Jean-Claude F.
Très bon câble HP
Acheté en remplacement d'un câble Mogami 3103 pour bénéficier du bi-câblage. Ce sont les mêmes conducteurs donc j'ai...
Jean-Claude F.
Très bien
Contrepointes de bonne qualité pour un prix raisonable
Yvain C.
Mes fostex fe 208ez ce sont mises à bouger instantanément après l’installation du câble, des gravés en plus .
J’ai hâte de la...
DAYTON AUDIO DATS LA Analyseur de Haut-Parleur - avis - Il y a 2 avis.
Ralph G.
Browse the web for existing issues
The product works as expected, however expect noisy output (likely doesn't affect results) and expect offset (which may affect results in very softly suspended speakers). Looking forward to a fix, hopefully w/o having to send-in the unit
Andrzej J.
Fast and accurate measurement
Good user manual. Easy measurement process. Software controls the entire process. Measurement results are available in a file, allowing for further processing in other programs. The device itself is well-made. The only minor issue is the power cable with an American plug. But since it's a standard PC cable, you're sure to find one at home.
Le Dayton Audio DATS LA (Digital Audio Test System Loudspeaker Analyzer) révolutionne la mesure des haut-parleurs par sa...
