mickael C.
Une des meilleures prises
mickael C.
Michel P.
Michel P
Avis clients - Il y a 19367 avis.
Eimantas S.
Excellent product
Nice product, quick delivery time. All service excellent, as always with Audiophonics. Thanks.
Vladimir p.
GENALEX GOLD LION KT88 Tubes Platinum (Paire Appairée) Les tubes Genalex Gold Lion KT88 sont des tétrodes à faisceau octal de très grande qualité. Ces modèles profitent d'une excellente fabrication...
Gold Lion KT88 - simply the best
At last time has come to check GL KT88 in my Muzi x7. Amp had very good sound with original chinese KT88, even better sound was when I started to use Mullard KT66 new, I even could not understand how sound could improve with another KT88. But when yesterday I put in GL KT88, I was really surprised - all good things of Mullard has remained but all started sounding somewhat more "delicate", with more finesse, all became more "musical"... Now I have three different but all very good KT88s which I will use with different rectifiers (to get slightly different but very good sound).
Thnx to audioph.fr for all this.
Vladimir p.
MULLARD KT88 Tube Tétrode (Unité) Le Mullard KT88 est un tube tétrode de première qualité. Il s'agit de la copie exacte du tube fabriqué par Marconi-Osram pour Marshall à la...
Mullard KT88 recomended
Got my Mullard KT88 as usual with no any problems, thnx.
Straight from the box a BIG positive changes compared to original chinese KT88 (Muzi x7). Soundstage is enormous, separation and instruments placing is exactly what I love about good quality sound. After about 80-90h sound became even better (as it usually happens on the lines of the the first impression).
Very satisfied with everthing, thnx again to audioph.fr
Christian M.
Filtre Jack DC 12V 3F à Supercondensateurs vers jack DC Ce filtre jack DC 12V à supercondensateur vous permet d'obtenir une alimentation propre pour vos équipements et appareils Hi-Fi grâce à 5...
Une fois branchée entre un Switch Meraki tweaké et une alim linéaire, impossible de l'enlever....c'est plus clair, plus détouré....le gain le plus significatif est sur la lisibilité du grave....fortement recommandé !
marco p.
terrible pour un assemblage DIY
Le bricolage est compliqué avec ceux-là, la rondelle isolante possède un élément gênant, il faut l'enlever avec un cutter ! Sinon la douille PVC ne peut pas rentrer dans le trou, c'est dommage que ce ne soit pas précisé dans le descriptif !
Monter sur du ramm Amadeus c'est fiches sont totalement neutre
pascal r.
UN OVNI !
SIMPLE IS BEAUTIFULL
Marc Andre C.
NICHICON KZ MUSE Condensateur Audio Audiophile 100V 47µF Les condensateurs de la gamme KZ Muse peuvent notamment être utilisés pour le traitement de signaux audio dans des appareils nécessitant la meilleure...
Good...!!!
Marc Andre C.
NICHICON KW Condensateur Électrolytique Audio 50V 470µF La série KW est une gamme de condensateurs électrolytiques spécialement conçues pour une utilisation audio. Ils offrent en effet d'excellentes...
Good..!!!
Marc Andre C.
NICHICON KW Condensateur Électrolytique Audio 50V 1000µF La série KW est une gamme de condensateurs électrolytiques spécialement conçues pour une utilisation audio. Ils offrent en effet d'excellentes...
Good...!!!
Marc Andre C.
Module Softstart de Commande / Temporisation et Protection pour Amplificateur Ce module permet de commander l'allumage d'un amplificateur. Il dispose d'une fonction standby, sotf-start, de temporatisation et de protection thermique. Il limite l'appel de...
Parfait...Le module fait son job.
Marc Andre C.
Parfait. Au TOP !!!
Marc Andre C.
Article correspondant à mon besoin, mais des composants avait souffert du transport...Pas de souci à ce niveau car j'ai pu les remplacer [ 100n / 200µ pattes cassées ]
Martins R.
XANGSANE XS-DIY1 Fil Argent Pur 99.99% FEP 0.08mm² Ø0.62mm Ce fil de câblage Xangsane XS-DIY1 profite d'une conception high-end, utilisant comme matériau conducteur de l'argent pur à 99.99%. Il assure ainsi une...
Perfect headphone cable
This is a perfect cable for headphones eith just a bit of stiffness and microphonics. The sound quality though makes up for it completely. Best cable have ever heard for a headphone..
Martins R.
XANGSANE XS-DIY1 Fil Argent Pur 99.99% FEP Ø0.8mm Ce fil de câblage Xangsane XS-DIY1 profite d'une conception high-end, utilisant comme matériau conducteur de l'argent pur à 99.99%. Il assure ainsi une...
Perfect internal cable
Perfect for speaker internal externel wirering stiff
Martins R.
Awesome quality
Perfect silver cable for internal wires and speaker internal and external wirering. Sublime sound quality, astonishing quality of finish. Phenomenal performance for price, unbeatable bang for buck. Can not use for headphones to thick and stiff. Use the one doqn for headphones.
Martins R.
MUNDORF MCONNECT SGW105W Câble Argent/Or Isolé PTFE 0.5mm Blanc Ce câble Mundorf MConnect SGW105W vendu au mètre assure une excellente transmission du signal grâce à sa composition à base d'Argent...
Best cable period
Simply put this is the best signla wire one could ever want, quite a nice step up from silver. With a lot more texture and clarity. Pretty stiff though, for using in internal wires works great, could not use this thicknes for a headphone cabl3
Martins R.
ATAUDIO AT-0T Connecteur Jack 6.35mm TRS Plaqué Or Ø8mm Rouge Ce connecteur ATAudio AT-0T au format Jack 6.35mm TRS profite d'une belle qualité de conception, assurant à la fois performances et durabilité. Il se...
Fantastic quality
Very good quality 6.35mm jack. Gold plated contacs and solder tags. Easy to work with.
Martins R.
ATAUDIO AT-X10 Connecteur Jack 3.5mm TRS Plaqué Or Ø6mm Bleu Ce connecteur ATAudio AT-X10 au format Jack 3.5mm TRS profite d'une belle qualité de conception, assurant à la fois performances et durabilité. Il se...
Fantastic quality
Perfect 3.5mm jack for line in cables and desktop use. For hp cables and portable use a bit to thick. Super easy to solder and work with.
pascal P.
Excellent en liaison phono. Il enterre les câbles spécialisés renommés. Ce n'est peut-être pas pour rien que le gourou japonais Kadena l'utilise en phono...
Piotr K.
Neotech silver
Bought this out of curiosity to check how good it can be against established brands. I have build this Nei-2001 with Aeco silver plated XLR"s . I'm amazed how god it sounds. It's still new so it only get's better with burn in. It seems to be very detailed and articulate, air around instruments is very nice. Sound seems to be denser more defined and most importantly very! engaging.. I like it a lot ,it's way better than my previous reference XlLR (which was for years nordost quatro fil )
Didier T.
Une valeur sûre pour mélomanes, sans se ruiner
Utilisateur de Titanex 3G2.5 (sur recommandation de FIRODIL) de longue date, celui-ci propose des résultats assez chaleureux et articulés pour un prix dérisoire.
S'il n'est pas du genre à donner envie de couper les décibels en 4 ni à se pâmer "audiophilement" devant son grave, son medium ou son aigue, la cohérence mélomane qu'il procure est tout bonnement exemplaire à ce prix.
On pourra toujours pinailler ici sur plus d'aération ou là sur moins de coquetterie dans la charnière haut medium/aigüe, mais je le suspecte d'être sacrément plus homogène, plein et naturel que nombre de câbles dédiés à l'audio qui fleurissent ça et là y compris à des tarifs sensiblement supérieurs.
Et compte-tenu du sérieux d'Audiophonics, s'ils le propose, c'est qu'il y bel et bien une raison...
Bref, troquer les câbles basiques d'origine par ce Titanex 2G2.5 ne se discute pas...
Juan M.
AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Noir Le X8 XVIII BT Magic DAC de Aune est une édition spéciale du DAC, à l'occasion du 18ème anniversaire de la marque. Celui-ci reprend notamment...
DAC with sparkos ss2590
This dac for the price is wonderful, I bought it and directly installed the operational sparkos SS2590 Pro. The sound is simply perfect, I couldn't imagine it better. Airy, clear, musical, with an impressive dynamics. I recommend 100% the update with SS2590 Pro. Warning, you need to buy a small elevalor for the chip, otherwise it touches the case, and then put some higher feet.
Gonçalo P.
MOGAMI NEGLEX W2549, That's OK
Regarding the item purchased, the material is what was expected. Regarding shipping, it should be noted that the shipping carrier provided a service well below average, with a day delay compared to what they themselves sent as alert. I strongly advise you to change your shipping service
3E AUDIO 480-1-29A PFFB Module Amplificateur Mono Class D Symétrique TPA3255 1x480W 2 Ohm Ce module amplificateur 3E Audio 480-1-29A est un module d'amplification mono class D symétrique basé sur une puce TI TPA3255. Ce module...
Excellent, 3 fois deux !
une paire de blocs mono réalisée avec ces modules: résultat magnifque , très musical . encore meilleur que le module stéréo (déjà excellent) du même fabricant. c'est peu dire!
adrien n.
AUDIOPHONICS TPA-S120 Amplificateur 2.1 Class D 2x TPA3255 Bluetooth 5.0 QCC5125 2x120W + 1x240W 4 Ohm Noir Le Audiophonics TPA-S120 est un amplificateur Class D capable de fournir une puissance confortable et une restitution sonore riche, le tout à prix contenu. Au cœur...
Super ampli
Au niveau son, rien à dire, il fait le job pour une utilisation streaming à partir d'un PC (Tidal, chaînes TV sur internet...). La puissance est suffisante pour mes petites enveintes colonne Triangle.
Mais ce qui est bluffant avec cet appareil c'est sa simplicité d'utilisation. En deux temps trois mouvement tout fonctionne, notamment l'appariement bluetooth avec tablettes et baladeurs. Par comparaison j'ai acheté un Wiim amp qui a un très bon son également mais qui m'a causé des maux de tête tant l'application est compliquée à utiliser.
Pareil au niveau design, c'est hyper sobre et ergonomique. Adieu la brique d'alimentation à découpage, le DAC séparé... On pose sur le bureau, on branche et c'est ti-par !
J'ai relevé deux petites imperfections qu'on lui pardonne volontiers : 1) il semble impossible d'éteindre l'éclairage (très puissant, et blanc contrairement à la photo 2) l'entrée USB marche mais il faut sélectionner l'entrée BT au lieu de US.
Au final, super appareil, je ne regrette pas du tout cet achat, bravo à l'atelier Audiophonics qui est compétitif par rapport aux marques chinoises. On attend les mesures sur Audio Science Reviews avec impatience !
SERGE B.
Mal concue
Cette prise Schuko est très mal conçue. Il n'y a en effet que très peu de place pour faire passer les fils à coté de l'emplacement de la vis centrale. Ne peut à la rigueur convenir que pour du câble de faible diamètre. Par ailleurs, la fixation du fil de terre est très mal fait.
A éviter
LHY AUDIO LPS25VA Alimentation Linéaire Régulée Faible Bruit 220V vers 12V 1A 25VA Voici une alimentation linéaire régulée et stable pour tout projet DIY audiophile de haute qualité. Tous les raffinements techniques...
super génial
Produit top la classe qualité sonore l'image incroyable vue rapport qualité prix rien à dire compatible sfr zeop orange
netflix 5 étoile bon matos 2024 merci
Philippe E.
EVERSOLO BTR-12 Télécommande IR / Bluetooth pour DMP-A6 / DMP-A6 Master / DMP-A6 Gen 2 / DMP-A6 Master Gen 2 Cette télécommande IR / Bluetooth BTR-12 proposée par Eversolo a pour vocation d'être appairée à tous leurs appareils de la gamme DMP,...
La télécommande BTR-12 est très fonctionnelle, elle permet de ne pas être connecté en permanence sur son mobile pour tout faire dans l'utilisation du DMP-A6. Au passage, ce lecteur réseau est également excellent et possède plusieurs réglages qui optimisent encore la retranscription de la musique.
SERGE B.
Très bons embouts à sertir pour protéger les extémités de fils ou câbles de cuivre
SERGE B.
Excellente qualité
Chers mais d'excellente qualité pour protéger les embouts de câbles de qualité.
SERGE B.
Excellente qualité
Bien finis et très utiles pour protéger les embouts de câbles.
SERGE B.
Fourche Cuivre Plaqué Or 24k Ø4mm (Unité) Cette fourche robuste est faite de cuivre et est plaquée or 24k, ce qui lui permet une forte conductivité et une résistance à la...
Très bonnes fourches en cuivre OFC 4N comme il se doit et plaquées or. La longueur du corps est suffisante et le système de serrage du câble à deux vis est parfait. Je sertis les extrémités des câbles avec des cosses en cuivre plaquées or également ce qui facilite leur introduction et évite de casser des fils.
Inutile de payer plus cher à moins d'avoir du câble plus gros.
SERGE B.
Excellente qualité
Excellentes fourches assez épaisses en cuivre OFC 4N comme il ses doit et plaquées or. La longueur du corps est suffisa systèmede
Michael L.
O-NOORUS PA-316 Amplificateur Class D 2x TPA3116D2 Bluetooth 5.0 2x60W 4 Ohm Ce petit amplificateur Class D O-Noorus PA-316, compact, polyvalent et performant, intègre deux puces d'amplification TI TPA3116D2, chacune dédiée à...
Not perfect but good for the low price
My pa-316 just arrived
long press volume to turn it on,off short input selection (no aut bt) no pop sound turning it on,off
loose volume knob, like a steering wheel that only make the car turn after half an inch (hate it)
tone controls off neutral sound, clean sound even at max volume, above 12 o'clcok if you want it loud (volume better on a Fosi audio bt 20a), the difference on the volume from 12 o'clock to max is to big or not big enough how you interprest it (medium to loud from 12 to 2 o'clock) + a good bass
Gets varm playing loud (not alarming), a Fosi Audi bt20a don't get warm, 24v 6.75 psu instead of 24volt 4.5 a as some amps has
Usb works but no driver to change samplerate and to se what samplerate is used
Pierre-Marin L.
Je vais continuer la litanie des gens satisfaits : ce cable remplace un cable I2S couteux, et sur mon Holo Red vers mon Holo Spring le résultat est bien meilleur ! Pour un prix avantageux
Merci Audiophonics !
Deividas S.
Stéphane M.
2ème commande de ce produit magique
Tellement efficace et pas cher pour un nouvel usage et encore un exploit un terme d'efficacité tout comme Audiophonics ! commandé et réceptionné en 5 jours malgré un jour férié vers l'île de la Réunion. Un site vendeur exceptionnel.
voir ici le changement que produit ces isolants sur ma barre ambeo plus et Q Acoustics 3060s (remarquez la finesse de 1khz à 20khz) gain en clarté et spatialisation : https://i.postimg.cc/hP9rNS8M/Effet-sorbothane.jpg
bon rqp
Solide pas de perte audible prix correct.
Câble Jack 6.35mm Mâle vers Jack 6.35mm Mâle Stéréo Blindé Plaqué Or 2m Ce câble double Jack 6.35mm stéréo propose un cœur en cuivre pur pour une conductivité maximale. Ce dernier est blindé par une feuille en...
bon rqp
Aucune perte audible prix correct
DAYTON AUDIO PS95-8 Haut-Parleur Large Bande 10W 8 Ohm 86dB 110Hz-20kHz Ø9cm Le Dayton Audio PS95-8 est un haut-parleur large bande de la gamme Point Source de la marque. Il est doté d'un cône incurvé en...
Parfait, mis dans une sphère imprimée en 3D, excellent résultat audio.
Neutre
Très bon RQP.
Sebastien S.
La musique prend de la vie avec ce DAC
J'ai remplacer mon intégré Cyrus 8 qui ne donne plus de dynamisme , ce préamp Dac redonne la vie à la musique, sur un ampli vintage DENON PMA 501 double transfo. J'ai connecté un lecteur CD mais cela ne fonctionne pas, faut-il un lecteur transport uniquement ? Merci pour votre réponse.
Eric D.
SMSL DL200 DAC ES9039Q2M Amplificateur Casque XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Le DAC SMSL DL200 est un DAC hautes performances intégrant des composants de qualité tels qu'une puce ES9039Q2M, une interface USB XMOS...
Enfin satisfait
J’ai acheté ce dac ampli casque pour pouvoir exploiter min recent achat d’un casque moondrop para sur ce même site. Ce dernier sous 08ohms manquait cruellement de volume connecté à mon littledot mk2.
Aujourd’hui, totale satisfaction la puissance 3watts sous 16 ohms est parfaite pour mon casque.
Je découvre le dac et envisage un abonnement pour exploiter ses capacités au delà du mp3 et aac.
Merci à audiophonics pour l’expédition rapide et l’emballage serieux.
Benoit d.
Bornier Encastré Isolé pour Bi-Câblage Enceintes 95x75mm Ces borniers pour enceintes disposent de connecteurs à visser, acceptant également les fiches bananes (4mm). Le diamètre de perçage est de 95x75mm.
Bien mais petit défaut
Conforme et bien construit. Les barettes de connexions pour bicablage sont simple a démonter. Mais pour mon usage il y a un défaut : les borniers dépassent du cadre même vissés complètement alors que je voulais qu'ils soint protégés pour le transport de l'enceinte.
Benoit d.
Nettoie parfaitement le bruit parasite qui venait de la connections de 2 amplis sur une même source
bernard g.
pince très fine passe partout parfait
bernard g.
CWS1 Pince 3 en 1 pour Couper / Dénuder / Sertir Cette pince 3 en 1 CWS1  se dote de 3 fonctions. En effet elle vous permettra de couper, dénuder et sertir des câbles.
trés bonne pince
bernard g.
collier parfait pour travaux délicat
bernard g.
ATAUDIO SNOW SLEEK Câble de Modulation Symétrique Cuivre OCC Plaqué Argent Ø8mm Ce câble de modulation symétrique vendu au mètre se compose de 12 fils en cuivre OCC plaqué argent et isolés individuellement à l'aide...
cable secteur
une fois assemblé les 3 cables et les connecteurs krell de très bonne qualité après un essai le résultat est surprenant avec une section de 6mm2 les cables sont croisés ensemble
le cable secteur est entre la prise murale plaqué rodium et les barrettes shuko la musique a gagné en dynamique et est très bonne surtout avec une riche de détaille des basses très naturelle et des aigus limpide et des médium incroyable
attention tous a été optimisé les cables secteur sont tous de hautes qualités ampli casque a tube casque éléctrostatique haut de gamme et lecteur cd haute qualité fiches xlr haute qualité musicalement ce cable est le meilleur que j ai bernard
