Richard H.
Dayton Audio BST-300EX
précis et chaleureux
Eric v.
bonne prise
Avis clients - Il y a 19688 avis.
Arnim S.
FX-AUDIO D2160 MKII Amplificateur FDA Bluetooth 5.0 Class D TAS5614 2x100W 4 Ohm Noir FX-Audio revient avec un nouvel amplificateur Full Digital (FDA) : le D2160. Celui-ci fait directement suite à son grand frère, le FX-Audio D802C, en proposant...
A very interesting amplifier that does many things well.
I have spent several weeks listening to this amplifier.
I do not have experience with many high end amps. I have owned Adcom GFA-565s, Adcom GFA7607, and the class-D SMSL-98E.
This amplifier sounds drier, more accurate, more extended than any of these. However it is not my favorite.
It lacks the 'punch' of higher headroom amps. The bass tightens up considerably with a second power-supply, but then with my setup, it gets too tight.
Wondering what's going on, i decided to check the cable to the 36V power supply.
https://abload.de/img/61i9m.jpg
I'll not comment on this, not being an electrical engineer. But I will replace with my own power source and give results.
The haptics / usability of the amp is excellent. Simple, direct controls, one function per button. Very nice.
The Aux-In (analog-in) is much noisier than say, the SMSL-98E. Unusable for me.
Turning on the onboard EQ routes the audio through an analog stage, which is very interesting to compare with pure digital operation. I also found that with reduced treble and bass, the EQ'd audio is much more relaxing for long-term background-music listening. (Ears get tired with too much treble!)
It is an amazing sound, but I cannot say it is my favorite amp - i cannot help wondering what the Hypex units and more expensive pure-digital amps sound like.
Definitely not a party amplifier - this will not get them dancing. It is exceedingly interesting to experiment with 192khz though. I can hear differences to 48khz, which is downright scary.
Merci @ audiophonics.fr!
CHRISTIAN P.
Transformateur torique sur mesue
Il est aujourd'hui très difficile de trouver un fournisseur de transformateur qui puisse vous fournir du "sur mesure".
Transfo réalisé comme demandé. Parfait!!!
Le délai est certe un peu long, mais je le savais avant de passer commande. Trop satisfait.
patrick a.
itom 66
je viens de brancher cet USB en liaison ordi- dac
je suis sidéré par le rendu musical de ce cordon par rapport à son prix !
bravo…..
TOPPING DX3 Pro DAC 2x AK4493EQ XMOS XU208 32bit/768kHz Amplificateur casque Bluetooth aptX HD Noir Le DX3 Pro de chez Topping remplit à la fois les fonctions de DAC et d'amplificateur casque. S'il offre déjà d'excellents résultats une fois...
Tout petit et mieux qu'un grand
En vue de simplifier mon installation mais désirant rester dans la qualité, j'ai tenté en premier lieu le petit frère converto USB-RCA Topping D10 (à 85€, cherchez pas ailleurs !)
Juste un PC server, le D50, et amplification sans préampli. C'était parfait et simple.
J'ai très vite senti le besoin d'un volume autre que celui du PC, avec une télécommande, et un sélecteur d'entrées. Le Topping DX3 semblait satisfaire mes besoins :
Bluetooth (pratique pour ceux qui passent à la maison) - optique (pas testé) - USB (excellente) - Coax 1 et 2 (super pratique ça ! Top audio). Une alim extérieure (j'ai tenté alim de course sans meilleurs résultats).
Un défaut : il manque au DX3 une entrée ligne.
L'utilisation d'un unique bouton est en fait très pratique (on/off - volume - sélecteur d'entrées).
Télécommande très légère en plastique (j'aime bien lourd en alu massif, ben quoi !). Elle n'est pas couverte de boutons, juste l'essentiel et c'est bien !
Et maintenant l'écoute audio :
J'utilise mediacenter J.River et sa télécommande Android JRemote. Fichiers FLAC rippés via EAC. Je connais certains fichiers par coeur.
Brad Meldhau "exit for a film" : Piano présent, j'aime. J'attends la cymbale à rivets, c'est moins bien qu'avec mon Ayon CD3S, ça me rassure presque (6000€ vs 200€). Puis arrive la basse. C'est plus punchy mais dans mon cas c'est un plus (enceintes Martin Logan un peu molles).
Quelques écoutes de plus et je me dis que ce petit boitier à l'éclairage orange (je préfère bleu, ben quoi !) est sacrément performant. Très. Et pratique.
Le rapport qualité/prix est tout simplement ENORME.
Merci Audiophonics.
Jean Christophe C.
Très mécontent
Excellent produit, graves profonds.
Dommage que les stocks ne soient pas correctement tenus, car en cas de non disponibilité, les délais sont très longs.... Il faut compter deux mois.... Inadmissible.
Davide L.
Excellent tweeter
Je suis ravis du résultat des NEO CD 3.0, pour tout vous dire le rendement est supérieure au tweeters que j'ai sur mes colonnes B&W 683 s1, bien sur j'ai aussi créer mes filtre passe haut à 3500 hz avec les éléments de chez AUDIOPHONICS .
La livraison rapide et super bien emballez.
j’espère que mon prochain achat sera aussi nickel.
Davide LI PUMA
Sylvain H.
Bon produit lorsqu'il fonctionne
Un premier exemplaire défectueux m'a été envoyé. Suite a cela, un contact rapide et efficace du SAV Audiophonics a débouché sur l'envoi d'un deuxième hub, qui lui fonctionne parfaitement. Je remercie donc le SAV pour sa réactivité.
Maintenant qu'il est installé, ce hub est le complément idéal du pi zero !
Hafed S.
Ce câble est parfait, neutre, équilibré, timbre juste, grave tenu, j’ai mis mon ancien câbles à plusieurs xxx € au placard, après plusieurs test de câbles onéreux je me résous finalement que ce n’est pas forcément meilleur qu’un câble simple et des connecteurs bien fabriqué.
David G.
Mon avis ne vaut sans doute pas grand chose dans la mesure où c'est le premier ampli casque que j'achète, pour utiliser un akg 701. Je suis très satisfait du rendu de l'ensemble, notamment pour ce prix. La construction n'appelle aucune critique, c'est du solide. Reste à voir à l'usage sur différents types de musiques, mais j'ai écouté avec plaisir la Symphonie fantastique et du Desert Rock. Une interrogation toutefois : l' empli chauffe quand même pas mal. Est- ce normal ?
oui c'est normal de part la technologie utilisée.
Wybo W.
Great Sound
Now more than a week in use. Because I use a server with LMS, I chose Moods software because of the extensive setting possibilities.
The dac sounds great and the spdif input is a nice extra.
A power supply of at least 2 Amp is recommended.
The set is easy to assemble and has no defects. All in all, a great streamer.
Michaël K.
Objectivement, que du positif....!!!
Bluffant....!!!
J'ai choisi cette multiprise sur la base d'un budget , de différentes lectures et des avis publiés sur le site ! Mon système est un lecteur CD et ampli YAMAHA de la série 700 / connexion RCA Oehlbach 3900 silver express / enceintes FOCAL 726 V ! Mes éléments et les enceintes reposent sur des pads acoustiques VT Feet en PORON de chez Vahalla Technology ! j'utilise un câble HP de chez Viard Audio !
Après quelques heures d'écoute, que du positif ! Clarté, netteté, précision et détails musicales sont au rendez vous ! La musique est plus fluide, plus riche de détails, un peu plus brillante également !!! cette multiprise a révélé le haut & le bas médium des enceintes !!! les basses sont toujours bien présentes mais plus sèches par contre et moins rondes qu'auparavant !
J'ai un son plus aérien et plus spatiale ! les enceintes sont également moins directives ! une scène sonore plus profonde ! la grande surprise, c'est également à faible niveau sonore ! Bref, Je redécouvre mon système !
Bref, à recommander sans hésitation !
franc f.
cable usb
Parfait, conforme et reçu rapidement
Bernard S.
condos filtrage sur jcm marshall
commandés et vite reçus. composants qualité meilleurs que l'original.merci donc
bernard
Pas très solide
Assez déçu de la qualité ce ce boîtier, les tôles couvercles/fond sont relativement peu épais, et le bord se situant coté face avant se plie pour un rien. Il aurait dû y avoir deux renforts à ce niveau, un un décrochement sur la face avant (10mm) afin que ça puisse reposer dessus.
baptiste b.
ARYLIC A50 Amplificateur FDA STA326 WiFi DLNA AirPlay Bluetooth 2x80W 4 Ohm Le A50 de Arylic est un FDA aux nombreux atouts, portant notamment sur sa connectivité sans-fil et réseau très complète. Il permet donc de streamer...
très bien, mais pas d'arborescence des dossiers en USB
En utilisation depuis peu. Donc trop tôt.
Cependant cela semble très bien fonctionner.
La télécommande est un petit plus bien pratique.
Très bons conseils par mail. Expédié très rapidement.
Peut se connecter à de nombreux services.
Seul bémol. Du moins avec l'application Muzo.
Un souci avec la lecture des morceaux stockés sur un disque dur en USB.
Il n'est pas possible de parcourir les répertoires. Tout est en vrac.
Vraiment pas pratique.
Peut être une autre application permet de le faire correctement?
Cet appareil est également compatible avec la solution Ieast Play : https://play.google.com/store/apps/details?id=com.wifiaudio.iEastPlay&hl=fr
Jean Luc m.
En remplacement du câble d'origine sur un Audio gd dac 19.
Premières impressions,je constate un meilleur respect des timbres (moins de colorations),amélioration des silences entre les notes,écoute apaisée(aucunes agressivités),parfait sur système un peu dur ou agressif dans le registre médium.
Par contre, pas noté d'amélioration au niveau définition
et dynamique,sur ce dernier point j'ai même la sensation que ce câble et peu trop sage.
Ces impressions sont données après un temps d'écoute relativement court,après je suppose qu' avec le temps ce câble va encore s'améliorer,constat souvent relevé suite à
l'achat de matériel de qualité.
Un point positif sur la qualité de fabrication et la robustesse car à la prise en main on l’impression de pouvoir tracter un bus avec.
Un bon point à Audiophonics pour la réactivité,commande traitée rapidement et livrée idem.
Je voudrais féliciter Audiophonics d'exister car je ne connais pas de site de vente en ligne de matériel électronique ayant autant de choix,ou l'on trouve des produits
qu'il est difficile de se procurer sur le marché ,surtout de qualité audiophile.
Alfred M.
great product
really like this product and works perfectly; use it with an interface also bought with Audiophonics; stable supply of clean power by using a usb battery pack; Audiophonics keeps you well informed with the shipping progress and sent the items very quickly to Holland; all thumbs up!
un must !
encore meilleur que le 3103 , le 3104 , qui sont deja des références .
le 2972 a 4 files , il suffit en répétant bien les couleurs de jumeler a chaque extremités du câble les files deux par deux . vous obtiendrez ainsi les caractersiques techniques des plus grandes références du câble .
je l ai comparé a ses grands frères 3103 , 3104 , fantastique !
transparence , aération , timbres ...
a ce prix c est un cadeau des dieux .
samuel r.
excellent câble.
Utilisé avec satisfaction sur électronique, dac et cd. Excellent câble, légèrement fermé sur les hautes fréquences.
David m.
excellent casque
c'est un excellent casque intra. il n'est pas si neutre il a un chouia de basses en trop. mais en terme d'écoute il est parfait. par contre on voit bien que le cable du casque est fragile
David m.
il marche très bien
ce cable est très abordable et franchement il est parfait. pas besoin de se prendre la tête . j' ai viré mes cables pour ne garder que celui là
David m.
bon cable long
je l'utilise pour relier mon pc à mon dac pour les mesures.
fait son travail parfaitement.
David m.
marche très bien
le micro marche très bien, j'avais eu un souci avec un micro minidsp et j'ai pu changer pour celui çi. la gestion d'audiophonics a été parfaite.
David m.
efficace
acheté pour pouvoir écouter mon dac au casque.sans défaut et bien conçu.
Michel W.
Fiches HP
Pas chères mais efficaces et avantage pour un Breton l'oxydation ne sera pas un problème contrairement au cuivre pur. Merci à l'équipe Audiophonics comme à son habitude très efficace.
JEREMY H.
OK
Le transfo est livré sans notice et sans boite d'emballage. Seule la protection pour l'envoi est tout juste correcte ...
JEREMY H.
Module DAC AKM AK4497EQ I2S SPDIF 32Bit / 384kHz Régulateurs LT1963 Ce DAC vous permettra de lier tous vos lecteurs numériques à votre chaîne via l'interface digitale ou grâce à un module USB afin de soumettre un...
Je suis globalement satisfait par l'achat. 2 bémols néanmoins. Le DAC est livré sans notice et sans boite d'emballage. Seule la protection pour l'envoi est tout juste correct ... Surtout, les soudures entre la commande 3 boutons et l'écran de contrôle sont très fragiles : elles ont tenu à peine 2h ! j'ai du ressouder ! Dommage pour le prix et la qualité du DAC ...
Kurt W.
Toller Miniverstärker
Ich benutze den Miniverstärker für einen Auna Plattenspieler mit Denonboxen, der klang hat sich nun deutlich gegenüber dem eingebauten Verstärker verbesser, ich kann den D8 nur empfehlen satter ausgewogener Sound (natürlich ist es kein A1 Verstärker), perfekt fürkleine Projekte. Top
Dominique J.
Super petit appareil
Connection très rapide, l'aptx est bien présent et donne de bons résultats sonores associé au Fda Alientek D8.
Dominique J.
Un excellent petit ampli
Une connectique complète, un afficheur bien lisible, une bonne finition, un bon résultat sonore, un prix attractif, parfait; associé au SMSL B1 c'est encore mieux.
Francis F.
Utilisation double avec un X5s et un X7s
Pour le X5s le message sonore est plus posé et timbré qu'avec l'alim fournit avec le 'X5s.
Le cadeau est que cette alim peut également alimenté un X7s.
Yannick M.
matériaux
contrairement à ce qu'un avis affirme, je ne pense pas que ces connecteurs contiennent de rhodium.
Il est bien spécifié cuivre au beryllium plaqué argent.
https://fr.wikipedia.org/wiki/Bronze_au_béryllium
Franck S.
Utilisé pour compléter un câble optique qui passe dans un mur étroit pour une installation home cinéma. Facile à monter, bonne qualité d'enfichage du connecteur, bonne restitution du son.
Francis F.
AUNE X7S Amplificateur Casque Class A Sortie Variable / Symétrique Noir L'amplificateur casque en pure classe A Aune X7S à sortie symétrique est l'aboutissement d'une longue recherche après l'amplificateur casque nomade Aune B1...
Ampli casque et préampli X7s Aune
Je cherchais un ampli casque et un préampli pour mon système Hi-fi de qualité Hi Res.
Achat en aveugle car je n’ai pas trouvé de review pertinente sur ce X7s cependant il est en class A (espoir)
Je l’utilise en couple avec l’Aune X5s et l’alimention spécifique XP1 d’Aune sur laquelle il est possible de connecté les 2 appareils.
Partie casque, j’ai testé avec mon Sennheiser HD 25 C en jack, l’écoute est superbe bien au-dessus de toutes les possibilités des différents matériels émetteur que j’ai en ma disposition, préampli, S8+ ,PC , lecteur CD.
Image, stéréo, timbre avec beaucoup de chaleur et une sensation de puissance illimité, bien au-delà du supportable.
Test avec mon Sennheiser HD 650 en mode Jack, l’écoute est également superbe avec en plus des détails dans le grave et l’infra. Je le trouve du coup un peu trop chaleureux, mais très agréable. Puissance énorme et largement suffisante
Je branche mon cordon symétrique en XLR 4 pôles sur le HD 650. Alors là, je suis dans un autre monde. Une dynamique terrible, un spectre audible très large, cette chaleur excessive gênante moins importante remplacé par des nuances et timbre de grave jamais entendu, vraiment les peaux des instruments est très « lisible » avec fidélité. Je change la SD de mon X5s pour passer des morceaux en 48/24 et 96/24 de Qobus. Et là le bonheur, Je crois que c’est ça de la Hi Res, Ouah des détails, de la stéréo, du timbre incroyable, une image large et profonde, un aigu très détaillé et doux. Je cherche des morceaux très bien enregistré de grande musique avec orchestre pour vérifier le placement dans l’image ; c’est tout simplement génial. Restitution du positionnement des groupes d’instruments dans l’orchestre. Pour moi c’est une découverte.
En mode préampli c’est également tout nouveau, le X7s branché sur mon ampli Grand Mos j’obtiens une image superbe large, profonde. Je redécouvre mes enceintes Davis et la qualité des HP et leur dynamisme. Je continu à tester le positionnement de l’orchestre. Je suis épaté par le grain des violoncelles …. « Cela prend aux tripes »
Le couple X5S + X7S avec le XP1 soit sur casque ou en chainon dans un système Hi-Fi en Hi-Res haute définition ressemble aux écoutes vinyle master de ma jeunesse dans les salons Hi-Fi. Je valide mon achat et je vais passer de grande bonne heure de plaisir.
Une tres belle construction ! J'ai testé également le cable entre les 2 chainons Aune il faut une bonne qualité.
J-C- P.
Fortement déçu
Belle conception au demeurant mais le matériau utilisé pour accueillir les vis à Allen est trop malléable et ne permet pas un serrage convenable avec un câble en fil de Litz de 4 mm2. Le taraudage a tendance à céder malgré un serrage modéré. Résultat, une des deux vis tourne dorénavant dans le vide ..... Par conséquent, une utilisation à conseiller uniquement avec un câble en multibrins, monobrin et fil de Litz à éviter totalement.
Rafal B.
Transformateur Torique 100VA 2x15V 3.3A Ce transformateur torique de haute qualité délivre une puissance de 100VA 2x15V 3.3A et sera un choix idéal notamment pour la réalisation de vos...
Great quality
It was my second transformer from Audiophonics and again, great quality built and also sounds absolutely amazing in my DAC. In comparison of other two this one sounds most analog with full and reach sound. Highly recommend. Idle voltage a bit to high, 15V measured 17.2V but it's only minor thing.
RESTITUTION DE HAUT NIVEAU...
Ce petit FDA est un champion, sans le moindre doute! La restitution ne prête le flanc à aucune réelle critique: la définition, les timbres et la dynamique sont excellents. Embarquant la même puce STA326 de ST Micro que le FX audio D802, il est possible d'alimenter l'Alientek avec du 32 V au lieu du 28 V fourni par l'alim d'origine. La restitution gagne légèrement en définition (remarquables transitoires du piano!) et en image stéréo (un peu plus profonde), par contre on y perd légèrement en douceur; question de goût personnel, chacun fera son choix. On appréciera la sortie casque qui peut, bien évidemment, se déconnecter des enceintes; une sortie très correcte qui fera vivre sans soucis les casques de milieu de gamme. Un ampli qui remplace avantageusement les gros équipements analogiques coûteux, encombrants et énergivores. Reste une grande inconnue: la fiabilité.
Lars J.
Poor build quality
Bad quality soldering, and uneven mounting of heatsinks. Had to resolder the whole board.
Bonne finition
Un produit très agréable à utiliser , finition de qualité , et la sonorité est bonne .
Frederic H.
En remplacement iFi Power 5V
Acheté pour remplacer une alimentation iFi Power 5V (Rasp+Allo DigiOne), je dois avouer ne remarquer aucune différence notable sur le son. Mais au moins il y a un interrupteur ! Et quand j'utilise cette alim sur un autre Rasp. + OSMC + DD externe, il y a l'ampérage nécessaire et je n'ai plus ce petit éclair clignotant dans le coin de l'écran.... Bref, content :-)
Gregory T.
Fusible ampli
Erreur de frappe de ma part pour du lent (F) mais fonctionne pareil même si pas en tube transparent à voir sinon j'en recommanderai merci .
Gregory T.
DAYTON AUDIO DC200-8 Classic Haut-Parleur de Grave 60W 8 Ohm 87dB 29Hz - 3000Hz Ø20.5cm Le Haut Parleur DC200-8 8 Pouces de chez Dayton Audio propose un rapports qualité/prix très intéressant dans sa gamme. Il est pensé pour offrir de bonnes performances tout en...
Bose 301 s 1
En attendant une réparation à l'originale actuellement en rodage avec un mistral lfd déjà très bien ! Pas livraison super rapide merci!
Gerard T.
AOP HDAM
Il serait bien d 'indiquer le sens de branchement .
pas une seule indication sur le circuit .
Le sens de l'AOP est visible via la sérigraphie blanche sur le PCB horizontal.
Arnaud D.
AUDIOPHONICS CANARE Câble numérique Coaxial 75 Ohm RCA-RCA Gainé 1m Voici notre câble numérique coaxial Audiophonics Canare en version 75Ω. Sa particularité est de comporter des connecteurs Canare C5F, certifiés 75Ω et un câble Canare L-5CFB.
Excellente rapport qualité prix!!
Commandé le lundi matin, livré à Versailles le mercredi matin!
4 euros de plus que son petit frère Canare.
Même câble L-5CFB, même connecteurs C5F, avec en plus une gaine isolante posée par Audiophonics.
Le résultat est étonnant:
Plus de finesse dans l’aiguë, plus de présence dans le médium, des graves mieux contenus. Une scène plus claire!
Comme quoi à ce niveau de qualité (AGD M1, AGD M3, Dac Naim, lecteur SoTM, Enceintes cabasse Galion3), chaque composant compte.
Rapport résultat prix au top!
Sans hésitation.
Sacit T.
Thanks for quick shipment
Marcella B.
AUDIOPHONICS U-Sabre USB DAC 24Bit/96kHz SA9023 / ES9023 OTG V2.2E TCXO Edition
très bien, améliore la qualité du son de façon significative
Bon rapport qualité/prix, expédition rapide
claude s.
incroyable " boite d'allumete"
audiophile depuis les années folle 70/90 de la hifi ? ou il fallait des amplis
hors de prix pour être satisfait comme QUAD, - HIRAGA -etc.etc. d'un poids de 10 kgr. de composants électronique et d'un prix qui correspondais avec. le poids .
j'ai fait l'achat de ce minuscule FX AUDIO D802 par curiosité et son prix
car je n'y croyais pas ; et "plaf " une grande claque ! en écoutant mes vieilles enceintes QUAD et JEAN MARIE RENEAU sur source iMac .c'est de la hifi cinq étoiles ! bravo a fxaudio et audiophonics de nous faire partager ce plaisir
ps. petit bémol a la réception l'alimentation était hs , le sav rapide et accueillant a remédié dans les 48 heures au changement. bravo. merci
Roland S.
pour audio télé philips
Génial, associé à l'ampli FX AUDIO M160E et l'extracteur HDMI ARC vers RCA model CYP DCT-25 avec deux enceintes bibliothèque CABASSE ANTIGUA 220, pas besoin d'investir dans un système barre de son à 500 ou 600 Euros.
RS
Sébastien L.
pour raccorder un DAC (ou tout autre carte hat) sur un Raspberry Pi sans pour autant devoir recouvrir le Pi avec la carte.
DENIS D.
charmeur
ce smsl est un charmeur il fait le job et le fait bien mais pour ma part ne remplace un bon ampli conventionnel, tester sur plusieurs enceintes ……….kef q 300 highland 3205 elipson prestige 4 pioneer cs / hpm il s en sort plutôt bien mais manque un peu de vie , de chaleur , ideal pour un premier système le rqp est imbattable pour les budget serré mais je ne pense pas qu il puisse remplacer un bon ampli hifi a 1000€ comme souvent lu ,déjà que mon technics suv 550 le laisse loin derriere mon pioneer sa 708 l enterre définitivement et Yamaha rxa2030 ( HC ) le remet dans sa boite !!! ca n est que mon modeste avis pour resumer faite des comparaisons mais a 130 € cela reste une bonne affaire
