Marc A.
Un bon cable...
David m.
une super prise hifi
Jochen M.
Tout n'est pas parfait
Avis clients - Il y a 19553 avis.
Nikolaus S.
Good Quality, but not for more than Ø15mm cable
Only an artist will be able to fix a Ø18mm cable into this connector. The sound ist typical for rhodium coating, smooth an very detailed.
Mikulas K.
ATAUDIO RIBBON Flat Speaker Cable Silver Plated OCC Copper 2x1.5mm²
WOW !!! Best cables I had so far. Terminated with M AUDIO BS-210G Banana Plugs they are by me very good solution for Hypex Ncore amp and my System Audio speakers. Simply awesome.
Unbelieveble what you get for few euros.
Dominique P.
Excellente qualité perçue et superbe finition.
On peut trouver moins cher mais le prix de cet article me semble justifié.
Achat recommandé
Christian S.
jack reçu pas en rapport a l'image
Bonsoir,
Très surpris et déçu par ce jack mono. Extrêmement difficile de mettre la soudure sur le conducteur de plus il ne correspond pas à ce qu'il y a sur l'image, donc à ma commande.
J'étais pressé et je me suis arrangé avec l'un deux, je garde les trois autres en attendant votre explication.
Je peux vous faire une photo de celui reçu.
Cordialement.
Gordon M.
AES / EBU HAT RPI
I paired this with a Pi4b streamer running Moode in a Argon M2 case with a Funk AES cable connected to a Gustard X18. Listening between USB2 and USB3 BT LDAC with very good cables the AES was a quantum leap. Sound stage a meter wider, bass clean and forceful, mids just sweet, highs crystal clear, high hats some I hadn't heard on tracks I'd listen to 100 times before.No hint of digital sound or tinny sounding, an absolute upgrade and at an excellent price. For the M2 case and HAT I needed 2 PSUs but it was all set up on Moode in a few minutes.Top product, thanks Audiophonics for the great service as well.
Leonas J.
6np3
hello,it is made in ussr tubes/ or any better maker? how it compare vs stock russian tube on my china amp 6np3 valued at 2eur only?
Laurent D.
Le cablosceptique
Toujours très méfiants sur les commentaires dithyrambiques de certains "cablophiles" je me suis laissé surprendre par la nette amélioration avec ces petits câbles de liaisons par rapport aux originaux de mon bras SME. Je recommande vivement ces câbles même si sur une Ortofon OM10 il faut un peu forcer pour les enficher. Comme toujours Audiophonics fait les bons choix: bravo
Raymond M.
Peux mieux faire
Je serais moins dithyrambique que les autres commentaires… J’ai pris cet appareil dans le but de bien positionner la phase dans mon meccano hifi, mais je n’ai que le message ‘terre manquante’, ce qui est visible sur les prises et logique, vu que mon installation électrique, bien que rénovée entièrement, date des années 80 et que la terre n’est présente que dans la cuisine, les salles de bain et le sous-sol (normes de l’époque), lieux où je ne vais pas installer mon home hi-fi. Quant au dernier diagnostic ‘inversion phase et terre & terre manquante’ il me laisse perplexe… J’aurais préféré ‘inversion phase et neutre & terre manquante’, mais bon vu le prix, je vais garder ce gadget au cas où, bien que dans l’immédiat il ne me serve… à pas grand-chose.
Axel H.
Très facile à mettre en œuvre, bonne qualité des composants.
Je recommande!
Ludovic L.
IFI AUDIO ZEN ONE SIGNATURE DAC Burr Brown XMOS Bluetooth 5.0 32bit 384kHz DSD256 MQA Le iFi Audio Zen One Signature utilise l'étage DAC du Zen DAC V2, tout en y ajoutant des entrées SPDIF (optique et coaxial) en complément du port USB, ainsi...
Parfait pour mes oreilles
Ce Dac associé avec le Zen stream me comble de bonheur. Il produit un son vraiment raffiné, loin du son analytique que j’ai pu avoir avec d’autres appareils. Il a certes une très mauvaise presse au niveau des mesures mais franchement c’est à se demander si il faut uniquement acheter en se référent uniquement aux mesures….je ne comprends pas pourquoi cette marque est d’une part dénigrée sur certains site technique et encensée par certains audiophiles.
Ludovic L.
Celà fait quelques années que j’utilise l’environnement Bluesound et j’en suis ravie avec un Node 2i et des amplificateurs NAD. Mais avec l’acquisition d’une paire d’enceinte BC Acoustique Nil, je me disais qu’il manquait un petit quelque chose et après quelques recherches j’ai choisi ce streamer. Et une fois branché sur Ifi Zen One signature, la musique prend une nouvelle dimension, plus large, plus de relief et une sonorité très analogique. Un vrai coup de cœur.
Philippe V.
Incroyable !
J'étais sur le point de me débarrasser de mes enceintes Alon 1 acquises récemment. Alimentées par un Luxman L507ux II via des câbles Qed genesis spirale, les aiguës à la limite de l'audible, les basses légèrement envahissantes et les timbres décevants.
En désespoir de cause et après être tombé par hasard sur un forum relatant les bienfaits des câbles Mogami, je me suis décidé (après avoir lu également le retour d'expérience de la soixantaine de clients satisfaits) d'acheter 6 mètres de câbles et des fiches bananes Viborg.
J'ai reçu mes achats en moins de 48h (merci Audiophonics).
Le lendemain, tout était monté (câbles et pontages de borniers réalisés avec le même câble).
Dès la première écoute, j'ai compris que le miracle s'était produit. Tout était équilibré et naturel. J'avais à la fois envie d'écouter les morceaux jusqu'au bout mais également d'en re-découvrir d'autres. Comme pour bien d'autres, ces câbles resteront installés de manière définitive.
yves r.
AIYIMA A05 Amplificateur Class D TPA3221 Bluetooth 5.0 aptX HD 2x85W 4 Ohm Aiyima propose avec son A05 un petit amplificateur Class D, simple et efficace à petit prix, idéal pour le montage d'un petit système audio. Il embarque un...
marche très bien,pas longtemps...
très bon appareil connecté à des focal 19ti, super dynamique,^récis etc...
mais en rade au bout de 3 mois ??!!!!
C'est parfaitement anormal, contactez mes collaborateurs du SAV qui vont prendre en charge le problème.
Grégoire N.
Trés bon appareil
Le montage ne présente pas de difficultés particulières ; il faut juste veiller à bien brancher les nappes - une erreur de ma part à ce niveau m'a valu de devoir faire appel au SAV d'Audiophonics qui s'est montré efficace et sympathique.
RAS coté son : ça marche très bien. Petit bémol toutefois sur les pleines performances (DSD256 et PCM 32-bit 768kHz) exploitables uniquement via le port USB-B : c'est un peu dommage puisque l'intérêt majeur de cet appareil et de combiner DAC et lecteur réseau (lequel ne peut exploiter le DAC qu'à hauteur des formats DSD128 et PCM 384kHz).
L'ergonomie à l'utilisation est très bonne (même si l'intégration linux reste perfectible sur quelques détails comme l'arrêt du système).
En conclusion, ce DAC est donc un appareil tout à fait satisfaisant auquel j'attribue volontiers cinq étoiles.
Kostas K.
Amazing
After reading the comments here and seeing its excellent construction, I decided to give this cable a try.
After about 200 hours of burn-in the first cable was fitted to the DAC Rockna Wavelight and it was a revelation.
Then I built a total of 6 cables for myself and friends the way Patrick L. ("Rsimple") describes above.
It needs ATTENTION in the construction in order to remove the PE Jacket from the thin copper conductors.
Highly recommended.
Excellent produit !
Remplace avantageusement beaucoup d'AOP, ils sont pour moi supérieurs aux Staccato. Mieux que ces AOP, il n'y a plus que le Sparkos SS2590, mais attention à l'adaptation, qui n'est pas toujours aisée.
Excellent produit !
Remplace avantageusement les NE5532 qui sont trop souvent installés dans des appareils dit Hi-Fi.
Très pratique, et de bonne qualité, rien à redire !
Thibaut M.
Belle connexion
Très bon produit, bien construit et efficace dans sa mise en œuvre et dans son utilisation. Excellent rapport qualité prix.
Christian M.
TOPPING D10 BALANCED DAC USB Symétrique ES9038Q2M XMOS XU208 32bit 384kHz DSD256 Noir Topping propose avec son D10 Balanced un DAC symétrique compact et surtout extrêmement performant. Celui intègre des composants de grande qualité pour...
le meilleur rapport qualité/prix
Exceptionnel rapport qualité/prix ....si en plus vous l'associez à un petit reclocker USB du style Idéon Renaissance Black Star.....les performances deviennent stratosphériques, et le combo rivalise avec des Dacs valant 15 fois leur prix !
surprenante !!!
Bonsoir , j ai testé cette schuko sur ma platine cd ,belle transparence ,rapidité ,neutralité !!! niveau d une bals73 !! le top pour le prix
belle neutralité et vigeur!
Bonsoir , j ai remplacé ma fi38 or par la rhodium sur ma murale oyaide , la rhodium est plus transparente ,neutre ,rapide,precise, et l or un peu plus chaleureuse ,ronde . Pour un systeme sombre ou lourd optez pour la rhodium ,pour un systeme deja clair ou maigre optez pour l or , La fi38 rhodium est la meilleure schuko que j ai testé a ce jour !
Michael S.
Recommended!
For the money this is an excellent product. Simple to install and recogized by windows on reboot.For best results I would recommend complementing the card with an external linear 5V power supply. The Allo - 5V Power Supply for similar money works fine.
jean-pierre c.
bon rapport qualite prix
balance precise , testée avec une pièce de 1 centime d'euro elle affiche bien les 2,30 grammes.
La notice qui l'accompagne est tres insuffisante ! en anglais uniquement (et chinois) on comprends pas grand chose.
Le sens dans lequel il faut mettre les deux piles LR 43 n'est meme pas indiqué !! quand on sait que certains composants electroniques peuvent etre endommagés avec une inversion de polarité c'est un peu embetant !
Pour ma cellule (godring 1042) qui a une tres faible garde entre le cantilever et le corps de la cellule , celui ci touche la plaque de la balance avant le diamant ce qui peut fausser la mesure.
Le creux central de la balance ne fait qu'agraver le problème.
SMSL VMV A1 Amplificateur class A MOSFET PGA2311 2x15W 4 Ohm Le SMSL A1 se présente comme un amplificateur Class A compact mais néanmoins très performant, offrant une excellente restitution sonore, à la fois ronde, musicale et précise.
Très intéressant.
Tant sur le plan musical, esthétique et encombrement !
Le laisser chauffer et une fois atteint une trentaine de C° (sympa ce thermomètre embarqué), ça fait vraiment de la belle musique.
Là où beaucoup d'ampli à transistors pêchent par leurs qualités de leurs aigus (je suis un habitué des bons montages à tubes depuis un moment déjà), cet A1 s'en sort plutôt très bien.
Son seul vrai défaut (annoncé toutefois) est sa relative incapacité à remuer des HP aux masses mobiles moyennement lourdes.
Des biblio en membranes papier et équipage mobiles légers (il en existe à 3.000€ bien entendu) et vous aurez très certainement un compromis musical de haute volée. Autrement dit, pas besoin d'investir de grosses sommes en amplification pour des biblio mêmes très qualitatives (ici, des Pascal Louvet EloquenSe si Audiophonics m'autorise un petit coup de promo ;+)
Jerome A.
HIFIMAN EDITION XS Casque Planar Magnetic 92dB 18 Ohm 8Hz-50kHz HiFiMan propose avec son casque Edition XS un excellent modèle Planar Magnetic, utilisant les technologies propriétaires Stealth Magnets et NEO Supernano Diaphgram...
Impressionnant
Associé à un bon ampli, le son produit par ce casque est remarquable ! Hifiman à réussi un exploit, pour rivaliser, à ce jour, il va falloir mettre 2 fois son prix, rapport-qualité-prix tout bonnement incroyable.
Seul petit défaut, il est un lourd, on ressent le besoin de le poser 5 minutes de temps en temps (après quelques heures tout de même). Attention, dans le monde des casques magnétique planaire, il n'est pas le plus lourd, loins de là, mais certaines marques produisent des arceaux plus confortables, mais c'est beaucoup plus cher.
Dražen S.
TOPPING E30 II DAC 2x AK4493S XMOS XU208 32bit 768kHz DSD512 Noir Topping revient avec le DAC compact E30 II, véritable évolution de l'excellent E30, présentant de nombreuses améliorations techniques permettant...
Excelent product
DAC is compact and very well built.
In terms of audio performance, nothing to complain about.
If you need a DAC with single-ended output, look no further.
All recommendations!
Olivier C.
AIYIMA A08 PRO Amplificateur Class D TPA3255 2x220W 4 Ohm Bluetooth 5.0 Aptx-HD LDAC Le Aiyima A08 PRO est un petit amplificateur Class D, très puissant, performant et abordable. Il se base sur une puce d'amplification TPA3255 et un AOP NE5532P, lui...
Bluffant
Commandé pour installer dans un bureau avec des qacoustics 3020i, je suis ravi.
Le son est détaillé, transparent, on peut ajuster la tonalité.
Je l'ai essayé sur mes colonnes dali opticon 5, quelle claque !!! Ça envoie, déjà à la moitié du volume c'est fort !! Mon ampli anthem mrx 300 fait pale figure à côté.
Après, il manquera un peu de profondeur de scène sonore pour ceux qui aiment les bulles.
Mais ça remue bien comme petit ampli et il a un petit look sympa.
Christian M.
Alimentation faible bruit
Très bonne performance de cette alimentation utilisée dans un domaine de réception radio où son faible bruit de fond est remarquable.
La finition est top et son rapport qualité/prix excellent.
la neutralité !!!!!!!!!!!!!
Bonsoir ,j ai comparé avec la version gold , la rhodium est plus transparent,neutre, rapide, precis, detaillé, juste un peu moins chaud et moins rond , qualté prix une des meilleurs schuko du marché!! Franck
qualité prix magique
Bonsoir ,schuko mennekes sur ma platine cd avec du belden et iec c15 ncf , tres rapide,clair , neutre , bonne finition , pour des systeme un peu lent sombre ,elle est parfaite !! franck
Philippe V.
TOPPING EX5 Amplificateur Casque DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Argent Topping propose avec son EX5 un combo DAC et amplificateur casque extrêmement performant. Son étage de conversion se base en effet sur deux puces DAC ES908Q2M et...
Du bon et du mauvais
Avantage par rapport au Topping DX3pro+ son alimentation secteur intégrée au boitier, le deuxième dac ES9038
Désavantage en tout premier je trouve vraiment inintéressant le décodage MQA qui augmente nettement le coût de l'appareil et n'apporte rien pour la grande majorité des utilisateurs. Un petit regret encore, sur la puissance de sortie inférieure au DX3 pro+
Sinon quel plaisir de commander chez audiophonics à prix compétitif.
Envoi très rapide et bien emballé
Jean Marie F.
Superbe sonorité
Excellent modules.
Sonorité douce et détaillée.
Ne chauffe pas avec des dissipateurs adaptées.
Comme signalé sur les autres commentaires mérite les meilleurs preamplis.
Bien vérifier les soudures des composants j'ai eu un condo avec une pâte non soudée.
Sinon pour le prix c'est une véritable aubaine de quoi mettre une raclée à pas mal d'ampli dits " audiophile " à des tarifs stratosphérique..
Jean Marie F.
Très bon module.
J'en utilise deux dans une réalisation d'ampli.
Jean Marie F.
Module Protection stéréo pour haut parleurs large borniers Voici un module de protection Stéreo pour Haut Parleurs. Avec ces relais rapides de marque Omron à faible résistance de contact, ce module protégera...
Fait parfaitement le job pour un prix dérisoire.
Jean Marie F.
Commandé deux transfos pour monter un ampli double mono.
Les deux transfo ronronnent comme un gros matou.
J'ai tout essayé rien à y faire.
J'avais déjà eu le même problème sur un autre modèle défaut de conception.
Un des deux avait déjà servi ... fils raccourcis et traces de soudures.
Plutôt moyen !
Gilles J.
Bonne dimension et bon rapport qualité /prix. Prix attractif.
Ricardo G.
XDUOO XA-10 Amplificateur Casque DAC Symétrique 2x AK4493 Bluetooth 5.0 32bit 768kHz DSD512 Le xDuoo XA-10 est un combo amplificateur casque et DAC symétrique de bureau. Profitant d'une belle conception, il délivre de très bonnes performances audio...
Great product
Great sounding and fully featured product, at a very reasonable price.
Congrats also to Audiophonics for the easy ordering process and quick delivery; I will definitely consider purchasing again from them in the future.
alessandro i.
LAO Condensateur Électrolytique Hautes Performances 63V 10000µF Ce condensateur électrolytique  offre de  hautes performances,  spécialement conçus pour une utilisation audio HiFi. Ce modèle offre...
condensatori elna
sito affidabile serio consegna puntuale in italia 3 giorni con dpd grazie,!!!!!!!
Le top
En préambule je précise qu'un cable qui modifie le son ca n'existe pas.
Ce cable en argent pur qui est le meilleur conducteur, laisse tout passer et c'est ainsi que je découvre des détails, une aération, et une finesse que je n'avais pas avec un cable ordinaire.
J'aurais du y penser plus tot, car j'avais déjà été séduit par les cables de modulation en argent pur.
Alors si vous voulez que tous le 1 et 0 arrivent à destination sans déperdition, je vous recommande fortement ce cable.
OLIVIER G.
TOPPING G5 Amplificateur Casque NFCA DAC ES9068AS Portable Bluetooth aptX HD LDAC Argent Topping présente avec le G5 un amplificateur casque et DAC portable à la fois compact et performant. Celui-ci intègre notamment un puissant étage...
Une bonne alternative portable
Possesseur d'une pile SMSL SU9/SH9 très précise, j'ai également une pile Topping E50/L30 que j'apprécie car plus chaleureuse.
J'écoute sur plusieurs casques mais actuellement sur un Clear MG.
En solution mobile, je n'avais qu'un Fiio btr5, pas mal surtout pour la taille :-) , mais manque de corps et de pas mal de choses en fait.
Je voulais trouver une alternative plus proche du son Topping que j'aime et le G5 a la même puce DAC.
Je retrouve une sonorité proche mais avec une scène sonore un peu moins large et des basses un peu moins percutantes.
Cela dit, pas déçu pour l'utilisation prévue, c'est à dire en mobilité et en vacances. Mais il ne remplacera pas les piles de bureau, normal.
Bruno G.
Cable de qualité
Bonne qualité et souplesse idéale. Le son est bien détaillé.
Bruno G.
Faciles à installer avec du Canare L-4E6S. Bonne tenue de la prise sur le réceptacle.
Aristotel Eduard G.
Nice one
Used them on my Dali zensor 7 crossover. definetly an audible improvement !
Aristotel Eduard G.
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 6.8µF La gamme Superior Z-Cap de chez Jantzen Audio se compose de condensateurs non polarisés haut de gamme, conçus spécialement pour l'audio afin de permettra...
Piotr G.
SMSL A300 Amplificateur Class D Infineon MA5332MS USB Bluetooth 5.0 Subwoofer 2x160W 4 Ohm SMSL propose avec le A300 un amplificateur Class D compact mais pour autant puissant et performant, basé sur une puce d'amplification Infineon MA5332MS. Celle-ci lui...
Simple et efficace. Très content de mon achat
J'ai remplacé mon ancien ampli-tuner Yamaha par ce SMSL + une source audio Triangle AIO C (que je recommande aussi). Excellent son, mes anciennes enceintes hifi ont démarré une nouvelle vie ! Il me manquait une entrée optique, mais je le savais. J'ai complété mon installation avec un commutateur / DAC pour brancher un DVD / TV en optique et coaxial.
Christian S.
Génial !
Ce petit machin est tout simplement génial !
Je profite pour vous remercier tout est parfait ! Envoi rapide et bien emballé .
La communication est excellente, merci
Christian
Excellent Amplificateur
Reçu en deux jours et super bien emballé. Merci Audiophonics.
Concernant l'ampli, il tourne depuis quelques heures et le son est déjà excellent. (Câblé en XLR)
Très beau boitier sobre comme j'aime.
Pas besoin de fioritures pour un ampli de puissance, car le son prime.
Je conseille vivement cet appareil.
CHRISTOPHE B.
Pas de notice en français
Helas,pas de notice en français alors que le produit est vendu de France
Eric T.
FX-AUDIO D-AMP-50W Module Amplificateur Class D TPA3116 & 2xAOP NE5532 2x50W 4Ω Ce module amplificateur Class D intégrant à la fois une puce d'amplification TPA3116 et deux AOP NE5532 assure une puissance en sortie de 2x50W sous 4Ω. Celui-ci...
Très bon ampli
J'ai fait un petit home cinéma avec. Très content
