Marcus L.
Michael M.
Worth every penny!
mathieu l.
Avis clients - Il y a 20137 avis.
Marc F.
Fibre optique Toslink SPDIF Connecteurs métal et gaine 1.8m Ce câble fibre optique Toslink tout est indiqué pour le branchement d'un DAC, d'une interface USB vers optique ou d'écrans plats et TV demandant une transmission digital de...
Acheté pour relier mon Player Freebox à un DAC et avoir ainsi un son de TV digne de ce nom, ce câble est très bien fini et semble durable. Quand est-il du son ? Je n'ai pas d'éléments de comparaison, mais formant un tout avec un DAC SMSL PS100, un bon ampli vintage et une paire de petites biblios réputées, c'est la joie !
Herbert N.
MUSICIAN PEGASUS II DAC R2R Discret Symétrique 32bit 1536kHz DSD1024 Noir Le Musician Pegasus II se présente comme un DAC magnifique et particulièrement performant, profitant d'une architecture R2R soignée. Intégrant les...
What a great DAC
With my Pegasus II you can now assume that my device has completed the warm-up and I have to say, I am more impressed with the sound of this DAC than ever before. The sound is full, full of dynamics, great transparency, I don't notice any of the supposed slowness... I can't say which DAC/preamp combination sounds better, our Gustard R26 with the integrated preamp or the Pegasus II in the office the Aune S17Pro as a preamplifier. I also can't fault the resolution compared to the R26. Maybe it's my other devices, i.e. the entire hi-fi chain, which has a very positive effect on the Pegasus II here in the office, but in any case it's really absolutely great here. It copes better with all acoustic music than the Gustard R26, and the voices are perhaps a little better. The R26 is perhaps a touch more relaxing than the Pegasus because it has such a certain consistency across all genres of music.
I also considered the Topping DX9 because it is a promising all-in-one device and tried it at home. I didn't like the DX9 at all with the integrated preamp, but with the Aune S17pro as a preamp the DX9 was like a replacement, downright terrific. Breathtaking dynamics, extremely clear, only a slight lingering of the higher frequencies bothered me a bit, but otherwise really great. In the meantime I had already ordered the Pegasus and delivery was on the way. I also have to admit that I would only have kept the Topping DX if I didn't need an external preamp, because then the combination for the office would have slowly become an expensive investment.
A little thing: I had to look a little for settings for the I2S input because the standard pin assignment didn't match the SD-9 from SMSL, but you can change that with the NOS button (if anyone wants to know).
I'll probably try one more thing, namely I read about the tip to replace the micro fuses, which should open up the sound even more. I'll try it, but from my point of view that wouldn't be necessary, as I'm already taking measures in the other direction to tame the transparency and resolution a bit. I find poor sound recordings to be a little more difficult to listen to on the Pegasus than on the R26. So I don't think I want the sound to be any more open and transparent, it's great.
Marc F.
SMSL PS100 DAC ES9023 USB SPDIF HDMI ARC Bluetooth 5.0 24bit 192kHz Le SMSL PS100 se présente comme un DAC abordable, performant et incroyablement polyvalent. Malgré ses dimensions réduites, le PS100 se base sur des...
Pour transformer le son d'une TV
J'ai acheté ce DAC pour améliorer le son de ma TV, à qui je peux ajouter désormais un ampli stéréo et des enceintes dignes de ce nom. Par Toslink ce PS100 décode le signal venu directement du Player Freebox, tout en étant sous tension grâce à une des prises USB de l'écran (pratique !).
Tout petit rikiki, donc discret, il n'en est pas moins richement doté en connexions. Surtout, question son, il fait plus que le job ! Etonnant pour le prix.
Je l'avais choisi un peu nez au vent, pour sa connectique et son prix, mais il confirme que chez Audiophonics il n'y a pas de mauvais produits. Je recommande !
Stéphane G.
TUNG-SOL 12AU7 / ECC82 Tubes (Paire Appairée) Le Tung-Sol 12AU7, fabriqué en Russie, assure un très faible bruit. Il a été conçu pour imiter les performances des tubes américains...
Paire de TUNG-SOL 12AU7/ECC82
Je viens de les monter dans mon préampli ART PRO MPA II, en remplacement des lampes chinoises d'origine.
A première écoute ces Tung-Sol sonnent très clair et aéré, avec une très bonne linéarité sur l'ensemble du spectre et d'une grande précision.
En revanche, je trouve qu'elles manquent un peu de coloration et de chaleur lors de la prise de voix, mais comme je viens de les monter, peut-être manquent-elles de rodage ou de préchauffage ? A voir avec le temps..
ELECAUDIO HP-25OFCS Câble Haut-Parleur Cuivre OFC Plaqué Argent Isolé PTFE 2x5.1mm² Ø7.5mm Le reconnu et réputé câble HP Elecaudio HP-25OCC revient dans une nouvelle version, toujours plus performante, le HP-25OFCS. Celui-ci reprend la même...
2eme avis
Les basses sont devenues plus propres et bien présentes. Ce câble nécessite un certain temps de rodage pour se placer...
Jose l.
IFI AUDIO IPOWER MK2 Adaptateur Secteur / Alimentation Audio Faible Bruit 12V 1.8A L'adaptateur secteur iFi Audio iPower MK2 permet de fournir à vos appareils audio un signal électrique extrêmement propre et stable. Cette nouvelle version...
très efficace
Je lui est mis une tresse de cuivre étamé de 10mm. Plus une en coton de 8mm. mais j'ai du couper petit a petit le plastique autour de petite ferrite avec une pince coupante pour les faire passer , une h.de boulot .Le résultat est au de la de mes espérances après 50h de rodage ,très contant un gros nettoyage du secteur comparer a l'origine .
yann j.
Belle qualité et fabrication impeccable. Pour le passage du son ou du signal, c'est juste parfait. Rien à en médire !
yann j.
IAN CANADA LINEARPI MKII SOLO Module Alimentation Linéaire Ultra Faible Bruit 5V / 3.3V / 12V 2.5A Le Ian Canada Linear Pi Solo MKII est un module d'alimentation ultra faible bruit délivrant un courant élevé de haute qualité, à la fois...
Achetée pour appliquer un principe énoncé par Mr. He Qinghua sur la pureté du son...
Cela alimente un SONOS port utilisé comme streamer. Il est connecté sur l'entrée 1 d'un Master 7. Cette configuration Insupportable avant le changement d'alimentation, Remplace maintenant avantageusement mon pc et sa liaison via usb avec Amanero combo 384. Cette configuration est nettement plus constante et fiable que celle utilisant le pc avec Fidelizer et d'autres logiciels onéreux soit disant high end.
Eduard V.
Great opamp.
Better than the NE5535 cleaner more details (not sharp)and better separetion between the channels .It,s great for that money .MVG Eduard
Eduard V.
Great opamp.
Change with NE5535 its cleaner and more detail .
István K.
IKKO LOT Adaptateur DAC USB-C Mâle vers Jack 3.5mm Femelle 16bit 48kHz Cet adaptateur et DAC Ikko Lot doté d'une part d'un connecteur USB-C mâle et d'autre part d'un Jack 3.5mm femelle. Il est notamment idéal pour vous permettre...
disappointment
Tested under Windows 10, Lenovo T14. It hums, heats up, and beeps slightly. The factory sound card is better than this.
Sergio C.
WIIM AMP Amplificateur Stéréo Class D TPA3255 WiFi DLNA AirPlay 2 Chromecast Bluetooth 5.0 2x100W 4 Ohm Gris Le WiiM Amp est un amplificateur connecté aussi compact que polyvalent et performant ! Il vous permettra de diffuser votre musique extrêmement simplement via DLNA,...
Excellent product
Very good all-in-one product, it ticks almost all boxes for my use case. One of the few on the market with a proper subwoofer out with lowpass/highpass filters. High-quality measurments reported by several testers.
Excellent performance/price ratio.
jérémy r.
Super ampli mais prix injustifié
Ampli de puissance utilisé 15 jours non stop. Très bon ampli mais comparé à ses petits frères (mp500 et nc252mp) la différences n'est absolument pas probante... Pour ma part j'ai préféré le renvoyer. J'ai trouvé qu'il manquait de vie par rapport à ses prédécesseurs. Les mesures c'est une choses, l'écoute une autre à bon entendeur.
Denis Gabriel G.
Incroyable ce "petit truc"
Acheté pour remplacer un Streamer ALLO Signature qui ne répond plus.
J'ai alimenté le WIIM Pro avec une alim linéaire Shanti et il part en coaxial dans un FDA QULOOS QA 690. ( je n'ai pas testé le DAC interne au WIIM Pro )
Paramétré en moins de 5 min avec QOBUZ en natif dans le WIIM (fini les prises de tête Linux du ALLO pour un non-initié)
Résultat : même qualité sonore qu'avec le Allo Signature qui tournait sous Volumio.
Après test : l'alimentation linéaire est indispensable pour optimiser le son.
Je n'en reviens pas qu'un tel "petit truc" de moins de 200€, hyper facile à installer, puisse être aussi efficace.
Ralf D.
Super Upgrade für meine Anlage
Ich muss jetzt auch mal einen kurzen Bericht schreiben.
Habe den Verstärker nach einigem lesen im Netz recht spontan bestellt. Er kam nach 2 (!!) Tagen zu Hause an. Dafür schon mal Danke, das war super schnell.
Und ich gebe ihn nicht mehr her. Die Auflösung gegenüber meinem alten Tripath ist nochmal eine ganze Klasse besser. Die Instrumente stehen noch klarer im Raum, ganz großes Kino. Ich betreibe sie mit einem paar Manger Wandlern. Diese stammen noch aus damaligem Selbstbau.
Michael F.
Michael
In alles Belangen eine absolut hervorragende Endstufe die auch weit über ihren Kaufpreis konkurrenzlos ist, eine Dicke Empfehlung !
Narcisse a.
Il en jette le bougre!
Monté en doublette bass reflex dans un caisson d'une quinzaine de litres et alimenté avec un DLS 2x200w, il encaisse sans broncher en offrant une basse ronde et dynamique. Il ne descend pas à 300 hz mais il pousse fort dans les 45hz et offre un grave détonnant dans cette tranche.
On est pas dans le SQL mais dans le démonstratif compact.
Il ravira les amoureux de basses percutantes en manque de place.
Hocine H.
Dévidoir Dérouleur Soudure et Support Fer à Souder Idéal pour vous accompagner dans vos soudures, cet accessoire se compose à la fois d'un dévidoir pour bobine de soudure et d'un support pour fer à...
Digne d'un kit bricolage pour enfant.
Déjà je l'ai reçu en pièces détachés, pas de soucis, mais il manquait le dérouleur. C'est très, comment dire sans être brutal, très léger comme fabrication, le fer à souder à tendance à descendre sur le support du fait de son poids car le serrage ne peut pas être optimal. Bref, si vous avez un petit budget ce sera bien,
Hocine H.
XANGSANE XS-6001AU SHORT Borniers Haut-Parleur Plaqués Or (Set x4) Les borniers pour haut-parleurs XS-6001AU SHORT de la marque Xangsane sont idéaux pour un montage sur boitier et/ou des enceintes avec une épaisseur de paroi de...
Très belle qualité.
Je commence à connaitre la marque, je la teste par curiosité et ces borniers sont indécents. En main ils sont lourds, le reflet noir bleuté est juste magnifique, mais surtout (ce dont j'avais besoin) la connexion avec les fiches banane se fait dans son intégralité et fermement, donc un contact optimal. Très facile à monter car le pas de vis de montage peut accepter des câbles de 4mm +, parfait pour recabler le cross over de mes enceintes avec les mêmes câbles que j'utilise pour les alimenter. Je verrai à l'écoute s'il y a amélioration, mais en tout cas le but pour moi était d'avoir une bon contact avec des viborg banane de 3.8mm. Esthétiquement le contrat est rempli et à 20 euros les 4, c'est offert. Je vous les conseille fortement.
Hocine H.
XANGSANE SP-6008AG Câble de Modulation Cuivre OCC Plaqué Argent Blindé Ø8.3mm Ce câble de modulation de grande qualité permet une excellente transmission du signal, et ce à prix abordable. Il se compose en effet de deux conducteurs en...
L'arbre cachant la forêt.
Acheté par curiosité, je n'ai pas été déçu, ce câble m'a donné le sourire tant par sa conception que par sa qualité d'écoute. COnnecté en symétrique avec des Neutriks SOM c'est un pur bonheur de clarté et de précision, peutêtre est-ce dû au phénoméne psychoacoustique ? Non je ne pense pas car cette qualité à ce prix c'est vraiment un cadeau. Foncez les yeux fermés et merci AUdiophonics de nous proposer ce genre de produits.
Serge V.
AUDIOPHONICS Q6 Récepteur Bluetooth 5.4 QCC3084 DAC ES9018K2M aptX HD LDAC Le Audiophonics Q6 est un petit récepteur Bluetooth combinant une puce Qualcomm QCC3084 ainsi qu'une puce DAC ES9018K2M. Il supporte les codecs aptX HD (24bit 48kHz) et...
super qualité audio 24bits 384 kHz
J'ai 3 modules TX/RX Bluetooth et celui ci fournit la meilleurs qualité audio et de loin. Un simple chargeur USB de tel est suffisant pour le faire fonctionner.
robert c.
Très bons connecteurs
Connecteurs parfaits avec l'avantage de ne pas avoir de soudure à faire . Ils sont très bien réalisés et robustes , avec un joli aspect , je recommande vivement .
robert c.
Super câble
Très bon câble utilisé en modulation , parfait entre une platine TECHNICS SL 1500 et un ampli MARANTZ SR 7008 .
Il mérite largement les 5 étoiles partagées avec nombre d'utilisateurs !
Michel V.
FX-AUDIO BL-MUSE-01 PRO+ Récepteur Bluetooth 5.1 QCC3031 aptX HD Pratique, le récepteur Bluetooth 5.1 FX-Audio BL-MUSE-01 PRO+ vous permettra de conférer à votre système audio HiFi classique une capacité de...
Correct
Bon produit pour son prix. Quelques petits décrochages de temps à autre malgré que l’appareil soit bien en vue et dégagé.
Je l’utilise pour la télé principalement.
Eric G.
E1DA COSMOS ADCISO GRADE B ADC Symétrique ES9822Pro 32bit 768kHz E1DA propose une version améliorée de son ADC symétrique high-end, le ADCiso . L'étage de conversion analogique/numérique se base toujours...
E1DA cosmos ADC premiers essais
Agréablement surpris , utilisation pratiquement instantanée sous Linux , mes premières mesures montrent que les spec sont réelles
et permettrons de faire des mesures correctes .
Merci à Audiophonics d'avoir été aussi efficace pour la prise en
charge et la livraison (Nickel)
JOSE N.
DAC ES9318C Lightning MFI Mâle vers Jack 3.5mm Femelle Hi-Res 32bit 384kHz DSD256 Cet adaptateur intègre d'une part un connecteur Lightning MFI mâle et d'autre part un Jack 3.5mm femelle. Il embarque par ailleurs un DAC ES9318C lui permettant de...
Utilité ?
Bonjour , est ce qu'une âme charitable peut m'expliquer l'utilité de DAC ?
Si je branche mon iphone avec ce dac et que j'écoute Apple Music et des morceaux codés en audio Lossless HQ 24 bits 192 khz , qu'est ce que cela change par rapport à un câble jack classique branché sur mon casque ?
luc f.
JANTZEN AUDIO ALUMEN Z-CAP Condensateur 100V 1µF Les condensateurs Jantzen Audio Alumen Z-Cap sont basés sur la série Silver Gold Z-Cap avec une présence tonale plus neutre et musicale. Cette série...
parfait!... livraison ultra rapide++++++++++++
Andoni G.
All perfect
I use them in a Macintosh 252 preamp, original box and no problems
Andoni G.
Good pack
It comes in a little plastic box with all the ítems we need for clean out conections. Superb
Rupert S.
HOT
It gets very hot and uses twice the energy the little Meanwell PSU uses. I frankly cannot heat much of a difference in my setup. Overall not worth it for me.
Audiophonics Hypex amp, EVO DAC, PMC TwentyFive.23
Petit cr
En remplacement du Mogami w3103, sur un ampli classe d 3e audio pffb, définition et ouverture supérieur tout en gardant le même timbre mais manque de basses fréquences.
Sur ampli a tube kt88, il lui est supérieur a tout les niveaux.
En résumé, ce câble est moins suave et "musical" que le mogami mais est nettement plus défini. C' est une affaire de goût et de combinaison système.
Je l' ai monté avec des fiches bananes elecaudio cuivre plaqué argent soudé avec mundorf suprême 10%.
Câble recommandable mais prochain test, ce sera du neotech occ ou mundorf angélique..
Cablage interne
Sensible aux câblages internes, veillez a l' équiper de bon conducteurs. Pour ma part, ces du elecaudio 2,5 mm2 occ ( alimentation et HP)Très bon résultat !
Christophe L.
FURUTECH FT-785M (R) Embase XLR Mâle 3 Pôles Cuivre Plaqué Rhodium Traitement Alpha (Unité) Ce connecteur XLR mâle 3 pôles FT-785M (R) utilise d'excellents matériaux afin de favoriser la conductivité du signal audio et profite du savoir faire...
En remplacement de la connectique Mini xlr acss audio GD entre un master 10 et un he7 r2r ladder dac. Cela permet de mettre un très bon câble ce qui n'est pas le cas avec les Mini xlr, tout simplement génial Au niveau sonore. Par contre il faut être un bon bricoleur l'opération est très compliqué. Je vais pouvoir mettre un furutech Das le top quoi mimi xlr on est très limité.
Trés bonnes pointes
Pointes trés efficaces, excellent résultat.
Cipriani M.
All perfect.
my congratulations to all the Audiophonics staff.
KONSTANTINOS L.
SMSL AO300 Amplificateur Class D MA5332MS Amplificateur Casque DAC CS43131 2x165W 4Ω 32bit 768kHz DSD256 MQA Argent SMSL dévoile avec son AO300 un appareil Hi-Fi polyvalent remplissant les fonctions de DAC, amplificateur et amplificateur casque. Puissant et qualitatif, il...
I didn't throw away my money
The amplifier has a very good performance. Excellent dac performance. Drives triangle titus, sennheiser 650 and audio technica m40x with comfort and clarity. Not the same good with audeze lcd 2c. I don't like it at high volumes, above 30, but it is very pleasant at medium and low levels, below 30 volume. Compared to smsl da9 it is better. Excellent buy for its cost. Over the years Smsl has become my first choice. Worth it.
Arend B.
High end device for low budget
This is really a great device with high-end sound for little money. Easy to assemble for anyone. Unfortunately four of the screws provided were not the right size, so I had to use my own. Therefore a star deduction. Conclusion: Absolutely recommended! Excellent!
Guillaume M.
Contrepointes Aluminium avec Anneau Caoutchouc 50x19mm Argent (Set x4) Ces contrepointes en Aluminium seront parfaite pour une installation sous des appareils HiFi (amplificateur, préamplificateur, DAC...) ou sous des enceintes, afin de...
Contre pointe
Très bonne qualité font parfaitement le boulot et ont un joli rendu
Francis T.
7HZ SALNOTES ZERO Écouteurs Intra-Auriculaires IEM Dynamiques Ø10mm Jack 3.5mm Les écouteurs intra-auriculaires 7Hz Salnotes Zero sont des modèles particulièrement abordables mais pour autant performants. Ils intègrent un...
très bien et pas cher c'est possible
J'ai choisi cet IEM d'après la base de données des réponses en fréquences du site Squiglink. La courbe des 7HZ Salnotes Zero se superpose parfaitement à la cible du casque Grado SR325e. Un model de référence pour moi en matière de neutralité. Le résultat est conforme aux prévisions. Ni boumi dans le grave, ni agressif dans l'aigu. Parfaitement plat au milieu et confortable. Si c'est bien un son HiFi neutre que vous cherchez, ne vous laissez pas influencer par le prix incroyablement bas pour cette qualité. À voir dans le temps pour ce qui est de sa longévité.
Alain M.
Module Symétriseur de Sources RCA / XLR Stéréo Ce module symétriseur stéréo permet de récupérer un signal asymétrique via ses entrées RCA sur bornier à...
Consommation de ce module
Vous annoncez une consommation de 200 mA pour ce module équipés de deux NE5532 !
Ca ne serait pas plutôt 20 mA ?
Je comptais faire l'acquisition de 2 de ces modules et les alimenter à partir des tensions annexes fournies par une alimentation SMPS300RE, soit une consommation de 400 mA ce qui me semble donc beaucoup.
Alexandre S.
Incroyable
Une bonne semaine que mon petit Za3 remue ma baraque.
Quel punch, une dynamique digne de beaucoup beaucoup plus cher. Même à moyen volume les basses sont retranscrites avec netteté et puissance, le corps vibre !
Une scène stéréo très ample, large, super détaillée.
Couplé avec un dac topping e30 pro II acheté un an avant sur ce même site, il anime soit une paire de jmlab profil 77 soit une paire de jmlab opal 706, les deux upgradees en MKP.
Bluffant, dingue, sensationnel, je manque d'adjectif. On est loins devant les premiers petits FDA et mini class D d'il y a deux ans.
J'ai changé pour essayé les OP amp d'origine par deux Oracle 2-02 pour pas cher, c'est une petite amélioration, notamment de la qualité des médiums mais ce n'est pas unnm changement transcendant.
Tamás G.
Symmetrical Class A
I bought a pair from this amplifier. I use a SMSL SU-9n as preamp and dac. I use xlr connector between the amplifier and DAC, and no other volume control. The two panel working in bridge. The power supply is Mean Well LRS-150-24 set on 20,8V, the output power 2x20W (calculated). I use Fischer SK 418-100 heatsinks, the temp is 60-62 degrees. I have removed the output condensers, so the output DC 10-20mV diference. No clipping when switching on. Powerfull dynamics, perfect frequenci response, no nois on output. The streo sound is wunderfull, incredible resolution. (I have other JLH1969, with condenser (Visai 2x2200uF low ERS+ Rubicon 6x1000uF low ERS + 7 x 10uF WIMA MKP), i think the output condenzer 20-30% kill the sound, primarily the bass). I use the bridge version with Fostex Fe206NV and FT17H in reflex box, 5000KHz crossover 6dB/dec, viablue SC2 speaker cable. Whit this amplifier and Speaker you can hear, a whole new side of your musics, sometimes to break down a wall...
Alexander D.
DD TC09S Câble USB-C Mâle OTG Argent / Cuivre OFC 50cm Le câble USB-C DD TC09S profite d'une conception parfaitement maîtrisée, utilisant des composants de très grande qualité afin d'offrir une...
très bon cable
très bon cable
Pedro V.
Great preamp tubes
Bought to replace tubes 13+ year Audio Analogue preamp.
New tubes are much quieter than the old ones (which are also the same brand). Sound quality seems to be improved as well.
Fast delivery and great packaging by Audiophonics!
Olgierd Z.
SMSL katastrofa
Je suis très triste après avoir acheté cet équipement SMSL AO300, pour ce genre d'argent, vous ne pouvez pas écouter de la musique, comment pouvez-vous produire un équipement aussi mauvais pour écouter de la musique. SMSL honte à vos ingénieurs
Xavier C.
DYNAVOX AUX-S PRO Commutateur Sélecteur Audio pour Entrées / Sorties RCA Argent Le commutateur Dynavox AUX-S Pro permet de commuter entre cinq appareils audio stéréo en entrée et deux appareils stéréo en sortie, sans avoir...
Bon Produit (2)
Avec une goutte d'huile dans les axes et quelques jours d'utilisation le défaut signalé a disparu.
Donc tout bon !
Ioannis K.
Very good quality product
Connected to pre out of my amp and delivers the signal to an headphone amplifier as also to a powered subwoofer (with 5m cable).It works without any noticeable problem.It actually seems as there is not exist in the chain! Great stuff.Absolutely recommended!
Hocine H.
Pureté
J'ai acheté ce câble sur les avis et aussi pour tester différentes configuration. J'ai monté ce câble avec des RCA Xangsane à visser et aussi à souder. Le montage est simple, la gaine se dénude facilement malgrés une légère rigidité et j'ai été surpris par les conducteurs et son cuivre épais. Le meilleur résultat a été avec les fiches à visser et à la première écoute j'ai émis un "putain" tellement c'était juste, aéré, pure (le câble n'est pas encore rodé). Tout est en place avec une belle synergie, ce câble agit comme un chef d'orchestre en ouvrant une scène sonore parfaite à mon oreille, pour ce prix c'est vraiment un cadeau. Foncez vous ne le regretterai pas.
Laurent T.
DD DJ65B Adaptateur Jack 6.35mm Mâle vers Jack 4.4mm Femelle Plaqué Or L'adaptateur DD DJ65B dispose d'un connecteur Jack 6.35mm stéréo mâle et d'un Jack 4.4mm symétrique femelle. Il vous permettra ainsi d'utiliser un...
Excellent adaptateur pour celui qui souhaite utiliser un câble symétrique, terminé par une Pentacon 4,4 mm (de plus en plus généralisée sur les DAP, et ampli casque/DAC) et le relier à une entrée jack 6,35 mm très répandue.
Je souhaitais pouvoir utiliser un câble, symétrique (avec terminaison 4,4mm ,haut de gamme, réalisé par un artisan) sur un ampli lampe OTL.
Mission accomplie grâce au DD DJ65B.
Qualité de fabrication excellente, matériaux de qualité et pas de perte ou d’altération sonore lors de son utilisation.
DDhifi est devenu la référence, me concernant, en termes d’adapteurs entre mes différentes terminaisons de câbles et mes différents amplis/DAC et DAP.
Je possède plusieurs adaptateurs de ce fabricant et tous me donne entière satisfaction.
Un dernier mot, sur le sérieux et la rapidité d’envoi d’Audiophonics: toujours au top, un grand merci !
Stefan N.
Eine super Endstufe!
Ich habe die Endstufe als Ersatz für die eingebauten Front-Speaker-Endstufen meines Denon AVC-6700H gekauft und bin begeistert. Super Klang und unerwartet wertig gebaut! Das Gehäuse wird bei mir - ganz anders als der Denon - nicht einmal warm, so effizient sind die Purifi-Module. Was ich nur nicht bedacht hatte: die eigentlich clevere Halbgröße bedeutet, dass man keine Standardkomponente obendrauf stellen kann. Ich wollte die Endstufe deshalb eigentlich auf die "oberste Ebene" stellen, musste aber feststellen, dass der bisher dort stehende BD-Player zu wenig tief ist ... Ich muss als erst noch ein kleines Podest basteln, damit diese tolle Endstufe nicht mehr neben dem Hifi-"Turm", sondern darin bzw. darauf stehen kann.
