olivier P.
Déception !!…
Matière sans doute qualitative .. mais finition très moyenne un brin corrodée et mal ébavurée… on trouve mieux à 10 fois moins...
Maik B.
Maik B.
Fast shipping.
The sound is excellent. Ranked 5th out of many...
Avis clients - Il y a 19110 avis.
Szilard M.
Very-very good quality, my DIY amplifier is happy now and the fading of the LED ring with an Arduino program is a cool extra in standby mode. :)
Szilard M.
Transformateur Torique 60VA 5V 12A Ce transformateur torique de haute qualité délivre une puissance de 60VA 5V 12A et sera un choix idéal notamment pour la réalisation de vos projets DIY nécessitant ces tensions.
A quality transformer
.. but due to voltage drop it cannot feed the Raspberry Pi4 with my stabilizer module, I had to use a DC-DC step-up converter after rectification/stabilization. With that, everything is fine now. When looking for a Raspberry/DAC based transformer, choose a higher voltage one. Apart of this, quality is really top notch, the transformer is absolutely silent, quality work.
Szilard M.
TOPPING D30 PRO DAC Symétrique 4x CS43198 32bit 384kHz DSD256 Argent Puissant et compact DAC symétrique, l'étage de conversion numérique/analogique du Topping D30 Pro se base sur pas moins de quatre puces Cirrus Logic...
A matter of taste
Great DAC, measures excellent and sounds very refined. From my experience it fits systems rather with relaxed highs because this kind of Cirrus-based DAC has it's own clarity. Mid region, mid tones and vocals aren't that emphasized like with an AKM DAC, bass is well-controlled. Top quality overall and the simultaneous use of XLR and RCA outs make this an amazing "preamp" too (in PRE-mode) for e.g. a 2.1/2.2 system (where you feed your sub/subs from the RCA outs while main system is fed from XLR). All-in-all, a neutral, precise sound without much emotion. It just doesn't has its own sound. Some people like this, some not. A matter of taste. For us it lifted a bit on the highs which came very handy so we give it 5 stars.
Szilard M.
Cleanness and transparent sound with power
This is the first time I ordered this Hypex module based amplifier of Audiophonics and I don't regret it. It arrived into to a luxurious home's audiophile system and the owner (a friend of mine) was blown away by the quality and cleanness of sound. Excellent product, thank you Hypex, thank you Audiophonics.
Szilard M.
AUDIOPHONICS MPA-S125NC XLR Amplificateur de Puissance Class D Stéréo NCore NC122MP 2x125W 4 Ohm Version XLR du Audiophonics MPA-S125NC. Un amplificateur de puissance Class D basé sur la technologie Hypex Ncore. C'est une solution d'amplification compacte,...
Beautiful sound
Szilard M.
Great quality
Excellent button of great quality, I can only recommend.
Exelent steamer
Brancher avec alimentation Ifi élite 12v 4a et usb neotech neu argent sur interface digital di20 audio gd qui est branché via hdmi (pangy premier cardans pl argent 0,5m) sur dac r2r r28 audio gd. Et ami cayn st200. Superbe image superbe audio du grave profond à l aigus montant et lumineux. Ont sens la puissance la dynamique et la spacialite avec transparence naturel et ultra musical. Par apport à mon lecteur cd. Sais vivant et jubilatoire. Bon si il faut chipoter un chouilla l infra grave manque très peut d assise. Mais pour le prix d un cable secteur moyen de gamme. Le RQP et exceptionnel. A consommer sans aucune modération. Merci à audiophonics de proposer de vrais bijoux tj à pris contenu et réaliste.
Rémy D.
LINDY Câble Ethernet RJ45 Cat 8.1 S/FTP LSZH Plaqué Or 1m Le câble Ethernet RJ45 profite de la dernière norme Cat 8.1 permettant la prise en charge de bande passante jusqu'à 2000MHz. Le câble dispose d'une...
Gain en qualité et vitesse
Après avoir remplacé mes câbles cat 5e par ces câbles, j'ai gagné sur mon réseau interne presque 10Mbps grâce à la propreté du signal. Le câble est plus gros que du câble ordinaire, il est aussi plus rigide mais les connecteur rj45 sont de bonne qualité et ne bouge plus une fois enfichés. Je recommande (j'ai mis entre boitier fibre et ma box puis de ma box vers du cpl...)
Rémy D.
PANGEA PREMIER SE Câble Ethernet RJ45 Cat7 Triple Blindage Cuivre Cardas Plaqué Argent 1.5m Si vous disposez de périphériques audio high-end connectés en réseau, alors il est essentiel d'utiliser des câbles Ethernet de qualité pour permettre à vos appareils de délivrer...
Aération et silence
Dès la pose du câble, le son m'est apparu bien plus calme (moins de perturbation) se traduisant par de meilleurs silences, son moins agressif. Un très bon câble pour l'audio
markus s.
Perfect Bass
Very good bass, better than the TCS31. For me on the amplifier with Electra speakers. But the treble is too resolved and slightly harsh. Whether with gold or rhodium. With good recordings it's ok, with bad ones too many details, somehow slightly metallic. It now has 60 hours on it.
Grégory O.
Module Softstart de Commande et Temporisation pour Amplificateur Cette carte permet de commander l'allumage d'un amplificateur. Elle assure la fonction stand-by, soft-start, temporisation et protection thermique. Elle limite aussi...
Carte ok
Tout fonctionne correctement. Le schéma fourni en description par audiophonics est appréciable. Livraison toujours Ok après plusieurs commandes.
Prise coudée de très bonne qualité, avec une FI48or sur un SP1100 ça marche très bien sur un R7.
Magnifique
Câble de grande qualité monté sur des Furutech FI48R. C'est très propre, net, fin, et plus rapide oui.
Testées avec un Yarbo Sp1100 les FI48R apportent de la propreté, mais ce FP-P55N va plus loin et amène une exécution immédiate de la musique. C'est très impressionnant.
Diametre
J’apporte une petite précision sur le diamètre extérieur de ce câble
Il fait 6.5 mm et non 4.6 mm
Essayé avec une chute avec des prises rca rean en modulation c’est absolument bluffant et Il tient la comparaison avec des câbles à 3/400 €.
Je viens de le monter avec des rca Elec Tellurium, une gaine cuivre, soudure mundorff 10% et gaine de finition. Soit 40€ le tout en 1 mètre.
Seconde claque, qui renvoie le ultra haut de gamme très cher au rang d’imposteur.
Essayez par vous même, c’est une révélation.
Damien N.
Très complet, de bonne qualité et performant
Ce tout petit ampli fait bien ce qu'on attend de lui. En l'occurrence il remplace ma vieille chaîne compacte qui sonorisait mon PC. La finition est bonne, jusqu'à présent je n'ai pas eu de mauvaises surprises et je l'utilise principalement avec les entrées bluetooth et optiques.
J'apprécie les réglages disponibles pour ajuster les graves et les aigus, et c'est ce qui me l'avait fait choisir face à un Elipson Music Center BT équivalent. Alors ça ne donnera pas autant de contrôle que l'égaliseur à bandes de ma vieille Sony mais ça suffit largement.
Elsa A.
Module symétriseur DRV134 Stéréo Le module DRV 134 permet de symétriser tous signal stéréo ligne RCA classique. Il trouvera son utilité pour brancher une source audio ou un préamplificateur asymétrique dépourvu...
Bruit de fond
Bonne idée d'une alim non symétrique, mais le bruit de fond augmente dès qu'elle augmente mème au delà de 5V (tests avec une alim faible bruit : ça ne change rien)
Jean Michel P.
Excellente fiche banane
Excellente fabrication et rendu sonore parfait : son consistant et raffiné . insertion très franche. Utilisée en mode vissage avec du câble HP de section de 1,5 mm2 que j'ai replié à l'extrémité .
La meilleure parmi les nombreuses que j'ai testées .
Merci à Audiophonics de proposer ce modèle de qualité
Trés bien pour un smartphone
Je rechercherchais un petit dac pour connecter à mon smartphone Samsung,afin de lire ma musique stockée sur une micro sd(que du lossless ou supérieur),suite à un essais peut concluant avec un FX Audio dac X6.
C'est très très bon, même en utilisation sur un système classique ampli rega et enceintes monitor audio.
L'appli permet de sélectionner plusieurs filtres passe-bas (c'est subtil mais il me semble que ça modifie l'impression d'effet 3D )
En tout cas,quand je pense à mes début en hifi il y a plus de 20 ans avec des dacs séparé et mes centaines de CD et ce que maintenant on peut faire avec ce minuscule appareil à 100 euros et de la musique stockée sur une minuscule carte mémoire,c'est vraiment bluffant.
Valentin R.
Good heatsink with predrilled holes
But one of them may be not enough for TT5200 amp, I tested it with 24V power supply and it gets really hot, so bought the second one.
Valentin R.
MEAN WELL RS-100-24 Module d'Alimentation à Découpage SMPS 100W 24V 4.5A Cette alimentation à découpage de chez Mean Well offre une puissance de 108W, une tension de 24V DC et un courant de 4.5A. Avec un système de connexion universel, il se montera...
used it for TT5200 amp.
Valentin R.
Unexpectedly good experience
Assembled a small amplifier, used MEAN WELL RS-100-24 power supply, for this power supply one Heat Sink Radiator Black Anodized 176x60x33mm (that has already holes for the transistors) is not enough, final version will have two of them in ECO Case EP1001825 180x250x100. Can only recommend it.
Massimo L.
Buon prodotto
Per il prezzo che costa, è un buon connettore XLR.
Massimo L.
Câble de Modulation XLR Femelle - XLR Mâle 1m CANARE L-2E5AT Blanc Ce câble XLR, bien que vendu à prix abordable, propose une conception de très bonne qualité. Son câble Canare intègre deux conducteurs en...
Sezione del cavo ridotta.
Si tratta di un cavo economico, funziona senza nessun problema ma il cavo è di sezione davvero piccola.
Massimo L.
Buon prodotto
Massimo L.
ECCELLENTE ! !
Ordinato domenica, spedito il lunedì e ricevuto giovedì. Imballaggio semplice ma molto efficace: complimenti AudioPhonics!
Dunque io cercavo da tempo una schedina per portare le uscite di un filtro passa basso attivo per subwoofer, da sbilanciate a bilanciate. però avevo due problemi : lo spazio limitato a disposizione, e l'alimentazione del filtro 15 Vcc non duali. Quasi tutti i circuiti RCA/XLR necessitano di alimentazione duale. Io avevo a disposizione invece 15 Volt CC molto ben filtrati, e non avevo nessuna intenzione di aggiungere una alimentazione dedicata, e non avendo lo spazio avrei dovuto aggiungere uno "scatolotto".
Lo spazio libero all'interno del filtro passa basso era di 50-55 /60-65 mm. Questa piccola PCB soddisfa entrambe le mie necessità. Quindi verificato questo, ho ordinato. La scheda si presenta bene, buone le saldature, e SOPRATUTTO DOTATA DI CAVETTI SCHERMATI con relativi connettori. La scheda è sicuramente di costruzione Cinese, ma ripeto di buona qualità Le aree di massa sulla scheda sono più che abbondanti. Nessun circuito integrato è zoccolato, essendo tutti in versione SMD.-SOC, e neppure servirebbe. L'alimentazione in CC della scheda va dai 5Volt ai 24 Volt, io la utilizzo a 15V e funziona benissimo. Non capivo come potessero lavorare due DRV134 senza alimentazione duale. Molto semplicemente il circuito funziona con un LM7805 sul ramo positivo, mentre il ramo negativo viene generato da un LM2662M: semplice e geniale: in sostanza il circuito lavora con +/-5V, ottenuti riducendo i 15 Vcc del filtro passa basso attivo. La scheda penso che abbia una uscita di 2rms per ramo. Proprio quello che mi serviva per pilotare un finale BTL in classe D ! Il circuito ha anche un piccolissimo diodo LED rosso che indica la presenza della alimentazione. La circuitazione di presenta molto "standard" quasi presa da una application note della Texas Inst. La misura della PCB è esattamente quella indicata : 50x50mm e l'ho montata senza nessuna difficoltà nel medesimo case del filtro passa passo. Funziona davvero molto bene, nessun ronzio nessun disturbo. Ancora complimenti a AudioPhonics che riesce a "trovare" questi prodotti!
Branislav K.
ERATO M7 Préamplificateur à Tubes 12AX7 / 6N4 XLR Symétrique Le Erato M7 est un préamplificateur à tubes haut de gamme profitant d'une conception intelligente et soignée, lui permettant de délivrer des...
Salut Daniel,
il est possible de vous contacter pour me donner de meilleurs avis sur cet appareil. Je serais intéressé par lui, mais il est impossible de le trouver sur Internet.
Merci Brano K.
Luis V.
FX-AUDIO TUBE-06 MKII Préamplificateur à Tubes 2x 6N3 DAC ES9018K2M CM6642 Subwoofer 24bit 192kHz Noir Le FX-Audio TUBE-06 MKII est un préamplificateur à tubes abordable et efficace. Son étage de préamplification se base sur l'utilisation d'une paire...
Very good product.
I bought this dac/preamp to feed a headphone amplifier and i was stunned with this dac-tube preamp combo, my headphones never sounded so good, and i have a much more expensive high-end dac.
This is the best value for the money.
Vincent b.
très bon dac
dac ayant toutes les qualités qu'on peut en attendre.
les (-) j'ai déjà eu de plus beaux timbres mais le produit est neuf...
les (+) excellente dynamique et suivi mélodique. Maillon sensible car
c'est le premier dac qui offre autant de différences d'écoute à chaque changement de câble numérique. Meilleur résultat obtenu avec le câble AES/EBU de Canare. J'ai obtenu un resultat encore meilleur en le découplant avec 3 VIABLUE TRI SILVER et un mode NOS plutôt que OS préconiser par Gustard
FURUTECH FI-48 NCF (R) Connecteur IEC C15 Cuivre Plaqué Rhodium Traitement Alpha NCF Ø20mm Le Furutech FI-48 NCF (R) fait partie de la gamme de connecteurs de la marque intégrant le matériau NCF et profitant, comme pour l'ensemble des produits Furutech,...
Impressionnant !
IEC monté sur un Yarno SP1100 déjà utilisé avec des Viborg, c'est mieux y a pas à dire. Voir mon commentaire sur la Schuko. Bon we
Wouah
En premier lieu je tiens à remercier Patrick pour son analyse des prises secteur, super sympa et pro de ta part ;)
Je me suis effectivement décidé à me lancer sur ces connecteurs haut de gamme Furutech et j'aime mieux vous dire que durant le montage j'avais comme une impression de serrage de fesse assez prononcé me demandant si j'avais pas claqué 460€ dans du vent lol. Après avoir monté les Schuko et IEC sur mon Yarbo SP1100, j'ai lancé un cd juste sur mon petit Shanling Tempo. Ma première sensation fut un soulagement personnel; la décontraction revenue je me suis surpris à entendre mes Focal s'amuser avec la musique comme jamais. En effet mon ampli a trouvé plus de sérénité, les timbres, les fines dynamiques, la scène bien en place, tout est là mais en plus maitrisé, le son est plus propre je dirai. J'avais des Viborg qui me donnaient déjà de bons résultats mais là on passe un cran au dessus, c'est assez impressionnant. Prochaine étape, passage de mon dac R7 en Furutech aussi.
Encore merci à Patrick et aussi à Audiophonics, bonne journée à tous
eddy-pierre m.
Sélecteur de source XLR 3 pôles 2 vers 1 Cablage PTFE Cet appareil permet de relier plusieurs sources analogiques sur votre préamplificateur, votre amplificateur intégré ou vos enceintes passives.
Je voulais un selecteur pour mes pré-ampli HC et stéréo vers mon ampli Mc Intosh, je craignais des pertes, mais non. AU TOP ce produit. Meme pour les installations haut de gamme je recommande vivement.
François S.
Produit de qualité
Reçu rapidement.
3 détails.
Les vis supérieures et inférieures me paraissent un peu faibles. Je vais sans doute les changer.
Livré avec 4 pieds. Je suppose qu'il faut percer des trous pour les fixer.
La face arrière qui m'a été livrée est dotée d'un emplacement pour prise IEC.
Emmanuel G.
LUDIC POLARIS Câble secteur Schuko IEC C15 Cuivre UP-OCC plaqué Or 2m Le Ludic Polaris est un câble d'alimentation de grande qualité. Il intègre en effet des conducteurs en Cuivre UP-OCC Drawn® brevetés, permettant...
Câble sérieux
Un très bon câble secteur compte tenu du prix au mètre ! connecteurs de grande qualité - écoute détaillée sans être analytique ni agressive - scène sonore large - extinction des notes aigües convaincante - pas de défauts prononcé mais câble très rigide !
Stéphane M.
WONDOM PS-BC12114 BCPB0 Module d'Alimentation BMS / Chargeur de Batterie Lithium 26650 avec Protections Module berceau d'accumulateur 1x 26650 avec sortie USB-A protégée et port direct pour alimentation et montage sur Raspberry Pi.
Nouveau connecteur
Parfait pour alimenter un raspbery zero pendant des heures
Quel est le type de connecteur présent sur la carte (facilite son branchement)) ?
Jean C.
sounds very good and compliant with Linn Openhome player
Just finalized the port to run openhome on it, compliant with Linn devices for multiroom installation
see : https://github.com/jchassin/ohPlayer
open issue to contact me for support if needed
Hasni Z.
MUNDORF BL100 Self à Air 1mm 0.39mH Les selfs à air, sont pour des raisons physiques, imbattables en terme de précision sur la restitution des impulsions, et sont libres de toute distorsion...
L’imprégnation de vernis du bobinage est un plus.
Très bon. Rapport qualité/prix
Hasni Z.
JANTZEN AUDIO CROSS-CAP Condensateur 400V 10µF Les condensateurs Jantzen Audio Cross Cap MKP 400V sont considérés comme étant le meilleur rapport qualité/prix pour la conception de filtres passifs...
Utiliser pour RC Zobel, très bon rapport qualité/prix.
Hasni Z.
MUNDORF MRESIST SUPREME MRES20-6.8 Résistance 20W 6.8 Ohm La gamme de résistance Mundorf MResist SUPREME propose des produits d'une qualité exceptionnelle. Avec un réel impact sur la restitution sonore, des...
Très bonne résistance
Utilisée en L PAD pour atténuation après montage d’un premier filtre, je n’ai pas constaté de dénaturation du signal.
Très bonne résistance pour le passage du signal et vu le prix, cela serait dommage de s’en priver
Hasni Z.
JANTZEN AUDIO SILVER Z-CAP Condensateur 800V 10µF Les condensateurs Jantzen Audio Silver Z-Cap permettent de maintenir une parfaite neutralité sonore et un très bel équilibre tonal. Il sont...
Excellent pour le signal aigu
Vu la taille imposante de ce condo, on ne peut que saluer la qualité de fabrication.
Quand à l’écoute associé au D260, ça reste cohérent et très naturel, sans trop en faire niveau définition. Très musical, neutre, pas ce côté métallique retrouver sur d’autre marque ni de coloration. L’aération est bien là, bref c’est équilibré.
Une valeur sûr
Hasni Z.
Traitement et Livraison ultra rapide par audiophonics!
Merci à vous :)
Pour la qualité du câble, il reste plutôt silencieux grâce à son isolation au Téflon qui évite le contact direct avec l’isolant externe en PVC.
Utiliser pour le câblage interne bornier-filtre et filtre-mediumboomer.
gabriel m.
AUDIOPHONICS TPA-SW25F Amplificateur 2.1 Class D TPA3116D2 Bluetooth 5.0 2x 50W + 100W 4 Ohm Noir Amplificateur class D avec sortie droite / gauche et basses. Aigus et graves réglables séparément, volume du caisson de basse réglable, filtre passe bas réglable.
Très bien !
J'aurais vraiment aimé voir quelques graphes dans la description !
Sinon vraiment pas mal. J'ai monté un 2.1 avec du matos de récup : deux enceintes 30w JVC et un sub Samsung. Très content du résultat. Il faut juste penser à l'alimentation non fournie. Je n'ai pas réussi à me connecter au bluetooth mais je n'ai pas acheté pour ça alors, attention si c'est important pour vous !
Le code pour l'appairage Bluetooth est : 0123
Laurent M.
SHUGUANG 12AX7B / ECC83 Tube d'Amplification (Unité) Ce tube Shuguang 12AX7B pour amplificateur vous permettra de remplacer un modèle équivalent mais aussi les tubes 12AX7, ECC83 et 12AX7-T ou bien une...
Parfaites
Lampes de qualités et contrôlées.
Livraison rapides et très bien protégée.
Merci.
Jozef Š.
Great sound upgrade, NOT 75 Ohm !!!
Excellent build quality, fine sound upgrade for interconnection type...but it is not 75 Ohm cable like was in description before my order...well not so suitable for digital coax type cable construction.
Jozef Š.
Unusable for coaxial cable
Excellent build quality but not suitable for coaxial cable.
Stunning cable
I run this cable for amplifier, CD and conditioner unit. It is sonically the most gorgeous I’ve used bettering Nordost by a long way.
I have it terminated with solid silver IEC’s and UK plugs and again, sound is stunning, especially the mid range depth and realism.
Stunning cable
I have used many €20-€30 p/m cables and so glad I jumped to this price level and even more so that the sonic improvements have been worth every penny.
Naturally, the first few weeks are a little light and muddy in the bass, but other out of the box includes more air around vocals abs terrific timing.
A very worthwhile cable upgrade.
Excellent cable
I changed out a V1 Nordost Blue Heaven RCA to a self made cable and the results were astonishing. It makes one wonder why you pay silly money for a brand with good marketing when you can make as good, or better, for a fraction of the costs.
François D.
Préampli McIntosh C2300
Très bonnes lampes sur la partie ligne du préampli C2300. La scène est plus large qu'avec les tubes d'origine avec un très bon medium et des graves qui se tiennent.
Roman R.
Compared this cable with the stock cable that goes with Marantz PM-8006 and instantly heard tighter bass. No soldering. Connectors are also Elecaudio.
Benoit s.
KLEI CLASSIC HARMONY BANANA Fiches Bananes Cuivre Pur Plaqué Argent Ø4mm (Set x8) Suite à une longue période de recherche et développement de KLEI, la marque propose des fiches bananes aux performances exceptionnelles, notamment...
excellent!
je viens de d'installer ces fiches banane sur un câble audioquest relativement bas de gamme et je suis très agréablement surpris par le résultat sonore obtenu. La différence est plus que subtil!
La finition est certes un peu "cheap" mais pour celui qui cherche avant tout un nette gain sonore sans se ruiner c'est parfait
