Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Mohammed B.
die
Avis clients - Il y a 19398 avis.
Vincent R.
VIBORG CF201 (G) Embase XLR Femelle 3 Pôles Cuivre Pur Plaqué Argent / Or 24k 3μ (Unité) Cette embase XLR 3 pins femelle CF201(G) profite d'une très belle qualité de conception et de l'usage de matériaux de qualité. Ainsi, les contacts...
Réactivité, parfait.
Produits commandés conformes à la description.
Bravo Audiophonics!
GGAudio
Dany P.
Top vendeur, rapide, a recommander !!!
Christian H.
MONACOR SPP-250 Haut-Parleur
Commande, expédition, livraison tout à fait satisfaisante.
Le produit correspond à ce que je recherchais, l'enceinte fonctionne correctement à nouveau.
Bravo et merci à Audiophonics, je recommande!
Yevhenii V.
Amazing power amp
Don't have enough hi-fi amp experience.
But this amp with hi-end killer Yulong Da8 Dac and Klipsch forte really rocks!
Michele H.
I'm in heaven!
Until today I have been relying on the DAC of my AV amplifier, but I needed highres also for my new audiophile headphones, and AV amplifiers can't properly drive high impedence headphones. This little box connected to a good amp can truly sing! I've been using it with a few flac lossless CD rips and Tidal Hifi (24/96), all streaming from a dedicated Intel NUC connected through usb (Asio drivers) . I was surprised and delighted to get 24/192 when streaming Tidal Hifi from my Samsung S21 connected via USB: tidal on android can perform the MQA unfolding via software (presumably as the Topping e30 doesn't decode MQA).
I haven't tested the spdif or optic inputs and I am using it in pure DAC mode, mostly because I always want to visualise the sampling rate. The remote is useless for me after the initial setup.
As power supplier I'm using an old ipad charger which I am sure is cleaner than the power delivery from the NUC usb, but the power utilisation is so small that I could use a battery :)
I can't yet feel any difference among the DAC profiles.
A small click can be noticed whenever the DAC switches resolution, but I'm not overly bothered as I don't switch very often using my sources.
I can't imagine a better DAC at this price. If sound quality from usb is the priority I strongly recommend this
Simon C.
JANTZEN AUDIO SILVER Z-CAP Condensateur 800V 1µF Les condensateurs Jantzen Audio Silver Z-Cap permettent de maintenir une parfaite neutralité sonore et un très bel équilibre tonal. Il sont...
Superb capacitor, but...
This is a superbly transparent and detailed capacitor for the cost. It gives far superior resolution compared with low cost metallized film capacitors. I have successfully used this range of Jantzen capacitors both in passive crossovers, and as amplifier decoupling caps.
BUT: there is a slight emphasis at high frequencies, which in a bright sounding system might prove fatiguing. So if you have a neutral or slightly ‘dark’ system, the Jantzen Silver Z-Cap is an excellent choice.
Jean-Michel R.
Câble de modulation Canare
J’ai commandé le modèle 1,5 m sans soucis.
J’ai été contacté quelques jours après pour m’indiquer que le modèle n’était plus en stock et qu’il fallait attendre de 1 à 3 mois !!!!
Inadmissible.
Je me suis rabattu sur la version 1 mètre.
Xavier B.
VIABLUE UFO Absorbeurs de Vibrations Ø35mm Argent (Set x4) Les absorbeurs Viablue UFO permettent d'amortir les vibrations néfastes en se plaçant sous vos enceintes ou appareils HiFi. Du fait de leur pression optimale sur...
Produit de qualité.
A l'achat de ces absorbeurs, j'étais sceptique sur le résultat. Il s'avère que c'est parfait pour l'utilisation que j'en fait. Ces absorbeurs servent de pieds à mes enceintes. Elles sont posées sur des dalles de béton sur un plancher en chêne de 2.5 cm dans une maison ancienne. Les pointes ne me donnait pas satisfaction avec les graves et maintenant les contrebasses ont retrouvé leur superbe.
Antoine P.
Antoine
very good connector, speedy delivery!
Francis L.
inégalable à ce prix !
Mon écoute sur casque Hifiman H500, auparavant sur ampli casque Schiit Lyr2 (vendu par Audiophonics, mais production arrêtée) et Little Dot MK2 ((également disponible chez Audiophonics). Ce petit ampli K214 en pure classe A est vraiment impressionnant pour le prix. Construction de qualité, avec des connecteurs RCA de qualité, un potentiomètre haut de gamme, un prise jack robuste. Sur le bouton de volume on aurait aimé une marque permettant de mieux visualiser le niveau sonore. Pour ma part, en écoute raisonnable, je ne monte pas plus haut que 9 heures. Ce qui me plaît, alors que je n'écoute que depuis quelques heures et que l'ampli n'est pas rodé, c'est la qualité des timbres, l'absence d'agressivité et de brillance, des basses propres... tous critères qui sont appréciables pour l'écoute au casque qui deviendrait sinon fastidieuse, voire douloureuse pour nos petites oreilles. L'écoute a ce caractère vivant, mais serein, apaisant, que j'apprécie particulièrement et que permet le mariage avec un casque planar / orthodynamic. Seul bémol : l'ampli ne comporte qu'une entrée, pas de sortie et donc pas de pass through. Ce qui ne facilite pas son branchement dans votre système. Personnellement j'utilise une dérivation en Y à la sortie de mon lecteur/DAC, une liaison vers mon préampli, l'autre vers l'ampli K214.
michel g.
1877PHONO COVE-ST Câble RCA vers DIN OFHC pour platine vinyle 1.2m Ce câble a été spécialement conçu pour les applications analogiques et a pour objectif d'améliorer considérablement le signal d'entrée de votre platine.
Trés bon câble qui s'adapte parfaitement à mon bras Micro Seiki 505.
Belle finition à un prix très compétitif.
Stephane c.
Magique
Super pratique! J'ai relevé le plastique qui garde les pates alignées pour ne pas le faire fondre en soudant, opération délicate qui demande un peu de patience. Très bon produit très pratique pour changer un aop soudé au ci d'une carte audio.
Merci!
Stephane c.
TX C2 Module interface I2S vers I2S LVDS HDMI Ce petit module vous permettra de récupérer un signal I2S pour sortir ensuite sur du HDMI I2S LVds. L'interface supporte le DSD pour profiter de fichiers très haute résolution.
Fait ce qu'il faut
Bon module, simple, transparent, permet des montages de haute qualité sonore en i2s.
Stephane c.
Fonctionne très bien
Stephane c.
JANTZEN AUDIO ALUMEN Z-CAP Condensateur 100V 3.3µF Les condensateurs Jantzen Audio Alumen Z-Cap sont basés sur la série Silver Gold Z-Cap avec une présence tonale plus neutre et musicale. Cette série Aluminium Polypropylène...
Surprise
Ce condensateur m'a permis par son équilibre de simplifier grandement le circuit de filtrage de mon tweeter.
Beaucoup d'espace, scène sonore réaliste, du relief, du placement plus facile des instruments, plus de lisibilité des instruments /chanteurs entre eux. Le meilleur Rapport Q/P que j'ai pu pratiquer à ce jour, face à du audyn cap jusque true copper, du mundorf, du scr jusque étain, et du jantzen jusque Silver z cap. Je n'ai pas testé les amber. Aussi je n'ai pas testé ce que donne ce modèle sur un mid, il semble qu'il soit fabriqué plus particulièrement pour gérer les fréquences hautes, donc les aigus.
Stephane c.
RADICAL
Passer d'un LME49720HA en circuit intégré à ce SS3602 en circuit discret classe A a permis d'exprimer toute la qualité du circuit de conversion de mon DAC.
Plus de puissance, plus de réserve, meilleur traitement du signal, plus d'amplitudes de fréquences, plus de rapidité des informations. L'impulsion arrive plus vite et se pose plus tôt qu'avant avec plus de calme dans son relevé.
Le résultat: des graves qui explorent toute la bande passante, des bas mediums et mediums qui ne se mangent pas entre eux, les aigus sont là sans jamais offrir quelque fausse brillance. Tout est très réaliste et équilibré, la scène sonore s'élargit, la profondeur prend beaucoup de dimension, le placement est bien plus vrai et les textures sonores ressenties plus naturelles/ charnelles. On découvre de nouveaux détails sans en être envahis, la lisibilité est juste nettement supérieure et ce quelque soit la fréquence.
La disposition des fortes, des signaux complexes et très aisée. On sent que le dac s'exprime dans ce qu'il fait réellement.
Si vous avez un aop sur votre circuit audio (pas sur un la stabilisation d'un circuit parallèle), en entrée ou en sortie, soyez certains que cette ingénierie fonctionnera bien mieux que quelque autre aop de circuit intégré du marché.
Je l'ai mis dans mon topping D70 sur un support d'adaptation fourni par audiophonics, opération très délicate, pas recommandée à tous. Faites vous aider d'un électronicien compétent au besoin. SI votre matos a un socket qui permet d'interchanger rapidement les aop, alors vous pourrez considérer le changement par vous même sans crainte. Prenez soin de respecter le sens de branchement, sans quoi vous détruirez l'aop instantanément au branchement.
Un superbe produit qui a dépassé mon attente, malgré tout ce que j'ai pu déjà en lire. Les retours qui en sont faits ne sont pas mensongers. Je recommande vivement si votre aop se trouve sur le signal audio. Tout autre aop fait effet de bouchon pour moi comparé à celui-ci. Je n'ai pu tester leur SS2590 faute de place disponible dans mon dac.
Merci à audiophonics pour proposer ce produit comme tant d'autres qui permettent de mettre au point des équipements audio réellement époustouflants si on prend la peine de s'intéresser un peu.
Julien L.
Super câble à prix compétitif !
J'étais plus "Mogami" pour le biwire mais j'ai finalement craqué pour ce CANARE en 2*3.62mm² .. une taille peu commune mais au final pour alimenter des ATMOS j'ai pas vraiment besoin de plus !
Comblé par cet achat, le câble est d'excellente qualité de fabrication avec une gaine ondulée qui épouse les 2 câbles (à l'inverse du mogami qui est ultra droit), je ne dirais pas que c'est mieux, c'est juste un détail visuel :)
Pour l'écoute c'est parfait rien à dire. Utilisé avec des fiches bananes. Bref je recommande surtout à ce prix !
Philippe w.
La différence est clairement perceptible dès que le DAC est connecté.
Une qualité de son incomparable avec la carte son de l'ordinateur.
Les tonalités naturelles des voix sont tres bien restituées avec beaucoup de detail.
Un équilibre entre graves et aigus parfaitement respecté.
Le DAC s'installe tout seul, pas besoin de pilote.
Une excellente decouverte !
Pierre C.
Tissus Acoustique
Arriver en temps et en heure, identique a la description produits en deux mots rapidité et professionnalisme
Et bien sur 5 étoiles
Amicalement
Dominique S.
Idéal pour ajouter une entrée USB à un DAC qui est dépourvu
La sortie optique de mon iMac comporte un léger rumble. Ce DAC m'a permis d'utiliser l'USB pour alimenter mon DAC Linn via l'entrée SPDIF coaxiale, car il n'a pas d'entrée USB. Pas de driver nécessaire sur Mac. Pas de rumble! Fonctionne avec J River et encore mieux avec Roon (meilleure gestion du volume). Toutes fréquences audio HD FLAC reconnues. Son correct, un peu doux, légèrement moins de punch qu'en utilisant l'UPnP ou Roon via le réseau sur le Linn. Produit très bien fini.
剛史 大.
最初の喜び、開封時の落胆、そして2度めの喜び
・最初の喜び
納期は2ヶ月、と覚悟していたけど、10日後には日本の郵便局が届けてくれたよ。迅速に送ってくれてありがとう。
途中でくれたeメールの情報に安心できたよ。信頼できるチームだ。
・開封時の落胆
日本の関税が高すぎる。ポストマンに9000円くらい払った。次から日本向け納品書には500ドルって記載して発送してくれませんか?
開封したら、3mmサイズの白い発泡スチロールが1万個。誰が掃除する?それは私。
これは日本の"o-mo-te-na-shi文化"では起きない事案。改善してください。
・そして2度めの喜び
気を取り直して開封の続き。電源は100v-120v。これは嬉しい。
オリジナルは110v-230vのはず。100vの日本を気遣って変更してくれたんだね。日本の一般家庭では変圧しないと使えないからね。こういうサプライズは嬉しい。ありがとう、"omotenashi"
・音
昇圧して115vで聴いています。
押しのある音。音の粒にエネルギーを感じる。分離もいい。実にいい。強弱の自然さ。ちょっとスゴイぞ。
デジタルアンプの進化に感動しています。音楽がスローに聞こえる。これを何度も体験できる幸せ。
実は今回DACも変えたんだけどねー
anyway、この価格でこの音。優秀なアンプ。最高に満足しています。
良かったよ、ありがとう
Florin M.
OPA1612 AOP Double DIP8 (Unité) L'amplificateur opérationnel double TI OPA1612 profite d'excellentes caractéristiques techniques, permettant de très bonnes performances électriques...
Opa1612
Everything went very well, and products of excellent quality! They are professionals! Thank you! Audiophonics!
Florin M.
Opa 627
Nicolas L.
OYAIDE EXPLORER V2 Câble Haut-Parleur Cuivre 102 SSC 2x1.25mm² Le Oyaide Explorer V2 fait parti d'une nouvelle gamme de câbles d'enceintes en Cuivre 102 SSC, simplement composés de conducteur et d'isolant. La magie...
Bon cable
Achat d'un cable de 1,25 de section pour un ampli Denon Deol N11 et enceinte Eltax Shine 4 en remplacement d'un Norstone 1,5 .
Le son semble plus clair ,plus précis dans les basses et les aigu ,pas de fioriture c'est bon .A prés c'est pas 10 fois mieu (le prix est fois 10 par rapport au precedent ) mais je regrettes à aucun instant .Tres satisfait de cet achat .
Je ferais à nouveau confiance à cet marque .
Christian T.
Bon produit.
Bon produit. Intuitif et simple d'emploi. J'ai même réussi à l'appairer à des aides auditives.
Jean Paul T.
Audiophonics très performant pour la livraison et la gestion de la commande.
Très bon produit Dayton audio, Très simple, facile à utiliser, et très rapide. Evaluation de Hp et enceintes très facile. Produit très bien fabriqué.
Noel R.
date de livraison
date de livraison non respectée par collissimo avec des dates de livraison farfelues : 3 dates de livraison différente pour le même colissimo. Ce n'est pas le cas pour d'autres sociétés qui elles informent correctement leur client (collissimo est un transporteur a fuir).
Saphon I.
Belle reproduction sonore
Les instruments sont extrêmement détaillés digne d’un studio musical
Lui associer à un lecteur cd vintage de 1986 ou une station de radio.fm est un pur bonheur !
Serge P.
Qualité
petit Dac qui transforme votre PC en PC audiophile pour pas cher
István B.
breboistvan@gmail.com
Kiváló minőségű kábel. A vásárláskor éppen kifogyott a készlet, de megérte várni az új szállítmány beérkezését. Köszönöm a korrekt üzletet. Mindenkinek ajánlom a boltot. :)
eric p.
première écoutes
beaucoup de finesse dans le message ,mais je pense que dans quelque semaines il y aura plus de maturité après un rodage méticuleux,car pour l,instant c'est un peu brouillons, merci à la rapidité d' audiophonics par contre zero pour la poste a qui on paye pour une livraison au domicile et pas de chance il faut encore perdre du temps pour aller chercher son colis au bureau de poste et perdre 2h de boulot car eux ferme a 17h00.
Saphon I.
Ce fût un plaisir un bonheur !d’avoir un câble de haute qualité,les tonalités sont parfaites !les accords sont justes,les basses et les aigus sont bien stables ,sommercable dépasse mes attentes !
Ivo K.
Very satisfied with the wire construction and the final sound quality. I didn't expect such a good sound for that money.
Ivo K.
Câble USB Cuivre OFC Plaqué Argent PTFE Double Blindage Ø7.8mm Ce câble permet la confection de modèles USB audio numérique de haute qualité avec des matériaux nobles. Les conducteurs sont isolés...
Claudio c.
IBASSO IT00 Écouteurs Intra-Auriculaires Haute Définition Membranes Graphène Les écouteurs intra-auriculaires iBasso IT00 profitent d'une magnifique conception permettant une réception riche et dynamique, et ce à un prix abordable....
INCTOYABLE IBASSO
C"est le genre d"écouteur qui vous fait dire des la première écoute, pourquoi mettre 1000 euro dans des écouteurs haut de gamme.
Pour son prix c'est vraiment incroyable, tout y est un son vraiment excellent dans tout les registres, et surtout le plaisir d "coute est immédiat. Une petite perle pour son prix Bravo Ibasso.
Sreenath C.
WONDOM DB-DP11219 Module de Programmation SigmaStudio pour DSP Sure Wondom propose une carte de programmation compatible avec les DSP de marque Sure. Ce module s'avère indispensable pour programmer le DSP et gérer le traitement du...
Audiophonics Rocks
Best in class, got it delivered to India. Still not tested yet, but hope to do it soon!
Denis C.
Le chaînon manquant
Lecture parfaite des FLAC ultraHD 24b/192KHz d' Amazon Music HD depuis mon PC portable HP Pavilion X360 sur ma chaîne Harman Kardon A401 + 3A Adagio infini
https://m.facebook.com/story.php?story_fbid=3780039658731403&id=100001762192840
Ioannis P.
NCF always delivers
Another Furutech product up to spec. The brace seems to be the cheapest (all things considered) way to NCF-ise your power cable!
Jean-Philippe B.
Propre et efficace
Ces fiches banane sont de belle facture. Le maintien des câbles est parfait. Le maintien de la fiche est efficace grâce à la vis de serrage.
Ne pas oublier de se munir d'une clé six pans, non fournie, pour le serrage des câbles (raison pour laquelle 4* et non pas 5*)
Gerard G.
Substantial improvement of sound quality
Connected to my Intel NUC with Roon Rock it resulted in a serious improvement of the sound quality of my Roon environment. More dynamics, a bigger sound stage, a beter definition in the middle and high frequenty range and a more convincing base. A highly recommended tweak! Use also a high quality power cable for an even beter result.
Mick C.
Dommage, ne m'a pas convaincu
J'étais super de le recevoir. Mais j'ai pas eu de chance.
Couplé à mon DT 990 Pro 250 Ohms, j'ai eu trop de soucis, j'ai demandé un retour, Audiophonics a été au top!
En gros:
- En optique, bruits aigus dans le casque au démarrage, puis après ça partait. DAC limité à 24 bits / 96KHz en TosLink, ce qui n'était pas grave moi. Dance ce cas là, un très beau son, sur de l'écoute de musique classique je me suis régalé.
- En USB ou en SPDIF, donc en utilisant le module interne Amanero, la cata: bruits aigus au démarrage, mais en plus distorsion horrible sur le canal gauche, qui ne partait pas...
Dommage, les divers réglages en facade sont tops, mais pour un produit neuf, je préfère passer mon chemin. A noter qu'en cherchant de l'aide sur ce problème de distorsion, je suis tombé sur des posts de personnes aux US ayant eu le même soucis après quelques mois d'utilisation, contrairement à moi où c'est arrivé dès le déballage...
Tant pis, je passe à une autre marque, je ne le sent pas...
FREDERIC M.
Ne s'emboite pas facilement
Trop dur à clipser avec le cable optique acheté en même temps. heureusement, j'avais un autre cable optique avec une tête plus malléable sur lequel j' ai pu clipser l'adaptateur
NICOLAS C.
DYNAVOX X2000 Distributeur Secteur Filtré 5 Prises Schuko Fonction Master-Slave Le X2000 est le dernier distributeur secteur HiFi de Dynavox, complétant la gamme déjà composée du X4100 et X7000. Le X2000 en reprend les bases avec...
Consomme 20W en permanence
Oblige à éteindre manuellement la prise pour éviter une consommation électrique inutile, ce qui annule l'intérêt du dispositif maître/esclave.. Problème de conception ou de fabrication ? En tout cas ce n'est plus admissible sur aucun appareil électrique aujourd'hui, et encore moins sur un appareil haut de gamme. Retour à l'envoyeur.
Massimo L.
Ottimo accessorio
Comperato per completare l'auto-costruzione di un preamplificatore e schermare eventuali flussi magnetici dispersi del trasformatore toroidale di alimentazione.
Devo dire che è in acciaio abbastanza spesso e verniciato davvero bene, si presenta nero opaco,
Semplicemente perfetto per un toroidale da 30-40 VA.
spedizione per l'Italia rapida e imballaggi fatti con cura !
complimenti AUIDIOPHONICS !!
Massimo L.
Fanno il loro lavoro
Non c'è molto da dire su un fusibile
Massimo L.
Ottima scheda
Ne ho acquistati due per avere due alimentazioni separate, una a 5 Volt e una a 15Volt.
La scheda è realizzata bene, buoni condensatori e stabilizzatore montato su dissipatore.
Di notevole qualità le morsettiere per il collegamento delle uscite/ingessi
Il prezzo è assolutamente adeguato alla qualità / prestazioni della scheda.
spedizione per l'Italia in tempi davvero rapidi e imballaggio davvero MOLTO BEN FATTO.
Complimenti AUDIOPHONICS
Massimo L.
Câble d'Alimentation Jack DC 5.5 / 2.5mm Mâle vers Fils Nus 18AWG 30cm Ce câble dispose d'une part d'un connecteur Jack DC 5.5/2.5mm mâle et de deux fils dénudés d'autre part. Un câble dédié à l'alimentation de vos appareils disposant de ce type de...
Cavo di buona qualità
Davvero ottimo, buona sezione del conduttore interno e ben costriuito
Massimo L.
Geniale
Avete mai provato a montare un potenziometro su un pannello e cablare insieme i cavetti schermati che devono andare al preamplificatore ?
Con questa semplicissima schedina è tutto molto più semplice, pulito e ordinato
Davvero molto comoda, per la sua spesa ne vale davvero la pena
Spedizione per l'Italia in tempi davvero molto rapidi, ed imballaggi fatti davvero con cura : complimenti AUDIOPHONICS !
Massimo L.
NICHICON KW Condensateur Électrolytique Audio 50V 6800µF La série KW est une gamme de condensateurs électrolytiques spécialement conçues pour une utilisation audio. Ils offrent en effet d'excellentes...
Ottimo componente
Acquistato insieme a molti altri componenti per costruirmi due alimentatori lineari audio,
Spedizione per l'Italia in tempi velocissimi e ottimi imballaggi : complimenti audiophonics
Massimo L.
Cavo di ottima sezione
Cercavo un cavo di alimentazione per la mia DAC di sezione e lunghezza adeguata: TROVATO!
Per me la lunghezza è perfetta, non mi occorrono 2 metri di cavo, piuttosto visto che la DAC assorbe 1 Ampere cercavo un cavetto con una sezione adeguata a portare questo carico.
Devo dire che è perfetto.
Spedizione per l'Italia in tempi molto rapidi, e imballaggi fatti davvero con cura !!
Complimenti Audiophonics
