Luca C.
Panos M.
Its more my personal taste
Ludovic P.
Avis clients - Il y a 19585 avis.
Gilbert H.
Expédition rapide comme d'habitude. Produits conformes.
Mait N.
FOSI AUDIO TB10D Amplificateur Class D TPA3255 2x230W 4 Ohm Le Fosi Audio TB10D est un amplificateur Class D compact et puissant, proposé à prix contenu. Son étage d'amplification utilise une puce TI TPA3255 hautes...
Excellent for bass
Powerful. Does not care of your speaker impedance curve. Dynamic. If there is sudden peak, it stresses this over. Probably you have to pay 10 times more for getting better amplification for your woofer. I have compared this to mediocre 4x more expensive Yamaha, this blows it away with ease.
On higher range, above 1000 Hz not so good any more. Still with power and dynamics but somehow the sound is like it transforms sinus wave to square a little bit. Also, as tested shows some harmonics there. Could be excellent choice for old and lazy paper driver system. Gives you dynamics and sharpness without need for new drivers. In case you have some metallic tweeters then the combinations is not the best.
But still, for the money it is more than five stars. Would buy again.
Mait N.
Récepteur Bluetooth 5.0 CSR8675 aptX HD LDAC Ce récepteur Bluetooth 5.0 compact vous permettra d'ajouter une capacité de réception sans-fil à un système audio existant. Ainsi, il devient...
Partial functionality
Somehow LDAC to optical out did not work. It works to digital out, but not optical for me. Sound started cracking and whistling. So had to return it. All other functions were working.
Mait N.
XDUOO XQ-50 PRO2 Récepteur Bluetooth 5.1 QCC5125 aptX HD LDAC DAC ES9018K2M xDuoo propose avec son XQ-50 Pro2 un excellent récepteur Bluetooth, simple d'utilisation et performant, qui vous permettra de transformer votre installation audio en...
LDAC is good
Good receiver, takes highest BT LDAC settings to optical out without any problem. Seems bigger on the picture, but in reality is nice small sized. Did not need or test other settings.
Guy H.
Belle esthétique et finition.
Silencieuse.
Livraison rapide et bien emballé.
LE ROI DES AOP
La technologie discrète est souvent préférée à l'intégrée pour des raisons qui sautent aux oreilles à l'écoute de ce SPARKOS. Lors des premières écoutes, c'est aussi bon que mes AOP TLE2142 CP mais ce n'est qu'après plusieurs heures d'écoute que le SPARKOS se réveille en révélant la musique dans son sens le plus fidèle. Je crois qu'on ne peut pas trouver de point faible à cet AOP. Le prix n'est certes pas donné mais la plus-value est certaine. Deux petits Sparkos ont transformé mon Aiyima A07 en un produit High End.
Constantin N.
TOPPING LA90D Amplificateur Discret Class AB 2x120W / 1x180W 4 Ohm Noir Topping propose maintenant l'excellent LA90 dans une version utilisant des circuits discrets, le LA90 Discrete. On retrouve ainsi un amplificateur puissant offrant d'incroyables...
The last amp you'll ever need
You know why you're here.
You've seen the measurements.
You know what this is amp is capable of - especially in bridged mode.
Is it expensive? Kind of.
Is it expensive compared to all the ultra expensive voodoo amps out there? No, it's actually a steal.
Go grab it and be happy ever after.
No but really, so far I bought two of them. Absolutely incredible clean sound - no frequency dependend distortion!
Only thing left to see is reliability, but this amp didn't even get remotely warm in my first week of usage. So I expect it to last decades, at least.
Rene C.
Do the job in a non hifi context
I purchased an offer =1,8 m
Used 1,5 m of this cable for my Ampeg Bass Combo BA-112. The 3 x 3,5 mm is spot on, the sound isn´t too fat / full.
The sound must not be to clean (hifi) a little dirt left, is to prefer !
Jean-Pierre f.
AUDIO-GD R2R-11 MK2 DAC Amplificateur Casque Amanero 32bit 384kHz DSD512 L'Audio-GD R2R-11 MK2 est LE couteau suisse pour audiophile. Combinant les fonctions de DAC, préamplificateur et amplificateur casque, il comblera la plupart des besoins....
acoustiquement délectable
Acheté par curiosité audiophile pour cette technologie sans suréchantillonnage (merci à David et Grégory pour leurs conseils), j'en suis à présent totalement séduit. Mon convertisseur PS audio stellar gain est battu, ne m'offrant pas cette aération simple et claire, cette respiration pas spécialement dynamique mais qui respecte la sonorité d'origine des enregistrements. Ce n'est pas redécouvrir ses CDs comme on le dit souvent, c'est découvrir la musique comme elle a été jouée et chantée. Le plus frappant est ce naturel acoustique des voix et instruments, dès les premières minutes d'écoute. Et ce n'est que du RCA et du coaxial (et de l'USB pour mon ordi qui a tout de suite reconnu le DAC). J'écoute peu au casque et essentiellement via mes enceintes colonnes, des CDs et du flac sur disque dur externe. J'ai branché les jumpers fournis (il faut des doigts fins ou une pince à épiler !) pour le "warmer sound" préconisé par Audio GD, résultat plus fluide me semble-t-il. Pour éviter de légers "plocs" possibles à l'allumage, je branche d'abord le dac puis l'ampli (Allo Volt +D ou Sabaj A20A première mouture), pour éteindre, faire l'inverse.
Avis aux amateurs qui peuvent se permettre cet achat, émotion musicale au rendez-vous garantie !
xavier R.
excellent DAC
C'est mon premier achat chez Audiophonic et je recommande fortement ce site.
Choix des produits aux meilleurs prix, conseils et compétences.
Après 1 mois et demi d'utilisation de ce DAC S.M.L.S D300, je suis très content de mon achat.
Ce DAC sonne plutôt analogique et à pris place au coeur de mon installation.
Il est relié en USB derrière un mini-Pc Daphile qui gère ma collection de musique dématérialisée jusqu'au DSD.
Le bluetooth accepte des flux jusqu'à 24/48, très pratique pour lancer un streaming depuis un téléphone à la volée.
Il est relié à ma TV en optique.
Et à mon vieux lecteur CD/SACD SONY en coaxial et remplace avantageusement le DAC d'origine de celui-ci.
Ce DAC est agréable sur tout les styles musicaux.
Il manquerait peut-être un peu de tenue dans l'Infra-grave.
Mais à ce prix, rien de rédhibitoire.
Bref très satisfaite de cet achat pour le prix.
Arnaud T.
Très bon DAC et rapport qualité/prix
Voulant autre chose que le son sortant du Jack mon écran PC (venant lui-même de l'HDMI de ma carte graphique) par qui effaçait les basses et aiguës, j'ai voulu prendre de suite du durable avec un bon rapport qualité/prix pour mon casque Fidelio X2HR et futur upgrade(s). (bientôt un Hifiman XS probablement)
Eh bien là le son est parfaitement neutre en sortie de prise Jack (confirmé par des tests de par exemple Audio Science Review), enfin des basses et aiguës appréciables !
Le tout sans avoir besoin d'installer un pilote sur Windows 10 (et 11), même s'il faut aller dans les paramètres Windows pour aller au-delà du 44,1-48000Hz en 16 bits.
Avec la télécommande on peut régler certaines choses notamment que les LEDs oranges s'éteignent au bout de 30 secondes sans toucher/changer de paramètres, rendant l'appareil encore plus sobre et adaptable au look de son bureau ou setup.
Jeanphilippe c.
Restauration
Self pour le médium. Très bon. Je recommande. Détail sonore important. Merci à audiophonic pour sa préparation soignée et sa livraison rapide.
Jeanphilippe c.
Restoration
Je recommande fortement cette self. Bocoup de détail inattendu. (Kenwood 5090)
Jeanphilippe c.
JANTZEN AUDIO CROSS COIL 000-7300 Bobine Cuivre Plat 14AWG 0.2mH Les bobines Jantzen Cross Coil représentent actuellement ce qui se fait de plus proche de l'inducteur parfait. Celles-ci ont été développées...
Restoration
Installé dans une paire d’enceinte (kenwood kl5090). Le détail est parfait. Je recommande.
Emmanuel R.
Mawels
Très belle construction, assez lourd, beau produit.
Alimente mon décodeur Orange + switch audiophile Silent Bonn 8
Alimentation silencieuse, ne chauffe pas.
Un petit palier de franchi sur la qualité : apporte un peu plus de relief et de stabilité à l'image (écran LCD 4K), plus de clarté et de détail dans le son.
Me permet d'alimenter deux produits en même temps.
Rien à dire pour le prix.
Incroyable
Connecteurs qui joue dans la cour des très grands et sans complexe.
Décidément, Viborg n’arrêtera pas de me surprendre.
J’ai connecté cette nouvelle gamme de prises à un câble Oyaide black Mamba, non référencé sur ce site, et quel dommage.
Avec 30 ans de montage et d’essais de différents câbles secteur, je pense avoir trouvé LE TOP.
Ces prises Viborg révèlent un équilibre tonale jamais entendu à ce jour. Elles mélangent à merveille, dynamique et finesse.
C’est le meilleur assemblage à ce jour et sans parler de gamme de prix.
Cet ensemble, dépasse et de loin, des câbles à plusieurs chiffres.
Bref, c’est ce faire plaisir avec un investissement largement justifié, et c’est tellement rare de nos jours, que j’ai voulu partager mon ressenti avec vous amis audiophiles.
Je ne change plus rien et vais en recommander avant rupture.
Csaba M.
Hungary
The point is, I think it was worth it. Its sound is almost creamy, it packs the instruments into the space better + I feel it is a little more detailed, more listenable (analog), more lovable in the long run. Of course, this is just my opinion. I made a loose video, unfortunately, due to the high compression, the difference doesn't come out as much as in reality, but once I've "worked" with it (rather played it), I'll share it. .., have fun with it: https://youtu. on/sZKlYxdNpoo
David L.
TOPPING PA3S Amplificateur Class D Symétrique 2x MA12070 2x65W 4 Ohm Noir Topping propose avec son PA3s un petit amplificateur Class D symétrique, simple, performant et abordable. Il se base sur deux puces d'amplification Infineon MA12070 et...
Vraiment pas mal, super compacts, puissants, silencieux et cleans, bref tout ce qu'il faut...
Ou presque, en effet je regrette qu’il n’aient pas été adaptés a ma config (actif pour mediums et aigus) mais ils ne pouvaient me servir en tant qu'amplis de puissance.
Une protection s'enclenche a chaque allumage si le volume est a fond. Pour le débloquer il faut baiser le volume et refaire un cycle d’allumage, trop genant, et pas envie de les laisser allumés 24/24.
David L.
Parfait pour un débutant
Premiere vraie station, ça change la vie !
David L.
Apres en avoir commandés plusieurs types ici c’est ceux que j’ai retenus. Tiennent bien en main au montage/demontage, un blocage suffisant une fois en place, et pas cher, impeccable.
Thierry J.
Câble de Modulation XLR Femelle - XLR Mâle Plaqué Or CANARE L-4E6S 1m Rouge Ce câble de modulation XLR mâle vers XLR femelle profite d'une belle qualité de conception, utilisant un câble Canare L-4E6S. Celui-ci intègre...
Parfait!
J'ai pu comparer ce câble aux réputés Sommer Galiléo 238 et Mogami 2549. Ils sont tous trois légèrement différents, et dans tous les cas recommandables. Ce Canare me semble un peu plus détaillé dans l'aigu, plus aéré, peut-être, que ses concurrents logiques. Le grave est tenu, l'image sonore forcément magnifique d'ampleur, bref, on le connecte et on l'oublie de suite, tant il semble naturel, dénué de défauts saillants, équilibré, silencieux, d'une certaine manière difficile à décrire. Sans doute pas la solution universelle, mais enfin, j'imagine que ce Canare en offrira suffisamment pour éviter de dépenser des fortunes dans l'achat (toujours risqué) de bidules plus idiophiles... mais pas supérieurs. A bon entendeur!
Bien optimisé il n a pas de concurant.
Je vous beaucouo de pouces en bas. De critiques trompeuse. Un des avis a le meme probleme rencontré sur mon streamer zen en suisse. Si non l alimentation fournie n est que basique. La programation est simple. Bouton arriere reglé sur all option. Alumer le logiciel ifi local et selectionné vos option. Sorter du mode et tourné a l aide du tourne vis la couche logiciel par ex dlna pour l utilisation avec bubbpnp. Il faut un cable usb de grande qualité type neotech argent ou le must un synergetics researche foundation. L alimentation ifi elite vas super bien ou autre ali de haute qualité. Un rj45 idem argent neotech ou sr. Et la vous avez un flagchip de tres haut vol. Comme tous outils de precision il merite le minimum pour s exprimé.
Matthieu O.
GENALEX GOLD LION KT77 Tubes Platinum (Quad Appairé) Ces tubes Genalex Gold Lion KT77 permettent une reproduction sonore fidèle. Chaque tube est doté d'un verre épais et de plaques robustes pour une grande...
COURTE durée de vie.
Si j'ai pu constater une légère amélioration de la définition des aigus par rapport aux EL34 de mon PrimaLuna Evo 300, ces tubes m'ont lâché régulièrement après quelques mois d'utilisation. Retour aux EL34...
Matthieu O.
Impeccable!
Le très vieux plancher de ma salle d'écoute est très inégal. Ces pointes permettent de niveler aisément des enceintes lourdes, et de les déplacer aisément si besoin. Mes enceintes étaient déjà sur pointes, mais le positionnement des contre-pointes, le nivellement étaient bien fastidieux en cas d'incident ménager... Livraison rapide, comme d'habitude, merci!
François G.
Le câble est tenu par 2 vis qui sont opposées à 180°, le maintien et le contact câble fiche est parfait, le corps en plastique se monte a la fin. Le contact avec la prise femelle est excellent.
Un très bon produit pour ce prix, je le recommande vivement.
Frank G.
LPSU200 Alimentation Linéaire Régulée HiFi 12V 13A 200W NAS / Freebox / Mac Mini L'équipe Audiophonics est fière de pouvoir vous proposer une alimentation linéaire régulée destinée à alimenter proprement les...
Fast delivery and the power supply works perfectly on my Roon Rock server. In terms of sound, this is a big step towards more analogue, more space, more depth graduation and the overall sound is more relaxed.
FURUTECH FP-TCS21 Câble Secteur Cuivre OFC (Alpha) Ø12.8mm Câble secteur très haute performance à 3 conducteurs dédié aux applications Audio sans compromis, le FP-TCS21 témoigne d’une...
rectification de mon commentaire précédent
Et bien il ne m'aura pas fallu 1 mois pour remettre en place l'Elecaudio , avec ce Furutech assez vite apparait une fatigue auditive : trop précis trop "chirurgical" au détriment de l'émotion. Je possède aussi un FURUTECH FP-S022N qui ne pose pas ce genre de problème , beaucoup plus équilibré.
Bon cable sans plus
Fait son boulot, mais les fiches sont un peu lâches sur mes appareils.
Aucune différences avec mes autres câbles optique qui ne sont pas en verre.
David M.
gold flakes falling off
horrible plating.
Reference rqp au top
Câblé entre un récepteur Bluetooth LDAC et un ampli . Transparence de très bon niveau , ambiance palpable , bon équilibre général , aucune frustration, un plaisir musical . Mérite des sources de qualité il vous le rendra .
1MII LAVAUDIO B03PRO+ Récepteur Émetteur Bluetooth 5.0 aptX HD LDAC CSR8675 DAC ES9018Q2C Le 1Mii B03Pro+, évolution du B03Pro, est comme son grand frère un récepteur et émetteur Bluetooth particulièrement polyvalent et performant,...
EXCELLENT
Câblé en sortie casque avec un câble mini jack vers rca Viablue sur ampli . Connecté en LDAC avec un smartphone . Son excellent avec beaucoup de détails , rivalise sans problème avec le cd voir le dépasse , mérite une connexion de qualité pour profiter de ce support . Recommandé chaudement .
Jean-Pierre T.
Question pour patrick
Bonjour Patrick
Merci pour vos avis et remarques si précieuses sur les connecteurs et les câbles Ramm Audio. J’en ai acheté quelques mètres pour fabriquer un premier câble secteur. J’avais quelques questions à vous poser et je n’ai pu vous contacter sur EBay comme vous le suggérez car vous n’avez plus d’article en vente. Accepteriez vous de me joindre par mail ou tél ? Je vous donne mon tél pour un premier contact par sms ? 07 86 07 87 21. Merci d’avance !
Et merci à Audiophonics qui nous permet aussi (en plus des conseils et de la qualité de l’organisation) de mettre en contact des passionnés.
Jean Pierre Testard Bordeaux
Vincent F.
tres bien, ras
Rien à dire sur ce tissu extensible fait le job demandé, pour ma part agrafer sur le cache
Vincent F.
Respire la qualité
Produit de bonne facture, respire la qualité mais ne peut me prononcer clairement sur le son car utilisé sur du vintage
Vincent F.
JANTZEN AUDIO Absorbant Textile Feutre pour Enceinte 100x100cm Cet absorbant textile est idéal pour réaliser l'isolation interne d'une enceinte. D'une épaisseur de 8mm, ses dimensions sont de 1x1m.
Conforme
Conforme à la description , utilisé pour tapisser mes vieux caissons d'enceintes 3A qui étaient nus
Ian F.
well worth getting
Installed a pair on my Magnat RV3, although not yet burnt in they have impressed me.
Andre L.
Very good quality and solidly built power supply
Packaging was very good (double boxed and good protection foam inside). The power supply is much bigger and heavier than I imagined, but that is good.
Solidly built, good solid connections and works perfectly with my NUC8.
Thomas Alexander H.
Good quality. However the inner cables do not fit in 275 paracord
Roland J.
Attention au diametre percage indiqué
Audiophonics indique un percage panneau de 8mm, c'est complétement faux il faut percer à 12 mm et faire des encoches pour pouvoir insérer les petits débords plastiques intégrés anti rotation.
Grrrr pas merci Audiophonics pour cette info erronnée, ça a été une vrai massacre pour aggrandir des trous déjà percés sur une plaque inox
François C.
TRIANGLE S01 Pieds d'Enceintes (La paire) Les pieds d'enceintes Triangle S01 ont été pensés pour vous permettre de positionner vos enceintes bibliothèques de manière optimale. Avec une...
stabilité et rapportQ/P
Extrêmement satisfait de mon achat à prix plus que contenu. Bonne qualité de fabrication (contre-point es un peu cheap), Esthétique discrète et bonne stabilité
Bouexiere c.
E70 velvet
Appareil reçu rapidement très bien protégé
Belle qualité de construction, multiples entrées, sortie symétrique et asymétriques.
En somme un bel objet toutefois je n’entend pas de différence avec mon petit DAC ampli casque, donc renvoyé.
Merci à l’équipe audiophonics pour leurs conseils et leur réactivité
Roland J.
KLEI CLASSIC HARMONY Embases RCA Cuivre Plaqué Argent (La paire) Les embases RCA KLEI Harmony Classic offrent une excellente qualité de conception pour des performances accrues, se reposant sur un savoir faire certain, fruit des...
Fiabilité de contact zéro
Très déçu par la qualité mécanique de ces embases, le contact du point se fait par une minuscule lamelle à l'intérieur de la fiche.
Cette lamelle étant trop aplatie contre le corps de la prise, le contact de la fiche se faisait très mal.
Conséquence une panne aléatoire sur l'ampli que je venais de terminer, des heures à chercher d'où venait le problème.
Je précise que je suis fan des fiches rca Klei sur tous mes cables rca mais là ces embases sont pas top.
Bien sûr embases soudées donc j'ai même pas pu demander le remboursement
Cris K.
NEOTECH NEET-1008 Câble Ethernet RJ45 Argent UP-OCC 1m Neotech propose avec son NEET-1008 un excellent câble Ethernet RJ45, profitant d'une conception d'exception. Celui-ci intègre en effet quatre paires de conducteurs...
Cris K.
Excelent cable. Silent and Detailed. A hidden treasure.
Plays better than cables worth 2-3 times its cost.
Corentin M.
Plutôt déçu, la qualité du câble est la, c'est du gros et costaud.
Mais certaines fonxtione intelligente ne passe pas, exemple, la nintendo switch la xbox one et ma box free, ne sont pas reconnue lorsqu'elles sont connectées avec ce câble à ma télé samsung.
Pourtant un pauvre câble no name hdmi 2.0 fonctionne sur ce point.
Du coup je m'interroge sur la fonctionnalité de toute la norme 2.1.
Je ne rachèterai pas ce câble, première déception chez audiophonics.
Donovan E.
NJR MUSES01 AOP Double DIP8 (Unité) L'AOP à double entrée J-FET NJR MUSES01 offre une excellente qualité sonore, marquée par une grande précision et pureté, mais...
Incroyable
Comme vu dans d'autres commentaires, ils sont effectivement très proche des 8920 mais avec une meilleure définition de l'audio. Les basses sont plus rondes, dans un casque on à l'impression que ça résonne comme dans une pièce, les instruments et les voix sont un petit peu plus en avant également, sûrement une conséquence des aigus qui sont désormais proprement séparés et qui ne noient plus le milieu du spectre audio. Avoir accès à autant de détails demande un réglage de l'égaliseur extrêmement minutieux, vous pourrez facilement discerner les erreurs de mastering récurrentes chez les petits artistes d'electro, celles-ci seront d'ailleurs difficilement rattrapable. Ce sont sur les grandes productions que l'on en profitera le plus. Ce matériel me donne l'impression d'avoir atteint la limite de mon DT990 (j'ai encore du mal à maitriser les aigus, j'aime un son ouvert mais ils sont trop brillants à mon goût), je vais probablement acheter un meilleur casque bientôt. Ces OPA étaient encore très chers récemment, mais à ce prix j'ai tenté le coup et je ne suis pas déçu. Fixé dans une Xonar Essence STX II qui commence à avoir quelques années, ce matériel fait un boulot formidable.
Michel l.
EVERSOLO DAC-Z8 DAC ES9038Pro XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA Le DAC-Z8 de EverSolo est un DAC high-end extrêmement performant. Il embarque des composants haut de gamme avec notamment une puce de conversion numérique /...
exceptionnel
après avoir demander conseil a mr david hubert entre gustard x18 et le model eversolo z8 je n'ai pas hésité une seconde j'avoue qui'l est très beau bien construit j'ai télécharger la derriere mise a jours pour le vumètre vintage l'effet et superbe un beau BB j'ai pris également AUDIRVANA un Régal un son d'une qualité irréprochable très aéré pour moi il est parfait d'une richesse en detail incroyable pour le tarif franchement allez y encore merci a vous
Per F.
AUDIOPHONICS Câble d'Alimentation Jack DC 5.5/2.5mm vers GX16 Cuivre OFC pour Alimentations Audiophonics LPSU100 1m Ce câble d'alimentation Audiophonics, assemblé en France dans nos ateliers, se compose d'une part d'un connecteur Jack DC 5.5/2.5mm et d'autre part d'un connecteur...
NUC Intel cable 2.5 mm.
Great Value for the money.
The new Power cable take you a step up at the sound ladder.
Thanks Audiophonics again :-)
Per F.
The new cable take you a step up at the sound ladder.
frederic D.
avis
cable modulation d'excellent rapport qualité/prix, sonorité neutre naturelle et non agressive niveau de définition interressant, coté timbres: je dirais chaleureux.
Olivier F.
DAYTON AUDIO PC83-4 Haut-Parleur Large Bande 30W 4Ω 86.8dB 80Hz-20kHz Ø7.6cm Le haut-parleur large bande Dayton Audio PC83-4 est doté d'une membrane composite en fibre de verre tissée, une suspension en caoutchouc ainsi que d'un puissant...
Utilisation Arcade-Jeux ok
Monté aisément dans caisson d'origine d'une borne Sega New Astro.
C'est mieux que les anciens HP, surtout dans medium/aigüe, mais pas énorme sur les basses.
Personnellement, je préfère les Visaton FRS 8 test sur Astro, mais pas compatible New Astro.
