Marc S.
Ce Bliss est incroyable en tant que préamplificateur classA HDG. Je l'utilise avec le DAC Holo Sring3 L2 et pour la...
Johan v.
Good after software update
Not bought here for practical reasons it would not read anything after track 31 and after a helpful email from Shanling and a...
Johan v.
My favorite hookup wire
Strips easely soldering well heat resistant great to work with
Avis clients - Il y a 19589 avis.
Boris T.
Great DAC
This DAC represents great value for the money. In my system, it replaced Topping E50 that has the same ES9068A chip, only single one. Differences are easy to be heard as better sound stage, additional fine details in the reproduction and better separation of multiple voices or instruments.
Only let down is display. It’s very dim, even at max. brightness, with too small characters.
From the moment of order to delivered it took only 25 hours, from France to Croatia, using TNT service. Bravo Audiophonics!
Igor K.
AUNE X7S 2021 EDITION Amplificateur Casque Class A Sortie Variable / Symétrique Argent L'amplificateur casque en pure classe A Aune X7S à sortie symétrique est l'aboutissement d'une longue recherche après l'amplificateur casque nomade Aune B1...
Amazing, smooth, detailed, dark background
I'm using Sennheiser HD6xx and Audeze LCD-1 headphones. I also have the B1S from Aune. The headphone amp sounds "liquidy". It's easy to place instruments in space. The background is very dark. I would not call class A warm, just pleasant / sweet sounding. Excellent for long listening sessions. For comparison, I have Hegel H95 and I tried Woo Audio WA7 3rd gen, and I prefer this amp.
Fabien M.
rien à dire. C'est simple et bien fait
Fabien M.
pas ce que j'attendais
Tout d'abord... j'admets être un peu maniaque.
Je voulais remplacer mon ampli 70's par un ampli plus simple (pas de réglage aigu/grave/balance qui à mon sens n'ont rien à faire dans un ampli).
Le côté positif, le schéma électronique est TRES bien... c'est pour cela que je l'ai acheté.
Malheureusement le son n'arrive pas à la cheville de mon vieil ampli (HK505).
Je pense que les condensateurs ne suivent pas. J'aurais pu tout dé-souder et remplacer par des condos haut de gamme (MKT / Électrolytes) pour multiplier la qualité du son par 10... mais bon.
Le jour où il y aura une version 2.0 de cet ampli avec des condos haut de gamme je serai prêt à payer 100 Euro de plus avec grand plaisir.
Sami K.
Rigid cable
Excellent quality cable as such, but maybe not be the best choice for headphone use as the cable itself is pretty thick and stiff.
Fabien M.
Très bien (voir mesures ci-dessous)
Boudonnement mesuré sur le haut parleur:
50Hz passé de -45dB à -75dB!
100Hz passé de -60dB à -90dB
128Hz passé de -62dB à -74dB
Eric P.
TOP
Acheté en remplacement d’un autre sélecteur de sources/ enceintes qui me jouait des tours.. celui ci est parfait.
Il remplit son rôle sans faiblir ( je l’ai testé «  à mort »)
Il semble bien robuste avec ses grosses bornes et je sens qu’on va se plaire tous les deux.
Merci à audiophonics pour le conseil.
TRIANGLE BP400 Fiches Bananes Plaquées Argent Ø2.2mm 3.8mm² (Set x4) Les fiches bananes Triangle BP400 assurent à la fois un contact optimal entre le câble et le bornier du fait de leur forme, tout en assurant une conductivité...
Excellentes fiches bananes
Excellentes fiches bananes. Elles sont très faciles à installer.
Ne dénaturent pas le son et tiennent fermement sur la fiche HP femelle.
Il faut simplement mieux repérer le Plus et Moins.
Je recommande vivement ces fiches avec le câble triangle.
Envoi rapide comme d'habitude par l'équipe.
Marian M.
MUNDORF MLYTIC AG Condensateur 63V 15000µF Ces condensateurs ont été spécialement développés pour les amplificateurs de petite puissance ou les préamplificateurs. Ce nouveau...
noise activity
Great capacitors
fits Yamaha DSP A-592.
Great sound, they gave my amplifier (1997) a new life.
Extremely fast delivery, thank you.
Changement
Je reviens sur ma première analyse qualifiant ce câble de pas terrible.
Il n’en est rien en réalité, car après 1 mois de fonctionnement il révèle aujourd’hui tout son potentiel. Il est passé par différentes étapes, de très claire a très sombre.
J’ai bien fait d’insister car aujourd’hui c’est un vrai bonheur et je retrouve toutes ses qualités qui m’avaient bluffées en modulation.
Beaucoup de matière avec un registre grave profond et détaillé. Le reste du spectre sonore est riche de détails et la justesse des timbres est superbe.
Bref, vous l’aurez compris, ce câble a besoin de temps pour s’exprimer à sa juste valeur.
Alors avec un peu de patience vous aurez une petite merveille
Et si vous le jumeler à une paire de modulation (oui, je sais qu’il n’est pas vendu pour ça) vous entendrez vos CD sous un autre jour.
Par ailleurs je confirme que leur diamètre est bien de 6.4 mm et non de 4.6 mm comme annoncé sur le site.
Ç’est important pour commander les bonnes prises.
Faites vous plaisir sans plus attendre.
Mathieu W.
SMSL VMV D2 DAC AK4499 Symétrique I2S XMOS Bluetooth aptX-HD LDAC UAT 32bit 768kHz DSD512 MQA Le SMSL VMV D2 est un DAC high-end, embarquant des composants haut de gamme au sein d'une architecture soignée, pour des performances d'exception. Au cœur du DAC,...
MERVEILLEUX
Ce Dac est une incroyable surprise - ce qui n'est pas toujours le cas de mes acquisitions. Mon système (enceintes atlantis labs AT31 + LUXMAN L 509X) a été transfiguré. Pour plus de détails je renvoie a la REVIEW de SOUNDNEWS : vous aurez exactement ce que ce testeur y décrit (au millimètre). J'avoue avoir été sur la réserve à la commande pour le médium et la musicalité mais c'est superbe. C'est plein de matière et de technique. ET LE PLUS IMPORTANT et je ne m'y attendait pas : IL EST EXCEPTIONNEL en préampli et j'attaque directement le bloc du LUXMAN avec un meilleur résultat que le préamplificateur Luxman (Si!). Jusque la tout mes DAC étaient un peu décharnés en branchement direct : perte signal, timbres etc. La c'est le rêve et avec un grave d'un autre niveau pour la rapidité et les impacts. J'envisage d'acheter des blocs de puissances plus conséquents vu la synergie. Quelle transparence, quel niveau de détails et ce fond noir de la scène. Bref conquis.
Enfin le changement de la phase en façade est génial et la qualité en Bluetooth est également bluffante. J'espère qu'il durera dans le temps car vraiment très bon a ce prix. Ce n'est pas un DCS BARTOK mais pour écouter beaucoup de DAC dans ce créneau de prix et au delà c'est très fort. Impossible de se tromper.
Peter L.
Quality product
Very nice soldering. Refurbed ic's look like new. All test ok (4 units).
I have replaced 2 opa2134's in my preamp with the 627's. 2134's remain in the balanced receiver. In short the 627 are better: smooth, far more balanced tonally, defined rich bass. Mellow but all the texture and detail is there.
Patrick K.
Very good and soilid build quality! Very good sounding and lots of power!
The sound quality is very good, but the production in China is not flawless, because the stereo RCA channels are internally inverted! Therefor only 4 stars worthy.
Greetings
Jean-François S.
DAYTON AUDIO RS100-8 Reference Haut-Parleur Large Bande Aluminium 30W 8 ohm 85dB 90Hz - 20kHz Ø10cm La gamme "Reference Series" de DAYTON AUDIO redéfinie à elle seule la notion de rapport qualité/prix sur le marché ultra concurrentiel des...
Bon HP large bande à prix démocratique
Donne de bons résultats monté dans une enceinte de 5 litres accordée à 60 Hz pour un usage de monitoring en MAO et d'écoute de proximité. Au début les aigües étaient un peu timides, défaut disparu après quelques heures d'utilisation (rodage ?). Ecoute très "analytique" et neutre, c'était le but visé, mais les graves sont tout de même bien présents malgré la petite taille des enceintes.
David S.
1877PHONO THE MAHONE RCA Câble Phono RCA - RCA + fils de masse 1.5m Le câble "THE Mahone" de la célèbre marque Canadienne 1877 PHONO permet de connecter votre platine phono sur votre préamplificateur phono doté de prises RCA.
à recommander !
Je manque surement d’expérience dans le domaine des câbles phonos, mais le rendu est tout à fait conforme à mes attentes et les dépassent largement. Je me suis fié aux retours d’utilisateurs lus sur des forums anglophones.
Il me fallait un câble qualitativement plus en adéquation avec ma cellule MC bas niveau pour remplacer mon câble pro-ject. C’est chose faite : une image stéréo renforcée avec énormément de micro détails sur tout le spectre sonore avec beaucoup de poids et dynamisme, tout en restant naturel.
Pour 155 Euro, on en a largement plus que pour son argent.
Le seul petit moins : les pinces pour le fil de masse ne sont pas très pratiques, du moins sur mon installation.
Le petit plus superflu mais agréable au déballage : un superbe packaging.
Merci à Audiophonics de mettre à disposition cette marque méconnue en France sur son site.
Igor K.
AUNE B1S Amplificateur Casque Portable Discret Class A Le Aune B1S, nouvelle version du B1 impressione par sa conception en Class A intégrée dans un boîtier au format réduit, idéale pour une...
Amazing, holds its own against much higher priced units
Tried with Audeze LCD-1 and Sennheiser HD 6xx. I only had Woo Audio WA7 gen3 and Hegel H95 to compare with side by side. Aune has darker background than WA7 and is a touch more dynamic and a bit more resolving. There is greater separation of instruments and the soundstage is deeper (again, a bit). Considering the price, this is an amazing accomplishment. Hegel H95 throws a wider sound stage, but I'm not sure if it's more accurate. Overall, very pleased with the unit. I normally don't buy lower priced units, but this is the only portable class A unit I could find under 1k. This unit holds its own against much higher priced desktop amps.
Luis V.
Transformateur Audio d'Isolation Boucle de Masse RCA Ce transformateur d'isolation RCA stéréo permet d'isoler le signal audio afin d'atténuer considérablement les interférences et par...
Excelent
Solves ground loops without the compromise of sound quality
Florian G.
SMSL HO200 Amplificateur casque / Préamplificateur symétrique Amplificateur casque & préamplificateur compact et élégant avec étage de sortie capable de délivrer jusqu'à 6W sous 16Ω (3W...
Très satisfaisant
Associé temporairement avec un M300 de la même marque, rien à redire sur le son ; c'est très propre.
Gain très correct avec des casques monitoring 250 ohms ; largement de quoi se rendre sourd. (-:
N'ayant plus d'ampli disponible, je n'ai pas testé les sorties préampli.
arnaud g.
c'est beau, c'est très mauvais
pourquoi vendre des cables comme cela sur un site audiophile, je ne sais pas.
Cable de faible qualité, tient à peine, n'enserre pas, bref je l'ai rangé dans la caisse de suite
Iulian M.
The best 24v smps I have ever owned.
60-80mV is NOT ultra low noise/ripple but with more filtering i could get it to 2-3mV and that is the best result i ever had with a smps.
Powering a Burson Funk, it really makes a difference. It's like the Burson SuperCharger but without the background noise and without the exagerated price. A minor issue is the input filtering choke that is flapping around and it really needs a bit of glue.
Srboljub S.
ELECAUDIO GB-05 Gaine Tressée Extensible Nylon (PET) 07-14mm Gaine tressée élaborée en  PET (Polyéthylène Terephtalate)  monobrins pouvant être utilisée dans une large...
Very happy
This sleeve is both beautiful and high quality. Will buy again.
Pastorelli g.
DAYTON AUDIO EPIQUE E180HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 Ohm 84dB 25Hz - 3000Hz Ø17.8cm Associant d'excellentes performances à un prix raisonnable, le subwoofer Epique E180HE-44 à membrane en fibre de Carbone établit un nouveau standard en...
Impressionnant
Un superbe subwoofer, très bien construit et qualitatif. Monté dans un caisson clos de 8,5l fitlré à 60hz ....le résultat est terrible, rapide et une très belle frappe, aucun trainage. Un excellent choix.
Service Audiophonics parfait !
David O.
TOPPING D90SE DAC Symétrique ES9038Pro 32bit 768kHz DSD512 MQA Argent Le Topping D90SE est un DAC high-end, profitant d'une conception sans intelligente et soignée pour des performances de haute volée. On y retrouve notamment une...
Formidable
Viens en remplacement d'un Micromega MyDac car il datait un peu.
Après quelques recherches j'ai lu que ce DAC avait des revues objectives sur sa transparence. Le résultat à l'ecoute est incroyable.
Laurent F.
VIBORG VE02R Embase Secteur Schuko Type F Cuivre Pur Plaqué Argent / Rhodium 250VAC 16A Cette embase Viborg VE02R exploite des matériaux de très grande qualité afin d'assurer une parfaite transmission du signal électrique. Les contacts...
Très bon produit, montage facile , vis type Allen avec clef fournie
Prise lourde et solide 5 * avec plaisir
Laurent F.
PANGEA PREMIER SE MKII Câble HDMI 2.1 Cuivre Cardas Plaqué Argent 8K 60Hz / 4K 120Hz HDR 48Gbps 0.6m Avec le Pangea Premier SE MKII, vous profitez d'un câble HDMI 2.1 de très haute qualité, permettant une parfaite transmission du signal entre vos appareils....
Les produits Pangea sont excellents
Laurent F.
PANGEA PREMIER Câble Ethernet RJ45 Cat7 Cuivre Plaqué Argent Triple Blindage 0.129mm² 3m Si vous disposez de périphériques audio high-end connectés en réseau, alors il est essentiel d'utiliser des câbles Ethernet de qualité pour permettre à vos appareils de délivrer...
Très bon et beau câble , excellente finition , je recommande
Johan Å.
AUDIOPHONICS HPA-Q250NC Amplificateur de Puissance Class D 4 Canaux NCore NC252MP 4x250W 4 Ohm Le Audiophonics HPA-Q250NC est un amplificateur quatre voies basé sur deux module d'amplification Hypex Ncore NC252MP.
Insane value and perfermance
As the title says, insane value and perfermance! Compared to my much more expensive Emotiva amplifier this one sounds smoother which I didn't expect. In fact this Audiophonics amplifier sounds so good I placed an order for the 3-channel Purifi amplifier.
Regarding build quallity; one of best built amps I have held in my hands - built like a tank!!
maarten v.
Nice looking and stable for this price
Angelo B.
SABAJ A10H Amplificateur Casque Class AB 1W 32 Ohm Sabaj vient compléter sa gamme A10 avec cet amplificateur casque A10h, un modèle de grande qualité basé sur une architecture optimisée...
Sabaj A10h
This neutral sounding amplifier surprised me incredibly with its open soundstage and very good separation of musical instruments. Also surprised by the sound quality with my HD650 and HD58X (incredible musical definition). The volume returned was more than enough to appreciate the perfect compatibility and goodness of the Sabaj A10h and HD650.
Comparisons made with:
-Violectric HPA V200.
-OTL MegaHertz.
-Schiit modi Multibit.
-Khadas Tone Board.
-Austrian Audio Hi-X65.
-Avantone Planar.
-Equalizer APO.
Thank you very much David Aubert who always very professional in recommending the products.
Ioannis S.
Coaxial not operate properly
Is a good DAC but the coax input operate with with continuous breaks when i connect a CD player !
Thierry A.
LUDIC AESIR Câble secteur Schuko IEC C15 Cuivre UP-OCC plaqué Or 2m Le Ludic Aesir est un câble d'alimentation de grande qualité. Il intègre en effet des conducteurs en Cuivre UP-OCC Drawn® brevetés, permettant...
Très bon niveau en terme de qualité prix
Différence perceptible en utilisant ce câble par rapport au câble d'origine sur une source OPPO 203. Un peu plus de définitions.
Très bonne qualité de fabrication. Très bon rapport qualité prix. Je conseille de le tester.
Ce câble ne détériore pas la qualité du son en privilégiant un registre par rapport à un autre comme certains câbles secteurs peuvent le faire ce qui est un très bon point.
Bien pour le prix
Fait le job pour alimenter un caisson de basse équipé Dayton. A noter que le ventilateur se met en route...pour ne plus jamais s'arrêter...
Philippe K.
DYNAVOX TW-2 Pèse Cellule Électronique 0.01g - 200g +/-0.01g Cette balance Dynavox TW-2 est destinée à peser vos cellules phono vinyle. Ainsi, elle offre une mesure de haute précision sur une plage de 0.01g à...
Excellent accessoire
Encore un excellent accessoire pratique de Dynavox. Pèse efficacement la cellule et permet un réglage fin et précis du contre-poids permettant une lecture optimisée. Excellent rapport qualité/prix.
Philippe K.
Excellent produit très bien usiné. Apporte stabilité à la lecture et réduit efficacement bruits et distorsions. Un accessoire indispensable pour tous possesseurs de platine vinyle.
VIBORG VF503 Connecteur IEC C15 Cuivre Pur Ø19mm Le connecteur IEC C15 Viborg VF503 offre une excellente qualité de conception et vous permettra de concevoir des câbles secteur high-end pour alimenter correctement...
parfait .
dans l esprit de rester tout cuivre j ai acheté cette fiche .
rien à redire.
bonne qualitée apparente meme si je doute que le corps de la fiche resiste à plusieurs chutes ou choques ?
accepte du câble plus gros que 2,5 mm .
montage sans difficulté et prix acceptable .
bravo .
Multiprise DIY Aluminium 8 Ports Schuko Noir Cette multiprise DIY intégrant 8 ports schuko avec mise à la masse profite d'une très bonne qualité de conception, idéale pour alimenter...
besoin de plus ?
cette barette fait parti des premiers prix de la catégorie , comment la critiqueur ?
mon choix c est porté sur le nombres de prises bien sur , mais aussi par la presence du rail en laiton de forte epaisseur qui relie les schuko et garant d une bonne restitution du courant entre les fiches .
pour la qualité c est du très très bon .
les fiches secteurs mal s emboitent avec resistance dans la barette gage d un bon maintien.
seul hic l assemblage !
je n ai jamais rien vue de si peu pratique .
pour un meilleur contact pensez à étamé le bout de vos câbles c est toujours meilleur et ca tient mieux au serrage .
un tres bon choix .
Jean-Claude T.
Produit Ok
Superbe produit et reçu très rapidement!
Jérôme L.
au top
La carte est géniale, le rendu est vraiment bon. J'ai déjà un raspdac mini qui est équipé avec celle-ci je commande donc les yeux fermés
Juste dommage qu'il n'y ai pas les entretoises vendu avec.
MICHEL B.
Il fait le job
Ce petit appareil duplique parfaitement le signal optique. Je l'utilise pour envoyer le signal de la TV ves des enceintes actives avec entrée optique.
Il n'y a pas de décalage son image.
MICHEL B.
Super qualité
Ce câble optique a des connexions d'excellente qualité et la gaine du câble est solide ce qui est un atout pour parcourir 5 m au sol.
Denis C.
Câble HP
Merci pour la rapidité de la livraison.
Il ne reste plus qu'à le roder.
Encore merci à toute l'équipe.
Denis
Thomas V.
phase inversée
Juste pour signaler que le câble que j'ai reçu inverse la phase. Ca arrive sur des câbles bien plus chers mais s'ils sont tous montés à l'envers (?) ça vaut le coup d'être précisé.
Michael S.
Does the job
I needed to raise the height of my dac to be able to provide space for a new op-amp and these were perfect. Added stability and height to the Aune X8.
Michael S.
Recommended!
Upgraded the op-amp in my Aune X8 magic from the stock amps to the Sparkos SS3602 Dual Discrete. I found this recommendation on you tube and although I am naturally sceptical by nature, the change made a very noticeable improvement to my system. Hugely recommended purchase!
Eric F.
Top quality :-)
Avis posté avec encore peu d'usage, mais le gain pour mon usage est important.
- 1 usage classique : écoute audio de musique sur casque : meilleure spacialisation, la scène sonore s'est ouverte, et chaque instrument est plus "individualisé" et moins écrasé par les autres présents à l'enregistrement. Quand une corde est grattée ou pincée à coté d'une voix, elle se sépare mieux et vient enrichir l'écoute.
Belle qualité sonore, assez étonnante pour le prix car pour avoir une belle scène sonore, j'utilisais un ampli casque à tube seulement jusqu'ici, mais pas transportable.
- 1 usage particulier : écoute de fichiers audios pour faire de la retranscription pro. Les fichiers sources ne sont pas forcément top qualité, plusieurs interlocuteurs pouvant parler en même temps voire avec un fort bruit de fond : la séparation de chaque source est meilleure et chaque voix est donc plus facilement audible et compréhensible.
Moindre fatigue du coup :-)
Ceci est mon premier DAC, donc je n'ai pas de point de comparaison avec d'autres, mais j'en suis très satisfait.
Qualité audio franchement très supérieure à la carte audio intégrée à mon PC portable (PC entrée de gamme valant seulement +/- 800 €) dont la carte son commençait à dysfonctionner.
DAC portable = contournement du problème ;-)
Stefano G.
AUDIOPHONICS CANARE Câble Numérique Coaxial Ultra Coax 75 Ohm BNC-BNC 1m Ce câble Coaxial Ultra Coax 75 Ohm avec connecteurs BNC mâles est assemblé en France par Audiophonics, avec des composants haut de gamme de chez Canare. On y...
Good
I am connecting a Oppo BDP 105 to a Lector Digicode s-192. Compaired with my previous 20 euro rca cable, the music is more transparent and the bass are more punchy.
I am very happy.
Giulio M.
IFI AUDIO DC IPURIFIER 2 Filtre Adaptateur Secteur 5V-24V / 3.5A / 84W Nettoie le bruit présent naturellement dans le circuit électrique général afin d'éliminer une grande part des erreurs audibles...
Must have
Try with my NUC Streamer .Superior performance than linear AMP
Better bass response,detail and silence.
Ready to order another one for my Project Audio CD Trasport to work together with Ifi IPower
Arnaud P.
SMSL SU-8S DAC Symétrique ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA Le SU-8s de SMSL est un DAC symétrique profitant de la nouvelle puce de conversion numérique / analogique ESS ES9068AS. Cette dernière supporte des taux...
Tiptop.
Je cherchais un DAC avec réglage du volmue et lélécommande, pas cher, AVEC sortie XLR. J'ai vu que ses fonctionalités étaitent plus que complètes. Je l'ai pris.
Il est placé entre 2 sources, et des moiteurs actifs (d'où besoin des sorties XLR !) ; moniteurs actifs pour utilisation "à la maison".
Le SU-8S ne chauffe pas du tout, il est froid en fonctionnement, signe d'un bon design.
Il est tout pti rikiki, et c'en est rigolo car le rendu des Dynaudio Core59 au bout des câbles XLR de 5m (1er prix) est tout l'inverse :-)
La télécommande est un peu directionnelle mais à 6m ca marche nickel sans cafouiller. L''écran du SU-8S est petit, mais à 6m il indique très lisiblement le niveau du volume ; j'ai coché dans les réglages, d'éteindre l'écran au bout de 5s, comme ça il se fait complètement oublié. Simple et efficace ce SU-8S.
Merci Audiophonics de proposer ce pti DAC au RQP au plafond ; et merci pour livraison & service tjs au top.
Cdt
Thierry G.
VIBORG VH302G Connecteur Jack 3.5mm Stéréo Plaqué Rhodium Ø6mm Le Viborg VH302R est un connecteur Jack 3.5mm stéréo de belle conception, utilisant des contacts en alliage de Cuivre plaqué Rhdoium, afin d'assurer une...
Déçu
Les points de connexion pour souder les fils ne correspondent pas à la photo et ne sont pas pratiques.
Ce ne sont pas des oeillets. Il faut venir coller le fil sur la partie à souder.
Très peu de filetage pour visser le capot. Se dévisse facilement.
Les côtes sont très différentes des Elecaudio JK3-103 et ne correspondent pas à mon application,
Du coup, commande pour rien, j'ai recommandé les Elecaudio.
Cédric T.
Splendide
La photo ne fait pas justice à ce câble de diamètre plus que convenable et superbemen assemblé.
Un poil rigide mais rien de la dérangeant.
A littéralement transformé mon système stéréo en Dolby Atmos avec une représentation holographique,....
Blague à part, cet l'exemple même que c'est pas la peine de dépenser 500€ dans un câble en uranium cristallisé uni directionnel. Un bon câble, pas cher, qui fait 100% du job sans "snake oil"
