Nikolaus S.
Parfait sur un bureau
MICHAEL K.
Recommended
Avis clients - Il y a 19275 avis.
XDUOO MU-605 Récepteur Bluetooth 5.1 aptX HD LDAC DAC 2x ES9018K2M 24bit 96kHz Le MU-605 de xDuoo se présente comme un récepteur Bluetooth 5.1, vous permettant d'offrir à vôtre système HiFi classique la capacité...
Excellent produit !
Un résultat Audio très satisfaisant, toutes les sorties utiles dispo ! Une rareté sur le marché...
On aurait apprécié une entrée AES-EBU, mais la perfection n'est pas de ce monde :)
Conrad F.
IAN CANADA TRANSPORTPI DIGI Module Interface Audio Numérique Ultra Faible Jitter Le TransportPi Digi est une interface audio numérique tout-en-un haute performance pour Raspberry Pi. Il propose une qualité de signal à très faible...
A bargain
I bought this based on positive reviews, but expected them to be hyperbole. This replaced an IQaudIO Digi+ board and was a massive improvement. Overall clarity was similar, but my system suffered in sounding hyper clear but 2D. The Ian Canada board brought weight, body and a huge amount of depth. Things are very 3D. I was not a believer that streamers could make much difference if well engineered. Well either the commercial product market is full of sub-competent engineering, or the focus on creating a low noise, ultra low jitter source with hyper accurate clocking makes more difference than those over at ASR website claim. I have enjoyed my last 2 weeks with this board and a UcPi that I've just plumped for all the flagship boards to make a no-holds-barred streamer. I reckon just this Ian Canada board I am reviewing is one of the best bargains of about 30 years in high end hifi. Those old 70s and 80s recordings that on modern digital streaming services sounded thin or cheesey now sound full 3D and immersive. More modern stuff is just more so, or louder. Everything is now like a live performance.
John T.
Excellent Amp!
Purchased the HPA-S400ET as alternative to my Parasound HALO INT 5. I am running Magneplanar LRS+ speakers and felt the extra power may deliver an even better sound than the HALO. This is exactly what happened! Paticularly in the mid and high tonal area the clarity was outstanding. I was very happy with my HALO but am now pleased I went for the PURIFY Amp. Excellent delivery service and product quality from Audiophonics!
Vincent D.
GENALEX GOLD LION Tube Double Triode 6922 / ECC88 Gold Pins Le Genalex Gold Lion ECC88/6922 est un tube double triode high-end permettant le remplacement des modèles 6DJ8, ECC88, 6922, E88CC et 7308. Celui-ci intègre des...
Un ampli casque transformé
Sur un petit ampli casque Audio Technica monté d'origine avec des JJE88CC, la différence est flagrante. Probablement que ces tubes commençaient à fatiguer mais là je redécouvre mon ampli. Basses tendues et impactantes, medium naturelles et aigus qui restent doux. Une scène sonore plus large, un rendu moins «mou». Je ne regrette pas d'avoir payé plus cher que les tubes d'origine pour cet ampli qui m'accompagne depuis 7 ans déjà. Livraison Audiophonics rapide et soignée, au top!
Rapport qualité/prix imbattable !!
Ce modeste câble impressionne par son efficacité sur mon iFi One Signature, il sait restituer la musique dans toutes ces nuances. C'est à décourager d'investir dans des câbles 3 fois plus chers !! C'est pas bon pour le chiffre d'affaire de l'entreprise Audiophonics qui a l'art de dénicher des produits abordables et efficaces :) !
Andrius N.
VIBORG BP-603 Borniers Cuivre Pur Ø4.5mm (Set x4) Viborg propose avec ses BP-603 des borniers d'exception pour enceintes, grâce à une conception utilisant des matériaux particulièrement haut de gamme.
andrew
Amazing quality a big difference than same production from AliExpress.
Andrius N.
andrew
Perfect quality.
Peter L.
AUDIOPHONICS EVO-SABRE DAC Symétrique 2x ES9038Q2M USB GPIO Raspberry Pi SPDIF Bluetooth XLR RCA Successeur direct de notre fameux module DAC I-Sabre ES9038Q2M, le EVO-Sabre DAC 2x9038Q2M est une version symétrique du convertisseur avec une panoplie complète...
Ver nice DIY plug and play device
Works best with Volumio, in my opinion. With Volumio and the audiophonics-volumio-plugin, it is possible for me to skip tracks, control volume and shutting down proper with the remote control. Sound is very good - better than Topping DX3pro+, imo.
I paired it with pi3B+, 1GB RAM. Works fine! I build a case out of thin wood plates. Now, got a very good all-in-one STREAMER/DAC for 260 Euro!!! Nice!
But please Audiophonics-Team, make a big HINT in Github, that the old procedure of changing the kernel of raspy in order to get the I-Sabre-driver working, is NOT necessary anymore, because it is implemented in the newer os versions. That costs me hours of work, when i prepared a OS for plexamp!!!
Gerard T.
NEOTECH NEVD-2001 Câble Coaxial 75 Ohm Pur Argent Quadruple blindage Ø7.6mm Le NEVD-2001 est un excellent câble Coaxial avec une impédance de 75Ω, offrant une large bande passante afin de réduire le jitter et assurer une...
Magnifique...!
Installé sur rca canare 75ohms.
Avec dernier blindage raccordé que d un côté.
Ce câble sonne très analogique et naturel.
On ne se pose plus de question.
Gerard T.
Le câble
Bien respecter le dernier blindage que d un côté.
Musicalement ce câble est simplement "parfait"
Naturel et analogique.
Bravo
Sina M.
Look no further! Best performance vs price
Very powerful and clean amp. This is the best amp module out there for such a price range. Hook it up to a powerful PSU and take care of the wiring, you should have a great class D amplifier that can easily compete with the Big names for a fraction of their price.
Sina M.
MORNSUN LOF550-20B48 Module d'Alimentation à Découpage SMPS 550W 48V 11A PFC Ce module d'alimentation à découpage SMPS LOF550-20B48 délivre une tension de 48V et 11A pour une puissance de 550W. Ce module...
Great Amp - Extreme low noise and proper heat dissipation
I assembled this UPS for a power amplifier project using the recent 3e stereo module. The result is very satisfactory. It has enough juice to power up 2 ELAC Tower speakers and the noise floor is non-existence to my ear. I didn't hook up a fan to the setup firstly because I didn't notice a change in the output power (it is advertised 11 Amps using the fan) and secondly the large heatsink at the bottom does a great job dissipating the heat. Keeping the setup running for hours the housing is warm to touch (32 C) and the transistor heatsinks are not too hot (40-45 C). I am very happy with the result
Hubert S.
TINYSINE TSA6017 Récepteur Bluetooth 5.0 avec Entrée Microphone Le Tinysine TSA6017 permet d'ajouter une fonction de réception Bluetooth 5.0 à un système HiFi classique ou à un casque. Il devient ainsi possible de...
Utilisé pour donner un accès Bluetooth à un ampli HiFi classique d'environ 20ans d'âge. En test audio depuis 3 jours. Parfait : le niveau d'entrée est bon, un peu plus faible mais bien. Le son est excellent. Comparé à un bon DAC à 200€ (très bien noté dans les critiques) sur une chaine HIfI de qualité classique, c'est très proche : même rendu des graves et des aigus, même présence des voix et des instruments, sonorité un poil moins ronde. Excellent rapport Qualité-Prix. L'avenir dira si la durabilité est bonne.
Hocine H.
Magnifique
Utilisé pour bretelle RCA de 60 cm, ce câble est bien un Mogami, détaillé, pur, précis, compléte parfaitement les câbles d'enceintes 3103 de la même marque. J'ai utilisé des connecteurs RCA Xangsane à 10 euros les 4 et je me retrouve avec une paire de câble de très grande qualité pour moins de 15 euros. Merci
Hocine H.
Connecteurs RCA Plaqué Or Ø6mm (La paire) Doré Ces connecteurs RCA mâles de belle qualité profitent de contacts plaqués Or, assurant une bonne qualité de transmission et une excellente...
Pas mal
Bons connecteurs, de bonne qualité. Dommage que la soudure soit un calvaire si on souhaite souder le point froid car il est trop proche du point chaud (5mm environ). Ce même connecteur avec plus d'espace aurait été parfait car il est top pour ce prix.
michel m.
DAYTON AUDIO DSA115-PR Radiateur Passif Aluminium 30.9Hz Ø10.2cm Le Dayton Audio DSA115-PR est un radiateur passif pouvant être utilisé dans de très nombreuses installations, que ce soit pour la création d'une...
Renforce nettement les graves dans un caisson petit volume.
Guillaume V.
XANGSANE SP-6008AG Câble de Modulation Cuivre OCC Plaqué Argent Blindé Ø8.3mm Ce câble de modulation de grande qualité permet une excellente transmission du signal, et ce à prix abordable. Il se compose en effet de deux conducteurs en...
une très bonne surprise
je suis agréablement surpris par ce cable, je dois avouer que j'ai un faible pour les cables plaqués argent qui privilégie les aigus et médiums, ce qui permets des basses trés propre mais légèrement en retrait.
première paire de cable montés avec des fiches rca de la marque, trés satisfait de cet essai, je vais essayer une paire en xlr.
Guillaume V.
pas vraiment concluant
l'effet de pince est trop faible, du coup les fiches flottent un peu sur les connecteurs, pourtant les matériaux inspirent confiance et les soudures se font trés facilement, pas le cas de nombreuses rca.
par ailleurs l'utilisation avec le cable de la marque est vraiment satisfaisant pour ce qui est du son.
Dario G.
Dépanne bien, commode et pour un prix dérisoire.
Bravo audiophonics
Eric C.
FOSI AUDIO DA-2120C Amplificateur Class D TAS5352A 2x90W 4 Ohm Bluetooth 5.0 Noir Avec le  DA2120C ,  Fosi Audio  propose un  amplificateur Class D  polyvalent et abordable. Son étage d'amplification lui permet de...
Tres bon rendu.
Couplé avec des Spektor2 (Dali)
J'étais méfiant envers ces FDA.
Très bonne scène en Optique; du Volume et des basses que je suis obligé de moduler en fonction des enregistrements.
J'avais peur de basses électroniques, d'un rendu des aigus trop froid, trop clean-ique. Non, Impeccable.
Possible qu'a un volume au-delà de 65, ça sature. (suivant qualité de l'enregistrement) Je monte guère au delà des 40.
je ne me sers pas du Bluetooth; RCA décevant.
L'USB est surprenant en précision. L'optique: parfait (câble fourni relié à mon ordi)
Christophe H.
JANTZEN AUDIO COMPACT MKT 001-8080 Condensateur MKT Axial 160V 6.8µF Les condensateurs Compact MKT de Jantzen Audio sont fabriqués avec un film polyester métallisé de la lus haute qualité possible. Jantzen Audio est...
Pour remplacement des médiums aigus sur filtre enceintes Cabasse Doris M2, en lieu et place des condensateurs d'origine Wishay MKT 1822 (verts). Le résultat est très bon. Les médiums et aigus retrouvent leur place. Les voix initialement criardes retrouvent leur ton (surtout les voix masculines, qui n'avaient pas de caractère et manquaient de texture). Les instruments et voix sont mieux placés et respirent. Ce n'est serte pas aussi dynamique, explosif et aéré qu'avec des Jantzen sup Z que j'ai monté sur des Dali Zensor 7, mais je dois dire que je suis assez surpris par la qualité. Pour ma part je trouve supérieure aux Jantzen cross cap et z cap. Ils sont plus neutres. leur valeur est exactement celle indiqué à 0,01micro farad près gage de qualité de fabrication. Cerise sur le gâteau si vous ne voulez pas vous torturer pour trouver une place sur le filtre, ils sont de taille modeste. Environ la même que ceux qu'ils remplacent.
Arnaud B.
Excellent ampli
Merci Audiophonics pour les conseils m'amenant à ce choix d ampli !
Le resultant est bluffant
Cédric R.
SENDY AUDIO Rallonge Jack 4.4mm Symétrique Cuivre OCC 6N Plaqué Or 1.5m Cette rallonge symétrique Sendy Audio se compose d'un connecteur Jack 4.4mm femelle et d'un Jack 4.4mm mâle. Elle offre une excellente qualité de conception...
Bien mais onéreux
Ça pourrait être le câble d’origine livré avec le casque sivga p 2. Cher pour la longueur je trouve mais bon. Je n’ai pas trouvé de câble de 3 m pour le sivga.
Jose l.
TOPPING DX9 DAC AK4499EQ Amplificateur Casque NFCA Bluetooth 5.1 AptX LDAC 32bit 768kHz DSD512 Argent Pour ses 15 ans Topping dévoile un DAC / Amplificateur Casque extrêmement performant : le DX9.  En plus de ses très hautes...
très belle scène sonore
c'est un dac très bien construit , avec une très belle connectique . pour le son, c'est un plaisir musical. testé depuis 2 mois et comparé avec un smsl su-10 double dac sabre 9038 pro qui est très bon aussi, mais moins musical et moins équilibré .très belle réussite de la part de topping bravo.
Petit ampli qui tient ses promesses
Malgré mes craintes au sujet des FDA et de leur absence de boucle de rétroaction avec pour conséquence un faible facteur d'amortissement, cet ampli dépasse mes espérance en terme de qualité sonore (malgré des enceintes bibliothèque relativement basiques)
L'utilisation via Bluetooth. aptx-hd est vraiment très bonne même si les entrées numériques sont permettent une diffusion encore plus qualitatives.
Il est installé dans une résidence secondaire et c'est juste parfait.
Je l'ai également testé sur des enceintes colonnes et avec un streamer node, le son est excellent.
Xavier C.
DYNAVOX AUX-S PRO Commutateur Sélecteur Audio pour Entrées / Sorties RCA Argent Le commutateur Dynavox AUX-S Pro permet de commuter entre cinq appareils audio stéréo en entrée et deux appareils stéréo en sortie, sans avoir...
Boîtier lourd et massif (1kg !), tôle d'acier épaisse et façade aluminium anodisé. Ça inspire confiance et c'est stable.
Pour mon usage j'aurais préféré 6 entrées ...
Cet appareil remplace un préamplificateur inutile (sauf pour la platine disques analogique évidemment) pour attaquer les amplis de puissance via un simple potentiomètre de volume.
Bon fonctionnement, c'est bien le moins.
Un défaut, le sélecteur d'entrées est assez désagréable et "râpeux" dans sa rotation.
Emballage et expédition sans défaut, très bien.
Pierre F.
SABAJ A20A 2022 Amplificateur Stéréo Class D Infineon MA5332M Bluetooth 5.0 2x170W / 1x350W 4 Ohm Le A20A 2022 de Sabaj est un amplificateur Class D stéréo puissant et performant. Avec ses 2x170W sous 4Ω, il vous permettra d'accompagner même les enceintes...
Excellent "petit" ampli.
Pierre F.
SMSL VMV D2 DAC AK4499 Symétrique I2S XMOS Bluetooth aptX-HD LDAC UAT 32bit 768kHz DSD512 MQA Le SMSL VMV D2 est un DAC high-end, embarquant des composants haut de gamme au sein d'une architecture soignée, pour des performances d'exception. Au cœur du DAC,...
VMV d2
Un mot !
FANTASTIQUE.
Hocine H.
Top produit
Je devais splitter un câble Mogami 3103 de 12 mm avec 2 conducteurs 4 mm. J'ai pu poser les 4 splitters en moins de 5 min en appliquant un peu de vaseline sur les conducteurs, ça passe sans effort. C'est efficace et tellement plus jolis pour termier les câbles HP. Je recommande vivement !
Hocine H.
Des frissons
Après quelques heures à dénuder, gainer, thermo coller, graisser, visser pour obtenir 2 câbles de 2 m, je me faisais une joie de les tester.
Quelle n'a pas été ma déception, je pensais vivre une histoire d'amour avec ces câbles, mais ils n'avaient pas de vie.
Alors j'ai vérifié une deuxième fois la construction, mais ils étaient corrects ; j'ai alors relu les avis élogieux et j'ai constaté cette fameuse période de rôdage...
J'étais sceptique sur le rôdage des câbles, mais après 15/20h continues (sans les écouter, j'ai laissé tourner en boucle un titre) ça a été le coup de foudre.
Ces câbles sont exceptionnels pour le prix, détaillés dans le haut du spectre, des médiums précis et, beaucoup de basses à mon goût (c'est subjectifs et ça se corrige).
Ce câble est comme une fleur qui a besoin d'éclore et une fois l'éclosion faite c'est un pur bonheur à en donner des frissons ; je ne regrette pas cet achat. Foncez à ce prix !
Thomas H.
NEOTECH NEX-OCC RH Connecteurs XLR Mâle / Femelle Cuivre UP-OCC Plaqué Rhodium Ø13mm (Set x4) Les connecteurs XLR Neotech NEX-OCC RH, vendus par 4, profitent de contacts en Cuivre UP-OCC plaqué Rhodium, afin d'offrir une parfaite conductivité et...
Fabulous Connectors
Perfect in every way, at each end of the audio spectrum. Small break-in time, in fact new sonic details emerged as well. Used as a primary set from my DAC to Preamp, they are well worth the higher entry point. Thanks Audiophonics!
François C.
IBASSO DC06PRO DAC / Amplificateur Casque Portable 2x ES9219C 32bit 384kHz DSD256 MQA 16x Ibasso dévoile une nouvelle version de son DAC / amplificateur casque portable DC06, le DC06 Pro. Compact, il intègre 2 puces DAC ES9219C et des boutons de...
IBASSO DC06PRO DAC
Apporte un gros + sur iPAD. Son de meilleure qualité. En revanche rien de mieux sur un Samsung S23 Ultra.
NEUTRIK NC3MX-BAG Connecteur XLR Mâle 3 Pôles Plaqué Argent Ø8mm (Unité) Ce connecteur XLR mâle 3 pôles Neutrik NC3MX-BAG permet un montage rapide et facile, composé d'uniquement 4 pièces et d'aucune vis. Il...
Comme sa version femelle, bonne fiche qualitative et neutre .
Fiche de bonne facture avec un rapport qp très bon. Facile à mettre en oeuvre.
Cote son, elles me semble assez neutre .
zeljko j.
Good wire. Very fast shipping . I will buy from you again.
Jochen M.
LHY AUDIO BATT-USB Alimentation Linéaire Régulée sur Batterie 5V 2A Ce module d'alimentation linéaire régulée LHY Audio BATT-USB fonctionne grâce à quatre accumulateurs 21700 d'une capacité de 4900mAh...
Basically a fine thing
I bought two devices. Both have an audibly positive effect on music playback with the devices now supplied with clean power (rpi/WiiM/Dac). The first device is flawless. The batteries of the second device are weak. The batteries are empty after approx. 3 hours. Two green LEDs still light up, then the device switches off. On the first device, the batteries last for at least 5 hours without any problems until all LEDs go out.
Marc L.
TRIANGLE BP400 Fiches Bananes Plaquées Argent Ø2.2mm 3.8mm² (Set x4) Les fiches bananes Triangle BP400 assurent à la fois un contact optimal entre le câble et le bornier du fait de leur forme, tout en assurant une conductivité...
Ces fiches sont parfaites. Très faciles à mettre en oeuvre et le système de vis permet au câble d'être parfaitement attaché.
olivier P.
TOPPING PA5 II Amplificateur Class D Symétrique 2x100W 4 Ohm Noir L'amplificateur PA5 II de Topping est un modèle compact et puissant, adoptant une structure totalement symétrique et un circuit d'amplification Class D innovant,...
Pour HF en actif
Utilisé pour driver une compression 114db en actif asymétrique afin de supprimer le souffle.
Essai transformé, l'oreille à 20cm de l'embouchure du pavillon plus de souffle il reste juste un très faible bruit électronique inaudible avec un peu de recul.
Léger ploc à l'extinction suivant ordre d'arrêt et chauffe quand même malgré la faible puissance demandé mais moins que mon ancien classe A.
Donc je préconise cet ampli lilliputien pour cette application et pour le reste je croise les doigts
Stephane N.
Acheté pour un second système, c’est un très bon ampli, bien fabriqué et aux qualités musicales réelles.
Stephane N.
Mise à niveau réellement audible
En remplacement d’un MCap standard dans le filtre d’une paire de JERN AUDIO 11s, l’opération n’est pas si simple, la taille du Suprême est 4 fois plus importante !
Mais l’entreprise et le temps passé en valent le coup.
Tout est bien plus homogène, certaine crispation des aiguës ont disparue ( câbles Nordost sans pitié ).
L’investissement financier est fondé.
Ravi de ce produit.
Ralph L.
TOPPING LA90D Amplificateur Discret Class AB 2x120W / 1x180W 4 Ohm Noir Topping propose maintenant l'excellent LA90 dans une version utilisant des circuits discrets, le LA90 Discrete. On retrouve ainsi un amplificateur puissant offrant d'incroyables...
Vielen Dank an das Audiophonics Team!
Seit 35Jahren ist HiFi für mich ein Hobby. Viele Geräte sind seit dem gekommen und auch wieder über den Gebrauchtmarkt gegangen. Was soll man sagen? Ab und zu braucht man
halt wieder was neues … Dieses Mal sollte es ein Class D Amp werden um in meinen langen
Hörsitzungen nicht so viel Strom zu verbrauchen. So groß würden meiner Meinung nach die Unterschiede nicht sein wenn man doch nur die Endstufe tauscht …dachte ich. Doch nach dem Audiophonics mir 2 verschiedene Class D Endstufen geschickt hatte wollte ich schnell wieder meine alte Endstufe zurück … doch die war bereits verkauft. Dann sind 2 von diesen kleinen LA 90 d angekommen … Und jetzt bin ich wieder sehr glücklich mit dem Klang in meinem System. Die Maximale Lautstärke ist sowieso nicht wichtig für mich und nur wenn es laut sein soll sind hier Abstriche zu machen … klar mit den kleinen Verstärkern kann man keine Bäume ausreißen. Einen LA 90 d würde ich nicht für Lautsprecher unter 88dB empfehlen … Und zwei auch nicht für Lautsprecher unter 86 dB Wirkungsgrad. Ansonsten können die alles was ein Verstärker um 5000 Euro kann … die Frage ist also nur wieviel möchten Sie ausgeben? Wie laut hören Sie? Und welche Lautsprecher haben Sie?
Stephane N.
AUDIO BASTION X-PAD III Contrepointes Aluminium Acier Inoxydable Ø50mm (Set x4) Conçues en acier inoxydable polie à la main et aluminium T6061, ces contrepointes sont pensées pour réduire efficacement les vibrations de vos...
Excellente qualité et très bon résultats sous un AUDIOMAT Arpège Référence.
vincent g.
Trés satisfait !
Il vient remplacer un vieux Technics SU-V460. Le Fosi est alimenté par un préampli DAC Tangent et alimente des Focal Chorus 705v.
Tout s'accorde très bien, un son clair et précis comme ce que je souhaitait.
Jyrki K.
Jyrki
Dry and precise. No Color the sound. Hard, not soft.
I recommend.
Jyrki K.
AUDIOPHONICS PSU-HC Alimentation Linéaire Régulée 5V 5A 60VA Cette alimentation linéaire régulée PSHP permet de disposer d'une tension et d'un courant de sortie de 5V 5A propre et stable. En sortie on retrouve deux...
Jyrki
The transformer was loose and allowed to move and rattle inside. Just a little tightening of the screw and the problem is gone.
The power supply supplies power to the Volumio Rivo network player and the Pro-Ject Pre Box S2 Digital DAC.
The power source opens up the sound and brings more separation. It feels like there is more power and the dynamics increased. Hears more details in the recording.
I recommend.
Gilbert H.
Bon Connecteur, mais...
Un bon connecteur d'un prix tout à fait raisonnable. Seul regret, la partie métallique du connecteur n'est pas reliée à la broche centrale par une vis comme sur les autres connecteurs de ce type, elle n'est donc pas reliée au chassis , dommage... donc une étoile en moins
jean michel G.
TOPPING D70 PRO OCTO DAC 8x CS43198 XMOS XU316 Bluetooth 5.1 LDAC aptX-Adaptative 32bit 768kHz DSD512 Noir Le DAC Topping D70 Pro OCTO embarque de nombreux raffinements propres à un produit audio haut de gamme. Puces performantes, horloges ultra faible jitter, interfaces...
Belle surprise
Après avoir longuement utilisé un Audio GD 19 SINGULARITY qui m'a donné de belles écoutes, ce Topping est un passage pour l'écoute du DSD. DAC très musicale, apporte une belle précision des notes. Passage directement en mode NOS des sa mise en route.
Emmanuel A.
NEOTECH NES-5004 Câble Haut-Parleur Cuivre UP-OFC 2x4mm² La gamme NES-5000 de Neotech intègre des câble à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Dans cet esprit, le NES-5004 va...
Un excellent câble qui ne paye pas de mine malgré un prix bas
Pas besoin d’autre chose
Yassin B.
j'avais l'ancien modèle dont j'étais très satisfait.
Suite à sa panne, j'en ai profité pour une mise à jour.
Encore mieux.
Pour ceux qui o,t une imprimante 3d, je mets à dispo un boitier :
https://www.thingiverse.com/thing:6473605
bonne écoute,
Un câble secteur impressionnant
La taille du câble est énorme et la fabrication est vraiment de qualité. Branché sur un ampli casque Audio GD, le résultat auditif donne une belle musicalité. Du grave à l'aigu tout semble parfaitement équilibré. Pour un prix raisonnable c'est un très bel équipement.
