Sandy G.
EXCELLENTE REVELATION.
Je l'utilise avec ROSE RS 150 B en mode drive , ou avec mon 3D NANO LAB PLAYER SIGNATURE' en mode drive lui aussi....
Denis K.
Très bon!
Un son de très bon niveau dans un tout petit boitier!
La clarté de la reproduction sonore est épatante pour le prix de cet...
Gerrit G.
Very good DAC , BUT .....!
The USB A to C cable that comes with it is only good for powering the davice , not for data transfer . If used for data ,...
Avis clients - Il y a 19040 avis.
Laurent D.
the best of FURUTECH FT-SWS NCF (R)
rien a redire prise de tres haute qualité avec une réel amélioration dans l'ensemble du spectre sonore ...tres bon de conseil de l'equipe d'audiophonics et un merci pour son geste commerciale Cdlt......
Ricardo S.
QUALITY Power Adapter :)
This a fantastic, quality heave built cryogenic power adapter that delivers upon his specs.
It's definitely improve the sound quality of my Meridian highly resolving stereo system.
Highly recommended, specially for the price, it's definitely a no brainer!
Ricardo S.
Mean machine!
What a really good ergonomic and quality wire cutter, specially for cable finishing. For the price is a no brainier!
Ricardo S.
Perfect power tester
This accessory is perfect for testing your power distribution circuit, giving you the change for your self to make sure everything is built according to the electrical code!
Ricardo S.
Very good quality and well though trough accessory.
This is a very good quality built heavy bras with gold plated accessory. perfect for 6 plugs + earth box connection + incoming IEC plug C13 or C19 (in my case) connection. Very happy and satisfied with the quality and though around the built details, specially the incoming connection for the incoming IEC power plug connection.
Ricardo S.
Fantastic DIY power distribution case!
This power distribution case is of really high quality, precision built with really good solid and heavy aluminium and very good quality paint, and straight forward to built. Highly recommended.
Patrick C.
Magnifique
Après avoir l'avoir connecté sur mes deux Cabasses Brik 235 M7 de 1983, quel bonheur de découvrir la transparence et la profondeur d'écoute que développe ce magnifique SMSL AD18 et ceci dans tous les genres musicaux. Image Stéréo superbe. D'une simplicité d'utilisation quasi biblique, il fait tout ce qu'on lui demande avec brio, jusqu'à jouer le rôle d'une carte son sur le ProTools 12. Vraiment enchanté. A tel point que j'ai immédiatement souscris un abonnement chez Qobuzzzz....Et là, depuis, ce sont mes oreilles qui me disent merci.
Transaction avec AudioPhonics impeccable, livraison extrêmement rapide. Un tout petit bémol, le bouton de volume et d'accès aux menux paraît fragile sur son axe. Mais, comme tout peut-être fait de la télécommande, on n'a pas trop besoin d'y toucher. 5 étoiles largement méritées
jean claude g.
ters bon rapport qualité prix
très bon rapport qualité prix, livraison au top . Je recommande. JClaude
DAYTON AUDIO DC160-8 Haut-Parleur de Grave 50W 8 Ohm 86dB 30Hz - 4000Hz Ø16.5cm Le Dayton Audio DC160-8 Classic Series 6-1/2 peut-être utilisé comme un woofer, un midbass ou encore comme un petit subwoofer.
De belles basses
Utilisé pour une enceinte amplifiée à filtrage actif avec un ampli « WONDOM AA-JA32172 JAB 3-50 Module Amplificateur Class D avec DSP Stéréo 2x50W », ce HP fonctionne très bien. Les basses fréquences sont étonnamment belles et riches, pour le reste dans mon cas, le DSP et le tweeter font le travail.
Le DSP totalement paramétrable avec SigmaStudio est extrêmement appréciable.
Utilisé pour une enceinte amplifiée à filtrage actif, avec un Dayton DC160-8 et un tweeter de récup, de cela fonctionne très bien.
Thierry A.
VIABLUE QTC BLACK Pointes de Découplage Noir (Set x4) Les pointes Viablue QTC sont fabriquées en Laiton et les pièces soumises à pression (disque maître, peak) sont durcies à l'acier. Le diamètre d'une pointe QTC est de 30mm.
Très bonne facture mais
Ces pointes sont d'une très bonne qualité de fabrication pour un prix qui reste tout à fait abordable toutefois la longueur des tiges filetées fournies (M6) s'est avérée être un peu trop optimisée et il m'a fallu acheter de la tige filetée que j'ai coupé sur une longueur plus confortable pour obtenir une fixation stable sur 2 des 8 pointes placées sous mes Cabasse Galion IV.
Paul P.
WONDOM ADAU1701 Module DSP pour filtrage actif compact Ce DSP Audio SURE ADAU 1701 flexible permet de grandes possibilités de filtrage numérique et de traitement d'égalisation dans un format intégré très compact.
Grandes possibilités et petit prix
J'ai déjà posté un avis pour ce même article vendu avec sa carte fille RCA, j'en suis très satisfait. Je voulais juste préciser que le module que j'ai reçu comporte une horloge 12.288Mhz. Je le fais fonctionner en i2s output vers un module DAC PCM5102 (utilisant sa propre horloge).
Paul P.
petit dsp mais gros potentiel
Excellent produit pour le diy. Comparé à un mini-dsp, il faut un peu plus de patience et de connaissances pour le mettre en oeuvre (interface de programmation, cablage, sigma studio, etc...) mais la carte fille RCA permet de sortir du son rapidement pour tester ses filtres. En simple correction de réponse 2:2, ou en filtrage multi-voies il y a de quoi faire.
Pour ma part j'ai réussi à faire fonctionner 1 sortie i2s stéréo en plus des 3 sorties analogiques disponibles, en raccordant un petit DAC PCM5102 . Le son est clairement meilleur sur le DAC externe. Il me reste beaucoup de choses à expérimenter : entrée i2s, configuration de potentiometres ou encodeurs rotatifs pour modifier en live des parametres (volume, preset de filtres..) du DSP , plusieurs sorties i2s simultanées, test en 96kHz, etc... Pour le prix c'est parfait. Merci à audiophonics pour la mise à disposition d'explications de démarrage claires dans le blog.
Paul P.
WONDOM DB-DP11219 Module de Programmation SigmaStudio pour DSP Sure Wondom propose une carte de programmation compatible avec les DSP de marque Sure. Ce module s'avère indispensable pour programmer le DSP et gérer le traitement du...
interface compacte
C'est petit et ça fonctionne bien sur mes 2 pc portables sous windows 7 et 10 en usb 2 et 3 (programmation d'un ADAU1701 wondom). Merci à Audiophonics pour la page de blog avec guide détaillé d'installation de Sigma studio, dans mon cas il fallait effectivement installer les pilotes séparément pour que le module soit reconnu.
David b.
le rasberry
Raspberry 2 + kali + audiophonics td 1387 , le tout monté sur cette box. La partie vide me permet d'y mettre un poids afin qu'elle ne soit pas emporté par les cables. RAS
cedric R.
les polarités...
Bonjour, vous avez inversé les polarités sur l'image du site. attention!
DYNAVOX Câble de Modulation Jack 3.5mm - 2 RCA Stéréo Cuivre OFC Plaqué Or 3m Voici un câble Dynavox Jack 3.5mm vers RCA Stéréo, idéal afin de brancher votre lecteur portatif à votre amplificateur ou à des haut-parleurs portatifs.
qualité prix au top
Connecté avec un smartphone bas de gamme sur ampli marantz , résultat bluffant pour le prix . Très bon rendu , détaillé et naturel .
JB JFX Condensateur Axial Premium Met Polypropylène 400V 8.2µF Ces condensateurs audio JB JFX à l'étonnant rapport qualité/prix vous amèneront transparence et justesse à petit prix.
En remplacement sur un filtre d'enceinte Mission 761i , ce condensateur est parfait. Plus gros que celui d'origine, mais ce n'est pas la place qui manque.
Farfait
Jacques B.
Bon produit.
A un prix très raisonnable, cette terminaison est de bonne conception, de belle fabrication tant extérieure qu'extérieure et bénéficiant de très bons contacts en cuivre.
Jacques B.
Bon produit.
Robuste fabrication tant de la barrette, des prises schuko que de l'embase IEC. A recommander.
Pierre B.
Enfin une rallonge sans perte , ni mauvais contact.
Rallonge de tres bonne qualite, Assez legere, et flexible, et a prix interessant .Aucune perte de qualite, meme sur un casque a faible impedance (18 ohms). Il manque a mon avis , un manchon en caoutchouc aux connecteurs, afin d'eviter un rayon de flexion trop faible.
Pierre B.
Excellent cable blinde a prix interessant.
le cable est de bonne qualite, il est assez souple, malgre la section des fils (2, 5 mm2 ). Connecteurs de bonne facture. Il est tres efficace, a condition, bien sur d'avoir un filtre efficace en amont. A tres fortement reduit des interferences radio , sur des blocs amplificateurs mingda mc 845 C. . prix tres correct. Je le recommande.
Pierre B.
Excellent, et a prix tres interessant
Petit amplificateur casque en classe A veritable, bien construit, mais , sans fioriture. Assez puissant, tres dynamique, transparent, , bruit de fond imperceptible, capable d'alimenter sans probleme des casques a haute comme a basse impedance. Qualite sonore exceptionnelle . les plus petits details , comme les plus forts niveaux sont rendus sans distortion , ni coloration. Excellent rapport qualite / prix exceptionnel.
ASSOCIATION EXCEPTIONNELLE.
Mon dernier achat ( ampli audiophonics N CORE ) s'intègre au niveau des éléments suivants : récepteur Bluetooth CRS 8675, préampli audiophonics PGA 2310, et dac X3 Fx Audio. La restitution sonore se fait par le biais d'une paire de Q Acoustics 3020i câblée en Viard hd 12 et modulation canare. Les fichiers audios sont tous en flac hd. Que dire de la restitution: " exceptionnelle". Cet ensemble n'a rien à envier à des systèmes que l'on qualifie haut de gamme. Tout le spectre sonore est restitué avec une qualité surprenante. La tessiture des voix est riche en émotion. Les aigus files très hauts avec matière et subtilité. Tous les types de musique sont restitués avec une véracité surprenante. Le secteur grave n'est pas en reste. Il est surprenant non seulement par sa spontanéité, mais également par son exploration des infras graves. Bluffé par cette déferlante sonore, mon ami aux système haut de gamme, reconnaissait avec fairplay la qualité exceptionnelle de ces nouvelles électroniques.
Sandras Z.
DAYTON AUDIO ND105-4 Haut-Parleur Bas Médium Aluminium 30W 4 Ohm 87dB 60Hz - 10kHz Ø10cm Un haut parleur médium grave dans un format compact et robuste. Capable de produire des sons fidèles avec un impact dynamique important.
DAYTON AUDIO ND16FA-6 Haut-Parleur Tweeter à Dôme Soie Néodyme 10W 6 Ohm 88dB 3500Hz - 27kHz Ø1.9cm
DAYTON AUDIO DS215-PR Designer Series Radiateur Passif Papier 23.3Hz Ø21cm Les Radiateur passifs Dayton  DS215-PR 8"  sont conçus pour fonctionner de concert avec des hauts parleurs actifs qui auront un débattement Xmax proche...
PETIT PAR LA TAILLE,GRAND PAR LE SON
Le PGA 2310 a été comparé chez un ami à des préamplis ( Mark Levinson, Classé Audio, Bel canto, préampli passif schéma Sonic Frontiers). Grosse fut notre surprise de voir le PGA 2310 tenir la dragée haute à ces préamplis d'exception. La qualité des timbres, la dynamique, la définition, l'espace sonore tout était présent. Mon ami n'en revenait pas, bluffé par ce petit préampli qui paraissait minuscule à côté de ses appareils HDG. Notre conclusion était celle du titre. Petit par la taille mais grand par le son.
Philippe A.
fais le boulot
boitier commandé et arrivé très rapidement comme d'habitude avec vous. permet de visualiser un lecteur de laser discs en hdmi, le convertisseur fais ce qu'il peut, et selon le disque les résultats vont de passable à bien. simple à utiliser.
Thierry B.
nickel sur mon caisson
reçu rapidement, trs pratique pour la connexion du gros caisson HC
Jean-Christophe M.
Beau boitier mais impossible à travailler
Le boitier correspond très bien à la description belle finition rien à dire de ce côté là, le problème avec l'aluminium c'est q'un DIYeur du dimanche ne risque pas de monter quoi que ce soit avec il vous faudra faire appel à un professionnel tôlier ou métallier pour le perçage
Jean-Luc M.
Très bon câble de qualité juste la gaine un peut trop rigide,très belle qualité d'image et de son.
Jean-Marie A.
C'est une solution intéressante de correction acoustique
Commande et Livraison chez Audiophonics rapide et bien faite.
Le Dirac est simple (mais attention, précis pas à pas) à installer.
IL faut tout de même être à l'aise avec l'Anglais. La notice est sur le net et la site de MiniDSP est très complet pour explorer les possibilités de correction acoustique d'enceinte et de pièce, avec ce matériel. On peut récupérer un fichier fait avec Rephase ( en 1024 tags seulement et en 32 bits ce qui n'est pas mal) , ce qui est déterminant pour travailler la correction plus précise. L'ergonomie du logiciel de réglage est très bien.
seule chose que je regrette, est le manque d'un inter On/off externe, voire d'une liaison d'alimentation en 12 volts sur carte d'ampli par exemple. ET la télécommande pour driver sans l'ordinateur est en option en plus, il faut penser à l'ajouter à la commande. Bon produit qui fait l’essentiel et sans dépenser des sommes folles en matériel redondant.
Dirk S.
AUDIOPHONICS PA-S125NC XLR Amplificateur Stéréo Class D NCore 2x75W 8 Ohm Le Audiophonics PA-S125NC XLR intègre un module d'amplification de puissance Hypex NCore NC122MP. Celui-ci est une base solide pour construire un système HiFi...
perfect smal amp's
I use this amp's in the high / mid section of my active speaker
pierre c.
Produit conforme, bien fabriqué, malheureusement les délais affichés sur le site sont exacts(Environ 2 mois entre la commande et la reception).
Antoine E.
Mon ampli retrouve ses couleurs ! c est vraiment nickel, les les sont biens calibrées, ni trop blanches ni trop sombres!
c est re parti pour longtemps !
bon produit...
après avoir lu les autres avis je me suis lancé et il sont réellement amortissant. le visuel sur le cite ne le permet pas mais on peut en juger en les écrasant entre les doigts. pour des HP DIY c'est parfait ainsi que pour ma platine cd plutôt imposante ( sony 300 cd ) que je réutilise aujourd'hui grace à ces absorbeurs EVA. bon rapport qualité-prix.
Dominique L.
Coaxial canare
Excellent câble avec une bonne qualité de fabrication
Meilleur définition dans lespercussions et dans la tenue du grave
Rapport qualité prix remarquable j'aimerai pouvoir faire une comparaison avec des câbles beaucoup plus cher
Achat recommander
Elisabeth J.
Très utile !
Ayant remanié moi même mon circuit électrique, j'ai trouvé cet article très utile pour vérifier la réussite du montage de chaque prise.
Valery S.
EIZZ EZ-206 Connecteur XLR Mâle 3 Pôles PTFE Plaqué Or Ø9mm Rouge (Unité) Ce connecteur XLR EIZZ avec isolant PTFE permet la conception de câbles XLR symétrique de qualité. Sa finition plaquée Or et ses borniers à vis...
Belle connectique de qualité, ça faisait un moment sue je voulais essayer un produit sans soudure afin d'avoir "un intermédiaire" de moins, et le résultat est fructueux, sur le câble haut de gamme que j'ai dépecé (Burmester Silver) en enlevant ses prises de qualité soudées j'ai eu un petit gain for t sympathique à l'écoute :)
Valery S.
EIZZ EZ-206 Connecteur XLR Mâle 3 Pôles PTFE Plaqué Or Ø9mm Noir (Unité) Ce connecteur XLR EIZZ avec isolant PTFE permet la conception de câbles XLR symétrique de qualité. Sa finition plaquée Or et ses borniers à vis...
Valery S.
EIZZ EZ-206 Connecteur XLR Femelle 3 Pôles PTFE Plaqué Or Ø9mm Noir (Unité) Ce connecteur XLR EIZZ avec isolant PTFE permet la conception de câbles XLR symétrique de qualité. Sa finition plaquée Or et ses borniers à vis...
Valery S.
EIZZ EZ-206 Connecteur XLR Femelle 3 Pôles PTFE Plaqué Or Ø9mm Rouge (Unité) Ce connecteur XLR EIZZ avec isolant PTFE permet la conception de câbles XLR symétrique de qualité. Sa finition plaquée Or et ses borniers à vis...
nicolas s.
DYNAVOX Connecteur XLR Femelle 3 Pôles Ø8mm Noir (Unité) Ce connecteur XLR abordable vous permettra de concevoir des câbles de bonne qualité à un prix contenu. Il est par ailleurs habillé d'une...
Très bon matériel conforme à mes attentes
nicolas s.
Cezary C.
Plaque murale Aluminium embase Schuko pour FURUTECH FI-E30 Noir Nous avons conçu cette plaque murale tout en aluminium pour habiller l'embase Furutech FI-E-30 (G) et FI-E-30 (R) et ainsi la tranformer en prise murale complète.
Schuko for FURUTECH FI-E30
A great alternative, and the price ... I heartily recommend.
Dominique M.
Efficaces
Livrés en packaging avec la clé allen,serrage efficace,bon contact .Fait le travail que l’on en attend !J’espere qu’il s’agit réellement de cuivre doré.
Vismantas B.
TOPPING DX7s 2xES9038Q2M DAC / Préamplificateur / Ampli casque DSD 32Bit / 768kHz symétrique Noir Le Topping DX7s est un appareil polyvalent qui vous servira à la fois de DAC, préamplificateur numérique et amplificateur casque haute imépdance. Il...
best amplifier in 1500+ euro range , for only 500 eur:)
better what gustard a20h.
im using it with HD800S headphones +balanced cable
awesome combo !!! no need for tube amps... this amplifier delivers smooth midrange, clear highs, bass a little weak, boot acceptable,and 3D soundstage is very good. My best invested 500 euros :)
Mehmet B.
Very good. Thanks
I am very satisfied
Julien C.
Transfo sur mesure
Super service pour nos projets de tweak ou rénovation avec en plus beaucoup d options possibles (point milieu, écran...).
La qualité est très bonne avec dans mon cas aucun ronronnement audible ce qui est assez rare.
Dorénavant je ne passerai plus que par ce service bon marché en plus.
Les modèles « tout fait » audiophonics étant d après mon expérience (3 achats) un peu trop bruyant à mon goût.
Bravo pour ce service, j aimerais juste que les délais de production soient plus rapide (1 mois 1/2 c est un peu trop).
Julien
