Jean-louis L.
Jean Michel P.
Hervé R.
Pas si bien que ça !
Avis clients - Il y a 19012 avis.
Alexandru N.
GUSTARD X30 DAC 4x ES9039SPRO + ES9311Q XMOS XU216 Airplay 2 DLNA 32bit 768kHz DSD512 MQA Noir Avec son X30, Gustard dévoile un DAC d'une performance et d'une polyvalence exceptionnelles. En effet, ce DAC dispose de pas moins de quatre puces DAC ES9039SPro...
Gustard X30
First of all I would like to thank Audiophonics for the prompt delivery and exemplary packaging! It was delivered to me in Bucharest between Christmas and the 31'st.
This DAC is nothing short of amazing. I haven't heard anything like it before.
I can't find a single drawback to it's sound, the stage is deep and wide, the timbre is spot on, dynamics are off the charts with big swings and a really potent bass. I've always thought that the bass can't be very tight in my room because I have no treatment installed, but this DAC proved that it was the source that was keeping my system back in this regard. I don't mean to say that room treatment wouldn't help further, but to some this is not an option.
All of the aspects I've stated are impressive, however, the separation of instruments and voices is on a different level and this makes music make sense.
With this DAC I found that songs I thought were poorly recorded were just not reproduced well by my previous DAC.
Regarding the burn in period that lot's of reviewers mention, it sounded great right out of the box and I was happy with my purchase, but it did improve in the first three days.
Build quality is impressive, but the remote is of poor quality. Luckily I don't use it since I have a separate preamp. Regarding the preamp, it sounds a lot better with a preamp, but this might be system dependent. Going into my preamp if I adjust the volume from the Gustard the sound quality is not affected at all so the volume control inside it is good, but If I take my preamp out of the chain the sound is downgraded from all points of view. My preamp (Benchmark HPA 4) has no gain in the range that I use it in, but it has input and output buffering and it makes any DAC I connect to it sound better. If you've never tried a preamp you will still enjoy the upgrade compared to other DAC's connected directly to a power amp, but if you want an impressive upgrade further down the line get a good preamp.
Simply amazing!
Laurent P.
Fiches Bananes BFA Plaquées Rhodium Ø9mm (La paire) Ces fiches bananes, bien que peu onéreuses, profitent d'une belle qualité de conception. Le design BFA de ces fiches permet un très bon contact...
très bon serrage et solidité
Pour l'instant à leur niveau qualité / Prix , je n'ai rien trouvé de mieux Très bon serrage et une solidité bien supérieure à tout ce que j'ai pu avoir précédemment. Je les recommande.
Francis B.
Très propre
Le son est vraiment bon. Isolation et blindage efficace. Réalisation soignée! Prix raisonnable. Formidable.
Francis B.
Câble Casque Symétrique XLR 4 Pins Mâle vers 2x Jack 3.5mm Mono Mâle Cuivre Plaqué Argent 1.5m Ce câble high-end pour casque symétrique profite d'une conception extrêmement soignée, faisant usage de composants de grande qualité. Il se...
Ben voilà. Enfin!
Oubliez le câble d’origine Focal pour les casques Focal Clear avec XLR 4 pin. Le câble apportera l’équilibre tonal qu’on attend avec le clear MG par exemple que j’utilise avec. Et tout sera plus transparent, meilleurs basses . Formidable.
Nikolaus N.
SMSL PO100 PRO Interface USB XMOS XU316 I2S SPDIF 32bit 768kHz DSD512 MQA Le SMSL PO100 PRO se présente comme une interface USB extrêmement performante et incroyablement compacte. Malgré des dimensions réduites, le PO100 PRO...
Perfekt
Ich verwende den USB-Adapter so, wie er bei cheap-audio-men empfohlen wurde. Er kommt zwischen dem WIIM ultra und einem DAC (smsl d400 ex) zum Einsatz. Er erwirkt ein unglaublichen Gewinn.
Xavier B.
AUDIOPHONICS HPA-Q250NC Amplificateur de Puissance Class D 4 Canaux NCore NC252MP 4x250W 4 Ohm Le Audiophonics HPA-Q250NC est un amplificateur quatre voies basé sur deux module d'amplification Hypex Ncore NC252MP.
Plutôt bon
L'ampli est plutôt bon, je reconnais que la définition est meilleurs qu'avec mon crown XLS 1502 (plus de micros détails), par contre je ne suis pas bluffé par la différence qualitative, à l'écoute on gagne un peu c'est vrai dans les détails, , mais au vu des critiques et review sur les amplis hypex ncore je m’attendais à un gain qualitatif plus conséquent, je reste malgré tout satisfait de ce nouvel ampli qui s’intègre mieux.
richard L.
XANGSANE XS-LB001 Câbles d'Enceintes Bananes Cuivre OCC 2x6mm² 3m (La Paire) Les câbles pour enceinte XS-LB001 de Xangsane sont constitués de 12 brins en monocristal de cuivre OCC 5N afin d'assurer une conductivité parfaite. Chacun de...
Surprise
Si comme moi vous êtes un adepte du mogami 3103 et bien achetez le xangsane sans hésiter une seconde, il fait tout mieux, et même beaucoup mieux.
Le prix en regard de la qualité est ridicule, bref je suis ravi.
AUDIOPHONICS GXDC-21 Câble d'Alimentation Jack DC 5.5/2.1mm vers GX16 Cuivre OFC pour Alimentations LHY 1m Ce câble d'alimentation Audiophonics, assemblé en France dans nos ateliers, se compose d'une part d'un connecteur Jack DC 5.5/2.1mm et d'autre part d'un connecteur...
Excellent!...
Câble d'alimentation excellent, remplaçant avantageusement celui d'origine fourni avec l'alim. L'amélioration est évidente sur les plans de l'espace, de la densité et des timbres. Indispensable à l'alim pour laquelle il est conçu et construit par Audiophonics.
Mark S.
LPSU200 Alimentation Linéaire Régulée HiFi 12V 13A 200W NAS / Freebox / Mac Mini L'équipe Audiophonics est fière de pouvoir vous proposer une alimentation linéaire régulée destinée à alimenter proprement les...
Really opens up with a better power cable
I bought this LPS to replace an Uptone JS-2 which was powering my Mac mini. (The JS-2 was a bit-underpowered --sometimes the Mac mini restarted during heavy updates-- moved to my UltraRendu and EtherRegen. With this Audiophonics LPS's extra amperes the Mac mini no longer reboots.
I initially noticed little difference in sound quality (which is good -- the JS-2 is more expensive and for my Mac mini this LPS sounded similar). I have since experimented with various power cords in the €50-€250 range. It turns out that this LPS is a very nice match with a shielded €57 OFC copper cable.
I recommend this LPS especially with a nice shielded power chord. Best with 1,5m -2m length, in my experience.
Delivery by Audiophonics to Sweden was quick. The LPS is heavy and feels very solid.
Rik H.
SMSL RAW-MDA1 DAC 2xES9039Q2M Amplificateur Casque Bluetooth 5.1 32bit 768kHz DSD512 MQA Le DAC SMSL RAW-MDA1 est un DAC symétrique qui dispose de deux puces ESS ES9039Q2M et d'une interface USB XMOS XU316. Ces composants de qualité lui permettent de...
Great product!
For the price this thing is great! It's well build, looks good and functions as promised.
Menus are very clear and settings are easy to changes according your personal needs.
The remote also works better then the one from the Topping product I had before.
The display is clear and informative. (brightness is high, so you can set it to the lowest level and it is still readable from a good distance)
But better still: objectively it lives up to the specs the manufacturer shows on the product page. (https://www.audiosciencereview.com/forum/index.php?threads/smsl-raw-mda-1-dac-headphone-amp-review.56430/) It does not sound. It just transforms from the digital domain to the analog and amplifies (actually it attenuates) the signal without any audible artifacts.
CASPAR P.
j'ai du mal à comprendre
Bonjour à tous.
J'ai testé ce câble sur mon installation, Naim supernait3, JMR cantaile jubilé, Atoll MS120.
J'avoue avoir du mal à comprendre les nombreux avis positifs sur ce câble. Il est terne, très mou dans le grave et peu définit dans le médium aigu. Les voix deviennent tristes et les timbre voilés dans un flou à la David Hamilton.
J'imagine que sur beaucoup d'installations, il corrige un coté agressif de l'aigu, Pour moi, le but d'un câble est de transmettre, pas de corriger. Démonté au bout de 50 heures d'écoute.
par contre 5 étoiles pour le service Audiophonics, il est rapide, définit, bref, tout l'opposé de ce câble.
Pierre
GEORGIOS C.
ELECAUDIO TE-RC90S Connecteurs RCA Cuivre Tellurium Argent Ø8.5mm (La paire) Ces connecteurs ont été conçus pour vous offrir une très grande conductivité grâce au Cuivre Tellurium.
Remarkable sound for a very reasonable price
The plug has all the attributes that i'm looking for, the most important being the PTFE insulation and the direct silver plating. The surprise came when i compared it with the VIBORG VR106G which has solid silver contacts and costs four times the price of the Elecaudio. To my detailed system (costing 15.000€ that are spent very carefuly) their sound is indistiguisable. This is an exceptionaly good sounding RCA plug, which is allso very well made and, to my knowledge, with the highest value/money ratio.
Jean Louis L.
NEOTECH NC-P303G Connecteur IEC C13 Cuivre UP-OCC Plaqué Or Ø24mm Ce connecteur IEC C13 Neotech NC-P303G vous permettra de concevoir vos propres câbles secteur hautes performances. Il intègre en effet des contacts en Cuivre UP-OCC...
Timbres juste et grand naturel
Ce connecteur en cuivre pur OCC vient remplacer un déjà très bon connecteur Viborg en cuivre pur OFC, sur un câble Furutech TCS31.
L'écoute après le rôdage habituel montre un progrès net dans le naturel des timbres et sur la reproduction des voix. En association avec le Furutech TCS31, l'écoute est de toute beauté !
Ce connecteur ne montre aucune brillance, c'est le naturel qui s'impose (attention si ce point est important pour vous à la version Rhodium, mais c'est affaire de goût de chacun).
A son tarif, il permet un réel progrès de l'écoute et représente une valeur sure et une référence, pour qui recherche une écoute juste et naturelle des voix, avec des timbres riches et de toute beauté sur des instruments acoustiques, sans la petite brillance et sur-définition artificielle "hifi" que personnellement, je n'aime pas.
Jose Molina Cuerda P.
Mcap
Sonido natural y refinado
Mcap
Mcap
sonido natural y refinado
Eric J.
SMSL A50 PRO Amplificateur 2.1 Class D 2x MA12070 Bluetooth 5.0 HDMI ARC 2x70W 4 Ohm + 100W 2 Ohm Le SMSL A50 PRO est un amplificateur 2.1 canaux class D intégrant deux puces d'amplification Infineon MA12070P. Il est en mesure de développer une puissance...
Une bonne surprise, avec du souffle
Ma base de comparaison se fait avec Smsl DA-6, Aiyima T9, Xduoo MT-605, Fosi Za3, Aiyima A08 pro, Topping MX3S.
Et des amplis Kenwood vintage qui sont ma préférence jusqu'à aujourd'hui.
Cet ampli sonne brillant, transparent, sans doute la signature des deux MA12070. J'aime bien. Très expressif, peut être trop pour certains. En tonalité direct, les aigus paraissent excessifs, les basses aussi. La rythmique est bien maîtrisée.
Son défaut, c'est que sans musique jouée, il fait du souffle.
Pour le prix, la sonorité, les entrées, la télécommande, la puissance 2X70W présents, je l'ai vraiment apprécié. Et je le préfère en sonorité aux amplis d'Audiophonics, cités plus haut.
Michel V.
SHANLING EC SMART Lecteur CD Vertical Sanyo DA11 CS43131 Bluetooth 5.4 Le Shanling EC Smart est un lecteur CD abordable et performant, au design atypique et résolument moderne. Affichant un format vertical, le EC Smart accueille les CD juste...
Elégant lecteur et pratique
Peut se mettre à la verticale ou à l'horizontal. La dynamique est bonne.
Le son délivré par le jack casque et par le BT a de la puissance.
Quand utilisé à plat, les entrées arrières / dessous, ne sont pas très pratiques.
jean-françois v.
IAN CANADA SC-PURE Horloge Femtosecond Ultra-Faible Bruit de Phase 45.1584MHz Le SC-Pure de Ian Canada est une horloge audiophile high-end, fabriquée à partir de cristaux SC-CUT de haute qualité. Afin d'obtenir les meilleures...
Retour d'expérience après rodage - environ 50H
Je tenais à faire un petit retour d'écoute de ces horloges au combien excellentes, cependant après rodage de celles-ci (45 et 49 MHz) installées sur mon Reclocker FIFO PI Q7 II, il apparait ce qui suit :
- Les voix de certains chanteurs étaient auparavant un petit peu sourdes , elles sont bien en place après rodage.
- Tout parait beaucoup plus juste, plus à sa place.
- On gagne de la matière dans le bas médium
- Les graves sont abyssales et très tendus
- Les fins de notes sont hyper silencieuses
Pour finir le plus important, il y a une séparation des canaux et des instruments encore plus marqué, j'ai une stéréophonie qui prend de la largeur comme jamais. Et puis tout ça c'est très naturel, sans crispation ni dureté on en oubli que c'est du numérique !! Produit à acheter pour atteindre les sommets (auparavant j'avais des horloges Accusillicon), le gap est vraiment important entre ces deux horloges !! Bravo à Ian Canada pour le développement de leurs produits qui sont bien au-dessus de la concurrence.
jean-françois v.
IAN CANADA SC-PURE Horloge Femtosecond Ultra-Faible Bruit de Phase 49.1520MHz Le SC-Pure de Ian Canada est une horloge audiophile high-end, fabriquée à partir de cristaux SC-CUT de haute qualité. Afin d'obtenir les meilleures...
Sc Pure après rodage d'environ 50h00
Etienne c.
AIYIMA A08 PRO Amplificateur Class D TPA3255 2x220W 4 Ohm Bluetooth 5.0 Aptx-HD LDAC Le Aiyima A08 PRO est un petit amplificateur Class D, très puissant, performant et abordable. Il se base sur une puce d'amplification TPA3255 et un AOP NE5532P, lui...
Dommage
Ampli bon son avec très bonne dynamique.
Problèmes : écartement bornes hp pas normalisées.
diamètre passages de câbles hp très petits.
Bouton power on / off capricieux.
Ampli reçu pas neuf, modèle d'expo ?
Etienne c.
Dommage
très bon ampli neutre et très bonne dynamique .
Les problèmes : espacement des bornes hp pas normalisées .
le diamètre de passage câble hp très petit.
bouton marche arrêt capricieux
Le produit que j'ai reçu n’était pas neuf , modèle d'expo ?
Teddy A.
MUNDORF MLYTIC AG Condensateur 100V 1000µF Ces condensateurs ont été spécialement développés pour les amplificateurs de petite puissance ou les préamplificateurs. Ce nouveau...
Le meilleur des meilleurs
Utilisé pour upgrader les composants existant dans un DAC déjà excellent (ERATO DAC100V1) c'est incroyable de constater combien les autres condensateurs manque de transparence !!!
david h.
DAYTON AUDIO HDN-8 Haut-Parleur Vibreur Exciter Large Bande Étanche 50W 8 Ohm 40Hz - 15kHz Ø10.2cm Vibreur électrodynamique étanche, plaçable virtuellement n'importe ou le HDN-8 de Dayton Audio permet au sens propre de faire "sonner" tout...
haut parleur
les meilleur pour un pincab et le service audiophonics du tonnere
Emmanuel A.
Bien meilleur que d’autre très cher
J’ai essayé de nombreuses grammes de Câble pour des connexions modulation sur mon système Attol in 300 Avec streamer et lecteur, ainsi que Dac, de très bonnes factures sur l’ensemble, des cables testés du commerce et ce que j’ai fait fabriquer ce modèle m’a donné la plus grande satisfaction, il est supérieur À l’autre modèle de cette marque, le l2-t2s a beaucoup plus de détails, je trouve le moins montant que le L-4E6S
Pour les avoir tous les deux testés en alternance
Bruno C.
BERRYBAK BEA 1 R2CEPTEUR BLUETOOTH
Excellent rapport qualité prix. Facile à installer , facile à mettre en route!
Paulo A.
FOSI AUDIO BOX X1 Préamplificateur Phono MM Le  Fosi Audio Box X1  est un petit  préamplificateur phono MM  simple, efficace et abordable. Celui-ci utilise des composants à faible...
This is a tiny, cheap pre amp phono that i bought to replace a broken NAD ... and it sound very very clear and cristal. For the price it is a great product! Love fosi brand.
Paulo A.
TUNG-SOL 12AU7 / ECC82 Tubes (Unité) Le Tung-Sol 12AU7, fabriqué en Russie, assure un très faible bruit. Il a été conçu pour imiter les performances des tubes américains...
I put this new tube in my Xduuo 605 amp and the sound is fantastic... very good. It's an huge upgrade from the original tube at a very nice price!
Paulo A.
XDUOO MT-605 Amplificateur à Tube 12AU7 TPA3116 2x30W 4 Ohm Le MT-605 de xDuoo est un petit amplificateur abordable, combinant les performances d'un Class D à la musicalité d'un système à tube. Son...
Fantastic little amp
This is a great little amp. I love tube amps and the warm sound ...this one is a super budget hifi piece. I roll to a new tube (thanks for the tip) a Tung Sol and it just sound amazing. Great mids and highs, bass is very smooth but present. The sound is vey neutral and warm ... just fantastic
iouri C.
PSVANE EL34-Z Tubes de Puissance Pentode (Paire Appairée) Le tube de puissance EL34-Z de PSVANE propose un son chaux et doux, ample et naturel, un bel équilibre et un bruit de fond absent. PSVANE nous offre ici un tube à...
Superbes !
Ces tubes sont magnifiques ! Je ne parle pas du coffret, de l'écrin grande classe dans lequel ils arrivent. Acheté en deux fois deux appairés pour mon primaluna prologue one. J'ai des el34 jj versions 1 et 2, des Mulard 6450, des lion gold KT 88... J'ai débuté avec psvane sur deux 12ax7 puis deux 12AU7 qui ont remplacé des mulards et jj la aussi. Maintenant tout est en psvane. Si j'aime le son des kt88 je les trouve trop "modernes" en son. Avec lrs psvane el34z, je retrouve le grain des el34 série 2 de jj mais avec un son plus analogique et surtout une présence et détails dans les voix, des harmoniques... C'est assez fabuleux alors qu'ils n'ont pas encore tourné plus de 25 heures environ. A voir ou plutôt entendre si ils se bonifient encore !
hugues O.
Convertisseur Ethernet vers Fibre Optique (La paire) Alimentation IEC Cet appareil permet de convertir un signal Ethernet 10/100/1000Base-T vers de la fibre Optique 1000Base-SX/LX. Il est ainsi possible d'isoler le signal du reste réseau...
Fibre
C’est le premier et le moins cher des convertisseurs optique qui fonctionne chez moi. Je ne sais pas si c’est dû à la fibre monomode. Ne pas oublier de commander une fibre monomode si vous n’en avez pas et des câbles IEC. SHUKO
Hocine H.
Sceptique, mais...
Je devais changer la double prise qui alimente mon système, je me suis dit cher, mais pourquoi pas. J'étais sceptique, voire je n'attendais rien de particulier ; et pourtant quelle claque. Ce n'est pas le jour et la nuit, mais tout est plus limpide, détaillé. Alors comme j'ai une double prise juste à côté, j'ai pu faire la différence et non je ne rêvais pas, il y a bien un avant et après avec cette prise Furutech et si je devais tout recommencer de 0, c'est la première chose que je changerai, n'hésitez pas, vous ne le regretterez pas, cette double prise change votre perception de la musique.
Sylvain M.
Super streamer. Je ne suis pas audiophile, mais je peut dire que le son est très bon, détaillé, les basses profondes. Un appareil qui s'oublie (avec une bonne application) : pas d'affichage superflu, et une petite taille parfaite pour le cacher dans un meuble. Je recommande !
stoica r.
Neotech 3200
Best cable for the money.
I have exchanged my 3200 with mogami. I lost a sens of 3d on the super lowe frequency. Overall I gained in naturala musical dimension . I have a audio gd master 11 Singularity with audio gd master 1 he vacuum and 2H monoblocs. Speaker go to 2 ohms
Antonio D.
AUDIOPHONICS CANARE Câble numérique Coaxial 75 Ohm RCA-RCA Gainé 1m Voici notre câble numérique coaxial Audiophonics Canare en version 75Ω. Sa particularité est de comporter des connecteurs Canare C5F, certifiés 75Ω et un câble Canare L-5CFB.
Três bom cable. Bonne construction et trés neutre au niveau son.
Juha T.
AUDIOPHONICS LPA-S450ET Amplificateur de Puissance Stéréo Class D Purifi 1ET6525SA 2x450W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics LPA-S450ET, un amplificateur de puissance stéréo classe D basé sur deux modules Purifi 1ET6525SA....
Excellent quality
Build quality really good, excellent sound. Although the case is small and lots of power, amplifier case heats only little during modest levels of listening.
George A.
SHANLING CR60 Lecteur Ripper CD Sanyo HD850 Argent Avec son CR60, Shanling dévoile un lecteur/ripper CD relativement compact et peu encombrant. Le CR60 est basé sur une tête laser Sanyo HD850 et un...
Τα αρνητικά ... είναι η μικρή οθόνη δεν βλέπεις αριθμό κομματιού και χρόνο από θέση ακρόασης, και δεύτερον δεν έχει πλήρες αριθμολόγιο 0 έως 9 πού έχουν τα cd players. Επίσης αργεί λίγο να πάρει εντολή στο πάτημα των κουμπιών του. Δηλ. δεν προδιαθέτει για εναλλαγή κομματιών με το γνωστό τρόπο, σταμάτα ξεκίνα κτλ. Προσωπικά δεν έχω θέμα με όλα αυτά... μπορεί για κάποιον να είναι αρνητικά...
George A.
Shanling cd transport cr 60 + musical fidelity v90 dac. Είχα rotel cd 965, cabridge cd azur 640; Τα ξεπερνάει εντελώς! Υπέροχη στερεοφωνία, ανάλυση αβίαστη απεικόνιση, αθόρυβο εκτός και ο δίσκος είναι άκκεντρος; (Σε ελάχιστα cd). Αρκετά βαρύ (Φούλ αλουμινένιο κουτί και παχύ!!) βλέπεις τα χρήματά σου με το παραπάνω. Με ποιοτικό τροφοδοτικό είναι το κάτι άλλο!
le meilleur de fosi
achetés puis revendus pour fosi v3 mono, je regrette cet echange. Meme si v3 mono est plus propre sur le signal, le plaisir d' écoute( spacialisation, detail, relief) est bien meilleur sur les za3
OYAIDE SS-47 Étain à Souder Soudure Argent 4.7% Cuivre 1.7% Flux 3.3% Ø1mm 50g La SS-47, la soudure haute fidélité d'Oyaide, permet la réalisation de soudures de grande qualité. Celle-ci contient de l'étain pur 4N...
nickel
cet etain allié a l' argent est super a travailler et les soudure sont propre et brillantes. Apres plusieurs essai de marque, je retiens en definitive celle ci.
tout simplement le meilleur rapport qualité prix en matière de fiche xlr.
Fiche Banane Cuivre OFC Plaqué Or Ø5mm (Set x4) Cette fiche banane offre un excellent rapport qualité / prix. Conçue en cuivre OFC 4N avec plaquage or, elle assure une très bonne conductivité et...
bien et jolies
bonnes fiches bananes mais suivant le bornier, on peut être ennuyé pour les enficher.
MUNDORF ACS1150GY ANGELIQUE Fil de Câblage Cuivre / Argent / Or 1.5mm² Gris Le fil de câblage Mundorf ACS1150GY Angelique est un modèle haut de gamme dont les conducteurs sont faits de cuivre, d'argent et d'or pour une conductivité...
usage bien précis
J' ai voulu essayer ce câble pour un câblage interne de 'un ampli en liaison HP, a lui seul, il ne convient pas pour cet usage . En effet, il excelle dans le haut médium et les aigus mais trop maigre pour des basses dignes de ce nom.
parfaite
Tout comme les fiches bananes de cette marque présentes sur ce site, ces fourches sont de très bonne qualité, je les recommande.
tres moyen
J' ai essayé ces fiches de qualités moyennes voir en dessous. le signal est assez passant mais la qualité de serrage et de fabrication n e fait pas honneur a Viborg même à ce tarif.
top
ces fiches rca sont parfaites en tous points. faciles a souder, légères et peu encombrante et transmission du signal intègre.
elles font souvent partie des choix des grandes marques de câbles.
parfaite
je epnsais que jantzen était une marque chinoise proposant des produits de qualité moyenne.
Il n' en est rien. C' est une société suédoise qui propose dew produits de treès bonne qualité à un prix ultra compétitif. Ces fiche en sont la preuve. elles sont jolies, bien calibrées et le serrage est parfait meme en faible section. Leur design minimaliste offre une finition hi end. je recommande ces fiches sans hésitation.
Patrice T.
HIDIZS S9 PRO PLUS MARTHA Amplificateur Casque DAC Portable ES9038Q2M Symétrique 32bit 768kHz DSD512 Noir Hidizs dévoile avec son S9 Pro Plus Martha, évolution du S9 Pro, un amplificateur casque DAC portable symétrique puissant et performant. Il dispose d' une...
Impec !
J'ai acheté ce DAC sur les conseils d'Audiophonics que je remercie vivement. Dans un budget contenu je voulais dépenser pas plus d'une centaine d'euros pour essayer ce type de matériel que je trouve désormais indispensable.
Il ne fonctionnait pas avec mon Samsung S23 Ultra, j'ai donc écrit chez Hidizs qui m'ont répondu très rapidement et de manière bienveillante, je les remercie également de fournir un support de qualité. Finalement il s'est mis à fonctionner. Pour info il fonctionne sous Windows 11.
Il faut absolument respecter le sens du câble, le logo sur la prise du smartphone.
Que dire...c'est mon premier DAC donc pas de comparaison possible. Je ne vais pas parler de la profondeur du grave, de la transparence des aiguës et j'en passe, non...je vais simplement dire que je suis très satisfait de la restitution, de sa limpidité, d'une bonne musicalité qui me satisfait pleinement. Sur Qobuz c'est magique en Hi-Res.
Il faudrait que j'essaye un jour un DAC 5 fois plus cher pour comparer. Il y a peut-être mieux mais je n'en sais rien...
Le logo sur le DAC s'allume dans une couleur en fonction de l'encodage du fichier lu, c'est du plus bel effet.
Il est petit léger, les boutons volume pratiques, belle construction, bel achat.
Loic T.
pour mon khadas tone2 pro
fonctione parfaitement, impecable !!!
Michal L.
AUDIOPHONICS Trigger 12V 230V sur prise IEC Déclencheur d'alimentation Cet accessoire, fabriqué en France, dans nos ateliers, permet d'ajouter aisément une fonction d'allumage automatique (trigger) à vos appareils ne...
Good
Works/performs as expected. However I must confirm this - from another review: "Another con is the tolerances of the connectors - the plug side is tiny bit too small and tends to wobble when plugged in and the connection does not feel as secure as it should. Same goes with the input side which is a bit too loose."
