Fredrik B.
Fredrik
yann r.
6 moi utilisation
Michel V.
Musical et costaud !
Avis clients - Il y a 19152 avis.
M A.
LHY AUDIO Module DAC Symétrique 2x PCM1794A I2S 24bit 192kHz Ce module DAC symétrique de belle, simple mais de belle conception, se base sur l'intégration d'une paire de puces de conversion numérique / analogique...
great dac, sounds very nice.
I have played the pcm 1794A dac for about two days now and am very happy with it, plays very nicely and quietly with a nice stereo image.
a side note, I have to upsample with an ian canada FIFO MA 1.5 and ian canada isolator II between a raspberry (volumio as software) otherwise no sound will come out.
otherwise a great dac.
Victor R.
VIBORG VF503 Connecteur IEC C15 Cuivre Pur Ø19mm Le connecteur IEC C15 Viborg VF503 offre une excellente qualité de conception et vous permettra de concevoir des câbles secteur high-end pour alimenter correctement...
satisfied with the upgrade
I've purchased together with VIBORG VE503 Schuko Power Connector Type E/F Pure Copper Ø19mm, and install it on an Elephant cable, to replace the power cable of a power amplifer. The results are: more defined bass, overall natural musical sound, wormer, separated voice, distinctive instruments. A better stereo imagine and increased soundstage on all axes. Very satisfied with the upgrade
Victor R.
VIBORG VE503 Connecteur Secteur Schuko Type E/F Cuivre Pur Ø19mm Le connecteur Schuko Viborg VE503 offre une excellente qualité de conception et vous permettra de concevoir des câbles secteur high-end pour alimenter correctement...
I've purchased together with VIBORG VF503 IEC C15 Pure Copper Connector Ø19mm, and install it on an Elephant cable, to replace the power cable of a power amplifer. The results are: more defined bass, overall natural musical sound, wormer, separated voice, distinctive instruments. A better stereo imagine and increased soundstage on all axes. Very satisfied with the upgrade
Helmut M.
DAC SMSL SU-1
works perfect for me
tested with WIIM Pro optical and coaxial up to max speed (24-192) to DAC
also testet Raspi with RoPieeeXL USB out (24-192) to DAC
no problems.
low power consumption of about 250 mA at 5V max
Helmut M.
Adaptateur Convertisseur SPDIF Optique Toslink/Coaxial vers Toslink/Coaxial Pratique, ce petit convertisseur permet de transformer un signal audio SPDIF optique Toslink en coaxial, et inversement. Il supporte les technologies Dolby, DTS, AAC et PCM...
Audio converter
works perfect in both directions (optical to coaxial) and vice versa
testet up to 24 Bit / 192 kHz
great product
Gerben Z.
Canare L-2T2S
great cable as an interlink between my marantz cd player and my sonneteer alabaster amplifier
AUDIOPHONICS Câble d'Alimentation Jack DC 5.5/2.5mm vers GX16 Cuivre OFC pour Alimentations Audiophonics LPSU100 1m Ce câble d'alimentation Audiophonics, assemblé en France dans nos ateliers, se compose d'une part d'un connecteur Jack DC 5.5/2.5mm et d'autre part d'un connecteur...
sur une alimentation dac marche très bien
c'est un cable que j'ai monté moi mème manque la viborg je rajouterais après l'autre prise a tout l'air d'etre une electerco
ca cable ouvre le son les mediums et les timbres sont manifiques, bref il est musical
un très bon prix que fait audiophonics vu le prix ders connecteurs, le cable lui meme coute 5€ mais il assure avec une bonne tresse de connection que j'ai connecté coté source
Bastien S.
Bof bof...
Troisième main de piètre qualité.
Tout fonctionne mais les matériaux sont cheap, en particulier les systèmes de rotules qui permettent de positionner les pinces : deux plaques de métal fin, percées à chaque bout, prennent les 2 rotules en sandwich, et une vis à papillon au milieu permet permet de bloquer l'ensemble...
Ok, mais cette plaque est un peu trop fine, pas assez rigide, le serrage est donc tout juste suffisant et guère commode.
Et après quelques utilisations, ces plaques se tordent et serrent donc de moins en moins les rotules.
La lampe loupe n'est pas mauvaise, mais éclairage un peu juste.
C'est décevant, mas à quoi peut-on vraiment s'attendre à ce prix. Encore un de ces objets de qualité médiocre, et qui deviennent donc vite pénibles voire inutilisables.
Je serais prêt à mettre 4 ou 5 fois ce prix pour avoir de la qualité. Pas cher s'avère toujours finalement trop cher.
Un câble de fort diamètre mais souple et maniable. Le téflon entourant chaque groupe de brins de chaque section colle bien aux fils. Pour s' en débarrasser, je le coupe délicatement dans la longueur et c' est plus facile a défaire.
Aux premières écoutes, bof, bof, rien de transcendant, voir plat...
Mais déjà une dizaine d' heures de chauffe et il commence à démontrer son potentiel très neutre, offrant une belle ouverture, une très bonne image stéréo, la musique est très proche de ce qu' elle est sensée être.
Je le recommande , surtout a ce tarif !
MICHEL B.
Les fiches "Neutrik" sont solides et parfaitement blindées. C'est parfait !
Alain C.
ISOACOUSTICS OREA INDIGO Absorbeur de Vibrations Ø58x33mm (Unité) Les absorbeurs de vibrations de la gamme Orea de chez IsoAcoustics éliminent les vibrations parasites et offrent une plus grande clarté et précision sonore....
Le grand son !
Posés sous un lecteur CD Esoteric (HDG), ils ont tout simplement transcendés la lisibilité (plus de détails) et l'équilibre (plus de grave)
Après bien des essais (pieds ACTYNA, pieds sorbothane, pointes et contre pointes HDG,...) j'ai enfin trouvé la liaison parfaite avec le meuble support !
Bernard G.
LUDIC KRATOS Distributeur Secteur Filtré 6 Prises Filtrées + 2 Prises Directes Schuko Noir Le Ludic Kratos est un distributeur secteur avec section filtrée extrêmement performant, capable de soutenir la comparaison avec les produits les plus haut de...
trés bon rapport qualité/prix
patience récompensée
MICHEL B.
Magnifique restitution
Ce câble respire la qualité de fabrication et la qualité musicale.
L’écoute sur platine CD Marantz SA-10 est magnifique. Tout est parfaitement transmis sans distorsion. Somptuosité des timbres sans agressivité, respect de la réponse impulsionnelle, dynamique intégralement transmise, plan sonores de toute beauté.
Ce câble est bien meilleur que beaucoup de grandes marques qui affichent des prix délirant. Si vous avez du matériel de haut de gamme ou même de moyenne gamme, n’hésitez pas foncez, vous ne le regretterez pas, c’est une révélation.
Jacques B.
VIABLUE TS2 Fiches Banane Plaqué Or Ø5mm (Set x4) Les fiches bananes Viablue TS2 utilisent un système de raccord par tube pour assurer un contact maximal avec les borniers d'enceintes. Lors du branchement de la fiche...
Belle qualité !!
Belle qualité de produit. Serrage efficace du câble et excellent contact dans le bornier. A recommander.
Nicolas V.
SMSL D400EX DAC 2x AK4499EX AK4191 XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Avec son DAC D400EX, SMSL revient sur le devant de la scène en adoptant deux puces DAC haut de gamme AK4499EX et une puce AK4191 de chez AKM. Associée à des...
Je suis d'accord avec vous M.Guillaume S.
Surtout que votre DAC est actuellement chez moi....
Même config à peu près. Magnepan mais ASR ref 110...
je compare avec mon benchmarck mark 3 à 2500€ actuellement.
Bcp plus de détails dans les aigus.
mais BEAUCOUP plus.
Par contre une perte en effet de musicalité dans le médium et bas.
Je trouve en effet que le rapport Q/P est fou.
Mais je trouve l'écoute benchmark quoique moins précise, plus reposante et musicale.
En effet, audio research à manier avec des pincettes...
Merci à audiophonics encore et toujours
Raphaël B.
C'est la deuxième fois que je fait appel à ce service. La première fois pour un transfo très compliqué et cette fois beaucoup plus simple. A chaque fois les résultats obtenus on été conforme à mes attentes. Excellent rapport qualité prix, le délais d'attente est un peu long mais il faut considérer que c'est du sur mesure
Fiche Banane Cuivre OFC Plaqué Rhodium Ø5mm (Set x4) Cette fiche banane offre un excellent rapport qualité / prix. Conçue en cuivre OFC 4N avec plaquage rhodium, elle assure une très bonne conductivité...
Presque parfaites
Très esthétiques et de bonne fabrication.
Seul petit reproche, les vis de serrage sont un peu court pour du câble de faible section (2mm). Il ne faut donc pas trop serrer au risque de voir la vis passer a l' intérieur de la fiche. Sinon pour de plus grosse section, c' est très bien.
M A.
ACCUSILICON AS318-B-451584 Horloge Ultra Low Jitter 45MHz Cet oscillateur crystal à bruit de phase extrêmement bas est conçu pour les équipements de studio professionnels ainsi que pour les appareils de préccision électronique.
beautiful clocks for relatively little money.
I've had the clocks in for two days now (ian Canada FIFO MA 1.5) and I must say the sound has gotten better. do you still have the standard clocks in it, these are a nice upgrade.
GUSTARD C18 Horloge Maître OCXO 10MHz Argent Cette horloge externe Gustard C18 hautes performances est idéal pour assurer une parfaite synchronisation des signaux audio numériques et ainsi améliorer la...
fais le job mais trop cher
Dans le domaine des horloges il y a tous les prix
Celle la permet de controller 2 source on mode carré ou sinusoidale j'utilise les deux une sur mon transport gustard (qui lui n'est pas cher) et aussi sur mon switch
pas 5 vu le prix
Première écoute...
Je viens de remplacer le Real câble élite 500 (5mm2, installé en bi cablage et bi amp. A+B) par ce mogami 3082, entre un Yamaha as700 et des elipsons pf14f
Meilleur tenue des basses, me semble t il, autant de détails et beaucoup de ressemblance sur le rendue sonore.
Cependant mon précédant câble me donnait ce résultat, très bon pour moi, au bout d' une centaine d' heure.... Ce mogami est donc très prometteur..
Je le recommande, surtout sur un système un peu trop basseux.
Laisse passer le son
tes belles performance par contre si le son est pas terrible cela ne pardone pas !
Au debut je préférait le bornier pur cuivre et finalement je préfère celui la après avoir équilibré mon systeme il va plus loin
top
Sur mes enceintes très beau son
nickel
sur mon ampli le son passe très bon son et super prix
Sékou K.
Meilleur câble secteur testé. Couplé aux Oyaide M1 F1 le résultat est stupéfiant.
Tout simplement, ce câble se fait oublier. Il ne sera jamais le maillon faible d' un système. En remplacement d' un norstone rca, il est plus ouvert e neutre, arrangé ainsi le signal e les informations. Je le recommande a 100%.
Claudio c.
XDUOO X2S Baladeur Numérique DAP 24bit 192kHz DSD128 xDuoo propose avec son X2S un baladeur numérique particulièrement compact et pratique, offrant cependant de très bonnes performances sonores. Son...
Bon son à petit prix.
Alors pour son prix vraiment bon.
Giovanni-Mattia P.
Perfect match to my Musician Pegasus
I bought Holo Red to have a DLNA network renderer with I2S output.
I use it with a Musician Pegasus, Holo Red performance is without any glitch, immaculate. Setup was easy and I2S worked immediately without any change in the default switch scheme, just using an Amazon basics HDMI High Speed cable. DSD256 playback is now a reality, with great subjective result. All in all, a great product for my use.
Marc M.
super!
facile à mettre en œuvre du bon materiel
Marc M.
XANGSANE XS-A012 Pieds Aluminium avec Pointe de Découplage Cuivre 44.5x34.5mm Argent (Set x4) Les pieds en aluminium XS-A012 de Xangsane intègrent une pointe de découplage réglable en cuivre pur. Ils permettent une absorption des vibrations et des...
Très utile
pour moins de 20 euros le set rien que le déballage met en joie , belle pièces alu et cuivre qui inspire la qualité , les pointes sont réglables pour la mise a niveau. bravo
Marc M.
ce n'est pas un gadget
superbe objet, cela remplacera avantageusement mes pièces de 5 centimes sous les pointes , juste positionnées sous les enceintes de 60kg pièces et immédiatement les basses sont plus profondes , plus tendues .
Zoran O.
NEOTECH SOCT-16 Fil de câblage Cuivre UP-OCC PTFE 1.3mm² Neotech a longtemps été le leader dans la production de câbles en utilisant le cuivre UP-OCC "monocristal" développé par le professeur Ohno de...
mediocre sound quality wire
Tried 4-5 different types of neotech occ.
Few hundreds spent alltogether
Subject is explaning everything.
Zoran O.
NEOTECH SOCT-14 Fil de câblage Cuivre UP-OCC PTFE 2mm² Neotech a longtemps été le leader dans la production de câbles en utilisant le cuivre UP-OCC "monocristal" développé par le professeur Ohno de...
expensive mediocre wire
Supposed to be a hiend wire but after initial cooking lasted 20-30 hrs i found it bodied but without any transparency at all
Waste of money
anael g.
rapport qualité prix au top
j'en et deux utiliser sur diverses enceintes je l'ait testé sur des cabasse sampan 311 des sampan 310 des aviso aussi et des colonne jamo s 626 il se débrouille super bien et au vue se sont prix y-a aucun reproche à luis faire , je utilise pour le son de la TV en optique et pour jouer au jeux video , et le 2 emme dans une chambre sur des petite enceintes jamo bref , il et pas asses audiophile pour avoir le logo hi-fi mai bien des ampli plus cher sont même moins bon ^_^ en gros c'est moins bon qu'un naim nait 5 si !! 1600 euros mai c'est au dessus d'un denon pma 520 ae 400 euros !! donc pour 139 euros rien à dire
Jean R.
Très bien ,mais seulement pour le PC.
Très musical sur un PC malgré l'embonpoint du grave. Ne fonctionne pas sur Android, contrairement aux indications 1 du test qobuz 2 des avis clients.
Adam M.
LHY AUDIO Module d'Alimentation Linéaire LT3042 5V 1.5A Ce module d'alimentation linéaire LHY Audio offre une très belle qualité de conception, utilisant notamment un régulateur de tension LT3042 afin de...
The supplied heatsink is waaaay too small
Even when powered by as little voltage as 6.5V AC, the heatsink gets extremely warm. Delivering 0.7A (@ 5VDC) of constant current, which less than 50% of rated max current (1.5A), the heatsink instantly heats up to 60'C in a well ventilated area.
Renzo L.
Connecteur Jack DC 5.5/2.5mm Mâle Plaqué Or Cette fiche d'alimentation au format Jack DC 5.5/2.5mm avec contact en cuivre plaqué Or vous permettra de créer vos propres câbles d'alimentation avec...
Too short
I confirm that I have a cable with these exact plugs and these plugs do not make electrical contact, these plugs are a 5.5/2.5 non-standard variant, they are about 2mm shorter than the standard.
Renzo L.
Câble d'Alimentation Jack DC 2.5mm Plaqué Or 1m Ce câble d'alimentation se compose de part et d'autre d'un connecteur Jack DC 2.5mm. Il profite d'une belle qualité de fabrication, avec des connecteurs...
Connector too short
I believe they are 5.5/2.5 plugs, in my opinion the plugs really do look that size but they are about 2mm shorter than the norm and unfortunately in my case they don't make electrical contact even though they do plug in cleanly, maybe they are designed a non-standard size because another 5.5/2.5 cable Audiophonics reference 16283 has no problems. I would not recommend this cable unless you need shorter 5.5/2.5 connectors. I'm not sure if I can return the cable because sending it back would be too expensive compared to the price of the cable.
Renzo L.
Câble d'Alimentation Jack DC 5.5 / 2.5mm 0.5m Ce câble d'alimentation permet de connecter des appareils équipés d'entrées Jack DC 5.5/2.5mm de façon à les relier à des alimentations linéaires régulées compatibles.
Very Good
Doesn't look cheap at all and the 5.5/2.5 plugs go in cleanly and make stable electrical contact.
Paulius M.
Connecteur Jack 4.4mm TRRRS 5 pôles Plaqué Or Nu Ce connecteur Jack 4.4mm mâle 5 pôles est idéal pour un montage DIY  et vous permettra de concevoir un câble symétrique efficace. Ses...
Great connector, easy to solder
This one has bigger areas to solder wire onto, than the similar one which comes with a screw on sleeve, so this one is a better addition to that sleeve.
Paulius M.
Connecteur pour Casques HD800 / HD800S / HD820 / D1000 Plaqué Or Ø4mm Noir (La paire) Cette paire de connecteurs est conçue autour du savoir faire de la marque. Disposant de deux pins, ils sont adaptés pour la conception de câbles compatibles...
As good as original connectors
To me it even seems better than original, fits perfectly.
Henrikas S.
SMSL SU-6 DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Noir SMSL propose avec le SU-6 un DAC performant et abordable, profitant d'une conception soignée garantissant une restitution sonore précise.
SMSL SU-6 DAC
Solid DAC
This SU-6 is very nice with excellent build quality. The sound is clear, highly resolving and neutral. The wireless sound using the LDAC codec is also of high quality. I am very impressed with the performance of this DAC.
Fast delivery. The item was securely packaged.
Thanks seller.
DYNAVOX Liquide de Nettoyage pour Cellule Vinyle Ce liquide de nettoyage de chez Dynavox permet d'entretenir le diamant de vos cellules efficacement. Il est livré avec une petite brosse permettant d'appliquer le liquide...
un bon complément
Je l'associe avec le produit polymère WINYL de ce même site . Le polymère apporte la netteté et la propreté de son et le liquide dynavox apporte du relief au son . impression d'avoir changé de platine .
WINYL ONE-TOUCH POLYMER Nettoyant Solide Polymère pour Diamant Platine Vinyle Le Winyl One-Touch est un nettoyant pour diamant de platine vinyle contenant un polymère de Polyuréthane (PU) solide de la plus récente génération et spécialement conçu pour...
très éfficace
Apporte une grande netteté à l'écoute mais le son est un peu mat. Je l'associe avec le nettoyant liquide en second passage et le résultat est génial . J'ai l'impression d'avoir une platine de plus haut de gamme . Très recommandable.
Eric L.
SMSL C200 DAC ES9038Q2M Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 SMSL propose avec le C200 un DAC aussi compact que performant, profitant d'une conception soignée et d'une connectique capable de répondre à la...
Excellent Dac ampli casque
Ce DAC/Ampli casque tient toute ses promesses, la dynamique est très bonne, vraiment neutre, des détails à foison, la séparation des canaux bien marqués, la scène sonore bien large, il y a mieux pour la profondeur mais elle existe…
Bien timbré, il y a plus « musicale » mais parfois au détriment de la transparence, impitoyable avec les mauvais enregistrements…
Je recommande ce Smsl C200 , qui pourra s’intégrer dans un système haute fidélité.
Câble de bonne qualité .
LAURENT G.
SMSL D1SE DAC ES9038PRO Symétrique CPLD Altera XMOS 32bit 768kHz DSD512 Noir Le D1se de chez SMSL est un DAC extrêmement performant, se basant sur une architecture symétrique utilisant une puce de conversion numérique / analogique...
DAC transparent et silencieux
En remplacement d'un ATOLL 100SE vieillissant, ce DAC est transparent et retranscrit les phonogrammes de façon très exacte et stable. Aucune signature sonore décelable. Ne pardonne rien aux enregistrements de mauvaise qualité.
Utilisé en liaisons RCA avec un amplificateur intégré.
Aucun bruit résiduel transmis à l'amplificateur lorsqu'il n'y a pas de source envoyant un signal. Aucun bruit non plus à la mise sous tension et à l'extinction.
Ne chauffe pratiquement pas.
seul bémol : entrée I2S non compatible avec source munie d'une sortie HDMI ARC (audio), quelles que soient les configurations de l'entrée I2S choisies. D'où le retrait d'un point.
à signaler: DAC détecté par mon PC et utilisable en liaison USB avant même d'avoir téléchargé le pilote dédié. Ce dernier installé, je n'ai vu rien de modifié dans l'utilisation du DAC.
Que la lecture des fichiers se fasse au format natif (flac 16 bits/44 Khz la plupart du temps) ou rééchantillonné en 32 bits/384 Khz ne change pratiquement rien au rendu sonore.
Fonctions MQA et Bluetooth inutiles pour mon usage et donc non testées.
Laurent G.
Matthieu D.
Ma sono est au -1 et ma cuisine au RDC, du coup j'avais besoin d'une télécommande pour piloter le volume sans avoir à descendre à chaque fois.
Produit au top, bonne pré-amplification, réponse en remote très satisfaisante.
Si je devais chercher la petite bête je dirais que par rapport au volume en direct on n'a que de la diminution possible, mais si on calibre bien sa sono, ça n'est pas un problème. Un bon gain en entrée et on se prépare la plage de volume de confort sans souci.
En nettoyant ma sono je l'ai fait tomber. Il est mort. RIP. Je viens de commander le même. Tout est dit.
L
Anh J.
GUSTARD A26 DAC 2x AK4499EX XMOS XU216 LAN UPnP Roon 32bit 768kHz DSD512 MQA Noir Gustard dévoile avec le A26 un DAC haut de gamme, aussi performant que polyvalent. Il se base sur une architecture de grande qualité, utilisant notamment un double...
Wonderfull AKM DAC in perfect implementation; a diamond waiting to be discovered.
i have bought this DAC some time ago and play only CD and SACD. Use a CD driver from Jay's Audio with upsampler. CD with upsampler button and gustard on NOS filter.. Smooth as it can gets. Combination is really wonderfull. This new AKM dac is a winner. The AKM 4499EX combination in another brand, Cary Audio, Marantz or Esoteric, can bring some upgrade. But this Gustard a26 and Jay Audio shows all the things you need to hear it all. And all in the wright colour and balance. Really natural sounding and with no glare at all. No fatigue. It doesn't downgrade other devices and went along with BW 801 D4, Accuphase C 3900, Mcintosh MC 1.25KW. Alle connected with vd Hull Cumulus 3T. Same goes for the combination with ToneWinner Class A amplifier. Another diamond on the market to be discovered. This AKM in a Gustard is a diamond to be discovered and if it is shows it real worth. Thank you for great service.
Thomas W.
TOPPING MX3S Amplificateur Class D Infineon Amplificateur Casque DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Noir Véritable couteau-suisse de l'audio, le Topping MX3S endosse à la fois les fonctions d'amplificateur Class D et amplificateur casque avec DAC AK4377 et...
Très satisfait !
Acheté en remplacement d'un SMSL Q5 pro pour accompagner des Davis Eva et un caisson Yamaha NS-SW100. J'utilise ce matériel principalement dans le cadre d'une écoute "nearfield" lorsque je suis assis à mon bureau.
Ce FDA est très complet, tant par les fonctionnalités qu'il propose (écran, Bluetooth, prise subwoofer et prise casque) que par les réglages qu'il permet (aïgus, graves, extinction/allumage automatique du FDA avec le PC, extinction automatique de l'écran etc.). Sa télécommande est bien plus complète et intuitive que celle de mon Q5 Pro. L'écran est lisible et l'agencement des informations qu'il affiche est clair. En revanche, je conseille très fortement d'avoir le manuel sous les yeux lorsqu'on s'aventure les premières fois dans ses menus très peu explicites. C'est vraiment le seul petit bémol que j'ai noté jusqu'à présent, pour le reste c'est un sans faute à mon humble avis.
Concernant l'écoute, je suis très satisfait de ses prestations. Il me semble qu'il exploite beaucoup mieux le potentiel de mes enceintes. Il me paraît les diriger avec plus d'autorité et de précision que mon Q5 Pro, ce qui rend l'écoute moins fatigante par ailleurs. Cependant, n'étant ni ingénieur ni mème audiophile, je crains toujours qu'il y ait un peu d'effet placebo dans mes ressentis.
En revanche, je n'ai aucun doute sur la gestion des basses qui est clairement meilleure, tant la différence est importante, que celle de mon Q5 Pro. Je me rends compte aujourd'hui que le Q5 Pro était vraiment brouillon sur ce point. J'ai l'impression d'avoir un autre subwoofer quand je suis bien conscient d'avoir les mêmes enceintes.
Je n'ai pas encore testé la prise casque ni le Bluetooth, je n'ai donc aucune opinion sur ces points.
Pour conclure, je suis heureux de mon achat tant cette petite boîte métallique est bien finie, pratique au quotidien et agréable à mes oreilles pour l'usage que j'en fait.
Thomas W.
Très satisfait !
