Gianfranco P.
crystalline
Alexandre G.
Thierry C.
Avis clients - Il y a 19516 avis.
Renzo L.
Câble d'Alimentation Jack DC 2.5mm Plaqué Or 1m Ce câble d'alimentation se compose de part et d'autre d'un connecteur Jack DC 2.5mm. Il profite d'une belle qualité de fabrication, avec des connecteurs...
Connector too short
I believe they are 5.5/2.5 plugs, in my opinion the plugs really do look that size but they are about 2mm shorter than the norm and unfortunately in my case they don't make electrical contact even though they do plug in cleanly, maybe they are designed a non-standard size because another 5.5/2.5 cable Audiophonics reference 16283 has no problems. I would not recommend this cable unless you need shorter 5.5/2.5 connectors. I'm not sure if I can return the cable because sending it back would be too expensive compared to the price of the cable.
Renzo L.
Câble d'Alimentation Jack DC 5.5 / 2.5mm 0.5m Ce câble d'alimentation permet de connecter des appareils équipés d'entrées Jack DC 5.5/2.5mm de façon à les relier à des alimentations linéaires régulées compatibles.
Very Good
Doesn't look cheap at all and the 5.5/2.5 plugs go in cleanly and make stable electrical contact.
Paulius M.
Connecteur Jack 4.4mm TRRRS 5 pôles Plaqué Or Nu Ce connecteur Jack 4.4mm mâle 5 pôles est idéal pour un montage DIY  et vous permettra de concevoir un câble symétrique efficace. Ses...
Great connector, easy to solder
This one has bigger areas to solder wire onto, than the similar one which comes with a screw on sleeve, so this one is a better addition to that sleeve.
Paulius M.
Connecteur pour Casques HD800 / HD800S / HD820 / D1000 Plaqué Or Ø4mm Noir (La paire) Cette paire de connecteurs est conçue autour du savoir faire de la marque. Disposant de deux pins, ils sont adaptés pour la conception de câbles compatibles...
As good as original connectors
To me it even seems better than original, fits perfectly.
Henrikas S.
SMSL SU-6 DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Noir SMSL propose avec le SU-6 un DAC performant et abordable, profitant d'une conception soignée garantissant une restitution sonore précise.
SMSL SU-6 DAC
Solid DAC
This SU-6 is very nice with excellent build quality. The sound is clear, highly resolving and neutral. The wireless sound using the LDAC codec is also of high quality. I am very impressed with the performance of this DAC.
Fast delivery. The item was securely packaged.
Thanks seller.
DYNAVOX Liquide de Nettoyage pour Cellule Vinyle Ce liquide de nettoyage de chez Dynavox permet d'entretenir le diamant de vos cellules efficacement. Il est livré avec une petite brosse permettant d'appliquer le liquide...
un bon complément
Je l'associe avec le produit polymère WINYL de ce même site . Le polymère apporte la netteté et la propreté de son et le liquide dynavox apporte du relief au son . impression d'avoir changé de platine .
WINYL ONE-TOUCH POLYMER Nettoyant Solide Polymère pour Diamant Platine Vinyle Le Winyl One-Touch est un nettoyant pour diamant de platine vinyle contenant un polymère de Polyuréthane (PU) solide de la plus récente génération et spécialement conçu pour...
très éfficace
Apporte une grande netteté à l'écoute mais le son est un peu mat. Je l'associe avec le nettoyant liquide en second passage et le résultat est génial . J'ai l'impression d'avoir une platine de plus haut de gamme . Très recommandable.
Eric L.
SMSL C200 DAC ES9038Q2M Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 SMSL propose avec le C200 un DAC aussi compact que performant, profitant d'une conception soignée et d'une connectique capable de répondre à la...
Excellent Dac ampli casque
Ce DAC/Ampli casque tient toute ses promesses, la dynamique est très bonne, vraiment neutre, des détails à foison, la séparation des canaux bien marqués, la scène sonore bien large, il y a mieux pour la profondeur mais elle existe…
Bien timbré, il y a plus « musicale » mais parfois au détriment de la transparence, impitoyable avec les mauvais enregistrements…
Je recommande ce Smsl C200 , qui pourra s’intégrer dans un système haute fidélité.
Câble de bonne qualité .
LAURENT G.
SMSL D1SE DAC ES9038PRO Symétrique CPLD Altera XMOS 32bit 768kHz DSD512 Noir Le D1se de chez SMSL est un DAC extrêmement performant, se basant sur une architecture symétrique utilisant une puce de conversion numérique / analogique...
DAC transparent et silencieux
En remplacement d'un ATOLL 100SE vieillissant, ce DAC est transparent et retranscrit les phonogrammes de façon très exacte et stable. Aucune signature sonore décelable. Ne pardonne rien aux enregistrements de mauvaise qualité.
Utilisé en liaisons RCA avec un amplificateur intégré.
Aucun bruit résiduel transmis à l'amplificateur lorsqu'il n'y a pas de source envoyant un signal. Aucun bruit non plus à la mise sous tension et à l'extinction.
Ne chauffe pratiquement pas.
seul bémol : entrée I2S non compatible avec source munie d'une sortie HDMI ARC (audio), quelles que soient les configurations de l'entrée I2S choisies. D'où le retrait d'un point.
à signaler: DAC détecté par mon PC et utilisable en liaison USB avant même d'avoir téléchargé le pilote dédié. Ce dernier installé, je n'ai vu rien de modifié dans l'utilisation du DAC.
Que la lecture des fichiers se fasse au format natif (flac 16 bits/44 Khz la plupart du temps) ou rééchantillonné en 32 bits/384 Khz ne change pratiquement rien au rendu sonore.
Fonctions MQA et Bluetooth inutiles pour mon usage et donc non testées.
Laurent G.
Matthieu D.
Ma sono est au -1 et ma cuisine au RDC, du coup j'avais besoin d'une télécommande pour piloter le volume sans avoir à descendre à chaque fois.
Produit au top, bonne pré-amplification, réponse en remote très satisfaisante.
Si je devais chercher la petite bête je dirais que par rapport au volume en direct on n'a que de la diminution possible, mais si on calibre bien sa sono, ça n'est pas un problème. Un bon gain en entrée et on se prépare la plage de volume de confort sans souci.
En nettoyant ma sono je l'ai fait tomber. Il est mort. RIP. Je viens de commander le même. Tout est dit.
L
Anh J.
GUSTARD A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA Noir Gustard dévoile avec le A26 un DAC haut de gamme, aussi performant que polyvalent. Il se base sur une architecture de grande qualité, utilisant notamment un double...
Wonderfull AKM DAC in perfect implementation; a diamond waiting to be discovered.
i have bought this DAC some time ago and play only CD and SACD. Use a CD driver from Jay's Audio with upsampler. CD with upsampler button and gustard on NOS filter.. Smooth as it can gets. Combination is really wonderfull. This new AKM dac is a winner. The AKM 4499EX combination in another brand, Cary Audio, Marantz or Esoteric, can bring some upgrade. But this Gustard a26 and Jay Audio shows all the things you need to hear it all. And all in the wright colour and balance. Really natural sounding and with no glare at all. No fatigue. It doesn't downgrade other devices and went along with BW 801 D4, Accuphase C 3900, Mcintosh MC 1.25KW. Alle connected with vd Hull Cumulus 3T. Same goes for the combination with ToneWinner Class A amplifier. Another diamond on the market to be discovered. This AKM in a Gustard is a diamond to be discovered and if it is shows it real worth. Thank you for great service.
Thomas W.
TOPPING MX3S Amplificateur Class D Infineon Amplificateur Casque DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Noir Véritable couteau-suisse de l'audio, le Topping MX3S endosse à la fois les fonctions d'amplificateur Class D et amplificateur casque avec DAC AK4377 et...
Très satisfait !
Acheté en remplacement d'un SMSL Q5 pro pour accompagner des Davis Eva et un caisson Yamaha NS-SW100. J'utilise ce matériel principalement dans le cadre d'une écoute "nearfield" lorsque je suis assis à mon bureau.
Ce FDA est très complet, tant par les fonctionnalités qu'il propose (écran, Bluetooth, prise subwoofer et prise casque) que par les réglages qu'il permet (aïgus, graves, extinction/allumage automatique du FDA avec le PC, extinction automatique de l'écran etc.). Sa télécommande est bien plus complète et intuitive que celle de mon Q5 Pro. L'écran est lisible et l'agencement des informations qu'il affiche est clair. En revanche, je conseille très fortement d'avoir le manuel sous les yeux lorsqu'on s'aventure les premières fois dans ses menus très peu explicites. C'est vraiment le seul petit bémol que j'ai noté jusqu'à présent, pour le reste c'est un sans faute à mon humble avis.
Concernant l'écoute, je suis très satisfait de ses prestations. Il me semble qu'il exploite beaucoup mieux le potentiel de mes enceintes. Il me paraît les diriger avec plus d'autorité et de précision que mon Q5 Pro, ce qui rend l'écoute moins fatigante par ailleurs. Cependant, n'étant ni ingénieur ni mème audiophile, je crains toujours qu'il y ait un peu d'effet placebo dans mes ressentis.
En revanche, je n'ai aucun doute sur la gestion des basses qui est clairement meilleure, tant la différence est importante, que celle de mon Q5 Pro. Je me rends compte aujourd'hui que le Q5 Pro était vraiment brouillon sur ce point. J'ai l'impression d'avoir un autre subwoofer quand je suis bien conscient d'avoir les mêmes enceintes.
Je n'ai pas encore testé la prise casque ni le Bluetooth, je n'ai donc aucune opinion sur ces points.
Pour conclure, je suis heureux de mon achat tant cette petite boîte métallique est bien finie, pratique au quotidien et agréable à mes oreilles pour l'usage que j'en fait.
Thomas W.
Très satisfait !
Savvas P.
XANGSANE S-PAT II Pieds Aluminium 50x26mm Noir (Set x4) Les pieds en aluminium S-PATII de Xangsane permettent de limiter les vibrations et les effets de résonance générés par vos équipements HiFi...
Pieds Aluminium
Très bon support pour mon ampli casques.
Christopher B.
IFI AUDIO ZEN PHONO Préamplificateur Phono MM/MC Le iFi Audio Zen Phono est un petit préamplificateur phono de bureau performant et abordable. La marque a particulièrement travaillé à la...
Works Well, Arrived Quickly and in Good Condition
This was the first item I ordered from Audiophonics. As a result of their excellent service I have ordered other equipment and expect to order more in the future. This phone amp is visually cute with good features, and works as expected. It really is easy to use and set up and so far has worked without any problems whatsoever. I only wish it had an output with which I could directly connect it to my AUDIOPHONICS DAW-S250NC Amplificateur Intégré. But it does its job, does it well, and connects to my Topping electrostatic headphone amp (also purchased from Audiophonics) without any problem.
Christopher B.
TOPPING EHA5 Amplificateur Casque Électrostatique Symétrique 700Vrms La plupart des casques électrostatiques offrent un excellent potentiel musical mais leur performance est souvent limitée par l'amplificateur casque associé....
Works Well
I just moved to France and am setting up my sound system. I purchased this and Stax Lambda headphones for my new home audio system, and it works well and looks good. I can not compare it with the other electrostatic headphone amplifiers available for Stax headphones because I have not heard any of those available now, but this is a fraction of the cost and sounds clear and clean to me. I like the visual aesthetic (and the fake tube glow, which amuses me, but...I like it), and I am contented with this product's ability to drive my difficult-to-drive headphones.
Christopher B.
AIYIMA T9 PRO Amplificateur TPA3250 Tubes 2x JAN5725 ES9018K2M Bluetooth aptX HD 2x60W 4 Ohm Le Aiyima T9 Pro est un amplificateur intégré polyvalent et abordable, idéal pour monter un système audio sans se ruiner et sans multiplier le nombre...
A Little Treasure
This little amp is cute and fun. It is very versatile and the Bluetooth works well. I have been using it as my television and CD/DVD/Blueray audio amplifier, and it has really grown on me. Whether the sound improved or I adjusted to it, I cannot say, but I really enjoy it. The power output is more than that of most of the amplifiers I've had in my life and the sound quality is surprisingly good. This little amplifier has an almost cult following in the U.S., and I can understand why. Small, convenient, multiple inputs, fun to look at and use, and it sounds good running my small and also cute speakers (Lii Audio Raindrop-3) and has the power to fill the house with music. Tiny and cute as it is, this is a serious little amplifier and I like it.
Christopher B.
AUDIOPHONICS DAW-S250NC Amplificateur Intégré Class D NCore NC252MP DAC ES9038Q2M WiFi Bluetooth 2x250W 4 Ohm 32bit 768kHz DSD Polyvalent et performant, nous vous proposons avec le DAW-S250NC un amplificateur intégré à entrées numériques auquel il suffira d'ajouter des...
Good Integrated Amp
I find this to be a good amplifier and I greatly appreciate its power, clarity, and versatility. I have no reservations about it and I am pleased to have it in my system.
My only regret is that it does not have RCA inputs. I would like to connect a phono amp directly into it, but that is my problem, not this amplifier's. This is a modern integrated amp that accepts Bluetooth and WiFi streaming, and phono is for dinosaurs--like me. With a DAC built in and COAX, OPT and USB inputs, this really is a versatile and advanced amplifier. It is very responsive to the remote control and the design is aesthetic: simple and pleasing. It is remarkably light for the rated power output and VERY convenient to use. I connected audio from a video projector via Bluetooth and was impressed by the quality of sound and the excellence of the connection. I was streaming videos and films with audiophile sound and quick and easy connection.
I have been able to stream from my computer, my laptop, my phones, and the phones of guests with quick and easy connections that provided stable wireless connection and audiophile-quality sound. I have also been able to connect a Topping electrostatic headphone amp that I also purchased through Audiophonics to it, and the sound is clean and clear.
I am happy with this purchase and will no doubt recommend this amplifier to friends.
I recently moved to France and wanted to buy French-built products for my new home and new life and I am very proud that this amplifier, which is advanced and of good quality is French. French-designed and French-built and in line with legendary French quality.
Christopher B.
Well Built, Well Designed, Works Well
I feel that this is a good-quality item. It is well-designed: the prongs go in to the outlets at right angles; another power strip that I have has them at an angle and some power plugs prevent another from being positioned in the next outlet. The same plugs in this power distributor have no such problem. It feels solid and well-built and heavy enough to not be twisted around by the power cords plugged into it. I feel confident in the quality of this item and I am comfortable plugging in my audio equipment to it.
I would buy this item again if I need another and would recommend it to a friend.
Christopher B.
It Works Well
It works well. I see no problems. I would not hesitate to order this again.
I purchased this cord to connect an "AUDIOPHONICS Aluminium Power distributor 8 Schuko plugs Black" to an outlet (that power strip needs the additional purchases of a cord and bumpons for feet), and it fits perfectly and I see no problems whatsoever.
Rodolphe L.
Petit ampli vivant
Cet ampli marche correctement, il semble vivant et dynamique. Je l'alimente à +-40V.
Rodolphe L.
Bon boitier et pas cher. Mine de rien c'est un boitier radiateur très discret et pratique pour tourner un petit ampli classe B ou bien tout montage qui a besoin de dissipation. Je fais tourner un Ampli LJ L7 dessus et ça va très bien.
Rodolphe L.
Module d'Alimentation à Découpage 700W +/-40V Ce module d'alimentation à découpage LLC dispose d'une sortie principale délivrant une tension de ±40V. Le circuit de résonance utilise une...
Très pratique mais Bruyant
Alimentation qui est bien pensé, pratique avec des sorties 12V ventilateur, +-12V auxiliaire en plus de la tension principale, le tout sur borniers, très appréciable. Il fait le job d'alimenter mais le seul bémol il est bruyant. Je suppose au prix vendu , il ne faut pas s'attendre à mieux.
Laurent C.
Excellent connecteur, musical et précis, monté sur Elecaudio cs-361b vers un ampli Marantz... à renvoyer sur leboncoin des câbles secteur de grande marque.
David G.
Top qualité
Qualité vraiment au top pour ce bloc prise!
Rien que le poids en dit long!
Livré dans un petit coffret.
Gain significatif sur la propreté du signal! Un upgrade indispensable !
Jerome C.
Belle qualité
Je n'avais pas fait attention à la description et c'est une belle surprise, une finition exemplaire, entièrement métallique, la marque non pas imprimée mais emboutie, une peinture sans défaut et un contact doré.
Leur longueur n'est pas excessive et effectivement c'est plus simple pour la soudure du câble.
20/20
Renzo L.
KECES P8 Alimentation Linéaire Régulée Ultra Faible Bruit 19 / 20V 8A + USB 5V 1A La Keces P8 est une alimentation linéaire régulée de grande qualité qui permettra à votre système audio haute-fidélité de...
Stark und edel
Eigentlich habe ich mein Keces Gerät als gebraucht günstiger kaufen können aber seine Ausgangsspannung ist stabiler als bei anderen günstigeren chinesischen Netzteilen. Auf dem Display erscheint auch vieviele Ampére die Last beansprucht, mein HTPC mit Windows10 AsrockVision benötigte nur um die 3A, aber das wusste ich ursprünglich nicht, darum hatte ich diesen starken Netzteil mir gewünscht. Aber nachdem ich Windows stark getweakt habe, vor allem dank MSMGToolkit, habe ich nur noch 1,7 A im Maximalfall. Für mini-PC und Laptop ist absolut notwendig ein Linearnetzteil, ich konnte sofort den Unterschied zum SMPS feststellen, vorher die hohen Töne waren kreischend, überlagert mit SMPS-Schwingungen, jetzt sind sie klarer, ein USB-Isolator allein half nicht genügend.
MONOLITH M1060C Casque Fermé Planar Magnetic 90dB 18 Ohm 10Hz - 50kHz Le casque Monolith M1060C se dote de haut-parleurs planar magnetic repensés, capables de reproduire une scène sonore détaillée et précise au...
agréable
Le casque est volumineux mais son port est confortable ; on à tendance à l'oublier . Le son est détaillé et le rendu spatial séduisant et pas caricatural . Un bon compromis pour moins de 300 euros . Fait aussi bien que certains casques plus chers .
Sans plus ...
Pour les porteurs de lunettes le port de ce casque pince celles-ci et décolle les lunettes du nez . Sans lunettes le port manque clairement de confort . Le son ne pas convaincu mais je souligne que je n'ai pas eu la patience d'attendre le rodage malgré un léger mieux après dix heures d'écoute . ( son de boîte ).
Déçu !
Petit prix mais qualité médiocre.
L'isolant central fond quand on soude.
Avec ma station de soudure réglable, impossible de souder un fil sans que la pin centrale se mette en oblique.
Achetez une fiche rca avec isolant PTFE téflon, c'est impératif.
Uwe K.
Phantastisch
Bestellvorgang und Lieferung ohne Probleme.Lediglich der Umkarton und die Freundlichkeit des DPD Mitarbeiters sind zu bemängeln,was aber nichts mit Audiophonics zu tun hat!Erster Eindruck ist großartig...solide Verarbeitung,problemlose Integration in mein Heimkino und eine Dynamik meiner Frontlautsprecher,die ich so noch nie gehört habe.Wie gesagt...erster Eindruck,aber voll umfänglich zufrieden!!!!
Aristotel Eduard G.
I buyed them for my Ramm Amadeus speaker cable . Good looking and top quality. I recommend these spades.
Aristotel Eduard G.
I buyed them to replace my Dali Zensor 7 factory binding post. By far these are in a different class. Good looking and top quality.
Baptiste R.
MOONDROP LAN Écouteurs Intra-Auriculaires IEM Dynamiques 10mm 120dB 32 Ohm 15Hz-37KHz Moondrop dévoile avec les LAN des écouteurs intra-auriculaires dynamiques ayant la particularité d'une coque compacte en acier inoxydable ainsi qu'un...
Sympa
Une valeur sûr !
Aigus un peu en avant mais pas trop. Semble super solide.
Seul petit point regrettable la boîte est super grande mais y'a que 3 paires d'ambouts.. Plus d'embouts et une boite moins tape à l'oeil ça aurait été pas mal.
Suis fan et ça m'énerve ...
Bien moins cher qu'une paire de de câbles de modulation de haute qualité si vous voulez un résultat immédiatement positif (à condition d'avoir une chaine résultante ou résolvante).
Je ne croyais pas à une amélioration sur des signaux de 1 et 0. Alors je ne me l'explique pas, mais c'est à l'encontre de ce que disent les experts en informatique (manque d'objectivité face au savoir ?).
Je fais confiance à mes zoreilles et j'oublie mes croyances.
Ce truc ... ça fonctionne. Les voix sont plus belles. Entre autre.
De toute façon, si vous n'entendez pas le gap, retournez le Ifi silencer à la boutique.
Comme à chaque fois, c'est en revenant à la situation d'avant que l'on sent si c'était mieux ou pas.
La marche descente est curieusement plus haute que la marche montante. Si le gain ne saute pas aux yeux, pardon, aux oreilles de façon flagrante, retirer le ifi dégrade le son.
Je recommande ce ti-truc miraculeux et anti-logique :
ça fonctionne (si votre chaine est à la hauteur).
Roman J.
Highly recommended AMP
I'm using a miniDSP flex RCA to drive the MPA-S250NC amp. Both devices in combination are superb. There is no noise or hum. Without an input signal, it's simply dead silent. Listening to music is really an enjoyment.
- The built quality and finish of the MPA-S250NC amp is perfect.
- The output signal measurements are well known and can be found on the ASR forum.
- The audio output of the amp is excellent.
Dirk d.
TOPPING G5 Amplificateur Casque NFCA DAC ES9068AS Portable Bluetooth aptX HD LDAC Argent Topping présente avec le G5 un amplificateur casque et DAC portable à la fois compact et performant. Celui-ci intègre notamment un puissant étage...
Audiophile... ?
Après plusieurs semaines d écoute, j ai un avis différent de tout ce que je lit sur les éloges du produit .
Super produit dans l ensemble.
Connection Bluetooth super.
Connection Usb super.
Les détailles , qualité de restitution , souffle, super .
Autonomie ,et sa charge constante , super
par contre....
un manque de vie, de dynamique , le son est clair, mais vide qu' il en devient fatigant .
Je suis quand même content de mon achat, pour les raisons décrit plus haut.
je m en sert juste lorsque je me déplace, car il fait son job .
Par contre a la maison, tranquille dans mon jardin , je passe a autre chose.
Je suis toujours a la recherche d un dac nomade, qui peu me surprendre.
Déçu.
Super !!
Jeu de clés made in Japan qui ne se tordent pas quand on serre.
Un jeu de grande qualité à petit prix, profitez-en.
Philippe S.
Séduisant.
J'ai choisis ce câble pour mon préampli en échange d'un furutech 31, c'est plus présent dans le médium, j'en ai acheté un deuxième pour le dac, la couleur du câble ressort trop, j'ai donc du furutech tc31 et 32 et un oyade.
Le deuxième vondida alimente maintenant la barrette pour le vidéo projecteur, l'image à fait un bon en avant, idem après un essai sur une télé oled panasonic.
Philippe S.
FURUTECH FI-48 NCF (AG) Connecteur IEC C15 Cuivre Plaqué Argent Traitement Alpha NCF Ø20mm Le Furutech FI-48 NCF (AG) fait partie de la gamme de connecteurs de la marque intégrant le matériau NCF et profitant, comme pour l'ensemble des produits Furutech,...
La qualité à un malheureusement un prix
Excellent connecteur, un peu plus de subtilité qu'une fi46, meilleur scène sonore, évidemment ce n'est pas le jour et la nuit mais sur un bon système on voit la différence. Associé à un câble furutech 55, je me régale.
Philippe S.
Un cran au dessus
Comme de nombreux clients, je me suis constitué quelques câbles furutech, j'en ai gardé 2, le 31 et le 32, les 31 pour mon préampli, l'alimentation de mon streamer et mon dac, c'est un câble que je trouve cohérent. Pour l'ampli et la barrette j'ai choisi le 32 un peu plus présent dans le grave mais un peu moins bon dans le haut médium. Le 55 est nettement plus long à rôder, les premières heures sont une catastrophe (c'est bouché, peu d'aigu, on peut vite regretter son achat) il faut l'accepter. Aujourd hui après une cinquantaine d'heures, le câble s'est ouvert, j'y retrouve les qualités du 32 avec un grave encore mieux défini et lhaut du spectre qui ressemble au 31.
P. S : il fonctionne avec une Schuko fi46 et une IEC Fi48 argent.
Jean-Marie L.
Bon rapport Q/P
Bon plan que ces fiches à # 1.50/ pièce, en alu au lieu de plastoc, fabrication esthétique et de bonne qualité. Le système utilisé pour la connexion s'apparente au goupilles élastiques fendues Mécanindus. Le contact est étroit, pas de risque de déconnexion accidentelle, et grand surface de contact sur toute la longueur de la "banane". Du tout bon !
Savvas P.
NEOTECH NEUB-3020 Câble USB-A Male/USB-B Male 2.0 OCC plaqué Or 24k 1.5m Le câble USB AUDIO class 2.0 Neotech NEUB-3020 offre une qualité de restitution numérique redoutable utilisant des technologies innovantes venant bousculer...
Bonne Fabrication
Très bon câble à prix raisonnable.
Savvas P.
Très bonne multiprise
Fabrication de qualité
Frederic B.
Module DAC pour Raspberry Pi PCM5122 I2S 32bit 384khz DSD128 Ce module DAC pour Raspberry se base sur l'utilisation d'une puce de conversion numérique / analogique PCM5122, lui permettant de supporter les flux PCM jusqu'à...
Bien, mais quelques détails à revoir :-(
Bonjour à toutes et à tous,
Après l'achat de cette carte je l'ai montée sur mon Raspberry pi4 qui tourne sous moOde AUdio (la dernière version de Volumio est trop buggée et rAudio, ex Rune Audio, est un projet qui semble désormais en mort cérébrtale avec quelques modifications mineures par-ci par par-là).
L'installation est super simple et, après avoir choisi le bon "driver" I2S pour cette carte comme indiquée, il fonctionne sans souci. Seul truc à savoir il faut appuyer sur le bouton pour sélectionner "I2S In" afin d'avoir du son direct depuis le pi4.
L'écran est vraiment sympa pour savoir si le pi4 joue bien ce qu'on lui demande de jouer dans le bon format. Il affiche manifestement correctement le taux d'achantillonnage (44.1, 48 ou 96khz) mais le mitrate est faux : il affiche 32bits au lieu de 24bit... Alors de là à croire qu'il upsample il n'y a qu'un pas. Or je voudrais avoir la certitude qu'il ne sort pas un message "faussé". Bug d'affichage ou vraie difficulté ?
Par ailleurs, si la sortie casque a l'air d'être suffisamment puissante, il faut l'utiliser avec des casques ULTRA gourmands... Pourquoi ? Parce que le régalge ne s'opère que sur 8 niveaux. Inutile de dire que du coup si le réglage "5" est un peu insuffisant, le réglage suivant "6" est vraiment fort... Un régalge sur une douzaine de niveaux n'aurait pas fait de mal si ?
En conséquence, je ne mets qaue 4 étoiles. Mais 4 étoiles quand même pour la simplicité d'utilisation, pour la qualité du son, pour la puissance de la sortie casque et pour le petit écran, qui reste quand même une petite aide...
Et quand je parle de qualité du son, franchement, je trouve que c'est vraiment vraiment BON. Même comparé à des propositions bien plus "puissantes" et dédiées à l'écoute au casque : c'est franchement pas mal pour mes oreilles. Peut-être que la puce 5122 fait des petites merveilles ou que simplement la différence me fait croire que c'est bon... Quoiqu'il en soit, je pense que le son qui sort de cette petite carte à 65€ peut rivaliser avec un combo DAC et Ampli casque jusqu'à 8 fois plus cher. Alors pourquoi se priver ?
Ballester M.
XDUOO MT-602 Amplificateur Casque à Tubes Class A 2x 6J1 Le xDuoo MT-602 est un amplificateur casque à la fois compact, performant et abordable. Il se base sur une architecture Class A, intégrant des transistors pour son...
UTILISATION PREAMPLI
BON PREAMPLI ENTRE UN DAC SMSL DO100 ET UN AMPLI AIYIMA A07 PRO AVEC AOP MUSES02 ET SPARKOS.
LE GAIN EN SORTIE EST ENORME PAR RAPPORT AU GAIN DU DAC J' AI MIS DU TUBE VOSHKOD DESSUS ET LES DETAIL ET LA DYNAMIQUE SONT AU RENDEZ VOUS.
J'AI FAIT DES TEST AVEC ET SANS CE PREAMPLI ET C'EST LE JOUR ET LA NUIT.
JE RECOMMANDE VIVEMENT CET APPAREIL !
Ferenc M.
KHOZMO ACOUSTIC Atténuateur de Volume à Relais Stéréo 64 Pas Commutation MBB Vishay 10K Khozmo propose avec ce produit un atténuateur de volume ladder à relais très haut de gamme aux performances audio incroyables. Celui-ci est basé sur...
Very good quality
This attenuator is very good! The clicking sound of the relay is smooth and more quiet than the other I have tried. The display is tricky to be applied to the front panel of a chassis but functional, clearly visible, adjustable brightness.
Pavol B.
DYNAVOX ANTIVIBE Pieds Absorbeurs Antivibratoires Ronds Caoutchouc Noir (Set x4) Ces pieds pour enceintes ou systèmes hifi en caoutchouc très simples d'utilisation absorberont efficacement les vibrations générés par votre système pour un son plus clair.
perfect isolation pads
Easy to use, good work, very soft and eat many small vibrations and etc. Recoomend it for any hifi device or speakers.
