François G.
Samuel A.
What a surprise!!!
Frederic A.
3E AUDIO 260-2-29A PFFB
Fonctionne...
Avis clients - Il y a 19454 avis.
Richard P.
Très bon câble.
Merci à Audiophonics pour vos précieux conseils.
Avec des connecteurs RCA ELECAUDIO TE-RC85S le son est très aérien avec une belle assise. Pas fatigant sur de longues écoute.
Très bon câble.
Maciej Z.
MUNDORF ACW115BK Fil de Câblage Cuivre / Argent / Or PTFE 1.8mm² Ce fil de câblage haut de gamme Mundorf ACW115BK offre une excellente qualité de fabrication pour une conductivité maximale. Ainsi, ses conducteurs sont fait...
I purchased 1.8mm and 0.79mm Mundorf Angelique to rewire my Snell E3 speakers.
Original Snell cable is nothing special, possible 12AWG twisted multi strand copper.
Mundorf is very stiff and hard to work with, and very hard on speaker connectors, so care ash to be taken while moving drivers with soldered cable.
It's also very hard to domestically twist 2 runs of the cable, as it twist more at the start and then further it become uneven, while if you twist more, you will apply to much pressure on the PVC so it breaks.
After 20h of initial listening I was hoping for more, but nothing changes.
The sound is dull, lacking definition and resolution, with poor soundstage. Everything became closed in. There is not much air and ambience, or textural richness. Tones are ending quicker then they should be without any pleasant overtones.
I like smooth sound too, but it must not lack definition, and clarity. This is nowhere near smoothness. It's too polite. Perhaps it would work slightly better on extremely bright, and harsh system, but if your system is neutral you should choose something else in my opinion.
When it comes to Audiphonics service, its one of the best, as usual. Great communication, great choice, reasonable pricing and fast delivery. 5 stars for the service. 1 - 2 stars for this cable.
christian w.
XDUOO TA-66 Amplificateur Casque / Préamplificateur à Tubes 6N2 6N5P xDuoo nous présente avec son TA-66 un amplificateur casque / préamplificateur à tubes. En effet, le TA-66 se dote de deux tubes : un tube 6N2 pour le...
Great value tube amplifier.
Super fast delivery to the UK. Actually quicker than me ordering in the UK
Daniel D.
super cable secteur
J'ai tiré 2 lignes séparées de mon tableau électrique à chacun de mes blocs mono avec ce Tornado sans me ruiner. Gain évident à tous niveaux et superbe musicalité avec prises Iego 8085 pour un son un peu chaud, rapport qualité/prix hors norme. Il me restait quelques mêtres de chute que j'avais remisé à la cave. Venant de recablé différemment toute mon installation, je me suis dit qu'il ne coutait rien de faire un essai avec ce reste de Tornado pour alimenter une source (ce que certains déconseille). J'ai constitué un CS avec d'un côté une schuko Viborg cuivre/or/argent et de l'autre une IEC Oyade C004. EH bien!!! après 60 à 70 Heures de rodage le mariage fonctionne à merveille avec toujours cette superbe rapidité/musicalité et belle ouverture. Je valide à 100% la polyvalence de ce cable. Une vraie réussite, à ce tarif ce câble et une vraie pépite... foncé!
Stefano P.
Addicting!
I just replaced with it the FP-3TS20 power cord feeding my pre, with immediate results! Dead silent, with a simply unheard clarity over the full range of frequencies. Unexpected and addicting.
Hocine H.
Incroyable.
J'étais un peu sur la réserve concernant le monobrin, je l'ai utilisé pour recâbler le woofer de mes enceintes et ce câble après une dizaine d'heures est d'une précision et d'une délicatesse que je n'aurai imaginé. Très belle surprise.
Hocine H.
Belle découverte
Utilisé pour recâbler le tweeter des enceintes, ainsi que le bornier, ce câble est une grande révélation. Facile à travailler et d'une précision redoutable, les tweeters on une nouvelle vie.
ANTONIO M.
3E AUDIO 480-1-29A PFFB Module Amplificateur Mono Class D Symétrique TPA3255 1x480W 2 Ohm Ce module amplificateur 3E Audio 480-1-29A est un module d'amplification mono class D symétrique basé sur une puce TI TPA3255. Ce module...
baja corriente
Es mucho peor que la 3e PFFB stereo que conservo, compré 2 mono PFFB con fuentes de alimentación lineal de 300va cada no reguladas...un desastre, no tenia ni graves ni dinámica, creo que esta internamente puenteada mal el mono de manera que si la impedancia mínima de la 3e estéreo PFFB ya son 4 ohm y necesita cajas muy facules tipo mark audio, Klipsch...la monk es para IMPEDANCIA MINIMA de +8ohm (si) por tanto con casi todas las cajas sonara sin graves ...pero si tus cajas son de impedancia mínima 8ohm, compralas, mide genial
ANTONIO M.
mejor que purifi
Tuve una PURIFI con la desastrosa SMPS hypex y sonaba estéril y enclenque. La devolví. -purifi con fuente de alimentación lineal hubiera sido perfecta sin embargo pero no se hacerlo porque es multivoltaje - . Encargué este módulo por sus buenas medidas aprebachando que la impedancia mínima de mis cajas no es demasiado baja -este no es estable a 2 ohm como purifi- pero como es un solo voltaje se le puede meter fácil un toroidal y una fuente no regulada lineal...resultado: con un previo realmente cálido/transparente como el perfecto Glasshouse TVC, la resolución es infinita el detalle el realismo , calida valvular sin ruido pero con cuerpo con grip emocionante ¡Mucho mejor que la típica Purifi o NCORE con SMPS hypex -probablemente con una SMPS Meanwell hubiera sido mucho mejor+! Brillante suena mejor -con un previo TVC - que la clase A
florent n.
SHANLING MTW200 PLUS Écouteurs Intra-Auriculaires Sans Fil IEM Dynamiques Ø10mm 32Ω 112dB 20Hz-20kHz Avec les MTW200 Plus, Shanling nous présente des écouteurs intra-auriculaires sans fil. La marque a ici opté pour un haut-parleur dynamique de 10mm avec...
impressive
remarkably light, side independent (left can be right and vice versa, and once you take them out of the box, it resets the earbud put in the left socket as the main earbud), they sound great. Great bass extension while keeping great clarity. No buzzing sounds from bluetooth. Compared to quality wired iem, they sound just as good. The transparency/ANC modes while "available in the voice menu" do not work but who cares? Cherry on top, a beautiful case
Valéry H.
AMPLI DAC CASQUE
Excellent ((petit)) Il lui manque juste une tél.
Comme ampli approchant les " AUDIOPHILE " Il a bien sa place.!..
michel f.
Filtre Jack DC 15V à Supercondensateurs vers jack DC Ce filtre jack DC 15V à supercondensateur vous permet d'obtenir une alimentation propre pour vos équipements et appareils Hi-Fi grâce à 6...
Attention
filtre qui ne convient qu'à une tension strictement de 15v
Maurizio I.
NEOTECH STDCT-16 Fil de Câblage MultiBrins UP-OCC PTFE 1.3mm² Le fil de câblage STDCT est un câble de très grande qualité multi-brins avec conducteur en Cuivre UP-OCC pur à 99.99998% et isolation PTFE....
Avevo Cardas, ho ricablato le mie magnepan con Neotech e la differenza è disarmante! piu volume,piu profondità d'immagine,più naturalezza,più armoniche,non credo ci sia cavo migliore di questo!
Maurizio I.
NEOTECH STDCT-14 Fil de Câblage MultiBrins UP-OCC PTFE 2mm² Le fil de câblage STDCT est un câble de très grande qualité multi-brins avec conducteur en Cuivre UP-OCC pur à 99.99998% et isolation PTFE....
ho rifatto totalmente il cablaggio interno delle mie Magneplanar3.6 insieme i crossover. Che dire,suono pieno e dettagliato naturalezza e profondità d'immagine pazzesca.
Jacques L.
Câble modulation Audiophonics
Comme l'avais déjà signalé certain acheteurs le connecteur coté ampli est de mauvaise qualité et ne s'enfiche pas sur de nombreux appareils.
Remboursement demandé et effectué sans difficulté.
Gary H.
Excellent, slim profile chassis
Well constructed and finished to a high standard.
pascal B.
IFI AUDIO ZEN AIR PHONO Préamplificateur Phono MM/MC Avec le Zen Air Phono, iFi Audio propose un préamplificateur phono abordable et pour autant performant. Il vous permettra de brancher votre platine vinyle en...
petit preamp phono
excellent petit préampli phono, testé sur son entrée MM
son détaillé et clair ; grand silence sur les blancs grâce probablement à la batterie intégrée et à loa fabrication soignée
Hans Peter N.
MUSES8832E-TE1 AOP Double SOP8 (Unité) L'amplificateur opérationnel MUSES8832E est un AOP double au format SOP8 optimisé pour les applications audio haute fidélité et professionnelles. Cet...
Replaced an SGM358
Hey there,
I replaced an SGM358 in my FIIO DK03. I am very pleased with the sound now. Thanks Audiophonics for the great service.
Hocine H.
Qualité optimale.
C'est cher au premier abord, mais une fois en main, puis installées on comprend pourquoi on met le prix. Une qualité irréprochable, une installation agréable, un maintien efficace et un son très neutre. Je tenais à remercier audiophonics car avec toutes les commandes que j'aie passée, ils ne se sont jamais trompés sur un article. un grand bravo et merci pour ce que vous nous proposez.
Pavol B.
SMSL PS200 DAC ES9039Q2M USB SPDIF Bluetooth 5.0 32bit 768kHz DSD512 MQA-CD Le PS200 de la marque SMSL est un petit DAC compact qui dispose de composants de qualité. Il dispose d'une puce DAC ES9039Q2M, d'une interface USB XMOS XU316 ainsi que...
New BEST DAC under 100€
A few words about this little plastic DAC. First of all - the delivery was quick, but unfortunately, even though the package included 10 meters of network cable, they did not fill it with foam, so the paper box arrived completely destroyed. Fortunately, nothing happened to the DAC.
Now to the DAC itself. It's really a single, cheap-looking plastic box with plastic buttons, taking it apart would probably mean destroying the box. It looks really cheap in that sense. The second thing is what's in there and how it plays. And here the game changes completely. Those who saw it disassembled claimed that this is a really seriously made DAC, with quality components and a good architecture. Sound - I compared it with my flagship DAC, built on top of the ESS 9018SE chips, as well as with the NOS DAC built on the Wolfson chip, and with the R2R DAC, although "only" DIY. What I heard got me. It's true that the sound didn't have as much layering and harmonic richness as the two ESS9018SE chips, but that DAC was 20 times the price. On the other hand - the smoothness on the SABER is incredible, the richness of details, the light naturalness, the strength in the bass and yet so deep, the dynamics did not lag behind... But what got me the most was that I could literally hear it playing silently. Silence around the instruments, around the singers, the empty space around them literally played. The space is the same - at first glance more stereo than in depth. But if you listen closely, it's there, it's just not added forcibly. I still have to come back to the price, how much it costs. SMSL probably really invested mainly in the interior, as in the packaging. Although a risky purchase for me, I didn't know what I was getting into. But I'm glad I did. I love the sound of it. He is amazing. And for €100!!!!! I RECOMMEND!!!!
Istvan M.
Weak mechanics...
...or I was just unlucky. I bought two for my monoblocks and while one socket works perfectly, the entire "inner workings" of the other one, i.e. the part with the contacts, pushes backwards when I try to plug in a cable , and of course there is no contact - for some reason the middle part of this socket is not attached correctly or not at all to the sockets frame. It's completely unusual from Furutech.
Génial !!
Simples, bien conçues et facilité de mise en oeuvre. Le signal est très bien respecté. Excellente fiche.
Excellent coax
Il fait jeu égal avec un coax. Diy polarisé équivalent a plusieurs centaines d' euros.
Belle surprise et pour le tarif, c' est une aubaine !
Monte avec des switckraft RCA, beau combo ! A essayer !
900M-T-0.8D Panne de Fer à Souder Ø0.8mm Cette panne de fer à souder bénéficie d'une longue durée de vie grâce à sa haute qualité de fabrication. Elle vous permettra d'effectuer vos soudures pour vos projets DIY.
Gérard M.
WONDOM PS-BC12112 BCPB3 Module BMS d'Alimentation Chargeur de Batteries 5x Lithium 18650 Le Wondom BCPB3 est un module de gestion et protection de batteries, profitant des performances et de la fiabilité des modèles précédent tout en...
Très bien.
Fait parfaitement le job pour alimenter un préamplificateur phono. MAIS attention le set de câbles et leds n'est pas livré avec comme indiqué précédemment et il est quasi indispensable.
Renaldo V.
Elipson 1400
envoi très rapide Merci
pour une mise à jour sur des filtres ( Elipson 1400 )
amélioration garantie
Renaldo V.
JANTZEN AUDIO COMPACT MKT 001-8040 Condensateur MKT Axial 160V 3.3µF Les condensateurs Compact MKT de Jantzen Audio sont fabriqués avec un film polyester métallisé de la lus haute qualité possible. Jantzen Audio est...
Elipson 1400
Renaldo V.
JANTZEN AUDIO COMPACT MKT 001-8020 Condensateur MKT Axial 160V 2.2µF Les condensateurs Compact MKT de Jantzen Audio sont fabriqués avec un film polyester métallisé de la lus haute qualité possible. Jantzen Audio est...
Elipson 1400
Une pépite
Je rejoins complètement les avis précédents. Pourtant câble fait cheap... Le bleu un peu clinquant aussi. Mais une fois installé, c'est un remède miracle.
OYAIDE SS-47 Étain à Souder Soudure Argent 4.7% Cuivre 1.7% Flux 3.3% Ø1mm 50g La SS-47, la soudure haute fidélité d'Oyaide, permet la réalisation de soudures de grande qualité. Celle-ci contient de l'étain pur 4N...
Mon choix désormais.
Validey après avoir essayé Mundorf 10% et dinavix 4%( qui s' en sort très bien).
Les soudures sont belles, et le prix reste correct.
Parfaite
Excellentes fiches RCA, simple efficace et agréable a travailler et au rendu sonore
AUDIOPHONICS MUSES8920A AOP Double DIP8 (Unité) Audiophonics est fier de vous présenter son AOP MUSES8920A au format DIP8. Cet AOP double est basé sur une puce authentique JRC (Nisshinbo Micro Device Inc). Il...
Mouais
J'ai voulu essayer, je préfère les JRC 1612.
Je n' enlève pas d' étoile car c' est une affaire de goût et ils sont très bien construit.
Brice D.
TUNG-SOL KT120 Tubes de Puissance (Quad Appairé) Le tube Tung-Sol KT120 dispose d'un plateau de dissipation de 60W, faisant de lui le tube le plus puissant de la famille des 6550/KT88/KT90. Une paire de ces tubes en...
Rodage KT120
J'utilise ces tube sur un Jadis DA88S et je préfère vous prévenir que le rodage est très long.
Prévoyez minimum 100 heures avant d'avoir une idée et 500 heures pour un rodage total.
Très bon tube si vous avez la patience d'attendre.
AECO AMI-1060G Connecteurs XLR 3 Pôles Mâle et Femelle Cuivre Tellurium Plaqué Or Ø12mm (La paire) Cette paire de connecteurs AECO AMI-1060G est composé d'un connecteur XLR mâle ainsi que d'un connecteur XLR femelle. Ces connecteurs XLR 3...
Comparativement aux étiquettes link, elles se soudent facilement et sont super bien conçu. Très transparentes, elles laissent le message via le câble intégre !
Superbes fiches aux rqp excellent
Elom G.
Top avec une très bonne réputation.
Testé chez moi dans un fosi v3, le son était bon et bien équilibré; pas grand chose à lui reprocher.
Mais pour le prix je m'attendais à un effet vraiment wahoo !
Bref, bon app très clair et équilibré mais pour moi un peu cher pour le résultat obtenu.
Elom G.
Cet aop bénéficie d'une très Bonne réputation.
Mais, testé chez moi dans un fosi v3, je n'ai pas été convaincu. Le son est doux et musical, ça c'est sur ! Mais les graves manquais de netteté et étaient même un peu brouillons.
Pour le prix, je ne suis pas convaincu.
Elom G.
TI LM4562NA/NOPB Amplificateur Opérationnel AOP Double DIP8 (Unité) Le Texas Instruments LM4562NA/NOPB est un amplificateur opérationnel (AOP) hautes performances 2 canaux, intégré dans un boîtier PDIP8. Cet AOP ultra...
très bon rapport qualité prix
utilisé dans un fois v3, cet app est assez surprenant. Le son est très bon pour son prix. Les graves sont bien tenus, les aigus corrects sans trop piquer. Il y a surtout un dynamique de fou, à la fois très agréable et peut être parfois un peu fatiguant.
Bref, pour le prix, ça vaut vraiment le coup de les essayer. Je recommande.
Elom G.
BURR BROWN OPA2604AP AOP Double DIP8 (Unité) L' OPA2604AP est un AOP qui combine la précision et le faible bruit de transistors bipolaires avec la vitesse et la qualité sonore des JFETs. Cela permet...
Testé dans un Fosi V3, c'est op font un peu mieux qui ceux fournis d'origine avec l'ampli, mais sans être exceptionnels. Les graves sont correct mais les aigus un peu métalliques. Le tout est un peu fatiguant; en tout cas pas très doux ou musical. Je ne les retourne pas vu le prix, mais ils ne me servirons à rien.
Elom G.
AUDIOPHONICS WIRE Câble de Modulation RCA Stéréo Cuivre OFC Plaqué Or 75cm La gamme Audiophonics Wire propose une sélection de câbles abordables mais pour autant performants, assemblés à la main dans nos ateliers, en France....
Bon câble avec un bon équilibre. Je n'ai pas pu le comparer au canard star quad qui est actuellement en rupture.
En attendant le réapprovisionnement pour faire la comparaison, je suis plutôt satisfait de ce câble.
Elom G.
Moyen
Ce câble est un bon rapport qualité prix; mais vu l'incidence du câble de modulation sur une installation, il vaut mieux mettre un peu plus cher pour quelque chose de plus équilibré. Pour 40euro le Audiophoncis à base de Mogami Neglex W2549 a été pour moi un meilleur choix.
Elom G.
Je rejoins la multitude de commentaires élogieux sur ce câble. Après avoir essayé beaucoup de câbles enceintes (audioquest, elecaudio, triangle, real cable, oehlbach), j'ai trouvé mon bonheur avec ce câble que j'ai adopté pour toutes mes installations audio, en simple et en bicablage avec la version 4x4mm2
Elom G.
TANCHJIM ONE Écouteurs Intra-Auriculaires IEM Dynamiques Ø10mm 126dB 16Ω 7Hz-45kHz Ces écouteurs intra-auriculaires Tanchjim ONE, plus qu'abordables, sont dotés de drivers dynamiques de Ø10mm ainsi que d'un design de...
Ecouteurs de bonne qualité, sans prétention. Le son est bien équilibré; graves médium et aigus sont bien restitué. Pas de fatigue sur la durée d'écoute.
Après, ce sont des intra-auriculaires donc pas de sessions d'écoute trop longues ou pas à volume élevé, si vous voulez préserver votre audition.
Les écouteurs tiennent bien dans les oreilles grâces aux embouts de différentes tailles fournis.
Très bons conseils de la part d'audiophoncis
Serge G.
DYNAVOX AUX-S PRO Commutateur Sélecteur Audio pour Entrées / Sorties RCA Noir Le commutateur Dynavox AUX-S Pro permet de commuter entre cinq appareils audio stéréo en entrée et deux appareils stéréo en sortie, sans avoir...
Decu
Claquements a la mise sous tension. bruit de moteur pendant la lecture.pas de clavier numérique sur la télécommande . obligé de faire défiler les chansons . vraiment déçu
Sandy G.
AUDIO-GD MASTER 3A Amplificateur de Puissance Pure Class A Symétrique ACSS 2x180W 4 Ohm Le Audio-GD Master 3A reprend l'excellente base du Master-3, cette fois-ci dans un modèle en pure Class A capable de délivrer une puissance de 2x180W sous 4 Ohm....
MUSICALITE ET PRECISION
Une belle expérience, que l'écoute de ce magnifique amplificateur.
Raccordé à un préampli MUSICIAN Monoceros, le résultat est excellent. Le différents registres musicaux sont présents, et fouillés, sans tomber dans un coté "ultra". La musique est belle, douce mais punchy à la fois...Un ampli a tube (j'en ai un) se justifie t il encore, au vu de l'évolution des "transistors" ?
IBASSO DC06PRO DAC / Amplificateur Casque Portable 2x ES9219C 32bit 384kHz DSD256 MQA 16x Ibasso dévoile une nouvelle version de son DAC / amplificateur casque portable DC06, le DC06 Pro. Compact, il intègre 2 puces DAC ES9219C et des boutons de...
Excellente qualité audio et finition du produit
Mon meilleur dongle DAC, et cerise sur le gâteau, il chauffe peu (à peine tiède).
Cyril J.
AUDIOPHONICS PSU-HC Alimentation Linéaire Régulée 5V 5A 60VA Cette alimentation linéaire régulée PSHP permet de disposer d'une tension et d'un courant de sortie de 5V 5A propre et stable. En sortie on retrouve deux...
Node2021
Respire la qualité
Cyril J.
BEATECHNIK x LHY AUDIO Kit Module Alimentation Filtrée pour Bluesound Node X / N130 Ce kit de module d'alimentation filtrée est conçu par LHY Audio à la demande de Beatechnik et est destiné aux produits Bluesound Node X et N130.
Node 2021
Changement de l' alimentation en une demi heure enfantin
Restitution sonore transcendai tout est plus naturel équilibré aucun regret
Claude T.
IAN CANADA TRANSPORTPI DIGI II Module Interface Audio Numérique Ultra Faible Jitter Avec le TransportPi Digi II, Ian Canada nous propose une belle évolution de leur interface audio numérique tout-en-un haute performance pour Raspberry Pi. Ce...
grande évolution
Par rapport a la version précédente, il y a une nette évolution dans la qualité du son. De plus en mode coax les parasites emi ont disparu.
Waouhhhh !
Le câble est rigide mais ce n'est pas une barre de fer non plus.
Il est suffisamment souple pour relier mon transport CD HDG à mon convertisseur HDG qui se trouve à côté de lui.
Le diamètre du câble est conséquent, la finition est magnifique, les fiches sont de très haut niveau et serties de caoutchouc à l'extérieur.
Livré en plus dans une jolie housse, ça fait pro !
Le plus important, le son : waouhhhh ! essais comparatifs avec plusieurs câbles numériques 75 ohms, il se compare à l'unanimité (de mes copains d'abord et autres individus ensuite) avec les plus onéreux, les plus réputés, que rigoureusement " ma mère " m'a demandé de ne pas nommer ici...
Bravo à Audiophonics pour ce superbe montage Haut De Gamme à un prix démocratique, livré en 48 heures.
Connecteurs RCA Plaqué Or Ø8mm (La paire) Gris Ces connecteurs RCA de belle qualité profitent de contacts plaqués or, assurant une bonne conductivité électrique et résistance à...
Excellentissime !
Voilà une paire de connecteurs RCA à faible coût et de très haute qualité. Isolant PTFE Téflon, ça ne fond pas quand on soude.
J'ai pu faire plusieurs câbles de longueurs différentes grâce à ces fiches cinch montées sur le fameux câble SOMMERCABLE EPILOGUE.
Diamètre et qualité, tout est ok.
Merci Audiophonics, livraison en 48 heures.
