Thierry H.
upgradable
Bruno R.
Semble OK
Radek P.
neotech nei 1220
Avis clients - Il y a 19385 avis.
Frederic p.
Surpris
J’avais des câbles de merde sur mon porte cellule,
J’étais septique sur la qualité du résultat sonore.!!
J’avais toujours un petit souffle un son étouffe et franchement après avoir changé les câbles plus clair plus d’impact…pour le prix top
Après jute bémol pour la connexion les cosses sont très petite j’ai dû les élargir pour les branches..
pjm k.
ATAUDIO POLARIS Câble USB-A Mâle vers USB-B Mâle Cuivre 7N OCC Plaqué Argent Quadruple Blindage 1.5m Le câble Polaris USB-A mâle vers USB-B mâle de chez ATAudio offre une très belle qualité de fabrication pour des performances optimales. On y...
usb
very nice cable
David P S.
IAN CANADA UCPI 2025 Module d'Alimentation à Supercondensateurs pour Raspberry Pi Le UcPi 2025 de Ian Canada est un module d'alimentation 5V à supercondensateurs haute performance et abordable, conçu spécifiquement pour les applications...
Agree with Clive S above: Ian knows his stuff
I had been having issues after a Roon infrastructure upgrade getting the same fantastic SQ I was used to on my main system. After trying a few RasPi digital transport hats that didn't do it, I reached out to Ian Canada via email for advice. He graciously responded the next day and suggested a transportPi Digi + this UCPi would solve my audio fidelity woes. Boy was he right! Got the TransportPi unit first and it was a huge improvement in the right direction. When the UCPi arrived 10 days later, wasted no time charging up the caps and installing. Bingo! This pairing along with upgraded clocks on the TransportPi does indeed deliver audio nirvana on a great system, it defies belief such bit perfect quality can be this affordable. Fun to play with the Pi units and wait for the next improvement to arrive, I just pretend I'm a 12 year old again waiting for the new parts of my nerd science kit to arrive! Thank you Ian Canada and Audiophonics.
David P S.
IAN CANADA TRANSPORTPI DIGI Module Interface Audio Numérique Ultra Faible Jitter Le TransportPi Digi est une interface audio numérique tout-en-un haute performance pour Raspberry Pi. Il propose une qualité de signal à très faible...
TransportPi Digi
Ian Canada is a great designer indeed! After a system redo I also needed to redo my Roon streaming infrastructure and had tried several types/brands of Pi transports, most were nice, but all were lacking in comparison with what I had going on before. Like the reviewer above, I finally got the TransportPi digi and upgraded to Accusilicon clocks as soon as I got the endpoint functional. Wow, finally the accurate sound with all the superlatives I was looking for again, and no more needing to maintain a pain in the a** Windows OS to have excellent audio quality again. Accuracy, detail retrieval and soundstage in spades. Wonderful audio quality that only makes you wish you had more time to listen. Thanks Ian and Audiophonics for the great customer service you provide!
Jean Claude R.
Déclencheur Audiophonic .
Le top pour piloter 3 amplis CROWN XLS classe D, bien inférieur a la puissance d'appel (démarrage temporisé ) prévue par le déclencheur d'alimentation malgré son pouvoir de coupure de 8 A.Pilotage par li trigger de mon préampli HC pionner SC LX 85. Nickel....A voir a l'usage dans le temps .
Xavier G.
TOPPING TCX1 Câbles de Modulation XLR 25cm (La paire) Les câbles TCX1 de chez Topping sont des câbles XLR mâle / femelle de grande qualité. Ils intègrent des conducteurs en Cuivre 6N et en Cuivre 6N...
Excellent câble XLR !
Ce câble fait preuve d’une grande qualité de fabrication ce qui laisse présager une grande robustesse. Il est cependant très rigide ce qui avec sa faible longueur ne permet de relier que deux appareils qui se touchent. Associé aux appareils de la même marque, il faut bien les mettre en forme sinon ils sont capables de les soulever ! Ainsi, il faut que l’appareil soit suffisamment lourd pour bien rester en place. Voilà pourquoi, si je devais refaire cet achat, je prendrais le même câble mais dans une plus grande longueur pour éviter ce problème et surtout pouvoir placer les appareils plus librement en cas de changement de configuration. Bref, je recommande pour la qualité malgré ce petit désagrément lié à l’installation.
Stewart L.
Minimal but high quality
This amp has everything I really need. Power seems solid, UI is adequate, and the fit and finish of the enclosure is high quality. Shipping to the USA was fast and very reasonably priced.
There was a small firmware bug involving the mute relays clicking that needed fixing. Audiophonics was prompt about fixing it AND about providing me with requested support to flash it in the field. (This issue should be resolved for new shipments according to Audiophonics.)
This amp is a great way to try out modern Class-D without breaking the bank or buying a bunch of separates.
Cyril M.
Enfin une machine qui fait de la musique!
Fan de la classe D depuis ses débuts et possesseur d'un ampli Gemincore, je me suis laissé tenter par la techno Purifi, après avoir lu les avis sur les forums et la revue sur audioscience.
Et bien je ne suis pas déçu! quel bond en avant au niveau de la restitution!
C'est d'une transparence et d'un équilibre extraordinaire.
Ce qui m'a le plus frappé, c'est la dynamique énorme avec des nuances extraordinaires entre les instruments et les attaques sont percutantes. Chaque instrument est à sa place dans la scène sonore et tellement bien défini qu'on peut se concentrer sur un et le détacher du reste. Et les timbres ainsi que les voix sont restitués à la perfection (on se surprend à croire que c'est de la musique live lorsqu'on est dans une autre pièce et on est attiré pour aller écouter en face des enceintes).
Bref je redécouvre mes albums, quel que soit le style ou la qualité d'enregistrement!
PS : l'ampli est couplé à un PC avec Quobuz / carte son studio (127 db de dynamique) en XLR, enceinte BW CM9S2 + Subwoofer ASW610 pour charpenter la restitution
Radek P.
TOPPING PA5 Amplificateur Symétrique Class D 2x125W 4 Ohm Argent Topping propose avec le PA5 un amplificateur symétrique compact mais pour autant puissant et très performant. Il intègre un circuit d'amplification Class D...
O.k.
I have 2 pieces connected as biamping. And it plays great. Preamplifier ADI-2 DAC FS.
Xavier G.
Excellente qualité !
Ces fiches bananes sont idéales et permettent une excellente connexion aux bornes de l’amplificateur et des enceintes. Il faut bien vérifier que votre matériel soit compatible cependant. La qualité de fabrication est impeccable et des gaines thermo rétractables sont même fournies ce qui permet d’habiller le bout des câbles. Bref, je recommande pour le prix modique.
Alain D.
Inetrupteur à Bascule Avion
Je suis ravi ! Les interrupteurs ont mis du temps à arriver mais ma patience a été largement récompensée! J' ai fait un tableau de commande électrique dans mon bar et le résultat est top! J' aurais bien partagé des photo mais je ne peux pas sur cette page... MERCI!
Stéphan B.
Module DAC pour Raspberry Pi 2x ES9023 24bit 192kHz Ce module DAC HAT vous permettra de transformer votre Raspberry Pi en véritable système audio haute qualité, sans vous ruiner. Celui-ci embarque un...
Son agréable
Monté sur un Pi 3 A+ sous moode player ce module a un son très agréable. Je n'ai pas de matériel de qualité suffisante pour en dire plus.
Il est livré avec une télécommande totalement inutile (et sans pile malgré une bandelette qui laisse croire le contraire). Pas envie d'acheter 3 piles bouton juste pour satisfaire ma curiosité.
Le point qui m'a fait retirer une étoile est qu'il n'y a absolument aucune documentation. On aurait pourtant bien aimé savoir comment piloter par logiciel les fonctionnalités que la télécommande laisse supposer. Ou tout au moins savoir quel pilote choisir dans la longue liste proposée par moode player.
Marek M.
Weights
A little flexible
suitable for light audio chains
R= 0,054 Ohm C=600 pF L=1,17 microHenry
Marek M.
high capacitance per meter ,low resistivity.
Marek M.
does not fit some bright headphones/iems.
unsuitable for high-impedance headphones. 100 ohm and more.
Marek M.
Adaptateur Jack 2.5mm Mâle vers XLR 4 Pins Femelle Neutrik Cet adaptateur symétrique à base de Neutrik se compose d'un connecteur Jack 2.5mm et d'un XLR 4 pôles femelle. Il profite d'une belle qualité de...
the connector on the xlr side is difficult to pull out
Marek M.
polarity weakly marked (+), adapter fulfilled its purpose
Nick P.
Very good service
The item is perfect , it is working as described.
Thank you for your perfect service once more.
Thomas H.
Excellent cable, excellent value. Extremely well constructed, and great fidelity.
Eric V.
NEUTRIK REAN NYS231BG-LL Connecteur Jack 3.5mm Stéréo Mâle Plaqué Or Ø8mm (Unité) Ce connecteur Jack 3.5mm stéréo mâle profite d'un belle qualité de conception avec un plaquage Or des contacts, favorisant la conductivité et...
Bon diamètre interne
Enfin une fiche mini jack bien construite pouvant être utilisée avec un câble épais, le tout pour un tarif démocratique.
Eric V.
câblage interne
Câble bien construit et relativement souple. Idéal et facile à utiliser notamment pour remplacer les câbles de liaison audio quelconques, dans un amplificateur par exemple, avec pour résultat un gain en dynamique et transparence.
Eric V.
câblage interne
Philippe S.
FURUTECH FP-S032N Câble Secteur Cuivre OFC (Alpha) 3x2.5mm² Ø16mm Câble secteur très haute performance à 3 conducteurs dédié aux applications Audio sans compromis,...
La bonne affaire !
L'avis que je viens de donner était pour le tc 31, pour le 32, je peux assurer qu'il boost la dynamique, ce câble est fait pour les amplis, le mien semble avoir gagné des watts pour pas chère. Je recommande.
Philippe S.
Un vrai câble premium
Une amélioration au niveau de la scène sonore, les timbres me paraissent très justes, je suis satisfait de mon achat.
Philippe S.
Câble que je trouve assez neutre au niveau des registres ce qui pour moi est une qualité, la scène sonore s'est encore agrandie, les musiciens se sont légèrement rapproché.
Le rapport qualité prix est incontestable.
Gianluigi C.
Good performances
I tried Elecaudio CS 321B on my CD reader and the result was definitely better than the CS 331B I used till now. So I decided to try it also on my ampli.
Audiophonics service is precise and on time as usual
Guillaume B.
ELFIDELITY AXF-107 Filtre d'Alimentation PCI Express / PCI Express 16x Le module AXF-107 de Elfidelity est un filtre d'alimentation à découpage pour ordinateur se raccordant en PCI Express ou PCI Express 16x et destiné à offrir un courant plus...
Testé adopté!!
Monté sur un PC tout neuf avec MATRIX Element H, ce n'est pas très flagrant mais, comment dire, le silence est bien posé, la fuguasse distorsion ou coloration tout en haut des aigus n'est plus, je note aussi un mieux pour le dynamisme qui aide à l'équilibre du morceau joué.
Carte enlevé puis remis puis enlevé puis remis et laissé car je dirais que ce filtre aide au rendu naturel du son.
Pas mal du tout ce filtre.
Guillaume B.
Tranquillité et musicalité
Après quelques petites cartes qui effectuent leur job correctement, la carte MATRIX ferme la porte pour laisser le bruit dehors MAIS VRAIMENT et permet une belle musicalité, elle apporte aussi une très bonne stabilité du signale.
Satisfait de cette achat.
Guillaume B.
AUDIO-GD R-1 2021 DAC R2R DSP FPGA USB Amanero HDMI I2S 384Khz 2x Accusilicon Avec le R1, AUDIO GD nous propose une nouvelle version du fameux R2R1, équipée cette fois d'une interface permettant de paramétrer les filtres, le niveau...
pour - de 1000 euros y a pas mieux!!
Bon, après rodage, le biniou s'est bien ouvert et y'a pas photos, le son est vraiment spatiale, hauteur profondeur largeur du spectre audible, tout est en place et très bien détaillé sans coloration particulière et cela peu importe le style joué, et à aucun moment j'ai pensé êtres sur une source numérique!
Un DAC transparent et MUSICAL!
Guillaume B.
WBT-0708Cu Borniers Haut-Parleur Cuivre Plaqué Or (Set x4) Issue de la dernière génération de développement par WBT, les borniers haut-parleur 0708Cu sont pourvus de conducteurs en cuivre pur et d'une...
très très bien
Pour upgrader des JBL, en comparaison avec l'original puis d'autres borniers 8mm en ofc plaqué argent, les borniers WBT sont très très bien, pas d'effet bouchon ou de voile sur une partie du spectre qui est étendu, ça descend vraiment bas et monte bien haut , la quantité de matière utilisé est cohérent avec les sections de câble HP généralement utilisé.
Très content de ce produit, vraiment.
Merci à Audiophonics pour la passion commune, bravo à l'équipe.
claude b.
IBASSO DX240 Baladeur Numérique HiFi DAP DAC ES9038Po Symétrique Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Noir iBasso revient avec un DAP haut de gamme, mêlant avec brio performances sonores pures et design moderne et ergonomique. Son étage de conversion numérique /...
RAVIRA VOS OREILLES
Aprés un DX80 (pb de batterie heureusement non récurent sur le DX240) je retrouve les qualités audios de ces baladeurs audiophiles
Fabrication soignée, écran superbe (trés sensible) et bonne autonomie.
Performances à la hauteur, son un peu "métallique" pendant la période de rodage des composants, plus chaud par la suite (en conservant l'alimentation d'origine)
Scéne sonore détaillée et large, basses comme il faut, sans excés
La molette de réglage du son et on/off qui pourrait paraître un peu prohéminente n'est pas du tout un handicap (bien protégée)
Le syteme d'exploitation est trés réactif, bref que du bonheur...
Quelques petits défauts sans conséquences ; protection transparente fournie un peu bas de gamme (preference pour le silicone noir du DX80) mais efficace, l'interface "Mango" (navigation simplifée) est un peu moche à mon goût, les codecs Bluetooth sont basiques pour une utilisation eventuelle avec écouteurs "true wireless"
en résumé :
qualité de fabrication 5
design (question de goût) 5
qualité audio 5
fonctionnalités 4
note globale 5
Si vous voulez le câble avec les connecteurs Oyaide beurium palladium acheté le monté il est moins cher
Dispo chez audiophonic
Vincent G.
Excellent câble relativement souple, néanmoins les fiches sont un peu serrées et nécessitent un petit ajustage sur certains connecteurs RCA. Qualité sonore excellente.
Vincent G.
Excellent pour le prix
Câble bien construit, souple et robuste, il offre une écoute très agréable. Excellent rapport qualité prix.
Matthew S.
NEOTECH NEI-1002 Câble de Modulation Argent UP-OCC Triple Blindage Ø11.5mm Le Neotech NEI-1002 est un câble de modulation composé de deux conducteurs monocristallins en Argent UP-OCC. Ces conducteurs sont maintenus à...
Impressive
This wire, using ETI Kryo XLRs, replaced a set of NEI-3001 mkIII going from dac to preamp. I was worried that the shift from copper to silver, and from 17awg to a 22awg wire would have a negative effect on tonal balance. After about 200 hours, those worries were unfounded. Beautiful tone, detail, and staging. The only negative is that I'm still curious about NEI-1001.
EVERSOLO DAC-Z8 DAC ES9038Pro XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Le DAC-Z8 de EverSolo est un DAC high-end extrêmement performant. Il embarque des composants haut de gamme avec notamment une puce de conversion numérique /...
Je le garde !
Je le garde !
Voici un DAC performant, musical, au look sobre et une utilisation bien meilleure que le HifiRose revendu pour cause d'ergonomie détestable.
Le Z8 ne fait pas lecteur de réseau contrairement au Rose. Pas grave, je passe par mon PC.
Le Z8 a une excellente entrée USB couplé au volume, contrairement au Rose qui reste à fond (bêtise !!!)
Le Z8 à une appli android. Très pratique.
A noter la réactivité d'EVERSO aux suggestions : http://forum.zidoo.tv/index.php?threads/wishes-z8-suggestions-souhaits-dam%C3%A9lioration.95035/
patrick b.
Module Amplificateur Class AB 4 Canaux TDA7388 4x45W 4Ω Ce module d'amplification Class AB à quatre canaux se base sur l'utilisation d'une puce TDA7388,capable de fournir une puissance de 45W par canal sous 4Ω.
Module ampli 4 canaux class AB TDA7388 ref : 16881
Module absolument stupéfiant dans ses performances et son rapport qualité prix .J'ai réalisé pour un atelier d'ados 5 enceintes bluetooth avec des HP 8 ohms :enceinte cubique avec le HP basse (20 cm) en dessous diffusant le son vers le sol ,à quelques cm au dessus de lui , et trois HP large bande de 12 cm de diamètre sur chacune des trois faces ; la face restante du cube sans HP et le module fixé sur le dessus de la boite .
Le tout alimenté par une alimentation à découpage 12 volts/5ampères (ne générant aucun bruit de fond et suffisante pour l'application ) .
Le son est impressionnant, puissant malgré l'emploi de HP 8ohms ,91db (perte normale de puissance ), mais surtout la qualité sonore est bien présente : son détaillé, bluetooth très performant portant à plus de 10m .
Par contre le radiateur du TDA7388 chauffe au bout de 5mn d'utilisation ,ce qui est normal mais nécessiterai de prévoir un ventilateur 12V ,idéalement peu bruyant, au dessus en usage plus intensif .
Il est également possible de l'alimenter en voiture par une batterie 12V ( ou système LIT-ION) ,il y a un connecteur prévu sur le module,
Les ados très contents de leur réalisation nous ont remercié vivement .
Une réussite pour le Noël 2022 .
Patrick B
Robert M.
music is more fun
I bought this DAC a few weeks ago. I was curious about the new Japanese digital/analog converter by Rohm, which is said to have a warm and analog sound signature. Well, I don't have many comparisons. So far I've used the Sabre ES9018 chip in my CD player. I also looped my Bluesound Node 2i streamer over this sabre chip. For me personally, the SMSL-DAC with Rohm chip sounds very neutral at first, luckily! In general, the entire frequency spectrum is resolved very well. What I noticed in contrast to the Sabre-Dac is that, for example, the sonatas and partitas by Bach, played by Leonidas Kakaos, no longer hurt the ears at certain heights like the Sabre-Chip does (at least to my ears). I also noticed with the Rohm-Chip a improved stage resolution (width and depth of the stage). I noticed this particularly clearly in Bartok's music for strings percussion and celesta (Zoltán Kocsis), but also in other orchestral works. Jazz recordings also have more stage and air. This makes the music more involving. The differences aren't huge, but the bottom line is that the music is more fun, and that's - apart from all the technology - the most important thing. The sheet metal case and knobs of the DAC are rather cheap. But the low price has to come from somewhere...
Bernard a.
Très satisfaisant.
Très satisfaisant.
Streaming Qobuz HD studio sur PC
DAC : TC electronic bm-c2
écoutes : Magnepan MG 1.5qr bi-câblés
auditorium de 20m²
Il a remplacé 2 T-amp 75w/4Oh bridgés en mono
Les Magnepan sont gourmands, le NCore ne s'essouffle pas, même sur la musique de chambre et le préampli du DAC à encore de la réserve.
Impressionnant sur les grosses musiques symphoniques du XXème, genre Prokofiev, Sibelius, Chostakovitch, Malher, etc. Détail, scène stéréo, profondeur.
Excellets produits
Depuis l'installation de ces SuperSpikes sous mes enceintes, le son est excellent. L'image sonore s'en est trouvée agrandie.
Très bon achat à recommander
Merci Audiophonics comme d'habitude parfait
David C.
Très bien!!
Bon produit pour de beaux câble DIY je trouve juste un peu court, avis qui n'engage que moi, sinon parfait!!!
David C.
ELECAUDIO EB-05 Gaine Tressée Extensible Nylon (PET) 07-14mm Gaine tressée élaborée en PET (Polyéthylène Terephtalate) monobrins pouvant être utilisée dans une large diversité...
Joli
Super finition avec cette gaine, délicat à couper faut avoir d'excellents ciseaux & finir avec de la gaine thermo rétractable
Anastasios T.
Perfect!
Great product to get airtight, elegant connections for a subwoofer enclosure.
David C.
Esthétique
Permet de faire une belle finition de câbles HP DIY en complément d'embout séparateur. Mais me semble très léger & pas très solide.... a voir dans le temps, ceci dit léger peut être bon pour ne pas alourdir un câble HP. Rapport qualité prix en corrélation avec le produit.
Balázs G.
NEOTECH NEET-1008 Câble Ethernet RJ45 Argent UP-OCC 1m Neotech propose avec son NEET-1008 un excellent câble Ethernet RJ45, profitant d'une conception d'exception. Celui-ci intègre en effet quatre paires de conducteurs...
Recommended
I am using it as I2S digital cable between network streamer and DAC - Ayon NW-T and Stealth. There is not better solution on the market for its price.
LAN is packet switching data system of grouping data into packets that are transmitted over a digital network...
David C.
EXCELLENT!!!!!
Je souhaitais suite à un up-grade de mes câble HP & au changement d'enceintes éviter les alliages/placage sur les fiches bananes, mais surtout pas mettre du câble dénudé!
Donc j'ai acheté du câble ATLAS EQUATOR 2.0 et monté ces fameuse fiches bananes VIBORG PUR RED COPPER et croyez moi la différence & amélioration ce sent réellement, plus d'ouverture , d'aération, de profondeur bref une définition nettement supérieure. Même les basses à faible volume se ressentes mieux, et pourtant j'ai une petite installation; ampli TAGA HARMONY HTA 25B (2X18W) & enceintes HIGHLAND AUDIO ORAN 4305 (87db 8ohm). Certe elle sont pas données mais superbes , fournis avec gaines thermo (non collantes, dommage) et clé Allen , chaudement recommandé!!!!!
Alain H.
Améliore nettement le rendu sonore de mon lecteur réseau sotM.
Merci à l'équipe Audiophonics pour ses belles réalisations à un prix très correct.
Fabien G.
TELEGARTNER MFP8 T568B Connecteur RJ45 Ethernet High-End Métal TELEGARTNER MFP8 T568B, tout simplement pour nous le meilleur connecteur RJ45 du marché, son corps métal, son exceptionnel blindage et sa facilité d'usage...
Qualité
J'ai fait tous mes connecteurs avec ce modèle car solides.
Comme toute connexion RJ il faut être soigneux avec la préparation du câble et respecter les longueurs à dénuder, attention la masse qui doit bien être mise. le clipsage se fait bien avec une pince multiprise qui a des mords parallèles. Une fois assemblé c'est robuste, éventuellement démontable en cas d'erreur. Bref c'est pro, c'est cher mais ça vaut la qualité.
Livraison Audiophonics rapide comme l'éclair et finalement un bon prix.
Christophe L.
FURUTECH DPS 4.1 Câble secteur Cuivre OCC DUCC Traitement Alpa 4.02mm² Ø17mm Ce câble secteur Furutech DPS4.1 est conçu à patrtir d'un conducteur 79/0.18α-OCC , d'un conducteur 37/0.18α-DUCC ainsi que d'un conducteur...
L'excellence
Je suis passé de l'alpha 3 a fp s55n et maintenant le dps en gardant toujours Les mêmes fiches. Le meilleur rapport qualité prix est le s55n qui est génial ,avec le dps on rentre dans le monde du détail de la perfection c'est Un câble pour Les puristes uniquement . + Silence détail envoûtant. - le prix bien sur . Complètement envoûté par le son de ce câble ne surtout pas écouter électro bidouilleur sur youtube c'est une chèvre. Faites vous plaisir. Audio GD Master 10 ,he 7r2r ladder dac,auralic aries G2, JM lab Diva Utopia. Cordialement
Théophane B.
MOONDROP ARIA Écouteurs Intra-Auriculaires IEM Dynamiques 10mm 122dB 32 Ohm 5Hz-36kHz Moondrop dévoile avec les Chu des écouteurs intra-auriculaires profitant d'une très belle qualité de conception et de restitution sonore à un...
À la hauteur des TRÉS hautes attentes
Les MOONDROP ARIA sont à la hauteur des TRÈS hautes attentes que j'avais. Impossible de trouver de gros points faibles. Agréables pour écouter tout types de musiques ou regarder des films grâce à un des basses boostées et une spacialisation large.
Je pourrais seulement déplorer un cable un peu cheap mais qui fait le travail.
Dans tout les cas, les ARIA sont devenus le mètre étalon des écouteurs intra en dessous de 100€ et ne peuvent que difficilement décevoir, ce qui en fait la paire parfaite pour rentrer dans le hobby audiophile.
