Gianfranco P.
crystalline
Alexandre G.
Thierry C.
Avis clients - Il y a 19513 avis.
Robert g.
Very nice DIY budget chassis with slim profile
This galaxy GX348, is very well designed and finished product.
When assembled, it fits to perfection, with no glitches. Aluminum parts are finished very well. Side could be flipped just for desing variations, and could be used as heatsinks. Front and back plates are well brushed and anodized, and easily to drill/mill.
This is my second GX chassis I purchased - for an AKM 4499 DAC project - and I am very content of both (first hosts a full valve phono stage).
Only one problem: the last chassis was not well packed ( weak protection on the sides ), and 2 corners of the bottom plate were slightly bent at transport :((
Hope next time audiophonics will be more careful when dispatching these GX chassis, to properly protect them inside the box !
That's why I will give 4 * only rating.
Robert g.
Decent looking solid aluminum feet
Nice decent black finish, and good anti-slick patches on top/bottom.
Maybe not the ultimate surface finish, but theses are under the base plate.
Good deal for the price.
Robert g.
Good power on/off button with nice finish
Well build (full aluminum case), not obtrusive design, flat profile as seen from the side, nice and smooth click feeling, and nice black finish. It comes with a silicon o-ring for perfect mounting. Could fit even a 10 mm face plate, if needed. Recommended.
Robert g.
ARMATURE HECATE LT Interface USB SPDIF XMOS Xcore 208 Asynchrone TCXO (Version DIY) Armature propose désormais son excellente interface USB SPDIF XMOS dans une version simplifiée, mais toujours très performante, permettant de la proposer...
Amazing value USB /SPDIF interface for DAC
Me and my friend bought this module when catching a promo. Until that moment I was using GUSTARD U12 32Bit / 384KHz USB XMOS DSD. I just build a small thick walled (4mm) alu chassis for this module, and served the power supply voltage separated from the USB cable, by using an audiophonics usb separator cable, and an external no-fancy well made smps wall power supply. The module need some serious burn in , be aware. Once this settled, the sound quality is top notch.
First of all, what pleased me was the resolution, control and the depth of the lowest register! Also, the dynamics rendering is superb. Soundstage is very correctly rendered, with no exaggeration, you could detect easily instruments locations (separation of sound sources is good), with a very good sense of depth. The timbres of acoustic instruments are reproduced faithfully, a must in classical music auditions. The attack on aggressive well mastered tracks (percussion instruments, or plucked classical instruments) is as should be. Human voices sound natural, without being harsh or on the analytical side. Also, large scale recordings ( big classical orchestras) are a joy to listen.
Just a brief example: the first track on Erato CD 'Joyce DiDonato - 2014 - Stella di Napoli' it's enough to check for making an idea on how Hecate LT knows how to shine. This Hecate LT thrashed away the good old Gustrad, which was a good companion.
Be aware, this Hecate LT works very well on I2S, as me and my friend tested it with top DAC, if wanted to implement inside the DAC chassis.
If wanted just for the SPDIF use, buy the finished in chassis version, it worth the difference :)
For Daphile/ Roon users: Hecate LT works like a charm on Linux based audio players without drivers.
Highly recommended!!!
Robert g.
Top class chassis full aluminum
This is a very nice designed full aluminum chassis, with a remarkable quality of finishes, both for the solid thick aluminum faceplate and for the anodizing of the rest of the case plates. Also, the shape and finish of the massive ALU knobs (delivered in the package) is outstanding. For the front plate, the cut-out is exactly dimensioned for 'TEK Vomit backlight white dB with calibration module' (but check with the store support for accuracy), as the front plate has the exactly window cut-out for the TEK Vu-meters, but it also has the necessary cut-out milled on the back of the front panel for the shape of the VU-meter plastic box.
The bottom and back plates are not hard, but very easy to drill/mill for the needed holes. In my case, the chassis hosts a led biased Mu-follower line preamplifier based on E88CC.
Highly recommended!
Robert g.
Decent sturdy chassis for big amps
This is a perfect low cost/ high quality DIY chassis for big projects, if you are using amp modules that have already the PCB mounted onto the heatsinks. Internal volume for 4U- 300mm/400mm depth is so big, that you could build a 5+1 amplifier inside easily by using ready heat-sinked modules. I was using it to re-box an Anthem 225 amplifier, and all the elements has space to cool inside. I was using the spare top
'HIFI 2000 Perforated housing cover 19 "300mm' to allow air circulation.
As the box cannot bear a massive weight on it's own in basic version, my advise is to use this spare bottom: 'HIFI 2000 Inner baseplate 425x260mm (300mm Series)', or to reinforce the chassis base with some L aluminum profiles. It was not my case, as the bottom was reinforced by the 2 massive heat-sinks of Anthem modules. The finish of the 4mm face plate is top notch! Also, the black matte anti-scratch paint of the top/bottom covers is of good quality. The bottom and back-plate steel is easy to process (drilling, milling), as the material does not have a high hardness. Despite the chassis seems to flex without the top cover mounted, when assembled, the whole structure become rock solid! My project weights about 15 Kg, and the box is like a rock-stone once assembled. Highly recommended for tight budget projects.
jean jacques m.
Très bon cable coaxial
Je recommande sans hésiter.
jean jacques m.
extraordinaire carte son
superbe carte avec une sonorité époustouflante.
livraison super rapide.Je recommande+++
Olivier R.
Produit plus en stock mais remplacé rapidement par son petit frère en 3m par Audiophonics (merci pour la réactivité !)
A l'air solide et de bonne facture, fonctionne bien, très satisfait.
Olivier R.
Fonctionne très bien
Acheté pour sonoriser deux PC sans encombrer (un sur l'entrée USB et l'autre sur l'entrée AUX), ça fonctionne très bien.
Petit bémol, impossible de configurer la sortie numérique coaxiale sous Windows 10 (son saturé qui craque), mais la même machine s'en sort parfaitement sous Linux donc à priori pas un problème de l'ampli. On s'en sort avec l'entrée AUX qui suffit largement à mon usage.
Très satisfait.
Holger B.
TINYSINE AUDIO-B PLUS TWS Module Récepteur Audio Bluetooth TWS aptX Stéréo / Double Mono Si vous souhaitez fabriquer un amplificateur Bluetooth simplement et pouvoir streamer votre musique depuis votre smartphone, alors le module AudioB Plus de TinySine est un...
bitz
Works.
But beware, the aux in is a simple (mechanical) switch on the aux plug. This is different than the i2s module from tinysine. Works only on the module, you can't use a extention cable.
Marc F.
JQAUDIO DS2206 Transformateur Audio 600:10K (Unité) Transformateur Audio 600:10k permalloy avec capsule epoxy.  Peut convertir un signal symétrique en asymétrique ou inversement (chaque enroulement...
Isolation de charge indispensable
Ce transfo est indispensable pour toute conversion de montage As/symétrique . C'est un transfo audio transparent du signal entre niveaux hauts/bas. Il autorise le montage en inverse avec brio. Interrupteur de boucle de masse à prévoir. Très bon Item
Marc F.
Haute Qualité du micro de mesure
J'ai chargé le fichier de calibration sur le site de Dayton, cet équipement se combine parfaitement avec REW6 comme outil de mesure. J'ai vérifié la mesure origine avec un calibrateur de micro et multimètre Labo , tout identique. Coffret complet.
Giuseppe B.
Ottima
Costa il giusto e suona molto bene (nel mio caso simile ad un modello rodiato).
Ottimo soundstage e controllo sul basso.
So bene che non è rame ma il mio udito ha dato il responso e paragonata ad altre spine ben più costose spesso si lascia preferire.
Juergen N.
Great device!
This is a great tool for the raspberry pi. I even used it with an Allo USBridge Signature. connecting to a DAC with I2S sounds even better than with USB. Just ordering the FiFo from IAN Canada to get a precise clock.
MICHEL B.
NEOTECH NEMOI-1220 Câble de Modulation Argent UP-OCC RCA-RCA Double Blindage Ø10mm 2m (La paire) La série NEMOI du constructeur Neotech est l'aboutissement de longues recherches dans le domaine du câble audio. Le câble de modulation Neotech NEMOI 1220...
Excellent câble RCa, mais cher
Ce câble est très neutre, c'est parfait, et sa résolution sur les voix est absolument extraordinaire.
Les personnes qui parlent semblent présentes dans la pièce (auditorium de 34 m2).
Les instruments de musique brillent par leur présence.
Donc le plus par rapport à un câble Sommercable Epilogue est bien là, mais la différence de prix aussi.
Je pense que cela vaut la peine sur du matériel très haut de gamme (Cabasse Colonne 135 et amplis McIntosh).
Merci à Audiophonics pour le suivi de l'approvisionnement qui a posé quelques problèmes suite à cet afreux virus COVID 19.
Franck L.
Serrage inefficace.
Personnellement je les soude et là j'en suis satisfait.
Jean-David R.
Très content
Utilisé dans un système full tube déjà conséquent après avoir essayé de câbles de marques bien connu et plus chère, j'approuve au vu de son prix ce HP-25OCC.
- Il a complétement effacer cette dureté dans les aigus, sans enlever de dynamique ou de détails.
- Les voix et les instruments se place et se distingue mieux sans confusion même avec beaucoup de son. Meilleur placement.
- Les basses sont tenu et percute sans excès.
Globalement c'est un câble plutôt posé, analytique et facile à intégrer. il ressemble plus à une écoute de mélomane que de hifiste mais n'Est-ce pas la l'intérêt ? écouter sans ce poser de question !!!! ce câble les fait ROYALEMENT !!!!!!
Franck S.
AUDIOPHONICS BT60DSP Amplificateur TPA3116 Bluetooth 2x50W / 4 Ohm Le BT60WDSP est la troisième génération des amplificateurs / DAC BT60. Il intègere désormais une interface Bluetooth 5.0 ainsi qu'un processeur DSP
Bluffant
Pour amplifier une paire de QA3010 comme système Hifi de bureau. Il est connecté à un convertisseur USB Fostex équipé d'un contrôleur de volume.
Extra vu le budget.
Aurélien D.
Très correct pour le prix
Petit préamp sans prétention qui dépanne bien. J'ai essayé 4-5 paires de tubes dessus (Mullard, RCA,...) et des opamp plus haut de gamme pour le fun et il se défend bien. Contrairement à d'autres avis je ne pense qu'il fasse mieux que mes autres préamplis.
Face à un rotel RC972: Le FX-Audio a un bruit de fond sensiblement plus élevé et moins de dynamique. Il est un peu plus "rond" suivant les tubes. Différent mais clairement pas mieux.
Face à Luxman CL34 : Le tube-03 ne lui arrive pas à la cheville. Tout est moins bien. Le prix est beaucoup plus faible que le Luxman mais ca s'entend.
En résumé c'est un bon petit préamp compact et économique mais ca s'arrête là. Pensez à allumer votre ampli en dernier et à l'éteindre en premier si vous souhaitez éviter un "plop" désagréable dans vos haut parleurs.
Bruno C.
ALLO boitier pour DigiOne et Pi 3
Le rapport qualité / prix est très bien.
Je suis pas très bon bricoleur, mais sur Internet on peut trouver des video de montage ... bref, montage facile et clair.
Seul petit regret : non transparent : suivi visuel des leds impossible.
Enea S.
Not bad at all
I needed a digital out to feed my external DAC. I used Spdif cable (have not tried the optical) and it sounds pretty good. Before I was using the hdmi cable through the tv optical out, It definetry improved the sound: more detailed. bass very accurete and deep. I think it needs somme time to wear out ...
FREDERIC G.
Très bon dac
Je suis satisfait du résultat et donc de l'association avec mes JMR bliss.
Le son est très propre et précis. Les basses sont également très bonnes.
Je l'utilise principalement en usb mais je le trouve aussi très bon en bluetooth (En partant du principe qu'il y a une compression). En effet le son garde sa clarté ce qui est très appréciable sur ce mode (tv connecté dans ce mode). Curieusement je le trouve moins clair et précis sur l'optique (console connecté).
Dans l'ensemble je suis donc très satisfait et quelle présence quand le son sort des enceintes !
Compléments
Je suis toujours aussi satisfait de ce DSP.
Avec le recul, je complèterais mon avis en revenant sur l'interface androïde dont l'utilisation n'est pas des plus précise, surtout lors de l'utilisation des curseurs gain +/- ou facteur Q où il n'est pas possible à l'instar du réglage des fréquences, de renter une valeur.
Il est possible de choisir l'unité pour le réglage du delay en ms ou en cm (en " aussi).
En ms il y a le possibilité d'incrémenter de 385 réglages différents par pas de 0.0208ms alors qu'en cm, cette incrémentation est de 277 par pas de 1cm.
Je croyait que les deux évoluaient symétriquement, mais non.
Le réglage en ms est donc plus "précis" (de la à percevoir des différences)
Plus dans le domaine des suggestions, 3 voies et 10 fréquence pour chacune, j'aurais réparti les fréquences différemment en attribuant plus de fréquence au médium.
Par exemple sur les 30 dispos j'en aurais réservé 7 pour le grave qui demande dans mon cas moins d'intervention, 16 pour le médium qui demande lui plus fréquence et 7 pour l'aigu.
Pour une configuration active avec des coupures à 300/4000HZ par exemple je pense que ça aurais pu le faire.
Je suis en trois voies, mais en passif sur le passe bas et passe haut du médium/aigu, je dois donc utiliser une voies du DSP pour le mid/high donc ma coupure basse étant à 100hz 10 bandes de 100hz à 20khz, c'est un peu juste, ça oblige à faire des choix.
Dernières précisions, si vous voulez intervenir sur le 20khz, il faut lorsque l'on tape sur le clavier virtuel la fréquence, rentrer 19999.
J'ai intégré mon DSP avec sa clef bluetooth dans un coffret métallique, cela limite chez moi la porté BT à quelques mètres 5 environ.
Gilles J.
Boitier capot
Belle fabrication, facile à travailler, taille réduite, excellent rapport Q/P.
Joanny B.
ALPS RK27 Potentiomètre Stéréo Axe Lisse Haute Qualité 50K Ohm Le ALPS RK27 50KA2 est un potentiomètre stéréo haute qualité disposant d'une résistance de 50kΩ et d'une courbe de progression logarithmique....
Potentiomètres ALPS 50K log
Très bien.
Livraison très rapide de Audiophonics en Colissimo. Colis livré, le surlendemain de la commande, dans la boîte aux lettres, sans signature.
Emballage de qualité.
Cyril M.
Efficace et pas cher, c'est Canare que je préfère.
Je voulais un câble isolé pour relier mon DAC arcam rPac et mon ampli SMSL SA300. Après m'être pris la tête pour savoir quelle était la meilleur option (du pas cher jusqu'à des prix franchement abusifs), j'ai contacté le service client Audiophonics qui m'a conseillé cette solution.
Pour 40€, rapport Q/P impeccable. Je recommande chaudement ce câble ET les conseils d'Audiophonics.
Jonathan D.
Excellente prise qui se démonte complètement pour facilité le montage de gros câble (rigide sur une petite longueur) dans mon cas le YARBO SP-1100PW, très satisfait.
A B.
Je suis parti sur cet cable pour relier mon Bluesound Node 2i et Dac Soncoz SGD1. Le son est très équilibré neutre et bien raffiné avec un charme analogue. Un équilibre général et un plaisir d’ecoute.
Luis G.
Produit exceptionnel.
Il diffère des auteurs DAC par une qualité sonore supérieure. Grâce au FPGA ALTERA MAX2 avec deux cristaux 44,1x et 48x. supprimer le jitter des entrées USB, Raspberry PI ou Bluetooth.
De nos jours, c'est un grand avantage d'avoir un DAC avec entrée IP sans jitter. Avec radio Internet et musique NAS.
C'était très facile à faire pour moi.
A B.
Fiches de qualité et facile à monter, vraiment très belle finition. Le système blocage banane est efficace. Je les utilise personnellement avec Audioquest Rocket 11 et j'ai obtenu des très bonnes résultats. Un petit rodage de deux jours est nécessaire.
Bruno P.
NEOTECH NES-5005 Câble Haut-Parleur Cuivre UP-OFC 2x2.5mm² La gamme NES-5000 de Neotech intègre des câble à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Dans cet esprit, le NES-5005 va...
Ce câble prends place à des Sommercable Ele­phant de 6 ans et tout vient de se réveiller sur mes Elipson Prestige 5(2008) en bi-ampli et mes klipsch rb-81 mk2(2014) bi-ampli. Le son est équilibré doux aéré, un son vivant qui fait du bien de l'aigu au grave. Les yeux fermés vous pouvez.
Patrick R.
TUNG-SOL 12AU7 / ECC82 Tubes (Unité) Le Tung-Sol 12AU7, fabriqué en Russie, assure un très faible bruit. Il a été conçu pour imiter les performances des tubes américains...
Superbe restitution
En remplacement d'un tube Sylvania (déjà très supérieur à un autre tube Chinois "no name"), ce Tung-Sol après quelque heures m'apparait comme étant très détaillé, précis et dynamique. Installé dans un ampli casque mono-lampe.
Jonathan D.
Pour moi le Top
Très bon câble d'une très bonne qualité de fabrication, très satisfait. Merci à Audiophonics.
Jonathan D.
Très bon câble d'une très bonne qualité de fabrication, très satisfait. Excellent rapport qualité prix.
Jonathan D.
Au top
Très belle prise d'une très bonne qualité de fabrication, très satisfait.
Jonathan D.
VIBORG VF503S Connecteur IEC C15 Cuivre Pur Plaqué Argent Ø19mm Ce connecteur IEC C15 Viborg VF503S high-end utilise des matériaux de très grande qualité pour favoriser la meilleure conductivité électrique...
Jonathan D.
Jonathan D.
VIBORG VE503S Connecteur Secteur Schuko Type E/F Cuivre Pur Plaqué Argent Ø19mm Ce connecteur secteur Schuko Viborg VE503S high-end utilise des matériaux de très grande qualité pour favoriser la meilleure conductivité...
Damien G.
Pour particulier.....
Pour un usage dans le cadre particulier, ces connecteurs sont de bonnes qualités et ils font très bien le job....il n'y a plus qu'à choisir un bon conducteur (câble) .....
Samuel L.
Superbe Jumper
Livraison rapide, produit au top, mes enceintes fonctionnent encore mieux, le son est plus détaillé, je recommande.
Enceintes : BW 703S2
jean-philippe g.
vraiment top rien a dire
Antoine F.
Module d'Alimentation à Découpage 9V 1.3A 12W Ce petit module d'alimentation délivre une tension de 9V et un courant de 1.3A. Idéal pour alimenter de petits systèmes.
Bloc d'alimentation
Parfait pour remplacer un bloc d'alimentation défectueux. Audiophonics toujours top.
A.j. v.
Impressed
I am using the 2x4HD for a 2.2 system, 2 subwoofers and 2 full range DIY speakers. I found the miniDSP quite easy to install and setup, functionality is outstanding and in terms of sound quality it seems transparent (at least enough for me).
A.j. v.
Excellent value
Very good sounding amplifier and no quality issues detected. I received it within a week which was a welcome surprise.
yannick a.
Câble USB Cuivre OFC Plaqué Argent PTFE Double Blindage Ø7.8mm Ce câble permet la confection de modèles USB audio numérique de haute qualité avec des matériaux nobles. Les conducteurs sont isolés...
Caâle USB de bonne facture, que l'on peut rendre très bon !
Genèse d'un câble USB qui apporte un réel plus, à base d'éléments de chez Audiophonics...
Il y a 7 m entre la sortie de mon PC qui assure le rôle de source et l'entrée USB du DAC.
Le but est de concevoir un câble d'une seule pièce, puis de gagner en restitution sonore.
Mission accomplie !
Première étape :
Cable USB OFC PTFE Double Blindage Plaqué Argent Ø7.8mm
VIBORG UA201 Connecteur USB-A 2.0 Mâle Plaqué Or 24k Ø8.5mm
VIBORG UB201 Connecteur USB-B 2.0 Mâle Plaqué Or 24k Ø8.5mm
Je relie le blindage au connecteur uniquement du coté USB A, comme il est d'usage.
Musicalement à ce stade, c'est bon mais il n'y a encore rien d'extraordinaire.
Sur mon installation, j'ai toujours ce petit bruit numérique qu'on entend en poussant un peu le volume de l'ampli :
sans signal délivré par le PC, il y reste ce voile de son.
Je me dis qu'il y doit y avoir moyen d'améliorer cela.
La magie va venir d'un concept de blindage que j'ai voulu tester : JSSG 360
Petite recette DIY pour un câble USB qui a changé mon installation : plus d'ouverture, de dynamique.
Plus de finesse dans les instruments, de micro détails qui apparaissent et un bruit de fond réduit à néant.
NB : le plus simple est de faire toutes les opérations qui suivent avant de souder les connecteurs USB-A et USB-B.
Deuxième étape :
Glisser autour de la gaine jaune du câble USB une 1ère gaine de blindage tressée.
ELECAUDIO GC-0410 Gaine de blindage tressée 100% Cuivre 4-10mm
La gaine de blindage ne doit toucher ni les extrémités du câble, ni les (futures) prises USB.
C'est curieux, un blindage qui n'est relié électriquement à rien...
Justement !
J'ai laissé environ 1 cm sans gaine de blindage à chaque extrémité du câble USB.
(prévoir plus d'1 cm si vous soudez les prises après et que vous avez besoin de dénuder le câble USB pour accéder aux 4 fils Vcc, d+, d- et 0V).
On peut utiliser de la gaine thermorétractable ou du scotch électrique pour fixer les extrémités de cette 1ère gaine de blindage à l'isolant jaune du câble USB.
Ensuite, on glisse au dessus une gaine isolante, plus courte.
ELECAUDIO SG-03 Gaine Tressée Extensible Nylon (PET) 06-11mm
J'ai laissé environ 5 cm de gaine de blindage non recouverte à chaque extrémité.
J'ai donc maintenant 5 cm de gaine de blindage visible à chaque extrémité du câble.
Là encore, scotch ou gaine thermo pour fixer les extrémités de cette gaine isolante.
Puis par dessus la 2ème gaine de blindage, qui doit recouvrir entièrement la 1ère gaine de blindage.
scotch, gaine thermo...
Et enfin, la dernière gaine isolante qui recouvre toute la longueur du câble USB cette fois.
Gaine thermo pour que ça soit joli et que rien ne bouge, et en longueur suffisante pour bien écraser les 5 cm de gaine de blindage en dessous.
En résumé, on crée autour du câble USB un blindage double, connecté électriquement à ses 2 extrémités, mais flottant.
Flottant, c'est à dire qu'il n'est connecté à aucun potentiel électrique.
Ni à la masse.
A rien.
Ce type de montage peut aussi s'utiliser sur les câbles réseau, et on trouve dans le commerce des câbles tous prêts (mais à prix conséquents) avec ce double blindage flottant.
Bonne écoute !
FRANCOIS G.
Produit de qualitè
Bonjour Très satisfait de ce produit utilisé comme convertisseur numèrique analogique sur la sortie son optique de ma smart tv Samsung
Le niveau du volume sur un ampli muticanal est très peu diminué et sur un ampli intégrè parfait
Le service livraison est au top et le sérieux Audiophonics également
Peter S.
Veredlung meiner Verstärker
Ob Phono - Pre oder Vollverstärker:
Erste Wahl!
First class!
Premier choix!
Bruno J.
VIABLUE UFO XL Absorbeurs de Vibrations Noir Ø65mm (Set x4) Les absorbeurs Viablue UFO XL permettent d'amortir les vibrations néfastes en se plaçant sous vos enceintes ou appareils HiFi. Du fait de leur pression optimale...
VIABLUE UFO
Produit de belle qualité et finitions très design. Pas encore essayé mais je vais les utiliser sous mon lecteur Panassonic UB9000 J'avais déjà les QTC sur mon lecteur Marantz BD8002 plus une plaque de granite par dessus le lecteur le résultat était déjà super donc je pense que ça sera encore mieux avec les UFO que me semble de meilleur facture et de technologie que les QTC. Dès que j'aurais mon nouveau lecteur et que je ferai des tests je reviens vous donner mon avis
Ludovic B.
Excellent ampli mais mauvais boitier (2019)
J'ai acheté cet ampli en 2019 pour remplacer le SMSL AD18 acheté un an plutôt ici même pour monter en qualité d’écoute.
Je n'ai pas été déçu, à côté l’AD18 parait bien fade !
Pas besoin d'être un expert pour se rendre compte que cet ampli à base d'Hypex NCORE est bien meilleur à la production actuelle.
Ses qualités sont le dynamisme, la neutralité et la clarté de l'écoute.
Pour vous donner une idée aller voir sur le site Audio Science Review le test du March Audio P122 équipé du même module pour lire son test.
Par contre il a un petit défaut, c'est le ronronnement qui provient de l'alimentation du trigger qui une fois éteint se fait entendre.
Donc si vous dormez dans la même pièce c'est insupportable, il faut à chaque fois le mettre sous tension.
Aujourd'hui AUDIOPONICS vend cet ampli avec ce bouton à l'arrière sauf qu'en 2019 ce n'était pas le cas !
Je suis très déçu de la part d'AUDIOPHONICS de ne pas y avoir pensé dès le début et le vendre avec un boitier plus large pour y intégrer cette option qui est indispensable.
Car aussi qui dit boiter plus grand dit plus d'air pour refroidir les composants. Dans l'ancien boité commercialisé il chauffe assez vite et je ne préfère pas m’en servir en cas de forte chaleur.
Donc 5 étoiles pour la qualité d’écoute mais -1 pour la conception d'AUDIOPHONICS.
