Tomasz C.
arnaud m.
Exelent
Jean-Louis R.
ne chauffe plus assez
Avis clients - Il y a 19313 avis.
Bogdan B.
Really good PSU (build and weight), using it to supply clean power to the Node 2i on the 5V rail and nearby router on the 12V one. Can not comment purely on the PSU but both the upgrade board on the Node with the power supply deliver a superior sound. More clarity, realism and surprisingly better bass weight. Definitely worth it, a quite considerable upgrade.
Thanks Audiophonics team!
Roman Z.
LOXJIE D50 DAC AK4499 USB XMOS Bluetooth 5.0 MQA 32bit 768kHz DSD512 Loxjie nous propose avec son D50, un DAC résolument moderne. Basé sur une excellente puce AKM AK4499 et interface USB XMOS, il supporte les flux PCM jusqu'à...
LOXJIE D50 DAC REVIEW
The LOXJIE D50 DAC is a fanstastic product. It is sonically extremely precise with a natural sound. The character of the DAC is not very direct, instead it is sophisticated and very listenable. The bass is precise, the vocals are natural, the highs are clear and precise. The overall structure of the sound is balanced and dynamic. The DAC doesn't inflict fatigue on its listener and it's very enjoyable. Of course the DAC isn't the only important part, the RCA interconnect cables are also very important (as well as all your other equipment). I heartily recommend this DAC to all music enjoyers and audiophilles, I'm certain that its quality is comparable to DACs of even the 1500€ range.
J'ai opté pour ce sp1100 pour sa triple isolation et sa grosse section occ et pas déçu du tout. Sur mon ampli YBA et preamp phono Pier Audio il fait des merveilles. Branchement fait avec des prises Viborg, c'est du 5/5 pour moi.
Petit lecteur cd très efficace, même non rodé les graves sont présents et bien charpentés, les médiums sonnent vrai, et l'aigu pas acide. C'est un beau début, je ferai un test avec un dac externe histoire de voir mais ca marche déjà très bien, dynamique et détaillé.
Herve C.
Modules Amplificateurs Class A Bipolaires MJ15024G / MJ15025G 2x15W 8Ω (La paire) Ce double module amplificateur mono propose une conception des plus classiques, reprenant des schémas éprouvés qui ont marqué le sont des glorieuses...
1 an déjà
J'ai acquis cet historique et mythique ampli, il y aura bientôt un an déjà. Surpris dès sa mise en service, et avec une alimentation et filtrage largement dimensionnés, cet ampli s'est montré depuis vraiment extraordinaire, simple, puissant et précis je ne l'ai jamais pris en défaut. Il exige de très bons haut-parleurs et des enceintes de bon rendement. La puissance annoncée parait modeste mais à l'écoute ce sont de vrais watts puissants, détaillés, une scène sonore d'une réelle précision, Patricia Barber, Diana Krall, Bach aux mains d'Alexandre Tharaud des variations Goldberg exquises, Grégory Porter est là, sa voix puissante est rendue merveilleusement. L'ampli nécessite un budget certain en périphérie, mais l'ensemble est hautement pertinent de l'avis d'amis exigeants. Il a été testé chez eux sur des Rogers et sur des Focal, les essais ont provoqué l'étonnement.
Stephane E.
Simple et excellent !
Hello,
Tout d'abord merci à Audiophonics pour la qualité de service, livraison rapide et sans souci.
Concernant ce commutateur amp-s et bien je suis très agréablement surpris.
Je souhaitais faire cohabiter mes triangles lyrr XS avec un ampli hc Yamaha dspz7 et un "vieux" Pioneer A-717.
Les essais de connexions en preout ne me satisfaisant pas, je cherchais une autre solution.
Et bien j'ai trouvé avec l'Amp-s
Tout d'abord le boîtier est de bonne qualité, bien fini (full métal) et construit serieusement. Il suffit de l'ouvrir pour s'en apercevoir : les borniers sont bien serrés sur la platine arrière, les pattes sur lesquelles sont soudés les fils sont isolés avec de la gaine thermo, le bouton de commande est verrouillé fermement, c'est propre sans fioritures.
A l'écoute, il est totalement transparent, même pendant 3 heures d'écoute a haut niveau ... Et pourtant les Lyrrs ne pardonnent pas.
Je garde le son vintage du du Pionneer (graves profonds et moelleux, médiums incisifs) sur Vinyls/cd et la dynamique explosive du Yam en HC. Aucune détérioration audible, il se fait totalement oublié !
Donc vraiment satisfait de ce boîtier.
Une seule remarque qui lui fait rater la 5e étoiles : les borniers mériteraient d'être 5 mm plus profonds pour y rentrer entièrement un fiche banane "standard"
Sinon très bon produit et prix sommes toute correct au regard de la qualité.
A+
Steph
Pierre-Louis L.
Fx Audio... A confirmer après rodage.
En lisant les avis des uns et des autres j'ai voulu ajouter ce préampli en l'installant à la sortie de mon déjà très bon ATOLL PR300 . L'ampli de puissance est un KECES S125 - Mes enceintes sont des JBL L112 . Résultat : Les premières écoutes sont un peu décevantes. Je suis maintenant à une dizaine d'heures d'écoute. Certes, il y a plus de basses mais le médium est très légèrement amputés , je perds un peu en lisibilité, voire il apparait un très ( très ) léger souffle avec le FX audio tube-03 qu'il n'y avait pas avant.
Je rajoute une alimentation linéaire ( audiophonics ) et pour l'instant rien ne change. Il faut espérer que le rodage des nouveaux câbles RCA et des Tubes du FX-Audio vont améliorer le tout sinon je repartirai sur ma précédente configuration qui me donne déjà beaucoup de satisfaction. J'ai vu aussi qu'on pouvait changer les OP amp et les tubes. J'essayerai cette option si je vois que le rodage améliore le son. Bonnes écoutes à toutes et à tous ! Pierre-Louis
NEOTECH NEUB-3020 Câble USB-A Male/USB-B Male 2.0 OCC plaqué Or 24k 1.5m Le câble USB AUDIO class 2.0 Neotech NEUB-3020 offre une qualité de restitution numérique redoutable utilisant des technologies innovantes venant bousculer...
complément sur mon premier avis
Au niveau de la qualité et de la fabrication du câble je n'ai rien à rajouter, mais pour l'écoute, j'ai repris mon ancien câble USB FURUTECH GT2 qui est aussi un câble en cuivre OCC et là le câble FURUTETCH est largement supérieur. Bien sur le câble NEOTECH apporte une bonne écoute mais il manque quelque chose au niveau de la dynamique. Peut être est ce du à une meilleure adaptation avec mes appareils, mais cela montre bien que le choix peut s'avérer difficile sans un essai .
Bernard N.
Parfait pour ampli anglais
Je devais remplacer les borniers de mon amplis qui n'accepte que les fiches bananes , comme beaucoup d'amplis anglais de cette génération..
Coup de bol , ces borniers sont à la parfaite dimension , au millimètre prés , de la découpe du châssis de mon ONIX :l'encastrement est parfait .
La qualité de construction est de bon niveau . C'est le genre de borniers que l'on trouve sur les petits FDA;, ils ne sont pas gigantesques , mais font parfaitement le job.
Quel joie de pouvoir utiliser du câble nu ou des fourches .
Je recommande fortement .
Yves G.
Préamplificateur Symétrique RCA XLR 10x NE5534D 4x NE5532D Potentiomètre ALPS avec Télécommande Ce préamplificateur symétrique offre une excellente qualité de conception se basant sur des circuits reconnus pour leurs performances et la qualité...
Un appareil hors du commun
L'appareil est en fonction depuis une semaine, et mes explorations sonores avec lui ne sont pas encore terminées. Choisi sur le conseil de David Aubert, arrivé sans encombre, très bien emballé. Ce préampli est anonyme, mais on peut assez facilement retrouver son origine sur certain site chinois, où il est présenté comme un clone (sonore ? car l'apparence ce n'est pas ça du tout) du monstrueux préampli allemand MBL6010D. Le design du préampli est peu commun, avec ses touches en alu (?) munies en leur centre de led bleues, et avec ses pieds dorés (faute de goût à mes yeux, mais pardonnable et aisément masquable). La machine donne une rassurante impression de solidité. Télécommande en plastique, un peu cheap. Le tout sans aucun mode d'emploi, ce qui est un peu déroutant mais n'est pas un obstacle, tellement l'utilisation coule de source. Aucun problème pour l'installation, entre un DAC SMSL SU-9 et un ampli MPA-S125NC XLR stéréo classe D NCore alimentant des Q Acoustics 3030i (chaîne de bureau). Pour mettre en route, il faut actionner l'interrupteur arrière, ce qui fait clignoter discrètement le bouton Power sur la face avant. Ne reste plus qu'à choisir sa source en appuyant sur une des cinq touches à disposition (ou en se servant de la télécommande). L'action enclenche des relais, dont on entend les clics très francs en même temps que s'allument les leds de la touche Power et de la touche source choisie. Il faut dès alors actionner le gros bouton de volume (ou la télécommande) pour atteindre le niveau sonore désiré.
Et là c'est un vrai plaisir ! La qualité sonore est au rendez-vous : délié, détail, fruité des cordes, fermeté des graves, scène sonore large et profonde, le... pied ! Et je pense que ça va encore un peu s'affiner avec le temps. Mais ça ne pardonne pas pour les mauvais enregistrements.
Attention : à l'extinction, le volume se remet à zéro tout seul (ce qu'on a tendance à oublier lors de l'utilisation suivante, car le bouton ne revient pas à sa position précédente, qui n'est pas mise en mémoire, apparemment).
Les fonctions de la télécommande sont basiques : ouverture/mise en veille, choix des sources, mute, volume + ou -.
En bref , les moins : anonymat (vite démasqué), design un poil baroque, absence totale de documentation. Les plus : qualité de la construction, facilité d'utilisation, qualité sonore exceptionnelle, et... le prix !
Joachim B.
A true gem
I must admit I was sceptical at first. A first rate preamp at this price. But now I'm a convert. This piece of kit is excellent. All the way down to the construction. It sounds amazing, beating out a lot of preamps that I have in my possession many times the price of this unit. With better soundstage, clarity and separation. The only caveat is that the gain might be a little hot for some amps. Many thanks to David at Audiophonics customer service.
DAVID H.
très Satisfait
Je suis un objectiviste donc pas très fan du "son " prétendu des amplificateurs. Mais ayant des enceintes difficiles à driver j'ai décidé de me lancer dans l'achat d'un fameux Purifi 1ET400A. Le prix est très compétitif. J'ai rencontré un problème : une boucle de masse (j'entendais le son des HDD dans les enceintes)... après plusieurs tests cela venait de mon installation car la même multiprise partageait l'ampli et mon PC. Je conseille donc d'utiliser ce modèle sans autres électroniques type PC, box, chargeur de téléphone sur la même prise. Merci à l'équipe d'audiophonics pour les réponses à mes questions.
Câble USB qui s'éfface devant la musique.
Ce câble offre une belle fabrication et sa souplesse est un plus. Cela évite les contrainte sur les connecteurs. Il apporte une grande transparence et se fait oublier. Il n'y a pas d'aigus cristallins, de grave puissant etc...Il y a la musique, toute la musique rien que la musique. Son prix est raisonnable, loin de certaines productions qui frôlent des prix délirants et qui appellent plus de questions que de réponses. Ici, nous avons un câble qui apporte une grande satisfaction auditive difficilement surpassable au regard du prix.
Cédric T.
Super son
Pour le prix je sais pas si il peut avoir mieux.
Comparé à mes Audioquest Evergreen, le son est plus détaillé, surtout sur les aigus, il y a de la profondeur et de la dynamique.
Construction exemplaire tout en restant souple
Cédric T.
Superbes !
Super fiches.
Le design est idéal pour la soudure et le soudeur débutant.
Le build est bien, et très correct, le tout a résisté dans soucis à la température.
LAURENT L.
SINGXER SDA-6 PRO DAC Symétrique AK4499 AK4118 FPGA XMOS I2S LVDS 32bit 384kHz DSD512 Le DAC symétrique Singxer SDA-6 profite d'une architecture high-end favorisant une restitution sonore de haute volée. Ici rien n'est laissé au hasard,...
Exceptionnel
Voici un DAC exceptionnel, je l'ai comparé à des concurrents 6 au fois plus chers et il fait jeu égal. Par contre il demande bien 200 à 300 heures de rodage pour que les composants Mundorf de l'étagère sortie analogique se rôdent, une fois ce cap passé on ne peut rien reprocher ace convertisseur tout y est: timbres, dynamique, résolution.
LAURENT L.
SINGXER SU-2 Interface Digitale USB 32bit 768khz DSD1024 SPDIF AES/EBU I2S HDMI LVDS Voici la seconde version des interfaces digitales SINGXER SU. Celle-ci gagne en puissance et peut désormais traiter les flux numériques jusqu'à 768kHz...
Déception
Grosse déception, pourtant utilisé avec un Dac de la même marque Singxer, attenuation du signal sonore de 15 db ce qui est énorme.
Miomir K.
Excellent DAC
I use it via a USB connection to a Sony TA-F3000ES amplifier that powers the Wharfedale Diamond 230 speakers. I am very happy with the purchase.
A : Stephane B
J'ai fait la même expérience que vous, au départ l'ampli semble merveilleux partout, mais manque de relief, de tessiture, et devient vite ennuyeux. Fonctionne mieux dès qu'il est mis en route, soit froid, ou fatigue auditive, je ne saurais pas répondre.
Ces amplis semblent exceller dans le grave, c'est l'utilisation que j'en fais à présent.
Associez le à un Mosfet classe A pour la section médiums/aigus, ou carrément atteignez le nirvana en l'associant à des amplis type SE en 45, 2A3, 300B, 811, 845. en fonction du rendement de vos haut-parleurs, et de vos goûts musicaux.
Milan H.
Plug&play experience
Unbox it, plug to you PC, done. No drivers, no headache. Sturdy build, USB-C. Perfect
recablage d enceintes
j était un peut inquiet pour le diamètre de seulement 2 mm2. et bien sais super.. aigus sans tonique ni stridente.. doux et soyeux. medium riche de détails .instrument a leurs place. Les voix sont très naturel et chaleureuse dans le bon sens. les graves sont bien tenu. Serré et dynamique. l image stéréo et bien agencée et profonde. Un petit câble qui paye pas de mine qui monter sur mes xo jmr de 1987 redonne toute sa présence sa dynamique. Excellent aussi en câble hp pour la petite chaine de mon amie. Cayn st200 et une paire de Kef et lecteur réseaux sotm m100. jsa ma donné l envie de me mettre a la haute définition.. ;-)Ps: pour des woofer de plus de 150mm préférer les oayde across en 2.8mm2. idem pour une enceinte dépassant les 80w /120w crête. les across sont superbe. pas besoin de dépenser plus si vous rechercher avant tous naturel détails et présence et dynamique contrôlée. du vrais bon matos d audiophile.
Quentin B.
Au Top
Couplé a un cable isolé ce dynavox fait formidablement bien son job!
Claude W.
DD DJ44B Adaptateur Jack 4.4mm Symétrique Femelle vers Jack 2.5mm Symétrique Mâle Plaqué Or Cet adaptateur symétrique se compose d'un Jack 4.4mm femelle et d'un Jack 2.5mm mâle. Il profite d'une très belle qualité de conception avec un...
Une merveille
Utilisée avec un Sennheiser HD 800 S la symétrie apporte un gain de clarté et une descente dans le grave incroyable. L'apport audiophile obtenu grâce à cet adaptateur est sans commune mesure avec la modeste dépense effectuée pour tirer plein parti d'un ampli Topping A50 avec une sortie symétrique de 2,5mm. Bravo.
Pedro V.
Good cable, some quality-control issues
The cable appear very nicely finished, but the metal ring that differenciate L/R are less practical than simple color coded plugs.
At first the cable sounded a bit muffled and "wrong", but after a while I tried reversing it and the sound opened up. Conclusion: I think the directional arrow were assembled the wrong way round - maybe some quality assurance issues?
When wired correctly I quite like it and prefer it slightly more expensive cables by QED that it replaced.
Bernard g.
Excellent produit pour un nas
Après m'être offert un bon pré-ampli (Atoll Pr300), j'ai constaté une amélioration très qualitative en particulier pour les enregistrements Jazz des années 50_60:qualité des timbres, présence de la contre basse, profondeur de la scène sonore. En revanche, J'avais un écart important de rendu sonore entre la musique écoutée via Qobuz et le même morceau enregistré sur mon NAS.
Fort de ce constat, j'ai branché cette alimentation sur mon Nas et mon routeur.
Le gain en qualité sonore est indéniable. La qualité sonore via mon Nas est montée d'un cran.
Merci à Audiophonics pour cet excellent produit qui plus est pas trop cher par rapport à la concurrence.
affaire en or
utilisant le 1220 argent dont je suis toujours émerveillé par ses qualités de timbre de précisions et de détails.. une écoute naturel presque physiologique fait de matiere et de musicalité hors paire au rapport qualité prix somme toute excellente .je voulais le comparer a sont homologue cuivre.. je ne suis pas déçu. même qualité même dynamique.. musicalité un peut plus chaude cependant.. qui plaira aussi bien au aficionados du tube que des Gas comme moi recherchant un parfait équilibre entre musicalité espace sonore et timbre au dessus de la moyenne.. monte en xlr vibors rhodium.. il excelle partout..et a quelques détails il est très proche du 1220 argent. peut être un peut plus analytique.. le cuivre et plus chaud et plus doux.. recommander sans hésitation.. un des meilleures gap du moment.. et de loin.. privilégier des rca ou xlr de la même veine.. genre eti cuivre ou furutech rhodium.. les klei cuivre plaqués argent serrais génial mais le diamètre et un mm trop grand. Ont peut enlever du diamètre sur la gaine. Mais sa demande un travail minutieux..
Tuğçe A.
Canare
hello everyone
I have done shopping from many companies abroad and I am doing it for the first time from this store.
But I would like to say that I am not satisfied at all.
I ordered 3 sets
13.80cm cable came instead of 14m
I sent an e-mail
I am not satisfied with the answer I got.
good cable i recommend
Excellent préampli solid state.
Ce JC2-FET semble remplacer l'ancien préampli Audiophonics solid state, noir, appelé JC2 par beaucoup et doté seulement de 3 entrées et qui a d'ailleurs récemment disparu du catalogue Audiophonics.
Et bien que dire du nouveau JC2-FET, de ce nouvel arrivé?
Il chauffe un peu, plus que l'ancien préampli noir, ce qui n'est pas un mauvais signe.
Tout d'abord, que les qualités du nouveau venu semblent bien supérieures à l'ancien, lequel en donnait déjà beaucoup pour 170€. Ici la différence de prix s'entend clairement. Plus de précision, de matière, de relief, les timbres sont d'une plus grande richesse, la transparence fait un bond étonnant. Mais cela ne serait rien si la musicalité, l'expressivité n'avait pas suivi cette progression. Et bien, elle est clairement plus évidente, les voix d'un opéra de Rameau, par exemple, nous interpellent, elles ne sont pas que de simples exercices stériles de style, leur humanité nous bouleverse tout simplement.
Ce préampli m'a conquis mais cela a pris du temps.
Tout d'abord, il réclame un rodage de plusieurs semaines, donc trés long, je préviens les pressés.
Ensuite, il est très sensible aux câbles de modulation, en amont j'ai mis un Van den Hul First qui lui va trés bien, en mettant en valeur la délicatesse du rendu sonore qui nous est offert, pour un prix assez démocratique.
Et puis il est trés sensible à l'ampli de puissance placé en aval: un Quad 606 est servi aux petits oignons avec ce JC2-FET alors qu'un Goldmund n'y fait pas des étincelles, mais cela ne m'étonne pas, Goldmund a toujours été un peu atypique.
Bref ce préampli offre une transparence assez incroyable mais il sert aussi vraiment la musique et ne fait absolument aucune chirurgie sonore.
Je cherchais un préampli solid state pouvant atteindre les qualités musicales d'un bon ampli à tubes et je crois bien avoir atteint mon but.
Tres bien
J'avais déjà pris deux sets et j'en ai recommandé un car c'est un très bon produit. Placé sous des enceintes colonnes, ces pointes sont parfaites.
Merci l'équipe pour l'envoi rapide et l'emballage nickel.
Romain R.
Très bonne finition
Un câble très bien fini, la qualité est au rendez-vous.
Romain R.
Excellent appareil à prix raisonnable
Ce petit appareil a un excellent rapport qualité/prix. Le design est sobre et efficace. La finition est très bonne même s'il faut être évidemment précautionneux, notamment avec le connecteur USB-B. La restitution sonore est de qualité.
Configurations testées :
- connecté à mon lecteur CD et enceintes sans ampli, belle restitution sonore quel que soit le filtre utilisé.
- connecté à mon PC en USB, bonne restitution avec de grosses différences selon la qualité de la source (fichiers audio, vidéo, jeux, internet et streaming ...) et le filtre utilisé (avec purifieur audio en entrée de DAC).
- connecté à mon PC via Bluetooth, excellente restitution sonore à 3m, scène large et aérée, bluffant ... et plutôt cool pour supprimer les câblages !
Conclusion : je recommande vivement ce matériel au regard de son rendu et de son prix.
PS : merci à Audiphonics pour l'envoi très rapide, l'emballage de qualité et la traçabilité du produit.
Benjamin V.
Dac Magic
Après un Audio-GD depuis 4 ans, j'ai voulu essayer et je suis ravis. Le son est tout simplement Magic avec un Supernaite 3 et des 702S2 ... on entend réellement les instruments, les doigts sur les cordes de guitare, les marteaux qui tapent sur les cordes d'un piano, les cymbales vibrés. En Live vous pouvez différencié la salle et le placement du chanteur.
Je l'adore sur des lives unplugged et sur des B.O. comme John William à Vienne!
Dans le cadre de Films, je me sens bien plus au milieu de l'action qu'avant.
L'affichage des fréquences d'entrée est très utile. J'ai pu me rendre compte que certaines sources dégradé les signaux ...
J'avais très grandement sous estimé le Bluetooth : parfait pour la télé, Shield Nvidia et box android, écoute de Spotify dans des soirées avec du monde!
Rafael S.
fansastic
I've replaced my old hi-end mono amps pair, 250W/4 ohm for listening to my classiques Dynaudio Confidence 5 (4 ohm, 80 dB/W/m). I am surprised this Ncore sounds absolutely transparent, no sound signature. I've noticed lower distorsion when playing loud, I cannot hear amp limitations. My room is about 27 m2 so this 250W works well. For a larger room and a so low 80 dB/W/m sesitivity a 400~500W could be necessary if real world SPL is wanted. The trigger input is very suitable. The amp remains cool even when playing loud. The box is ok and no luxurious kind of. This Ncore is almost perfect, immo.
Cédric A.
Câble USB-C vers Micro USB Plaqué Or OTG 20cm Les ports USB-C étant de plus en plus répandus, notamment sur les smartphones et les ordinateurs, ce type de câble USB-C vers Micro USB devient un...
Perfect !
RAS, c'est un câble qui câble bien.
Cédric A.
FX-AUDIO D502BT Amplificateur FDA TAS5342A Sortie Subwoofer Bluetooth 5.0 2x60W 4 Ohm Noir Le FX-Audio D502BT fait suite, comme son nom l'indique, au D502. Il en reprend donc la base et les composants, tout en embarquant cette fois-ci un récepteur Bluetooth...
So far So good
Un rapport qualité prix imbattable pour une installation avec de vieilles 3 voies Kenwood. Branché en usb sur un PC en 96k. RAS après qq heures d'écoute, pas aussi bon que mon vieil ampli Kenwood avec sa paire de Célestion mais encore une fois pour le prix c'est top.
Vincenzo v.
Power cable
Great neutral sounding power cable.The main quality of this cable is the excellent mid / bass details, full bodied / full sound not fat, great well articulated bass, never fatiguing high range, good 3d.I got great results on the amp integrated. Quite stiff cable. It pairs well with neotech 75 ohm coaxial cable, purchased / reviewed on Audiophonics. Tested on a high level system. Of course always excellent products from Audiophonics. Widely recommended cable also considering the price.
Vincenzo v.
Coaxial cable neotech
Excellent coaxial cable, tested on cd mechanics, network streamer, with excellent results.Neutral cable, excellent instrumental separation, excellent voice definition, excellent 3d.The cable immediately sounds good, but I recommend at least 20/30 hours of running-in. That at this price you can not find better. Tested on a high level system. Highly recommended.
marc g.
Module Amplificateur 2.1 Bluetooth 4.1 TPA3110D2 2x15W + 30W 4 Ohm avec Contrôle de Volume Ce module amplificateur est parfait pour les amateurs de DIY souhaitant construire un petit système 2.1 amplifié avec réception Bluetooth et contrôle...
bon rapport qualité prix
au final j'en ai acheté un deuxième, car l'offre en amplis 2:1 avec bluetooth n'était pas pléthorique (un point à améliorer). L'avantage, c'est qu'on a tout dans la même carte, et que ça marche tout de suite.
Eh bien le bluetooth marche plutôt bien, c'est le premier acheté qui devait avoir un défaut. Puissant, il reste de constitution fragile (surtout les boutons plastiques pas bien ajustés) mais une fois enfermé dans son montage, tout va bien. A conseiller pour des petits montages sympa et rapides car tout de suite opérationnel.
ces RCA sont pour moi excellentes car le fameux RQP est très bien. bonne construction solide le capot est métallique, il y a un embout de sortie de câble, qui s'adapte selon le diamètre, et si besoin on l'enlève pour un gros câble. le point chaud est accessible a la soudure, et la partie masse est très bien faite, sans faire une grosse masse de métal qui pourrait gêner au soudage des fils. J'ai fais une paire de câble avec du Sommer câble Albedo mk II, et le résultat est très bon. voir mon avis sur ce câble. n'hésitez pas, même pour les novices en soudure.
Alexandre C.
IBASSO DX300 AMP11 MKII Baladeur Numérique DAP Symétrique 4x CS43198 FPGA Bluetooth 5.0 WiFi Noir Baladeur numérique high-end, le iBasso DX300 dispose d'une architecture soignée, pensée pour offrir les meilleures performances sonores pour une...
Magnifique appareil
C'est un appareil vraiment bon, même s'il est perfectible niveau Android.
Amp11 MK2, non négigleable. Le MK1 souffrait d'une sur utilisation de la batterie Amp et d'un son moins qualitatif.
L'amp11MK2 alimente très bien les casques les plus exigeants.
Je ne parlerai pas du streaming, préférant la sonorité des câbles. Ni de Mango OS (pas mon usage, même s'il était très réactif sur le peu d'essais que j'ai fait).
Pour la qualité sonore, je n'ai rien à redire. Il est très neutre et sans excès. Si je poussais, je dirai même que je redécouvre avec plaisir certains de mes morceaux.
Beaucoup de reviews en parleront mieux que moi.
Android est très fluide grâce aux 6 GB de ram.
Le choix d'un Snapdragon 660 (2017) et d'un Android 9 (2017) peut être tendancieux (security patch 2018).
Il n'est pas possible de gérer l'equalizer sur l'ensemble du système (confirmé sur Head Fi).
Et il y a assez peu d'option Audio (dû à un système/CPU Android assez ancien... Un point poouvant être décevant pour les experts du micro tuning audio).
Pour ma part, ce n'est pas un problème, n'utilisant jamais les equalizers (écoutant des genres très variés).
Le vrai bémol est lié à un bug d'Android 9(-). Bug de copiage de fichier qui peut interrompre le transfert des fichiers audio.
Un des moyens de l'éviter est de compresser en "zip" les fichiers (Option "Store", WinRAR sur Windows (pour ne citer que lui)) et de les copier sur l'appareil ou sur la carte SD à travers l'appareil.
Avant de décompresser l'archive à l'endroit voulu via un "unziper" installé pour l'occasion (ex: RAR).
Un autre -, en usage DAC, le chargement (USB3.1) ne semble pas compenser la diminution de batterie à l'usage. (Son à 60%/Jack symétrique 3.5)
En utilisation Android, je recommande l'usage de : (sans vouloir faire de publicité, il doit exister d'autres app qui font tout aussi mieux/voir +)
- Firefox plutôt que Chrome, pour sa gestion des extension Privacy/Ads.
- Greenify pour l'"hibernation" des applications qui ne sont pas en cours d'utilisation.
Ainsi, il est possible d'atteindre 17H d'écoute en FLAC. (l'appareil n'intègre pas d'application pour "hiberner" les applications)
- Poweramp/Neutron peut être un + en usage Android. Mango app étant assez limité en gestion de liste de lecture, ou encore de lecture aléatoire + liste repeat.
Le rodage/Burn-in est obligatoire, l'appareil gagne réellement en qualité d'écoute après 100H et + encore après 200H. (ce n'est que mon avis).
Malgré les quelques points négatifs, j'en suis très satisfait.
Avec ses 128GB de ROM, je n'ai même pas eu besoin d'une carte SD.
La charge est rapide, 2x2 MIMO permet une connexion WIFI parfaite (utilisation émetteur comme récepteur)
BT5.0 permet à l'appareil d'être valable pendant plusieurs années.
A mon sens, c'est un des meilleurs lecteurs sur le marché.
Au point qu'il me donne envie d'acheter un nouveau casque Hi-Fi.
Je ne regrette pas mon achat et je le recommande vivement. (chose rare de ma part).
En poussant plus loin les points négatifs, je regrette :
- L'étui en cuir bleu pour la version noire, une coque TPU (même si moins belle, aurait été plus protectrice et aurait moins gardé la chaleur)
- L'absence de "caches" pour les entrées non utilisées (poussières.., surtout en usage nomade)
- La non utilisation d'un CPU 86X (économie d'énergie/dissipation de chaleur), même si les 6GB de RAM compense niveau rapidité d'execution.
RQP top
j'ai essayé cet Albedo mkII, en modulation entre un cd et mon intégré, monté de façon classique, c,a dire, les deux fils rouge et blanc ensemble sur le point chaud, et la tresse en masse des deux cotés, mais ATTENTION, sur les ref imprimées au bout il y a une petite flèche (triangle équilatéral),donc j'ai mis les deux câbles dans le même sens, et j'ai fais un repère sur une gaine thermo tenant les deux câbles avec une flèche dessus. Après, brancher et déguster; mes connecteurs sont des amphenol, donc a ce niveau il est possible d'améliorer, mais dans ces conditions, le RQP est top car la scène sonore est très bonne pas projetée, beaucoup de clarté et de définitions, vraiment un bon résultat, j'en suis très content, n'hésitez pas a essayer.
Jérôme V.
- Bon produit. Semble de bonne qualité et robuste. Fait parfaitement le boulot dans REW EQ.
- Commande rapidement traitée, correctement emballée et expédiée. RAS.
yves p.
R.A..S
Sa fonctionne très bien avec un FDA AD 18 (TV,CD, Blu-ray).
Michael A.
DAC correct mais sans plus.
J'ai pu comparer ce DAC avec un Cambridge Dacmagic 100 et les DAC Analog Device intégrés dans mon DENON AVC A1SE. Sur ce DAC FX01 les graves sont trop présents et mal "tenus", les aigus en retrait et il manque cruellement de détails sonores. A utiliser en dépannage pour améliorer une sortie son de PC.
Bruno M.
DYNAVOX ST30 Support pour Disques Vinyles et Tablettes Afin de mettre en valeur visuellement la musique que vous écoutez, Dynavox propose le ST30. Il s'agit d'un support pour disque vinyle qui vous permettra d'exposer les pochettes...
Bien pour le prix
Il arrive replié sur lui-même dans une toute petite boite. Les articulations sont crantées et s’assouplissent très vite lors des manipulations. Une fois les bras bien positionné la pochette vinyle présente bien et l’ensemble est stable quoique ce support soit léger. Un peu léger pour une tablette sauf à ne pas la toucher. Je ne suis pas sûr que les crans plastiques résisteront à de nombreux dépliage-pliage. Une fois en forme il présente magnifiquement le disque en écoute.
Bruno M.
LINDY ANTHRA LINE Câble USB-C 3.1 Mâle vers USB-A 3.1 Mâle Plaqué Or SuperSpeed+ 10Gbps 5A 1.5m Les câbles de la gamme Anthra Line de chez Lindy sont des produits de grande qualité, idéaux pour des installations professionnelles. Il s'agît d'un...
Même si pour la transmission des données plus le câble est court et mieux c’est, cette longueur de 1.5m donne plus de souplesse notamment lors de l’utilisation relié au chargeur pour mon DAP.
Connecteurs de qualité sans aucun jeu. Assure la charge rapide sans tiédir. Transfert de données sans problèmes mais je ne suis pas un Geek. Excellent.
Bruno M.
Incontournable
Belle qualité, doré pour de bon contact.
Transforme pour pas cher un câble RCA/RCA en Jack/RCA. Excellent résultat sur un DAP ne disposant que d'un connecteur S/PDIF Jack ainsi transformé en RCA.
Bruno M.
Bien vu
Il arrive dans son petit carton bien protégé par sa pochette suédine noire.
Formé de 2 parties en multiplis courbées et teinté en surface il est plus mat que ne le laisse penser certaines photos qui le présentent. La teinte n’épouse pas partout minutieusement les chanfreins. Je ne suis pas sûr qu’il soit de nature à se patiner, un fin cirage non teinté devrait lui donner plus de matière. Le mien se pose aussi sur l’arrête inférieure mais la tranche est franchement biseautée vers le haut laissant apparaitre plus visiblement le multiplis.
Une fois assemblé Il est très harmonieux et très stable et rend mieux que de nombreux concurrents plus chers. Du fait de sa profondeur, à réserver aux casques de salon, il est parfait pour mon Grado circumaural. Mes petits casques nomades font ridicules dessus.
Gonzalo B.
Gonzalo Bilbao
Dear Sirs,
Since two months ago I m waitign for my KHOZMO ACOUSTRIC but y ou week by week is delay de delivery. Do you have any real possiblility of dispacht it??
adrien n.
Fait le job, attention aux casques basse impédance et/ou très sensibles
Je ne comprends pas les critiques formulées à l'encontre de cet appareil. pour le prix la qualité de fabrication est irréprochable.
Avec un casque très sensible (Denon AH 7200 : 25 ohms ; 105dB/mW) et un gain de 0dB il est parfaitement utilisable, sauf si on écoute à très bas volume car alors on rencontre un problème de déséquilibre des canaux : c'est le seul vrai défaut de cet ampli.
A éviter donc pour les intras et les casques sensibles et/ou à basse impédance, qui ne nécessitent pas d'ampli casque de toute façon.
