Cedric J.
Surprenant
Sur un ampli purement symetrique, cet adaptateur confère une sonorite qui semble souffrir d' aucune perte si ce n'...
Régis C.
C'est la classe (D) cet ampli
Première expérience en classe D et je dois dire que je ne m'attendais pas à ça.
Après un excellent Rotel RB 1582 MKII qui...
bernard g.
cablage xlr
des connecteur de bonne facture pour faire des trés bon cable
monté en gamme pour les connecteurs eizz pour faire un cable...
AUDIOPHONICS MPA-S250NCX RCA Amplificateur de Puissance Class D Stéréo NcoreX NCx252MP 2x250W 4 Ohm - avis - Il y a 28 avis.
Aleksy R.
Best choice for this money
This amplifier is simply a sensation compared to my Marantz PM5003! Paired with the WIIM Ultra and KEF C7X, it delivers a truly mind-blowing musical experience. The entire soundstage has opened up, everything is clearly separated, the bass is tight and punchy, and the clarity is incredible. I’m listening to lossless and FLAC formats from a USB drive. Highly recommended — great job, guys!
Luca D.
Another masterstroke by Audiophonics
The power amplifier is exceptional. I bought it to drive my two JBL LS120P subwoofers converted to passive, replacing my TRANSAUDIO D5PRO, which is another excellent amplifier but does not have the technical specifications suitable to drive those subs. The Audiophonics proved to be extremely brilliant, balanced, precise, dynamic as it should be, perfect in every circumstance, both in a 2.2 and a 5.2.4 configuration. The bass is noticeable, definitely, but you never perceive its source: the subs "disappear," a sign of excellent integration into the system. Moreover, I purchased it on Friday afternoon, it was shipped on Monday afternoon, and on Wednesday morning it had already arrived in Rome. Another masterstroke by Audiophonics. Truly, thank you again.
Richard M.
Really really good - but capacitators are not Japanese like in pic
Truly fantastic amp - but am a bit disappointed: the capacitators in the picture are top Japanese ones - what I actually got were very average Chinese ones (Aishi). Will probably never make a big difference IRL but please update the pictures, it is a bit misleading.
 (3)
Gwendal L.
génial
je souhaitais au début changer d'ampli pour booster un peu mes Elipson Prestige Facet 24F qui étaient très à la peine avec mon ampli Marantz.
On m'a conseillé de jeter un œil à cet ampli de puissance et je l'ai commandé.
C'est une vraie révélation, je redécouvre totalement mes enceintes qui malgré leur qualité me décevaient. Je suis ravie, le son est détaillé, dynamique, elles revivent.
Je suis très très content de cette achat, merci Audiophonics de faire ce genre de produit pour un prix très correct au regard de la qualité.
Duncan A.
Superb quality
Superb quality, beautifully made power amplifier,highly recommended
Nicolas D.
Audiophonics mp-250
Bonne tenue des haut-parleurs, hyper définition sur l'ensemble du spectre. Avec mon preamplificateur le gain est trop élevé et il y a du bruit de fond sur les compressions.
En revanche excellente association avec des enceintes dynaudio et un preamplificateur avec moin de niveau de sortie.
Thierry R.
Très bien
Envoi très rapide et protégé. L'appareil est bien conçu, ne chauffe pas, discret, sauf cette satanée led blanche, alors qu'il sert aussi en support home cinéma, donc dans le noir...
Le son n'est pas très chaud, mais c'est souvent le signe d'un manque de coloration et donc de distorsion.. les Klipsch Heresy lll en frontales sont bien reprises la ou le Yamaha rx V6 était un peu mou, les autres voies ont plus d'impact, les effets plus sensibles..
En le branchant, j'ai senti qu'il serait moyen avec les câbles Viard premium, que j'ai remplacés dans la foulée par une commande de simple, moins cher. mais très efficace Canare 4S11.
Il est relié au "préampli" par des RCA Canare L4e6 succédant à de vieux Mit...
J'aurais préféré les branchements H.P en bas, mais en pratique, ils sont mieux là où ils sont...
Un bon achat...
Roman J.
Highly recommended AMP
I'm using a miniDSP flex RCA to drive the MPA-S250NC amp. Both devices in combination are superb. There is no noise or hum. Without an input signal, it's simply dead silent. Listening to music is really an enjoyment.
- The built quality and finish of the MPA-S250NC amp is perfect.
- The output signal measurements are well known and can be found on the ASR forum.
- The audio output of the amp is excellent.
Christophe C.
Jusqu'à maintenant, que du bon!
Première bonne surprise: l'ampli non dispo avec délai de 2-4 semaines. Je commande et je le reçois 4 jours plus tard. Merci @audiophonics
2ème surprise (qui ne devrait pas en être une): le son est superbe. Je reconnais cependant l'improbabilité de mon installation: en remplacement de 2 blocs mono flying mole, l'ampli est connecté à un sélecteur de sources audiophonics partagée entre une interface usb esi gigaport ex, la platine dvd, la télé et un player hidizs ap80 pour la réception bluetooth , et à mes antiques Jamo e610 pour les sorties. Quelques essais en bluetooth, puis en filaire avec une playlist sur le pc et enfin la nvidia shield. Sans conteste ni prétention audiophile de ma part, cet ampli délivre un son pêchu, détaillé riche en aiguës et basses... Boitier massif que je loge dans une case de mon meuble TV ikea, sans chauffe apparente.
Mon impression est donc plus que positive . A voir sur la longueur, mais j'ai confiance.
Merci encore pour cet appareil!
Derrick S.
Excellent amp for the price
You get what you pay for. They are succeeding my old mono's from '97 and do all things for music better! I like the tiny case. All feels solid and is playing for week now and no issues and the sound is great! My fear was that things could get lean but non of that. Highly recommended!
C b.
audiophonics 2*125 w
connecté à mon ampli denon avr 3313 par la prise trigger,impossible d'éteindre complètement mon ampli denon. Celui ci reste en veille avec à l'écran "ampli off" et la diode verte qui reste allumée. Sans connection à l'ampli de puissance quand il était éteint , pas d'indication sur l'écran et la diode éteinte...
Je pense donc qu'il reste en veille avec l'ampli de puissance qui lui est bien éteint.Le tout est branché sur un filtre de courant audioquest 3.
A quoi est ce dû?
Merci pour votre réponse.
Anton P.
Flawless, beautiful Power Amp.
Thanks Audiophonics for this great Amp.
It came well packaged and protected.
My speakers sound way more dynamic now.
I used the Topping Pa5 before on my Polk R700 Speaker setup.
Not sure, if i am having a placebo, but it sound much better.
There is no hiss and popping. Dead silent amp and pure enjoyment of music.
ANTONIO M.
Not better than UCD with linear PSU
Yes is more efficient than linear PSU amps but the treble is dull and not detailed at all. CI hope Purifi is much better than this. I ended selling it as i did with the NC500MP dual mono i purchased here too. Built construction is great, as all audiophonics house products but ncore is with smps is not good enough for hifi or high resolution monitoring. But Brunos's designs are advancing and the good thing is contruction is great, is durable, it really can handel 3 ohms loads, is dynamic .... but is low resolution highs... Looking for next generation of Purifi to see if they fix its high reslution weakness. Just ordered some pro class d amp for a popular brand of pro single driver passive studio monitor, Aurartone, still waiting for it. I use Focal, B&w and dynaudio only. Hope someday some class d amp can surpass my quad 606 or even my modest NAD 216thx regarding crisp highs and liquid mediums
Matthias J.
Perfect unit - nothing more, nothing less
This is a totally boring device. Deadly quiet, lots of power, absolutely neutral, well built. It makes nothing wrong and you can hear exactly the sound of your source and your speakers. It easily controls even an Apogee Duetta Reference or a Cabasse Bora unconstrained and relaxed. And if your system sounds bad with the MPA-S250NC don’t blame this amplifier but look for the reason elsewhere. Highly recommended budget amp.
Noel C.
Bon Ampli de puissance
Premières écoutes...
Cet ampli est excellent si on prend le soin de le configurer avec des éléments de qualité en amont et en enceintes.
Très satisfait sur des enceintes Kef Référence 205 qui ont un rendement de 90Db.
Pas totalement satisfait sur des enceintes au rendement de 85Db.
Enfin au vu du prix, il est réellement bon.
ANTONIO M.
MPA-S250NC SONIDO LIMPIO CALIDO Y POTENTE
calided valvular pero sin el ruido, calor ni lios de las valvulas. Graves con control y corriente mas que una etapa de estado solido clase ab de 200w.... agudos calidos, medios liquidos valvulares, y ademas pequeña ligerra discreta y eficiemte. Sustituyo a Bryston 2.5B SST3 porque suena mejor en ambos extremos del expectro y ademas es mas dinamica y mas limpia
Chan Pong I.
Great Sound and Powerful AMP
The performance of this Hyper NCore AMP is great.
The 4ohm and 2ohm output is powerful to use on speaker with min ohm as low as 3ohm.
The sound is transparent and no extra added.
The build quality is good and they are kind enough to send me the UK plug power cable in the package, which is a nice touch!
Although the front panel is a little too Bright but it is ok to and not affecting you to enjoy your music.
I am already planning to add a mono for my center channel and maybe even more to power the surround speakers!
Highly suggest anyone who is finding a class d amp at a reasonable price, you won’t regret this purchase!
Christopher D.
NCore bargain
Great amp, great price. Audiophonics have built a quality product, looks great, sounds better. I challenge you to find a better spec'd Ncore 250W/c class D for $600AUD. Be prepared to wait a little for delivery - good things come to those who wait.
Bert B.
Super amplifier.
I had been searching for a long time to find an amplifier with Hypex modules. The Audiophonics MPA-S250NC was my perfect fit for a very good price.
I wasn't satisfied with the sound of my system and I thought it was because of the quality of my speakers(Millon Phantom-S).
Now that I replaced my Yamaha amplifier with the MPA-S250NC the speakers sound so much better.
I didn't expect an amplifier to give such an improvement.
The trigger input to power on the amplifier from my pre-amplifier is also a very welcome option.
Delivery to The Netherlands within 3 days for a reasonable price is also perfect.
So, nothing to complain!!
David L.
superbe ampli de puissance !!!
J'ai fait l'achat de cet ampli après renseignements et avis divers..donc un peu à l'aveugle en fait...eh bien...franchement pas du tout déçu, je suis enchanté par le rendu de cet ampli. Tout est plus clair et détaillé.
le tout reste très dynamique sans tassement. il est en amont d'un NAD D3020 V2 et une paire de Davis Olympia one master...c'est vraiment beau et d'une douceur incroyable, les médums sont magnifiques , les graves fermes, et les aigus précis. cet ampli devrait couter plus cher...mais tant mieux pour nous....il reste très abordable et on rentre de pleins pieds dans la haute fidélité . Bravo Audiophonics !!!!!
Reis H.
Does exactly what you expect!
Using this to power my front Elac DBR-62 speakers (which are in a 5.1 setup) pre-out from Denon AVR-X3600h. Can I tell an immediate difference and upgrade from the Denon at the average listening levels I typically enjoy? No. Does it still sound great? Yes! So why bother? Well, I was mainly curious and wanted absolute assurance my speakers were being driven properly by an amp.
Chances are that unless you have a bad amplifier, or are asking a lot of your AVR (powering 7+ speakers at loud volumes) that can't really drive your speakers then you won't hear much of a difference, like in my scenario. It's a transparent power amplifier that will allow you to go to really high volume levels and supply the power you require for speakers that may demand more. It's a good product for doing this in a relatively small enclosure, it feels solid, and I expect to not need to upgrade again for a long long time.
It gets about as warm as my Denon so make sure you have some room for it to breath. Originally I put it in a drawer in my unit but after approximately 90mins of moderate usage I rechecked the heat and it was quite warm so I moved it outside of the drawer as a precaution.
I'm happy and received the product in 4 working days (ordered Thursday morning, here Tuesday morning) through TNT tracking which was great.
A.j. v.
Excellent value
Very good sounding amplifier and no quality issues detected. I received it within a week which was a welcome surprise.
Edouard C.
Formidable ampli
Construction de très bonne qualité dans un emballage parfait.
L'ampli est branché derrière un préampli Yamaha pour alimenter des Cabasse Egea 500.
Une dimension supplémentaire est atteinte dans la tenue des graves et la dynamique.
Pas encore eu le temps d'attendre un rodage suffisant ni de faire tous les tests nécessaires, mais le reste du spectre me parait très bien traité. Les bons enregistrements sont encore plus formidables et je profite chaque jour de ce bel ampli.
Michel l.
une merveille
je remercie tous les collaborateurs de audiophonics de m avoir sollicite a prendre ce produit car j'avoue je n'en espérais pas tant car il est étonnamment surprenant après avoir patienté trois mois
c'est excellent ampli et branché sur un préamplificateur fx audio 3e de chez audiophonics platine cd Yamaha c700 rca cable cardas et wireworld equinox 7 j'ecoute principalement des hqcd le son et parfait l'impression d’être face au chanteur merci à toute l'équipe
George R.
Superb & unassuming power amplifier - but takes time to sound optimum
When I received this I was initially disappointed. The sound was perfectly clear and (I hate to use this word!) neutral - but "flat & boring! However, after approx. 2-weeks of pretty constant daily use the sound has "opened-up" dramatically. It still takes a good 30-mins after switch on even from standby to open-up which is mildly frustrating, but now I understand why people love the Hypex amps. It is very clean, open and dynamic - with no compression, no harshness and no edginess. My KEF LS50s have never sounded so good! I think mine is still improving, but now I am sorely tempted to upgrade already to the higher specification Hypex mono-blocks! A minor comment / observation; the delivery packaging was "nothing special" - being more like "Amazon packaging" than a high-end manufacturer - which is probably reasonable / fair and I would prefer the money was spent on the hardware anyway.
Jacques D.
Prof
Excellent amplifier at a *very* good price. I've seen amps built around the same Hypex module selling for hundreds more. Speedy (1 week) delivery to the USA.
Pierre R.
Un ampli de grande qualité
Un ampli avec transistor bipolaire 2x70w d’une trentaine d’années alimentait mes HP grave de 38 cm. J’ai décidé de le remplacer suite aux conseils d’Audiophonics par cet amplificateur Hypex Ncore qui est remarquable, il est très défini avec beaucoup de dynamique et d’impact. Il descent très bas, et apporte beaucoup de profondeur à l’image. Je l’ai essayé dans le médium/aigu (à ruban)pour le comparer à mon ampli MC Intosh KT88 2x 75w ( beaucoup plus cher), l’Hypex est transparent, défini mais je préfère mon Mc Intosh. Ensuite je l'ai essayé sur des enceintes classiques électrodynamiques, il est dynamique, neutre, défini, il est difficile de lui trouver des défauts. L’ampli est bien construit, ne chauffe pas et prend peu de place.
 (3)
Michel R.
Excellent produit
Service Audiophonics excellent, commande et livraison rapide, surtout pour cette période de fêtes, bravo et merci.
Ampli offrant une bonne réserve de puissance, musical, je l'ai associé
à un SMSL M500, parfait duo pour moi.
Au déballage l'ampli paraît léger au vu de ses capacités, une fois branché, fait
parfaitement son job.
Le Audiophonics MPA-S250NCX RCA est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore...
