Lacking
The best
These are a little difficult to work with due to the hollow pins, but they are the best sound wise. Have used Viborg and others...
Astonishing- finally
I rated this cable before a few years ago when using fairly budget RCA connectors. I terminated it today with Neotech NEX GD...
Avis clients - Il y a 19516 avis.
ONDER O.
VIABLUE TS2 Fiches Banane Plaqué Or Ø5mm (Set x4) Les fiches bananes Viablue TS2 utilisent un système de raccord par tube pour assurer un contact maximal avec les borniers d'enceintes. Lors du branchement de la fiche...
Very good looking products
Price and quality is nice . recommended.
ONDER O.
VIABLUE TS Fourches 8mm plaqué Or 24K Ø5mm (Set x4) Les fourches TS ViaBlue se vissent aux bornes des enceintes pour fournir un contact ferme et durable entre le câble d'enceinte et les bornes polaires. Les connecteurs...
Very nice and good looking products.
For the money quality is very good.
ONDER O.
Good Quality
expensive but it looks very nice on the cable.
ONDER O.
Good Quality
it's good quality product.
ONDER O.
VIABLUE Gaine Tressée 5-14mm Noir Le diamètre de ces gaines est modulable de 5 à 14mm.
good quality
ONDER O.
Very good entry level speaker cable
You can immediately hear the difference of the speaker cable in the high-end music system. The main thing here is to find the speaker cable where we can get top-notch sound without spending a lot of money.
So I'm trying to find the speaker cable that I can get the best performance by trying low and mid-priced cables.
Viablue sc-4 was a good price-performance cable. The sound stage was wide enough, Upper and mid frequencies were detailed and well-bodied, the bass was tight and strong.
If I will make some comparisons;
Highs are rolled off and the sound stage is narrower on the Viablue sc-2.
Highs, mids, bass and stage performance was 5% worse on the Qed xt-40.
The much more expensive Vandenhul revelation was very close.
Viablue sc-4 performance 5% lower than the VDH revelation.
I can say that VDH Revelation and Viablue cables are generally well balanced cables.
At this price level, the vialue sc-4 is a very successful speaker cable.
Aurélien B.
FX-AUDIO DAC-X3 PRO DAC Amplificateur Casque ES9023 CS8416 24bit 192kHz Le FX-Audio DAC-X3PRO se présente comme un combo DAC et amplificateur casque particulièrement compact et abordable. Il propose cependant de bonnes performances...
J'utilise l'ampli dac sur la sortie optique de la TV. Ça améliore bien le son de mon casque par rapport à la sortie jack et il n'y a plus de bruit parasite.
Attention en revanche a ne pas trop pousser le son, suivant le casque utilisé ça peut l'endommager.
Merci au sav très efficace qui m'a envoyé une alimentation toute neuve pour remplacer celle d'origine qui avait un dysfonctionnement et qui est à première vue de très mauvaise qualité.
Dario G.
Très efficace.
Produits très efficace, pourtant partie d'une alimentation spécifique..
Ce produit recule encore la distorsion, meilleure aération, douceur et réalisme des timbres.
La basse de la source...
Adelmo T.
Je suis très surpris de la qualité de ce câble. J'ai remplacé un câble 3 fois plus cher par le Neotech, fantastique. Très forte recommandation!
Giovanni M.
Molta buona
Per un mio progetto da anni cercavo una scheda del genere ,fino a qualche giorno fa non conoscevo questo sito ,appena l ho visto l ho acquistato subito. Alla ricezione della merce mi è arrivata danneggiata,ma il supporto clienti ha subito risolto la problematica è posso confermare che la professionalità e competenza è alti livelli. Per la scheda veramente ottima.
Giovanni M.
Condensatore top
Conoscevo il produttore dei condensatori, li reputo uno dei primi mondiali per cui posso dire solo eccellente qualità, il venditore ha prezzi bassi ma di alta qualità di materiali
Giovanni M.
Embase IEC C20 3 Pôles Cette embase de IEC C20 (mâle) vous permettra de monter vos connecteurs d'alimentation et d'y connecter un câble avec connecteur IEC C19 (femelle). L'embase dispose...
Eccellente
Presa fantastica, non l ho ancora montato, ma il materiale è di buona qualità. Il fornitore è eccezionale una supporto efficiente, comprerò molto da voi.
Denis K.
Excellent appareil
Une découverte que ce petit appareil. Le DAC est très performant sur le papier, et à l'écoute aussi (Entrée USB - Flac 44.1 et 96: tout est nickel). L'ampli casque est précis et pas du tout agressif, largement suffisant en puissance pour mon AKG 702.
La sortie ligne (un ampli PP à tubes derrière) est sans défaut. On entend tout, et le son est très naturel.
Alim intégrée, ergonomie au top....
Le BT fonctionne bien (je n'utilise pas trop, juste testé.....). Ce n'est pas la philo de ce type d'appareil, je pense, mais c'est un plus.
Les 2 volumes (ligne et casque) sont indépendant et mémorisés: parfait.
L'écran n'est pas bien grand, mais l'appareil lui même est très petit. De toutes façons, une fois les réglages faits, on l'oublie, sauf éventuellement le réglage du volume.
Il me reste à explorer les filtres (il y en a 6) pour bien comprendre à quoi ça sert, et si ça s'entend.... Mais tout le reste est très bien conçu et facile à mettre en oeuvre, aucune faute de goût.
Et à ce prix là.... Rapport Qualité/Prix imbattable. Même pour le DAC seul!
Merci au support technique Audiophonics (Mr Aubert) pour les conseils avisés.
Jacques B.
Tres bon produit, fonctionne parfaitement
Denis K.
NEOTECH NEUB-3020 Câble USB-A Male/USB-B Male 2.0 OCC plaqué Or 24k 1.5m Le câble USB AUDIO class 2.0 Neotech NEUB-3020 offre une qualité de restitution numérique redoutable utilisant des technologies innovantes venant bousculer...
Reçu dans les délais les plus bref, ce câble remplit bien sa fonction. Construction de qualité, rien à redire. Associé à un Objective DAC. Seul bemol: s'il existait en plus court, ce serait pas mal.
Nicholas R.
Great microphone, very easy to use!
I was very impressed with the build quality and packaging of this microphone. The compatibility with Room EQ Wizard is likely the reasons others will be looking at this mic, and in that regard it performs very well.
Fred F.
Sonorité exceptionnelle
Câble de très grande qualité (conseillé une fois de plus par M.Aubert David, merci à lui !!!) qui transforme mon installation en remplacement du câble grand public. Un bon système nécessite ce type de câble. Il supporte largement la comparaison avec un câble 10 fois plus cher de grande marque que l'on voit dans les magazines spécialisés. Et cerise sur le gâteau, fabriqué en France.
Encore une fois, merci Audiophonics !
Jean Louis G.
cable
Excellent câble que j'utilise depuis son achat dans le grave en remplacement d'un câble pur cuivre industriel. La voie a retrouvé un tonique et un naturel remarquable, améliorant l'image sonore et l'ambiance ds enregistrements "live". diamètre imposant mais assez facile à dénuder.
Patrice G.
Bien mais...
Ces fiches bananes sont jolies, elles font leur travail.
Le prix de vente, comme tout le matériel en hi-fi est complètement surdimentionné. Ces fiches peuvent être trouvées sur des sites chinois à quelques euros. Alors que dire des autres produits ???
Boitier ECO EP1153220
Faciles à souder, on peut même le faire plusieures fois si besoin !
SOMMERCABLE SC-AQUA MARINEX MIKRO 25 Câble AES / EBU 2x0.25 mm² Ø7,20 mm Le câble SC-AQUA MARINEX MIKRO 25 par Sommer Cable est adapté aux utilisations AES/EBU aussi bien qu'en tant que câble instrument sur un microphone.
Utilisé en cable de modulation RCA
Très bien, de belles basses, un son plein, une belle énergie.
francois R.
Dépassé par le Canare L-4E6ATG ou L-4E6AT
J'ai pu comparer les Canare L-4E6AT vs L-4E6S, sur mon systeme transparent en XLR entre ampli et dac, ca s'entend à l'avantage du L-4E6AT. Les 2 cablés identiques en XLR de 1m selon datasheet Canare. Ce qui confirme bien les avis des audiophiles coté Asia.
Vraiment dommage que Audiophonics ne propose pas ces cables qui mettent tout le monde d'accord: respect de l'ensemble de la bande passante (aigus fins et conservés, basses precises)
Lionel C.
Utilisé pour raccorder deux paires d enceintes Yamaha pianocraft (une paire côté bureau et une côté lit) sur un seul ampli yamaha E810 : aucune perte de musicalité audible avant - après.
Très facile d’utilisation
Le petit modèle est largement suffisant et aucun problème place pour des connexions avec des câbles de 2x2,5
Jacques B.
IFI AUDIO DC BLOCKER Filtre d'Alimentation Secteur 90-240VAC Le iFi Audio DC Blocker est un filtre d'alimentation secteur, permettant de supprimer les tensions DC résiduelles afin de limiter le niveau de bruit.
Un accessoire efficace
J'utilise le filtre iFi Audio DC Blocker en entrée du conditionneur secteur qui alimente ma chaîne hifi. J'en utilise également un deuxième en entrée d'un transformateur d'isolation qui alimente d'autres équipements ailleurs dans mon logement.
Mon conditionneur secteur contient un transformateur toroïdal et émet, de temps en temps, un ronflement léger, perceptible seulement à proximité immédiate et inaudible à ma place d'écoute, même en l'absence de musique (intervalle entre deux pistes).
L'accessoire n'a pas supprimé entièrement le léger ronflement, mais celui est subjectivement plus faible, encore moins gênant. L'effet le plus marquant est une nette amélioration de la transparence de la restitution musicale: elle est plus propre, avec des détails supplémentaires et surtout, la scène sonore a pris une nouvelle ampleur (hauteur, largeur et profondeur), remarquable sur les enregistrements qui s'y prêtent.
Pas de modification de la signature sonore, ni les basses, médium et aigus n'ont été influencés dans un sens ou dans l'autre.
Ailleurs chez moi, l'effet est visible sur un écran PC de qualité: image plus propre, couleurs plus profondes et naturelles; c'est très visible sur des photos numériques.
Comme pour tous les accessoires qui agissent sur le courant électrique, une période de rodage est nécessaire. Je l'ai trouvée ici assez longue: cet accessoire a atteint son plein effet en deux semaines environ.
Je recommande, avant la mise en place, le traitement de l'entrée IEC de l'accessoire avec un produit améliorant le contact afin de limiter les pertes d'insertion.
Jean F.
A BESOIN D'UN BON FER A SOUDER
Soudure utilisé avec des bornes banane Atohm WT-FB-1960-G.
Pas évident de souder deux câble 2,5 mm2 dans la même bornes.
Il faut effectivement un bon fer.
Jean F.
TRES BON
Sertissage impeccable. Utilisée avec la plus grosse section de câble des cosses, donc très bon contact.
Jean F.
MUNDORF 6.3G Cosse Plate Femelle Isolée Plaquée Or 6.3mm 1.5-2.5mm² Bleu (x10) Ces cosses femelles permettent une connexion / déconnexion simple et rapide tout en assurant un excellent contact. Les contacts de ces cosses sont plaqués Or afin...
Pas utilisées, mais ...
Cosses identiques aux 2,8 mm et 4,8 mm déjà utilisées, donc pas de raison pour qu'elles soient moi bonne .
Jean F.
MUNDORF 4.8G Cosse Plate Femelle Isolée Plaquée Or 4.8mm 1.5-2.5mm² Bleu (x10) Ces cosses femelles permettent une connexion / déconnexion simple et rapide tout en assurant un excellent contact. Les contacts de ces cosses sont plaqués Or afin...
PRODUIT TOP
Idem que cosse 2,8 mm
Cosses utilisées avec câble Atohm ZEF mini 2,5 mm2. Le contact semble Ok (pas de jeu).
Un peu de difficulté pour enficher sur cosses mâle des haut-parleurs Atohm, mais ça bouge pas.
Je n’ai pas de comparaison avec câble directement soudé à l’argent, mais ça semble équivalent.
Pas de mauvais contact à l’écoute (même à très fort niveau), mais il faut une bonne pince pour un sertissage Pro.
Jean F.
MUNDORF 2.8G Cosse Plate Femelle Isolée Plaquée Or 2.8mm 1.5-2.5mm² Bleu (x10) Ces cosses femelles permettent une connexion / déconnexion simple et rapide tout en assurant un excellent contact. Les contacts de ces cosses sont plaqués Or afin...
TRES BON
Alberto S.
similar of many others
From China many pseudohifi objects. Nothing special. Not good not bad; just enaugh for modest hifi setup. Quick courrier.
RENE R.
1877PHONO THE MAJESTIC MK2 COUDE
BELLE PRESENTATION POUR CE CABLE, LE SON N'EST PAS ENCORE FINALISE PUISQUE LE RODAGE POUR UN CABLE PHONO EST SOUVENT ASSEZ LONG. SINON BELLE DEFINITION POUR UN CABLE VISIBLEMENT BIEN FABRIQUE, QUI SOUS CERTAINES MARQUES AMERICAINES OU ANGLAISES COUTERAIT FACILEMENT LE DOUBLE.
MAIS IL FAUDRA ATTENDRE ENCORE UN MOIS POUR SE PRONONCER SUR LE RENDU SONORE.
Donny V.
Perfect connector
Nicely finished, excellent quality for your high-end cable.
Donny V.
Great connector
Great connector to finish your high end cable. Very solid and good quality.
Donny V.
The best connector, very solid.
Donny V.
VIABLUE STONE Gaine Tressée Ø13-26mm Cette gaine tressée Viablue Stone accepte des câbles d'un diamètre allant de 13mm à 26mm, offrant une protection efficace aux contraintes...
Top material
Perfect quality material to finish your cables
Donny V.
Excellent high end power cable. Recommend.
Excellent quality cable, super insulated material and a fantastic reproduction of the sound. Full harmony of the sound. With furutech connects, this makes the best sound cable.
Audiophonics great to do business with. Fast delivery in the Netherlands
Jorge P.
De la hauteur...
Ses Pointes sont de bonnes factures, solides et jolies. Leurs prix restent tout fait honnête par rapport à la concurrence dont le prix excède x2 les Atohm.
Mes vieilles enceintes Bc Accoustic Araxe reprennent de la hauteur.
J'en ai placé trois, celle du fond a été vissée de telle façon que la colonne reste légèrement inclinée.
Seul petit bémol, l'autocollant qui se colle sous les contre-pointes se déchirent facilement.
claude h.
SMSL DA-9 Amplificateur Class D Symétrique 2x MA12070 Bluetooth 5.0 2x90W 4 Ohm Amplificateur de grande qualité, le SMSL DA-9 profite d'une architecture symétrique lui permettant de dévoiler une restitution sonore musicale, riche et...
Champion
Ce petit ampli est un champion, je n'ai comme comparaison que l' Alientek D8 et le Aiyima 07 avec OPA1612, il les supplante allègrement.
Branché en RCA avec Sanskrit.
Magnifique!!!!
thierry s.
Pourquoi dépenser plus ?
Simplement parce qu'il est juste en dessous du fameux 'présence'
de MPC mes cables à 900€,mes cables modulation préférés......
Panikos K.
TOP SELLER
Excellent range of products, very fast shipping and excellent service.Will keep buying from AUDIOPHONICS.
Bruno C.
Module Contrôle de Volume Motorisé 50K Ce module de contrôle de volume très pratique est équipé d'un potentiomètre motorisé 50K, ainsi que d'une LED de réception IR....
tres bien
livraison rapide dans mon cas super produit fait parfaitement le boulot je recommande ce produit
Pierre-Marin L.
ALLO DIGIONE SIGNATURE Lecteur réseau Raspberry Pi 4 DigiOne Signature DietPi pré-installé Noir Dépourvu d'écran et d'interface de contrôle, ce lecteur ALLO DigiOne signature se pilote à distance depuis un téléphone portable, une...
Fabuleux
En fait pour ce qui est des connaissances informatiques sur un mac avec Audirvana c'est complètement plug and play. Airplay est reconnu et upnp (gmediarender) sous Audirvana.
Je précise que j'utilise l'alimentation Shanti d'Allo (je n'ai pas de tests sans pour comparer....)
Par rapport à un mac en sortie usb sur cable Audioquest Carbon + Ifi IPurifier, c'est le jour et la nuit : tout est beaucoup plus net et propre, un rythme mieux maitrisé, tout est plus aéré...
Mais en fait cela ne s'arrête pas là : je voulais tester GentooPlayer suite aux excellents échos que j'en ai eu, là déconvenue : le son sous Gentooplayer est fabuleux mais mpd et upmpdcli sont instables avec Audirvana, c'est sans compter sans la tenacité homérique de son développeur qui fini par m'installer gmediarender et à me le compiler à distance via Teamviewer sur mon RPI !!!
Là c'est la claque de folie, Avec GentooPlayer le son est tellement analogique que c'est renversant !!! Je n'ai jamais entendu un tel son...
Tout est tellement naturel que j'en oublie que c'est de la hifi, je suis au concert. Cette distrib linux est une merveille, surtout si gmediarender est finalement intégré dans une prochaine version dans l'image...
Tout ce que je peux dire c'est que ce Digione signature avec le système qui va bien est absolument hors norme niveau qualité...
Pour Info mon Système :
Quellis 1 Optima + BC 362D + (connection XLR) Master 7 Singularity + (connection BNC) Digione Signature tout ça correctement cablé.
didier D.
rapport qualité/prix 10/10
Super câble pour son prix. Très facile a travailler et en mettre en œuvre.
didier D.
Bon produit. efficace pour pas cher
Quand je l'ai reçu, le look et le coté "machin en plastique" ne m'as pas inspiré confiance.
Puis je l'ai installé sur la sortie audio de ma TV qui est branché sur le by-pass de l'ampli, c'est là que j'avais identifié le problème. un sifflement horrible du certainement a une boucle de masse.
Effet immédiat, plus aucun bruit... moche mais magique.
Merci à Audiophinics pour leur bon conseil
Franck B.
Leger mais de bonne taille
Il est bien en taille mais je le pensais bien plus lesté en fait.
Je suis bon pour chopper un morceau de ferraille à mettre au fond, et un antidérapant dessous parceque je le pousse en nettoyant ma panne.
Franck B.
Super qualité prix!
Facile à monter, ne fait pas cheap malgré une face de seulement 3mm.
Les vis ne sont pas trop courtes, ce sont les trous qui ne sont pas suffisamment chanfreinés. Apres un coup de fraise les vis sont à fleur.
franck J.
SHANLING UA2 DAC Symétrique USB-C ES9038Q2M 768Khz DSD512 Que vous utilisiez un smartphone dernière génération dépourvu de sortie audio analogique (compatible directement avec vos écouteurs / casques...
Super rapport qualité prix
Etant content du dac sabre 9038 de salon je me suis dit que cela devait être bien en version nomade : utilisé entre un P30 Huawei (Tidal) et un casque Hifiman, le résultat me plait puisque pour le moment je n'ai pas eu à utiliser un ampli de casque que je possède tant la sortie me parait suffisante. Je ne suis pas un expert, le son me parait aussi bon voire meilleur que sur mon lecteur Fiio M7 (ES9018).
Jean Michel P.
Excellente prise IEC après tweak ..
Cette IEC de base est très bonne mais devient exceptionnelle si on étame les lamelles de prolongation ( épaisseur à tester) et en resserrant légèrement les contacts pour une insertion plus franche . Timbres plus riches et consistants ..les petites brillances ont totalement disparu..
Maxime V.
En 2 mots : précision, détails
Branché à un streamer Sotm, je confirme les conseils avisés de l'équipe Audiophoncs (merci à eux) : très précis, beaucoup de détails, mieux par exemple que le DAC intégré de l'ampli Hegel H95.
Attention à la phase secteur, c'est la 1ère fois que je constate une sensibilité aussi importante sur un appareil Hifi. Le câble secteur d'origine est déjà bon, un câble plus performant apporte un petit plus.
Le bluetooth fonctionne parfaitement, c'est une option bien pratique.
Utilisé avec un câble de modulation RCA, à voir avec un XLR.
