Jam M.
6V6GT Electro Harmonics
Les tubes sont bien appairés. Les caractéristiques sont confromes.
Seul défaut: construction du tube non parfaite:...
Patrick V.
to much money for what you get
I received the case with one heatsink dented. So if this unit was intended for a client it was already useless. If you want a...
Please contact our customer service team via the forms on the website; the damaged part will be replaced.
Philippe T.
Excellent
Voilà il est arrivé .. il se rôde .. les premières impressions sont excellentes.. une très belle séparation des canaux .. un...
Câble USB-C Male / USB-C Male 3.1 15cm Noir - avis - Il y a 2 avis.
Yves A.
USB C vers USB C court
Rapide et fiable Bravo ....encore Merci
Patrick d.
Works fine as OTG Cable
Great cable, good quality and works like a charm, absolutely worth the money .... had other (so called) cheaper OTG cables, they didn't do the job properly. Used as audio interface cable Mac to MOTU, works great .... testing other options.
Ce câble de type-C mâle / mâle de haute qualité permet de brancher toute tablette ou smartphone avec une...
