david D.
setup simracing
Le BST-1 est un excellent produit pour débuter et obtenir une vraie immersion à petit budget.
Bien installé + bon ampli +...
George R.
Amazing value for money once upgraded!
In stock form, this preamplifier is pretty good value for money. However, it was transformed into something special once I...
George R.
Massive improvement pver original Opamps in Aiyima T20
OMG - these dual OpAmps were a massive improvement over the original Opamps installled by the OEM in my Aiyima T20 elevating...
Avis clients - Il y a 20876 avis.
Raffaele V.
AUDIO-GD DA-7 MKI 2023 Module DAC R2R 24Bit 384kHz Le module DA-7 MKI 2023 de chez Audio-GD embarque un DAC 24 bit basé sur réseau de résistances. Il profite de tout le savoir-faire...
AUDIO-GD DA-7 Kit
Not simple but not complicated either. You need to pay attention to the cams and feeds and I highly recommend them.
one day of work, rechecking everything three times, It practically worked the first time. The sound is basically excellent, but can be improved with some adjustments that I will install in the future.
Non semplice ma neanche complicato. Bisogna porre anttenzione ai camlaggi e alle alimentazioni che consiglio vivamente le sue.
un giorno di lavoro, riconytrollando tutto tre volte, Ha praticamente funzionato al primo colpo. Il suono, di base ottimo, ma migliorabile con alcunio accorgimenti che intallerò in futuro.
François G.
Le problème : ronflette quand une TV et un ordi sont branchés simultanément sur une paire d'enceintes amplifiées à deux entrées.
Le transfo placé sur la ligne TV résout le problème.
Alex C.
AUDIOPHONICS MPA-S250NCX XLR Amplificateur de Puissance Class D Stéréo Ncore NCx252MP 2x250W 4 Ohm Le Audiophonics MPA-S250NCX XLR est un amplificateur stéréo basé sur un module d'amplification Hypex Ncore NCx252MP. Cette solution est idéale pour...
Perfect amp
I have this driving a pair of KEF Q350s and they are perfect. Noise free. Incredible detail at any volume.
TAD KT88-STR Tubes Tétrode (Quad Appairé) Les nouveaux TAD KT88-STR REDBASE® sont conçus dans le style des premiers KT88 britanniques de MOV, avec une grande enveloppe en verre lourde et une base...
Excellents
Surpris et content de les voir au catalogue, peu de temps après en avoir fait la suggestion. Avant d'évoquer mon ressenti sur ces excellent kt88, je tiens à signaler que je suis épaté du sérieux et du respect qu' une entreprise comme Audiophonics manifeste envers ses clients. Bravo et merci pour votre excellent professionnalisme.
Quant aux Tube TAD kt88 STR, ils offrent une précision , du détail et de l' ampleur.
Tout est équilibré et bien dosé . Le grave et précis et tendu, médium riche, aigu filant et subtil. Une très bonne référence, le genre de Tube que l' on préfère...
Christophe H.
Pack Topping Amplificateur Casque A50s + DAC D50s + Alimentation P50 + Câbles RCA TCR2 25cm Noir Avec ce pack Topping complet, vous disposez d'une solution clé en main pour intégrer rapidement et facilement un excellent système audio orienté vers...
ensemble compact et élégant
l'ensemble est très compact mais a un aspect plutôt qualitatif.
Acheté pour driver un casque sennheiser HD800s il remplit très bien son rôle avec une bonne réserve de puissance. Sonorité neutre et limpide, du tout bon !
Pierre P.
TOPPING A90 DISCRETE Amplificateur Casque Préamplificateur Discret Symétrique Argent Topping revient avec le A90 Discrete, une amélioration du précédent A90, cette fois-ci équipé de composants discrets. À la fois...
Excellent preampli à prix modéré. Du fil droit avec du gain
restitution très neutre.
la télécommande est un peu capricieuse.
Pierre P.
Le serrage dans la prise n'est pas top et le câble n'est pas tenu fermement. Pour le reste c'est OK
Marc f.
fonctionne nickel très simple d'utilisation
Bruno M.
Un excellent produit !
Délivre un message musical extraordinairement détaillé et nuancé. (utilisation avec casque Ortho dynamique Kennerton Thror et un ampli casque à lampes AudioValve Luminare)... Je pense même en recommander un second prochainement pour pouvoir en profiter sur un second équipement ...
Jérôme H.
Rien à redire sur l'usinage et le maintien des câbles. Pas de dégradation non plus du signal sonore sur mon installation. C'est absolument transparent. Pour ceux qui ne veulent pas inutilement se ruiner dans des fiches haut de gamme, c'est un choix idéal.
Xenofon T.
next time i order from china
a cheap solution for diy. Cover and bottom plate are not well to mount. Actually this is a insult.
Sliding nuts... come on!.
All in all i payed for a impression that hifi2000 dont give a fu..
I builded 2 preamps. This case war for my own. The other for a friend. His case was a wellbuild aluminiumcase, complete milled, ready to go, ordered from china.
Pascal g.
SMSL AO200 MKII Amplificateur Class D Symétrique MA5332MS Symétrique Bluetooth 5.0 Subwoofer 2x160W 4 Ohm Le SMSL AO200 MKII est un amplificateur numérique Class D compact et performant, capable de développer une puissance de 2x160W sous 4Ω grâce à sa puce...
30 ans de certitudes audiophiles balayées en quelques secondes
Allez, je commence par 2 points négatifs : Le bluetooth est mauvais et les borniers HP n'acceptent pas les cables de grosse section avec fourches. Dommage, car cet ampli a des performances incroyables. Connecté à un streamer Aurender et un DAC Denafrips Pontus II en XLR, Il alimente à merveille mes capricieuses Thiel 2.4. Le registre grave est sublimé. Quelle énergie, présence et tenue ! L'aigu est fin et précis, la transparence est incroyable.Une prouesse à ce prix, et même bien au delà. J'ai possédé de nombreux amplis plus "ésotériques".. et beaucoup, beaucoup plus chers qui ne tiennent pas la comparaison (surtout dans le grave).La profondeur et la largeur de la scène sonore ne rivalisent pas encore avec des amplis HDG à x milliers d'Euros mais on parle ici d'un ampli à 249€ ! Mais commant font-ils chez SMSL ? La classe D a fait d'énormes progrès et ça s'entend clairement. ça donne envie de tester des modèles plus haut de gamme, Certaines marques "audiophiles " bien établies ont du soucis à se faire....
Et toujours une livraison ultra rapide de la part d'Audiophonics !
Excellent malgré (ou grâce à ! ) l'excès de basses
Je confirme beaucoup d'avis : rapport qualité/prix exceptionnel !
Associé au petit ampli Aiyima T9 (pourvu d'un DAC USB logiquement très basique à ce prix) , et tout aussi excellent en rapport qualité/prix mais dont le point faible est... le manque de basses en sortie ! , je vous laisse deviner l'avantage du mariage des deux.... , avec un rendu précis et une scène bien aérée sur mes FOCAL CHORA 806. Le son (Qobuz) qui sort alors de mon LENOVO (pas haut de gamme au demeurant) se révèle tout simplement comparable à celui d'un bon lecteur réseau...
Jean-Pierre B.
ELECAUDIO HP-25OFCS Câble Haut-Parleur Cuivre OFC Plaqué Argent Isolé PTFE 2x5.1mm² Ø7.5mm Le reconnu et réputé câble HP Elecaudio HP-25OCC revient dans une nouvelle version, toujours plus performante, le HP-25OFCS. Celui-ci reprend la même...
Le contexte :
Après avoir monté des pieds Kanto de 81 cm sous mes enceintes Blumenhofer Satellite Mini, initialement posées sur mon bureau, j'ai dû remplacer mes câbles MaxiTrans II de 2 fois 2,5 m par des câbles de 3.5 m au moins pour les relier à un Marantz Amp1. J'ai donc acheté 8 m de ce câble pour avoir 2 x 4 mètres et donc un peu de marge et je l'ai monté avec des fiches Bananes ETI KRYO.
Le montage :
Le câble est très épais avec une forte section et, si vous prévoyez un connecteur fourche ou fiche banane, assurez vous qu'il est assez grand (le ETI est limite). Sinon le montage est facile : dénuder le câble ne pose pas de problème particulier, le couper non plus (un gros ciseaux suffit).
A l'écoute :
J'étais persuadé que la notion de rodage était réservée aux moteurs de voiture, mais avec ce câble, je constate une très grande évolution après quelques heures d'utilisation : quelques fréquences stridentes se sont calmées et l'écoute est de mieux en mieux et globalement très bonne.
Conclusion :
Très bon câble avec un rapport qualité prix favorable, fortement recommandé si l'on cherche un câble dans une gamme de prix allant jusqu'à 50 euros le mètre, voire plus.
Ivan P.
Excellent product, very well made.
Ivan P.
Claude I.
Testé sur un système à haut rendement les résultats sont remarquables. L'écart entre les DACs premiers prix et le "haut de gamme" est beaucoup moins important qu'il y a 20 ans. Et ceci en tirant la qualité vers le haut. C'est l'ouverture et la spatialisation qui fond encore la petite différence. J'utilise le SU-1 comme une "carte son externe" pour extraire la musique de mon ordi et alimenter une bonne chaine de bureau. Résultat excellent.
Hugo B.
DAYTON AUDIO BST-300EX Haut-Parleur Vibreur Exciter 300W 4Ω Grand frère du BST-1, le BST-300EX offre une puissance de 300W avec ses Ø18cm de diamètre. Il vous permet de ressentir les fréquences basses non...
Very powerful
A single unit installed on a 3-seater sofa. The vibration is felt along the sofa at a third of the amplifier volume. I would definitely buy it again.
Adrien H.
DYNAVOX Connecteurs RCA Plaqué Or Ø4mm (Set x4) Ces connecteurs RCA de belle qualité profitent de contacts plaqués or, assurant une bonne conductivité électrique et résistance à...
Connecteur tout en métal, construction logique, prix raisonnable. Très satisfait.
Adrien H.
Très souple !!
Diamètre un peu gros mais qui correspond aux specs. La gaine est tres souple et permettra un routage facile du câble.
Adrien H.
Module Softstart 230V 15A pour Amplificateurs Ce module permet de commuter la sortie entre 1 et 2 secondes après avoir été alimenté. Pendant ce laps de temps, le courant d'appel est amorti par la résistance de 15W. Il se...
Fonctionne parfaitement
Installé dans un ampli avec deux transfos toroidaux. Pas encore mesuré la différence de courant inrush mais le produit fonctionne parfaitement.
Fabien B.
Parfait!
Fabien B.
Fabien B.
Aleksandr V.
Great!
works great in the middle and high frequencies section
Waldemar C.
IAN CANADA SC-PURE Horloge Femtosecond Ultra-Faible Bruit de Phase 49.1520MHz Le SC-Pure de Ian Canada est une horloge audiophile high-end, fabriquée à partir de cristaux SC-CUT de haute qualité. Afin d'obtenir les meilleures...
excellent - as all SC-Pure Ian.s clock.s
worth every penny....
Aleksandr V.
Great!
Aleksandr V.
JANTZEN AUDIO CROSS-CAP Condensateur 400V 22µF Les condensateurs Jantzen Audio Cross Cap MKP 400V sont considérés comme étant le meilleur rapport qualité/prix pour la conception de filtres passifs...
a good product for the low frequency section
I bought for the upgrade of the Dali opticon 8 crossover, I am very happy with the result!
Claude T.
Bizarre
Lorsque ce câble est apparu sur le site Audiophonics, j'ai cherché ce que pouvait bien être le traitement réalisé par la société Physis concernant la couche de carbone entourant le conducteur OFC.
J'avoue avoir bien ri et me suis demandé ce qu'il pouvait bien fumer après avoir lu les caractéristiques sonores apportées par leur fameux traitement.
Ne trouvant aucun commentaire sur le WEB, je me suis décidé à en commander, juste pour voir.
Pour mon système Tannoy D700 et ampli GATO 400S ce sera certainement le dernier câble.
Brièvement, les enceintes semblent avoir disparu et le son remplit toute la pièce... Je n'en dirais pas plus sur les qualités du produit. Très bizarre comme effet, et j'avoue ne pas trop comprendre.
Tubes ultimes
En paire appairee, ce duo offre une scène large, profonde haute ! 3d immersif !
Une sublime restitution dans tout le spectre.
Vraiment des tubes de haut vol et musicaux comme jamais.
Comparé à tung sol, TAD ecc803s, EH, ils sont loin mais très loin devant ! .
Transcendent un système hifi.
Jeanphilippe c.
Smsl ad18
Je vous raconte mon histoire je possède depuis quelque temps un amplificateur yamaha As701 connu de tous. A ma grande stupeur je me suis rendu compte que le son numérique du smslAD18 était pour moi un niveau au dessus. Clarté du timbre des voies. Le yamaha est très bon mais le Smsl a un son plus chaud. Il sont connecté à mes vieilles Philips rh 2253. À l’écoute sur celle ci c’est le Smsl qui gagne le match largement. Ce qui me fait peur c’est sa durée de vie. Espérons quil ne souffriras pas d’obsolescences. Merci à audiophonic pour sa rapidité. Je pense à l’avenir rester sur du numérique avec le Smsl a2.a bientôt. Je recommande ce produit.
Waldemar C.
IAN CANADA SC-PURE Horloge Femtosecond Ultra-Faible Bruit de Phase 45.1584MHz Le SC-Pure de Ian Canada est une horloge audiophile high-end, fabriquée à partir de cristaux SC-CUT de haute qualité. Afin d'obtenir les meilleures...
Simply excellent !
worth every penny ....
ISMAEL C.
PINTA AMORTSON Bi5A PHD
Hello, good quality of the article. Fast shipping to Spain...perfect!!!
Patrick D.
Adaptateur Secteur Alimentation 100-240V AC vers 48V 7A DC Cet adaptateur secteur prend en entrée une tension de 100-240VAC pour sortir du 48VDC 7.3A (350W). Les composants sont intégrés dans un châssis en...
Très bien avec un FOSI BT20A Pro
Avec mon FOSI Audio livré à l’origine avec une alimentation 32v, l’apport de cette alimentation 48v est bénéfique. Plus que la puissance , elle apporte de la matière et de la vivacité.
L’appareil paraît solide.
Un bon achat.
Patrick D.
FOSI AUDIO BT20A PRO-32V Amplificateur Class D TPA3255 Bluetooth 5.0 2x220W 4 Ohm Le Fosi Audio BT20A PRO est un amplificateur Class D compact et puissant, proposé à prix contenu. Son étage d'amplification utilise une puce TI...
C’est bien un ampli hifi
Ne pas se fier à sa taille. Il est puissant, le son est précis mais pas trop, vivant, délivrant une scène sonore crédible. Aucune fatigue auditive, les aigus sont doux et les basses bien tenues.
Je l’utilise avec un preampli XDUOO MT-603 qui dispose de 4 entrées dont 3 RCA, un lecteur réseau Yamaha WXC-50. Sur des enceintes bibliothèque KEF IQ10 ça donne vraiment bien. Le Bluetooth n’est pas super qualitatif, c’est juste pour dépanner. Les correcteurs de tonalité fonctionnent bien mais j’ai tout laissé à Odb, pour moi c’est très bien comme ça (après ça dépend de la pièce d’écoute).
Pour le prix franchement il fait bien mieux que certains amplis beaucoup plus cher !
Philip G.
ORACLE II 02 AOP Discret Double DIP8 (Unité) L'AOP double Oracle II 02 représente une nouvelle génération d'amplificateur opérationnel discret hybride, spécialement conçu pour...
Que dire...
Une claque. Installé dans mon FOSI V3 (48V), la différence est immédiate. Donne une tonalité d'ampli à tubes avec clarté et définition. Utilisé dans mon setup: Tinker Board+Volumio+Ares 2.
Un Must et pour le prix, y'a pas à hésiter...
david v.
ARYLIC S50 PRO+ Lecteur réseau audio DAC ES9023 ADC WiFi AirPlay Bluetooth 5.0 aptX HD Arylic propose avec son S50 Pro+ un préamplificateur stéréo connecté, ayant la particularité de profiter d'une connectivité...
nikel sauf lecture usb
rien a dire sauf que la lecture avec clef usb bug pas mal
david v.
AIYIMA A08 PRO Amplificateur Class D TPA3255 2x220W 4 Ohm Bluetooth 5.0 Aptx-HD LDAC Le Aiyima A08 PRO est un petit amplificateur Class D, très puissant, performant et abordable. Il se base sur une puce d'amplification TPA3255 et un AOP NE5532P, lui...
tres satisfait du son et de la puissance .
Kari J K.
Garba
Superb product,fast delivery,merci!
André G.
Fiches bananes wM de qualité
Ces fiches plaquées or sont pratiques et se connectent avec un excellent maintien et sont d un très bon rapport qualité prix. A recommander
jean luc d.
modification du module de controle
les condensateurs qui permet de crée une latence au niveau des vu metres , ne sont pas suffisant, il faut rajouter un condensateur en parallele sur les vu metres 220 uf 50 v bipolair.
remplacer l"ampli op par un lm 358 , les reglages des trims sont tres delicat . les condensateurs juste à cote du regulateur de tension c'est pas terrible.
Gilbert H.
Multiprise DIY Aluminium 8 Ports Schuko Noir Cette multiprise DIY intégrant 8 ports schuko avec mise à la masse profite d'une très bonne qualité de conception, idéale pour alimenter...
Un bel objet de bonne facture. De bons contacts, des prises qui tiennent bien, et la possibilité de le fixer au mur ou sur un support en bois est vraiment un plus.
Par contre les prises n'ont pas d'obturateurs pour le sécurité enfants... donc non conforme à la NFC 15100, donc une étoile en moins.
Jacek C.
Very good choise
I didn't expect such good sound quality in all aspects for this price. Audiophonics service and delivery are, as always, at the highest level. I highly recommend.
Jean-Pierre D.
Une révélation en matière de transparence, de fluidité et de détails
Je souhaitais avoir un amplificateur de puissance Hi-Fi qualitatif sur mon système multicanal (j’écoute pas mal de vidéos, plutôt musique classique) et les deux enceintes colonnes Triangle Signature Delta qui sont dynamiques et brillantes dans l’aigu souvent associées à des amplis à tubes et assez exigeantes au niveau de l’électronique associée, mon amplificateur intégré multicanal est le Denon 8500HA plutôt adapté à ce type d’enceintes et assez neutre.
Un modèle Purifi, système d’amplification réputé pour leur neutralité et leur transparence ainsi que leur finesse musicale, s’avérait être une bonne option, mais généralement prix élevé comme chez NAD. Ce HP-S400 ET a retenu mon attention, prix intéressant et performances sonores impressionnantes (mesures et qualités musicales), les avis sur ce site ont fini par me convaincre, ainsi qu’un échange avec le conseiller d’Audiophonics.
Depuis que je l’ai connecté à mon système, jusqu’ici j’avais un Nuprime MCX (classe D également) plus usage Home Cinéma et musique, là, avec l’HP-S400 ET, j’avais des détails beaucoup plus fins et retranscrits précisément et un équilibre très naturel, très bonne spatialité (largeur et profondeur). Très agréable à écouter, musical, neutre et fluide, je pense vendre le Nuprime, sur cette catégorie d’ampli de puissance à moins de 2000 euros, peu de propositions de la part des constructeurs.
Cet Audiophonics a une valeur exceptionnelle à mon avis, sa facilité à fonctionner avec beaucoup de configurations (préamplis et enceintes), je ne pense qu’il y a peu de concurrents à son niveau en classe D, très pratique lorsque l’on n’a pas l’espace suffisant pour des amplificateurs plus volumineux et lourds comme les classes AB ou A. De plus, pour ceux qui s’en servent sur une configuration Hi-Fi avec un meilleur préamplificateur, la qualité sonore doit être encore plus élevée.
très bon tube
Installer sur un ampli guitare en lieu et place d'un tube made in "China". Cette 12ax7 m'a littéralement envoyer dans une autre dimension musicale ..Présence accrue des basses précises, Crush ,overdrive et saturation ..médiums améliorés et aigus parfait ..
Cyril D.
Impressionnant !
1er ampli casque pour moi, mon Meze 109 Pro était auparavant branché sur un intégré Atoll IN200 Signature.
Testé avec des câbles secteur et RCA "basiques" et branché en asymétrique pour le moment, cet ampli casque a tout de même apporté beaucoup de choses positives :
Les plus :
- Énorme gain de puissance, en low gain sur le HA-B6120 et avec le bouton volume à peine au tiers, je suis à l’équivalent du volume 60 sur l’Atoll
- La scène sonore est transcendée : beaucoup plus profond et large, presque un effet 3D supplémentaire
- Beaucoup plus de détails
Les moins :
- Ampli qui n’est pas de classe A, donc moins chaleureux qu’un Atoll (et je parle pas des amplis à lampes) et aigus un peu plus tranchants.
- Légère perte de graves (mais ça vient peut être des câbles qui sont basiques)
A voir comment ça sonnera avec un upgrade de câbles. Même un ampli de ce prix mérite un bon câble secteur pour être alimenté dans de bonnes conditions.
En tout cas le rapport qualité/prix est très impressionnant ! Je recommande sans hésiter !
Codrat-Alin T.
Excellent rapport qualité/prix !
Je débute dans la HiFi.
J'ai pris ce SMSL SU-1 DAC pour compléter un Ultima Kombo 20 de chez Teufel afin d'améliorer le DAC de mon installation Teufel et de pouvoir brancher ma TV et console (via toslink) sur l'installation.
Le gain de qualité par rapport au DAC de mon installation est sensible.
Et les tests sur Internet confirme ce ressenti.
Pour le prix, c'est parfait et je recommande !
Pieds Caoutchouc Amortissant Ø18x10mm Noir (Set x4) Ces pieds en caoutchouc amortissant d'un diamètre de 18mm et d'une hauteur de 10mm se collent simplement sous vos appareils à l'aide du double face 3M fourni pour...
Pour le prix, ces pieds sont trés efficaces et pratiques
MONACOR SPS-35 Pointes de Découplage Gris Chromé (Set x4) Voici un set de quatre pointes de découplage Monacor SPS-35 de couleur grise. Ces pointes sont idéales afin de réduire et amortir les vibrations de vos appareils ou enceintes.
Des pointes sérieuses
Pointes belles, trés efficaces qui nécessitent des contrepointes toutes aussi sérieuses.
Contrepointes Aluminium avec Anneau Caoutchouc 50x19mm Argent (Set x4) Ces contrepointes en Aluminium seront parfaite pour une installation sous des appareils HiFi (amplificateur, préamplificateur, DAC...) ou sous des enceintes, afin de...
Trés efficaces
Installées sous des pieds d'enceintes, ces contrepointes sont trés efficaces avec des pointes de bonne taille.
