Nikolaus S.
Parfait sur un bureau
MICHAEL K.
Recommended
Avis clients - Il y a 19275 avis.
Attila R.
Amazing value, highly recommended!
I have tried a few cables in my system and although I am not a fan of power cable upgrades it was obvious I need to buy proper cables for all equipment to maximize its potential. This cable seemed to be the right value for the price in all aspects.
The chinese cable I used seemed to work way better than the factory supplied one. Then I changed to mid tier Isotek cables (same gauge as the AC14) and although it prooved to be a decent upgrade giving more detailed sound, it seemed to restrain the bass register for some reason.
Now that I have changed the cables to the Pangea, I have even more detail (in the highs too) and surprising amount of improvement in the bass register. It also seems like the stage is deeper a tiny bit. I do not wish to upgrade to anything more as I believe it really gives a chance to my Arcam and Primare integrateds and phono preamps to show their full potential.
I am truly happy with this purchase and Audiophonics.
J-C- P.
Une belle surprise
J'attendais un léger mieux avec mais au final, c'est véritablement un surprenant petit câble ! Même entre un boitier TV et un petit amplificateur il fait merveille. A recommander sans hésitation !
PIERRE R.
Capacité vraiment HI FI
Condensateur d'exception avec une grande transparence et beaucoup de dynamique . Il convient malgré son prix ,pour le découplage des alimentations de préamplificateur .
ANTONIO M.
muy buena fuente lineal
Indispensable para mi DAC irDAC-II de Arcam. Ahora sí suena bien bien bien
Frederic P.
HIDIZS AP80 Baladeur Numérique HiFi DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX Noir Avec son AP80, Hidizs propose un DAP au format vraiment réduit pour vous accompagner tout au long de votre journée, et ce en assurant d'excellentes performances audio.
QUESTION
"Storage up to 512Go" mais sur leur site ils disent "Extendable Storage MAX 1TB" et Il n'y a qu'un seul slot SD card.. Merci d'eclaircir.
Sur le papier il accepte 1TO ...
Mais nous n'avons pu vérifier faute de présence de ces capacités sur le marché (nous les attendons depuis 2016).
Hans H.
Excelent boots.
The little rubber feet have tot be glued. If the design would be a Little different this would not be necessary. Greater feet or...
Not all micro USB connectors Will fit, There is not much space due to the ( Nice) foot of the box.
Franck D.
SMSL DP3 Lecteur Réseau DLNA Airplay Bluetooth AptX DAC 2x ES9018Q2C 32bit 384kHz DSD256 Après nous avoir proposé leur flagship, le FDA AD18, SMSL revient et complète sa gamme avec le DP3. Nous avons ici à faire à un lecteur...
moyen
Lecteur valable seulement avec un dac externe car celui monté dans le produit ne vaut rien, attention en usb tout les dac ne sont pas reconnues .
Autrement c'est un lecteur de bonne qualité, le point noir c'est le pilotage par dlna impossible .....
L'alimentation interne PWM semble limité la qualité de restitution dommage.
Serge R.
Bon produit. Je m'en sers pour relier ma tablette à mon DAC pour écouter ma musique et il remplit parfaitement son office. Fait produit de qualité.
Christophe D.
Impeccable pour ampli guitare
Je l'ai utilisé pour changer celui de mon ampli guitare qui était "pourri" et vraiment ça lui donne un coup de neuf vraiment bluffant, les trous sont à la bonne taille et c'est de bonne qualité, à voir dans le temps mais j'ai suffisamment de tissu pour en changer.
Très satisfait de mon achat.
Lionel C.
LITTLE DOT MKIII Amplificateur Casque / Préamplificateur à Tubes Le Little Dot MKIII est un très bel amplificateur casque à tubes, offrant d'excellentes performances audio. Il est surmonté de deux tubes GE5654 (United...
un Ampli casque à Tubes exception
J'ai acheté récemment cet ampli à tube pour un Sennheiser HD 700 - avec un réglage de gain "5" - cet ampli permet une restitution sonore optimum idéale pour écouter de la musique classique pendant des heures et des heures sans fatigue auditive ( comme avec un ampli à transistor basique donnant des aigus souvent trop agressifs ) avec une précision dans tous les détails de l'enregistrement -
Sur le pop rock et toute autre forme de musique moderne , il donne un son doux et une scène sonore incroyablement riche tant dans l'aigu que dans le grave - mais il révélera aussi tous les éventuels défauts de la source car cet appareil est réellement un produit haute fidélité ...
un 10/10 pour ce produit et un grand merci à Audiophonics pour nous faire connaître cette marque Little Dot qui permet de rentrer dans le monde de la hi-fi à tubes sans se ruiner...
excellent câble
Aprés plus d'un an d'utilisation, et quelques essais avec d'autres marques plus chères, je garde ce modèle.Son rapport qualité prix est imbattable,
J'ai essayé du câble atlas a 27 euros le mètre, et franchement, faut arrêter...
Rien a dire si ce n'est la section, qui est quand même importante.
parfaites
Pour le prix, on s'attend pas à cette qualité.
Les fiches tiennent parfaitement, montée sur du mogami 2524 pour un caisson.
Livraison rapide.
cable subwoofer
Câble utilisé pour un caisson, ça fonctionne très bien.
Livraison rapide.
Emanuele D.
ottimi connettori
connessione buona ed assemblaggio semplice.
Romain B.
Connecteurs trop gros
Les connectiques sont trop grosses pour mon ampli. Les deux connecteurs RCA sont en contact lorsque je les branche....donc impossible de les utiliser.
Les connecteurs ont tendance à se dévisser tout seuls et la petite bande rouge ou noire n'est pas moulée/peinte mais est un autocollant qui s'est vite décollé.
La gaine tressée fait bel effet mais les extrémités en plastique brillant semblent assez fragiles.
Dans l'ensemble ce câble permet d'avoir un élément qui paraît beaucoup plus cher que les 10€ qu'il coûte vraiment. Mais ne le regardez pas de trop près....
Romain B.
Bien mais connexion instable
Quand il fonctionne j'en suis très satisfait. Le fait que le réglage de volume influe aussi sur la sortie RCA est très appréciable.
En revanche la connexion est relativement instable sur mon MacBook Pro 2017 ; je perds la connnection sans raison (ordinateur et récepteur dans la même pièce) une à deux fois par jour. La reconnection est toujours fastidieuse.
Le mode d'emploi n'explique rien du tout, impossible de savoir à quoi correspondent les séquences de couleurs des LEDs (parfois vertes et parfois rouges, mais il semble que rouge signifie que tout fonctionne et vert annoncerait un problème) et il semblerait ne pas avoir de moyen d'effectuer un "reset" complet de l'appareil.
Maxime S.
FX-AUDIO D802C PRO Amplificateur FDA Bluetooth 5.0 NFC Class D STA326 2x80W 4 Ohm Argent La version pro du D802C bénéficie d'un module Bluetooth amélioré (QCC3034) et d'une puce USB CM6422 plus performante par rapport au modèle...
Excellent...
Reçu début septembre, Colis livré à date prévu et très bien emballé. Rapport qualité prix imbattable. Fonction Bluetooth excellent ( essais à + 10 M concluant sans perte ). Connectique complète. Encombrement mini. Parfait pour mon système d'enceintes Bose Accoustimass 3. Seul Bemol : la fonction Hifi ( Direct source ) n'est pas présente dès l'allumage et donc petite manip. en plus.
Gérard T.
Module indispensable
Pour ceux qui utilisent des liaisons symétriques, il s'agit d'un module de très bonne facture qui fonctionne effectivement tel que décrit. Juste un petit bémol, il manque en entrée un filtre HF en PI de type double self VK200 et un condensateur 1nF si la ligne est très perturbée. On aurait aussi pu prévoir une alimentation 48V DC (pour micro amplifié avec sortie équilibrée sur transformateur) mais ceci n'enlève rien aux capacités de ce petit module.
Condensateurs très bien finis, du Mundorf quoi, encombrement réduit pour des valeurs plutôt élevées, très content de ce choix !
Fiches de haute qualité et polyvalentes, pour un prix très correct, construction de qualité très bien fini, aucun reproche !
De la qualité
De la qualité, pour un tarif somme toute peu élevé au regard du matériel mis en oeuvre.
Belle pièce
Composant de très haute qualité, très bien fini, mais attention à son encombrement, il sera parfait dans une enceinte, mais pour un ampli à tubes, prévoir beaucoup de place, il fait la taille d'un bouchon de peinture en bombe.
EIZZ EZ-4003-800 Sélecteur de Sources 3 Positions Axe Lisse Ø6mm Ce sélecteur de sources EZ-4003-800 de chez EIZZ à 3 positions offre une qualité de conception absolument exceptionnelle. Sous son corps en Aluminium...
Magnifique
Tout simplement magnifique, construction hors-normes, pour un composant très bien fini, un seul dommage, qu'il soit caché dans mon ampli...
snif !
Belle pièce
Construction parfaite, pour un produit parfait, que demander de mieux ?
MUNDORF MCAP SUPREME EVO SILVERGOLD Condensateur 1000V 0.33µF Depuis 2015, les condensateurs MCap Supreme EVO SilverGold représentent incontestablement la gamme supérieure de Mundorf. Il combine tous les points forts...
belle qualité
Matériel Audiophile, très belle construction et finition, le top !
Magnifique
snif !
Bouton Aluminium Axe Méplat 30x28x22mm Ø6mm Argent Ce bouton aluminium à axe méplat 6mm de couleur argent et aux dimensions de 30x28x22mm est idéal pour une intégration DIY, par exemple dans le cadre...
Belle pièce
Bouton de très belle facture, finition au top, très content de cet achat !
Claude B.
Excellent DAC et SAV au top!
J’ai acheté la version précédente de ce produit en 2016 pour complémenter un kit RaspDac DIY, qui m’a donné satisfaction, même si j’ai vite noté la présence d’un bruit de fond qui devenait gênant lorsque j’écoutais de la musique à volume (très) élevé, ce qui est, disons-le, assez rare. Le temps a passé, et ce n’est que récemment que je me suis décidé à parler de ce souffle au SAV d’Audiophonics, car je me demandais si le problème ne venait pas de l’alimentation lambda que j’utilisais. J’ai reçu une réponse très rapide et courtoise de la part de David Aubert, qui m’a proposé quelques tests pour localiser le problème. Après différents essais, il est clairement apparu que le souffle trouvait son origine dans la carte DAC elle-même. David Aubert m’a alors demandé de renvoyer la carte. Après contrôle par le SAV de la réalité de la panne, la carte a été gracieusement échangée pour une V4, et ceci bien que le produit retourné ne soit plus couvert par la garantie ! Le bruit de fond a complètement disparu après montage de la nouvelle carte, mais il s’est avéré que le câblage de l’écran du RaspDac n’était pas le même que sur la V3. Le SAV d’Audiophonics m’a alors envoyé les câbles adéquats, là encore gracieusement.
Merci encore à David Aubert et un grand bravo à Audiophonics pour la qualité exceptionnelle de son SAV !
Gareth J.
Super rapport qualité - prix
Cable à visser, sonorité et rapport qualité prix au top.
Mais attention toutefois aux trous qui ne conviennent pas aux cables de forte section comme les Elecaudio OCC FEP et les vis où la plus petite clé Allen de 1.5 mm ne rentre pas. Ni des instructions de montage ni de clé ne sont fournis mais j'ai finalement réussi à visser avec une Torx T5. Je maintiens 5 étoiles pour le premier point.
Xavier C.
astuce pour Daniel L
Le niveau de votre source est peut être insuffisant pour profiter de toute la puissance de votre ampli. Vous pouvez l'optimiser via le sélecteur DIP situé dans le boîtier (4 vis à enlever pour ouvrir la partie supérieure du boîtier) en positionnant le switch 4 sur on.
En revanche, pour ceux voulant réduire un gain trop élevé, cela n'est pas possible : le réglage usine est au minimum.
dany g.
ampli pour caisson de basse sono
livraison en temps et heures, correspond pour le prix à mes attentes, étamer les pistes rail d'alim et sortie transistors, et c'est nickel.
ailettes radiateur un peu petites, et mauvais sens, mais c'est pas grave pour mon montage casson de basse sono.
je regrette tjrs comme mes premier achats chez ljm, la doc qui n'est pas fournie sur une feuilles A4 lol, mais rien de grave, internet est là(transfo conseillé, ampérage pointe des transistors, ou comment les bridger, , je pinaille , là. je reprendrai des modules ljm, et suis content du site et du suivi.
yann M.
excellent appareil
appareil etonnament bon et pratique
il ne manque rien
la portée du bleutooth est impressionnante
Andrew M.
Power your I-SABRE DAC board & Pi
Bought this to power the I-SABRE DAC
Andrew M.
Great DAC and design
I first bought the complete system with case, pi, dac, etc and was very impressed with the unit and the sound. Having the audio and power on the same side as the I/O on the Pi is a great design and makes for a cleaner config. Wanted the same DAC to use with another piCorePlayer I want to build for another room because the sound quality. Long over due. The fact that it also works with a 2 line OLED display for smaller packages is another bonus.
Petter Jacob L.
LAO Condensateur Électrolytique Hautes Performances 63V 10000µF Ce condensateur électrolytique  offre de  hautes performances,  spécialement conçus pour une utilisation audio HiFi. Ce modèle offre...
Elna capacitors are normally a very good choice.
Have used Elna electrolytic capacitors in several electronic components and have never regretted.
Petter Jacob L.
Seems Solid
The potentiometer seems solid. Rotation of serrated axis is solid and fine. Have not used it as volume control yet.
Petter Jacob L.
Nice and compact size.
Marc F.
Un RQP sans égal ou presque
Comparé - sur mon système, tout est relatif et affaire d'associations - à différents Klotz, Mogami, Grimm, Belden, Hifi-câbles, etc. pour lesquels il manquait toujours quelque chose ou résidait une insatisfaction, ce Canare est un "no brainer" comme disent les anglo-saxons. On ne peut raisonnablement le vanter comme le câble ultime qui efface les références xx-fois plus chères, mais il restera sur mon système comme le juge de paix par lequel les autres seront jugés, en raison de l'homogénéité de ses qualités : équilibre, transparence, douceur, détails, densité des timbres, etc.
Marc F.
Connecteurs faciles à utiliser
Pour faire des essais de câbles, sans avoir à souder-dessouder, ces connecteurs sont très faciles à monter et à défaire. Et bien entendu, à demeure entre lecteur CD et ampli, ils font le job et le serrage sur les prises RCA est efficace.
Encore merci à Audiophonics pour la rapidité de la livraison et surtout d'avoir eu la gentillesse de corriger une étourderie lors de ma commande.
Vincent V.
Bon ampli 12Vdc
J'apprécie le rapport qualité/prix.
Le petit plus : entrées stand by et mute
En moins : tenir le connecteur bornier à visser si serrage fort, la solidité du bornier est un peu en dessous de l'image globale du produit.
Avant de passer aux impressions d'écoute, je voudrais signaler les observations suivantes. Le bouton de volume pour la sortie casque agit également au niveau de la sortie rca . On peut passer de très faible à haut niveau de sortie. Cela peut avoir une incidence au niveau du fonctionnement d'un ampli. Il faut donc trouver le bon niveau de sortie .
Ce récepteur Bluetooth est très séduisant. Il délivre un son chaud et détaillé, à la manière des bonnes électroniques à tube. Distinction au niveau du secteur médium aigu qui est très naturelle et émotionnel ( voix et instruments acoustiques.) Le secteur grave est précis et profond.
Ce récepteur Bluetooth est un produit excellent au rapport qualité surprenant. El plus il est très joli.
aime KP
bon condo, que j'ai mis en entrée sur mon ampli, pour remplacer un vieux fatigué. écoute nettement meilleure, claire, sans perte en aigus, a utiliser sans problème, surtout en audio.
Jean-Claude C.
Très bon !
Utilisé pour confectionner un câble coaxial avec connecteurs bnc d'un côté et jack de l'autre pour relier un digione allo et un chord mojo. Aucun problème pour la soudure des connecteurs, il est assez souple et solide. Il "transporte" parfaitement le signal numérique vers le dac !
Jean-Claude C.
Je l'ai utilisé pour confectionner un câble coaxial bnc d'un côté et jack de l'autre pour relier un digione allo avec un chord mojo avec ce câble FURUTECH FC-62 Câble numérique µ-OFC 75 . Résultat : c'est parfait !
Ce connecteur BNC est facile à souder, il est esthétique et solide. Juste parfait !
Alexey Z.
Perfect!
I like this up-to-date i2s spdif sound card (hat) for my Rpi3. I connected Rpi3 +Digione to multi bit DAC19 by coax cable and then to my tube headphone amplifier. I also connected CXC Cambridge Audio cd transport to DAC19 by optical cable. Made some comparisons in sounding between two systems using one composition (flac from Rpi3 and compact CD ). Finally I couldn't hear any noticeable differences in sounding! Rpi3 with DigiOne and LPS sounded as good CD transport. I was impressed with clarity of sounding as well as microdynamics provided by the DigiOne Spdif card. It is really good device.
PANASONIC FC Condensateur Low ESR 50V 1200µF Les condensateurs Panasonic FC profitent d'une belle qualité de conception et d'un faible ESR. Ils seront adaptés à la plupart de vos projets, que ce soit...
Condensateur 100 Yf Panasonic
Parfait ; Très faible ESR confirmée.
Fiabilité des expéditions Audiophonics aussi !!!
excellent RQP
je confirme l'avis de David R, quant a la qualité sonore de ce cable, que j'utilise dans mon système triphonique pour le medium. avant j'ai fais l'essai de câble de même section 2x2.5 mm2, mais plaqué argent. la qualité de l'argent, c'est que l'oxydation de ce métal est toujours conducteur, donc de vieux câbles gardent un bon contact. Mais il y a un défaut, le placage argent, donne une surbrillance aux aigus, le son n'est plus , naturel, et devient lassant. je retrouve avec ce sommercable, un son plein,clair, défini, sans rajout,ce qui me convient mieux. pi.r
Yvon C.
NEOTECH NES-5005 Câble Haut-Parleur Cuivre UP-OFC 2x2.5mm² La gamme NES-5000 de Neotech intègre des câble à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Dans cet esprit, le NES-5005 va...
GROSSE SURPRISE !
Je possède des câbles HP haut de gamme de ce fabricant dont j'étais très satisfait. J'ai donc commandé ce câble NES-5005 pour un deuxième petit système. Je cherchais donc des conducteurs de qualité à petit prix. L'écoute de ces petits câbles à été une grosse surprise car ils "sonnent" comme des câbles beaucoup plus chers et plus ambitieux. Je recommande donc fortement.
Jean-David G.
AUDIO-GD NFB-11.38 PERFORMANCE EDITION DAC ES9038PRO / Préampli / Ampli casque DSD 32bit / 384kHz Accusilicon Le NFB d'Audio-GD revient avec plusieurs évolutions notables. Son étage de conversion digital / analogique s'équipe désormais d'une puce ES9038Pro...
Impressionnant
Le dernier né de la gamme NFB 11 affiche des prestations de haut vol. (je l'utilise en tant que DAC branché à mes enceintes)
Pour imager, si le NFB 11.28 m'avait mis une gifle, ce NFB 11.38 m'a mis une grosse claque !
La musique délivrée devient physique , les enceintes semblent disparaître et les musiciens prennent place dans la pièce d'écoute ..
Tout est plus clair, plus précis , le son a plus d'impact , le registre grave notamment affiche une belle présence, sur certains enregistrements ça remue les tripes !
La scène sonore est vaste , chaque instrument est localisable et les timbres semblent réalistes. Les voix paraissent également naturelles avec peu de sibilances.
Amateurs de douceur, de finesse, ce DAC n'est pas fait pour vous.
Si par contre vous aimez écouter la musique comme au concert, avec la sensation d'être proche des musiciens , alors ce DAC devrait vous combler !
Pour comparer avec le Chord Qutest que je possède également, le Chord amène un peu plus de naturel et de musicalité à l'écoute , l'Audio GD semble plus précis et plus analytique. Difficile de les départager réellement, pour le prix l'Audio GD frappe fort.
Je précise enfin que j'utilise un câblage en full OCC cryo , qui permet d'obtenir un son organique , libéré de toute froideur digitale …
Merci Audiophonics pour le service au TOP !
gilbert f.
En remplacement d'une masse de mauvaise qualité
Bonne conductivité, bon produit
