MUNDORF L140 Self à Air 1.40mm. 15.00mH
Référence : 1671
69,50 €TTC
57,92 € HT
Disponible
Date d'expédition : 20-03-2019.
MUNDORF L140 Air Cored Coil 1.40mm 15.00mH
Air cored coils are, for physical reasons, unbeatable as far as accurate pulse reproduction and freedom from distortion are concerned.
For this reason, for all the purists, we stock air cored coils with wire diameters of up to 3.0 mm.
It is also possible in this way to create greater inductances with relatively low internal resistance.
Vacuum impregnation also leads in the air cored coils described here to greater detail and spatial quality in the reproduction of music.
Technical Specifications :
  • Electrolyte copper 99.99 %
  • Pure Coil forms : PA, glass fibre reinforced
  • Tolerance : Max 3%, typically 1.5%
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_1.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_3.jpg
https://www.audiophonics.fr/images2/4539-4567_MUNDORF-L100-140_4.jpg
Modèles Diamètre du Fil /mm
L/mH
R / Ohm
Puissance max (8 Ohm)
Dimensions
L140-0101.400.100.07
267 W
40 x 20mm
L140-0121.400.120.08265 W  40 x 20mm
L140-0151.400.150.10237 W 40 x 20mm
L140-0181.400.180.11251 W 58 x 18mm
L140-0221.400.220.12248 W58 x 18mm
L140-0271.400.270.13245 W58 x 18mm
L140-0331.400.330.15227 W  58 x 18mm
L140-0391.400.390.16239 W 58 x 18mm
L140-0471.400.470.19213 W  58 x 18mm
L140-0561.400.560.20192 W 58 x 22mm
L140-0681.400.680.23197 W 58 x 28mm
L140-0821.400.820.26184 W 58 x 28mm
L140-1001.401.00.30168 W  58 x 28mm
L140-1201.401.20.34164 W70 x 29mm
L140-1501.401.50.38156 W  70 x 29mm
L140-1801.401.80.43146 W 70 x 29mm
L140-2001.402.00.45148 W 70 x 29mm
L140-2201.402.20.46152 W  70 x 29mm
L140-2701.402.70.51133 W 77 x 28mm
L140-3001.403.00.55131 W 77 x 28mm
L140-3301.403.30.58123 W 77 x 28mm
L140-3901.403.90.65103 W 77 x 28mm
L140-4701.404.70.8098 W 70 x 59mm
L140-5601.405.60.8986 W 70 x 59mm
L140-6801.406.81.189 W 70 x 59mm
L140-8201.408.21.194 W 70 x 59mm
L140-10001.4010.01.293 W 88 x 75mm
L140-12001.4012.01.4100 W 88 x 75mm
L140-15001.4015.01.613 W 105 x 92mm
Colissimo - TNT - SoColissimo
0,00 € Dont TVA 20%
