Thierry W.
Avis clients - Il y a 19594 avis.
Pedro B.
GUSTARD DAC-R26 DAC R2R Discret I2S Bluetooth LAN AirPlay Roon DLNA 32bit 768kHz DSD512 MQA Argent Gustard dévoile avec son DAC-R26 un convertisseur numérique / analogique absolument exceptionnel. Celui-ci utilise une architecture R2R utilisant des composants...
An amazing DAC with a truly sense of presence and naturalness!
Nowadays DACs play an import role in a system, as the new formats like HD PCM, DSD, MQA and streaming services become available. While every other component can stay steady, the DACs are quickly evolving. For a couple of years, almost 15, I’ve have been keeping the Krell CD player, the Krell amplifier, the B&W floor stand speakers, the Rega turntable and Vincent phono preamp, only replacing the music player (streamer) and the DAC. So, I had some DACs from Cambridge Audio, NuForce/NuPrime, Gustard (X16) and Mytek. All different and each with their strengths and weaknesses. With R26 I’ve found a very nice balance for sound stage, detail, transparency, and pace, but the biggest difference is a truly sense of presence and naturalness which is amazing (the stage sound is so large that you may have to rotate speakers in to the listener position to have a better center image for voice). Using a music streamer based on Rasperry Pi 4 connect via USB 2.0 port, everything works fine too (current R26 firmware version is 1.4), without any issues (from Spotify, TIDAL, Youtube and local music database based on a NAS). The built-in streamer works very well, decoding all formats easily. Tried 2 configurations: 1st With Roon installed on a Synology DS220+ NAS (Intel CPU required) with a local library of music files and everything worked fine too. 2nd using R26 used as a UPnP renderer via mconnect Player Lite, but some improvement is required for this as, occasionally, the first time a DSD file is loaded from the NAS (using DLNA), there are some halts (these files are huge in size). Had 2nd thoughts about the A26 model, also a very praised DAC by critical listeners and reviewers, but there is something in the high processed audio signals from Delta-sigma DACs that make long listening’s easy tiring. In summary R26 is very musical DAC giving great sense of realism, excelling in bringing the emotion of live recorded music. For listening the best results are obtained in Non-Oversampling mode (NOS ON). Last a praise to Audiophonics which sent the equipment fast and very well protect.
Jean-pierre L.
HOLO AUDIO SPRING 3 LEVEL 2 DAC R2R Symétrique 32bit 1536kHz DSD1024 Holo Audio dévoile avec le Spring 3 un magnifique DAC R2R basé sur des composants discrets. Conçu sur mesure, il avance d'incroyables...
Juste sublime
Je suis très très heureux de cet achat ! Enfin j’écoute toute la musique numérique avec un plaisir immense. Tout prend vie avec ampleur, force, details et dans une musicalité que je n’imaginais même pas. Moi qui voulais changer d’ampli…..en fait il fait super bien le job ! Il lui manquait le HOLO SPRING 3 ! Une vraie réussite technologique au service du plaisir musical
Jeanphilippe c.
Smsl Ad 18
Très bon amplificateur. Je l’achète pour alimenter mes kenwood vintage de 75watts en 3 voies. Dommage quel alimentation réguler sois si cher. Ça serait l’idéal pour remplacer celui d’origine. Je recommande.
Davor F.
NEOTECH STDCT-16 Fil de Câblage MultiBrins UP-OCC PTFE 1.3mm² Le fil de câblage STDCT est un câble de très grande qualité multi-brins avec conducteur en Cuivre UP-OCC pur à 99.99998% et isolation PTFE....
Neotech,great upgrade wire
Terrific wire,what i got with this wire when i changed internal wiring of my speaker is more transparency in a sense of better detail openess,stage is more holographic and separation of instruments are in general better then before.I used 1.3mm for a tweeter and combination of 1.3 and 0.8mm for bass unit plus same for connecting crossover to terminals.Thanks Audiophonics for having this wire in youre collection for us to find how simple things can change our hobby for the better.
Roberto A.
TOPPING RACK Support HiFi Aluminium Acrylique pour PA3 / MX3 / VX3 / D30 / A30 Le Rack est un petit support HiFi proposé par Topping, afin d'y installer vos appareils HiFi et notamment les Topping PA3, MX3, VX3, D30, A30.
great little rack
exactly what i needed, sturdy quality and fits my topping devices perfectly
Philip K.
AMANERO COMBO384SE Interface digitale USB 384kHz / SPDIF WM8804 vers I2S / DSD Version Combo384SE intègrant également une interface S/PDIF WM8804 bidirectionnelle qui pourra fonctionner comme entrée ou comme sortie selon les besoins de votre projet.
Works fine
It works fine and is easy to install. Delivery was fast and my DIY DAC is now capable to get USB input. Perfect.
Philip K.
Module Ladder DAC R2R NOS Symétrique 24bit 384kHz Ce module Ladder DAC offre une conception de très haute qualité, avec un étage de conversion R2R, utilisant un CPLD Altera MAX II par canal, associés...
Good but too expensive
I bought the module at Audiophonics, because I thought the same on Ebay is may be a cheap china fake. But it's the same module! At Audiophonics the Company Logo is removed from the product photos. But on the delivered module it is printed the same way as the one on Ebay/from China. On Audiophonics it is 100€ more than ebay... The sound is great and the manufacturing quality is good. So it's your choice how much you would like to pay. But I think on Audiophonics the price is too high. I am disappointed the the same module is round about 62% offered more expensive on Audiophonics.
Nicolas T.
Excellent rapport qualité/prix !
Câble couplé à des fiches bananes PANGEA Xtreme qui reçoivent parfaitement la section de 6mm2 ! Bien que l’écoute d’un câble soit très subjective et fortement dépendante du système sur lequel il est raccordé, je peux confirmer que les graves sont propres et bien tendus, les médiums sont fluides et le haut du spectre est précis et bien défini… Pas de son projeté ni agressif ! L’image stéréo est large, stable et précise ! Ce câble nécessite cependant une bonne cinquantaine d’heures de rodage pour se faire totalement oubliés… N’est-ce pas là au fond le but d’un câble ?! Se comporter comme s’il n’existait pas ?! Un très intéressant mariage ! PS : Pensez bien à raccorder les câbles avec les spires torsadées dans le même sens…
Nicolas T.
Presque parfait !
Excellentes fiches bananes à visser ou à souder ! Pas de souci avec les vis qui mêmes serrées très fortement ne cassent pas… Les pas de vis sont également très résistants ! Si ces fiches bananes étaient livrées avec de la gaine thermo rétractable, cela serait parfait ! De plus, le contact entre fiche banane et embase est parfait et très bien étudié ! À recommander à 100% !
Alex Z.
Module Contrôle de Volume Motorisé 50K Ce module de contrôle de volume très pratique est équipé d'un potentiomètre motorisé 50K, ainsi que d'une LED de réception IR....
Easy to use,compact,logarithmic pot,works great. Fast delivery.
Simon R.
LINDY CROMO LINE Câble Numérique Coaxial SPDIF Cuivre Plaqué Or 0.5m Le câble SPDIF Coaxial Lindy Cromo Line profite d'une belle qualité de conception. Ses conducteurs sont faits de Cuivre assurant une très bonne...
LINDY CROMO LINE SPDIF
The cable works fine. Yes, the cable is very thin, but since the line is very short, the thickness of the conductor hardly plays a role. In any case, no audible difference to my multi-shielded cables that I usually use in my high-quality setup. For my purpose of use in a mobile system, I consider the high flexibility of the cable rather an advantage. The plugs also fit well without being too tight.
Simon R.
Loxjie A30
Ordered this little unit because I needed a new amplifier for speaker measurements. The ASR review showed perfect load independent linearity, and that was exactly what I needed for the purpose. In short, it all works as expected, the connections give me all the possibilities to input the measurement signals. And by the way, a short sound test via spdif convinced me so far. For a second sound system, or perhaps as a travel companion, the device is a great option. Small criticism: The device tilts a bit, because one foot is sunk deeper than the others. Since this is easy to fix and does not affect the function, I still give all stars as a rating.
Simon R.
SMSL SU-9n DAC ES9038Pro USB XMOS Bluetooth 5.0 32bit 768kHz DSD512 Petit frère du SMSL SU-9, le SU-9n en est une version modifiée, reprenant l'ensemble des caractéristiques de son modèle, mais cette fois-ci sans le...
SMSL SU9n
The SU9n was delivered a few days ago, and everything went well as usual when ordering from Audiophonics. The unit works flawlessly and I can now say after a few days that it plays very clear and transparent. I do not notice any euphonic or flowery tendencies, but a very neutral, detailed reproduction with very good spatiality and precision. This also in Bluetooth mode, which surprises me and makes me very happy. It also offers all the connections I need. My conclusion: Enormously high level at a very fair price. You have to dig much deeper into your pocket elsewhere than for SMSL. Splendid!
Raymond M.
AUDIO-GD R-28 2022 EDITION DAC R2R DSD Natif I2S ACSS Amanero / Préamplificateur / Ampli casque Le R-28 de chez Audio-GD est un appareil tout-en-un d'une rare polyvalence qui réunit dans un seul et même boîtier un DAC full R-2R très haute...
Une Merveille, Mais…
Ce Préampli-DAC-Ampli Casque est une pure merveille de restitution sonore (sans parler des spécifications techniques audiophiles ahurissantes). Associé en amont à des fichiers FLAC haute résolution décodés par JPLAY Femto & Audirvana Studio, et en aval à un casque Audeze LCD-XC relié par un câble Arctic ‘Grandis’ XLR dont j’ai eu la primeur, je touche, je tutoie, j’entends ! le Graal ‘Son’.
Alors pourquoi cette étoile en moins ? Parce que les concepteurs audiophile de l’Empire du Milieu ont tutoyé le pire du pire avec des connecteurs casque en façade totalement incongrus et indignes de présence avec en prime un système de verrouillage aberrant.
Le connecteur jack se retire très difficilement malgré le déverrouillage poussé à fond. Mais que dire du connecteur XLR 4 broches, impossible à enficher normalement. J’ai dû forcer comme un malade pour faire pénétrer les 4 fiches mâles de quelques millimètres dans les fiches femelles, mais il restera définitivement encore un bon cm à l’extérieur. D’après ce que j’entends... le ‘contact’ est établi, mais pour du ‘high-end’ peux mieux faire. Mon interlocuteur chez Arctic m’a confirmé qu’Audio-GD persiste et signe avec ces connecteurs (Neutrik pour ne pas les nommer) low-cost qui ‘fonctionnent en douceur’ avec leurs homologues, mais bloquent avec les ‘high-end’ du style Furutech ou CuTECH en ce qui me concerne. Délirant.
Quand on veut jouer dans la cours des ‘grands à 5 chiffres’, on se donne à 100% et on ne ‘mégote’ pas sur le dernier %.
Charles S.
DYNAVOX AMP-S MKII Commutateur Sélecteur Audio pour Enceintes / Amplificateurs Noir Le Dynavox AMP-S MKII offre la possibilité de commuter entre deux paires d'enceintes lors de l'utilisation d'un amplificateur HiFi. Inversement, il permet aussi de...
DYNAVOX AMP-S MKII
Très satisfait, commutateur de très bonne qualité.
gonzague d.
Connecteur imposant
Grande qualité pour ce câble au connecteur Bals imposant. Ce connecteur mural est bien long, environ 10 cm plus une relative rigidité du câble vu son blindage, il lui faut donc de la place, difficile à placer derrière un meuble. C'est le seul reproche que je lui fais...
gonzague d.
ARMATURE ELECTRA F8 V2 Distributeur Secteur Filtré 8 Prises Schuko Aluminium Noir L'Armature Electra F8 V2 est un distributeur secteur filtré de grande qualité, intégrant deux prises direct et quatres prises filtrées qui redonnera...
Super Multiprises
Distributeur de grande qualité de fabrication, juste un peu encombrant mais tellement pratique avec les 8 prises, dont 6 filtrées, dédiées à mon ensemble musical. il me semble que la musique a gagnée en clarté. C'est un bon investissement.
Christelle D.
THIEAUDIO LEGACY 4 Écouteurs Intra-Auriculaires IEM Dynamique Poly-membrane 9.4 Ohm 108dB 20Hz-20kHz Les écouteurs Legacy 4 ont été conçus pour apporter une touche unique à la gamme, en proposant un juste milieu en terme de réglages et...
Des intras étonnant si on sait les apprivoiser
Je suis très heureuse de mon choix mais je dois avouer qu'il m'a fallu un peu de temps pour en arriver à cette conclusion et donc les "apprivoiser". En effet, il faut impérativement trouver les bons embouts (n'hésitez pas à tester en premier lieu ceux fournis). Sans cela, vous risquez d'être déçu et cela serait vraiment dommage tant ils sont qualitatifs et tant le rapport qualité-prix est excellent. Je n'ai donc enlevé une étoile que pour la raison évoquée ci-dessus.
gonzague d.
Se rétracte bien, toutes les tailles pour avoir du choix et un stock
gonzague d.
Josselin B.
MEZE 99 NEO Casque Haute Fidélité Nomade 26 Ohm 103dB Le casque nomade audiophile Meze 99 Neo redéfinit le terme même du rapport qualité / prix, proposant un casque aux courbes contemporaines, offrant une...
Super casque mais pas le plus confortable
Globalement très content de mon achat.
La sonorité est très agréable même si le côté étriqué des voix m'a d'abord un peu rebuté comparé à mon Sennheiser HD660S qui lui est ouvert. Par contre le timbre des voix est particulièrement agréable !
Niveau esthétique je le trouve vraiment très beau.
Par contre le confort est loin d'être parfait. Rien à dire du côté de l'arceau et du système de réglage automatique mais j'ai beau avoir une petite tête, mes oreilles touchent en permanence à cause d'une profondeur trop faible des coussinets ce qui rend l'utilisation du casque douloureuse après quelque temps.
J'ai l'impression que je m'y suis un peu habitué mais j'ai quand même commandé des coussinets plus épais en espérant que le son et l'esthétique ne soient pas trop dénaturés.
Panos M.
could be much better
OK its cheap but the soldering is made by a monkey, at list on the one i got. Sound wise, nice, nothing that gives you tears.
Michel f.
VIBORG VB401S Fiches Banane Cuivre Pur Plaqué Argent Ø4mm (Set x4) Viborg propose avec ses VB-401 (S) des fiches bananes d'exception, grâce à une conception utilisant des matériaux particulièrement haut de gamme.
fiche banane haut de gamme
Enfin unee fiche banane haut de gamme bien concus qualitée pro une conexion haut de gamme Difficile de faire mieux et a un prix raisonnable les meillieur a ce jour dans cette garégorie de prix
luciano r.
ATAUDIO KING WOLF Câbles de Modulation RCA Cuivre OFC 6N Blindé Plaqué Or 0.75m (La paire) Ces câbles RCA ATAudio King Wolf affichent une fabrication de qualité avec des conducteurs en cuivre OFC 6N isolés, assurant une très bonne...
KING wolf RCA to RCA
Collegamenti: (output) unita CD JVC Mod.XL-Z551 (input) unita QUAD 34 pre.
il suono mi appare più brillante sulle medie alte frequenze, (forse un pò troppo) ma pulito e trasparente. Le basse frequenze presenti e ben smorzate. Percepisco un piccolo miglioramento, per un costo abbordabile.
luciano r.
AD797 opa
Sostituiscono gli : NE5534AN, risultano più stabili, meno rumorosi e con una distorsione minore di 4 dBv.
Fabrice j.
hum hum..."i can hear the grass grow"...
j'ai un doute par rapport à la prétendue connaissance des personnes rajoutant un signe négatif sous chaque commentaire d'un produit furutech dont la qualité est indéniable, mais bon bref...
Yves J.
Fiches din HP
Pas encore installé, je pense quelles sont des bonne qualité .
Envoi rapide et soigné.
Chris S.
OK
Marche bien mais on doit comprendre qu' on peut pas connecter HDMI Out avec son DAC si on voudrait utiliser I2S. À la place, on doit utiliser IIS Out. C'est aussi HDMI. Le nom est un peu trompeur. Pourquoi pas le qualifier I2S Out?
Eric d.
Parfait. Ce câble secteur a très avantageusement remplacé les câbles basiques d'origine livrés abec les blocs NCore mono 250.
Ouverture, scène sonore, timbres, dynamique, Etc..
Je l'ai comparé à un autre câble DIY à 7 fois le prix: la différence existe mais on est dans l'épaisseur du trait.
Fabrice j.
liquid liquid
pour être convaincu je l'ai utilisé sur les contacts de mon chargeur iphone et quand je l'utilise en le branchant j'ai une vitesse de réponse assez étonnante...amazing...
Nikolaus S.
great mod for every high resolution system
The heart of my System is a "ANK 5.1 signature" tube DAC. I use the "Audio Magic Premiere Ultimate" fuse already. Yesterday I changed the series inlet against the furutech one. It was more the obvious, that this inlet can be a real bottleneck for the whole system. After modification, you have more of evereything. More room, higher resolution, deeper bass, etc.
Arnaud N.
DYNAVOX AMP-S PRO Commutateur Sélecteur Audio pour Enceintes / Amplificateurs Noir Le Dynavox AMP-S Pro permet de commuter facilement et rapidement entre deux amplificateurs et deux paires d'enceintes, sans avoir à devoir effectuer de nouveaux...
Très qualitatif. L'ensemble fait "sérieux". Fait parfaitement son travail.
Arnaud N.
Qualité médiocre
Il est urgent de faire remonter à la marque que les vis sont d'une qualité MÉDIOCRE. Quelle galère parfois pour visser les câbles ! L'entaille est une fois sur deux mal réalisée ou en partie seulement.
C est dommage
pierre a.
tres rigide
je suis un peu deçu par ce cable , c'est surement un tres bon cable
mais il est tres rigide
Raymond M.
MENNEKES Connecteur Secteur Schuko Type F Femelle 230V Ce connecteur Schuko Type F femelle de chez Menekes est conçu en Allemagne et respecte les normes européennes. Il est par ailleurs équipé d'un...
Sans plus, mais...
Qualité plus que moyenne effectivement, connexions phase et neutre indignes de qualité et laissant vraiment à désirer. Et en ce qui me concerne, obligé d’enlever 5 mm sur le couronne extérieure, la prise mâle qui lui était destinée venant en butée et donc ne tenant pas. Quant à l'amélioration sonore ??? Ceci dit il n’y a pas pléthore de prises Schuko femelles (en dehors des prises murales) contrairement à ses homologues mâles.
Jan S.
Gustard R26!
Waoo. Out of the box! 3D, perspectives. The image nice. What will happen after some 100h? Looking forward
Hervé T.
XDUOO XQ-50 PRO2 Récepteur Bluetooth 5.1 QCC5125 aptX HD LDAC DAC ES9018K2M xDuoo propose avec son XQ-50 Pro2 un excellent récepteur Bluetooth, simple d'utilisation et performant, qui vous permettra de transformer votre installation audio en...
Bon petit appareil
Bon petit appareil, simple à mettre en œuvre, peu encombrant.
Bon rapport qualité/prix.
Fabrice j.
amazing...
japanese do very well their hobby... i do not know how many of them in that little capsule but i am sure one day we will have a paint-me-a-landscape version of it...gives the needed transparency and removes electrical pollution, even aside of the hifi system (would recommend to put one in the power block socket and one in a socket amongst the circuitry of your living space for enhanced comfort)...
Rémy P.
Dac U-sabre
Fonctionne correctement.Par contre, impossible de faire fonctionner ce DAC avec les pilotes ASIO, tout est haché, j'ai du laisser les pilotes windows.
Guillaume S.
SMSL D400EX DAC 2x AK4499EX AK4191 XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Avec son DAC D400EX, SMSL revient sur le devant de la scène en adoptant deux puces DAC haut de gamme AK4499EX et une puce AK4191 de chez AKM. Associée à des...
Faites confiance à vos oreilles.
Ma config de base : Panneaux MAGNEPAN 3.6r - preamp / ampli GAMUT (D200) - SUB REL T9i....
J’écoute surtout du Vinyle.
SMSL D400EX
Le chassis est plutôt robuste. Les boutons et la molete
font un peu cheap. Pas mal de connectiques, ça c’est plutôt bien.
Dans mon salon le SMSL reçoit un NUC pour faire tourner ROON (USB) et un lecteur CD Primare CD22 (COAX).
Je viens de remplacer mon DAC NP30 (très musical) de chez Primare en faisant confiance aux relevés de Audio Science review et surtout aux conseils avisés de Audiophonics dont je salue la disponibilité et la gentillesse.
Bref….on va dire que le gap est énorme. Avec ce DAC… foule de détails, la spécialisation est excellente, la scène sonore plus large. Par ailleurs je découvre Roon. Je ne saurais que trop recommander l’experience Roon.
J’avais en premier lieu acheté son petit frère le DAC SMSL D400ES. Fatiguant…. branché en COAX sur un NP5 peut être était-il mal exploité.
Le SMSL D400EX est plus riche en harmonique, plus doux et plus musical…
Dans tous les cas, ce sont de très beaux appareils compte tenu du prix. Leur pouvoir d’analyse est grand et les prestations qu’ils proposent sont impressionnantes. Mais…je suis habitué à écouter des choses plus musicales et moins fatigantes. Je dois préciser que j’avais fixé un budget max de 1000 €. On ne peut pas non plus s’attendre à des miracles.
Compte tenu du prix…je pense que c’est un excellent appareil pour se jeter dans le bain de la dématérialisation ou encore pour venir étoffer un système en cohérence. Et ça, c’est plutôt cool.
Je précise aussi que l’excellent site Audio Science review ne fait pas fonctionner ses oreilles mais seulement ses outils d’analyse. La seule réalité objective de la mesure ne suffit pas! Cette base de données n’est pas un site audiophile.
Nathan H.
WONDOM ICP5 Programmateur pour JAB Interface USB UART Application Bluetooth Le Wondom ICP5 est le nouveau venu de la gamme Wondom ICP, avec fonction USB UART permettant un contrôle via une interface PC et Bluetooth pour un contrôle depuis...
Décevant
Parfait pour utiliser Miumax PC et ainsi régler les filtres comme on veut et facilement MAIS il faut laisser brancher l'ICP5 à votre JAB ou APM2 donc il vous faudra acheter autant d'ICP5 que de module de filtrage ce qui est complètement débile.... Autant programmer directement sur Sigma Studio. Sauf que Sigma Studio ne reconnait pas l'ICP5 mais juste mon ICP3.
Nikolaus S.
Good Quality, but not for more than Ø15mm cable
Only an artist will be able to fix a Ø18mm cable into this connector. The sound ist typical for rhodium coating, smooth an very detailed.
Mikulas K.
ATAUDIO RIBBON Flat Speaker Cable Silver Plated OCC Copper 2x1.5mm²
WOW !!! Best cables I had so far. Terminated with M AUDIO BS-210G Banana Plugs they are by me very good solution for Hypex Ncore amp and my System Audio speakers. Simply awesome.
Unbelieveble what you get for few euros.
Dominique P.
Excellente qualité perçue et superbe finition.
On peut trouver moins cher mais le prix de cet article me semble justifié.
Achat recommandé
Christian S.
jack reçu pas en rapport a l'image
Bonsoir,
Très surpris et déçu par ce jack mono. Extrêmement difficile de mettre la soudure sur le conducteur de plus il ne correspond pas à ce qu'il y a sur l'image, donc à ma commande.
J'étais pressé et je me suis arrangé avec l'un deux, je garde les trois autres en attendant votre explication.
Je peux vous faire une photo de celui reçu.
Cordialement.
Gordon M.
AES / EBU HAT RPI
I paired this with a Pi4b streamer running Moode in a Argon M2 case with a Funk AES cable connected to a Gustard X18. Listening between USB2 and USB3 BT LDAC with very good cables the AES was a quantum leap. Sound stage a meter wider, bass clean and forceful, mids just sweet, highs crystal clear, high hats some I hadn't heard on tracks I'd listen to 100 times before.No hint of digital sound or tinny sounding, an absolute upgrade and at an excellent price. For the M2 case and HAT I needed 2 PSUs but it was all set up on Moode in a few minutes.Top product, thanks Audiophonics for the great service as well.
Leonas J.
6np3
hello,it is made in ussr tubes/ or any better maker? how it compare vs stock russian tube on my china amp 6np3 valued at 2eur only?
Laurent D.
Le cablosceptique
Toujours très méfiants sur les commentaires dithyrambiques de certains "cablophiles" je me suis laissé surprendre par la nette amélioration avec ces petits câbles de liaisons par rapport aux originaux de mon bras SME. Je recommande vivement ces câbles même si sur une Ortofon OM10 il faut un peu forcer pour les enficher. Comme toujours Audiophonics fait les bons choix: bravo
Raymond M.
Peux mieux faire
Je serais moins dithyrambique que les autres commentaires… J’ai pris cet appareil dans le but de bien positionner la phase dans mon meccano hifi, mais je n’ai que le message ‘terre manquante’, ce qui est visible sur les prises et logique, vu que mon installation électrique, bien que rénovée entièrement, date des années 80 et que la terre n’est présente que dans la cuisine, les salles de bain et le sous-sol (normes de l’époque), lieux où je ne vais pas installer mon home hi-fi. Quant au dernier diagnostic ‘inversion phase et terre & terre manquante’ il me laisse perplexe… J’aurais préféré ‘inversion phase et neutre & terre manquante’, mais bon vu le prix, je vais garder ce gadget au cas où, bien que dans l’immédiat il ne me serve… à pas grand-chose.
Axel H.
Très facile à mettre en œuvre, bonne qualité des composants.
Je recommande!
