Paul R.
Shanling EC3
David C.
Avant de...
Niels G.
Solid performer
Avis clients - Il y a 19681 avis.
Francis B.
ETI KRYO SPADES Fourches Cuivre Tellurium Plaqué Argent Traitement Cryogénique (Set x4) Ces ETI Kryo Spades sont des fourches haut de gamme utilisant des composants d'exception. Le conducteur est fait de Cuivre Tellurium plaqué Argent, permettant d'assurer une...
Formidable
ETI est une belle entreprise qui propose de très beaux produits à des prix raisonnables.
Ces fourches sont très efficaces pour ne pas gâcher le son d’excellents câbles quand on doit avoir une liaison fourche amovible rapidement. On peut visser fortement dessus. On gagne en transparence dynamique.
Panikos K.
FOSI AUDIO BOX X1 Préamplificateur Phono MM Le  Fosi Audio Box X1  est un petit  préamplificateur phono MM  simple, efficace et abordable. Celui-ci utilise des composants à faible...
FOSI BOX X1
Surprisingly good sound and build quality at such a low price.
It may not be as good as BOX X5 but at this price you can't ask for more. Perfect service as always from AUDIOPHONICS.
Peter H.
A clear upgrade over ~€200 power distributors
This is my first star wired power strip/distributor. I have previously used models from Supra, both versions with tinned copper wiring inside and the black models with silver plated copper. I have also used a Ludic Asgard (which I preferred over the Supra distributors). This Audiophonics power strip is head and shoulders better than all the previous distributors I have owned. It definitely sounds more like every device is plugged straight into the wall, ie every device has a more relaxed and effortless delivery of sound. In a normal power strip where devices are wired in series, all the devices interact with each other. I own two iFi AC filters, and if I plug them into the last two sockets on a normal power strip it dramatically affects the sound of the devices placed ahead of it in series. By using a star wired power strip, this interaction is minimized and everything clearly sounds better. I'm talking treble that is not as brittle and more pleasant, much better separation of sounds, and generally a slightly warmer more powerful sound. Basically, a cheaper power strip is a compromise that changes how devices work for the worse, whereas a power strip like this one allows every device plugged into it to work as intended without being affected by other devices plugged into the power distributor. Highly recommended. But why only 4 stars out of 5? Because mine arrived with loose screws inside. I opened it up and could screw them down without issue, and aside from the loose screws the finish and quality was impeccable both inside and out.
Eric H.
Au niveau sonore câble neutre, fidèle et sans coloration, qui ne rajoute rien aussi bien dans le grave que dans l’aigu
Artis R.
Pack Lecteur Réseau WiiM Ultra Gris + Amplicateur Audiophonics AP300-S250NC + Câbles RCA Audiophonics Wire 30cm + Câble Trigger Nous vous proposons un pack de produits WiiM x Audiophonics composé du Lecteur réseau Wiim Ultra, d'un amplificateur AP300-S250NC, d'une paire de câble de...
Good price performance
I would say a good combo which competes with more expensive integrated amps. There is a noticeable burn in period. At first there was a very high noise, which disappeared after few hours of listening.
Gregory P.
[GRADE B] AUDIOPHONICS HPA-S500ET Amplificateur de Puissance Class D Stéréo Purifi 1ET7040SA 2x500W 4 Ohm Produit reconditionné - Grade B L'amplificateur de puissance Audiophonics HPA-S500ET se dévoile avec une architecture Class D basée sur une paire de...
Parfait pour un ensemble TAD
Aucun "pop" à la mise en route ou à l'arrêt, le boitier reste tiède, et quel plaisir d'utiliser cet interrupteur (c'est bête, mais ça compte). En bref, très content d'avoir choisi les 1ET7040SA dans l'ensemble Audiophonics.
Michel E.
Fais le job
Câble digital entre une interface Hecate un Naim Dac, en bnc, pourquoi chercher plus cher alors que tout est devant vous, comparable a mon Vovox
Jean-Baptiste G.
SMSL SU-9 PRO DAC ES9039MPro XMOS XU316 Bluetooth 5.0 aptX-HD LDAC 32bit 768kHz DSD512 MQA MQA-CD Version mise à jour du SU-9, le SMSL SU-9 Pro reprend la base technique de son prédécesseur tout en procédant à une amélioration des...
DAC SMSL SU-9 Pro
Ce dak pour son prix ne m'a pas impressionné.
Tout Juste musical sans plus.
Je pense qu'il doit y avoir mieux où équivalent pour moins cher.
Un peu septique je ne recommande pas forcément ce dak dans cette gamme de prix.
Krzysztof K.
PANGEA PREMIER SE MKII Câble HDMI 2.1 Cuivre Cardas Plaqué Argent 8K 60Hz / 4K 120Hz HDR 48Gbps 0.6m Avec le Pangea Premier SE MKII, vous profitez d'un câble HDMI 2.1 de très haute qualité, permettant une parfaite transmission du signal entre vos appareils....
Good HDMI Cable, indeed!
Hey, folks!
Actually, sometimes differences in the sound of digital cables are bigger than in analog ones.
I can recommend this cable. Sounds really good. Connecting Singxer SU-6 to Audio-gd R-1NOS. Comparing to Audioquest Cinammon - Cinnamon is worse. Sound from Cinnamon is muddy, gray and flat. No saturation and no detail. Pangea sounds open and airy with good amount of detail and perfect saturation.
Minus one star for stiffness! This is not elastic cable.
Sound sample - all system elements is description.
HEADPHONES ON!!!
Urtsua R.
MUNDORF MR10 Résistance film métal non inductif 10W 2.7 Ohm Contrairement aux résistances classiques, les résistances à bobine & film metal n'ont pas d'inductance résiduelle. Ainsi, dans les cas où la réponse impulsionnelle est...
Fine
R. R.
Audiophile grade +
I use the connectors to complete satisfaction, they sound better than anything I've used before. I have them in combination with KLEI Perfect Harmony RCA sockets.
// They solder great, but be careful, if you don't know how to solder, you can ruin them just like any other connectors. //
Thierry C.
SHANLING ONIX ZENITH XST20 Transport CD / SACD / MQA CD Sanyo HD870 Avec le Shanling ONIX Zenith XST20, Shanling dévoile son nouveau transport CD très haut de gamme, alliant un design luxueux à des composants de pointe. Son...
Shanling reconnait enfin que ce lecteur n'est pas Gapless, sinon c'est un très bon lecteur CD/SACD
https://www.head-fi.org/threads/introducing-onix-zenith-xst20-high-end-sacd-transport-with-true-dsd-output.976312/post-18762663
And yes, we will be deleting the mention of Gapless SACD from our marketing materials. It was already adjusted in the texts, graphics should be done shortly after.
The marketing materials are created based on information from the engineers and the product manager. XST20 was indicated to support gapless for both CD and SACD.
Frédéric A.
NEOTECH NEP-3001G Câble Secteur Cuivre G-UPOCC Graphène 3x5.2mm² Ø16mm Le NEP-3001G de Neotech est un câble secteur incorporant 3 conducteurs composites G-UPOCC, combinaison de cuivre OCC et de graphène. Ce nouveau conducteur marque...
Excellent mais...
Ce câble offre une balance tonale équilibrée. Mais associé à l'amplificateur Audio-gd Master-3, il manque de présence dans le haut du registre, un peu d'éclat, bref. Ce n'est pas que le rendu n'est pas impressionnant. Le médium est fouillé, l'image stéréo large, la basse profonde et généreuse. Peut-être est-ce un manque de rodage, le câble à environ 230h au compteur. Je n'ai pas renoncé à l'intégrer à ma chaîne puisque je le considère tout de même excellent. A suivre.
Hans V.
Perfect passend voor infinity Kappa
Gezien de Infinity Kappa op de achterzijde in originele bezetting maar hele korte terminal pluggen kan gebruiken ben ik op deze uitgekomen.
Goed soldeerbaar.
Zelf ben ik gek op het geluid van zilver, in hoeverre dit hoorbaar is bij deze plug weet ik niet.
Ze klinken in elk geval zeker niet schel.
Krzysztof K.
AUDIO-GD R-1 NOS DAC Discret R2R DSP FPGA USB Amanero HDMI I2S 32bit 384kHz DSD512 Noir Le Audio-GD R-1 dans sa version NOS profite de nouvelles fonctionnalités ainsi que de certaines améliorations, dans le but de fournir une restitution sonore...
Incredible DAC!
OK, cons first:
1/ clicking sound on digital coax cable connection when you switch from one sample rate material to another also from PCM to DSD.
This issue is not present on HDMI/I2S cable connection. Strange.
2/ Ridiculous burn-in time. DAC straight from the box sounds like broken one. Muddy, unclear, unpleasant. And all of this despite 100 hrs factory burn-in. I would send it back to seller, but before the purchase I made deep online research and all R1NOS users advised long burn-in time: minimum 600 hours. So I gritted my teeth and gave this DAC a chance and time to spread the wings.
It was real rollercoaster. One day DAC was sounding OK, another day excellent, next day - really poor.
But after approx 400 hours of burn-in sound started to be more stable and after 610 hours - just incredible!
Anyway: I've purchased this DAC 12/4/2025 and I'm able to use it normally just since yesterday: 21/7/2025. 600 hrs of burn-in is a MUST!
Now - pros:
1/ plenty of connection possibilities, including HDMI/I2S (best one!). Strongly advise to use this one! You will avoid clicks and the sound is definitely best.
2/ SOUND!!! Just unbelievable! Sweet, refined, rich, saturated, airy, delicate, nuanced, crystal clear. My system sounds like minimum 50 000€ stack and I paid in general approx 7000€ for all (some elements new, some second hand). Detail? Well... this is not delta/sigma. If you want detail, buy ESS. There will be detail, but there will be no music at all. This DAC is typical R2R - detailed enough. Anyway - for example articulation of guitar strings is fully satisfactionable.
I have just 2 things more to say:
1/ in its price this DAC is a STEAL!!! Totally non fatiguing yet absolutely crystal sound.
2/ this is cheapest Audio-gd DAC. If the price floor in this factory has so incredible quality, I would like to see the ceiling...
HIGHLY RECOMMENDED!!! (if you're happy to wait 600 hours)
Sound samples (all system elements in clip description):
HEADPHONES ON!!!
https://rumble.com/v6wi06o-dac-burn-in-is-over-.html
https://rumble.com/v6wi0rc-chinese-godfather-.html
https://rumble.com/v6wi1d4-leftist-waltz-live-.html
https://rumble.com/v6wj5au-big-in-japan-.html
Good job, Audio-gd! :)
Alain C.
NEUTRIK NL2FXX-W-S Connecteur Speakon Femelle Ø12mm Le Neutrik NL2FXX-W-S est un connecteur Speakon à 2 broches robuste, idéal pour la conception de câbles de qualité professionnelle. Celui-ci...
Semblent bien faites, pas encore utilisées
Belle qualité de fabrication, pas plus d'infos à partager pour le moment
Alain C.
FIIO BR13 Récepteur Bluetooth 5.1 QCC5125 DAC ES9018K2M aptX-HD LDAC 24bit / 96kHz Le FiiO BR13 est un récepteur Bluetooth équipé d'un DAC performant. POINTS CLÉS : Puce de réception Bluetooth 5.1 QCC5125 SBC,...
Excellent au delà de mes attentes
J'ai choisi ce produit pour améliorer mon Bluetooth actuel, avec les codecs LDAC et AAC pour Androïd et Apple, et aussi parce qu'il comporte un volume donc je peux directement attaquer mes deux amplis en mono.
Tout est vraiment mieux, la clarté du son, les basses, et la spacialisation a fait un bond en avant.
J'avais un correct Real Câble et j'ai clairement changé de catégorie.
Je vous le conseille, avec en plus ses entrées digitales ...
Frédéric R.
Absolument top!
Absolument top! Enceintes installées sans les pointes et sur support standard en plastique car une contrepointe perdu durant un déménagement.
Le son n’était pas bon, fade et sans profondeur. Même obligé de pousser sur les basses. Je me suis même demandé si mes enceintes n’avaient pas été endommagées durant les déménageurs.
Après installation de ces contrepointes, le son a vraiment tellement changé que cela en est incroyable.
Le son a du relief et de la profondeur à nouveau!
A recommander sans hésitation. Rapport qualité/prix totalement correct.
Transformateur Audio E-9912 600:10K (Unité) Ce transformateur E-9912 600:10k en permalloy peut être utilisé pour de multiples tâches. Vous pouvez par exemple vous en servir pour convertir un signal...
great for balancing
bought one for test, ordered 16 for the 16ch audio interface.
I use a modular system which puts out 21 Vpp maximum; so the audio interface has to be leveled down, too.
my mixer has RECORD OUT mono jacks, 10K there - and balanced 600 ohms to the audio interface; level down is 4 or -12 dB.
Frequency respone is great, goes down to 10 Hz and above 40 kHz;
distorsion I can't measure, not noticed.
Renaud D.
SHANLING M8T Baladeur Numérique DAP Amplification à Tubes 2xAK4499EX 2xAK4191 32bit 768kHz DSD1024 Bluetooth 5.0 WiFi Le M8T de Shanling est un baladeur numérique classieux ayant la particularité de proposer une amplification à tubes, vous permettant de toujours avoir...
Exceptionnel
Merci Audiophonics pour l'envoi rapide et soigné! en plus je ne m'y attendais pas , livré avec étui officiel :)
Sinon que dire j'ai eu pas mal de daps depuis 10 ans mais celui ci est clairement une merveille, précis chaleureux et si musical (le mode triode) je redécouvre mes morceaux favoris. jamais un DAP ne m'avait procuré autant d'émotions. J'ai l'impression que ma quête du DAP idéal est enfin accomplie.
Robert g.
FOSI AUDIO ZP3 Préamplificateur symétrique NE5532 Le Fosi Audio ZP3 est un préamplificateur symétrique se basant sur des AOP NE5532. Il offre une qualité de restitution sonore dénuée...
The sound quality is amazing for the money, the ZP3 sound is neutral without being too dry, transparent enough, with exemplary resolution for a the budget range. What I really like is the bass control and dynamics, especially on the hi-rez files that have a higher dynamic range. ZP3 presents the soundstage correctly, with correct positioning of the sound sources in space, without exaggerating or compressing the width of the stage, or the depth. This is almost on par with my E88CC unbalanced tube preamp - a mu-Follower configuration with capacitor output and mild NFB - except for the apparent 'naturalness' of the tones of natural instruments and human voices, otherwise the Zp3 has the edge on any other chapter!
On the audio tracks with a Dynamic Range more than 10, the modern recordings with avant-garde jazz, contemporary classical music or full scale orchestral works could sound 'scary' in a healthy impressive manner. Some music albums examples here, that I used to evaluate the SQ of my ZP3 unit:
- Mussorgsky: 'Pictures at an Exhibition'; Gürzenich Orchestra Cologne, Dmitrij Kitajenko; 2019 [Oehms]
- Mats Eilertsen Trio: 'Sails Set'; 2013 [Hubro]
- Jonathan Faralli: 'Percussion XX'; 1999 [Arts]
- Bach|Gubaidulina, Anne-Sophie Mutter: Violin Concertos | In Tempus Praesens; 2017 [Deutsche Grammophon]
- Aaron Copland: Orchestral Works CD1; 1996 [Decca]
My unit came with LME49720 opa factory installed, to my surprise, and I left it how it is, after briefly testing AD8599, which proved not to be on par with the LME chip.
This preamlifier is a keeper for those loving a neutral - studio like sound - transparent, decently detailed and dynamic sound, that faithfully reproduce the recordings as god as they are, and do not bother the lack of a volume control display. The remote set provided inside the package is quite handy, and works well from all angles, having enough power, like any decent remote.
Despite ordering my unit was was not on stock, the Audiophonics announcements, packaging and tracking service was exemplary: merci a vous !
My audio set consists in: custom balanced DAC with AKM4499; Fosi ZP3; Fosi V3 Mono x 2; 2way custom made passive 98dB sensitive speaker with Beyma 15LX60V2 low-mid driver and Beyma CD10 Nd compression driver in a Polish horn SEOS15 by Autotech, with 2-nd order crossover implemented with CD passive equalization.
Will give it 4 stars out of 5, because:
- lacking of a volume display
- it is advertised to allow the customer to easily swap the 2 output opamps, which in practice is almost impossible for a less skilled owner, as the black glossy acrylic decorative sheets from the L/R case sides are very hard to remove in order to reach the 4 screws of the aluminum side plates of the case (are attached with double-sided tape)
- on balanced mode, the volume control chip does enter in a kind of soft mute mode, especially when the unit is freshly started, a mute and un-mute sequence from the remote set being the cure. I do not find this normal, but it does not affect the SQ so far after the 'fix'.
Pascal H.
Demande technique avant vente , réponse reçue dans la journée
le service est très réactif et surtout de bon conseil.
Commande reçue très rapidement en point relais, le tout à un tarif très doux.
Merci à l'équipe Audiophonics,
SMSL A200 Amplificateur Class D Infineon USB HDMI ARC Bluetooth 5.0 2x70W 4 ohm L'amplificateur SMSL A200 est un amplificateur classe D intégrant deux puces d'amplification Infineon MA12070 pour une puissance de sortie jusqu'à 2x70W sous 4...
L'aspect de cet appareil est flatteur, vis à vis du prix. Certains adorent les Vu-Mètres ! Plus sérieusement, enfin un ampli avec une alimentation interne et un cordon secteur, ras le bol des amplis soi-disant puissants, mais alimentés par un bloc secteur externe et son petit câble coaxial. Le son est clair, plutôt doux, aucune stridence, aucune sifflante (voix de cantatrice sur les forte), impossible de déterminer que c'est de la Classe D, on pense plutôt à un ampli à tubes, mêmes qualités, mêmes défauts, extrémités de la bande passante très légèrement raccourcies, mais c'est insignifiant. Image très profonde, plus que large. La dynamique est raisonnable sans atteindre le niveau des stars de la Classe D, on privilégie le confort d'écoute. Aucune fatigue auditive. Je l'utilise sur des enceintes à haut rendement, les gros boomers sont plutôt bien tenus. Il est à noter des borniers plutôt sympas. Un appareil que l'on peut emmener partout, mais que l'on n'a pas envie de cacher, trop mignon. On apprécie également une vraie télécommande pour la partie préampli, volume, sources (et même tonalité).
N.B. : Attention ! La sortie subwoofer n'existe pas, erreur dans la présentation, point faible par rapport à des concurrents bien connus.
Marc C.
AUDIOPHONICS DIGIPI+I2S Interface Numérique WM8804G pour Raspberry Pi SPDIF I2S TCXO Cette interface Audiophonics DigiPi+I2S permet d'élargir la connectique de sortie d'un Raspberry Pi, en lui conférant un panel de sorties audio numériques...
Utilisée en roon endpoint avec Riopeee, il faut choisir da
Marc C.
Vraiment bluffé !
Packaging sérieux. Utilisés en XLR et rien à redire...
Si le prix ! Un double mono à ce prix, c'est purement impossible de trouver ailleurs. Et la qualité est bien là.
Marc C.
Très étonné !!!
Je cherchais à connecter ma paire d'enceintes frontales à la fois pour mon système hifi et pour mon système A/V. Au début j'ai été dubitatif quand à l'achat de cette petite boite, n'aimant pas trop multiplier les connections entre les électroniques et les enceintes. Puis je me suis laisser porter par les autres avis.
Bien m'en fait puisque cette boite de répartition apparait bien transparente... enfin à mon oreille. Allez-y c'est du bon.
Merci à Audiophonics pour ce produit.
David S.
impeccable
Conforme à ma spécification un peu complexe: 0-11-22-40V et un second enroulement 0-4V: le tout très bien repéré et dimensions conformes au configurateur.
Délai un peu long, mais c'est du sur-mesure.
Mon vieux transport CD Audio Note dont le torique vibrait un peu trop ces derniers temps est de nouveau bon pour le service.
Merci Audiophonics!
Richard P.
Naturel
Je l'ai comparé à l'Albedo et bien pour moins cher il légale voir le dépasse si vous aimez un spectre moins montant qui apporte plus de détails mais moins de naturel. D'où mon titre naturel. Le bon équilibre pour mon système et mes oreilles !
Yannis G.
Petit mais costaud dans le haut grave et medium aigu
Mon 2 ième achat pour un ami qui l'utilise pour ses enceintes 3 voies diy monter par lui même en multi amplification il l'as utilser sur son medium 18 Sound 8NW650 et aigu beyma hd1030 parfait pour les fréquences haut graves et aigu , les borniers sont pitoyables pour les branchements mais on peut pas en demander plus pour le prix .
Pierre P.
HATTOR AUDIO THE BIG Préamplificateur Passif / Actif Symétrique Takman REX OPA2134 Noir Ce préamplificateur passif de superbe facture embarque deux atténuateurs haute précision avec résistances à film carbone Takman REX AMRT,...
J'ai possédé son petit frère il y a quelques années.
Ce modèle actuel est toujours aussi bien fabriqué. Il procure une transparence exceptionnelle, surtout si l'on ne met pas en oeuvre la partie active.
Je le recommande totalement.
IBASSO AMP16 Module Amplificateur Raytheon JAN6418 pour DAP DX340 Argent Le AMP16 de iBasso est un module d’amplification spécialement conçu pour accompagner le DAP DX340 de la marque et offrir à ce dernier une...
Pour ibasso dx340
Ibasso amp16 change la DONNE LA QUALITÉ DE SONORITÉ EST SUPÉRIEUR SURTOUT SUR LE MODE TUBE HEUREUSEMENT QUE AUDIOPHONICS VEND CE PRODUIT VOUS POUVEZ ACHETÉ FACILE A INSTALLER VOUS AVEZ LE TOURNEVIS POUR LE MONTAGE
Arvydas V.
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 1.5µF La gamme Superior Z-Cap de chez Jantzen Audio se compose de condensateurs non polarisés haut de gamme, conçus spécialement pour l'audio afin de permettra...
A
Mohammed B.
Im Vergleich zu Mundorf CFC Spulen spielen die Mundorf nervöser härter heller und offener, aber die Jantzen spielen ohne Kantten weich und mit richtige Tempo und sind viel billiger als die Mundorfs
sehr zu empfehlen für Musik Genießer und Audiophieler.
Mohammed B.
Im Vergleich zu Classic WBT spielen die Jantzen Dnamischer offener
und mit mehr Druck im Bass aber die Standard WBT spielen sauberer und zurückhaltender und im Vergleich zu WBT CU Polklemmen spielen die WBT CU viel sauberer echter harmonischer mit super Bass widergabe.
Wer etwas mehr Dnamisch und offenheit braucht soll die Jantzen kaufen obwohl man bekommt die vollkupfer XANGSANE oder von Eizz hier bei Audiophonics billiger und klanglich viel besser.
Mohammed B.
die
audiophile und lässt keine Wünsche offen. Im Vergleich zu standard bzw Messingsteckern und andere CU Steckern von andere Herstellt spielen die Furutech viel realistischer und Neutraler.
Ich habe von Vibrog und Monus Audio ich finde Furutech viel besser
die Monos Audio spielen etwas gekünstelt und mehr Bass aber die Führutech spielen durchsichtiger und viel Realistischer ausgewogener und ausgeglichener.
Sehr zu empfehlen!
Für Musikanlagen die sehr zurückhaltend spielen nicht zu empfehlen.
Mohammed B.
Super Stecker und Top Preisleistung
die
Sehr zu empfehlen!
Mohammed B.
Super Stecker mit top Klang und preisleistung
die steckern spielen sehr realistisch warm flüssig detailreich angenehm
Sehr zu empfehlen!
magique
C'est ma 2e, associée aussi avec le vondita, sur le dac et c'est juste exceptionnel. C'est naturel, ouvert, détaillé et sans agressivité....
EXCELLENT CÄBLE
C'est le second que j'achète, la coupe a été un peu plus généreuse, 10 cm de plus (sur le premier, pas un cm de rabe), c'est appréciable sur un câble aussi onéreux. Et ça laisse plus de marge étant donné la section. Sur mon dac nuprime avec une FURUTECH FI-E46 NCF (G) et une FURUTECH FI-C15 (G), Il ne bougera plus comme sur mon intégré. C'est le câble le plus naturel que j'ai écouté. Cher, certes, mais juste parfait.
Tsvetan A.
AUDIOPHONICS AP300-M450ET Amplificateur de Puissance Class D Mono Purifi 1ET6525SA 1x450W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics AP300-M450ET, un amplificateur de puissance mono Class D basé sur un module Purifi 1ET6525SA. Cette version...
Simply outstanding!
I have bought the Purifi to use for my Monitor Audio Silver C350 center, which before was powered by the receiver (Marantz SR6015), i wasnt expecting much, but to be honest the difference is big, much clearer voices/effects in movies, and for music... everything is better - voices, highs, even bass is tighter. Now a new problem - the rest of the speakers are lacking, heh. I Recommend it for center speaker with two hands!
Bernard B.
FIIO BTR17 Amplificateur Casque THX-AAA DAC Portable 2xES9069Q 32bit 768kHz DSD512 Bleu Avec le BTR17, FiiO propose un amplificateur casque et DAC portable reposant sur une paire de puces ES9069Q pour la conversion numérique/analogique, prenant en charge un...
fiio BTR 17
Pas d'ataptateur secteur pour la recharge de la batterie, dommage.
Envoi très rapide.
Laurent G.
AUDIOPHONICS LPA-S450ET Amplificateur de Puissance Stéréo Class D Purifi 1ET6525SA 2x450W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics LPA-S450ET, un amplificateur de puissance stéréo classe D basé sur deux modules Purifi 1ET6525SA....
Petit mais super efficace !!
Je viens d'un Sugden pure classe A, je peux affirmer que cet ampli n'est absolument pas froid, bien au contraire, les basses sont bien présentes, très définies et tout le spectre est bien mis en valeur. Le plus remarquable est sa transparence, Il alimente mes focal 948 avec aisance, fluidité et subtilité et s'efface pour transmettre le meilleur de mon pré ampli eversolo A8 (branchement XLR). Une véritable réussite à son prix.
Alain S.
SOFTEARS TWILIGHT Écouteurs Intra-Auriculaires IEM Dynamique 16 Ohm 116dB 15Hz-40kHz Avec les Twilight, Softears présente des écouteurs intra-auriculaires dynamiques haut de gamme qui allient une légèreté et un confort de port...
Vous n'écoutez plus de la musique mais êtes au cœur de celle-ci et ça change tout .
A noter l'étonnant form factor qui permet de loger ces intra dans les oreilles de toutes dimensions.
Wiim Amp Pro
Nice dac amp (power dac) based on a TPA3255 chip + PFFB. The real added value of this amp is that it offers a parametric equalizer and we can therefore use the EQ optimized by Spinorama org for acoustic correction
Fiio BR13
En soi concernant le BT il fait son job. En revanche l equalizer paramétrique bug puisqu on ne peut pas le sauvegarder ( bug Fiio connu et non corrigé honteux !
Didier T.
Mitigé...
Serties (et non soudées) sur du Ludic Silenos (2,5 mm2 multibrins), elles m'amènent aux constats suivants :
- un excellent "grip" une fois insérées dans les borniers femelles qui assure un excellent contact sur la plus grande longueur insérée
- un sentiment de relative fragilité provenant de la finesse du matériaux : si elles n'ont pas vocation à être manipulées régulièrement, certains câbles qui rigides ou lourds peuvent mettre à l'épreuve leur solidité
- un impact sur l'équilibre sonore empreint d'une certaine forme de "maigreur aigrelette" de timbre : cela me donne le sentiment d'une transparence factice, confinant dans certains cas à un peu de dureté
En fin de compte, elles ne sont pas restées en place.
Thierry H.
XDUOO XQ-50 PRO2 Récepteur Bluetooth 5.1 QCC5125 aptX HD LDAC DAC ES9018K2M xDuoo propose avec son XQ-50 Pro2 un excellent récepteur Bluetooth, simple d'utilisation et performant, qui vous permettra de transformer votre installation audio en...
upgradable
J’ai acheté la version précedente XQ-50 pro ( tout court ! )dont le pro 2 semble être le frère jumeau il y a 5 ans , très bon appareil , récement j’ai eu l’idée de l’ouvrir : comme sur le xDuoo xd05 basic v2 , l’AOP de sortie est sur un suport dip tulipe , donc facilement interchangeable !
Avec un opa 2134 le xq50 pro devient vraiement très très bon
Bruno R.
DD TC01BF Adaptateur USB-C Mâle vers USB-B Femelle Plaqué Or L’adaptateur TC01BF de ddHiFi se compose d’une part d’un connecteur USB-B femelle et d’autre part d’une connecteur USB-C mâle. Il assure une...
Semble OK
Contrairement au précédent acheté sur amaz.. celui-ci ne semble pas du tout affecté le transfert des données (donc le son) entre mon ordi Qobuz et mon DAC.
Belle finition, bon produit.
Radek P.
neotech nei 1220
Félix M.
6P1 Tube pour Amplificateur / Préamplificateur (Unité) Ce tube 6P1, durable et fiable, vous permettra de remplacer un modèle similaire défaillant ou bien de concevoir un amplificateur / préamplificateur à...
TUBO 6P1
LES TUBES ONT BIEN FONCTIONNÉ MAIS LE COLIS EST ARRIVÉ TOUT CABOSSÉ ET CASSÉ JE NE SAIS PAS COMMENT ILS ONT ÉTÉ SAUVÉS, MAUVAISE MANIPULATION DU COLIS MÊME S'IL ÉTAIT BIEN EMBALLÉ.
