Lacking
The best
These are a little difficult to work with due to the hollow pins, but they are the best sound wise. Have used Viborg and others...
Astonishing- finally
I rated this cable before a few years ago when using fairly budget RCA connectors. I terminated it today with Neotech NEX GD...
Avis clients - Il y a 19516 avis.
Frederic S.
Très bien dans mon cas
Venant du Sommercable Orbit 240, le passage au w3103 a été très bénéfique sur mon système: Little Dot Mk III en préamp / Nuprime STA 9 vers Elipson Planet L. Tout est plus équilibré, dense, plus aucune fatigue et cerise sur le gâteau; une scène plus large et profonde.
Jesper B.
ELFIDELITY AXF-102 ULTRA Filtre Alimentation USB 3.0 Externe pour PC Le Elfidelity AXF-102 Ultra est un filtre d'alimentation USB pour PC. Il permet notamment d'effectuer un filtrage progressif multibandes de l'alimentation ainsi qu'une...
From good to great!
Adding this device the music opened up and sounds more natural and engaging. Soundstage is deeper, wider and clearer, especially I noticed voices that before were a bit compressed now widened and became more balanced and natural. The whole sound is more like a high res picture with rich colors would be to the eye, but for your ears - just a great upgrade to my system!
I noticed it could run without an extra 5v feed, but with a quality 5v power it really made a difference, especially as my DAC is fed 5v via the USB cable now coming out of this USB power filter.
I now stream music from a Mac Mini with Audirvana (program) running Tidal Master Quality, via this Elfidelity AXF-102 ULTRA USB power filter feeding it with 5v from an iFi iPower, then to the SMSL M300 DAC, then via the FX-Audio Tube-00J Limited preamp powered with iFi IPower 12v, and then to Emotiva Stealth 8 active speakers on stands with an extra 2*9,5 kg granite stone weights on to make the speakers not move when playing.
Then of course there are good cables between each of these devices to make the sound great.
If you stream music via USB and you have a quality to high end stereo you can expect to get a good and, at least in my setup, noticably better sound!
remy e.
tissus tout a fait correct pour mon utilisation
Correspond a ce que je recherchais un tissus masqué derrière une grille métallique, entre les hauts parleurs et la grille
Holger B.
Préamplificateur Symétrique RCA XLR 10x NE5534D 4x NE5532D Potentiomètre ALPS avec Télécommande Ce préamplificateur symétrique offre une excellente qualité de conception se basant sur des circuits reconnus pour leurs performances et la qualité...
Préamplificateur équilibré RCA XLR
Tout d'abord, je viens d'Allemagne et j'utilise le traducteur Google pour la traduction (allemand-français)!
J'ai acheté ce préamplificateur car mon lecteur réseau Atoll MS120 n'a qu'un étage de sortie analogique satisfaisant. Avant cela, j'ai reçu des conseils de M. David Aubert, qui m'a recommandé cet appareil.
Les performances de ce préamplificateur sont plus que très bonnes! La clarté du son est tout simplement fantastique! Une richesse de détails, une basse profilée ...- Génial!
Pour moi, ce préamplificateur est de loin le meilleur que j'aie jamais eu avec moi, et pour un prix de 399 euros!
Pour les personnes qui préfèrent le son neutre, ce préamplificateur est le bon!
Un grand compliment au constructeur!
BRUNO B.
look HDG !
vraiment enchanté par ces câbles, finition exemplaire look HDG affirmé ! et que dire a ce tarif là ! rien ,je ne m'attarderais pas sur le rendu ! sujet a polémique ,donc pour moi ,cela me conviens donc c'est le principale !
au tarif proposé et finition , n’hésitez plus !
MICHEL B.
La qualité de fabrication (un vrai 75 ohms) et le résultat sonore sont au rendez-vous.
CANARE est excellent !
Jose D.
Produit Etonnant
Je l'ai branché sur une prise libre entre mon informatique et mon audio, le son est significativement plus "propre" effectivement comme déparasité
Fabien L.
Petit mais il fait le maximum
Micro acheté pour mesures acoustiques avec REW...
Parfait.
Je recommande néanmoins d'acheté avec un pied pour un positionnement optimal...
Audiophonics au top reçu 3 jours après la commande...
jean-paul V.
A recommander
Pour un usage domestique polyvalent et complet en entrées et sortie... bluffant par son ouverture au regard de la taille qui permet de le caser n'importe ou !
je recommande sans hésitation
(voir la fiabilité dans le temps car achat récent).
Rémy D.
Très bonne facture pour ce petit préampli, avec un très bel équilibre sonore. Petit look sympa aussi.
Zoltan E.
ARMATURE HECATE LT Interface USB SPDIF XMOS Xcore 208 Asynchrone TCXO (Version DIY) Armature propose désormais son excellente interface USB SPDIF XMOS dans une version simplifiée, mais toujours très performante, permettant de la proposer...
Great product.
I am a tube amplifier builder. But now I build a tube DAC. This product very very good for USB connection. The ARMATURE HECATE XCORE 208 is better but in the middle frekvencies the LT better.
eric b.
TINYSINE TSA7600 Module Amplificateur TPA3221 2x100W + 200W Le TinySine TSA7600 est un module amplificateur en Class D et disposant de 3 canaux, capable de délivrer 2x100W + 200W avec un rendement élevé de 90%. Le module peut être...
joli son !
suffisant .
j ai tout misé sur le traitement acoustique alors pour moi les câbles sont considérés comme la serice qui décore le gâteau .
acheté pour remplacer des rj45 du commerce et avoir l impression d un mieux. bon ... toujours est il tres bonne qualité des câbles réalisés par audiophonics .
petit bémol j aurai préféré economiser quelques euros supplémentaires que d avoir l étui fourni avec le câble , inutil , accompagné de son empreinte carbonne .
Didier L.
Audiophonics nickel, DATS bien mais ...
Concernant la livraison, Audiophonics ultra rapide, vraiment super.
Concernant le DATS, avis plus mitigé. C'est un super produit, facile à prendre en main. Mais il n'y a pas vraiment de documentation. Le plus compliqué reste la mesure du Vas d'un HP. Difficile d'obtenir la bonne mesure, chacun y va de son avis sur la méthodologie et chaque méthode donne un résultat différent. Difficile de faire une simulation de charge derrière. Je vais écrire directement à Dayton Audio pour avoir plus de précision.
Roman M.
TELEGARTNER MFP8 CAT.8.1 T568B Connecteur RJ45 Ethernet Cat 8.1 High-End Métal Ce connecteur Ethernet au format RJ45 profite de la toute nouvelle norme Cat 8.1. Cette dernière vous permettra de concevoir des câbles de haute qualité,...
Great product! Audiophonics Great Store! Everything is quick and to the point!
Thanks a lot!
Dhafer D.
Le DAC qui vous ruine pas
2 mois se sont écoulés depuis mon achat et j’avais envie de compléter mon avis du 13/01/2020 sur ce dac.
Sortie Casque avec un AKG702 :
Avec une moyenne de 2 heures d’écoute par jour, le son métallique du tout début a complètement disparu après environ 1 mois. Toujours aussi analytique et toujours aussi neutre, mais avec en plus une transparence évidente. L’AOP jrc5532 qui s’occupe de la sortie casque est vraiment une référence. Cependant, selon moi, il est fait pour composer et pour produire de la musique, plutôt que pour l’écouter et l’apprécier. Il ne me transporte pas.
Certes, tout est correcte, tout est à sa place, mais ce n’est pas musical, ce n’est pas entrainant.
J’ai pensé à changer cet AOP pour un OPA1622 qui selon mes recherches est conçu spécifiquement pour les sorties casques.
Sortie ligne vers un Marantz PM5005 et des focal chorus 706 V :
Bon, cet OP275 est vraiment une aberration. C’est tout l’inverse du 5532, il a une equalisation prononcée et claire en forme de V, comme si vous mettez la preset Rock sur un lecteur de fichier audio : basses et aigus augmentés, medium en retrait. De plus, sur les basses, il me donne l’impression que c’est lent, c’est paresseux, que ça tarde à sortir.
Si vous écoutez beaucoup de rock des années 80, vous allez aimer ! Autrement, un remplacement me semble evident.
J’ai pensé à changer cet AOP pour un OPA627 qui selon mes recherches s’avère être l’une des références en la matière.
Petite remarque sur le pilote Win10 en téléchargement sur ce site : il est plus stable que celui qu’on trouve sur le site de Xmos, mais la prise en charge du DSD en natif n’est pas systématique avec tous les lecteurs (Foobar : oui, Jriver : non ).
Pour conclure, cet appareil est sans doute un très bon dac et surtout un très bon amplificateur casque. Il offre en plus la possibilité de changer la signature sonore selon les gouts de chacun.
Vivement la date de réception des nouveaux AOP :-)
MICHEL B.
Qualité et musicalité excellentes
Le câble optique VIABLUE H-FLEX est très rigide et c’est tant mieux. Cela évite de plier la fibre optique en le manipulant. Il suffit de prendre une longueur de 2,50 m pour ne pas avoir de problème de branchement. A ce propos, les connecteurs sont d’excellent qualité, la fixation est parfaite, cela ne branle pas comme beaucoup de câble bas de gamme, voire haut de gamme.
D’un point de vue musical, la musique passe intégralement avec toute sa dynamique et tout son naturel. Aucune dureté, même sur de grosses formations orchestrales (test effectué sur des enregistrements de référence). L'image stéréo est en 3D. En résumé ce câble est meilleur que bien des concurrents vendus plus chers. Merci à Audiophonics de vendre des produits bien sélectionnés de très bonne qualité.
Le câble le coaxial CANARE est aussi une référence.
Daniel v.
boitier Lite Audio
Je me suis servi du boitier pour en faire un préampli à tubes, j'ai bien sur changé la plaque supérieure afin d'y monter les supports des tubes. je n'ai eu aucun soucis avec ce boitier que j'ai trouvé design et solide. j'ai eu effectivement quelques soucis avec les vis du fond de boitier mais sans plus je n'ai pas eu besoin d'en racheter. j'ai aussi changer les 2 boutons en face avant mais uniquement car j'ai préféré des boutons de couleur dorée. Je conseil donc ce boitier en fonction préampli.
Daniel v.
tube 12AT7
fonctionnement correct rien à redire
Daniel v.
connecteur 2 pôles
bon produit avec verrouillage sécurisé
Daniel v.
Bouton Aluminium Axe Cranté 34x17mm Ø6mm Cuivre Ce bouton en Aluminium de couleur Cuivre dispose d'un axe cranté de 6mm de diamètre et pourra donc être installé sur tout axe de potentiomètre...
bouton or
bon produit rien à dire
Daniel v.
sélecteur
Daniel v.
voltmètre
bon produit rien à redire
Daniel v.
voltmètre
Ce voltmètre ne fonctionne pas en alternatif, en le branchant directement sur le secteur avec ou sans résistance l'aiguille oscille à toute vitesse. Je l'ai donc utilisé en continu (avec résistance) et là il fonctionne !
Dirk d.
XDUOO TA-10 Amplificateur Casque USB DAC Tube Hybride class A Le xDuoo TA-10 est une amplificateur à tube et DAC pour casque, intégrant une puce USB XMOS. Il saura vous offrire une restitution sonore des plus juste.
xduoo ta-10
Après de longues heures d écoute,que dire sur ce produit .
Vraiment déçu!!!
Pas par le produit en lui même, mais par son prix.
Je m explique par la...
Dans ma région, plus de magasin de hifi, donc difficile de se faire une idée .
Je fais comme tout le monde, je regarde les commentaires ,sur les produits qui m intéressent .
J achète au pif en fonction des éloges, ça passe ou ça casse.
J ai pris contact avec ce site , en leur expliquant mes attentes.
Ils m'ont dit que le produit allait me convenir; c était un bon choix!
Badaboum ,un flop total, 299 euros mis a la poubelle.
J ai un Dac à 89 euros qui fait le même boulot .
J ai fait écouter à plusieurs personnes,nous sommes unanimes; pratiquement pas de différence lorsque on écoute de la musique.
Par contre, le xduoo ta-10 s'en sort moins bien que mon dac magic en écoute vocale .
Des " S" qui sifflent, très énervant.
En général je ne mets pas de commentaire , mais je suis trop déçu de ce produit .
Claude P.
Rudy C.
Rudy C.
RASPTOUCH I-SABRE ES9038Q2M KALI Lecteur Réseau Tactile Contrôleur de Volume Découvrez la toute dernière version du lecteur réseau tactile ES9038Q2M de chez Audiophonics. Version améliorée intégrant le tout...
Fabrication :
Qualité sonore :
Logiciel :
Qualité sonore : 5/5
Utilisation : 5/5
Dario L.
Perfect purchase
avis mitigé
ELECAUDIO SILVER LINE MKII Câble Secteur OFC 3x3.5mm² C7 1.5m Le câble secteur est une partie extrêmement importante dans votre installation HiFi, il ne faut donc surtout pas les négliger. Ainsi, nous avons conçu...
Très satisfait!
Pas toujours évident de trouver des câbles secteurs montés en C7. Souvent ils sont disponibles en 1m d'ailleurs, ce qui est trop court pour mon dac.
Je pars d'un cordon C7 ordinaire, pour cet Elecaudio sans doute très dimensionné pour un dac! Si le Pangea ac14se avait été dispo en 1,5m, j'aurais choisi plutôt ça.
Il me semble que l'Elecaudio apporte une amélioration sur le son, mais toujours difficile à dire, car c'est subjectif... en tous cas rien à dire, le son est équilibré, de la matière à souhait alors que demander?
Super!
Grâce au tutoriel d'Audiophonics et à la fiche de ce câble qui indique bien le sens de branchement des fils secteur, le montage s'est déroulé sans problème.
J'ai pris ce kit en 5m pour la longueur dont j'avais besoin, disons 3,50m, ce qui me laissera possibilité de monter un autre câble en 1,5m.
J'avais un Pangea ac14se en 2m, trop juste en longueur.
Avec le câble Elecaudio, le rendu audio est très satisfaisant je trouve, par rapport au Pangea qui est pourtant un bon produit.
Merci à ce site pour proposer de tels produits, ça rend grand service!
Excellent pour cellule MM !!
A petit prix, voilà comment améliorer l'écoute de vos vinyles.
Ce boitier simple et très bien construit d'une finition impeccable a considérablement amélioré l'entrée phono MM de mon ampli Harman-Kardon HK990.
Le gain obtenu en terme de dynamique et de transparence ont révélé les qualités de ma cellule Audio Technica Vm530en bourrée d'énergie.
J'ai changé le condensateur chimique 16V 2200 µF par deux autres audiophiles très haut de gamme tellement je suis satisfait de cet incroyable boitier phono. A acheter sans hésiter.
Suaudeau b.
Correct
Alimentation stable, ne chauffe pas, ventilo assez discret, mais réglage fin du voltage très imprécis et peu stable. Rapport qualité prix favorable quand même.
Thomas C.
AUNE B1S Amplificateur Casque Portable Discret Class A Le Aune B1S, nouvelle version du B1 impressione par sa conception en Class A intégrée dans un boîtier au format réduit, idéale pour une...
très déçu ...
Dans l'absolu le son reste très bon ... mais appeler ça un amplificateur est une usurpation ... quel manque de puissance !!!
très très déçu ... couplé à un HD600 ...
L'investissement ne vaut pas le coup.
Merci à Audiophonics pour l'envoi rapide et le suivi irréprochable ... dommage que ce soit pour ça ...
Didier P.
mini sub...maxi son!
mon enceinte portable "maison" manquait de peps...tir corrigé avec cette enceinte qui a tout d'une grande!
très efficace dans les fréquences sous 100Hz
Igor T.
Igor T
When you're turning the volume control, unpleasant and loud noise in the headphones is clearly audible.
This DAC does not reproduce low sound frequencies at all.
Maybe I've got a defective one.
In any case, I'm going to make a return of the product...
High and medium frequencies are a little bit clearer compare to the integrated sound card, but not striking. I can’t say that the sound is impressive and you immediately will hear the difference between DAC & integrated sound card.
Again, maybe the reason is I've got a defective product.
Hi,
the issues you're experiencing may surely come from a defective unit.
It's impossible for a Sabre DAC based product to doesnt provide any low frequencies.
I'll forward your post to after sales team who are gonna take care of your issues.
Yoakim T.
DAYTON AUDIO DSS2-BK Pointes de Découplage Noir (Set x4) Ces pointes de découplage vous permettront d'offrir à votre système un son plus clair, une image sonore plus large et une meilleure réponse dans les basses fréquences.
Vraiment très bon et esthétique, supporte sans soucis mes enceintes de 35kgs.
Remarquable !
Acheté pour relier un dac AudioGD et un AudiaFlight Three MKII , tout de suite disparition du bourdonnement des graves (que j’attribuais à l'acoustique de ma pièce !) , très belles voix , aigus très bien gérés, les micros détails sont bien présents , on perçoit bien le coté acidulé de certains aigus (violon) mais sans aucune stridence : remarquable . Un câble rapide et très transparent, sans aucune coloration.
Ioannis A.
Fast service, excellent product
Fast service, excellent product.
jean-Christian D.
Adaptateur Secteur Alimentation 100-240V vers 19V 5A 90W Cet adaptateur secteur permet de délivrer une tension de 19V et un courant de 5A. Il dispose d'un connecteur Jack DC 5.5/2.5mm en sortie et d'un connecteur 2 pôles...
jean christian
alimente correctement mon ampli
ne pas oublier de commander le cordon secteur .
attention! alimentation a découpage : perturbe le cpl D'une freebox
magnifique
que dire de ses petits câbles. tout la largeur des basses aux aigus gagne en douceur détails et transparence. la dynamique et encore plus ressentie les instruments classiques et les batteries et autres instruments en bois djembé etc. etc sont très physiques et palpable..les voix gagne en réalisme douceur et ont peut toucher l artiste..encore plus... le tout renforcé par une excellente musicalité. des timbres ma fois bien correct pour se prix..en résumé..acheter le vous comprendrez mieux..prochain achat un câbles d enceintes ou modulations.quel et le mieux..;-)
Ivan I.
RASPDIGI LTE LVDS V2 Lecteur Réseau I2S LVDS HDMI Reclocker Allo Kali Format Audio-GD Nous vous proposons un modèle mis à jour de notre RaspDIGI LTE avec cette version V2. Celle-ci profite de la solide base de la première version, à...
Good device
Reasonably priced. Easy to configure. Sounds great over I2S
JEAN-PHILIPPE B.
Excellente rallonge usb
Rallonge de grande qualité avec double blindage. À recommander.
Guy L.
Guy13
posés sous un graveur de CD plus aucune vibration pendant les opérations de finalisation. Excellent le Sorbothane
Guy L.
guy13
excellent filtrage qui apporte beaucoup de naturel et de présence
patrick w.
Tres tres bon produit.Acheter pour remplacer un dac rega qu'il bat sur tout les plans.les aigus sont tres détaillés mais doux ,le medium est excellent et le grave descend tres bas mais est hyper tendu.Ecouter ALL OVER ME de MARK CURRY (morceau test de la nouvelle revue du son) est une pure merveille. J'utilise les sorties symétriques avec le cable pangeas premium balanced qui apporte encore plus de details.A conseiller sans reserves un produits de toute beauté.Et merci a l'equipe d'audiophonics pour leurs tres bons conseils. Je vais poster un avis sur la carte ELFIDELITY AXF 100 PRO 3 qui est aussi un excellent produit
Andrei k.
PANASONIC FC Condensateur Low ESR 16V 3900µF Les condensateurs Panasonic FC profitent d'une belle qualité de conception et d'un faible ESR. Ils seront adaptés à la plupart de vos projets, que ce soit...
3900mF/16V
Rapporte Q/P excellente!
Andrei k.
ELNA LAO Condensateur Électrolytique Hautes Performances 63V 15000µF ELNA propose avec les condensateurs de sa gamme "For Audio" des produits particulièrements adaptés au domaine de l'audio et de la HiFi.
Très bon produit.
Stephane M.
Idéal
Parfait pour recâbler une platine Vinyle. Blindage suffisant pour ne pas avoir de hum.
