Efthymios X.
As per title really.
Efthymios X.
As good as it always was
Plus reliable. That's it :)
Patrick R.
Avis clients - Il y a 21000 avis.
Peter S.
FIIO BTR5 2021 Amplificateur Casque Symétrique DAC Récepteur Bluetooth 5.0 2x ES9219P CSR8675 XMOS 32bit 384kHz DSD256 MQA Le FiiO BTR5 2021 est un amplificateur casque compact et nomade, offrant une excellente qualité de conception et une polyvalence certaine, pour vous offrir une...
First impressions
Hi!
Just tried with tidal + bluetooth + audeze LCD2C headphone. The sound is big, detailed, loud, maybe a bit dark. The stage is open, but the mono in front of me is not very clear. (It's hard to beat the Quad ESL57 speakers in this.)
I don't really believe that compressed bluetooth can be good, but it sounds way better than anything bluetooth.
I wonder what the symmetrical output can produce, altough I don't know wher I will get a good quality 4 pin 2.5 mm minijack...
Lars S.
Awesome value for money
I‘m using the tone board (Signal-Input via USB) in combination with a JDS Labs Atom Amp and different headphones (AKG K702 and diverse Beyerdynamic) – CD quality music of all kinds of genres (CD player and Tidal Hifi). My decision to buy the tone board was based on the awesome measurements at audio science reviews. I have not been disappointed, the sound is very good and all in all this is a superb DAC considering value for money (I was not expecting such a good performance for just around 100€).
I’m glad that I found audiophonics.fr, otherwise I would be waiting for my tone board for another few weeks
super produit
Les fiche banane WBT cuivre pur il sont magnifique pour des câble section 10mm très bien merci !
Fortuné M.
Parfait !!!
Facile à souder, très bien conçues, elles m'ont permis de remplacer des embases soudées sur circuit imprimé qui étaient dorées sur la masse et en métal à ferrer les ânes pour le point chaud.... Avec un prix modéré, je recommande
David J.
Waouww
Incroyable !
Je pèses mes mots mais je suis ébahi par la qualité de ces jumpers !
Je les ai mis en remplacement de jumpers Atlas Hyper3.5 (qui ont basculés sur mes surrounds pour le HC) sur mes colonnes Monitor Audio Bronze 5.
Les graves sont vraiment plus présents, nets et détourés ; Il en est de même sur toute la bande passante qui semble, du coup, vraiment plus large, plus fluide et aérée...
Le potentiel de mes enceintes s'est enfin dévoilé !
Je n'aurais jamais cru que le simple changement de jumpers pouvais apporter une telle différence d'écoute.
A tous les sceptiques concernant la qualité des câbles, je vous conseille de tester ces câbles ! Vous ne le regretterez pas...
Je redécouvre ma musique, et j'envisage sérieusement l'achat des câbles HP de chez Phono1877.
Merci Audiophonics de proposer des produits aussi qualitatifs...
David J.
Praticité
Ce sélecteur de source me permet d'éviter de débrancher et de rebrancher mes différents câbles provenant d'amplis HC et Hifi en fonction de celui que j'utilise avec mes colonnes.
C'est un produit simple mais très efficace !
Câblage OCC, plaqué argent : il n'y a aucune perte dans la qualité du signal qui y transite...
Je recommande fortement cet accessoire !
Merci Audiophonics pour la qualité du matériel fourni (rapport qualité/prix génial) et pour la rapidité de la livraison.
cable HDG pas trop cher
j'ai fais un commentaire sur ce câble avec des connecteurs RCA cu/te elecaudio TE-RC 90 G; ce cable a donc deux paires en cu OCC,plus une masse en tresse, j'ai choisi la paire rouge et noir pour la phase et les jaune et bleu pour la masse,ça n'a pas d'importance,inverser si vous voulez jaune et bleu pour le point chaud,par contre ne dissociez pas les paires ,le résultat est mauvais. voila allez du courage,et bonne écoute. pi.r
ELECAUDIO TE-RC90G Connecteurs RCA Cuivre Tellurium Or Ø8.5mm (La paire) Ces connecteurs ont été conçus pour vous offrir une très grande conductivité grâce au Cuivre Tellurium.
RCa HDG
pour avoir déjà utilisé ces RCA en cu te,d'excellente qualité,mais un peu compliqué au niveau de la masse. j'ai trouvé une solution, sur la bague, séparée du corps de la masse, un coup de pince coupante au milieu, et après j'enlève un bon millimètre, et avec une pince je plis les deux parties coupées vers l’intérieur,pour faire passer le fil de masse,( ça fait comme un V) et pouvoir le souder, sans qu'il dépasse du corps,afin de pouvoir visser le capot.et comme ça tout passe sans problème. j'ai fais un câble avec ces RCA et du câble WM audio AC-02 en cu/occ. ce câble a deux paires,rouge et noir,et jaune et bleu; j'ai choisi les rouge et noir pour le point chaud,et les jaune et bleu pour la masse. la tresse de masse du câble je ne l'utilise pas coté CD et je la soude avec la paire de masse a l'arrivée,coté ampli.( bien sur attention au fil qui pourrait être en contact ou il ne faut pas). après brancher et se régaler; la définition la clarté des détails,l'image sonore,entre les enceintes et en profondeur,est très bien pas de projection, les musiciens ne sont pas sur vos genoux, mais bien a leur place; pour avoir fait un câble avec les mêmes rca,et du neotech 3004, je trouve ce câble proche,en rendu sonore. bien sur ça demande un peu de peine mais le plaisir final en vaux la peine,n'hésitez pas, RQP excellent. pi.r
Yvan L.
Pas mal
En accord avec les autres avis, il suffit juste de faire attention car elles sont très bien.
Yvan L.
Super câble !
Après avoir déplacé une de mes enceintes de 10 mètres et j'ai commandé ce qu'il manquait , et le résultat et à nouveau parfait,
OPA1611 AOP Amplifié Simple DIP8 (Unité) Cet AOP monté sur support DIP8 utilise une structure hybride. En effet, celui-ci se compose d'une puce AOP Texas Instruments OPA1611 suivie d'un étage...
OPA1622
Très OPA et fonctionne bien avec une TPA3255 / 3251.
Il a une meilleure scène sonore que le 627 et il dispose d'une très faible distorsion avec un équilibre agréable dans tout le spectre.
Par rapport à un NE5532, c'est mieux, plus neutre et meilleure séparation des instruments. A ce prix, super upgrade ! Fonctionne aussi avec un DAC AK4497 contrairement à mes Burson Audio 5vi.
BURSON AUDIO SUPREME SOUND OPAMP V5i AOP Double Hybride DIP8 (La paire) Le V5i de chez Burson est un AOP audio hybride, intégrant à la fois des circuits intégrés et des composants discrets pour des performances...
Burson AOP V5i
Super AOP, il remplace dignement un OPA1622 dans un Ampli à base de TPA3251. Très bon équilibre dans tout le spectre, scène sonore très fine et détaillée. Belle séparation des instruments et des basses tendues à volume plus haut. Il est meilleur en tous points que le OPA1622 et OPA627. En revanche, ne fonctionne pas avec mon DAC à base de AK4497... donc je retire une étoile.
rené k.
Ampoule Navette bleue
Livraison rapide malgré le Covi 19 ampoule à led qui redonne une nouvelle jeunesse à un receiver Marantz 2225L aux couleurs
bleues d'origine appareil qui date des années 70 fonctionnant à merveille
philippe C.
TRES BIEN
OUPS, impressionnant pour son prix.
Grave bien tendus.
philippe C.
NEOTECH NES-5005 Câble Haut-Parleur Cuivre UP-OFC 2x2.5mm² La gamme NES-5000 de Neotech intègre des câble à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Dans cet esprit, le NES-5005 va...
Très bien pour le prix
Bonjour ,
j'ai associé ce câble en bi câblage avec un autre câble en cuivre argenté dans un premier temps en bi câblage sur des martin logan, puis en monocablage avec l'autre câble donc 2X2,5mm.
Ce câble est neutre à mon sens et les médiums aigus sont beaux et transparents. avec le deuxième câble en cuivre argenté , je sens des basses plus tendues. J'ai essayé de nombreux câbles dans ma vie et à des prix 1à à 15 fois plus chers, et là agréablement surpris. Ce câble est monté aujourd'hui sur des enceintes valant 20ke. Comme quoi...
Eric M.
Embase rca de qualité, commandé pour upgrader une technics sl 1200mk2 , facilité de montage . Expédition très rapide . Recommande, merci .
Jonathan D.
ATOHM WT-D75-G Bornier Encastré pour Enceintes Plaqué Or Ø75mm (Unité) Le bornier WT-D75-G, tout comme l’ensemble des modèles proposés par Atohm, est équipé de bornes largement dimensionnées en Laiton sans...
Livré par deux
Le bornier correspond parfaitement à ce qui est décrit mais attention il est livré par 2. Je ne crois pas avoir lu cette mention, du coup je me retrouve avec 4 borniers pour ma paire d'enceintes...
Ce produit est bien vendu à l'unité, le fait que vous en ayez reçu deux est une erreur de notre part. Vous pouvez nous renvoyer une paire si vous le souhaitez.
Merci à vous.
Sylvain D.
Produit extraordinaire
Je pense que ce produit mérite qu'on en parle plus. Ce préampli aux humbles prétentions de 40 euros est un produit absolument splendide qui n'a que peu à envier aux modèles les plus onéreux qui puissent exister.
Je m'en sers depuis plusieurs mois sur un système très onéreux (dac Weiss Médéa+, ampli McIntosh MA6600, casques à plusieurs très haut de gamme - Focal Utopia, Audeze LCD-4, Kennerton Odin, JPS Labs Abyss, Stax SR-009...), des enceintes Focal Electra et des Dynaudio Contour et c'est un bonheur absolu.
Ce préampli est très transparent, et s'intercale entre un dac et un bloc ou un dac et un intégré (pour ajouter la sonorité des tubes) en toute transparence, sans dégradation du signal.
Attention, en préampli derrière un bloc, le réglage du volume est trop rapide et imprécis, je pense que le produit a été conçu pour rester derrière un intégré ou en tous cas un autre préampli, à transistor, ce qui permet de régler le volume de manière plus fine.
Bon, bref, que dire ensuite sinon qu'il y a tout ce qu'on peut attendre d'un produit haut de gamme : l'aigu est raffiné, le grave profond, la scène ample, les médiums onctueux et riches comme le tube sait le faire, aucun détail ne semble manquer après son insertion dans le système.
Les tubes d'origine, certes chinois, sont bons. Rien à signaler, ça marche. Mais c'est vrai que les 5654W JAN GE sont plus vivants et expressifs dans le haut médium et à mon sens apportent un plus, ils valent le coup.
Ce petit appareil n'est donc absolument pas limitant et il ne faut pas avoir honte de l'intégrer dans une chaîne très onéreuse, il remplit à 100% la fonction d'apporter une sonorité tube et un réglage grave/aigu.
Attention toutefois, au déballage le grave et l'aigu sont au minimum, si on ne s'en rend pas compte on peut le trouver un peu bouché...
Très bien aussi de n'avoir que deux tubes, on peut l'utiliser sans craindre d'avoir à racheter une brouette de tubes le moment venu.
C'en est si impressionnant qu'on en vient à se demander pourquoi dépenser plus cher.
Les seuls reproches se situent au niveau du confort d'utilisation : un peu trop léger (le poids des câbles peut le faire basculer), qu'une seule entrée/une seule sortie, et pas de vraie prise IEC pour pouvoir jouer avec d'autres câbles secteur. Espérons qu'un jour FX-Audio ponde un modèle supérieur offrant ce qualités. Côté son, c'est en tous cas déjà idéal.
Bernard H.
très bon choix
Transformateur d'excellente qualité : bon rendement (chauffe très peu) ; écran électrostatique efficace ; tension secondaire qui reste stable à pleine charge et accepte même une petite surcharge momentanée. A recommander sans réserve.
Jean-Pierre L.
IRS2092 Module Amplificateur Stéréo Class D 2x 400W 4 ohm Ce module amplificateur stéréo est idéal pour tout amateur désirant un son de qualité Haute Fidelité avec une bonne puissance sans les...
Bon ampli sur HPs à pas trop grande sensibilité (souffle audible sinon)
Cet ampli est très bien, mais comme tous les ampli classe D, attention toutefois à ne pas l'utiliser avec des HPs trop sensibles (
alain m.
alain m.
DAYTON AUDIO RS150-4 Reference Haut-Parleur de Grave 40W 4 Ohm 92dB 48Hz - 4000Hz Ø15cm La gamme "Reference Series" de DAYTON AUDIO redéfinie à elle seule la notion de rapport qualité/prix sur le marché ultra concurrentiel des...
excellent Hp pour des petites biblio
François P.
Pas donné, mais d'excellente facture. Les borniers sont top. J'ai choisi le petit modèle et ils sont tout à fait suffisants en taille pour du câble nu 2.5mm² par exemple.
Marc L.
VIBORG VF502G Connecteur IEC C15 Cuivre Pur Plaqué Argent / Or 24k Ø20mm Ce IEC C15 Viborg VE502G est idéal pour créer des câbles d'alimentation d'une grande qualité. Il utilise en effet de très bon composants,...
IEC Viborg 502 G
Très bon rapport qualité prix. Le connecteur est de qualité exemplaire pour le prix. Au niveau du son , il est équilibré . Aucun registre est mis de l’avant comme j’ai pu le constater avec d’autres connecteurs .il demande un certain temps de rodage pour s’assouplir mais il est déjà très bon dès le départ . Ces commentaires s’appliquent aussi aux connecteurs schuko de la même marque et série . Cette série amènent plus d’assise que les connecteurs Viborg 501 .
Hugues C.
Super !
Ce convertisseur procure une réelle amélioration de la qualité d’écoute. Les basses sont fermes et appuyées sans excès, les aigus sont présent sans clinquant et la séparation des canaux est d'une grande clarté tout en étant très équilibrée.
Convertisseur installé sur une unité centrale fonctionnant sous Linux Mint 19.3 reliée a un ampl intégré Thecnics SU X911 associé a 2 paires d'enceintes, 3A apogée et Triangle Titus TZX.
Aucun problème d'installation sous Linux Mint (plug & play).
Henry G.
Emballé dans des journaux Chinois ce coffret a une très bonne finition, toutes les faces sont en épaisseur 3mm a l'exception de la face avant 8mm.
Dominique G.
Produit d'un RQP imbattable, utilisé sur VDH 352.
Je recommande sans problème
Marc L.
FURUTECH FI-48 NCF (R) Connecteur IEC C15 Cuivre Plaqué Rhodium Traitement Alpha NCF Ø20mm Le Furutech FI-48 NCF (R) fait partie de la gamme de connecteurs de la marque intégrant le matériau NCF et profitant, comme pour l'ensemble des produits Furutech,...
Furutech Fi-48 NCF (R)
Le boîtier extérieur du connecteur IEC est d’aspect très robuste et l’intérieur respire la qualité.
Je l’ai utilisé en remplacement d’un connecteur IEC Viborg VF 502 G ( triple plaquage ) monté sur un cable furutech FP-3TS-762 associé à un connecteur schuko VF 502 G. Le son se rapproche globalement du connecteur IEC Viborg .
Par contre, il est plus défini et étendu. Il demeure naturel malgré le fait que le plaquage est en rhodium.. Pour faire une comparaison plus honnête , j’aurais dû utiliser le même plaquage mais après différentes lectures j’ai tenté l’expérience du plaquage rhodium. Je ne le regrette pas . Ma seule réserve est au niveau du prix. A mon avis, Le connecteur Viborg demeure un excellent rapport qualité prix.
J’ai aussi la possibilité d’essayer un connecteur IEC Neotech Gold. Par rapport au connecteur Furutech et Viborg, je le trouve moins équilibré . La présence du médium grave l’emporte sur les autres registres. Il est toutefois bien conçu et peut s’insérer favorablement dans le montage de cable. Le connecteur Furutech demeure pour le moment le meilleur connecteur IEC que j’ai pu essayer. En ce qui concerne le prix, je le laisse à l’appréciation de chacun . Autrement, je serais curieux de connaître les différences au niveau du son entre le connecteur IEC FI -50 NCF et le Fi-48 NCF. Seul le boitier extérieur les distingue et le Fi-48 est déjà très robuste .
Très belle fiches
Bornier vraiment de qualité, utilisées avec des fourches ou fiches bananes, dans le cas de fourches le serrage est top,
Seul bémol j'ai vissé le câble parce que le soudage avec le plaquage n'est pas évident.
Stephan C.
Great preamp for SL1200's
I wanted to upgrade the phono-stage in my Xone-92 mixer and this FX-Audio Box01 preamp does the job. I can now use the line-in of my mixer and get a loud and clear signal from my SL1200's.
The sound is much better than the Xone-92 phono preamps, louder and less noise.
Mickaël P.
livraison toujours ici rapide au top , câble hyper souper j'aurais pas cru je le recommande parfais
Mickaël P.
Connecteur RCA Coudé 90° Plaqué Or Ø6mm (La paire) Ces connecteurs RCA à petit prix mais cependant de très bonne facture sont coudés à 90°, et donc particulièrement pratique pour des...
bonjour j'ai commandé les connecteurs coudés pour pouvoir branché du dsp a l'ampli et je ne suis pas déçu du resultat je recommande ces connecteurs
Giuseppe P.
Vraiment superbe sans se ruiner!
Bernard L.
coffret A28
Deuxième réception après échange du premier coffret griffé sur les cotés.
Cette fois, ce ne sont plus les cotés mais la tôle de dessus ( heureusement sur le coté interne).
Quant à la tôle de dessous, toujours du gruyère alors que ce n'est pas mentionné sur l'annonce, ni visible sur les photos.
Quant à l'avis, bien sur, comme il est négatif, il n'apparaitra pas sur la fiche produit, tout comme le précédent.
Les perçages du fond sont normaux.
Comme précisé dans la fiche ces boitiers sont destinés au montage des kits de la même marque.
Fil de câblage Cuivre UP-OCC PVC
Une alternative économique au câble ;
"NEOTECH SOCT-20 Fil de câblage Cuivre UP-OCC PTFE 0.5mm² "
Même qualité, tres bien si l'isolant Téflon n'est pas indispensable
Ole B.
High quality
Easy to install.
Works perfectly.
Keeps everything promised.
Myrielle m.
super la classe
Furutech NCF est vraiment super rien à dire avec des câble secteur haute gamme la déférence est flagrant franchement merveilleux un son reposant pas fatigue à la fin on respire enfin merci !
benoit l.
rapport qualité/prix au rdv
utilisé en remplacement sur des JBL MODEL 4301B ,Fréquence de coupure max de 2500hz en total accord avec le tweeter LE26, le rendement sonore est parfait (ps: pour les puristes , pensé a redimensionner l’évent bass reflex on sort la dremel), des bass très agréables car la fréquence mini reste honorable pour ce prix.
Écrou nylon M3
Impeccable en complement des entretoises Nylon M3
Entretoise Nylon M3x10mm
Très bien pour isoler un pcb du boîtier.
Prevoir Ecrou Nylon M3 si besoin
Gaines Thermo Rétractables
Second achat, la qualité est constante, les diamètres proposés sont très bien...
Ideal pour avoir un petit stock
plaque à bornes
Idéal pour le câblage/fixation petits composants, d'amplis à tubes,
Un peu cher mais le produit respire la qualité
christian A.
Excellent cable secteur au rapport qualité prix imbattable
Cable tres naturel tres équilibré dynamique tres supérieur aux autres cables proposés souvent à des prix excessifs.......pas de duretés belle dynamique , il est surprenant pour le prix.....peut-etre que son excellent blindage et sa constitution en multibrins cuivre plus gros que ce qu'on trouve couramment (20 brins de 3/10 de mm) y est pour quelque chose.
il est parfait pour les amplis de puissance comme pour les sources si votre source est transparente....vous l'avez compris je le recommande vivement par contre il est tres rigide et ce n'est pas du tout pratique aussi prenez le d'au moins 1.5m à 2m.
avec fiche furutech fi-e38 et FI-12L, plaquées or, branché sur mon intégré, autant dire que c'est le câble le plus cher que j'ai fait...je voulais essayer et c'est plutôt une bonne surprise et je pense que le rhodium aurait apporté une brillance artificielle et fatigante.En effet, je m'attendais un câble terne, pour reprendre les termes des forumers mais il est juste naturel et ne gonfle pas spécialement le bas.Il est défini,cohérent, aéré et pas agressif du tout; juste ce qu'il faut dans mon système.Le grave est plus propre.
Par contre, il est plus rigide que FP SO32N (câblé sur la barrette mpc6).
Livraison rapide.
Sylvain F.
Attetion au montage - isolation élec
Attention quand vous monterez les circuits. Les boitiers TDA7293 sont connectés au pole négatif de l'alimentation. Donc soit vous isolez votre radiateur, doit vous isolez bien les TDA. Sinon risque de cour circuit!
Connecteur aviation 3 pôles
Très bien pour réaliser un câble 'signal
Les prises sont toutes petites et les pins assez rapprochés trop juste à mon avis pour un câble secteur (noté 250v 3a)
Le câble suivant passe bien ;
NEOTECH SOCT-24 Fil de câblage Cuivre UP-OCC PTFE 0.2mm²
Aucun problème d'isolement et contact franc
Enfin le diamètre de perçage est de 10mm
Fil de câblage 0.2mm²
Très bon câble monobrin
Isolant PTFE simple à dénuder, se torsade facilement...
Utilisé en câblage interne pour le signal (une paire torsadee)
Rien à redire à part que seule la couleur couleur rouge est dispo
Tony R.
AUDIO-GD NFB-28.38 DAC ES9038Pro DSD / DXD 32bit / 384kHz Amanero HDMI TCXO L'Audio-GD NFB-28.38 intègre l'exceptionnel DAC ES9038Pro et assure des performances audio hors normes. Il intègre également USB Amanero et I2S HDMI....
Bravo Audio GD
Tout d'abord un grand merci à Audiophonics pour la livraison express du DAC et pour les conseils prodigués.
Quelle surprise de voir la qualité de finition du produit et aussi la télécommande en full aluminium !! Vraiment valorisant...
Le DAC est relié en usb à mon PC optimisé pour les écoutes de FLAC et DSD (tweak windows+fidelizer+foobar)et il est branché à un ampli de puissance Yamaha qui envoie ses watts sur des enceintes BC Acoustique.
Les premières notes m'ont tout de suite donné le sourire, la dynamique est extraordinaire, l'image sonore s'est déjà stabilisé et la transparence est impressionnante.
Toutefois, la basse est brouillon, le bas médium est assez envahissant quelque soit la musique envoyée et il y a quelques duretés par ci par là. Un rodage s'impose, j'ai donc laissé tourné le DAC pendant quasi une semaine avant de reprendre mes écoutes.
Et là c'est WAOUH!! Malgré mes tweeters compression, la musique s'exprime de manière vivante et sans aucune agréssivité et pourtout les attaques sont foudroyantes et les détails fourmillent sur tout le spectre sans que le rendu soit analytique. Les voix sont charnelles et très centrées, bref que du bonheur.
Le cable USB fourni est bon mais je suis persuadé qu'en changeant ce dernier, la transparence, les timbres et l'image s'amélioreront d'avantage.
Laurent M.
Bien pensées.
Enfin des fiches bien conçues.
Déjà le corps en plastique transparent pour s'assurer du serrage optimal du câble .
Ensuite la masse métallique réduite pour que le signal soit le plus direct.
Le diamètre idéal permet d'enfoncer fermement la fiche jusqu'au bout des borniers sans les abîmer.
La possibilité que la partie dénudée du câble ne soit pas bloquée après la seconde vis.
La possibilité de serrer également la gaine .
Et enfin le résultat subjectif excellent.
Petite précision la photo montre une 2 fiches et il est précisé la paire il faut donc 2 paires côté ampli et 2 paires côté enceintes.
furutech fi-e38 gold
Livraison rapide comme d'habitude avec audiophonics en dépit des circonstances actuelles.
En ce qui est du produit, la fiche est globalement de bonne qualité, montée avec du furutech fp-tcs31.Le système de serrage contrairement aux commentaires, je le trouve plutôt efficace, et évite la destruction des brins.Par contre, il y a un soucis quand il s'agit de refermer la fiche, il est quasiment impossible de mettre les serres câbles; il faut mettre ces derniers au préalables mais le câble ne glisse plus au moment de refermer la fiche...a moins d'appliquer du lubrifiant que je n'ai pas...Il y a 2 paires de serre câble, 1 en métal et 1 en plastique, j'en ai mis un de chaque pour pouvoir faire glisser le câble.Problème de conception ou câble trop gros???Le fp-tcs31 fait 16mm de diamètre et passe tout juste.Je suis tout de même satisfait, elle est de bonne facture et le rendu sonore est plutôt agréable avec le fp-tcs 31.
