Daniel W.
Connecteur
J'ai envoyé une photo et...
Moyen
Elle se retourne en...
Giacomo P.
No for me
Absolutely no!
AUDIOPHONICS LPSU25 Alimentation Linéaire régulée Faible Bruit USB 220V vers 5V 2A 25VA - avis - Il y a 59 avis.
Craig S.
Perfect PSU for your RPi3 and Hifiberry board
This replaces a iFi iPower unit which failed to supply my RPi reliably (dreaded lightning bolt icon). This supply works perfectly and the jitter output to my toslink input to my soundbar has reduced with very good quality sound. Impressed by the build quality for the price. Would buy again.
Giovanni F.
Excellent device
This is the second 5v power supply I bought from audiophonics. Both are excellent. The last I bought has some more ventilation, no problem with the previous version anyway. It greatly improved the sound coming from my two Asus tinkerboard with Volumio. Also, they look nice in a hi-fi set. Recommended!
Jean Louis L.
INDISPENSABLE!
Apres quelques échanges mail, tres heureux de cet achat pour fonctionner avec un DAC ami musik ds5 .
Une fois branché , eh bien , c'est plus de tout, et dans tous les registres , grave , medium , aigu!
Et c 'est plus précis et plus dynamique !!
Il me serait impossible de revenir en arrière, maintenant !
Pieter T.
works wonders on my digione
I replaced the stock power supply of my digione+raspberry pi with this one. Very big improvement on the sound, sound much more clear and tight bass. My streamer now sounds like a high end streamer.
Paul R.
Stable & Low Noise
I ordered one of these supplies to evaluate as I needed to replace some switch mode supplies in my system. The regulation is fine and there is no appreciable electrical noise from this supply. I have ordered another of these based on the performance of the first one. This is the first time I have dealt with Audiophonics, they delivered quickly and gave several email updates regarding the progress of my order. Very satisfied new customer, thanks.
Claude T.
C'est le top !
DAC ISabre ES9028Q2M, avec le reclocker Kali et l'alim linéaire régulée, cable Mogami 3104 en bi-cablage sur des Tannoy D700. C'est le top.
Je n'aurais jamais cru que mes CD étaient aussi bons.
Maurizio F.
Oggetto ben fatto come da presentazione.
Ditta seria, e consegna molto veloce pur abitando in Italia.
Maurizio
Adrian C.
Now I'm a believer! :-) :-D
I did not measure the performance or ripple but I think that the sound quality improved: the piano sounds better.
I think I can hear the differences to the original (Allo) power supply even if I do not have high-end equipment.
I like the front and rear USB sockets and the surface finish.
I would have preferred a slightly harder power knob and a stronger feed-back but this is really not important and has something to do with the personal expectations.
The delivery to Germany was very fast.
My conclusion: excellent power supply.
Would I recommend it to my friends? - Yes!
luc P.
perfect sound
It took long to decide which DAC I should buy, finally I ordered also the AUDIOPHONICS Linear Regulated Low Noise Power Supply USB 5V 3.5A 25VA and in just 5 minutes the setup was playing.
I am really surprised that a DAC can do so much in the sound on the same setup.
So the source is indeed the first important step.
At this price a big improvement over the HiFiberry DAC+ Pro
didier b.
fait le job
je l'utilise pour le pasptouch digione
j’ai augmenter le voltage par la vis du potentiomètre a l’arrière
Guillaume L.
Effectivement il y a du changement dans le son ; grave plus tendu et aigu plus distingués
Il y a même une petite vis à l'arrière du produit qui permet de régler la tension
