Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Mohammed B.
die
Avis clients - Il y a 19398 avis.
Alain V.
RQP imbattable
Il a remplacé un câble de marque beaucoup plus cher... Son apport: dynamique, séparation des instruments, effet stéréo, aigu mieux perçu.
Je le conseille sur le bloc ampli, pas en DAC mais à voir selon son matériel.
Pour le prix vous ne risquez rien de l'essayer!
Vasileios S.
SMSL SA300 clean sound
Amazing sound from this small size amp. Great seller all perfect. Thanks
F. M.
AUDIOPHONICS EVO-SABRE DAC Symétrique 2x ES9038Q2M USB GPIO Raspberry Pi SPDIF Bluetooth XLR RCA Successeur direct de notre fameux module DAC I-Sabre ES9038Q2M, le EVO-Sabre DAC 2x9038Q2M est une version symétrique du convertisseur avec une panoplie complète...
First Impression
a first look at.
Since there is no case yet, I tinkered a paper case to put the mainboard in and the display at the side.
Mounting the RPI 4 is very easy and the drilling holes are exactly at the right place to mount it to the main board.
Power on gives a red glowing on/off button at the front.
Push it and the AUDIOPHONICS logo appears on the display (nice!), filter setting is displayed for a while and the volume setting in %.
Finally you see: unlock.
Now RPI must know what DAC is used.
In Moode: (Moodeaudio.org)
Go to M (menu, upper right)
Configure - audio - I2S audio device
A bunch of AUDIOPHONICS dacs appear:
I selected 2 of them where ES9038 is listed, both work!
Then you can edit the chip/device options: choose 7 oversampling filters, ofcourse all works!
But listening tests will determine which suits you best.
Starting playback in the browser window on my phone.
Immediately the frequency in KHz. is displayed, and the music is playing.
All sound well on my headphone.
I shut the power down.
At the RCA connectors I plugged in 2 monoblock amplifiers, which are under my floorstanding speakers.
For safety I did not power them on.
Again I pushed the red glowing button on the front.
Exactly the same happened at above.
Then I see: 100%. That is the volume setting! So I put the volume knob down to 10% and powered the monoblocks.
All sound well and the remote control works fine for the volume.
Additional knobs are for RPI commands like play/stop and next/previous.
I have to get lirc (Linux Infrared Remote Control) on the RPI, so it communicates directly with the infrared led at the front!
The first impression of the sound is that the speakers seem to disappear and the sound is very broad, even outside left and right.
Connecting my TV to optical toslink shows that the latency is very low, and that is Top Class!
So far, so good. Today the case is visible on the website, its a beauty! I have it on my wishlist already.
Henri F.
confirmation !
après quelques mois d'utilisation, et pris de l'expérience dans les distrib linux je confirme que cet appareil est fantastique alimenté avec l'alim Shanti. Pour moi quasiment imbattable à un prix défiant toutes concurrences ! Je conseille la distribution Gemtooplayer. Gratuite et la plus aboutie sans aucun doute. J'en ai essayé pas mal (volumio, runeaudio, moode, picore, max2play avec LMS, archphile, dietpi, collybia). Pour moi Gemtooplayer est bien au dessus tant pour sa stabilité, les possibilités de réglages, sa flexibilité (lecteur MPD, LMS, squeezelite R2...). On active le player de son choix. On peut faire tourner le système en RAM. La solution la plus aboutie !!! Et elle est gratuite !!! Je vous parle même pas de la qualité de son fantastique associé avec l'allo usbridge sig... Au dessus de toutes. Vraiment ! Je le fais tourner avec squeezelite R2 la meilleure de toutes..... Je les ais toutes essayés... Il y a pas mieux à ma connaissance. Donc j'invite et recommande fortement à tous d'installer Gemtooplayer en lieu et place de Dietpi. Vous ne le regretterais pas. Croyez moi ! Et à tout ceux qui cherchent un fantastique lecteur réseau et qui pensent qu'il faut mettre plus de 1000 euros pour cela.... Non non l'allo usbridge signature à 468 euros avec son alim shanti fait au moins aussi bien et je dirais même mieux. Et en plus on a le choix de sa distrib linux... Donc foncez, et essayer avec Gemtooplayer.
Mladen J.
Préamplificateur Symétrique RCA XLR 10x NE5534D 4x NE5532D Potentiomètre ALPS avec Télécommande Ce préamplificateur symétrique offre une excellente qualité de conception se basant sur des circuits reconnus pour leurs performances et la qualité...
Unbalanced and Balanced Preamplifier
The quality of a professional device for just over € 300, I really don't know how it pays off for the manufacturer! Nothing is missed by chance, multiple stabilized power supply with audio graded electrolytic capacitors, printed circuit board from edge to edge of the chassis, no wires, anti-oxidation coating, premium JRC AOP with the possibility of easy replacement according to taste on stabbing sockets, low noise metal oxide resistors , aluminum housing circa 5 mm thick, and all for a little over € 300! Wow! Congratulations to the manufacturer!
Van Truong N.
Truong
Excellent tube , qualité équivalente à un nos , combiné à 4 Tung sol 120 sur jolida jd 505 c’est une merveille !
Toujours imbattable
Aujourd'hui c'est l'anniversaire de mon R8....tous les jours c'est un bonheur immense d'écouter la musique en Streaming convertie par ce Fabuleux DAC R-2R.
Entre temps, j'en ai écouté des systèmes avec des lecteurs réseau ou Dacs à des prix stratosphériques dans des magasins HIGH- END ... Chaque fois j'avais l'impression qu'il y avait une couverture sur les enceintes.
Ne cherchez pas, AUDIO-GD n'est pas vendu en magasin.
Et comme cadeau d'anniversaire, j'ai offert à mon Dac l'interface numérique AUDIO-GD DI20... et là ne me demandez pas ce qui se passe sur le plan électronique, mais j'ai eu l'impression d'avoir changé de DAC.
https://www.audiophonics.fr/fr/interfaces-digitales/audio-gd-di-20-interface-digitale-amanero-accusilicon-32bit-384khz-p-14191.html
C'est tout simplement magique, c'était parfait avant et là c'est incroyable ...il faut écouter pour comprendre.
Hervé N.
OYAIDE FOCUS 1 XLR
Produit fidèle à l'image de la marque.
Qualité de la fabrication et des matériaux.
Résultat sonore à la hauteur :
+ de définition, + de dynamique,
+ de transparence,...
Attaques de notes réalistes.
Au final, + de musicalité.
Pour systèmes haut de gamme qui
feront entendre leur apport.
Roland B.
Bravo Soundcare
Résultat formidable du maintien du grave et une nette amélioration du médium aigu avec les Soundcare pour mes enceintes Martin Logan je ne pensais pas que le problème venait de mes pointes et contre pointes d'origine pourtant sur une dalle en granit et un acharnement sur les changement de câble de modulation et Haut-parleur sans résultats probant et voilà mon problème réglé et beaucoup de temps perdu et d'argent .
Merci a toute l'équipe d'Audiophonics .
kees V.
Good quality cable
Good quality cable and packed really well!
Thierry A.
Dac externe.
Achat à l'aveugle. J'ai fait confiance aux caractéristiques de ce modèle. Alors oui c'est risqué. Mais ma recherche était d'avoir un Dac très récent avec indicateur de niveau et l'indication de l'échantillonnage à placer entre un lecteur Node 2 et un préamplificateur Hifi.
je ne suis pas déçu de cet achat.
attention à ne pas casser la télécommande, elle pilote le DAC
Michael T.
BLUESOUND NODE 2i Lecteur Réseau Multiroom 24bit 192kHz MQA Le lecteur réseau Node 2i de Bluesound se connecte très facilement à votre système stéréo pour vous ouvrir les portes du streaming...
Franchement pas déçu, mise en œuvre ultra simple même pour un ignorant comme moi. Le son est franchement bon, Qobuz fonctionne à merveille, l’accès aux radio web est d’une simplicité enfantine.
Super produit livré en 48h!
Merci audiophonics.
Philippe L.
Pour piloter une freebox revolution v6
Marche parfaitement avec télécommande Essence 4 de One in All.
philippe j.
MONACOR DTM 104/8
Remplacement des tweeter dans des enceintes MARTIN
Des années 70 bon produit livraison efficace
Vincent P.
Ce câble sert de lien entre le Rasptouch édition Kali et l’alimentation linéaire Audiophonics : très bon câble qui fait le taf. L’ensemble est très cohérent.
Je mets 4 étoiles pour un tout petit souci de finition : la gaine a un fil noir qui n’est pas bien enroulé autour du câble. Ce n’est pas visible sur l’installation car derrière le meuble, mais c’est dommage sur ce produit (sans pour autant justifier un échange car tout fonctionne).
Vincent P.
Alimentation bien finie et apport immédiatement perceptible
J’utilise le Rasptouch édition Kali d’Audiophonics depuis janvier 2020 et ce produit fonctionne très très bien.
Je lorgnais sur cette alimentation depuis quelques temps, un peu septique cependant.
J’ai sauté le pas, après réflexion et en interrogeant l’équipe d’Audiophonics. Et là surprise, l’apport de cette alimentation est perceptible immédiatement : meilleure tenue des basses qui sont moins baveuses, et plus de micro détails.
Ce n’est pas la révolution tant le Rasptouch se débrouillait très bien sans, mais maintenant je ne me vois pas me passer de cette alimentation. Le plus apporté est indéniable et j’ai été scotché d’entendre la différence. Effectivement cette alimentation devrait être proposée en option à l’achat.
Encore une fois, Audiophonics propose un produit bien fini, avec des matériaux qui ont l’air solide.
Et les conseils éclairés de l’équipe qui a répondu à mes interrogations sans jamais pousser à la consommation.
Bref, un produit et une équipe 5 étoiles.
Paul E.
ingénieur-technicien
parfait. très bien fini, et bien emballé
Paul E.
parfait pour placer les transfos toroïdaux autrement.
Attention différentes photos montrent des perforations différentes de l'embase de fixation au chassis. Ce sont 4 trous de 4mm et non une encoche en U.
Gilles J.
Câble USB Pangea
Bon produit et fabrication excellente. A recommander pour une liaison CD / DAC par exemple.
Stéphane B.
Communication
Le relais de livraison a été très long , certes c'étais sans doute explicable en cette période mais un ou deux mail de temps en temps pour me tenir au courant auraient été les bien venu
Stéphane Brégeat
Alexandre B.
MONOLITH THX AAA-887 Amplificateur Casque Symétrique L'amplificateur casque symétrique Monolith THX AAA-887 intègre la technologie THX Achromatic Audio Amplifier (THX AAA). Celle-ci assure une qualité de...
Très bon ampli, aucun bruit de fond, le silence total. Que dire de plus que toutes les reviews que l'on trouve sur le net ? Il arrive très bien à alimenter des casques gourmands tel que le heddphone. J'en suis content à 100% Il est actuellement couplé à un dac Smsl M400 et c'est une tuerie !
Didier V.
Pour se faire plaisir sans se ruiner
Acheté pour alimenté mon casque Beyerdynamic DT 880 (32 ohms) avec une source Hi-Res SMSL SU-8. Le résultat est parfait, rien à dire. Pas de souffle, très bonne puissance. Je pense upgrader mon casque (Beyerdynamic DT 1990 Pro) pour profiter de la belle qualité de l'ampli. Attention l'ampli est en classe A et il dégage pas mal de chaleur, il faut prévoir une bonne aération. Je trouvais le bouton de volume pas très beau (trop long), je l'ai donc remplacé avec le modèle "K008B Bouton Aluminium Massif 25×15.5mm Ø6mm Noir". Il faut cependant couper la tige en aluminium du potentiomètre qui est trop longue (un coup de scie à métaux). Remarque : le fabricant à dû avoir un problème de montage sur ma série car ils ont ajouté une entretoise en bakélite pour fixer la prise casque, c'est donc pas aussi harmonieux que sur la photo du site.
Didier V.
Correctes sans plus.
Désolé je n'ai peut être pas compris ce qui justifiait le prix de ces prises mais à mon avis elles ne le méritent pas. Elles sont correctes sans plus. Le corps est en aluminium, le reste probablement en cuivre doré. Le montage et les soudures ne posent pas de problème à faire. Le câble est retenu à l'intérieur de la prise en repliant les griffes du connecteur de masse (système classique). Elle rentrent dans les prises femelles sans forcer et tiennent correctement.
Luis V.
Very Good Cable
Very Good Cable, supreme quality banana plugs who have a screw fit system for optimum contact.
AUDIO-GD R-28 2020 EDITION DAC R2R DSD Natif I2S ACSS Amanero / Préamplificateur / Ampli casque Le R28 de chez Audio-GD est un appareil tout-en-un d'une rare polyvalence qui réunit dans un seul et même boîtier un DAC full R-2R très haute...
musical typé analogique
belle présence. musicalité superbe. il y de la matiere sans dense et très bien équilibré sur toute la bande passante. alimenté avec câble secteur oyaide (acheté ici 49.5 euro avec prise schuko et iec neotech occ cuivre pl or).. sa chante superbement bien. et en même temps sais doux aéré dans le haut .articulé et expressif dans le medium.les cuivres les cordes et aussi bien les peaux des tambours que les grosses caisses sont très réaliste et riche.sais palpable sans excès ,de l analogique ultra précis. le bas et dynamique articulé et riches de nuance. ont oublie de réfléchir.la scène sonore est de bonne facture. en trois D. sans cet hyper focalisation qui rend un peut trop la définition caricatural comme sur certain dac de marque très connue.que du plaisirs. on vis la musique.. belle réussite que se dac somme toute bon marché vus ses nombreuses qualités. plusieurs réglage de gain en plus des réglage N.O.S véritable. mes préférés .les autre filtre sont plutôt pour les aficionados de la pop ou même de l electro etc. sais perso. et du r2r au prix grande surface..que vouloir de plus..un bemol tout te fois. les prises rca meriterais une meilleures qualité .par exemple je vais certainement les echanger contre des klei rca absolute et changer les fils d orignine par des fils argent pure/teflon pour les contact entre rca et l electronique. et idem pour l entrée numerique..sa montera d un bon crans la qualité subjective du matos.. mais a se prix sais du chipotage.. dans l etat .il estr remarquable. rapport qualité prix imbattable. je connaissais la marque que de nom.. apres se dac..je pense achetter un integré ou un ampli de puissance de la marque.. beaucoup lus et relus sur cet marque..sais étonnant. la différence de prix et de qualité entre audio gd et autres super marques est tenue ,voir plus objective dans sa démarche.. preuve que l ont peut faire de grande chose avec un petit prix ..merci audiophonics pour cet découverte..
Julien M.
Super matériel
Franchement, pour le prix, je suis bluffé, je rédécouvre quasiment toutes mes musiques (fichiers FLAC, sur Tidal ou Quobuz). Je voulais tester ce genre de produit et je ne suis pas déçu.
Pour son placement, c'est vraiment un bon DAC ampli :)
Jeroen S.
First impressions
It works as a headphone (HD580) amp, fed through usb from my computer. The DAC is also going out to my onkyo receiver but I can’t tell a difference in SQ compared to motherboard audio, which may or may not be due to the receiver using its own DAC.
The unit is very solidly built and I’m curious to see if using it to power a dedicated stereo amp will bring the audio enhancements I’m looking for.
Anders L.
Quality and practical
Good quality PCB, which is small enough to fit in various amps. Especially useful for fitting larger pots in old amps that had small pots.
Thomas U.
Très bon ampli, surtout pour le prix, je l'ai testé avec une paire Focal Aria 906, on a une excellente définition.
Je l'ai testé aussi sur des enceintes maison Fostex, résultat très bon, son pas artificiel, on n'a pas l'impression que c'est de la classe D.
franck C.
bon câble
Comme dit précédement, meilleur que le fil argent, facile à souder et quelle définition. le reste du câblage du bras aux prise cinch à été réalisé avec le canar L-4E6S ce qui donne un ensemble cohérant et rredonne vie à ma rega P3.
Yvan S.
DAYTON AUDIO KAB-PMV3 Panneau de contrôle JAB / KAB Panneau de contrôle pré-percé pour KAB / JAB. Aucune soudure nécessaire. Livré avec toute la connectique requise pour profiter de l'ensemble des fonctionnalités de votre module...
Très pratique
J'ai acheté ce produit afin d'avoir une finition parfaite pour des petites enceintes diy. Je ne suis pas déçu du produit, bien au contraire, il est très pratique lorsqu'il est installé avec un produit Wondom comme celui que j'avais commandé et la finition est vraiment top !
Excellent rapport qualité/prix, je le recommande sans réserve.
Christophe V.
Le meilleur !
Étant équipé d’une machine manuelle Knosti et après avoir essayé la majeure partie des produits disponible en France le Pro clean 6 est vraiment le meilleur en terme d’écoute et de facilité de nettoyage aucun résidu après rinçage même si la notice ne l’oblige pas...Une écoute plus défini et plus claire sur le médium/aiguë. Le Top !
Julien S.
DD DJ44B Adaptateur Jack 4.4mm Symétrique Femelle vers Jack 2.5mm Symétrique Mâle Plaqué Or Cet adaptateur symétrique se compose d'un Jack 4.4mm femelle et d'un Jack 2.5mm mâle. Il profite d'une très belle qualité de conception avec un...
Très bon accessoire mais chauffe la signature
Très bel accessoire, bien usiné, ça respire la qualité, pas de jeu dans les fiches, excellente finition. Chauffe cependant les signaux les plus froids, en l'occurrence mon câble Lavricables Master Line, du fait de l'utilisation d'un brin copper OCC, peut être que l'emploi d'un câblage hybride cuivre / argent aurait permis d'atténuer cette petite remarque qui n'est en aucun rédhibitoire.
Emmanuel A.
Bien pour débuter
Ceci est mon premier DAC. N'étant pas expert je ne peux donner un avis éclairé sur le sujet .
Je l'utilise comme DAC/ampli avec un casque Elegia et le son me semble tout à fait correct.
Quand les finances suivront, je le brancherais sûrement sur un ampli casque dédié.
Connecté en USB à windows 10 il est directement reconnu sans aucune installation et est utilisable sous foobar ou MusicBee en sortie WASABI.
Le son est propre à mon goût.
Seulement voilà, il existe un retard de lecture d'une demie seconde au démarrage/reprise de la lecture qui fait manquer une petite portion du morceau écouté.
Après échange avec FX-audio par mail, il semblerait que la puce IC CM6642 qui gère l'entrée USB est à l'origine de ce problème.
Il est possible sous MusiBee de jouer un silence à l'initialisation du DAC mais cela corrige en partie le problème.
Finalement, les meilleurs résultats avec délai à la lecture sont obtenus en branchant la sortie optique de la carte son incorporée de ma carte mère à l'entrée optique du DAC et en sortie ASIO uniquement.
Venant du monde des cartes sons je constate que je gagne nettement du côté des interférences électromagnétiques envoyées à la carte pour y perdre dans un petit détail.
Au final, le plaisir d'écoute est la pour un budget tout doux pour qui peut outrepasser ce petit problème avec l'interface USB.
Bon boitier.
Comme tous les boitiers galaxy et ils sont facile a utilisé et ont un aspect agréable. J'en est acheté plusieurs.
Un petit défaut de la série, c'est que les panneaux ont tendance a être isolées les uns des autres, et donc il est assez difficile d'avoir une bonne cage de Faraday.
Bon connecteur!
L'utilisation est simple, le soudage se passe bien et le connecteur tient bien en place sur l'embase. Les matériaux utilisé sont correct.
Attention cependant au câble il ne doit pas être trop gros! ...le Ø7mm est très vite remplie.
anthony h.
DYNAVOX X2000 Distributeur Secteur Filtré 5 Prises Schuko Fonction Master-Slave Le X2000 est le dernier distributeur secteur HiFi de Dynavox, complétant la gamme déjà composée du X4100 et X7000. Le X2000 en reprend les bases avec...
Un peu decu
Alors je n ai même pas eu l envie de tester le produit au deballage
Le potentiomètre est pas centré mais en plus il penche d un côté
Le bouton en plasite du maître esclave frottre contre la paroit intérieur du trou du bloc d alu
Ces deux défauts ne m ont pas donné envie de la tester
Pour ceux qui sont pas trop exigent sur la qualité pourquoi pas mais quand on est exigent surtout dans cet ordre de prix passez votre chemin.
Je ne comprends pas comment des défauts aussi flagrant soit il, arrive à passer le contrôle qualité . Pour moi c est retour direct
Les défauts que vous décrivez restent des défauts visuels mineurs. Le distributeur secteur et toutes ses fonctions fonctionne en somme parfaitement.
Patrick A.
Attention problèmes suivant cellule
Oui, j'avais déjà écrit un avis avec une note de 3/5 mais là, non. Impossible de peser une cellule Lyra par exemple, car le corps de la cellule touche la palette en même temps que le stylus. A cause du creux de la cible blanche de pesée, on le voit sur la photo... quelle bétise !
Jorge G.
Excellent for an Audio Research Reference 3
Excellent for an Audio Research Reference 3 as a PS tube driver, event better than Winged 6550C SED C. I don't understand why AR suplies 6550 Sovtek.
Thierry P.
AUDIOPHONICS CANARE Câble numérique Coaxial 75 Ohm RCA-RCA Gainé 1m Voici notre câble numérique coaxial Audiophonics Canare en version 75Ω. Sa particularité est de comporter des connecteurs Canare C5F, certifiés 75Ω et un câble Canare L-5CFB.
Tout simplement parfait pour relier ma platine cd Marantz Cd 5005 à mon amplificateur Cambridge cxa60 .
Prix tout à fait raisonnable pour ce câble de très bonne qualité de fabrication et d'écoute.
Rune E.
works well
Does what it does. Quick delivery from France.
John B.
TOPPING P50 Alimentation Linéaire Régulée Ultra Faible Bruit 2x 5V 1A + 15V 1A Noir Cette alimentation linéaire régulée Topping P50 offre d'excellentes performances et permet d'alimenter proprement un système HiFi et ainsi favoriser...
A worthwhile and affordable upgrade
I’ve been using Raspberry Pi and various HAT combinations for a few years around the house, in the bathroom, bedroom, garage etc. Powered from a selection of switching mode power supplies. No complaints, they sound fine. But for my “main” system I persuaded myself that I needed to upgrade. I am glad I did. I have removed all the switching mode power supplies from nearby and I am running an Audiophonics iSabre DAC and a Pro-Ject Phono DS2 Ultra from this Topping device. The improvement is tangible. The sound emerges from a quiet background and it has atmosphere and presence. Particularly enjoying the recent release of Bill Evans at Hilversum. I recommend this inexpensive upgrade. (Other components are - iconAudio 40i Stereo Valve Amplifier, ATC SMC11 loudspeakers, picoreplayer, Logitech média server.)
Prix dérisoire son nickel
Connecté entre une télé tcl et convertisseur musical fidelity ; impeccable pour le prix.
UN SANS FAUTE
Image fine et détaillée mais de façon naturelle. Prix très raisonable.
Une révélation
Je posséde plusieurs câble AES, après comparaison ce cable me donne vraiment Les meilleurs résultats ,on passe du tout venant a l'exceptionnel.Bravos Audiophonics pour cette réalisation au rapport qualité prix trés intéressant .
Diego D.
bonne rétractation
Diego D.
parfait bonne rétractation
Thierry R.
J'avais besoin d'un câble court, 50 cm c'est parfait pour moi, l'ampli étant juste au dessus du lecteur CD. Ce câble est effectivement très rigide, sans problème dans mon cas. Fonctionne parfaitement avec un IN200 Signature et un lecteur Marantz.
AUDIO-GD NFB-1AMP 2019 Préamplificateur / Amplificateur casque Class A Noir Ce préamplificateur / amplificateur casque NFB-1AMP de chez Audio-GD met à profit les différentes évolutions techniques de la marque et est capable...
Un appareil à l'excellent rapport qualité/prix
Mise à part une livraison particulièrement pénible (près de 15 jours) due , parait-il aux conditions sanitaires voilà enfin cet ampli en service, couplé avec le DAC SONCOZ nouvellement importé par Audiophonics. Le résultat musical est absolument parfait pour ma part. La puissance est énorme et mon casque Focal Clear respire comme jamais . L'aigu est restitué avec finesse et sans agressivité , le grave est parfaitement tenu est puissant et le médium n'est pas en reste. Je suis intégralement en liaisons symétriques jusqu'au casque. Bref un bien bel appareil, certes un peu massif mais quand on voit la qualité de la construction on comprend mieux, et enfin le prix, même si 649 € ce n'est pas rien qui permet à de nombreux audiophiles d'avoir un appareil de qualité.
Thierry R.
Pratique
Cette alimentation me permet d'alimenter une chromcast, une chromcast audio et un switch. Le tout pouvant être coupé d'un seul coup plutôt que de rester alimenté en permanence. Elle est assez stable entre 5V et 5.2V. Parfait
