuration. Sound quality using direct USB cable to DAC and using USB over SMSL PO100 to DAC gave almost the same SQ results.
Rather save the money and by something like Wiim Pro or Wiim Pro Plus for audio streaming purposes.
Robert C.
Valid improvement over laptop/PC as a streamer
I was surprised with the sound quality using Spotify connect over Wiim Pro Plus instead of my laptop. The difference in favor of Wiim is more then obvious.
Pros: Easy of use, Wiim app, SQ for the price, SQ can be further improved with better external power supply.
Cons: Only Coax and Optical outputs (USB would be ideal), no native support for DSDs (at least I couldn't get it working in my setup).
Stefano C.
1877PHONO CryoGold-Ag Fils de Litz Argent / PC-OCC Plaqué or 40mm (x4) 1.0 - 1.2 Un jeu de fils de liaison (Headshell Leads) haute qualité pour cellule de lecteur vinyle.
Not a good experience for me
I’m sorry to give a negative review on what seems to be a very high quality and well thought out product, but I have to share my experience. I have used this cables to connect my Benz Micro Glider SL to an Ortofon LH9000 headshell. Compared to the wires that come with the shell (I guess the ortofon 6N headshell leads), the 1877phono ones led to a more sterile presentation, less precise imaging, less threedimensionality and body, bass less controlled, highs a bit fatiguing, less dynamic. The clips on the shell side were a bit too large, but they allowed a sufficient grip on the pins and I don’t think that is the problem leading to the lesser presentation. I think the problem is most likely the rhodium plating. in my experience rhodium plating on audio signal connectors lead to sterile and harsh sound, this is the third time I have bad experience with rhodium, the other two being Ramm spades and Neotech XLR connectors. In all cases I had to switch back to gold or silver plating even giving time to break in. I have all power connector furutech rhodium plated but for audio signal now I’m really done with rhodium, I’ll try no more. To give context I have a Garrard 401 TT with modified SME 3009 II improved, Mark Levinson 26 and 23.5, and Tuscanini planar magnetic speakers (very revealing of any insignificant defect along the audio chain as in this case).
F M.
WONDOM AA-AB32221 Module Amplificateur Stéréo Class D TAS5613 2x150W 4 Ohm Le Wondom AA-AB32221 est un module amplificateur stéréo capable de délivrer une puissance de 2x140W sous 4Ω. Disposant d'une architecture Class D...
Impressionnant (suite)
Je reviens car mon avis a été tronqué...
Je confirme donc l'efficacité de ce module qui envoie du lourd. La puissance est bien là (sous 36 volts), certes diminuée dans du 8 ohms, avec un son percutant est clair.
Normunds Z.
Recommend
Great device!
Normunds Z.
Câble HDMI 2.1 8K 60Hz 48Gbps HDR eARC ALLM Dolby 2m Ce câble HDMI 2.1 hautes performances supporte les transmissions vidéo en 8K 60Hz et 4K 120Hz grâce notamment à une bande passante de 48Gbps. Ses...
Recommend
Excellent cable, noticeably improved the picture from computer to TV.
Cosse Plate Femelle Isolée 4.8mm Ø3mm (x10) Ces cosses acceptant des câbles jusqu'à 3mm vous permettront de connecter simplement vos hauts-parleurs. De plus, celles-ci sont composées d'un alliage de...
Attache Câble Adhésif 20x20mm Noir Cet attache câble adhésif se fixe simplement sur une paroi afin de vous permettre de regrouper vos câbles. La base de l'attache câble est...
Pratique
Très pratique et colle bien aux parois.
Je me suis lancé sur la construction diy d' un ampli classe d a partir de ce module 3e audio.
Ayant déjà eu un ampli 3255 en remplacement de mon tube parti en Sav, celui est incomparable !
Beaucoup plus nuancé, musical, silencieux et précis. Il représente sans doute l' avenir de la classe d , bien conçu et incontournable.
A ce prix, pas d' hésitation a avoir.
Je recommande sans réserve.
MP-H250S48 Module d'Alimentation à Découpage SMPS 250W 48V 5A PFC Ce module d'alimentation à découpage SMPS MP-H250S48 est en mesure de délivrer une tension de 48V et un courant de 5A pour une puissance de...
Bonne alim.
Simple et efficace pour une implantation réussie. Fonctionne parfaitement.
Pas ouf
Assez déçu par ce boitier dont le système de fixation des capot est mal conçu selon moi. De plus, les petites vis de fixation sont trop courtes pour atteindre l' écrou dans la rainuré. Y' a mieux.
Foret Étagé Acier HSS-4241 15 Niveaux Ø4-32mm Ce foret étagé à 15 niveaux, de 4mm à 32mm, et conçus en acier HSS-4241 permet de percer des matériaux tels que le fer, l'aluminium ou...
Nickel !!
Fait des trous avec précision . Dans de l' alu 3mm, c' est comme dans du beurre..je recommande
Embase IEC C14 Cuivre Pur Plaqué Or avec Interrupteur à Bascule ON-OFF et Fusible 250V 10A Cette embase IEC C14 est idéale pour une intégration dans un appareil DIY en tant que connecteur d'alimentation. L'embase intègre un interrupteur à...
Oui, mais....
Adapté pour une épaisseur maxi de 1,5 mm. Sinon, bonne connections et qualitatif.
Cablage interne ampli
Utilisé en cablage interne d' un ampli classe d 3 E audio, c' est très bien.
Cablage interne
Utilisé pour un cablage interne d' un ampli 3e audio stéréo, très bon résultat.
DURATOOL D03048 Multimètre Numérique 500V 5A 2MOhm Ce multimètre numérique Duratool D03048  dispose de l'ensemble des fonctions de mesure standards et convient pour tout projet professionnel ou DIY électronique.
Fait très bien ce pour quoi il est conçu.
Borniers HP Plaqué Or 24k Ø19mm x 50mm (La paire) Ces borniers HP offrent une belle qualité de conception à prix abordable. Leurs contacts sont effet conçus en alliage de cuivre plaqué or 24k,...
Parfaits
C' est lourds, solide, bien fabriqué et très sérieux, très bons borniers.
pascal P.
Déçu
Après avoir lu nombre d'avis élogieux sur ce câble, j'étais très bien disposé, mais je suis très déçu. Médium creux et froid, aigu métallique, le grave est très (trop ?) présent. Courbe en V physiologiqie. P
Gerard T.
Des les premières écoute le Gustard fait de la très belle musique
Mais avec un coté un peu glacé
Il faut être très patient.
Mais une fois rodé je confirme que ce Dac est vraiment fantastique la musique est libérée aucune coloration.
Et encore meilleur avec un drive extérieur 3Dlab.
Bravo..!
Edmond H.
LPSU25
Achetée pour améliorer mon Raspberry DAC PRO 2,
Je suis ravi du résultat obtenu. Graves mieux tenus, reproduction douce et puissante du spectre, possibilité de monter le volume sans distortion si je compare à l'alimentation de base. Un vrai et grand plus pour moi. Merci Audiophonics
FURUTECH CF-202 NCF (R) Fiches Banane Plaqué Rhodium NCF Traitement Alpha Ø5.5mm (La paire) Avec les CF-202 NCF (R), Furutech dévoile des fiches banane haut de gamme, offrant d'excellentes performances de transmission avec des contacts composés de cuivre...
Pas de Surprises
Après avoir acheté, monté avec bonheur les fiches RCA, de la même catégorie.(FURUTECH CF-102 NCF), je me suis décidé a changer les fiche bananes de mon câble d'enceinte( Crystal Cable Ultra) , qui avait de simples bananes Furutech cuivre rhodium visée , par ces magnifique Bananes, qui sont d'une fabrication incroyable, qui ont apporté , un gain de finesse, de micros-détails , et un recul du bruit de fond, un petit plus de véracité, mais cela ne fait qu'une semaine , quelles 'tournent' le rodage n'est pas terminé. J'avoue que la remise des soldes d'hiver, mon décidé , à effectuer cet achat qui et quand même conséquent, au vu de la multiplication des prises!!!
Eric J.
SBOOSTER BOTW P&P MKII Alimentation Linéaire Régulée 12V 3A / 13V 2.25A / 13.5V 2.1A Avec l'alimentation linéaire régulée SBooster BOTW P&P ECO MKII, la purification du signal électrique commence immédiatement là...
Je l'emploie pour alimenter ma box internet THD Redbox by SFR. L'alimentation est bien fabriquée et inspire confiance. Elle chauffe peu; consommation: une petite trentaine de watts.
Jacky D.
NEOTECH NES-5002 Câble Haut-Parleur Cuivre UP-OFC 2x2mm² Ø9.5mm La gamme NES-5000 de Neotech est composée de câbles à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Le NES-5002 intègre 2...
Bon câble
Câble qualitatif. Souple et facile à dénuder. Rendu sonore très correct, à confirmer après rodage. Livraison ultra rapide, bravo Audiophonics !
Jacky D.
Top qualité
Belle qualité. (fiche et vis). Elles tiennent très bien dans la prise. Pourquoi dépenser plus..!
Amélioration : séparation visuelle du + et - (rouge et noir) trop faible. Il manque un cerclage de couleur (que j'ai fait avec ruban adhésir de 2mm de large). Livraison ultra rapide, bravo Audiophonics
HERVE H.
AUDIOPHONICS Trigger 12V 230V sur prise IEC Déclencheur d'alimentation Cet accessoire, fabriqué en France, dans nos ateliers, permet d'ajouter aisément une fonction d'allumage automatique (trigger) à vos appareils ne...
Livraison rapide.
Petit accessoire malin qui fait parfaitement le job.
Après, il y aura toujours le débat: Laisser ses électroniques sous tension afin d'éviter les chocs à l'allumage et garder la bonne température de fonctionnement pour une meilleure écoute...ou tout éteindre...
Mark M.
Great sounding connector at a great price!
I built a cable with Belden 4694R 12G video cable for ,
my. Merason Frerot DAC. Awesome sound; so life like and real. I am buying more!
bien mais...
Nette amélioration d'un point de vue sonore, le médium est bien plus ouvert, c'est plus précis aussi sur le reste du spectre.
Il y a bel et bien une différence avec une prise Legrand.
L'embase est qualitative et upgrade réellement mon système.
Je regrette juste que les produits Furutech aient autant augmenté...ça devient dissuasif en dépit de leur efficacité et de leur qualité.
Par ailleurs, l'installation n'est dans mon cas pas achevée puisqu'elle ne s'encastre pas dans un boitier mural standard (prise Legrand mozaic), et dépasse de 3 cm. Elle tient aux 2 vis latérales du boitier.
Les conducteurs sont positionnés en haut et en bas, à la verticale, et non à l'arrière de l'embase, ce qui va m'obliger à élargir l'emplacement plus tard. A prendre en considération si vous avez des murs en béton ou en pierre par exemple...
Eric J.
Inspire confiance
J'emploie cette alimentation pour mon box internet thd red by sfr. Elle semble bien fabriquée, les nombreux adaptateurs sont pratiques. Elle alimente bien la box en chauffant peu. Consommation une petite trentaine de watts.
SMSL VMV D2R DAC ROHM BD34301 XMOS XU316 Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA Le SMSL VMV D2R se présente comme un DAC haut de gamme, offrant de très hautes performances grâce à une conception soignée et des composants...
D2R
The elegant, very musical DAC surprised me with its sound clarity, its range and space of sound delivery, fast and accurate high-resolution sound delivery, excellent setting options, only when switching the type of sound resolution, you can hear a slight banging, but that will definitely be solved by later controls, I extremely satisfied with this thing
LAURENT L.
Quel ampli
Moi, qui recherche toujours des test a gauche ou à droite avant de choisir.... Ce coup ci j'y suis allée un peu a l arrache, le son est formidable avec mon focal celestee, de plus le s.a.v répond très rapidement. Première commande et sans doute pas la dernière. Encore merci
Henry G.
HYPEX SMPS1200A400 Module d'Alimentation à Découpage 1200W 2x64V L'alimentation à découpage SMPS1200 est un modèle à très haut rendement capable de développer une puissance nominale de 1200 Watts dans...
Acheté en remplacement d'une alim similaire cramée après 6 ans de bons et loyaux services suite à une mauvaise manipulation.
Excellente qualité de fabrication, composants de qualité, notice très détaillée. Bien sous tout rapport.
Jani R.
AUDIOPHONICS Câble Trigger USB-A Mâle vers Jack 3.5mm Mono Mâle 1m Extrêmement pratique, ce câble trigger USB-A vers Jack 3.5mm mono, assemblé en France dans notre atelier, vous permettra de contrôler l'allumage...
Just works
I looked for a product like this for years and haven't seen anyone else sell one.
Affordable AVRs don't have trigger outs but they often have a USB port. Arendal Subwoofers need a trigger signal to wake up and stay on at low levels.
This cable is the solution and it works great. I just wish there were options for longer cables and 90-degree USB-connectors.
Philippe L.
Utilisé pour relier un laptop HP de 10 ans d'age à mon tout récent Eversolo DMP-A8 via sa prise OTG: reconnaissance et mise en liaison immédiate entre les appareils, transfert de 2 répertoires HiRes de 1.4 et 0.9Go en moins d'1 minute et sans accroc ! Perso, je préfère utiliser le câble physique plutôt qu'un protocole Samba.
