Thierry b.
Toute la...
remy l.
bon cable bonnes prises
Avis clients - Il y a 19350 avis.
Istvan D.
Great for DigiOne Signature player
Great for DigiOne Signature player "clean board". Absolutely recommended power supply.
Audier J.
Module DAC ES9038Q2M I2S Coaxial Optique 32bit 384kHz DSD Ce module est équipé de l'excellent DAC dernière génération ESS ES9038Q2M. Celui-ci offre des performances de conversion Digitale / Analogique...
correct mais il manque une information
Il a fallu que j'aille chercher sur un site de vente chinoix concurrent pour trouver comment faire fonctionner cette carte une fois l'écran connecté :
vous devez mettre un jumper sur J1 et J2 sinon rien ne fonctionne. ceci n'est pas précisé ici.
Merci, nous allons ajouter cette précision à la fiche.
Istvan D.
I cannot believe, just I'm just sitting and listening the music
Previously I used a Pioneer bluray player as the digital streamer to my Chord QuTest DAC. I did a try with the Digione Signature. I have to tell you it is amazing, really. I'm just sitting and listening music instead of some other stuff I must do today. The rhytmic, timing, bass response is ... my English too poor to describe how good is it.
I have never tried non Signature version, Canaris BNC-BNC coax and bought on Audiophonics a good linear power supply for 89EUR, so I cannot write comparison e.g. how it performs with basic power supply.
I don't think there is better music streamer on the world for a Signature Player + a good power supply price.
One minor negative; it was not really plug and play, I must install squeezebox server plus I use USB stick it means some linux knowledge is necessary to mount that as a permanent device, so it is not for my grandma. (After the setup no maintenance necessary). Easy to control with Android app on phone.
Jacques B.
Article très robuste s'adaptant parfaitement à mes borniers WBT avec serrage efficace permettant un excellent contact.
câble caisson graves
J'ai utilisé ce câble pour un caisson de basses, et le résultat est plus que moyen, je n'ai pas de basses.Je l'ai remplacé par un galileo 238+ et ça marche bien mieux (j'ai soudé les 2 conducteurs au point chaud et la masse des 2 cotés)
Il n'est pas du tout prévu pour ça ... pour du caisson de basse, favorisez du coaxial comme le viablue.
Matthieu L.
ARMATURE ELECTRA F6 V2 Distributeur Secteur Filtré 6 Prises Aluminium Noir L'Armature Electra F6 V2 est un distributeur secteur filtré de grande qualité, intégrant deux prises direct et quatres prises filtrées qui redonnera...
Très satisfait !
Ce produit semble robuste, construit avec soin et faisant appel à des matériaux sérieux.
Le poids et les dimensions sont conséquentes. Je précise qu il dispose d un interrupteur. Quant au rendu sonore, je ne m attendais pas à un miracle... Et c est effectivement le cas, mais j ai fait beaucoup de changement sur mon installation plus ou moins en même temps que l ajout de cette mutliprise, et je ne dispose pas d un ensemble tres haut de gamme. En faisant des comparatifs précis, il y aurait peut être moyen d entendre des différences avec une multiprise Casto à 20€...
Dominique G.
AUDIOPHONICS PI-SPC V2 Module de contrôle Alimentation Type ATX pour Raspberry Pi Ce module de contrôle d'alimentation pour Raspberry Pi permet d'allumer et d'éteindre proprement son Raspberry Pi comme un ordinateur ATX PC familial. Une fois le...
Indispensable avec Runeaudio
De mon coté, je viens de tester l'integration de cette petite carte ultra compacte pour mon application runeaudio : facile à intégrer, et le resultat est à la hauteur de mes espérances : enfin j'ai un beau bouton avec voyant qui me permet une marche arret propre de ma station runeaudio ! Merci Audiophonics
Arnaud D.
AUDIO-GD MASTER 3 2019 EDITION Amplificateur Class A Symétrique ACSS 2x 500W 4 Ohm Le Master 3 est un amplificateur de puissance Class A symétrique arborant une conception soignée offrant d'excellentes performances. POINTS CLÉS :...
Toujours au top!
Premier test il y a 9 mois avec Le préampli Master 1. Premier bon en avant! Merci!
Deuxième test aujourd'hui avec l'ampli master 3. Et encore une claque!
Vraiment un couple au top.
En synthèse la qualité du son progresse de façon exponentielle avec la qualité de l'enregistrement....
A chaque fois je découvre de nouveaux détails dans ma collection dématérialisée constituée avec Qobuz.
La musique est parfaitement spacialisée, la signature est neutre. Les basses ne bavent pas, aucune fréquence agressive. On peut pousser le volume sans rien perdre de l'aération d'ensemble. C'est propre, c'est précis, c'est pro.
Faute de place, j'utilise des Proac Signature qui me surprennent toujours.
Il me reste à remplacer mon DAC Naim, trop chaud et pas assez ciselé à mon goût, par le petit dernier d'Audio GD le D77.
L'ES9038Pro est déjà au top, alors en deux fois mono et packagé par Audio Gd, je n'ose imaginer...
Et enfin, un upgrade de toute la connectique finira le travail.
Pour info mes enregistrements sont stockés sur un serveur SOtM SQ1000 qui me satisfait pleinement.
Je tiens sincèrement à remercier Audiophonics pour la qualité de son service et de ses conseils.
La encore c'est propre, rapide, efficace et sincère.
Chaque réponse qui m'est apportée est la bonne. Je n'ai jamais été déçu des avis personnalisés qui me sont donnés.
Cela devient tellement rare d'acheter en confiance que je tiens à le souligner.
Conclusion: rapport qualité/prix imbattable, il faut juste garder les yeux ouverts pour le plaisir...
Claude T.
Bluffé !
J'ai acheté dernièrement le cable enceinte "RAMM AUDIO AMADEUS 5 MK2 Câble HP Cuivre OCC 11AWG Ø16mm. "
Tellement conquis par la qualité sonore apporté par ce cable, que j'ai décidé d'essayer le cable de modulation.
Et bien c'est pareil.. Il est difficile de décrire l'effet que ces deux cables ont sur mon système (Ampli Meridian et D700 Tannoy). Je ne pensais pas que mon ampli et mes enceintes étaient aussi bons.
Les Tannoy descendent très bas dans le grave, et je pense que les autres cables ne laissaient pas passer l'info.
Plus de raffinement et de sensibilité... Comment dire ! L'émotion passe .
Bluffant !
Cett marque est très peu connue, et c'est bien dommage !
Richard A.
Rien à redire, commande reçue rapidement.Récepteur fonctionne parfaitement avec freebox player révolution.
patrick w.
super
Prenez un petit dac (USB ES9028Q2M XMOS XU208 a 129€) Changer l'OP 275G par le burson audio OPAMP V5i,brancher le a un ordinateur avec un cable USb 1877 phono the majestic (audiophonics)allez sur qobuz et ecouter l'album de marie chapin carpenter between here and gone .Et la tout change le grave tappe beaucoup plus fort l'aigu perd sa pointe d'acidité,beaucoup de détails ,beaucoup plus de largeur et les voix alors la c'est vraiment le top elles sont de toutes beautées ;merci a burson audio pour avoir sorti un AOP de cette classe et a l'equipe d'audiophonics pour leurs conseils et leur rapidité (J'espere un jour pouvoir ecouter le dac burson audio avec la puce ESS et les AOP berson V5i)
Pascal A.
Fonctionne très bien
Utilisé entre la sortie audio d'un PC portable et une sono : ronflement si le PC est branché sur secteur, que ce transformateur abolit totalement.
Cédric R.
bon câble, rien à dire
Je souhaitais un câble de bonne qualité à prix raisonnable.
Utilisé pour brancher des enceintes surround, remplit bien son rôle.
Christophe A.
Vive le progrès !
Il m'a fallu l'essayer pour le croire... Mes enceintes sont des Klipsch RB81 (mkII) et j'ai toute une ribambelle d'électronique religieusement choisie pour profiter de ma musique:
airport - convertisseur Musical Fidelity - ampli Nad C352 , câbles de modulation, etc...
Et bien ce petit machin me procure bien davantage de plaisir à l'écoute. Au tout début il y avait beaucoup de choses en moins (des choses qui étaient en trop?) et une petite chose en plus qui était nouvelle.
Au fil du temps c'est devenu évident: de la transparence, pas d'agressivité, de la musicalité, plein de détails mais pas d'esbroufe.
Donc ce petit machin a définitivement remplacé ma chaîne d'éléments qui va partir sur eBay.
À bas volume comme en écoutant fort, de l'opéra, du piano, du symphonique, du clavecin, du rock.
Je n'ai rien trouvé à redire, même le prix. Il ne reste plus à espérer qu'il dure longtemps et qu'il soit fiable. À suivre !
Bruno F.
Adaptateur Convertisseur SPDIF Coaxial vers Optique Toslink Proposé à petit prix, cet adaptateur SPDIF simple vous permettra d'obtenir un signal Optique Toslink depuis un signal Coaxial pour par exemple brancher une TV ou une box internet.
Tres bien
Produit conforme à ma demande marche trés bien. A voir dans le temps.
Le seul bémol: il a été livré avec un emballage et une notice qui ne correspondait pas au produit. Ceux ci étaient destinés à un convertisseur analogique numérique. Alors que le produit commandé est un convertisseur spdif vers toslink ( numérique pour les 2).
Sinon parfait
Robert M.
Robert / NL
Quick delivery, reasonable shipping costs.
This product is hard to find in Europe, but exactly what I needed. SuperB that Audiophonics has it on stock!
https://youtu.be/I3fcfhaJILE
Pierre F.
J'ai remplacé tous les condensateurs des filtres de mes enceintes Klipsch CW3 par cette série de condensateurs pour un excellent résultat.
Je recommande cette série de condensateurs.
Qualité !!!
Pierre F.
ELECAUDIO BP-206 Bornier Isolé Acrylique Plaqué Or à Souder Ø19mm x 47mm Noir Ce bornier Elecaudio BP-206 de très bonne qualité utilise comme conducteur un alliage de cuivre plaqué Or, assurant une excellente conductivité et résistance à l'oxydation.
Franchement c'est vraiment une borne très grande qualité.
Je suis très content et a tous je vous recommande cette borne.
Bastien S.
Bien, améliore l'image et le son d'une TV.
Ce câble améliore nettement le son et l'image de la TV.
Tout est plus net, contrasté, nuancé.
Couleurs plus franches et plus belles, surtout sur les couleurs unies.
Les différents plans de l'image sont mieux découpés et détachés, l'espace devient plus lisible, plus profond.
Dynamique, il améliore aussi la fluidité des mouvements.
Attention, sur certaines images de qualité moyenne, les défauts sont accentués !
Mais sur des images très propres et bien travaillées, il est très bon.
Il m'a semblé très naturel sur des images d'extérieur (reportages animaliers par exemples), c'est reposant et agréable.
Pareil pour le son, tout est mieux.
La différence avec un câble d'antenne basique est très nette.
Mais j'ai obtenu encore mieux avec un câble cuivre / argent multi-brins ptfe Jantzen Audio 1,3 mm2, enfilé dans 2 gaines coton + blindage cuivre + gaine coton externe (tout est vendu ici).
Avec ce Jantzen comme conducteur, tout est encore meilleur qu'avec le Viablue (sauf pour pour la dynamique et la fluidité d'image), et il est aussi plus tolérant avec les images médiocres. Très bon son. Le résultat est impressionnant, mais c'est un peu plus de travail.
C'est étonnant de voir combien un simple câble peut améliorer l'image et le son d'une télé !
Je vais d'ailleurs récidiver en remplaçant le multibrin Jantzen par un faisceau de plusieurs monobrins cu/ag de différents diamètres et isolés entre eux (fil de Litz)... Je pense que pour un écran 4K, un bon câble d'antenne sera déterminant (le mien est un simple hd 1080).
Le Viablue est un peu rigide à cause des 2 feuillards de blindage, mais rien de grave.
Au montage, il faut être soigneux pour ne pas ébouriffer les tresses de blindage dont les fils sont très fins, mais pas de difficulté particulière.
Bref ce câble vaut le coût, il apporte des améliorations bien sensibles.
Daniel E.
Belle embase pour peu d'argent
Corps en plastique qui réduit les courants de Foucault, permet le montage sur des plaques épaisses. Je vais certainement changer toutes les embases de mon préampli par celles-là
Daniel E.
Bell embase, très bien fini.
D'un prix moins élevé que les WBT, Furutech semble également travailler sur l'aspect courants de Foucault, en faisant le corps en plastique et un minimum de métal. Je serai curieux de voir s'ils arrivent au même niveau.
Daniel E.
Beau boîtier, complet
Rapport qualité prix ok, bonne finition.
Précision d'assemblage pas aussi bon que les Hifi 2000, mais on y arrive.
Pascal A.
Reçu, monté sur Pi avec Picore , celui est détecté sans problèmes, a l’écoute que du Bonheur, vraiment a conseiller surtout en vue du prix....
Adaptateur ir reçu rapidement et fonctionne parfaitement pour pouvoir remplacer télécommande free box révolution par celle d un home cinéma bose (utiliser le code Alice et non free)
Didier R.
Bouton de bonne qualité
Philippe R.
1877PHONO SP-G-26 Jumpers Fourches OCC Plaqués OR 26cm (x4)
DYNAVOX Câble RCA Stéréo Cuivre OFC Connecteurs Plaqués Or 1.5m Ce câble RCA Dynavox intègre un conducteur en cuivre OFC 99.99% de pureté pour assurer une excellente conductivité du signal audio et soigner la restitution de votre système.
DYNAVOX Câbles d'enceintes bananes Cuivre OFC (La paire) 2m Ces câbles enceintes hautes performances d'un excellent rapport qualité/prix intègrent des conducteurs en Cuivre OFC ainsi que des fiches bananes permettant...
Du son et que du son.
Rien à dire pour ces trois produits .
J'ai honte pour les marques qui proposent des cables à des prix pharaoniques.On branche et on oublie tout!!!!
Gianni D.
bon rendue
conception correcte ainsi que le resultat
Klaus N.
Good product - complies to RC6 / MCE Specifications
Delivery to Germany was a little bit expensive. Within the EU a cheaper delivery should be possible. Therefore only 4 stars.
Sylvain D.
Une belle alternative aux supports casques en forme "Omega" qu'on voit dans les salons et qui coûtent très très chers.
J'étais un peu inquiet en l'achetant, ne sachant trop à quoi ressemblerait la finition en vrai.
A la réception, une vraie bonne surprise, la finition est sans défaut, une texture lisse agréable au toucher et du vrai bois. Le support est en deux morceaux qui s'assemblent, on peut donc l'ajuster légèrement pour le rendre plus écarté et moins haut, ou l'inverse.
Vraiment un bel objet qui met bien en valeur les casques de tout type.
Seul petit défaut: la forme en courbe sur les flancs fait que souvent, les pads des casques sont en contact sur la partie haute, mais pas sur la partie basse. Mais ce n'est pas bien gênant et se remarque surtout si on se met parfaitement de face.
thierry S.
bananes au rabais!
La fiche par elle même....bon....MAIS! les vis de serrage!!!!
a empreinte plate.....pas cruci encore moins btr.....IMPOSSIBLE de serrer le cable!!! il est vrai que les vis btr sont hors de prix
ces temps ci..........a fuir surtout si votre cable est de diametre
juste pour entrer dans la fiche.préférez les fiches a serrage btr dans tous les cas!
Jean B.
Les bon tubes !
Je laisse éclater ma joie car ayant fait l’acquisition de ces 2 paires de Psvane KT88-Tll sous les bons conseilles du service technique de chez Audiophonic j’ai eu la grande surprise après le remplacement des mes EL34 de mon PrimaLuna Prologue Premium par ceux ci de découvrir
après rodage un son magnifique ( aigu très précis, fin , médium couvrant son spectre
avec brio, justesse du timbre , chaleureux avec en prime un registre grave donnant toute son ampleur sans jamais défaillir.
Voilà mon ressenti sincère, je suis un client satisfait ( Psvane est une marque de qualité
Chinoise mais vendu par Audiophonic société bien Française .
Claude T.
Chapeau ......
Il faut du temps et être patient pour monter ce câble. Mais le résultat est là !
Mon système est composé d'un ampli Meridian et de Tannoy D700, des années 90. Alors c'est vous dire si des câbles j'en ai testé. Chacun changeait quelque chose, mais quant à dire si c'était mieux, c'est une autre histoire. Mais alors là, chapeau. C'est la première fois que j'arrive à suivre la ligne de basse, les voix sont incroyablement naturelles et présentes, l'aigu sans agressivité.
J'avais quelques problèmes de compréhension sur la façon de bicabler, mais le constructeur a été vraiment réactif, et j'ai eu toutes les réponses à mes questions.
Je n'arrive pas à comprendre pourquoi ce câble est si peu présent dans les recherches sur le web. Aucun test, aucun avis... C'est très étrange !
En tout cas merci à Audiophonic d'avoir mis ce câble au catalogue, qui sur ma configuration a vraiment apporté un plus.
Joel C.
IBASSO IT04 Écouteurs Intra-Auriculaires IEM High-End Quadruple Diaphragme 16 Ohm Les écouteurs intra-auriculaires IT04 de chez iBasso viennent se placer dans le segment High-End du monde audiophile, avec une conception tout bonnement exceptionnelle....
Parfait je recommande
J'ai couplé cet intra avec mon IBasso DX80 pour l'écoute de fichiers exclusivement de format FLAC ou APE.
Quelle claque ! La spatialisation est phénoménale, équilibre des basses présentent juste ce qu'il faut parfaitement rondes et claires, les aigus sont bien présents mais pas du tout agressifs et les médiums se font bien sentir. La réstitiuon des voix et des instruments accoustiques est très précises, les percussions percutent, il semble qu’aucun détails ne manque cela rend hommage au temps passé au mixage et au mastering.
J'écoute du Métal, de l'Electro Rock, de l'Industiel, du Jazz, du classique..... Bref tout un échantillon musical qui permet de se faire une idiée assez précise du potentiel de ce produit.
Je suis tout de même un peu embêté car je redécouvre chaque album et suis donc obligé de reparcourir toute ma ‘’musithéque’’ 400G en tout je vous laisse imaginer.
Un produit qui pour le prix est, à mon avis, comparable à d’autres beaucoup plus cher. Pour finir il n’y a pas d’hésitation à avoir c’est un très bon investissement.
CHARPENTIER P.
simple et efficace
Pour un médiocre soudeur comme moi, cet appareil est bien plus pratique q'un simple fer : affichage de la température réelle, temps de chauffe très court, et panes proposées (en plus) bien adaptées à nos bricolages audiophiles (soudures de connecteurs ...).
Cet appareil qui peut paraître un peu "luxueux" pour un utilisateur occasionnel s'avère en fait vite indispensable !
Klaus Z.
Enhanced sound quality
Compared to the standard Raspberry power supply higher sound quality
Klaus Z.
Easy to assemble, high quality sound
Product was easy to assemble and the subjective sound marvellous.
AUDIO-GD BRIDGE XLR-2RCA Câble XLR Femelle vers RCA Mâle pour Precision 3 (la paire) 1m Ce câble à spécialement été développé par Audio-GD pour permettre de Bridger son amplificateur de puissance Precision 3 et profiter ainsi d'un plus grand apport en puissance.
extraordinaire
j'ai resalent acheter un audio gd pression 3 brancher en stereo 2 x70 w très bien après rodage belle basse chaude mais pas de trop ,le medium est bien clair bonne compreantion des voies et le tweeter cristallin mais le volume était limiter par la puissance de l'ampli ,je suis passer en mode bridge avec SE CABLE franchement la claque ses un autre ampli bien sur il passe a 200 w donc plus de dynamique ,la basse est plus contrôler moin ronde ,le medium ouff très très cristallin surtout les vois humaine homme femme du vrais et tw jamais entendu si clair et encore mes enceinte ne sont pas un produit d'excellence jbl es 90 mais elle se sont quand meme transformer je presise un peut je suis en configuration homme cinema avec preampli av marrant av 7701
Andreas L.
Excellent Service,Great product
The service from Audiophonics was exceptional,product was received in 4 days with in Europe!
The D10 is an amazing quality DAC, i bought it for a usb to spdif converter ,i found out that the sound quality is amazing with lots of detail,it matches the sound of My Lynx 22 studio card.It runs along with more expensiveDACs. Recommended!
Jean-Christophe B.
AURALIC ARIES G1 Lecteur Réseau HiFi 32bit 384kHz DSD512 DLNA / UPnP AirPlay Bluetooth Le Aries G1, nouveau venu chez Auralic est un lecteur réseau high-end aux performances et fonctionnalités incroyables. Entre sa polyvalence exceptionnelle, ses...
Vraiment un excellent matériel, bien fabriqué et avec des fonctionnalités très intéressantes.
D'abord, c'est un des seuls streamers avec une sortie DAC USB, et en plus qualitative (femto clock + alim soignée). Cela a été pour moi le facteur principal d'achat, mon DAC étant "USB only". Mais même s'il y a le choix des entrées sur le DAC, l'USB reste pertinent de part son aspect asynchrone et sa capacité à transmettre les très hauts débits (DSD, + de 192 Khz etc..)
Son utilisation est assez liée avec le logiciel d'Auralic pour IOS (IPad/IPhone) seulement, malheureusement. Mais il est excellent, fiable, et même s'il n'est pas au niveau du logiciel de Qobuz, il donne une interface propre, agréable et ergonomique à Qobuz ou à sa bibliothèque dématérialisée sur un NAS ou un disque USB.
Il peut être commandable à partir d'autres logiciels comme BubbleUPNP, ou autre logiciel compatible OpenHome (Linn par exemple). Mais je ne vois pas l'intérêt par rapport au logiciel Auralic (sauf bien sûr si on n'a pas d'IOS).
Le DSP intégré Tesla 2 est pour le moment sous-utilisé (resampling essentiellement, qualitatif avec plusieurs filtres possibles), mais Auralic prépare une V6 du logiciel intégré avec equalizer et correction de pièce.
Parmi les inconvénients ou les frustrations, il consomme pas moins de 10W en standby ce qui est assez important. Cela permet de le démarrer rapidement, et de donner toujours l'accès par réseau au disque dur raccordé, mais un mode "deep sleep" serait bienvenu.
L'écran est assez illisible de loin, et il manque un mode "gros caractères" avec les infos principales.
Une liaison Google cast serait aussi bienvenue, ce qui permettrait de raccorder ce streamer directement avec beaucoup plus de logiciels, comme celui de Qobuz.
Raphaël B.
Suis très satisfait
Bon produit de bonne qualité prix. Bon serrage sur le châssis et bon contacte avec les cordons.
R. Bouziane
Michel R.
Construction de qualité
Une construction sérieuse et de qualité pour cette multiprise qui permet de mettre en phase les appareils, le tout pour un prix raisonnable. Une alternative recommandable aux multiprises de supermarché sans entrer dans les prix stratosphériques de certains produits « audiophiles ».
Christophe h.
efficace
en remplacement d'un cordon secteur prisonnier...fait le job!
André G.
fourches JANTZEN AUDIO
Ces fourches sont très pratiques et d'un bon rapport qualité prix.
Dominique M.
Etonnant
Tout simplement bluffant.
Pour le prix pourquoi s'en passer.
Ayant un Arcam FMJ D33, pour la pièce dédié, ce petit boitier en étonnera plus d'un et sur tout type de musique.
Il y a 10 ans pour avoir cette qualité de son il fallait débourser beaucoup plus.
Le rapport Q/P est excellentissime.
Emilio B.
Bon câble neutre
J'ai acheté le câble Canare pour relier mon lecteur CD au DAC. Il est neutre, ne colore pas et transmets toutes les infos avec fidélité: je trouve une belle dynamique ainsi qu'une spatialisation en largeur et profondeur très belle. Pour le prix, honnêtement il ne faut pas se poser des questions...
Bastien S.
Très bon cable, multi-usage.
Je l'utilise en câble d'enceintes (2 par pôle) sur des petites Klipsch bibilothèque, le rendu est assez bon.
J'ai l'impression qu'il manque un peu de grave, mais c'est difficile à évaluer, les Klipsch ne descendant pas très bas.
Le son est propre, détaillé, légèrement brillant ; il rend bien les ambiances, le grain est présent, il transmet de l'émotion. Les basses sont propres et bien tendues. Les voix sont nettes, bien présentes et expressives.
Globalement il est très agréable, et il apportera un gain très net par rapport à un multibrin en cuivre lambda !
Je l'ai aussi utilisé pour fabriquer un câble d'antenne pour la TV, en ajoutant deux gaines coton et une tresse de blindage en cuivre étamé (achetées ici).
Et le résultat est très bon !
Image bien meilleure à tous les niveaux, couleurs plus franches et nuancées, noirs profonds.
L'image prend de la profondeur, de la matière.
Sur les visages, on sent vraiment la peau, la chair, la présence des gens.
L'amélioration est surprenante, les décors des films, la lumière prend vie.
Le son est bien meilleur aussi, plein de nuances et de détails.
Changez votre câble d'antenne TV et vous serez surpris !
Bastien S.
Très bon mais assez rigide.
Très bon son, équilibré, détaillé, sensuel.
Par rapport à mon précédent câble optique (un hitachi à 15 euros), la différence est très nette !
Avec ce Viablue, on ressent les intentions des artistes, les émotions. Extinctions de notes, nuances, matière, dynamique, harmoniques, tous est bien placé, propre et net.
On ressent aussi le silence derrière la musique, ce qui la rend plus palpable, présente, spacialisée.
Bref que du bon.
Je l'utilise entre la TV et le SMSL AD18, le son est transfiguré !
Beaucoup de détails sonores apparaissent, c'est très agréable.
je me surprends même à écouter des clips du Top 50 !
Du coup, écouter des concerts à la télé devient vraiment intéressant mais la prise de son doit être soignée, sinon le Viablue mettra la médiocrité en évidence.
Par contre il est assez rigide, ça surprend.
Du coup, c'est son rayon de courbure qui décide de la position de l'AD 18 !
Dans certains cas, si vos appareils sont légers, il faudra les bloquer pour que la rigidité du câble ne les déplace pas.
eric s.
eric
testé avec picoreplayer / super resultat.
le DAC est dans la liste du logiciel / tres facile a mettre en oeuvre.
c'est mon premier DAC avec raspberry et je suis vraiment etonné du son produit.
sinon livraison +++
bref fortement conseillé (mais par un newbee / héhé)
alessandro f.
DAYTON AUDIO RSS315HFA-8 Reference Haut-Parleur Subwoofer Aluminium 400W 8 Ohm 86dB 25Hz - 1500Hz Ø30.5cm Intégré à la gamme "Reference Series" de DAYTON AUDIO, l'unité de grave RSS315HFA-8 reprend à son compte les critères de...
subwoofer dayton
Ottimo altoparlante per subwoofer
prodotto arrivato integro nelle confezione
complimenti a audiophonics , serio e veloce nella spedizione
Lucien S.
CYK Câble de modulation jack
J'ai acheté ce câble avec le DAC Ibasso D14 dont je suis satisfait et je crois entendre un peu plus de matière dans la sonorité en comparant avec un autre câble bon marché acheté sur Ebay.
C'est un jugement subjectif de l'immédiat et j'ai besoin de beaucoup plus de temps pour confirmer ce point de vue.
Lucien S
