Thierry W.
Avis clients - Il y a 19594 avis.
Hendrik-Jan H.
Very nice sound quality, good build, nice features
I bought this card in combination with the RaspiTouch DIY kit, and together with a touch screen and raspberry pi model 3B+ build it into a dac/music player/storage.
This is a wonderful card with very nice features:
- great power supply connectivity
- Very nice Clock crystal
- Perfect ATX feature for shutting down your pi like a real pc/hifi device
I had some issues getting the connections right as the print on the board is not 100% what is in the manuals. But the support team is very helpfull here and provides descriptions with pictures.
I ended up with a great audio device in a very nice case.
Would buy again.
Hendrik-Jan H.
Very nice product, not the easiest to assemble
The RaspTouch IY kit is a very nice product. The parts are nicely machined, and the resulting built looks very good.
Audiophonics also provides a guide on how to put it together.
Where things do get a bit tricky is in the build: I think I was a bit unlucky as it turned out i did not receive all the screws needed for this build. Also it seems there are several iterations of the kit where some components are placed on a different location than described in the manual. The trickiest part I found was the SD card extension that had to be taken out of its casing and placed on the metal. As to make sure I would not short-circuit the piece, I first taped it up before fixing it to the metal.
Also because of these changes in the kit, not all steps and parts are self-explanatory anymore, which makes the build tricky.
But the support team is very helpful here and provides useful information and images to guide you through the steps.
Also in my case: they provided the parts I was missing, thank you guys!
Now I have this case set up with a raspberry model 3 B+ with touch and a DAC. As software I chose Moode Audio, and it sounds and functions perfectly.
ah les dins !
pour un Ami, j'ai fais des câbles modulation avec d'un coté des RCA Amphenol, noir et rouge, qui vont bien avec ce câble, en dimensions, et qualité. et de l'autre coté une DIN 5 broches or. corps métal elle aussi de bonne qualité. il y avait assez longtemps que je n'avais pas fait de soudure sur DIN….je ne me rappelait plus comme c'était c..... enfin j'y suis arrivé, c'est l'essentiel, et le résultat est très bien.
Eric f.
AUDIO-GD NFB-1.38 DAC ES9038Pro DSD/DXD Sabre 32bit / 384K USB Amanero HDMI TCXO L'exceptionnel DAC Audio-GD NFB-1.38 est équipé d'un convertisseur ES9038Pro assurant des performances audio incroyables mais également d'USB Amanero, d'I2S...
après quelques heures d'écoutes, ce dac ne déçoit pas,
Très détaillé, offrant une scène sonore ample, cet audio-gd est un plaisir à écouter.
En y associant un bon câble secteur et des cables XLR de qualité les résultats en rapport qualité/ prix sont très au-dessus de la moyenne.
Eric
Roers studio 1, Roksan, Yba cd1 alpa, hifi cables (Thot)
Carlos B.
œuf de colombo
Pourquoi personne n'y avait encore pensé?
Très utile et pratique.
Elund C.
Really great value for money
Really great sound. Maybe the best deal if you want a DAC to your computer for your headphones. Only disadvantage is the size of box - could be smaller if you compare with DAC's from Topping.
Elund C.
TOPPING D50 DAC 2x ES9038Q2M 32bit/768kHz DSD512 XMOS U208 Noir Le DAC TOPPING D50 comporte tous les composants embarqués pour jouer de la musique dématérialisée de très haute qualité. Disposant...
Unbelievable value for money
I have replaced a Schiit Modi 2 with Topping D50. It's an impressing sound comming out of this little box. I would consider this little DAC to be the best buy overall, if you want to get good sound from your computer to your HI-Fi system.
Johan v.
One very good DAC!
I have taken of one star for some very minor quibbles that are mostly mechanical in nature.
First of all was the input selector that has a wobble on its shaft, it was not a loose knob.
As this black version is painted on all panels and screws I experienced some mobile phone breakthrough on my system.
Taking some paint away from the 6 top screw holes has cured it making it closed to Hf.
The last one, the coaxial input RCA is not mechanically connected to the chassis making it vulnerable to becoming disconnected from the pc board as it is only soldered to it.
So a little care is needed if you frequently plug and unplug your SPdif cable.
The sound is so good that it might beat some turntable setups!
It does deserve a better or different op amp to bring all its qualities out.
On red book material it beats my far more expensive Teac UD-501 DAC fed from a CD player`s output.
This is mainly because of its smooth presentation whereas the Teac can sound quite artificial sometimes.
On DSD from the laptop with Foobar the Teac pulled ahead , in a way not a fair comparison as the Audiophonics DAC does not do native DSD.
All in all excellent value for money and a big thank you for Audiophonics ! Merci!
olivier m.
High quality product & express delivery
Myrielle m.
fabuleux vraiment top
Le furutech Fi-E38-R est fabuleux par contre la référence furutech FI-E48-R gagne beaucoup plus avec piezo céramic carbone à l'intérieure du boitier une rapidité énorme bruit fond super bien présenté juste le prix c'est un choix personnel de votre système la plus haute gamme chez furutech NCF le rêve extraordinaire magnifique ko merci .
antoine L.
câble DC alimentation ifi pro ican,
le câble en lui même est très bien fait, avec des bons connecteurs, soudure de qualité, comme les câbles cuivre, il n'y a que des matériaux nobles,
mon reproche, et c'est pour cela que je supprime une étoile peut etre que j'aurais du en supprimer même deux,
Audiophonics a sur son catalogue à la vente l'ampli casque iFI pro ican, et la nouvelle alimentation Audiophonics qui apporte un vrai plus à l'ampli casque iFI pro, par contre ce que je ne comprends pas c'est le câble de liaison DC recommandé par Audiophonics ou la fiche DC 2.1 n'est pas totalement adapté coté iFI pro ican, le contact se fait, mais il ne se fait pas à la perfection, en cause les fiches DC classiques montées sur le câble de liaison, sur le coté alimentation Audiophonics c'est très bien, il n'y a pas de problème le contact est parfait,
je n'arrive pas à le comprendre de la part de spécialiste de la connectique, qu'il ne se soit pas intéressé plus sérieusement à la fiche DC allant coté iFI pro ican,
peut etre qu'un jour Audiophonics s'y penchera sérieusement, mais cela voudra dire, qu'il faudra encore débourser du fric pour avoir le bon câble souhaité,.......alors qu'il aurait du etre prévu, et surtout après essais en condition réels pour la liaison de l'ampli casque et de son alim,......
Marylène C.
Presque parfait
Cet amplificateur est capable de faire des merveilles. Associé à un dac FX01 on obtient pour à peine plus de 200€ un ensemble bourré de qualités, capable de driver des 38cm.
Il surpasse très largement le FX D802, IAMD V200, beaucoup plus de délicatesse dans le rendu, plus nuancé, moins brut et aucunement simplifiant.
Il surpasse également un SMSL SA-S3 (ta2021b, un incontournable également malgré ses limitations)
Ainsi qu'un ancien modèle de sono et un Marantz PM5005 (ces 2 là simplifient et masquent beaucoup de détails en comparaison du topping) même si le marantz est agréable et montre de sérieuses qualités si bien associé le Topping a clairement ma préférence.
Je l'ai également comparé à un petit class D icepower de 50w, et là aussi le TA2022 s'impose.
Les points négatifs qui lui font perdre une étoile: pas de télécommande, des transfos qui ronronnent un peu quand on est à moins de 50cm de l'ampli ça peut peut-être se révéler gênant pour une écoute de proximité de type homestudio. A noter que mon environnement sonore est très silencieux (campagne lojn de toute route fréquentée)
Globalement je trouve ce produit très satisfaisant et je regrette simplement de ne pas l'avoir testé plus tôt. Privilégiant des produits plus récents en class D ou FDA qui ne m'ont finalement rien apporté et se sont révélés franchement décevant. Clairement un TA2022 bien mis en oeuvre comme c'est le cas ici est toujours excellent en 2018.
A souligner la très belle qualité de fabrication, borniers de bonne taille, boitier bien fini, réglage du volume fluide, rien ne fait cheap.
En conclusion le TP60 c'est un savant mélange entre douceur et précision, punch et délicatesse.
Ante M.
DAYTON AUDIO ND140-4 Haut-Parleur Bas Médium Aluminium 40W 4 Ohm 88dB 54Hz - 8000Hz Ø13cm Le ND140-4 est un amplificateur type médium graves appartenant à la série NEO de Dayton Audio. Moderne et résistant, il exploite un cône aluminium cerclé de gomme pour maintenir...
Great product
Great product just what I needed.
Patrick H.
Audiophile sound on a budget
As the title states this little gem really offers an "Audiophile sound on a budget". Compared to the MATRIX MINI-I PRO 2S ES9026Pro and the FiiO X7 MKII ES9028Pro the Topping plays on the same level while using the stripped down version of the ES9038 pro, the ES90382Q2M. Detailing and clarity are on par and IMO slightly better with classical and contemporary music. To be honest, it doesn't sound good with highly compressed dynamic range (loudness) music. But so does not the two other above mentioned dacs.
Output the Topping to a Violectric V100, Sennheiser HD660s, Beyerdynamic Amiron Home be prepared to imerge yourself in an audiophile experience hard to find in this price range.
Frank P.
La marque Neutrik jouit d'une très bonne réputation et cet adaptateur n'en déroge pas.
Un satisfecit pour la boutique Audiophonics qui propose de bons produits et un excellent service. Merci à vous !
vraiment génial
le furutech FI-E48-R est déjà sublime rien à dire par contre la gamme furutech NCF passe le niveaux classe mondial exceptionnel un rare moment à écouté urgent avec des câbles secteur haute gamme furutech franchement bravo chapot il y à pas mieux merci .
Myrielle m.
magnifique furutech
malgré sont prix assez élevé furutech est l'un des meilleurs connecteur classe mondial n ° 1 c'est du rhodium carbone piezo céramic accompagné d'un lecteur cd YBA câble secteur nordost tout simplement magnifique mon pronostique persso que du bonheur à essayé avec plaisir sans modération merci .
JEAN FRANCOIS V.
Excellent couvre plateau.
Pour ma part je trouve que le diamètre de 30cm est trop important,
mais c'est du liège facilement recoupable.
La suppression des micro bruits est évidente dés la première écoute.
JEAN FRANCOIS V.
Trés bien
J'ai remplacé les pieds d'origine d'une platine vintage par ceux ci et le résultat est convaincant ,pas de bruits malgré le fait que la platine est posée sur une commode.
JEAN FRANCOIS V.
Trés bien
Du haut de gamme à bas prix.
Utiliser du cable de forte section pour qu'il soit bien serré dans la fiche
JEAN FRANCOIS V.
Très bon cable de modulation utilisé pour recabler des platines vinyl.
Souple et facile à souder à raccorder avec des fiches rca de qualité.
De plus le prix au mètre et vraiment inintéressant.
Fragile
Matériel correct qui souffre toutefois de deux défauts, les vis en métal mou déjà évoquées et un collier de serrage du câble fragile, dont le plastique ne résiste pas à trois serrages un peu fermes. Savoir aussi que "red copper" signifie laiton anodisé.
Au total, un peu léger pour le prix.
Bernard D.
très médiocre en streaming Qobuz
Je cherchais un streamer pour Qobuz... Quelle déception. Bien sûr c'est un joli objet mais cela s'arrête là !
L'application Qobuz est la version pour téléphone Android sauf qu'elle n'est pas vraiment adaptée au Nativ. Elle réagit avec un délai, le défilement prend beaucoup de temps, elle se plante, etc. Et de temps en temps, une fois toutes les deux ou trois heures d'écoute, la musique est subitement remplacée par du bruit type mauvaise bande FM!! Il faut tout redémarrer pour reprendre l'écoute. Non, vraiment à ce prix là il faut éviter ce produit ! Existe-t-il d'ailleurs un bon streamer HI-RES avec une une application Qobuz qui tienne la route ?
Ce produit évolue en permanence depuis sa mise en vente, l'équipe Nativ continue de l'améliorer par des mises à jour.
L'application Nativ est dorénavant disponible dans les deux stores : iOS et Android, elle permet d'accéder à l'interface du lecteur directement sur le téléphone, et permet donc de le contrôler à distance.
Les dernières mises à jour ont également apporté le support du DLNA en tant que récepteur et serveur.
Il est donc désormais possible d'envoyer un flux provenant d'une application comme Bubble UPNP sous Android ou 8Player sous IOS.
Ou d'accéder au contenu stocker sur le Nativ depuis une des ces applications pour le lire sur le récepteur DLNA de votre choix.
Le lecteur est également compatible avec l'application ROON Remote pour ceux qui sont abonnés à ce service.
L'application Bubble UPNP comporte (entre-autres) un plug-in Qobuz très pratique d'utilisation, vous permettant de profiter de ce service sur le VITA.
Sinon en streamer Qobuz, un Raspdac ou Rasptouch avec Logitech media serveur (PiCoreplayer ou Dietpi) qui comporte un plugin Qobuz, ou avec Volumio en envoyant le flux Qobuz en DLNA depuis Bubble UPNP.
Mais la configuration est moins aisée que sur le Nativ VITA.
Jean-Marc B.
AUDIO-GD MASTER 10 2019 EDITION Amplificateur Class A Symétrique ACSS 2x 500W 4 Ohm L'Audio-GD Master 10 est un impressionnant amplificateur intégré symétrique en Class A, capable de délivrer une grande puissance pour accompagner les enceintes les plus exigeantes.
RQP époustouflant
C'est sûr, le RQP de ce produit est impressionant. Histoire d'aider les autres audiophiles dans leur choix, je vais tenter d'apporter quelques infos supplémentaires.
J'ai acheté cet ampli pour remplacer un Audio Analogue Grand Maestro que je n'étais pas sûr de pouvoir faire réparer. Le Grand Maestro est sorti en 2001 à environ 4000 €, ce qui ferait 5300 euros d'aujourd'hui.
Résultat ? l'AA étant un classe A, il ne manque pas de dynamique, mais le M10 en a encore un peu plus, et surtout une meilleure présence et fermeté dans les graves. Par contre, en terme de finesse, fluidité, raffinement des timbres, domaines de prédilection de la marque AA, le M10 est plutôt en retrait, même s'il s'en tire remarquablement bien pour son prix.
En conclusion, j'aurais envie de dire que les deux amplis sont comparables, chacun avec ses avantages.
Quoiqu'il en soit, si vous avez 2200 € à mettre dans un ampli, c'est vraiment ce M10 qu'il faut acheter.
Myrielle m.
super top furutech
très cher mai comme on dit c'est du furutech rhodium produit haute gamme quoi dire de plus c'est juste le prix mai bon franchement beaucoup mieux que les ancien rhodium la classe voilà .
Eric L.
Qualité prix top
Pas d'autre point de référence mais pour le prix, très satisfait de mon achat. 4 montés en // et drivé par un behringer A500 par canal de quoi donné de la présence aux basses voir même de l'impact.
Seul léger bémol, sur des sons de type vrombissements, pales d'hélicoptère, on "entend" le vibreur légèrement. Peut-être du à mon montage.
Attention il faut prévoir des rondelles de fixations épaisses pour légèrement surelever le vibreur
Francois M.
sont-y pas mignons ?
Faciles à poser, tenant bien sur les prises en assurant une bonne protection contre la poussière et la corrosion, le tout à un prix dérisoire ! Parfaits pour moi ! Y penser pour la revente des appareils...
Francois M.
Respire la qualité !
Bien conçu, bien fabriqué, prenant bien la soudure, facile à monter et très bon contact !
Francois M.
Costaud !
Peut-être un peu gros (remplacement d'un inter on-off sur une platine) mais semble très robuste ! Montage très facile !
Joseph P.
RQP+++
J'ai acheté ce câble par curiosité lors d'une commande de composants pour filtrer des enceintes. A 1.40e le mètre on ne prend pas de risque. Je le branche entre mes blocs Pass f5 turbov2 et mes TQWT supravox +fountek et là... Ça marche du tonnerre. Je vous épargnerai les dithyrambes de circonstance simplement le meilleurs rapport qualité/prix qu'il m’ait été donné d'entendre...
Laurent D.
produit efficace
bonjour ayant un pc tour avec une alimentation pour ma musique dématérialisé j'ai opté pour ce filtre alimentation pour ventilateur car le miens était bruyant et la il a reduit enormement le bruit ,on entend encore quand on met l'oreille a coté mais pour cela il faudrait l'ailimentation mais il a fait son travail et rien de plus bon produit a recommandé.....
Denis B.
ELNA SILMIC II Condensateur Audio RFS Aluminium 50V 4.7µF La série Silmic II RFS (ROHS) est une série haut de gamme de condensateurs de chez ELNA qui présentent des qualités acoustiques supérieures....
NICHICON ES MUSE Condensateur Audio Audiophile 25V 10µF Les condensateurs électrolytiques Nichicon de la gamme ES Muse sont spécialement conçus pour une utilisation HiFi. Ils offrent ainsi d'excellentes...
NICHICON ES MUSE Condensateur Audio Audiophile 35V 470µF Les condensateurs électrolytiques Nichicon de la gamme ES Muse sont spécialement conçus pour une utilisation HiFi. Ils offrent ainsi d'excellentes...
Rien à dire ! Choix,prix,communication,expédition,site.....bref rarement été aussi satisfait !
Bernard G.
Excellent câble mais attention à la connectique.
Drôle d'histoire ...
Ne me sentant pas une âme de soudeur j'ai acheté des prises XLR vissées. Une catastrophe! Le câble rendait un son très sourd digne d'un caisson de basse.
Après quelques semaines de bouderie, Je les ai équipés de Neutrik RCA pour connecter mon ampli casque. Et là ce fut la Révélation: détails, spatialisation, timbres tout y était. Mes premiers connecteurs XLR seraient-ils en cause?
Pour en avoir le cœur net je les ai équipé de connecteurs XLR Neotech (en cuivre plaqués or). Depuis ils relient un Roksan Caspian M2 CD à un préampli Audio Research LS17. Ils sont extraordinaires et j'ai eu l'occasion de les comparer à des câbles haut de gamme de chez "Hifi câbles & Cie", Viard ou encore Ecosse.
Ils n'ont vraiment pas à rougir devant ces prestigieux concurrents et sont d'une extraordinaire musicalité.
La conclusion de cette histoire est qu'on peut sublimer des câbles avec de bonnes connectiques ... et inversement.
Julien F.
FURUTECH TF Fusible Cuivre OFC Plaqué Rhodium Type T Lent 5x20mm 4A Furutech propose avec sa gamme TF des fusibles temporisés semi-lent d'exception. En effet, la marque y intègre des composants de très grande qualité...
L'amélioration indispensable!
Après avoir lut pas mal de revues sur les fusibles et après avoir vu une vidéo où le directeur de Genesis (qui a participé à plein d'enceintes hauts de gammes, voir conçut directement) expliquait avoir été incrédule puis stupéfait sur les fusibles, j'ai eut envie d'entendre ce que ça donnait.
Je ne sais sincèrement pas ce que ça va donner une fois totalement rodé mais dès la mise en marche de l'appareil et le lancement de la musique, le son est plus sauvage, Toute une foule de détails est plus accessible et surtout on note une réduction assez forte du bruit, les sons sont désormais bien plus séparés, c'est un régal! Comme si l'appareil venait de se libérer d'une partie de son carcan, la musique est plus prenante, plus réaliste et l'illusion prends plus corps en face de vous.
L'autre point appréciable est que j'ai dut baisser mon son donc l'ampli chauffera légèrement moins.
C'est cher pour ce que c'est en un sens, une minuscule petite pièce qui a subit différents traitements tout de même, mais qui est vraiment la base avant toute amélioration audio car celle-ci, vous la garderez. Le retour en arrière est simplement impossible.
Gerald C.
Transfo d'excellente qualité, livré avec le support. Nickel
Miguel F.
DYNAVOX PKV-800 Amplificateur Casque Portable 900mW 16 Ohm Si vous trouvez que votre smartphone ou votre périphérique source ne fournit pas assez de puissance, alors le Dynavox PKV-800 est une excellente solution. Ce petit...
Objet de désir
Magnifique concentré de technologie, je l'ai offert a mon fils, mais je pense que je vais en prendre un pour moi aussi, la différence d'écoute avec et sans est tout simplement bluffante.
Stéphane P.
Qu'elle WattRms
Bonjours, vos produits on l'air fort intéressant mais pour pouvoir y connecter des haut parleur sans faire d'éreur il faudrait avoir une indication en wrms. Car les watt max ne permette pas d'avoir une valeur fiable
... merci
Fabrice L.
Acheté sans grande conviction vu le prix mais sincèrement très bien. Il apporte de la matière au signal, on perd en agressivité. Tout est moins dure, moins numérique, moins criard. Je l'utilise en plus dans des conditions un peu bof. Sortie de switch à 20€, switch lui même connecté au courant porteur. Je recommande. Branché à une super source (lumin A1) par contre. La machine apprécie visiblement.
Benny A.
Good quality
Nice thickness of the enclosure. Easy to assemble. Nice finish, although some small shifts in variation was noticed in bright light. Good value for money I think.
anastasios f.
Its better than my custom LM3875
I bought this amp because of the very good reviews for the ncore technology. I have a very transparent system , with a metrum acoustics dac and monitor custom speakers with a high quality crossover. My system is as transparent as possible and colorations are easily perceivable. There is a substantial difference to my custom built lm3875 amplifier. The sound is clearer , more dynamic, I would say more contrasty. The biggest difference is in the bass. Its overall better. However the music from youtube videos can be better with my old amp....... Sometimes colorations and artifacts can make a poor audio stream sound better. Needs good recordings to show its true potential. It is easily the best amp i ever had! Everybody should buy one of these. It is a must! The price quality ratio is the best on the internet. It matches very well my metrum acoustics dac.
Gilles G.
fiche RCA Gaofei
Il est vrai que ces fiches ont un corps en laiton, cuivré. Ce qui est discutable. Toutefois ces fiches sont de bonne facture avec l'intérêt d'être constituées d'un corps monobloc, ce qui est très bon pour la continuité de masse.
Gilles G.
Gaine Coton naturel pour câble Ø5-8mm écrue Gaine tressée 100% Coton naturel pour isolation de câbles.
Gaine coton
Gaine coton facile à poser et solide.
Gilles G.
gaine coton
Gilles G.
Embase RCA ER 103
Embase RCA de bonne qualité. Son principal atout, pour moi, c'est que la cosse de masse fait partie du corps. Ce qui évite le contact aléatoire d'une cosse serrée par un écrou.
Gilles G.
Câble Mono-conducteur multibrin silicone 0.5 mm²
Câble souple très agréable à travailler et facile à souder
Je l'utilise pour mes faisceaux de masses
Du neutrik quoi :)
Sans surprise pour un connecteur neutrik: qualité au top, rien à dire !
Impeccables !
Bonne qualité de fabrication, faciles à souder
La bague de couleur est légèrement conique et s'écrase lors du serrage contre le panneau pour empêcher la rotation ensuite.
Un excellent choix que je referai si besoin !
Laurent D.
produit de qualité
bonjour, que dire de IFI AUDIO que ce sont des produits de qualité a prix raisonnables et qui vous fournira un courant plus propre a vos appareils ,ils le valent bien alors pourquoi sans priver .....
Laurent D.
produit de qualité
bonjour c'est un cable de fabrication artisanale de qualité de chez audiophonics qui vaut son pesant d'or ,encore merci pour ce conseil avisé pour mon systeme ,que du bon .......
Sebastien y.
assez génial !
Pour 35€ vous avez un DSP et un ampli classe D tout à fait correct !
On regrettera la très faible documentation Wondom se résumant a quelques vidéos...
La programmation de l'engin est un peu laborieuse et demande le respect d'une procédure pour uploader son programme.
Je l'ai utilisé dans une enceinte bi-amplifiée avec le JAB3 pour les aigus et un T'Amp pour les graves. On peut régler le crossover, mettre en place des limiteurs pour protéger les HP, règler le volume avec un petit encodeur rotatif... Si j'achète un micro de mesure UMIK 1 je pourrais même corriger automatiquement mes HP...
