Ramiro F.
Ramiro F.
Marcus L.
Avis clients - Il y a 20142 avis.
ELECAUDIO VIPERA GN Gaine Tressée Extensible Nylon (PET) 09-13mm Voici la gaine tressée VIPERA GN d'ELECAUDIO, élaborée en PET (Polyéthylène Terephtalate) monobrins et pouvant être utilisée dans...
superbe gaine
cette gaine est d' une qualité remarquable . Elle ne s'effiloche que tres peu, solide, confortable et facile a travailler 20/20.
En plus elle est trezs jolie.
Szilard S.
MINIDSP FLEX HT Processeur Audio DSP 2x8 Canaux SHARC ADSP21489 XMOS HDMI ARC eARC Le miniDSP Flex HT est un processeur de la gamme des processeurs audio avancés miniDSP Flex. Cet appareil est un processeur DSP multicanal de 2x8...
Flex HT the audiophile nirvana!
I bought it on December 18, 2024. It arrived in Hungary very quickly. I replaced a Lexicon MV-5 processor. The bass is much more restrained, not so fluid and expansive. The active switching also works very well in it, I use LW-R 24db/octave filters. The crossover frequencies are 100Hz/4KHz. I don't use Parametric EQ for now, maybe when I buy the Umik-1 measurement microphone. It would be nice to buy a Dirac live license for it, but for now it's very expensive for me, almost the price of the device. There are power stages for each speaker, for each speaker, I use these now, all class D: AUDIOPHONICS MPA-S125NC ; Douk Audio TPA3116 ; Wondom TPA3255. I'm going to order these two power amps from Audiophonics now: O-NOORUS D1 Class D Amplifier TPA3255 PFFB. My dream is to get one of these power amps: AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels NCore NC252MP. This MiniDSP Flex is a real big gun, a game changer, the DAC in it is also very good, this is also confirmed very well by the Audio Science Review. I recommend it to everyone who would like to build a truly audiophile system with active switching. I use 2x3 way speakers with it, each in pairs: Dayton Audio PT2C-8 Planar Tweeter ; Tang Band_W5-2143 Midrange; SICA 12 PF 3 Sub. The fronts are open baffle, and the subs are closed! Thank you Audiophonics!
Ville E.
BURSON AUDIO V7 CLASSIC PRO AOP Double (La paire) Évolution du V6 Classic, le V7 Classic Pro atteint désormais un niveau de bruit ultra-faible tout en conservant les aigus étincellants qui font la force de...
Relax your class D amp
Bigger soundstage, more natural timbre. Singer a bit closer. These are all properties that this opamp provides. Tradeoff is a little less attack in the mids. The performance from the bands turns from metronome-oriented highschool band to seasoned veterans playing together for fun. Relaxed, engaging, fun. Provides some smokiness to live jazz trios, this thick air that exists in jazz cafes.
Anastasios D.
ATAUDIO L-4E6S Câble USB-A Mâle vers USB-B Mâle Cuivre OFC Plaqué Or 0.75m Ce câble USB ATAUDIO offre à la fois une très belle qualité de conception et un design luxueux. Il se compose en effet d'une structure à quatre...
Nice quality cable!
Nice quality cable!
Anastasios D.
Nice quality cable!
Nice quality cable!
Anastasios D.
Adaptateur Secteur Alimentation 100-240V AC vers 48V 7A DC Cet adaptateur secteur prend en entrée une tension de 100-240VAC pour sortir du 48VDC 7.3A (350W). Les composants sont intégrés dans un châssis en...
Quality build!
Nice quality build PSU with good connectors. Packed nicely and shipped fast!
Anastasios D.
AIYIMA A07 Amplificateur Class D TPA3255 2x225W 4 Ohm Le Aiyima A07 est un petit amplificateur Class D, simple, puissant, efficace à prix abordable, idéal pour le montage d'un système audio nécessitant...
Surpisingly good!!
I was looking to buy something cheap to replace my meridian 556 amp until it's fixed. I have the B&W 685 speakers (first edition) and this amp sounds so clear and detailed. I think it lucks some power compared to the meridian even with the "Switched Mode Power Supply 100-240V AC to 48V 7A DC". It is loud but I think it cannot drive the speakers with power compared to a transistor amp. But it is loud and clear, so I give it 5 stars for the money!
The service and experience from audiophonics is one of the best I had, very fast shipping and very good packaging! Thank you!!
Jean-Pascal H.
DYNAVOX X7000 Filtre Secteur 6 Prises Schuko Noir Le Dynavox X7000, évolution directe du X6000, est un filtre secteur HiFi permettant de fournir à vos appareils audio une alimentation propre et stable, favorisant...
Filtre secteur
Mes appareils sont enfin protégés le wattmètre est très pratique pour connaitre la consommation réel de chaque appareil , merci top
Jean-Pascal H.
Cable Secteur
Câble d'alimentation très bien réalisé à un prix qui me convient merci Audiophonics
Anastasios D.
SHANLING ET3 Lecteur CD Philips SAA7824 Sanyo HD850 WiFi DLNA AirPlay Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Noir Le Shanling ET3 se présente comme un lecteur CD complet et puissant, proposant un design moderne et offrant d'excellentes performances sonores. Polyvalent, il met...
Nice sound!
Very good device. I am connecting it through Coax, Toshlink and USB to my old AudioGD DAC19MK3 and it sounds beautiful. Unfortunately I cannot test the I2S yet, but I might modify my DAC to accept it. The service and experience from audiophonics is one of the best I had, very fast shipping and very good packaging! Thank you!!
David T.
Après neuf mois d écoute, aucun changement. Amplificateur de premier choix
Kentaro T.
IAN CANADA HDMIpi MKII Émetteur I2S / DSD / DoP vers HDMI Ce module vous permet de récupérer le flux audio numérique sortant du port GPIO d'un Raspberry Pi (ou de l'un de ses HATs) et de l'envoyer au format LVDS...
Great Product
I am using HDMIpiMkII (RaspberryPi5 GentooPlayer) and Musician Draco with i2s transmission. I have used Topping and RME products in the $200 to $1,000 range, but the sound quality is completely different from those. It is very smooth and has high resolution, and I want to listen to it forever. It took a little effort to get the sound to come out, so I will summarize the settings.
(1) HDMIpiMkII: Jumper Switch S1 settings
DIP1: ON DIP2: ON DIP3: ON DIP4: OFF (master clock is not output)
The initial state is all OFF, and i2s signals are not output from the HDMI terminal, so you must set it.
(2) Musician Draco: Set i2s mode to Mode5
The lamps [1X] and [4X] at the bottom right of the front panel should be lit. The mode setting method is described in the user's manual (i2s PIN configuration of DRACO).
(3) Connecting HDMIpiMkII to Musician Draco
I use ECDH-HD14SS03BK (made by ELECOM).
équilibre parfait
Salut ,comme j ai changé d enceintes et platine vinyle , je trouve le cable ludic d un realisme incroyable! Le couteau suisse des cables HP pour moi ,franchement pour faire mieux faudra mettre tres cher! recommander vivement
la reine de la rapidité ,finesse!!!
Bonsoir , j ai testé ma schuko 004 sur mon ampli nuprime , vondita oyaide ,iec 004 , a la place d une FI38r ,resultat plus de vitesse,precision, transparence ,finesse, super aigu! petit bémol elle degraisse un peu . Franck
Paul M.
SMSL D-6S DAC ES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA SMSL présente avec son D-6S un DAC compact et performant. Ce petit DAC D-6S intègre une puce DAC ESS ES9039Q2M ainsi que quatre doubles AOP OPA1612, une...
Compact, XLR out and balanced sound: all I need!
I use this DAC for conversion duties between my TV and active speakers. Happy to say that it ticks all the boxes for me. XLR out, solid build, foolproof and logical operation and most importantly: a detailed and balanced sound. It does not outperform the dac in my audio set (and it shouldn't at just 10% (!) of the price of the audio dac), but it would make me rethink the audio dac should I have to purchase that now. Recommended!
joel p.
TONEWINNER TY-1CD Lecteur CD DAC ES9028 Le lecteur CD Tonewinner TY-1CD profite d'une belle esthétique et de composants de qualité pour des performances de lecture CD supérieures. Il dispose d'une...
lecteur cd tonewinner ty-1cd, surpris !
colis reçu rapidement et bien emballé, merci d'avoir respecté ma recommandation sur ce point particulier.
Je suis agréablement surpris par la qualité de fabrication et la finition de ce lecteur.
A l'écoute, je redécoudre mes cd du point de vue de la musicalité, très analytique, procure un espace sonore en 3d encore amélioré par rapport à mon ancien lecteur british.
Avec des cd de bonne facture (qualité audiophile) j'apprécie tout son potentiel et qui pourra que s'améliorer après une période de rodage.
Bref, pour l'instant je suis très satisfait de cet achat ! très très bon rapport qualité prix !
Josep s.
XDUOO XD05 PRO Amplificateur Casque DAC Portable ES9039SPRO XMOS XU316 32bit 768kHz DSD512 MQA 8x Avec le XD05 Pro, xDuoo dévoile un amplificateur casque et DAC portable très performant, robuste et polyvalent. Il intègre des composants de grande...
XDUOO XD05 PRO
Envio rapido,muy bien empaquetado,web seria y muy de fiar.
El amplificador/dac,excelente en construccion,prestaciones,conectividad y gran calidad de sonido,es una maravilla en relacion calidad/precio!
Alain S.
DAC TOPPING DX3 PRO+
excellent DAC, correspond a mes attentes, HI RES enfin disponible sur mon installation HI-FI.
Son de très bonne qualité.
Uwe G.
Topp Kabel
Ein Kabel ohne Kompromisse.
Konfektioniert mit Kupfer vergoldeten Steckern ein Muss.
Alexandre L.
Cable de très haute volée
Acheté en remplacement du câble de ma multiprise Furutech TP60E (Audiophonics Stealth excellent cable pour 100E).
La clarté apportée est incroyable j'ai l'impression d'avoir un nouveau DAC ! Neutralité conservé avec plus d'extension des aigues, très cohérente et aucunement agressive ni incisive.
Pas d'extension dans les basses mais plus de précision et de slam. Pour le médium il était déjà incroyable dû au rhodium des prises mais il vient le rationaliser et pousser encore la barre pour atteindre une justesse jamais entendu !
Monté avec IEC Oyaide C004 et Schuko Furutech FI-E38(R).
Au passage le câble est balèze mais est suffisamment flexible pour une installation correcte. J'en rachèterai sans hésitation pour un cable d'ampli dans le futur !
David S.
AUDIOPHONICS DIGIRESCUE Reclocker SPDIF Optique Coaxial Isolation Galvanique 24bit 192kHz Ce reclocker Audiophonics DIGIRescue a été conçu en association avec Ian Canada. Il permet, grâce à une horloge locale de haute...
What an awesome surprise. This is just great.
I was completely caught off guard by this. I bought it more out of curiosity than anything else, quite certain of a return. Well, the Digirescue is not going anywhere. With a 5v IfI IPower 2 power supply, the sound of out of the reclocked coax tap was much improved compared to the sound obtained from my Elac ds s101g previously. But after connecting the Digirescue to my Keces P3 lps upgraded with a SR Orange fuse, the sound coming out of of my Rotel 1592 mk ii just exploded…it is way above anything I could expect. For me the lps is a must do upgrade. The imaging, the depth and width of the soundstage, the dynamics, and musicality, have just gone from adequate to really, really good. I know it probably sounds silly to use such an expensive lps with a component at this price point, but if you already have a power supply and are thinking about upgrading your streamer, just give this a go, you might have a surprise. I was not expecting anything given there weren’t many reviews, but I’d give this a 6/5. Well done audiophonics! I guess Ian Canada stuff is really that good. I’d recommend using good cables as well, totally deserving of them.
Pedro Jose T.
A 10 for Audiophonics logistics
In less than 36 hours my order was at home (Palma de Mallorca), a record. So congratulations to the Audiophonics logistics team.
I'm not going to talk about the sound characteristics, or the finishes, since other buyers have already done so and I fully agree with their observations, a fully recommendable amplifier if you are looking for quality-price and with a small footprint for your desk.
I just want to comment on how nice it looks with that red LED light that comes out from the inside through the ventilation slots and that I don't think anyone has mentioned. I also want to comment that I thought it would get hotter, but it has been working for about 4 hours (volume at 40%) and it is practically cold and moves my 84.5 db sensitivity speakers without problems.
Rainer E.
GUSTARD A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA Noir Gustard dévoile avec le A26 un DAC haut de gamme, aussi performant que polyvalent. Il se base sur une architecture de grande qualité, utilisant notamment un double...
Top !!
Nachdem ich bereits mehrere andere DACs ( Gustard x26 Gustard R26 und einen Questyle) ausgiebig in meiner Kette getestet hatte und die Firma Gustard fast ausgeklammert hätte, bin ich mit dem Gustard A26 hochzufrieden.
Dieses Gerät liefert eine sehr natürliche, authentische Wiedergabe mit ebensolchen Klangfarben, sehr guter Auflöung und einem ganzheitlich überzeugenden Gesamteindruck.
Klanglich habe ich nichts zu bemängeln. Ich kann damit Musik hören, ohne ständig da und dort mehr oder weniger Defizite verbessern zu wollen. Zuhören ohne Stress ohne in verrundeten Wohlklang abzugleiten.
Den Streamer habe ich nicht ausprobiert, da ich direkt über Macbook Pro und Audirvana höre.
Ich habe eine Hifi - Tuning Feinsicherung in der Gold Ausführung installiert, bzw. gegen die serienmäßige Feinsicherung ausgetauscht. Netzkabel ist das Furutech FP-3TS20. Auch dieses ist sehr empfehlenswert. Leider - wie so vieles - deutlich im Preis gestiegen.
Zurück zum DAC: Dieses Gerät ist in dieser Preisklasse absolut empfehlenswert und vielen anderen - auch R2R DACs überlegen.
Hätte ich den A26 nicht, würde ich wahrscheinlich den A26 schauen, oder dem Gustard X30.
Aber......die Nachfolge der aktuellerern Geräte ist noch lange kein Grund unzufrieden zu sein.
Hören Sie sich den A26 an, wenn sie die Gelegenheit dazu haben!
Die eingangs erwähnten Geräte lässt er locker hinter sich. auch den vielerorts hochgelobten RME DAC.. Ganz zu schweigen von allem was günstiger als Fertiggerät erhältlich ist.
Dimitar M.
SMSL PL100 Lecteur CD CS43131 Argent Le lecteur CD SMSL PL100 est un appareil qui vous permettra de profiter de votre collection de CD. Il repose sur une puce DAC CS43131 ainsi qu'un circuit PLL (Phase-Locked Loop)...
Excellent!
Great little CD player!
Very nice looks, decent remote control and superb sound quality! I first tried it with the optical out into my Aune X8 DAC with Sparcos Op-Amp. Sounded great.
After that I decided to try the onboard DAC and it sounds almost as good as my external DAC, that costs 4 times the whole CD player!
Overall, I am very pleased with it!
Murat D.
TUNG-SOL EL34B Tubes Pentode Platinum (Quad Appairé) Ces tubes pentodes Tung-Sol EL34B haute tension profitent d'une belle conception, utilisant des matériaux de grande qualité. Ils disposent d'une impédance...
Génial
Je les utilise au lieu des J&J EL34s sur mon ampli intégré. Je suis totalement satisfaite de cet achat. Un grand merci à Audiophonics.
FURUTECH NCF BOOSTER-SIGNAL-L Support Plat pour Câbles et Connecteurs Le NCF Booster Signal L de Furutech, déclinaison du NCF Booster Signal, est un support de câbles et connecteurs ayant pour particularité d'améliorer...
Le son se modifie mais est il meilleur ? rqp élevé
Ma chaine dispose de plusieurs câbles secteur stealth audio . Essayé sous le câble de l'ampli puis sous la prise du câble d'alimentation général . Je constate un son lissé et plus propre mais moins impliquant qu'avec les supports que j' ai fabriqué avec des supports de manche à balai muraux surmontés d'absorbants acheté sur ce même site . Cependant le son reste bon avec ce booster signal mais il s'agit sur mon système d'un autre type d'écoute plus rectiligne et avec moins de relief . Mon avis n'engage que moi mais ne justifie pas ce prix qui me semble élevé pour le résultat . A voir selon les systèmes .
Jean-Jacques R.
Gain trop important
Testé sur un ampli à transistor en remplacement de son préampli.
Le + :
- Le son à l'air déjà bon avec ses tubes d'origine,
- pas de ronflette,
- punch
le moins :
inutilisable sur mon ampli (Roksan kandy KII) du fait du gain élevé qui arrive dès le début de la course du potentiomètre de volume.
Le volume est trop fort alors que je ne suis même pas au quart et n'est pas gérable sur mon installation. Dommage.
Mais peut-être qu'un remplacement du potar serait une solution ?
Armin w.
It's Ok
After some fiddling with minor issues, I will correct my former review and give the case 4 stars for the price is fair.
Armin w.
Module Softstart de Commande et Temporisation pour Amplificateur Cette carte permet de commander l'allumage d'un amplificateur. Elle assure la fonction stand-by, soft-start, temporisation et protection thermique. Elle limite aussi...
Good quality
and works flawless. Recommended!
Szabó Z.
ELECAUDIO BA-40 Fiches Bananes Cuivre Tellurium Ø4mm (Set x4) Ces fiches banane Elecaudio BA-40  en cuivre tellurium assurent une excellente conductivité pour une parfaite transmission du signal audio. Le montage du câble...
quality product as usual
Xavier B.
ATAUDIO KING WOLF Câbles de Modulation RCA Cuivre OFC 6N Blindé Plaqué Or 0.75m (La paire) Ces câbles RCA ATAudio King Wolf affichent une fabrication de qualité avec des conducteurs en cuivre OFC 6N isolés, assurant une très bonne...
Mauvaise connexion
Bonjour, j'ai branché ce câble ATAUDIO KING WOLF sur ma platine Marantz et les connecteurs de chaque câble ne serrent pas assez du tout ; en tirant légèrement, les câbles se retirent assez facilement sans faire bouger la platine. Les connecteurs se serrent/desserrent un peu mais cela ne change rien à la force de serrage.
David O.
IFI AUDIO LAN IPURIFIER PRO Isolateur Réseau Galvanique Optique RJ45 Ethernet L'isolateur galvanique optique iFi Audio LAN iPurifier Pro vous permet d'optimiser la connexion LAN Ethernet de vos équipements audio. Une technologie d'isolation...
Easy to install - works well
Filtre Jack DC 9V à Supercondensateurs vers jack DC Ce filtre jack DC 9V à supercondensateur vous permet d'obtenir une alimentation propre pour vos équipements et appareils Hi-Fi grâce à 4...
Pratique et efficace
Apport évident dans la plupart des configuration.
J'en ai plusieurs et l'ajout d'une forte valeur capacitive de 4 à 5 Farad ( 4/5 millions de uF) apporte un vrai plus en matière de musicalité !
EIZZ EZ-206 Connecteur XLR Mâle 3 Pôles PTFE Plaqué Or Ø9mm Noir (Unité) Ce connecteur XLR EIZZ avec isolant PTFE permet la conception de câbles XLR symétrique de qualité. Sa finition plaquée Or et ses borniers à vis...
Très qualitatif et précis dans son utilisation. Le serrage inspire confiance et la fiche la qualité.
EIZZ EZ-206 Connecteur XLR Femelle 3 Pôles PTFE Plaqué Or Ø9mm Noir (Unité) Ce connecteur XLR EIZZ avec isolant PTFE permet la conception de câbles XLR symétrique de qualité. Sa finition plaquée Or et ses borniers à vis...
Etonnant
A la réception, j' ai été surpris par la qualité au toucher. Côté serrage, la aussi, c' est parfait. Une vraie pièce de précision !
Theodoros A.
MINIDSP MCHSTREAMER Interface USB XMOS vers I2S / SPDIF / ADAT / TDM/ DSD / PDM 32bit 384kHz DSD256 Le MiniDSP MHC Streamer est une interface USB multi-canaux asynchrone supportant de nombreux formats d'entrées et de sorties en tirant parti de l'expertise XMOS et...
MiniDSP MCHStreamer
Have been working with its previous version since 2013 without a single hitch. I integrated the new one in a multitrack interface setup (24ch) and is working flawlessly from day one. Albeit not really cheap, it' s worth its price..Audiophonics service prompt as always.
Rick H.
AUDIOPHONICS LPA-S600NCX Amplificateur de Puissance Class D Stéréo NCore NCx500 2x600W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics LPA-S600NCX, un amplificateur de puissance stéréo Class D basé sur deux modules NCore NCx500. Cette...
Wow - Great amp
The amp arrived in 3 days to the US! Very fast. Packaged well and I got it hooked up and it impressed me from the start. Smooth and musical - I could really see this amp as an end game. Gobs of power and control over my tower speakers. I am really impressed with how seamless the sound is. Nothing stands out - in a good way. Highly recommended!
Denis K.
SMSL B200 DAC USB CS43131 Récepteur Bluetooth 5.1 aptX HD LDAC 24bit 48kHz Le SMSL B200 offre les fonctions de DAC USB et de récepteur Bluetooth. Il bénéficie d'une puce Cirrus Logic CS43131 lui permettant de supporter des taux...
performant.
Acheté pour remplacer un Audiophonics U sabre , il tient bien la comparaison, son très clair et ciselé dans les médium et les aigus.
Mise en route rapide après avoir installé les pilotes ( lien fourni par l'assistance Audiophonics, merci ...) ça fonctionne direct en USB,
Apparié en Bluetooth en un éclair, pour écouter via le téléphone, à l'occasion.
J'ai utilisé les sorties RCA en analogique donc pas de retour concernant les sorties numériques,
En résumé très bon achat pour moi, en espérant une durée de vie aussi longue que le Sabre (8 ans!).
Très bon rapport qualité-prix pour ce DAC compact!
Dominique O.
PSVANE 12AT7-S Tubes Série S pour Préamplificateur / Étage Phono (Paire Appairée) Les tubes Psvane 12AT7-S offrent un courant de plaque élevé ainsi qu'un faible bruit. Ils sont donc tout particulièrement recommandés pour une...
12AT7-S
Tube comportant une finition excellente ;
montés sur un ampli Octave , ils ont une excellent définition, en particulier sur les médium / aigus
Rumen S.
Simple and reliable!
They are no nasty surprises with Neutrik XLRs.
The assembly is firm and tight and cable is ready for a heavy duty applications.
Rumen S.
Rumen S.
ELECAUDIO EB-05 Gaine Tressée Extensible Nylon (PET) 07-14mm Gaine tressée élaborée en PET (Polyéthylène Terephtalate) monobrins pouvant être utilisée dans une large diversité...
Very good product
This skin is easy to work with and has very good appearance.
I used it on OYAIDE TUNAMI V2 Ø15mm cable and it fitted perfectly.
Excellent value for money!
Pino M.
excellent cable!!
I own a Chord digital system that requires BNC SPDIF cables to express it's best: this cable makes the system to sound really well, better than any other I tried, great value for it's cost.
Impressionnant pour le prix
Comment dire...mes préjugés sur les amplificateur en classe D sont tombés...exceptionnel de transparence,sur des enceintes de rendement correcte (92 db) aucun tassement de dynamique ni de saturation même à niveau sonore déraisonnable
Comment vous faites pour moins de 300 euros ??
Petit aparté : je le trouve plus équilibré, moins brillant dans l'aigu que le AO 200 mk2
DAC INTÉGRÉ de qualité tres moyenne, mérite un dac externe
Gulnara G.
SYITREN R300 Lecteur CD sur Batterie Bluetooth 5.3 Blanc Le Syitren R300 est un petit lecteur CD affichant un design rétro du plus bel effet. Équipé d'une sortie optique Toslink et d'une sortie casque Jack 3.5mm,...
Beautiful player, love it!!!
Beautiful player, thoughtful retro design, and great quality. Packaging also looks nice.
THIERRY D.
gaine
la gaine est épaisse, très solide, idéale pour un travail propre et efficace...
THIERRY D.
gaines
les gaines sont épaisses, très solides, idéales pour un travail propre et efficace...
THIERRY D.
Fiches Bananes Plaquées Or Ø4mm (La paire) Ces fiches bananes à petit prix permettent la conception rapide et facile de câbles d'enceintes. Le montage se fait en effet à l'aide d'un système...
Bananes
fiches bananes d'excellente qualité, le contact avec les borniers est parfait. Montage facile !!!
Sanjin S.
ISOACOUSTICS APERTA Support d'Enceintes 155x190x76mm 15.9kg Noir (La paire) Les isolateurs IsoAcoustics Aperta assurent une excellente gestion de l'énergie de vos enceintes afin de réduire les vibrations résonnant à travers...
ISOACOUSTICS APERTA Speaker Stands
Great speaker stands.
I am very pleased with the improvement in the sound of my bookshelf speakers. If you have bookshelf speakers, I definitely recommend purchasing these stands.
Emmanuel L.
IBASSO DC07PRO DAC Amplificateur Casque Portable Symétrique 4x CS43131 32bit 768kHz DSD512 Noir Le DC07Pro est la nouvelle version du DAC portable / amplificateur casque de iBasso. Cet appareil compact est équipé de quatre puces CS43131 ainsi que d’un...
Mieux qu'un DC06 mais ça n'est pas le miracle
Ce petit DAC rend bien mieux qu'un iBasso DC06 ou même qu'un iFi Hip Dac 3 (sans la puissance). Il est plus précis et plus détaillé. La scène est plus large et les instruments bien séparés mais la largeur de la scène n'est pas envoutante.
Je l'ai testé avec un Hifiman, le FiiO FT1 et un Audiotechnica MSR7. S'il drive le Hifiman mieux que le iBasso DC06 qui menance de flamber tellement le casque en demande, ce n'est pas non plus ce que j'ai lu ici et là. Il se débrouille bien avec le FiiO et l'Audiotechnica mais un bon setting est nécessaire sans quoi la les basses et les aigus s'envollent.
La molette est gènante, elle s'active dans la poche et n'est pas manipulable aisément avec une seule main.
L'écran affiche trop d'informations en même temps, ce qui rend les caractères trop petits.
Sur un smartphone Android (Nexus 7a) c'est une calamité, beaucoup plus "picky" que le DC06 ou le Hip Dac. A la moindre perte de signal, le driver audio est désactivé. Au démarrage de l'application, il faut parfois plug-unplug plusieurs fois pour que le driver se load correctement; un peu comme avec les Questyle, qui, eux, m'ont carrément rendu dingue.
Bref, c'est bien, c'est petit mais je le trouve surcoté dans les reviews. Il y a des inconvéniants et il faut le dire
