Terrific cable
Tomasz C.
arnaud m.
Exelent
Avis clients - Il y a 19314 avis.
Damir D.
XDUOO TA-22 Amplificateur Casque à Tubes 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA xDuoo dévoile avec son TA-22 un beau combo amplificateur casque et DAC à la conception soignée. . Celui-ci embarque des composants de qualité afin de...
Beautiful, well-finished device, numerous connection possibilities and top-notch features.
Getting started is very easy. I had a little problem with mine unit because voltage switch at the back was placed at 110V instead of 220V when arrived. I didn't pay attention and burned the fuse.
After week of listening impressions are great. Mine Audeze LCD-2 sounded like never before. I can only compare this amp with Unison Research SH sound wise, but Unison lacks power to drive LCD-2 properly.
With this device max volume I needed (on most quiet recordings) was 45 out of 100.
I am pretty sure reviews that will come out will point that this device does not have perfect measurements and I can tell you, I don't care. I didn't by this amp to read charts and numbers but to listen to music.
It sounds great with stock tubes. In a couple of months I will probably replace them with other tubes (something like PSVANE 12AU7-S which you can buy at Audiophonics) , which will probably sound even better.
I am more than satisfied with this purchase, which I can recommend.
Andrew B.
IFI AUDIO iPOWER ELITE Adaptateur Secteur à Annulation de Bruit Active 12V 4A L'adaptateur secteur iFi Audio iPower Elite cache, sous son robuste châssis en Aluminium extrudé, une technologie de pointe permettant de fournir à votre...
Changé le son mais pas une amélioration pour moi.
J'ai utilisé cet iFi iPower Elite avec mon DAC exaSound e38 et cela a changé le son par rapport à l'alimentation à découpage fournie. Malheureusement, le changement n'a pas été une amélioration sur mon système, il a rendu le son très légèrement plus dur et a donné un peu moins d'air autour des instruments.
Après quelques jours, j'ai décidé de retirer l'iFi de mon système et de rester avec l'alimentation fournie par exaSound.
D'autres personnes pourraient trouver le changement de son de l'iFi bénéfique dans leur système, mais cela a fait pencher l'équilibre sonore de mon système vers un son légèrement trop dur et brillant.
Xavier G.
TOPPING E70 DAC ES9028Pro XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Noir Topping propose avec son E70 un DAC performant à la conception soignée. Un modèle capable d'offrir une restitution sonore riche et précise,...
Le summum musical !
Un appareil qui semble petit par sa taille mais qui s’avère immense dans ses prestations sonores. Tout d’abord, la qualité de fabrication est exemplaire, tout en métal avec des connecteurs solides. Le potentiomètre rotatif à cran est des plus agréable à l’usage. Le design est donc une totale réussite, avec une touche de rouge tout-à-fait bienvenue. Une fois, allumé, l’écran s’avère magnifique et surtout bien lisible en blanc. La réglage du volume est au quotidien un régal de précision et s’avère très précis et sans aucun décalage de volume entre les canaux. Une fois relié en XLR à l’amplificateur pour casque Topping L70 qui au niveau du design s’accorde avec lui à la perfection, c’est la claque sonore totale ! Il s’agit tout simplement du meilleur combo que j’ai pu entendre et peu importe le prix. Avec plusieurs casques Focal et Sennheiser, le résultat est toujours au top. Tous les qualificatifs habituels pour décrire précisément un signal sont de rigueur tant la retransmission est transparente. Ensuite, la sortie RCA connectée à mon système d’écoute composé de l’amplificateur Marantz PM 6005 et des enceintes Focal Aria 906, produit également un niveau de qualité rarement atteint ! Sinon, en mode sans-fil, je regrette simplement l’absence d’AirPlay ce qui aurait évidemment imposé une puce Wifi en plus de celle Bluetooth qui hélas propose une liaison qui dégrade forcément la qualité sonore. C’est quand même pratique pour y connecter rapidement n’importe quel appareil nomade. Le fabricant propose enfin des mises à jour du firmware ce qui est un très bon point. Bref, je recommande donc chaudement cette marque et cet appareil exceptionnel pour toutes ces raisons. Il procure un plaisir d’écoute sans précédant ! Bravo aux concepteurs !
Sebastien S.
Excellent 5 étoiles
+++ Câble SOMMERCABLE ONYX 2025 +++
Donne de l’aération et une douceur dans les notes sur mes enceinte Bibliothèque - Esprit Ez Comète + Panasonic SC PMX80 + Pieds amortissants Coupuréthane.
DAMIANO S.
Excellent product. At first the couple of Shuko/IEC with my Acoustic Revive cable sounded very harsh but after 2/3 days it became very smooth and extended. Cost is very high but I really recommend AAA+++
DAMIANO S.
Not easy to use
I really do not like this shear. It's very difficult to insert your cable, furthermore you risk to damage the cotton. I like cotton more than nylon sheath for damping features however the finish of nylon is better and fit better on the cable.
DAMIANO S.
Good tool to crimp your cable in the right manner. Easy to use and crimping is very well done. I prefer use naked cable but if you need to crimp your cable, it's the best!
cyril p.
Bonne finition
Fini bien un câble
cyril p.
Bonne finition
Fini bien un câble
cyril p.
Bon câble
Bon câble facile d'utilisation
cyril p.
De bonne facture pour ce tarif
Jon Y.
Solution intéressante pour calmer une électronique à sonorité agressive
Le Furutech Alpha Line Plus vient remplacer un Audioquest Tower entre mon préamplificateur et ampli casque.
Mon retour en quelques mots :
- Les graves sont mieux détourés, il y a moins de rondeur, c'est moins gras et ils deviennent plus impactants.
Ledit impact, plus propre et expressif qu'auparavant.
- Les médiums gagnent en définition ainsi qu'en détails.
- Les aigus ne sont plus du tout agressifs, ils s'adoucissent. Ils deviennent un peu plus chaleureux.
Le test sur "Pendulum - Come Alive" est révélateur (morceau très chargé en aigus).
La scène gagne en naturel.
Pas de sibilantes entendues, pouvant être présentes avec le morceau "Tango in the Night (2017 Remaster)" de Fleetwood Mac.
La différence de dynamique est notable, l'impact de la batterie est saisissante (toujours avec Fleetwood Mac).
Idem sur des morceaux électro (Grandson, Daft Punk), rock (Lenny Kravitz) et metal (Metallica).
Le détourage des instruments et la lisibilité est meilleure (perçu notamment avec "Are You Gonna Go My Way" de M. Kravitz).
Ces changements sont des plus appréciables pour mon système qui avait une tendance à sonner mou et fatigant avec l'Audioquest Tower.
En résumé, ce câble assagit les systèmes montants et fatigants mais n'enlève pas les détails. Il permettra aux graves de s'exprimer pleinement et librement.
On appréciera une belle lisibilité de la scène sonore notamment grâce au détourage des instruments.
Je le recommande !
Jon Y.
FURUTECH GT2 Pro Câble USB-A Male / USB-B Male 2.0 OCC 1.2m Ce câble USB est assemblé avec des connecteurs USB 2.0 plaqués or 24k non magnétiques et des conducteurs OCC plaqués argent α (Alpha). Le...
Un excellent câble qui donne plus de charme à la musique
Je passe d'un câble USB fourni avec mon DAC à celui-ci, le changement est radical !
Les graves ne sont pas ronds et envahissants mais puissants et maitrisés.
Les médiums ont davantage de "goût" qu'avec le câble de base. J'entends par là qu'ils sont plus texturés et agréables à mes oreilles.
Les aigus manquaient de vie et de présence, ils gagnent à présent en finesse ainsi qu'en clarté et sont plus aérés.
La scène sonore (même très chargée) fourmille de détails et reste très lisible.
Les conducteurs en argent apportent justement cette beauté des détails.
J'avais hésité avec l'Audioquest Carbon mais mon choix s'est porté sur le Furutech qui semble gagner en dynamique.
Sylvain p.
livraison rapide et soignée , hp conforme à la description
Jean Claude R.
Prèampli FX AUDIO
Rendu sonore bluffant,super basse extraordinairement profonde ,finesse et détail sont au rendez vous.Souci avec la paire de tube fourni défectueux ,problème rapidement résolue avec le SAV de AUDIOPHONICS, Expédition de deux autres tubes, sans frais le lendemain. Suivi et sérieux,au Top !!!!
Erreur flagrante
Je reviens sur mon avis précédent qui est erroné.
Erreur de branchements a l'arrière de l'ampli.
Donc après moult écoutes , ce câble est excellent.
J'avais un doute, car je n'ai jamais été déçu par Mogami.
Toutes mes excuses à ceux qui ont pu lire mon précédent avis…
Je recommande ce W3082 Mogami Câble
FURUTECH CF-102 NCF Connecteurs RCA Cuivre OCC Plaqué Rhodium Ø11mm (La paire) Furutech présente le connecteur RCA haut de gamme CF-102 NCF. Il s'agit du premier connecteur "signal" hautes performances de Furutech à être doté de...
De très beau connecteurs.
Ces Superbes fiches , sont de très belle facture, très bien construites (comme toujours chez Furutech, mais là on est un cran au dessus), montage facile, avec serrage de très bonne qualité par vis (clefs fournies).
chez moi elles sont montées en hybride, RCA/XLR sur un câble symétrique FURUTECH FA-αS22 Câble de Modulation PC-OCC .Ces prises ont étendu les extrêmes, avec beaucoup de finesse, et un accroissement de la définition, par rapport aux OYAIDE FOCUS 1 Connecteurs XLR , quelles sont venues remplacées, d'un coté seulement.
Jimmy H.
Incroyable !!!
Installé sur un Aune X8 Magic Dac...que dire, c'est le jour et la nuit.Une pure merveille.
stéphane g.
Incroyable, incroyable!!!
Viborg VE et VF 512 R pour les prises et ce câble entre les prises.
J'avais beau lire dans les revues spécialisées que de bon câble secteur permettrait d'améliorer la qualité du son. Je suis passé directement des câbles fournis par primare (ampli) et marantz (cd) vers ces câbles +prises que j'ai monté moi même.
In fine, une fois en place, c'est le jour et la nuit. Le son arrive enfin à remplir la pièce, beaucoup plus présent, en 3D. Comme ils disent dans les revues, un voile s'est levé. En fait, c'est vrai, vraiment, et c'est étonnant, pour le septique que j'étais.
Ludovic M.
DAYTON AUDIO UM12-22 Ultimax DVC Haut-Parleur Subwoofer 600W 2x2 Ohm 87dB 20Hz - 1000Hz Ø30cm Les subwoofers DVC de la série Ultimax de Dayton Audio sont spécialement conçus pour déplacer de l'énergie et créer des basses rapides...
Bonjour.
Comme d'hab livraison rapide et très bien emballé,
j'ai longtemps hésiter avant de commander le DAYTON AUDIO UM12-22
j'ai fabriqué un caisson de basse homecinema avec un amplis de 500w RMS LEDGE SVS pour mon DAYTON AUDIO RSS315HF-4 de 109l donc je l'es remplacer par le DAYTON AUDIO UM12-22 et la différence est incroyable beaucoup plus de puissance et des basses fréquences plus profondes au top content de mon achat
Pascal p.
SMSL SD-9 Lecteur Réseau WiFi DLNA AirPlay Bluetooth 32bit 384kHz DSD256 MQA Le SD-9 de SMSL se présente comme un lecteur réseau abordable et polyvalent. Il supporte en effet de très nombreux formats de fichiers et dispose d'une...
Avis mitigé
J'avais pris ce sd-9 pour le connecter en USB à un FDA. Malheureusement pour moi, ce fut la seule sortie à problème, pas de son.
Je l'ai testé rapidement en optique et coaxial, le son est vraiment très bon, précis et sans agressivité.
Le DD externe ainsi que la micro sd ont été reconnu immédiatement.
A noter, l'absence de certaines touches spéciales et monétaires sur le clavier, ce qui m'a posé un problème pour l'accès au NAS.
PS: je remercie Audiophonics pour son professionnalisme.
A tester
Câble installé une heure sur mon système.
Échec total, graves boursouflés et aigus très moyens.
Ne croyant pas au rodage des câbles vite retiré.
Cela dépend vraiment de chaque système et il faut essayer pour évaluer...
Albert L.
Performants, fiables et durables
Conducteurs audio performants, intégrant des composants de valeur sûre, réels atouts mécaniques, synonymes de fiabilité et durabilité. Câble d’une section correcte, souple, muni de connecteurs RCA de choix, assurant le contact parfait. Un ensemble, de qualité et solidité, qui correspond à la gamme de l’accessoire. Placé entre le préamplificateur et l’ampli de puissance, ce double RCA de modulation a contribué à une amélioration du système audio tout à fait surprenante. Un emplacement déterminant qui s’est traduit par une ascension dans la marge de progression de l’installation Hi Fi, à un niveau jusque là insoupçonné.
et je ne l'ai que depuis hier.....
je vous encourage a y jeter une oreille car pas rodé c'est déjà de la balle !!!
c'est meilleur que le dac intégré de mon lecteur cd hélios 1 qui certes a une bonne vingtaine d'années mais qui en comparaison délivre une sonorité plate...c'est meilleur qu'un audio gd 19 singularity en terme d'équilibre et moins systématique qu'un musician pegasus....et pour finir bien meilleur qu'un heed abacus...je ne l'ai pour le moment testé qu'en coaxial...la rencontre chine japon est pour moi une réussite !!!
Gorazd K.
SHANLING EC3 Lecteur CD ES9219C Bluetooth 5.0 LDAC 32bit 384kHz DSD256 Noir Le Shanling EC3 est un lecteur CD qui se distingue au premier coup d'oeil de par son format compact avec des mensurations de seulement 188mm de largeur pour 255mm et de...
CD ec3
This is my personal opinion. I have to admit that I am very satisfied with the CD ec3, especially the quality of the production is excellent, no plastic, only aluminum, even the round cover of the CD disc is made of tempered glass. As for the audio performance, the first impression is good. It also has coax and optical output so you can use it as a cd transport and connect it to your dac. I would also like to praise the fast and very good, safe packaging. In short, so far happy with everything.
Greetings, Gogo from Slovenia
Xavier G.
LINDY CROMO LINE Câble USB-A Mâle vers USB-B Mâle 2.0 Plaqué Or 2m La série Cromo regroupe les câbles USB les plus performants fabriqués par Lindy. Celle-ci mise sur une conception bien pensée et tournée vers une réalité technique, pour...
Vraiment superbe !
Voici un excellent câble dont la qualité de fabrication est impeccable et dont le prix est absolument imbattable étant donné le haut niveau de finition. Utilisé pour relier un ordinateur à un DAC, la liaison est tout simplement parfaite. Quand on pense que certaines marques célèbres et même encensées par les critiques osent vendre des câbles de ce genre à plus de 10 ou même 100 fois ce prix, imaginez le bénéfice colossal de l’opération… Leur marketing prétend évidemment de meilleur performance audio plus le prix augmente mais en réalité n’importe quel câble suffisamment bien construit suffit pour garantir un signal numérique bit perfect via la liaison USB. Quelques notions en physique et électronique suffisent d’ailleurs pour le vérifier et le démontrer. Quant à dire que les audiophiles sont pris pour des vaches à lait sans cervelle, il n’y a qu’un pas. Bref, vous avez normalement compris, ce câble est tout ce qu’il vous faut et en prime, c’est une affaire à ce tarif !
Tuomas E.
Bass missing
Works nice but sounds like it has a 12 dB highpass filter at 200 Hz. Not suitable for any system that is supposed to play bass.
benoit C.
AIYIMA TUBE-A3 PRO Préamplificateur à Tubes Stéréo 2x 6K4 2x AOP NE5532 Bluetooth 5.0 Noir Le Aiyima Tube-A3 Pro est un préamplificateur utilisant deux tubes 6K4. Il s'agit d'un modèle efficace vendu à prix abordable. Complet, il intègre un...
Déçu
Le pré ampli atténue le signal au lieux de l'amplifier et le son est distordu. J'ai fais plusieurs essais avec différentes source et différentes sortie (casque, ampli). Rien n'y fait. Les lampes utilisés sont celles livré avec. Il a été roder plusieurs heures . J"ai comparer avec le Douk Audio L1, les résultats sont bien meilleurs.
Autres inconvénient, a chaque mises en service il choisi par défaut l’entrée Bluetooth alors que j'utilise l’entrée "aux", Il faut donc re_selectionner la source a chaque mise sous tension..
Du coup je me sert pas de ce préampli.
Frederic p.
Surpris
J’avais des câbles de merde sur mon porte cellule,
J’étais septique sur la qualité du résultat sonore.!!
J’avais toujours un petit souffle un son étouffe et franchement après avoir changé les câbles plus clair plus d’impact…pour le prix top
Après jute bémol pour la connexion les cosses sont très petite j’ai dû les élargir pour les branches..
pjm k.
ATAUDIO POLARIS Câble USB-A Mâle vers USB-B Mâle Cuivre 7N OCC Plaqué Argent Quadruple Blindage 1.5m Le câble Polaris USB-A mâle vers USB-B mâle de chez ATAudio offre une très belle qualité de fabrication pour des performances optimales. On y...
usb
very nice cable
David P S.
IAN CANADA UCPI 2025 Module d'Alimentation à Supercondensateurs pour Raspberry Pi Le UcPi 2025 de Ian Canada est un module d'alimentation 5V à supercondensateurs haute performance et abordable, conçu spécifiquement pour les applications...
Agree with Clive S above: Ian knows his stuff
I had been having issues after a Roon infrastructure upgrade getting the same fantastic SQ I was used to on my main system. After trying a few RasPi digital transport hats that didn't do it, I reached out to Ian Canada via email for advice. He graciously responded the next day and suggested a transportPi Digi + this UCPi would solve my audio fidelity woes. Boy was he right! Got the TransportPi unit first and it was a huge improvement in the right direction. When the UCPi arrived 10 days later, wasted no time charging up the caps and installing. Bingo! This pairing along with upgraded clocks on the TransportPi does indeed deliver audio nirvana on a great system, it defies belief such bit perfect quality can be this affordable. Fun to play with the Pi units and wait for the next improvement to arrive, I just pretend I'm a 12 year old again waiting for the new parts of my nerd science kit to arrive! Thank you Ian Canada and Audiophonics.
David P S.
IAN CANADA TRANSPORTPI DIGI Module Interface Audio Numérique Ultra Faible Jitter Le TransportPi Digi est une interface audio numérique tout-en-un haute performance pour Raspberry Pi. Il propose une qualité de signal à très faible...
TransportPi Digi
Ian Canada is a great designer indeed! After a system redo I also needed to redo my Roon streaming infrastructure and had tried several types/brands of Pi transports, most were nice, but all were lacking in comparison with what I had going on before. Like the reviewer above, I finally got the TransportPi digi and upgraded to Accusilicon clocks as soon as I got the endpoint functional. Wow, finally the accurate sound with all the superlatives I was looking for again, and no more needing to maintain a pain in the a** Windows OS to have excellent audio quality again. Accuracy, detail retrieval and soundstage in spades. Wonderful audio quality that only makes you wish you had more time to listen. Thanks Ian and Audiophonics for the great customer service you provide!
Jean Claude R.
Déclencheur Audiophonic .
Le top pour piloter 3 amplis CROWN XLS classe D, bien inférieur a la puissance d'appel (démarrage temporisé ) prévue par le déclencheur d'alimentation malgré son pouvoir de coupure de 8 A.Pilotage par li trigger de mon préampli HC pionner SC LX 85. Nickel....A voir a l'usage dans le temps .
Xavier G.
TOPPING TCX1 Câbles de Modulation XLR 25cm (La paire) Les câbles TCX1 de chez Topping sont des câbles XLR mâle / femelle de grande qualité. Ils intègrent des conducteurs en Cuivre 6N et en Cuivre 6N...
Excellent câble XLR !
Ce câble fait preuve d’une grande qualité de fabrication ce qui laisse présager une grande robustesse. Il est cependant très rigide ce qui avec sa faible longueur ne permet de relier que deux appareils qui se touchent. Associé aux appareils de la même marque, il faut bien les mettre en forme sinon ils sont capables de les soulever ! Ainsi, il faut que l’appareil soit suffisamment lourd pour bien rester en place. Voilà pourquoi, si je devais refaire cet achat, je prendrais le même câble mais dans une plus grande longueur pour éviter ce problème et surtout pouvoir placer les appareils plus librement en cas de changement de configuration. Bref, je recommande pour la qualité malgré ce petit désagrément lié à l’installation.
Stewart L.
Minimal but high quality
This amp has everything I really need. Power seems solid, UI is adequate, and the fit and finish of the enclosure is high quality. Shipping to the USA was fast and very reasonably priced.
There was a small firmware bug involving the mute relays clicking that needed fixing. Audiophonics was prompt about fixing it AND about providing me with requested support to flash it in the field. (This issue should be resolved for new shipments according to Audiophonics.)
This amp is a great way to try out modern Class-D without breaking the bank or buying a bunch of separates.
Cyril M.
Enfin une machine qui fait de la musique!
Fan de la classe D depuis ses débuts et possesseur d'un ampli Gemincore, je me suis laissé tenter par la techno Purifi, après avoir lu les avis sur les forums et la revue sur audioscience.
Et bien je ne suis pas déçu! quel bond en avant au niveau de la restitution!
C'est d'une transparence et d'un équilibre extraordinaire.
Ce qui m'a le plus frappé, c'est la dynamique énorme avec des nuances extraordinaires entre les instruments et les attaques sont percutantes. Chaque instrument est à sa place dans la scène sonore et tellement bien défini qu'on peut se concentrer sur un et le détacher du reste. Et les timbres ainsi que les voix sont restitués à la perfection (on se surprend à croire que c'est de la musique live lorsqu'on est dans une autre pièce et on est attiré pour aller écouter en face des enceintes).
Bref je redécouvre mes albums, quel que soit le style ou la qualité d'enregistrement!
PS : l'ampli est couplé à un PC avec Quobuz / carte son studio (127 db de dynamique) en XLR, enceinte BW CM9S2 + Subwoofer ASW610 pour charpenter la restitution
Radek P.
TOPPING PA5 Amplificateur Symétrique Class D 2x125W 4 Ohm Argent Topping propose avec le PA5 un amplificateur symétrique compact mais pour autant puissant et très performant. Il intègre un circuit d'amplification Class D...
O.k.
I have 2 pieces connected as biamping. And it plays great. Preamplifier ADI-2 DAC FS.
Xavier G.
Excellente qualité !
Ces fiches bananes sont idéales et permettent une excellente connexion aux bornes de l’amplificateur et des enceintes. Il faut bien vérifier que votre matériel soit compatible cependant. La qualité de fabrication est impeccable et des gaines thermo rétractables sont même fournies ce qui permet d’habiller le bout des câbles. Bref, je recommande pour le prix modique.
Alain D.
Inetrupteur à Bascule Avion
Je suis ravi ! Les interrupteurs ont mis du temps à arriver mais ma patience a été largement récompensée! J' ai fait un tableau de commande électrique dans mon bar et le résultat est top! J' aurais bien partagé des photo mais je ne peux pas sur cette page... MERCI!
Stéphan B.
Module DAC pour Raspberry Pi 2x ES9023 24bit 192kHz Ce module DAC HAT vous permettra de transformer votre Raspberry Pi en véritable système audio haute qualité, sans vous ruiner. Celui-ci embarque un...
Son agréable
Monté sur un Pi 3 A+ sous moode player ce module a un son très agréable. Je n'ai pas de matériel de qualité suffisante pour en dire plus.
Il est livré avec une télécommande totalement inutile (et sans pile malgré une bandelette qui laisse croire le contraire). Pas envie d'acheter 3 piles bouton juste pour satisfaire ma curiosité.
Le point qui m'a fait retirer une étoile est qu'il n'y a absolument aucune documentation. On aurait pourtant bien aimé savoir comment piloter par logiciel les fonctionnalités que la télécommande laisse supposer. Ou tout au moins savoir quel pilote choisir dans la longue liste proposée par moode player.
Marek M.
Weights
A little flexible
suitable for light audio chains
R= 0,054 Ohm C=600 pF L=1,17 microHenry
Marek M.
high capacitance per meter ,low resistivity.
Marek M.
does not fit some bright headphones/iems.
unsuitable for high-impedance headphones. 100 ohm and more.
Marek M.
Adaptateur Jack 2.5mm Mâle vers XLR 4 Pins Femelle Neutrik Cet adaptateur symétrique à base de Neutrik se compose d'un connecteur Jack 2.5mm et d'un XLR 4 pôles femelle. Il profite d'une belle qualité de...
the connector on the xlr side is difficult to pull out
Marek M.
polarity weakly marked (+), adapter fulfilled its purpose
Nick P.
Very good service
The item is perfect , it is working as described.
Thank you for your perfect service once more.
Thomas H.
Excellent cable, excellent value. Extremely well constructed, and great fidelity.
Eric V.
NEUTRIK REAN NYS231BG-LL Connecteur Jack 3.5mm Stéréo Mâle Plaqué Or Ø8mm (Unité) Ce connecteur Jack 3.5mm stéréo mâle profite d'un belle qualité de conception avec un plaquage Or des contacts, favorisant la conductivité et...
Bon diamètre interne
Enfin une fiche mini jack bien construite pouvant être utilisée avec un câble épais, le tout pour un tarif démocratique.
Eric V.
câblage interne
Câble bien construit et relativement souple. Idéal et facile à utiliser notamment pour remplacer les câbles de liaison audio quelconques, dans un amplificateur par exemple, avec pour résultat un gain en dynamique et transparence.
