Jean-François D.
Impeccable !
Vasilios K.
Ça Chauffe !
Avis clients - Il y a 19303 avis.
Siegfried F.
AUDIOPHONICS AP300-M450ET Amplificateur de Puissance Class D Mono Purifi 1ET6525SA 1x450W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics AP300-M450ET, un amplificateur de puissance mono Class D basé sur un module Purifi 1ET6525SA. Cette version...
Ivan S.
SINGXER SDA-6 PRO2 DAC Symétrique 2x AK4499EX AK4118 FPGA XMOS I2S LVDS 32bit 768kHz DSD512 Le SDA-6 PRO2 de Singxer, seconde version du SDA-6 PRO, est un DAC symétrique haute fidélité. Il présente de nombreuses améliorations par...
IvanS
This is a truly exceptional piece of Hardware. The background sound is absolutely black to the point of incredible silence between passages or breaths. The tones and voices sound really true and the bass goes amazingly deep. Every instrument is exactly where it should be. Sometimes I find myself wanting to touch the musician's guitar because it is so precisely materialized in space.
I had borrowed an Eversolo DMP-A10 from a friend. It's a good machine but the Singxer outperforms it in all aspects.
I can only recommend it to everyone because after listening to it you will not think about replacing it for a long time.
Rumen S.
Excellent match!
This cable demonstrated perfect compatibility with systems featuring full-range speakers, particularly rear-loaded horns. Neutral, without exaggeration, and with a refined treble finish, the OYAIDE EXPLORER allows the drivers to reach their full potential. Highly recommended, especially for systems with single-ended tube amplifiers.
pascal P.
FOSI AUDIO BOX X2 Préamplificateur Phono MM à Tubes 2x6A2 Stéréo Noir Avec son préamplificateur à tube BOX X2 Fosi Audio dévoile un appareil Hifi abordable et qualitatif pour les personnes désirant profiter du...
Une merveille
Parfait à tous points de vue. Recul de bruit, distortion, dynamique tout est au top. Rapport qualité prix hallucinant. J'ai revendu mon préampli phono de grande marque à 200 € qui était loin derrière. Aucune hésitation pour ce produit. N'écoutez pas les forums qui disent que les tubes ne servent à rien : si , ils régulent la tension, même s'ils ne sont pas sur le signal. A quand un modèle mc ?
Impressionant...
Jusqu'alors, j'étais sceptique sur ce que pouvait apporter le traitement de l'alimentation électrique à un système audio. Pour mon système NAD C326 BEE / Davis acoustics Krypton 6 / câble Real cable TDC, 5mm2 dont je suis dans l'ensemble très satisfait, je trouvais des fois les basses un peu limites. Après avoir lu les différents avis, j'ai tenté le coup avant d'envisager plus précisément l'hypothèse d'un passage aux krypton 9 .
Bien m'en a pris ! Dès les premières secondes, j'ai ressenti les basses plus profondes et percutantes, sans en faire trop, exactement ce que je souhaitais, et une scène sonore plus élargie, plus riche, plus vivante, et ce pour une centaine d'euros !
Moralité : accessoire à tester, avant de système décider de changer !
joel V.
trés bon cable secteur
Paul V.
TOPPING LA90D Amplificateur Discret Class AB 2x120W / 1x180W 4 Ohm Argent Topping propose maintenant l'excellent LA90 dans une version utilisant des circuits discrets, le LA90 Discrete. On retrouve ainsi un amplificateur puissant offrant d'incroyables...
Topping LA90D power amplfier
I am very satisfied with the Topping LA90D power amplifier. I purchased four units to build an 8-channel active speaker setup. They are very solidly built and have a beautiful, professional appearance. The price-to-performance ratio is excellent. Their performance is outstanding. The measured specifications show exceptionally good results, with extremely low distortion figures. This results in a very pure sound without any coloration. In our opinion, this amplifier is highly recommended for use in a top-quality audio setup. The Topping LA90D performs as well as — and often better than — many other power amplifiers that are significantly more expensive.
Paul Vancluysen VCLLabs
Paul V.
AUDIOPHONICS WIRE Câble de Modulation RCA Mâle vers XLR Mâle Stéréo Cuivre OFC Plaqué Or 1.5m (La paire) La gamme Audiophonics Wire propose une sélection de câbles abordables mais pour autant performants, assemblés à la main dans nos ateliers, en France....
Very sastified about this product. Very flexible cable, high quality connectors. Good solid connection. In general, we have very good experience with produts made by Audiophonics Workshops.
Stephane M.
Installées sur un pré RIAA où les anciens tubes étaient devenus bruyants. Faible bruit de fond et ne semblent pas microphoniques.
Désolé, pas fait de mesures: Plug and play :)
Luboš W.
Rating
I use the power supply as a symmetrical power supply (2 pcs) to a low watt amplifier. It is almost noise free, no problems so far.
Johan v.
LB Interrupteur Aluminium avec Cercle Lumineux Bleu 220V Ø12mm Argent Interrupteur de type 1NO avec indicateur lumineux bleu. Fonctionne à partir d'un mécanisme bistable (deux positions).  Les connecteurs dédiés au...
Good but small
Good switch but the button is small so not thumb size but more pinky sized
Johan v.
My favorite hook up wire
Easy to strip with a good stripper
Johan v.
Good quality easy to fit and solder
When soldering this type of terminal a good powerful soldering iron or station is helpful.
SHANLING ET3 Lecteur CD Philips SAA7824 Sanyo HD850 WiFi DLNA AirPlay Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Noir Le Shanling ET3 se présente comme un lecteur CD complet et puissant, proposant un design moderne et offrant d'excellentes performances sonores. Polyvalent, il met...
presque parfait
Les plus:
Le chargement et le palet presseur
Le silence total de fonctionnement et plutôt rapide
Le look et la taille compacte
La connectique très complète
Le surechantillonage fonctionne très bien
Les moins:
Une télécommande vraiment pas bonne lente,ultra directive
L impossibilité d accéder directement a une plage du cd
Si vous aviez l idée de l utiliser comme un mini streamer vous pouvez oublier. L appli est très mauvaise.
Johan v.
Good product
Good product good quality when soldering remove the nut to lower the thermal mass it makes soldering easier.
l argent a fait mon bonheur
Fantastique cable .précis détaillé pas tres loin d être analytique tempéré dans mon système haut rendement par le furutech violet qui prend le signal en charge a la sortie du monoceros. Il fait donc la liaison entre le holo spring 3 et le monoceros.
L alliance entre l argent du neotech et le cuivre du furutech me plaît bien.Monté sur xlr EIZZ
Jizhuang S.
HOLO AUDIO MAY LEVEL 2 DAC R2R Symétrique et Alimentation Indépendante 32bit 1536kHz DSD1024 Après 3 ans de recherche et développement pour parvenir à un tout nouveau niveau de performance et de qualité sonore, HoloAudio présente son...
Holo Audio May 2
Je rajoutera la comparaison suivante qui me semble assez judicieuse, le Holo Audio May 2 correspond très bien au jeu du violoncelliste Pierre Fournier jouant sur des cordes en boyaux argent. Un jeu d'une élégance extrême, raffiné, aristocratique, mais un poil moins spontané que celui de Daniil Chafran ou de Jacqueline Du Près. Mais surtout ne pas penser que c'est un DAC HiFI, les émotions sont bien là, simplement elles ne sont pas jetées à la face de l'auditeur. Pour une personne à la recherche d'un DAC dont la signature sonore se rapproche des grands interprètes ( violon, violoncelle, piano, ... ) des années 1950, ce convertisseur est exceptionnel, même en comparaison à des DAC comme MSB, Esoteric et C°.
Jean-Michel P.
Déborde très peu de la face AV de l'ampli
Tout à fait satisfait.
Il a juste fallu que je ressorte le fer à souder, bien rangé depuis une dizaine d'années :)
Jean-Michel P.
Amélioration du son
Branché en entrée de mon Eversolo, j'ai tout de suite noté un son mieux installé, plus propre.
Par contre, j'avais initialement acheté ce filtre pour éviter des coupures de son en streaming (fibre, rj-45 de la box au streamer, mais beaucoup de domotique)
Cela n'a pas été concluant et les coupures sont restées.
Depuis, le problème de coupures a disparu. Pourquoi ? je l'ignore (mise à jour logiciel, sans doute, mais lequel ? voire lesquels ???)
Jean-Michel P.
EVERSOLO BTR-12 Télécommande IR / Bluetooth pour DMP-A6 / DMP-A6 Master / DMP-A6 Gen 2 / DMP-A6 Master Gen 2 Cette télécommande IR / Bluetooth BTR-12 proposée par Eversolo a pour vocation d'être appairée à tous leurs appareils de la gamme DMP,...
Conforme
Télécommande basique, utile si (pour une raison ou une autre) on ne veut utiliser ni l'écran tactile, ni son smartphone.
L'avantage est que la. télécommande fonction en BT, non directif
Jean-Michel P.
XDUOO MX-01 Transmetteur Bluetooth 5.3 aptX Adaptive Avec son MX-01, la marque xDuoo dévoile un transmetteur Bluetooth 5.3 performant. Ce dernier incorpore une puce de la marque Qualcomm, gage de stabilité et de...
Transmetteur utilisé en émetteur (de mon ampli vers un casque B&W)
Appairage un peu difficile : bien penser à éteindre / couper les appareils BT à proximité SAUF le casque (dans mon cas).
En effet, il est impossible de savoir avec qui le MX-01 est appairé !
Sinon, fonctionne sans problème
Francis B.
Étonnant
Un peu plus de transparence.
Un peu plus de profondeur dans les basses.
Pas mal vu l’investissement raisonnable! Excellent.
pascal B.
DAYTON AUDIO TD20F-4 Haut-Parleur Tweeter Néodyme 20W 4 Ohm 90dB 3000Hz-20kHz Ø1.9cm Le tweeter à dôme en soie Dayton Audio TD20F-4 intègre une membrane optimisée qui combine une faible masse, un superbe amortissement et un profil de...
petit tweeter
rapport qualité/prix exceptionnel pour ce petit tweeter qui associé à 1 large bande de 13 cm a permis de restaurer de façon très convaincante des micro enceintes
Eric v.
connexion
Eric v.
Eric v.
Foret Étagé Acier HSS-4241 15 Niveaux Ø4-32mm Ce foret étagé à 15 niveaux, de 4mm à 32mm, et conçus en acier HSS-4241 permet de percer des matériaux tels que le fer, l'aluminium ou...
Bon outil , l'acier a l'air de qualité.
Dominique S.
Bon coffret.
Rien à dire, ces coffrets sont presque parfait. L'aluminium, c'est un plaisir à percer déjà et l'esthétique est top. Comme certain le signale, on peut trouver le brossage un peu rugueux, mais un passage léger et régulier au papier abrasif fin règlera le problème, attention, léger, n'aller pas enlever la peinture non plus.
Alors vous me direz que j'ai écrit "presque parfait" un peu plus haut. C'est parce que, selon moi, pour être parfait, il faut remplacer la tôle du fond par la plaque alu correspondante et disponible sur ce site.
Robert C.
FOSI AUDIO ZD3 DAC ES9039Q2M Bluetooth 5.0 32bit 768kHz DSD512 Le ZD3 de Fosi Audio est un DAC symétrique possédant une excellente connectivité grâce à ses multiples entrées et à sa puce...
Compact DAC pact with features but...
After experiencing more expensive and objectively better-built DACs with various topologies (e.g., AKM-based, R-2R, and FPGA-based designs), I can't give this product a higher rating in terms of sound quality.
Subjective listening tests across my different setups—one with Class D amps, and the other with tube amps, both using high-efficiency speakers—consistently produced the same result: a linear, analytical, and overly digital sound. The sound stage feels shallow (almost flat), and the vocals are very sibilant. After certain time the listening becomes fatiguing (at least for me).
Some improvements can be achieved through OPA swapping (e.g., Sparkos SS3602 or other discrete op-amps), but at that point, you can achieve similar or even better results with a Topping E70 Velvet.
Further improvement, in soundstage development, can be achieved with tube preamplifier.
On the other hand, the functionality of the ZD3 is excellent for such a compact DAC: RCA and XLR outputs, 12V trigger support, and a built-in preamp with remote control. So, if you prefer the functionality over sound quality this can be good fit for you.
Dominique S.
Connecteurs RCA Plaqué Or Ø8mm (La paire) Gris Ces connecteurs RCA de belle qualité profitent de contacts plaqués or, assurant une bonne conductivité électrique et résistance à...
Très bon.
Jai assemblé récemment un câble avec ces fiches et le rapport qualité/prix me semble excellent, en comparaison avec d'autres marques plus chères dont le prix ne semble justifié que par la marque justement (par ex. F______H) .
Bastien S.
Qualité médiocre, échangé contre ref 8716
J'en ai acheté deux en prévoyant que l'un ne fonctionnerait pas (ou pas longtemps).
Et j'ai bien fait car sur l'un deux, un des deux jack ne sortait qu'un canal stéréo.
Je l'ai signalé à Audiophonics qui m'ont très gentiment proposé un splitter en échange (ref 8716).
J'ai trouvé ce dernier bien plus qualitatif, et il fonctionne parfaitement.
Jean-François S.
LINDY CROMO LINE Câble Numérique Coaxial SPDIF Cuivre Plaqué Or 0.5m Le câble SPDIF Coaxial Lindy Cromo Line profite d'une belle qualité de conception. Ses conducteurs sont faits de Cuivre assurant une très bonne...
Remplit sa fonction
à moindre coût. Certes il parait fragile mais si on l'utilise à poste fixe, une fois installé on n'y touche plus, c'est pas un problème.
Jean-François S.
Fait son boulot...
et une version longue peut être utile selon l'épaisseur du boitier... face avant...
Dominique S.
ELECAUDIO ER-109 Embase RCA Plaqué Or Noir (Unité) Voici l'embase ELECAUDIO ER-109, avec un diamètre extérieur du filetage 8 mm, doré véritable, version à souder.
Bon produit.
Je trouve que ces embases RCA sont de très bonne qualité et d'un excellent rapport qualité/prix. Je les ai d'ailleurs adoptées dans toutes mes réalisations.
Jean-François S.
FOSI AUDIO DAC-Q4 DAC PCM5100 Amplificateur Casque MAX97220 24bit 192kHz Compact, polyvalent et particulièrement abordable, le Fosi Audio DAC-Q4 endosse avec brio les fonctions de DAC et amplificateur casque. Idéal pour une installation...
Polyvalent mais...
Attelé à un lecteur CD - DVD - Blue Ray etc... de chez Sony qui ne dispose pas de sortie audio il permet soit l'écoute au casque soit d'envoyer un signal analogique sur un ampli audio. Tout ça fonctionne mais l'écoute au casque avec les correcteurs de tonalité en position "neutre" - " à 12 h " manque de graves. Précisons que le même casque donne toute satisfaction par ailleurs et d'un autre côté que s'il y a des corrections de tonalité sur le DAC autant s'en servir...
Dominique S.
Bonnes bornes.
Ces bornes HP sont de très grande qualité, assez massives (grosses) mais ce n'est pas un défaut, il faut juste en tenir compte si on n'a pas beaucoup de place dans un coffret. Ce qui n'est pas mon cas, et j'ai d'ailleurs adopté ce modèle pour tout mes amplis DIY.
AMPHENOL AC3MMDZ Embase XLR 3 Pôles Mâle Plaqué Argent Cette embrase XLR 3 pôles mâle Amphenol AC3MMDZ, propose un plaquage en argent de ses connecteurs pour une conductivité maximal. Le corps plaqué en...
embase XLR-M
bon produit, sans surprise et commande assez rapide
Dominique S.
Bon produit.
Ce sofstart fait ce qu'on en attend et correspond à la description. Cependant, dans mon cas, mis en route par un bouton poussoir monostable, il faut appuyer feux fois de suite sur ce dernier pour obtenir la mise en marche, et, lorsque l'ampli est mis hors tension secteur et que j'appuie sur le BP un déclenchement du relais se fait entendre. Cela aurait-il un rapport avec le condensateur qu'il faut éventuellement enlevé comme signalé dans la description, si quelqu'un a une idée?
Dominique S.
Pointe de Découplage M4 Aluminium Caoutchouc Ø41x28mm Noir (Unité) Cette pointe de découplage est faite d'Aluminium. Elle est entourée d'un anneau en caoutchouc amovible. L'association de ces deux matériaux permet...
Bonne pointe.
Ces pointes massives seront parfaites sous des enceintes tout aussi massives, associées aux contrepointes portant la réf. 8634 sur ce site, l'effet esthétique est indéniable. Oui, mais d'un point de vue sonore me direz-vous, et bien j'ai constaté que le grave y avait gagné en subtilité, me semble-t-il.
Kevin R.
Parfaites
Ces fiches sont de très bien conçues !
Dominique S.
2SC5200 / 2SA1943 Module Amplificateur Mono Class AB 250W 4 Ohm (La paire) Ces modules amplificateurs de puissance mono délivrent une puissance de 250W sous 4Ω. Il sont composés sur leur étage d'amplification de 6 transistors...
Modules sympas.
Je ne vais pas juger la conception du produit, je n'y connais pas grand chose. En pratique, on peut se faire un montage double mono propre et net vu que chaque module intègre son alimentation et sa protection HP. Vous ajoutez un ou deux transfo, un softstart, les connexions et c'est tout, pas trop de fils dans tout les sens. Dans mon cas, chaque module est alimenté par un transfo de 250 VA, 35 V après un softstart qui permet l'allumage/extinction. Après montage et première mise en route, j'ai constaté qu'il chauffait pas mal et je n'ai pas utilisé les radiateurs fournis (réutilisés ailleurs) et je l'ai monté en coffret (hifi 2000) avec dissipateurs. Autre petit détail, pensez à diminuer la valeur de la résistance ajustable avant la première mise sous tension car la tension peut être très élevée, vous économiserez quelques fusibles.
Kevin R.
RAMM AUDIO E72 Câble de Modulation Cuivre OCC Ø8mm Le câble de modulation Ramm Audio E72 offre une excellente qualité de conception, pour une parfaite transmission du signal. Il intègre ainsi deux...
Ce câble de modulation Ramm Audio E72 est vraiment très bon. Je l'ai assemblé avec des fiches XANGSANE XS-T1061(qui sont très bonnes aussi). Cela fait 3 mois qu'il est en place et j'en suis très satisfait.
Dominique S.
SOMMERCABLE Connecteur Secteur Schuko Type E/F 16A IP54 Ø13mm Ce connecteur secteur Schuko robuste et abordable de chez Sommercable vous permettra de concevoir des câbles d'alimentation de qualité à petit prix....
Excellent.
Cette prise est techniquement parfaite en tout point. Rien à voir avec les saloperies que l'on trouve en général dans les magasins de bricolage.
Dominique S.
Bouton Poussoir Aluminium Anodisé avec Symbole Power Lumineux Bleu 1NO1NC 250V 5A Ø19mm Noir Ce bouton monostable (une seule position) 250V 5A en Aluminium anodisé intègre une LED de couleur bleue et un symbole Power du plus bel effet. Il est idéal...
Très joli.
Très joli, fait son petit effet. Manipulation très agréable, le mouvement est fluide et le bouton émet un petit clic lorsqu'il est enfoncé.
Frederic d.
Plaque murale Aluminium embase Schuko pour FURUTECH FI-E30 Noir Nous avons conçu cette plaque murale tout en aluminium pour habiller l'embase Furutech FI-E-30 (G) et FI-E-30 (R) et ainsi la tranformer en prise murale complète.
L'illustration ne correspond pas au produit recu. Sur la photo on voit la plaque murale en aluminium brossé, l'embase recue est en alu mais pas brossée, beaucoup moins joli...
Ely R.
SPEAKER SNAP Fiches bananes Plaquées Or Ø4mm (La paire) Ces fiches bananes Speaker Snap sont plaquées or pour une résistance optimale à la corrosion et à l'érosion. Par ailleurs, elles se...
bon produit , bon site.
bonjour, produit reçu en bonne état, correspond a la description, efficace a l'usage. je suis satisfait de mon achat sur votre site.
Bogdan-Mihai M.
TOPPING PROFESSIONAL E2X2 Interface Audio USB 2 Entrées 2 Sorties 24bit 192kHz Noir Topping propose avec la E2x2 une excellente interface audio, pensée pour les musiciens et professionnels de l'audio. Cette excellente interface offre un très haut...
I really don't think you can find anything better at this price point
I got it because my focusrite interface (Solo 3rd gen) would keep disconnecting and wasn't working all that well for me.
Input & output sound quality exceeds expectations. Latency is very good too. Build quality is great, mostly metal.
I highly recommend this.
You can also find a detailed review of it here:
https://www.audiosciencereview.com/forum/index.php?threads/topping-e2x2-audio-interface-review.49127/
David M.
BURSON AUDIO V7 VIVID PRO AOP Double (La paire) Évolution du V6 VIVID, le V7 VIVID Pro se distingue par sa clarté, sa précision et sa dynamique élevée. Il...
Excelente sonido, pero.....
Compré estos para compararlos con unos DEXA que tengo instalados en un DAC eastern eléctric minimax DAC plus mk2.....
Lo primero que tengo que advertir es que esta reseña u opinión está publicada después de realizar la comparación entre los DEXA que tenía instalados y ya rodados y los burson V7 vivid recién estrenados, es decir, sin rodar.
Este DAC monta un par de opamps dobles y un par simples, y la comparación ha sido cambiando los 4.
Bien, el sonido de los V7 es realmente excelente. Los graves son articulados y bastante profundos, medios bien definidos y nada estridentes, agudos refinados y transparentes. Tiene una buena escena, con bastante anchura y buena profundidad, es muy estable y los instrumentos están bien localizados.
Lo que menos me ha impresionado es la dinámica, aunque, como ya he dicho, la prueba la he realizado si que tuviesen ningún rodaje previo.
Tengo que decir que los V7 vivid dobles se calientan bastante.
Comparados con los DEXA, estos últimos consiguen una gama baja con más garra, muy profunda y exuberante. La zona media también me ha parecido mejor, sobretodo en las voces o instrumentos de viento, muy holográfica, y por arriba más transparente. En general me han gustado más los DEXA, además la escena es bastante más tridimensional y espectacular, y la colocación de los instrumentos más estable.
Como ya he dicho, los dexa están rodados y los V7 no, de manera que volveré a publicar la reseña una vez que puedan competir a igualdad de condiciones.
Lo importante es que, tanto los burson como los DEXA superan ampliamente a los operacionales de serie, y supongo que lo mismo valdrá para el resto de máquinas. Otra cosa importante es que los DEXA ya no se encuentran a la venta, o por lo menos yo no los he visto.
Dicho esto, es posible que para otros equipos de audio sean más apropiados los V7 vivid antes que los DEXA.
La prueba la realice con un preamp audio research ls16mk2, etapa ALEPH J (25w pura clase A SE), sonus Faber electa amator mk1. He usado un EVERSOLO dmp a6 con upgrade de fuente PSU lineal como streamer y un sencillo lector marantz CD 6006 UK edition como unidad de transporte para CD
A H.
Easy to use
Perfect fit and nothing breaks after resoldering and reclamping a Canare cable. High quality.
A H.
Connecteur USB-C 3.0 Mâle Plaqué Or DIY Ce connecteur USB-C mâle vous permettra de concevoir vos propres câbles. Ceux-ci profitent de contacts plaqués or côté connecteur USB-C et de...
Easier to use as it seems
I use this between my dc cable and the iFi iDefender, so only the dc is connected. Although this usb is very tiny, soldering the wires and putting the plug together was easier than I initially thought it would be. Use heat shrink tubes to finish it.
Désiré A.
VIBORG VF501G Connecteur IEC C15 Cuivre Pur Plaqué Argent / Or Ø19mm Noir Ce connecteur IEC C15 Viborg VF501G est idéal pour la conception et l'amélioration de câbles secteur hautes performances et de grande...
A marié avec le câble secteur de votre choix, ce connecteur IEC va faire le travail avec perfection.
Je recommande vraiment un changement par rapport à des IEC no name.
Il y a mieux mais c'est déjà un minimum.
Je recommande ce produit à 100% par rapport à un connecteur basique.
