Miklos C.
Miklos C.
Miklos C.
Avis clients - Il y a 19510 avis.
Todor S.
IFI AUDIO IDEFENDER+ Filtre Anti Boucle de Masse USB-A Mâle vers USB-A Femelle Le iFi Audio iDefender+ permet d'annuler le bruit ayant pour origine une boucle de masse dans votre système audio. En effet, l'utilisation inévitable de plusieurs...
Great device!
I have a Chinese DAC that is powered by USB, but there is no noise filtering from the current, so I needed to feed it with clean electrical signal. Ifi Defender+ does a perfect job for this - I'm using a smartphone power supply now, but I'm thinking of buying an Allo Nirvana to further improve the sound quality.
Mark D.
RME ADI-2 DAC FS DAC Symétrique Amplificateur Casque ES9028Q2M 32bit 768kHz DSD256 Noir RME propose avec son ADI-2 DAC FS un convertisseur analogique haut de gamme, inspiré des appareils de studio mais adapté pour les audiophiles. Intégrant de...
Solid DAC
I have had this DAC for a few years now. I have the second AKM version. It have no other DAC to compare it too, but I have been impressed by its absolute reliability, great sound and useful features. The first of those is the perfect volume control that seems not to lose resolution as it is turned down. The second is the loudness button which is exactly what is needed for late night low level listening. I also use the basic bass and treble controls though not the parametric because frankly I have not been able to master it. The user interface is forbidding. Lastly, as far as filter go I set it NOS which sounds to me the most natural. There may be other DACs that are more impressive. I would like to get a good ladder DAC but at three times the price will it be three times better?
Andrii B.
Module Circuit d'Alimentation linéaire 4 emplacements Snap in 35mm plaqué Or Ce circuit dédié pour alimentation linéaire est idéal pour la conception d'amplificateurs DIY stéréo. Il vous permet d'intégrer...
Good quality.
Used in DAC power supply unit.
Andrii B.
LHY AUDIO DIR9001 Module Interface SPDIF vers I2S 24bit 96kHz Ce module d'interface SPDIF vers I2S permet de récupérer un signal depuis une entrée coaxiale ou optique Toslink pour sortie en I2S. Il utilise pour cela...
The product is as described.
Fast delivery from France to Germany.
Mark D.
Good input switch box
I was pleasantly surprised by the quality of this switch box. When introducing a switch and extra connections into your system, there is a natural concern that this could introduce some sonic degradation. This switch box seems not to have introduced any detectable sonic degradation at all. The switch itself is very smooth and easy to turn (almost too easy) which gives an impression of good quality. I was concerned that it might be too stiff.
Mark D.
1877PHONO ARCANA HYBRID Câble de modulation OFHC / OFC RCA-RCA 1.5m Le câble 1877PHONO Arcana dispose d'une excellente fabrication et finition avec des Cinch RCA de qualité avec pin central OFC, un traitement en surface du cuivre haute pureté et...
Very good Interconnects
I was not expecting these to be as good as they are. They have made a very positive contribution to my system especially to the sound of my DAC which sounds a lot more coherent and well-balanced than before. It had been connected with more expensive cables previously..
MICHEL B.
Les meilleurs connecteurs 75 ohm
Pas la peine de chercher ailleurs, ces connecteurs sont les meilleurs, le contact est parfait et surtout la norme 75 ohm est rigoureusement respectée !
MICHEL B.
AUDIOPHONICS CANARE Câble numérique coaxial 75 Ohm BNC-BNC 2m Voici un véritable cordon numérique coaxial BNC, en version 75 Ohm, de marque CANARE assemblé avec soin par AUDIO-GD. Sa particularité est de...
Superbe résultat
Ce câble qui respecte parfaitement la norme 75 ohms avec un conducteur et des connections de haute qualité donne un parfait résultat, la musique s'exprime en totale liberté.
Ce câble est bien meilleur que beaucoup de câble vendu très cher dans le commerce d'arnaque de la Hi-Fi !
Un grand merci à Audiophonics !
Windows 10
J'ai cet appareil depuis 3 ans, j'en étais totalement satisfait, jusqu'à ce que Windows 10 me soit imposé pour mon PC. Après avoir téléchargé le programme pour le réinstaller (DATS_V3_setup.exe), ça fonctionne, mais pas parfaitement. Rien qu'en faisant le test des câbles en court-circuit, au dessus de 10Khz, la courbe est totalement irrégulière, faite de creux et de bosses, pas trop normal je pense. Vivement que Dayton Audio propose une amélioration à son produit.
Bruno R.
LPSU100 Alimentation Linéaire Régulée 5V 11A DAC / Docking L'équipe Audiophonics est fière de pouvoir vous proposer une alimentation linéaire régulée destinée à alimenter proprement les...
Très satisfait par cette alimentation et le processus d'achat.
A la recherche d’une alimentation linéaire délivrant 5V et au moins 2A pour alimenter mon lecteur réseau Bluesound Node N130 « tweaké » avec la fameuse carte d’alimentation de la société polonaise PD Creative, mes longues recherches m’ont amené sur le site d’Audiophonics.
Bien m’en a pris puisque je suis à présent l’heureux possesseur de cette LPSU100 en 5V et 11A, que j’ai pu acheter à un tarif hyper intéressant grâce à la promotion en cours (-40%).
Le coli est arrivé très rapidement en Colissimo classique (commande passée le mercredi à 23H, livraison le samedi matin) et parfaitement emballé.
Le boitier d’alimentation respire la solidité et la qualité, aussi bien des matériaux (alu brossé) que des composants. Il ne chauffe quasiment pas même après plusieurs heures d’écoute.
Et le résultat sur la qualité du son est bel et bien là. Tout ce que j’ai pu lire depuis des mois sur le sujet a été confirmé dès la 1ère écoute : les basses sont devenus plus précises et profondes, les aigus moins agressifs. Les instruments se détachent les uns des autres et la scène sonore gagne en espace. Les voix se montrent plus présentes.
Et surtout, surtout, l’écoute est devenue beaucoup plus confortable : il n’y a plus de fatigue même à un volume plutôt élevé. Je peux écouter à présent pendant des heures au même niveau du potard de mon ampli tout type de musique (même dans le répertoire metal dont les morceaux « occupent » très largement toute la bande passante) alors qu’avant cette alimentation, je finissais par baisser le volume voire même arrêter d’écouter par fatigue.
Bref, je recommande à 200% l’achat de cette alimentation auprès d’Audiophonics !
Stefano C.
NEOTECH NEP-3001 III Câble Secteur Cuivre UP-OCC Plaquage Argent 5.26mm² Ø16mm La gamme NEP de Neotech est constituée de câbles d'alimentation high-end utilisant uniquement des conducteurs en Cuivre UP-OCC d'une extrême pureté,...
Fantastic power cable
One of the few times that, as soon as the power cord is installed, an improvement is immediately felt. Really nice product! Highly suggested!
Teddy T.
[GRADE B] AUDIO-GD S-1 Amplificateur Class AB 2x70W 8 Ohm Noir Produit reconditionné - Grade B Cet amplificateur Audio-GD S-1 profite d'une architecture en Class AB lui permettant de fournir une restitution sonore d'une belle...
Beaucoup de gens pensait que c'était un piège et pourtant ...
Pour son prix, c'est juste dementiel il est juste parfait.
Associé sur des petites Klipsch RB81MK2 ça fait vraiment des merveilles.
Michel L.
Moins de 10 heures d’utilisation et déjà une différence notable avec les électro harmonix installés précédemment sur mon préampli phono : meilleur rendu de la scène sonore justesse des différents registres et surtout des basses plus présentes et plus « grasses »
Pas de miracle non plus ces tubes ne transformeront pas une bourrique en cheval de course mais l’investissement vaut le coup si le matériel le justifie
Merci à Audiophonics pour la rapidité de la livraison
Claudio c.
TANCHJIM SPACE DAC USB Portable 2x CS43131 Symétrique 32bit 384kHz DSD256 Le DAC portable TANCHJIM SPACE est un DAC portable compact et efficace. Il  adopte une finition haut de gamme avec un cadre en alliage d'aluminium usiné CNC et...
Petit bijoux de puissance et de qualité sonore
Alors la je reste scotcher devant ce petit appareil audio. Puissant robuste, qualité sonore au rendez vous, rien à redire, excellent.
jouri k.
IAN CANADA MONITORPI Écran OLED et Analyseur de Signal pour Raspberry Pi Le MonitorPi de Ian Canada est un écran OLED fonctionnant pour tous types d'applications audio avec Raspberry Pi. L'installation se fait très simplement à...
Works!
My MonitorPi was defective on arrival. Bad solder joints at GPIO. Couldn't get into settings
Got it resoldered. Works like it should. Has a huge impact on the sound. No more clicks between tracks. Also coverting to 32 bit is great for low res sources. Also DOP can be pass-through It souns better than expected!
Happy
Edmond S.
beau produit efficace.
les instructions de montage pourraient être complétées. enlever toutes les vis, séparer les deux parties en aluminium, ENLEVER LE CACHE PLASTIQUE du coté opposé à l'arrivée de courant, et ensuite les glissieres glisseront, **si elles ne sont pas encombrées de résidus de peintures époxy qui n'ont rien a faire à l'intérieur et empêchent justement de glisser.(en parler à votre fournisseur?) c'est le détail qui rend le montage du câble un peu pénible (pour la première multiprise).. resultat sonore excellent et très beau produit, mis à part le détail cité plus haut. Merci audiophonics
Edmond S.
beau produit
très facile a installer, connections massives. beau produit
Dimitri D.
Excellent value!
Have always prefered solid core cables (starting many years ago with low cost power cables that even out performed many a "costly audiophile" cables ) and these Jantzen cables have to be one of the best hi-fi bargains around, providing neutral and naturally dynamic sound transmission! Should also add the web site and service is also excellent. Highly recommended!
Guus G.
Good banana tube terminators
They are well made and have some springiness to them, so they return to their original form quite well (after unplugging). Altough I soldered them initially with silver solder I noticed a performance drop so quickly unsoldered them and now use them pinched to the cable, which in my opinion deliveres a better sound quality.
Great service as always from Audiophonics.
Guus G.
Great value for money!
I orderd the AC-14se mk2 since I previously ordered the AC-14 and was amazed how a powercable can make that much difference.
The AC-14 gave me the confidence to invest yet a bit more and the AC-14se mk2 delivers. Not as much gain the AC-14 made over the stock cable but enough to be content. Great service from Audiophonics as always.
Guus G.
Disappointed
I bought the viablue sc-2 speaker cable as un upgrade to my 30 years old Monitor Cobra Cable 4mm. After a few days I switched back to my old cables as I was not convinced the ViaBlue sound better. On switching back I found my old cables are are better in revealing details across the spectrum. I tested some more playing audio test tones from Qobuz. The ViaBlue were not able to reproduce the 30 Hz tone but my old cables were rock solid. Some critical music listning also revealed less spatial information with the ViaBlue.
The cable is sturdy yet flexible. No complaints in that region. Sound wise however they are a disappointment.
David S.
ELECAUDIO HP-25OFCS Câble Haut-Parleur Cuivre OFC Plaqué Argent Isolé PTFE 2x5.1mm² Ø7.5mm Le reconnu et réputé câble HP Elecaudio HP-25OCC revient dans une nouvelle version, toujours plus performante, le HP-25OFCS. Celui-ci reprend la même...
top
Premières écoutes : Entre mon ampli Lector audio ZXT70 et mes enceintes Récital Define HEFA enterre le Mogami W3103 loin derrière.
Câbles très transparent, beaucoup plus de détails et de profondeur sur tout le spectre, les petites sibilances sur certains enregistrements difficiles ont disparues. Le couple cuivre/argent semble être adapté à mon système.
"C’est comme si on avait enlevé un bouchon. "
À recommander!
(du moins chez moi)
Eric V.
TOPPING E30 II DAC 2x AK4493S XMOS XU208 32bit 768kHz DSD512 Noir Topping revient avec le DAC compact E30 II, véritable évolution de l'excellent E30, présentant de nombreuses améliorations techniques permettant...
Sans réserve
Après plusieurs jours d'utilisation, ce dac remplit parfaitement son rôle, de plus sa construction et les composants utilisés sont de qualité.
A l'écoute, après quelques heures, il procure une écoute détaillée et précise ne mettant pas en avant un registre particulier (grave-aigu). La scène sonore est plutôt large et profonde. Sans être démonstratif, ce dac est assez dynamique.
Bref, ce Topping E30 II est à mon sens une réussite, compte tenu de son budget ! Audiophonics, comme souvent, a sélectionné un excellent produit. Bravo.
Jean B.
Cher, pour ce que c'est, mais bien construit.
Il faut mettre beaucoup plus cher pour avoir un vrai produit d'isolation.
Parfait sous de grosses platines vinyles ou des enceintes.
Jean
Jean B.
Très bien, plus de bruit lors des connexions à chaud
Dire que c'est mieux qu'une autre connectique moins cher, je ne sais pas, mais au moins on peut connecter à chaud sans risque.
Belle construction, à voir comment ça résiste sur le long terme.
Mais, de manière générale, je suis revenu des connectiques très haut de gamme genre Rhodium qui ne résiste pas aux conditions atmosphériques (humidité) du climat Marseillais par exemple. Ca flatte l'égo à l'achat et puis quelques années plus tard, l'état de la connectique (sans l'avoir branchée/débranchée outre mesure) laisse un gout amer, on a un peu l'impression qu'on a été le parfait gogo du marketing idiophile.
Je n'utilise donc plus que du câblage/connectiques pro, c'est moins cher, surtout si ça ne dure pas dans le temps et franchement, à l'écoute, ça fonctionne très bien.
Jean
Jean B.
DIN Pseudo Star QUAD
Parfait pour remplacer vos câbles DIN d'origine y compris les petits Naim.
Belle ouverture, pas d'agressivité.
Un très bon câble à prix démocratique.
Jean
Jean B.
Câblage platine vinyle
Parfait pour remplacer le câblage d'origine, souvent médiocre de votre platine vinyle.
Jean
Jean B.
DAYTON AUDIO DAEX32EP-4 Haut-Parleur Vibreur Exciter Large Bande 40W 4 Ohm Ø3.2cm Parmi les hauts parleurs vibrants les plus avancés et les plus précis de chez DAYTON Audio avec un moteur d'un diamètre généreux de 32 mm. Un...
DML
Parfait pour de petits panneaux DML.
Conseil perso, faites des panneaux légers, de faible épaisseurs et très rigides, n'hésitez pas mélanger les matériaux. Et de les utiliser avec des amplis avec contre-réaction en courant, y compris de petits LM1875.
Résultats étonnant pour le prix et l'encombrement.
Jean
Jean B.
MA-LM01 Module Amplificateur 2x LM1875 Stéréo 2x20W Class AB Ce module d'amplification stéréo MA-LM01 se base sur deux puces d'amplification TI LM1875. Ainsi, cet amplificateur est capable de délivrer 2x20W sous 8 Ohm...
FONCTIONNE
Commande expédiée très rapidement, bien emballé, produit fonctionne mais chauffe trop par rapport à la tension d'alimentation.
J'ai acheté ce kit en dépannage, car il me fallait un ampli très rapidement. J'ai construit plusieurs petits ampli à base de LM1875, avec la même tension d'alimentation et le schéma standard de la datasheet, les LM1875 ne chauffent pas.
Pour être précis, à +/- 12V DC (après le pont de diodes, mesuré sur les capas d'alim) les LM1875 délivrent environ 10W/4 Ohms et ne devraient pas chauffer. Avec ce kit, ce n'est pas le cas, les LM1875 sont tout de suite chaud, prévoir un bon radiateur, mais ce que ça indique, c'est qu'il est probable que l'ampli oscille...
Jean
Bruno M.
TOPPING E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Noir Topping propose avec son E50 un DAC compact et très performant, utilisant des composants audio éprouvés et largement reconnus par les audiophiles. Celui-ci...
Bon produit mais en-dessous d'un DAC même plus ancien avec puce AKM
Le DAC Topping E50 n'est pas mauvais, mais il reste en-deçà du DAC que je possédais déjà (Aune S6 équipé d'une puce AKM), L'élément manquant est la gestion des trémolos et des vibratos en particulier sur la voix ou la flûte traversière, insuffisamment fidèle avec ce DAC. J'envisage prochainement de commander un DAC Topping E70 Velvet qui lui est équipé d'une puce AKM me permettant de retrouver la musicalité manquante. Pour le reste, le dac Topping E50 est un bon DAC, avec une reproduction correcte des extrêmes basses aux quasi-ultrasons, sans distorsion repérable, même à haut niveau (proche du 0db, contrairement à ce que j'avais pu constater à haut niveau avec mon DAC précédent Aune S6 qui distorsionnait ponctuellement sur certaines hautes fréquences telles 13.7Khz bien avant d'avoir atteint le niveau maximum de 0db), Je suis donc en attente d'un changement de DAC et ne sait pas si je serais amené à utiliser mon Topping E50.
Charles R.
WONDOM DB-DP11219 Module de Programmation SigmaStudio pour DSP Sure Wondom propose une carte de programmation compatible avec les DSP de marque Sure. Ce module s'avère indispensable pour programmer le DSP et gérer le traitement du...
Marche plutôt bien.
Au cas ou vous galérez pour faire correctement reconnaître la carte par Windows même après 15000 installations des drivers :
AVANT d'y connecter le DSP
Branchez la carte à l'ordinateur, ouvrez sigmaStudio et établissez la connexion .
Après, ça fonctionne nikel.
Je ne met que 4 étoiles car sauf erreur de ma part, ce détail n'est mentionné dans aucune doc officielle de la marque.
Didier G.
AUDIO BASTION REDLINE DAMPER Absorbeurs de Vibrations Aluminium / Silicone 41 x 17mm (Set x4) Ces pieds pour appareils HiFi et enceintes permettent d'absorber efficacement les vibrations de votre équipement. Ils sont composés d'un patin en silicone,...
Absorbeurs efficaces
Placés sous des enceintes bibliothèques, ces absorbeurs améliorent la restitution.
Produit bien fini et esthétique.
Didier G.
Remarquable streamer
Ce streamer surpasse mon ensemble Melco N100+Audio GD DI20 (Dac HOLO spring entrée I2S) en termes de transparence, de relief, et d'image.
L’OS fourni est performant mais Gentooplayer apporte un plus à l’écoute
L’utilisation en mode UPnP avec l’application Mconnect ne pose pas de difficultés.
Une notice est disponible sur le net (en anglais).
Edmond S.
Hi-fi
Tout simplement excellent en hi-fi. Bande passante, détails, précision. Le monobrin cuivre serti sur des fiches cuivre y est pour quelque chose
Pedro V.
Update on previous review
Just like to update my previous review were I incorrectly blamed QC issues on this cable. The problem I had was related to other things on my system that I have since fixed. The ELECAUDIO cable is great value for money.
Sebastien w.
WONDOM AA-AS32157 Amplificateur Tripath TA2024 Class D 2 x 15W / 4 Ohm Wondom nous propose ici un amplificateur TA2024 Clas D délivrant une puissance de 2x15W sous 4Ω, idéal pour toute installation HiFi secondaire ou d'appoint. De...
Bon ampli
Bien construit et performant. Satisfait de mon achat. Reçu rapidement et bien emballé. Merci à audiophonics.
Alexander D.
DD TC28CPRO Adaptateur USB-C Mâle vers 2x USB-C Femelle OTG Cet adaptateur DD TC28 Pro se compose d'un connecteur USB-C mâle ainsi que de deux ports USB-C femelles, l'un compatible OTG et l'autre dédié à la...
Finally I can charge my device
Finally I can charge my device while my smartphone is connected on my dac
Connecteurs RCA Plaqué Or Ø8mm (La paire) Noir Ces fiches babanes bénéficient d'un plaquage or 24K pour une conductivité maximale et une résistance à la corrosion. Elles acceptent des câbles de 8mm de diamètre maximum.
En force
Connecteurs de bonne facture avec un niveau de finition très sympa.
Soudure facile et musicalité d’un très bon niveau.
Mais attention, l’insertion sur les embases femelles est très dure avec un risque mécanique évident.
Dommage, car la réalisation de ces prises RCA est sérieuse, et avec un diamètre plus important de quelques dixièmes, elles seraient parfaites, surtout au prix qu’elles sont proposées.
A bon entendeur
Après rodage sonne vraiment bien
Par contre sur un système très transparent elles donnent la limite (ETI tellurium par exemple donne son musical transparent et précis )
Frédéric R.
Interrupteur NO Lumineux Double 250VAC 15A Vert Cet interrupteur de type NO dispose de deux switch verts lumineux disposant chacun de deux positions. Le montage est de type snap-in et se fait simplement avec des cosses ou via...
Très bonne qualité, pas de jeu ou faux contact comme sur certains Interrupteurs bas de gamme.
lucien S.
aucun interet dans mon cas.
ne fonctionent pas pour moi avec en sortie un sony xm800 en hdmi sacd natif sur entre gustard x16 en i2s avec cette interface !!! a savoir......
Jerome A.
Très belle surprise, son fabuleux, excellent rapport qualité/prix
Etonnant de voir le grand nombre de messages élogieux sur cet ampli sur les forums, et le peu d'avis ici.
Après écoute, je partage l'ensemble des avis ici, et d'ailleurs, il n'est pas très design, mais le son... excellent.
Sans fioriture, ni télécommande, aucun gadgets inutiles, pas de marketing de revendeur audio souvent risible, non, mais entrée/sortie symétrique, composant de choix, il va droit au but, le plaisir.
Si vous vous moquez du look, que seul la qualité et le son vous importe, alors vous pouvez acheter les yeux fermés.
Il fonctionne à merveille avec mes casques, denon ah5200, hifiman edition xs, audeze lcd2, il va probablement devenir mon ampli principal.
Comme à l'accoutumé, envoi rapide & soigné de la part du vendeur.
Philippe S.
FURUTECH FI-E48 NCF (AG) Connecteur Secteur Schuko Type E/F Cuivre Plaqué Argent Traitement Alpha NCF Ø20mm Le Furutech FI-E48 NCF (AG) fait partie de la gamme de connecteurs de la marque intégrant le matériau NCF et profitant, comme pour l'ensemble des produits...
Monté avec iec 48 ag sur un câble furutech n55s et après une vingtaine d'heures de rodage, la musique sort comme je ne l'avais jamais entendu, cela fait un câble secteur à 700€ mais je trouve que l'investissement en vaut vraiment la peine.
ETI LINK BANANA Fiches Banane Cuivre Tellurium Plaqué Or Ø9mm (Set x4) Les fiches banane ETI Link Banana offrent une très belle qualité de conception, assurant une excellente transmission du signal. Les contacts sont fait de cuivre...
Musical
Rien a voir avec pangeo et autres qui rajoute des basses et autres la on écoute ce qu'il y a très musical avec de beaux timbres (si votre système en a )
Daniel n.
Excellent service!
I received items within a few days (to the US) but they had lots of dings but were still functional. I contacted Audiophonics and the situation was quickly resolved. I will definitely buy from Audiophonics again - thanks for the great service!
Rodolphe L.
SMPS800RE Module d'Alimentation à Découpage 800W +/-40V L'alimentation à découpage SMPS800RE est un modèle à très haut rendement capable de développer une puissance nominale de 800 Watts dans...
Fait le job !
Alimentation SMPS utilisé pour donner vie à un amplificateur classe B. La mise en œuvre est facile, comprend déjà le fusible, le connecteur secteur, reste à ajouter l'interrupteur. Les tensions auxiliaires indépendantes ont une vraie plus value. Les tensions sont respectés en charge.
Mais une étoile de moins car cette alimentation est légèrement bruyante.
Ludo B.
Aucun probléme avec ce transfo. Sous tension et avec il est vrai une charge pas énorme, aucun échauffement et chose étrange, le compteur Linky indique 0va ! Surprenant !! Ce torique doit étre d'une trés bonne qualité !
Ludo B.
Module Alimentation LT1764A +/-15V 2x15V 5V Ce module d'alimentation polyvalent permet de profiter de deux sorties 15V ou d'une sortie +/-15V selon le câblage, ainsi que d'une sortie 5V. La tension de chaque sortie...
En observant cette alimentation, on peut voir que chaques détails a été pensés. Qualité extréme ! Méme la couleur du circuit imprimé ( noir ) n'a pas été choisie au hasard. Excellent !!!
Utilisé avec Xlr EIZZ
Monté en Xlr sur Connecteurs EIZZ résultat excellent.
J'ai doublé les néotech sur point froid.
Le RQP est simplement exceptionnel sans dépenser des centaines voire des milliers d'€
