Patrick G.
tres bonne conception
Abdoulaye D.
Soudure
Abdoulaye D.
Pince 3 in 1
Avis clients - Il y a 20186 avis.
Christopher B.
Amazing New Product
First, before I say anything else, in case you are looking for such a thing, the WIIM PRO+ _does_ convert analogue to digital and stream it. I am using this remarkable new product, a real advancement in the world of audio, to stream an audio signal from my phono preamplifier to my Audiophonics DAW-S250NC, which does not have an analogue input.
Again: The WIIM PRO+ is streaming my phono signal to my modern Class D amplifier at a better-than-CD sampling rate. The sound is startlingly good.
At the same time, as you would expect, it also streams digital streams to my Audiophonics DAW-S250NC excellently well. There is no surprise there. For me, as a person with treasured records that I accumulated myself over my lifetime and 78-rpm discs and early LPs that I inherited from my father, the WIIM PRO+ has solved a problem that current advanced audio technology introduced to me.
I now have the option of listening to my records directly through my headphones or via the WIIM PRO+ to the speakers connected to the excellent Audiophonics DAW-S250NC amplifier. The WIIM PRO+ is a remarkably versatile element of my audio system and I think is well worth considering if you are looking for a streamer.
Tout d'abord, avant de dire autre chose, au cas où vous recherchez une telle chose, le WIIM PRO+ _convertit_ l'analogique en numérique et le diffuse en continu. J'utilise ce nouveau produit remarquable, une véritable avancée dans le monde de l'audio, pour diffuser un signal audio de mon préamplificateur phono vers mon Audiophonics DAW-S250NC, qui ne possède pas d'entrée analogique.
Encore une fois: Le WIIM PRO+ diffuse mon signal phono vers mon amplificateur moderne de classe D à un taux d'échantillonnage supérieur à celui d'un CD. Le son est étonnamment bon.
Dans le même temps, comme on peut s’y attendre, il diffuse également très bien les flux numériques vers mon Audiophonics DAW-S250NC. Il n’y a là aucune surprise. Pour moi, en tant que personne possédant de précieux disques que j'ai moi-même accumulés au cours de ma vie et des disques 78 tours et des premiers LP hérités de mon père, le WIIM PRO+ a résolu un problème que la technologie audio avancée actuelle m'a présenté.
J'ai désormais la possibilité d'écouter mes disques directement via mes écouteurs ou via le WIIM PRO+ sur les enceintes connectées à l'excellent amplificateur Audiophonics DAW-S250NC. Le WIIM PRO+ est un élément remarquablement polyvalent de mon système audio et je pense qu'il vaut la peine d'être pris en compte si vous recherchez un streamer.
Christopher B.
Very Good Quality
These are very satisfactory interconnects. The quality is excellent. I am glad to have them and will probably get them again when I need RCA interconnects in the future.
All of the Audiophonics equipment I have purchased has been excellent, in quality and design and also in aesthetics. Audiophonics combines quality with superb design at a very good price with fantastic customer service. For any equipment I need I will always look at Audiophonics first.
Raymond M.
Quelle qualité !!!
Avec ces 5m d’ElecAudio CS-361B et un connecteur Viborg VE512R, j’ai confectionné une ‘rallonge de luxe’ pour raccorder mon installation PC-HIFI à la terre. La prise de proximité en étant dépourvue. Mon ‘problème de riche’ c’est que j’ai tellement investi en matériel (pc, hifi, câbles) ‘high-end’ que je crois avoir atteint un tel niveau difficilement améliorable… Mais au moins ce qui est sûr c’est qu’une telle ‘rallonge’ ne peut pas faire l’inverse, car c’est superbe au niveau qualité. Curieusement j’ai la sensation que la visualisation de mes photos s’est améliorée avec des tons plus contrastés… Côté audio… Mais au bout d’un moment on rentre dans le subjectif…
frederic a.
TONEWINNER AT-300 EXT 5.1 Processeur Audio-Vidéo / Préamplificateur Home-Cinéma Dolby Atmos 16 Canaux 9.3.4 / 7.3.6 Le Tonewinner AT-300 est un processeur et préamplificateur Audio/Vidéo disposant de 16 canaux, idéal pour une intégration home cinéma sur des...
agréablement surpris
commende parfaitement traité par audiophonics rien à dire !
En ce qui concerne le processeur je sor d'un Yamaha CX 52àà a 2700 euros et quand j'ecoute celui ci il sonne mieux plus detaillé plus doux le systeme de calibration plus efficafe surtout au niveau des basses a condition de prendre l'option micro EM 2 bref je n'en revienns pas et je doute qu'a ce prix il y est beaoup de concurence
A.H. d.
A hell of an amplifier
This my first Class D amplifier, I enjoy it now for 15 months. And oh boy what a clean, powerfull and beautiful device it is! Well built, beautiful design. No remote contol but it has tirgger in/out so... no worries. Still one remark about the design related to ones health: Lifting it up be advised because the cooling fins are sharp, one could cut oneself.
Audiophonics did a great job building this amplifier and the very custom friendly approach is superb! Delevery was perfect as well.
Salvatore R.
NEOTECH NES-3003 MKII Câble HP Cuivre Hybride Multibrins UP-OCC Plaqué Argent 4x1.3mm² Ø19mm Le câble haut parleur Neotech NES 3003 MKII dispose d'une topologie particulière hybride lui permettant d'abaisser les effets de capacitance et d'inductance....
exceptional cables
exceptional cable, remarkable 3D image, the instruments appear more in focus and great musicality.
Excellent audiophonic in very fast shipping.
joffrey J.
Transparence
Câble qui remplace un audioquest qui vaut 2x le prix.
Le canare est meilleur, car plus transparent, moins flatteur. Un scène sonore plus large et des aigus et mediums plus nets et clairs. Des graves moins boursouflés également. J'ai eu bien plus cher encore en modulation (atlas hyper), le canare est meilleur que celui-là aussi.
N'achetez rien d'autre, vous gâcheriez votre argent.
Audiophonics est d'une réactivité aux mails qui mérite d'être souligné. Bravo pour le service impeccable.
Excellents !!
Les condensateurs Mundorf méritent leur réputation.
Ces deux-là ont remplacé deux condensateurs 1uF MKT de sortie de mon préampli phono, amélioration immédiate.
Commandés un jour et reçus le lendemain, on ne peut pas être plus rapide, bravo Audiophonics !!
ETI BP-50C Borniers Cuivre Pur Plaqué Or Ø19mm (La Paire) Les ETI BP-50C sont des borniers très hautes performances à prix contenu. Fait d'un conducteur en Cuivre trempé 1100 Series ayant un IAC de 102% (indice de...
Son magnifique et transparent
Je confirme c'est top
Cuivre only
Rosario Roberto S.
SMSL AO200 MKII Amplificateur Class D Symétrique MA5332MS Symétrique Bluetooth 5.0 Subwoofer 2x160W 4 Ohm Le SMSL AO200 MKII est un amplificateur numérique Class D compact et performant, capable de développer une puissance de 2x160W sous 4Ω grâce à sa puce...
SMSL AO200 MKII è un ottimo amplificatore in classe D
Pensa all'AO200 MKll come a una versione premium dell'A300. È come la relazione tra AO200 e DA-9.
SMSL realizza modelli speciali a seconda del canale di vendita. AO200 MKll è un modello progettato e venduto per Aoshida HiFi.
Il case e il display dell'AO200 MKll sono notevolmente migliorati rispetto a quelli dell'A300, conferendogli un aspetto lussuoso.
La configurazione interna è la stessa dell'A300, ad eccezione dei diversi tipi di ingresso. Il chip dell'amplificatore è Infineon MA5332MS e JRC NJW 1194 viene utilizzato per il volume elettronico e l'equalizzazione e ha esattamente la stessa configurazione.
Il volume elettronico dell'NJW1194 commuta elettronicamente dall'esterno l'attenuatore di gradino del resistore ladder all'interno dell'IC. Inoltre, è integrato anche l'EQ e vari pattern possono essere configurati tramite programmazione.
L'unità di alimentazione è la stessa sia per A300 che per AO200 MKll, ed è composta da due sistemi di +32V -32V.
L'A300 ha due ingressi RCA sbilanciati, ma l'AO200 MKll ha ingressi XLR bilanciati e RCA sbilanciati.
L'A300 può passare a una configurazione mono, ma l'AO200 MKll no, ed è dedicato al funzionamento stereo a 2 canali.
Per quanto riguarda l'uscita SW, l'A300 mixa R/L internamente e lo emette, ma l'AO200 MKll emette R/L separatamente in stereo.
BT e USB sono funzioni completamente bonus e l'unico codec per BT è SBC in modalità base. USB utilizza la funzione DAC del modulo BT e funziona solo a 48kHz/16bit.
Quanto sopra è la differenza tra A300 e AO200 MKll. Poiché la configurazione interna è quasi la stessa, penso che non ci sia quasi alcuna differenza nella qualità del suono.
PSVANE EL34-PH Tubes HiFi (Quad Appairé) Le tube EL34-PH de PSVane est une réplique du connu et reconnu EL34 de Philips, largement utilisé dans de nombreux amplificateurs à lampes. Il est ainsi...
Grandiose !
Après le re- tubage de la partie pré amplification de mon Cayin cs55a avec des tubes PSVANE qui avait bouleversé les caractéristiques sonores de cet ampli, voici le tour des tubes de puissance.
Je ne savais pas vraiment à quoi m’attendre, tout au plus à une petite augmentation de puissance.
Je confirme donc les avis laissés plus haut de Laurent H et Robert V.
Chez moi, j’obtiens un système énorme avec un son d’une ampleur inédite.
Mes petites DALI Menuet chantent comme des grandes Utopia. Je ne sais pas comment décrire autrement la sensation d’un son, à l’échelle 1/1. Les instruments sont pour le coup véritablement incarnés. Les timbres sont parfaitement retranscrit avec toutes les nuances possible avec une taille réaliste.
Ça manque un peu de profondeur et de largeur ; un peu…
Évidemment ça donne envie de tester les PSVANE KT88-T2 vendues dans cette même boutique.
Je pense que pour avoir le meilleur des deux monde, il faut passer sur des amplificateurs plus onéreux avec des tubes exotiques de type 845 - 805 ou autre 300B.
Manfred G.
BURSON AUDIO SUPREME SOUND OPAMP V5i AOP Double Hybride DIP8 (La paire) Le V5i de chez Burson est un AOP audio hybride, intégrant à la fois des circuits intégrés et des composants discrets pour des performances...
Burson
alles super geklappt, sehr guter Verkäufer, gerne wieder
Eric R.
8 ampères, mais attention pas vraiment 1800W
Utilisé pour mettre en marches des amplis d'un Home cinema. Sur le papier les 8X230, c'est à dire 1800W ne sont pas atteins. J'ai 1100W avec du classe D (800W) et 300W avec du classe AB. Mais cela c'est le max en utilisation, non pas à l'allumage. Cela doit faire en instantané probablement beaucoup plus. Donc au bout de 2 ans 1/2 le Trigger est "collé" en contact. J'avais déjà eu des soucis ponctuels à l'extinction en prémices...
Dominic D.
Mr.
Great product! Has all the bells and whistles that you would expect from a good LPS. High grade parts are used. Good value for the price.
Thank you!
NICHICON KG GOLD TUNE Condensateur Audio HiFi 80V 10000µF Les condensateurs électrolytiques Nichicon de la gamme KG Gold Tune sont spécifiquement conçus pour les usages audio haute fidélité. Ils...
Excellent condensateur
Fantastiques !
Fantastique!
Re-tubing CAYIN cs55a EL34
Enceintes DALI Menuet
Sources : DAC Hugo2 CHORD
Tuner Magnum-Dynalab (triode)
Platine vinyles ClearAudio (performances DC- MC Melody sur T5) pré ClearAudio
Test à froid immédiatement après branchement.
Les tubes de puissance, sont toujours ceux du constructeur d’origine (EL34)
Si il n’y a pas de différence maintenant, alors après ça va être très léger…
Je me doutais que le changement des tubes au niveau de pré amplificateur pouvait modifier considérablement la signature sonore de l’ampli tout entier. Je précise que j’étais déjà assez satisfait du résultat sonore de ce Cayin.
Mais là c’est carrément holographique tout est meilleur.
Les timbres, les harmoniques, la scène sonore. Les sons ne se marchent plus sur les pieds. Le headroom comme disent les ricain, extinction des notes et des voix grandioses.
Même le ressenti de puissance est augmenté mais le son est brutal, ça casse la tête, difficile de monter le volume…
Test à chaud toujours sans rodage.
Retour de déjeuner…
Le côté casse tête a disparu.
Du coup je monte le volume !
Les hautes fréquences sont d’un naturel confondant. Les médiums sont moins en avant. Les basses sont solides et lisibles. Grosse métamorphose du système, et que du bon à venir, surtout que demain je reçois les tubes de puissance EL 34 aussi en PSVANE.
Encore plus de douceur, un grave plus profond, un petit gain en puissance ?
Je ne sais à quoi m’attendre…
Maintenant, il y a plus qu’à rôder tout ça .
Bien à vous.
Fantastique !
Retour de déjeuner…
Bien à vous.
Manuel F.
DAYTON AUDIO PC105-8 Haut-Parleur Large Bande 40W 8 Ohm 86dB 80Hz - 15kHz Ø10.7 cm Un haut parleur large bande compact et aux belles finitions. Idéal pour construire / réparer un système audio de petite taille ou comme...
Dayton PC105-8
The speakers have a good quality/price ratio.
gilles t.
TOPPING DX1 DAC Amplificateur Casque AK4493S XMOS XU208 32bit 384kHz DSD256 Noir Topping dévoile avec le DX1 un combo DAC et amplificateur casque compact, abordable et pour autant performant. Celui-ci profite d'une conception optimisée...
Bien, mais...
Bonjour, acheté pour remplacer un FX 01, parfait pour mes besoins, mais dénué d'une prise casque, j'ai donc opté, sur les conseils toujours avisés, compétents et aimables d'Audiophonics pour ce dac/ampli casque qui vaut quand même près de trois fois le prix du FX 01. Mes premières expériences ont été très décevantes, autant sur mes enceintes amplifiés que sur les différents casques ou écouteurs branchés dessus.
Volume faible et métallisations des aigus qui vrillent les oreilles, bref rien d'agréable. Frustré, j'ai eu l'idée de remplacer le câble USB fourni avec le DX 1 par celui de l''antique et modeste FX 01.
Surprise : le volume était deux fois plus fort, mieux défini, beaucoup plus fin, quelle que soit la définition du son d'origine et la qualité des écouteurs... Morale de l'histoire : c'est un très bon appareil, mais livré avec un câble de grille-pain. Même si vous ne croyez pas qu'un câble informatique n'a aucune incidence sur le son, puisqu'il n'est censé transmettre que des données informatiques, mon expérience me prouve le contraire.
Je m'étonne que le câble blindé fourni avec le DAC le moins cher au monde, le FX01, soit infiniment meilleur que celui fourni avec un appareil très bon mais trois fois plus cher.
Sinon, pour ce qui est de la qualité du DX 1 en lui-même, et sur le service Audiophonics, rien à dire, ou alors que du bien.
Amicalement.
Pierre D.
Bon produit tout métal, contact optimal entre le câble et la fiche, très bon maintien mécanique dans le bornier
Petit bémol un marquage trop discret rouge et noir
ELECAUDIO EB-03 Gaine Tressée Extensible Nylon (PET) 06-12mm Gaine tressée élaborée en PET (Polyéthylène Terephtalate) monobrins pouvant être utilisée dans une large diversité...
Parfait!
Une fois pigé la façon de passer la gaine sur le câble, le résultat est top!
Bonne communication avec Audiophonics!
Tournade E.
EVERSOLO DMP-A6 MASTER EDITION Lecteur Réseau 2xES9038Q2M WiFi DLNA AirPlay 2 Roon Bluetooth 5.0 aptX HD 32bit 768kHz DSD512 MQA Eversolo présente avec son DMP-A6 MASTER EDITION un lecteur réseau aussi performant qu'intuitif et design. Il vous permettra de diffuser votre musique en...
qualitée du DAC
le partie streamer et juste parfaite, mais la partie DAC n'est pas en reste, j'ai décidé aprés un test avec un M400 de ne pas rajouter de DAC. application génial. vraiment un produit parfait.
Si le budget n'est pas un problème n'hésiter pas, car la partie streamer devient exceptionnel.
Jacques T.
Produit de très bon rapport qualité prix, livraison rapide.
Marnix M.
SMSL PS100 DAC ES9023 USB SPDIF HDMI ARC Bluetooth 5.0 24bit 192kHz Le SMSL PS100 se présente comme un DAC abordable, performant et incroyablement polyvalent. Malgré ses dimensions réduites, le PS100 se base sur des...
Excellent mini-dac for very affordable price.
Simple, cheap but excellent and very versatile mini-DAC with HDMI-Arc input. Power over USB which every modern TV has. 24 bit resolution and 192khZ sample frequency by far enough for any home theatre. Limitation to only 2 channels.
Henry G.
Pied à Coulisse Numérique Acier Inoxydable +/-0.01mm 150mm Ce robuste pied à coulisse numérique en acier inoxydable permet une mesure jusqu'à 150mm. Il assure une grande précision, avec une tolérance...
Bon outil
Outil de bonne facture. L'affichage, fort heureusement, ne se coupe pas automatiquement ce qui évite de perdre la mesure.
A noter: se met en route, sans activer le bouton on/off, dès que l'on active la coulisse.
olivier B.
AUDIOPHONICS T2 Préamplificateur Phono (MM) NJM2068 Noir Ce préamplificateur AUDIOPHONICS T2 est exclusivement conçu pour être utilisé en sortie d'une source possèdant une cellule phono à aimant mobile (lecteur vinyle).
Petit boîtier solide,bien construit,avec façade en alu.
Fait le job.
Merci Audiophonics de nous proposer ce type de produit de bonne qualité avec un tarif avantageux.
Jacques B.
ETI LEGATO Connecteur Secteur IEC Cuivre Pur Plaqué Or Ø20mm Le connecteur IEC ETI Legato profite d'une construction haut de gamme basée sur l'utilisation de composants de grande qualité permettant une conductivité...
Superbe produit
Qualité de fabrication irréprochable permettant une haute qualité de contact et d'assemblage avec le câble secteur. Transparence et qualité de timbrage superbe par une transparence hors norme. A mon sens, plus neutre que les connectiques Furutech, sans nier leurs qualités également. Superbe mariage avec le secteur DPS 4.1 Furutech avec un apport concret dès la mise sous tension. Bravo !!
Jacques B.
ETI LEGATO Connecteur Secteur Schuko Type E/F Cuivre Pur Plaqué Or Ø20mm Le connecteur Schuko ETI Legato profite d'une construction haut de gamme basée sur l'utilisation de composants de grande qualité permettant une conductivité...
Superbe produit
Jacques B.
La classe !!!
Remarquable produit avec une qualité de construction et un niveau de conductivité de très haut niveau. Dès le départ, il se passe quelque chose sur la restitution sonore malgré le fait reconnu que le rodage est très très long sur ce câble. Que cela va être après celui-ci ?? Large bande passante avec une beauté de timbres et une vigueur peu commune sans assécher le message. Bravo Furutech.
Joris J.
AUDIOPHONICS DIGIRESCUE Module Reclocker SPDIF Optique Coaxial Isolation Galvanique 24bit 192kHz Ce module reclocker Audiophonics DIGIRescue a été conçu en association avec Ian Canada. Il permet, grâce à une horloge locale de haute...
Addition
This text in the description above: “ The DAC connected to the module will then receive the audio signal on its optical input." this is only true when a optical cable is used between reclocker and DAC. This reclocker can also be used as a optical to coax converter. Both optical as coaxial output sockets of the reclocker give the output signal.
Mike d.
Fast delivery. Excellent device.
Suggestions:
1. offer a black faceplate as alternative
2. the psu is over dimensioned for a single intel nuc or intel-nuc-based-audio-device. Consider providing a second 19v output and second cable (as a bookshelf option?).
Je confirme les autres avis
Très bon produit qui fond bien et qui tient je le préfère /au viablue.
Câble Adaptateur XLR Mâle 4 Pins vers Jack 4.4mm Femelle Plaqué Or 15cm Ce câble adaptateur symétrique est doté d'une part d'un connecteur XLR mâle 4 pins et d'autre part d'un connecteur Jack 4.4mm femelle. Il vous...
Un adaptateur de très bonne qualité.
Cet adaptateur est fabriqué avec des prises tout en métal. Les contacts sont "francs" et sans jeu. Sa longueur est bien adaptée et son prix est compétitif. Je recommande
Luca D.
Incredibilmente performante
Cavo dalle prestazioni eccezionali, assolutamente di livello anche comparato con cavi analoghi di marce blasonate. Raffinato, preciso, assolutamente trasparente. E' un cavo di assoluto riferimento. Ottoni e voci rese con una raffinatezza indescrivibile. Da non perdere!
Antony C.
Fosi V3 : une boule de nerfs !
En ouvrant le colis l'ampli paraît petit mais branchez le et c'est une boule de nerfs ! Très dynamique, neutre, le son est top. La gestion du volume est fine et précise.
Ce V3 (la dernière version) représente bien la Class D "moderne" avec tout ses avantages, dont le prix mais pas que ...
Très bien conseillé aussi !
Je vous le recommande vraiment pour son rapport Q/P.
Livré en 36h !!!
EVERSOLO DAC-Z6 DAC 2x ES9068AS XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Le DAC-Z6 de EverSolo est un DAC performant basé sur une structure technique soignée. Il embarque des composants haut de gamme avec notamment deux puces de...
15h. D' écoute..
Tout simplement excellent dac pour le tarif.
Scène plus large et définie, hauteur, profondeur, tridimension, diaphonie, superbe timbre, respecte la musique et la restitué avec beaucoup de charme. Je recommande l' eversolo z6 sans réserve !
TUNG-SOL 12AX7 Tubes Triodes (Paire Appairée) Les Tung-Sol 12AX7 sont des  tubes triodes doubles à gain élevé de qualité supérieure avec des effets de microphonie ultra-faibles...
Excellents
Superbe paire de tubes de préamplification.
Comparés à des tubes plus onéreux, ils sont plus polyvalent, précis, musicaux, détaillés, match très bien avec du TAD en puissance.
Cyril T.
Connecteurs RCA Cuivre 4N Plaqué Or Ø11mm (Set x4) Ces connecteurs RCA mâles assurent une très bonne conductivité et résistance à l'oxydation grâce à leurs contacts en cuivre 4N...
A éviter
Qualité plus que discutable, le vernis et la peinture ne tiennent pas ce qui rendent l'esthétique peut valorisant.
Yoann G.
Utilisé pour alourdir les portières de mon coupé, fonctionne très bien pour atténuer la résonance de la tôle.
Moins de bruit au roulage et graves des HP renforcés.
En réponse au 1er avis de "felix q.", une plaque de bitume disposée sur votre lecteur Blu-Ray ne va pas transformer les informations numériques et rendre les basses "franches et sèches"... C'est de la folie, merci d'éviter la désinformation.
OPPO Signature l'a fait dans le seul but d'éviter à la tôle de vibrer (lecteur + capot supérieur).
Si vous partez dans cet optique, le capot de votre TV vibrera avant celui de votre Lecteur Blu-Ray...
C b.
ATOHM WT-STU Connecteurs HP Fourche / banane Cuivre OCC Plaqué Argent Ø3mm (La paire) Voici un set de connexion très haut de gamme. Le corps se fixe sur le câble (section de 6mm² max. soit Ø3mm de diamètre) par...
Connecteur Athom WT-Stu
Connecteurs de grande qualité, et en plus très esthétique. Je retire 1 étoile car pour 2 lots et quasi 68€ je ne m'attendais pas à les recevoir dans 1 petit colis et dans 2 pochettes plastiques en vrac.
Très bons
En remplacement d' EH jaune, et comparé aux TAD ecc803s, ils sont plus détaillés, moins rentre dedans mais très bons chef d' orchestre. Je n' ai pas beaucoup de comparatif, mais ils sont pour l' instant mes préférés.
Olivier G.
Un streamer performant
Véritable couteau suisse du streaming. Installation simple, appli fluide et efficace. Je peux caster Amazon music en qualité optimale directement en Wifi. La connectique est complète. Des performances étonnantes et une sonorité claire et aérée sur mon ampli NAD et mes enceintes Boston.
joffrey J.
Excellent câble HP
Il remplace l'elecaudio hp250 . Ce sommercable est meilleur à tous les niveaux. Plus de clarté, musique moins brouillonne, grave plus secs et tout aussi profonds. Je suis très étonné, la différence est flagrante. Mes enceintes sont encore en rodage et l'amélioration est sensible. Système : Davis balthus 90 et marantz pm8006
Thomas S.
Absolute Empfehlung
Ich habe diesen Verstärker aufgrund der vielen Empfehlungen direkt mit 2x SPARKOS LABS SS3602 AOP Discret Double DIP8 gekauft.
Es handelt sich um den besten Verstärker, den ich bis heute habe und hatte. Das Klangbild bekommt mit diesem Amp eine ungewohnte Selbstverständlichkeit. Ich habe den Eindruck, als hätte ich neue Lautsprecher, alles ist einfach nur noch stimmig. Gab es vorher immer irgendwelche Kleinigkeiten, die ich zu optimieren versuchte, ist mit diesem Amp Schluss. Egal ob Bass, Mitten oder Höhen, Räumlichkeit, Auflösung, ... ales passt. Ich kann mir nur sehr schlecht vorstellen, dass es unabhängig von der Höhe der Investition noch wesentlich besser werden kann. Für mich ganz klar der beste Verstärker ever. Eindeutig in allen Belangen besser als meine alte, fette, stromfressende Onkyo Class A 300W Endstufe.
Absolute Empfehlung.
Joris J.
Hard to solder
Sounds good, but especially the ground connection is very hard to solder, given the Rhodium plating.
Joris J.
Interface Numérique I2S vers SPDIF BNC WM8805 24bit 192kHz Cette interface WM8805 avec DSP XilinX permet de transformer un signal I2S avec MCLK vers un signal SPDIF classique.
Great sound quality
I2S to SPDIF without problems.
In my high quality set up, this board proved to be very good, feeded with Jung super regulator power supply.
Be aware that you need the MCLK connection of I2S (or buy a clock to solder on this board). On the board this is a seperately placed pin, labeled MCL.
Premières impressions
Je l'écoute pour la première fois et, pas mal du tout..
Outre l'aspect physique, bien conçu et qualitatif, ce dac est adjoint a un ampli a Tube kt88, fezz audio titania via RCA.
Premier test avec qobuz en hires. Très neutre, droit mais nuancé, détaillé mais pas analytique. Pas de souffle apparent, fond assez sombre.
Diaphonie respectable mais pas spectaculaire. Il n'en fait pas trop mais fait ce qu'il faut.
En bluetooth, il est tres très bon !!!
Simple d'utilisation avec ou sans l' appli.
Le rapport performance/prix est excellent. Reste plus qu'à a essayer en xlr.....
Roeland T.
Embase Jack 2.5mm Femelle 4 Pôles Plaqué Or Cette embase Jack 2.5mm femelle est idéale pour un montage sur PCB et vous permettra d'ajouter à un projet DIY une connectique symétrique efficace. Ses...
Close to what I need
This is a Female Socket that provides 4 connections. A 2.5mm diameter Jack plug with 4 Poles (3 isolation rings) does fit in this socket, However, only 3 Poles of the Jack plug make contact: the Pole furthest from the tip does not connect to the gold plated pin as I had expected.
Teemu M.
Sound quality isn't great, the board is noisy
It has high noise, bluetooth stopped working quite soon after the purchase (2018), loud crosstalk from line input while bluetooth and so on. Cannot use with all the attachments, like Jab3 and batter pack because they utilize same connector. It is feature packed product with great expectations, but a disappointment and would not recommend purchasing this product. While it works, it is cumbersome and just poor quality.
That said, purchased it 2018 and now 5 years later it still works apart from the bluetooth so in this sense it's fine. Just do not expect anything from such cheaply made product.
Teemu M.
Seems fine,
Seems fine, no issues, been in use about 5 years now. Not daily but still.
